[ Upstream commit 6e050503a150b2126620c1a1e9b3a368fcd51eac ]
Cc: stable@vger.kernel.org
[ Upstream commit c6852389228df9fb3067f94f3b651de2a7921b36 ]
It could be done in exception-handling bits in __get_user_b() et.al.,
but the surgery involved would take more knowledge of sh64 details
than I have or _want_ to have.
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull final removal of deprecated cpus_* cpumask functions from Rusty Russell:
"This is the final removal (after several years!) of the obsolete
cpus_* functions, prompted by their mis-use in staging.
With these function removed, all cpu functions should only iterate to
nr_cpu_ids, so we finally only allocate that many bits when cpumasks
are allocated offstack"
* tag 'cpumask-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (25 commits)
cpumask: remove __first_cpu / __next_cpu
cpumask: resurrect CPU_MASK_CPU0
linux/cpumask.h: add typechecking to cpumask_test_cpu
cpumask: only allocate nr_cpumask_bits.
Fix weird uses of num_online_cpus().
cpumask: remove deprecated functions.
mips: fix obsolete cpumask_of_cpu usage.
x86: fix more deprecated cpu function usage.
ia64: remove deprecated cpus_ usage.
powerpc: fix deprecated CPU_MASK_CPU0 usage.
CPU_MASK_ALL/CPU_MASK_NONE: remove from deprecated region.
staging/lustre/o2iblnd: Don't use cpus_weight
staging/lustre/libcfs: replace deprecated cpus_ calls with cpumask_
staging/lustre/ptlrpc: Do not use deprecated cpus_* functions
blackfin: fix up obsolete cpu function usage.
parisc: fix up obsolete cpu function usage.
tile: fix up obsolete cpu function usage.
arm64: fix up obsolete cpu function usage.
mips: fix up obsolete cpu function usage.
x86: fix up obsolete cpu function usage.
As execution domain support is gone we can remove
signal translation from the signal code and remove
exec_domain from thread_info.
Signed-off-by: Richard Weinberger <richard@nod.at>
This may be OK in archs with contiguous CPU numbers and without
hotplug CPUs, but it sets a terrible example.
And open-coding it like drivers/scsi/hpsa.c is just weird.
BTRFS has a weird comparison with num_online_cpus() too, but since
BTRFS just screwed up my test machines' root partition, I'm not
touching it :)
Reported-by: Oleg Drokin <green@linuxhacker.ru>
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic
Pull asm-generic uaccess.h cleanup from Arnd Bergmann:
"Like in 3.19, I once more have a multi-stage cleanup for one
asm-generic header file, this time the work was done by Michael
Tsirkin and cleans up the uaccess.h file in asm-generic, as well as
all architectures for which the respective maintainers did not pick up
his patches directly"
* tag 'asm-generic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic: (37 commits)
sparc32: nocheck uaccess coding style tweaks
sparc64: nocheck uaccess coding style tweaks
xtensa: macro whitespace fixes
sh: macro whitespace fixes
parisc: macro whitespace fixes
m68k: macro whitespace fixes
m32r: macro whitespace fixes
frv: macro whitespace fixes
cris: macro whitespace fixes
avr32: macro whitespace fixes
arm64: macro whitespace fixes
arm: macro whitespace fixes
alpha: macro whitespace fixes
blackfin: macro whitespace fixes
sparc64: uaccess_64 macro whitespace fixes
sparc32: uaccess_32 macro whitespace fixes
avr32: whitespace fix
sh: fix put_user sparse errors
metag: fix put_user sparse errors
ia64: fix put_user sparse errors
If an attacker can cause a controlled kernel stack overflow, overwriting
the restart block is a very juicy exploit target. This is because the
restart_block is held in the same memory allocation as the kernel stack.
Moving the restart block to struct task_struct prevents this exploit by
making the restart_block harder to locate.
Note that there are other fields in thread_info that are also easy
targets, at least on some architectures.
It's also a decent simplification, since the restart code is more or less
identical on all architectures.
[james.hogan@imgtec.com: metag: align thread_info::supervisor_stack]
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Acked-by: Richard Weinberger <richard@nod.at>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Cc: Steven Miao <realmz6@gmail.com>
Cc: Mark Salter <msalter@redhat.com>
Cc: Aurelien Jacquiot <a-jacquiot@ti.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Jonas Bonn <jonas@southpole.se>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Helge Deller <deller@gmx.de>
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Tested-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Cc: Chen Liqin <liqin.linux@gmail.com>
Cc: Lennox Wu <lennox.wu@gmail.com>
Cc: Chris Metcalf <cmetcalf@ezchip.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: Chris Zankel <chris@zankel.net>
Cc: Max Filippov <jcmvbkbc@gmail.com>
Signed-off-by: James Hogan <james.hogan@imgtec.com>
LKP has triggered a compiler warning after my recent patch "mm: account
pmd page tables to the process":
mm/mmap.c: In function 'exit_mmap':
>> mm/mmap.c:2857:2: warning: right shift count >= width of type [enabled by default]
The code:
> 2857 WARN_ON(mm_nr_pmds(mm) >
2858 round_up(FIRST_USER_ADDRESS, PUD_SIZE) >> PUD_SHIFT);
In this, on tile, we have FIRST_USER_ADDRESS defined as 0. round_up() has
the same type -- int. PUD_SHIFT.
I think the best way to fix it is to define FIRST_USER_ADDRESS as unsigned
long. On every arch for consistency.
Reported-by: Wu Fengguang <fengguang.wu@intel.com>
We've replaced remap_file_pages(2) implementation with emulation. Nobody
creates non-linear mapping anymore.
While working on arch/sh/include/asm/uaccess.h, I noticed
that one macro within this header is made harder to read because it
violates a coding style rule: space is missing after comma.
Fix it up.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
virtio wants to write bitwise types to userspace using put_user.
At the moment this triggers sparse errors, since the value is passed
through an integer.
For example:
__le32 __user *p;
__le32 x;
put_user(x, p);
is safe, but currently triggers a sparse warning.
Fix that up using __force.
Note: this does not suppress any useful sparse checks since caller
assigns x to typeof(*p), which in turn forces all the necessary type
checks.
virtio wants to read bitwise types from userspace using get_user. At the
moment this triggers sparse errors, since the value is passed through an
integer.
As there are now no remaining users of arch_fast_hash(), lets kill
it entirely.
This basically reverts commit 71ae8aac3e19 ("lib: introduce arch
optimized hash library") and follow-up work, that is f.e., commit
237217546d44 ("lib: hash: follow-up fixups for arch hash"),
commit e3fec2f74f7f ("lib: Add missing arch generic-y entries for
asm-generic/hash.h") and last but not least commit 6a02652df511
("perf tools: Fix include for non x86 architectures").
Cc: Francesco Fusco <fusco@ntop.org>
Cc: Thomas Graf <tgraf@suug.ch>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Pull audit updates from Eric Paris:
"So this change across a whole bunch of arches really solves one basic
problem. We want to audit when seccomp is killing a process. seccomp
hooks in before the audit syscall entry code. audit_syscall_entry
took as an argument the arch of the given syscall. Since the arch is
part of what makes a syscall number meaningful it's an important part
of the record, but it isn't available when seccomp shoots the
syscall...
For most arch's we have a better way to get the arch (syscall_get_arch)
So the solution was two fold: Implement syscall_get_arch() everywhere
there is audit which didn't have it. Use syscall_get_arch() in the
seccomp audit code. Having syscall_get_arch() everywhere meant it was
a useless flag on the stack and we could get rid of it for the typical
syscall entry.
The other changes inside the audit system aren't grand, fixed some
records that had invalid spaces. Better locking around the task comm
field. Removing some dead functions and structs. Make some things
static. Really minor stuff"
* git://git.infradead.org/users/eparis/audit: (31 commits)
audit: rename audit_log_remove_rule to disambiguate for trees
audit: cull redundancy in audit_rule_change
audit: WARN if audit_rule_change called illegally
audit: put rule existence check in canonical order
next: openrisc: Fix build
audit: get comm using lock to avoid race in string printing
audit: remove open_arg() function that is never used
audit: correct AUDIT_GET_FEATURE return message type
audit: set nlmsg_len for multicast messages.
audit: use union for audit_field values since they are mutually exclusive
audit: invalid op= values for rules
audit: use atomic_t to simplify audit_serial()
kernel/audit.c: use ARRAY_SIZE instead of sizeof/sizeof[0]
audit: reduce scope of audit_log_fcaps
audit: reduce scope of audit_net_id
audit: arm64: Remove the audit arch argument to audit_syscall_entry
arm64: audit: Add audit hook in syscall_trace_enter/exit()
audit: x86: drop arch from __audit_syscall_entry() interface
sparc: implement is_32bit_task
sparc: properly conditionalize use of TIF_32BIT
Pull arch atomic cleanups from Ingo Molnar:
"This is a series kept separate from the main locking tree, which
cleans up and improves various details in the atomics type handling:
- Remove the unused atomic_or_long() method
- Consolidate and compress atomic ops implementations between
architectures, to reduce linecount and to make it easier to add new
ops.
- Rewrite generic atomic support to only require cmpxchg() from an
architecture - generate all other methods from that"
* 'locking-arch-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (23 commits)
locking,arch: Use ACCESS_ONCE() instead of cast to volatile in atomic_read()
locking, mips: Fix atomics
locking, sparc64: Fix atomics
locking,arch: Rewrite generic atomic support
locking,arch,xtensa: Fold atomic_ops
locking,arch,sparc: Fold atomic_ops
locking,arch,sh: Fold atomic_ops
locking,arch,powerpc: Fold atomic_ops
locking,arch,parisc: Fold atomic_ops
locking,arch,mn10300: Fold atomic_ops
locking,arch,mips: Fold atomic_ops
locking,arch,metag: Fold atomic_ops
locking,arch,m68k: Fold atomic_ops
locking,arch,m32r: Fold atomic_ops
locking,arch,ia64: Fold atomic_ops
locking,arch,hexagon: Fold atomic_ops
locking,arch,cris: Fold atomic_ops
locking,arch,avr32: Fold atomic_ops
locking,arch,arm64: Fold atomic_ops
locking,arch,arm: Fold atomic_ops
The different architectures used their own (and different) declarations:
extern __visible const void __nosave_begin, __nosave_end;
extern const void __nosave_begin, __nosave_end;
extern long __nosave_begin, __nosave_end;
Consolidate them using the first variant in <asm/sections.h>.
Pull timer fixes from Ingo Molnar:
"Main changes:
- Fix the deadlock reported by Dave Jones et al
- Clean up and fix nohz_full interaction with arch abilities
- nohz init code consolidation/cleanup"
* 'timers-nohz-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
nohz: nohz full depends on irq work self IPI support
nohz: Consolidate nohz full init code
arm64: Tell irq work about self IPI support
arm: Tell irq work about self IPI support
x86: Tell irq work about self IPI support
irq_work: Force raised irq work to run on irq work interrupt
irq_work: Introduce arch_irq_work_has_interrupt()
nohz: Move nohz full init call to tick init
Use the much more reader friendly ACCESS_ONCE() instead of the cast to volatile.
This is purely a stylistic change.
Signed-off-by: Pranith Kumar <bobby.prani@gmail.com>
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Acked-by: Max Filippov <jcmvbkbc@gmail.com>
Link: http://lkml.kernel.org/r/1411482607-20948-1-git-send-email-bobby.prani@gmail.com
This patch defines syscall_get_arch() for the superh platform. It does
so in both syscall_32.h and syscall_64.h. I'm not certain if the
implementation in syscall_64.h couldn't just be used in syscall.h as I
can't really track the setting of CONFIG_64BIT...
This way is safe, but we might be able to combine these if a superh
person were able to review...
[v2]
fixed indentation stoopidity (Sergei Shtylyov)
use AUDIT_ARCH_SH instead of EM_SH
Based-on-patch-by: Richard Briggs <rgb@redhat.com>
Signed-off-by: Eric Paris <eparis@redhat.com>
Cc: linux-sh@vger.kernel.org
The nohz full code needs irq work to trigger its own interrupt so that
the subsystem can work even when the tick is stopped.
Lets introduce arch_irq_work_has_interrupt() that archs can override to
tell about their support for this ability.
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Commit: e676253b19b2d269cccf67fdb1592120a0cd0676 (serial/8250: Add
support for RS485 IOCTLs), adds support for RS485 ioctls for 825_core on
all the archs. Unfortunaltely the definition of TIOCSRS485 and
TIOCGRS485 was missing on the ioctls.h file
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com>
Many of the atomic op implementations are the same except for one
instruction; fold the lot into a few CPP macros and reduce LoC.
This also prepares for easy addition of new ops.
Link: http://lkml.kernel.org/r/20140508135852.770036493@infradead.org
Pull slave-dma updates from Vinod Koul:
"Some notable changes are:
- new driver for AMBA AXI NBPF by Guennadi
- new driver for sun6i controller by Maxime
- pl330 drivers fixes from Lar's
- sh-dma updates and fixes from Laurent, Geert and Kuninori
- Documentation updates from Geert
- drivers fixes and updates spread over dw, edma, freescale, mpc512x
etc.."
* 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (72 commits)
dmaengine: sun6i: depends on RESET_CONTROLLER
dma: at_hdmac: fix invalid remaining bytes detection
dmaengine: nbpfaxi: don't build this driver where it cannot be used
dmaengine: nbpf_error_get_channel() can be static
dma: pl08x: Use correct specifier for size_t values
dmaengine: Remove the context argument to the prep_dma_cyclic operation
dmaengine: nbpfaxi: convert to tasklet
dmaengine: nbpfaxi: fix a theoretical race
dmaengine: add a driver for AMBA AXI NBPF DMAC IP cores
dmaengine: add device tree binding documentation for the nbpfaxi driver
dmaengine: edma: Do not register second device when booted with DT
dmaengine: edma: Do not change the error code returned from edma_alloc_slot
dmaengine: rcar-dmac: Add device tree bindings documentation
dmaengine: shdma: Allocate cyclic sg list dynamically
dmaengine: shdma: Make channel filter ignore unrelated devices
dmaengine: sh: Rework Kconfig and Makefile
dmaengine: sun6i: Fix memory leaks
dmaengine: sun6i: Free the interrupt before killing the tasklet
dmaengine: sun6i: Remove switch statement from buswidth convertion routine
dmaengine: of: kconfig: select DMA_ENGINE when DMA_OF is selected
The core mm code will provide a default gate area based on
FIXADDR_USER_START and FIXADDR_USER_END if
!defined(__HAVE_ARCH_GATE_AREA) && defined(AT_SYSINFO_EHDR).
This default is only useful for ia64. arm64, ppc, s390, sh, tile, 64-bit
UML, and x86_32 have their own code just to disable it. arm, 32-bit UML,
and x86_64 have gate areas, but they have their own implementations.
This gets rid of the default and moves the code into ia64.
This should save some code on architectures without a gate area: it's now
possible to inline the gate_area functions in the default case.
Acked-by: Nathan Lynch <nathan_lynch@mentor.com>
Acked-by: H. Peter Anvin <hpa@linux.intel.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> [in principle]
Acked-by: Richard Weinberger <richard@nod.at> [for um]
Acked-by: Will Deacon <will.deacon@arm.com> [for arm64]
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Nathan Lynch <Nathan_Lynch@mentor.com>
Fix build error as reported by Geert Uytterhoeven here:
http://kisskb.ellerman.id.au/kisskb/buildresult/11607865/
The error happens when CONFIG_HAS_IOPORT_MAP=n because of which there
are missing definitions of ioport_map/unmap(). Fix this build error by
adding these prototypes.
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Cc: <stable@vger.kernel.org> [3.16+]
The symbol is an orphan, get rid of it.
Submitted by Richard a few months ago as "[PATCH 21/28] Remove
CPU_SUBTYPE_SH7764".
[pebolle@tiscali.nl: re-added dropped ||]
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
The arch_mutex_cpu_relax() function, introduced by 34b133f, is
hacky and ugly. It was added a few years ago to address the fact
that common cpu_relax() calls include yielding on s390, and thus
impact the optimistic spinning functionality of mutexes. Nowadays
we use this function well beyond mutexes: rwsem, qrwlock, mcs and
lockref. Since the macro that defines the call is in the mutex header,
any users must include mutex.h and the naming is misleading as well.
This patch (i) renames the call to cpu_relax_lowlatency ("relax, but
only if you can do it with very low latency") and (ii) defines it in
each arch's asm/processor.h local header, just like for regular cpu_relax
functions. On all archs, except s390, cpu_relax_lowlatency is simply cpu_relax,
and thus we can take it out of mutex.h. While this can seem redundant,
I believe it is a good choice as it allows us to move out arch specific
logic from generic locking primitives and enables future(?) archs to
transparently define it, similarly to System Z.
Signed-off-by: Davidlohr Bueso <davidlohr@hp.com>
Cc: Bharat Bhushan <r65777@freescale.com>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Deepthi Dharwar <deepthi@linux.vnet.ibm.com>
Cc: Dominik Dingel <dingel@linux.vnet.ibm.com>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Cc: James E.J. Bottomley <jejb@parisc-linux.org>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Jason Wang <jasowang@redhat.com>
Cc: Joe Perches <joe@perches.com>
Cc: Joseph Myers <joseph@codesourcery.com>
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
Cc: Michael Neuling <mikey@neuling.org>
Cc: Nicolas Pitre <nico@linaro.org>
Cc: Paul Burton <paul.burton@imgtec.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Qais Yousef <qais.yousef@imgtec.com>
Cc: Qiaowei Ren <qiaowei.ren@intel.com>
Cc: Rafael Wysocki <rafael.j.wysocki@intel.com>
Cc: Steven Rostedt <srostedt@redhat.com>
Cc: Stratos Karafotis <stratosk@semaphore.gr>
Cc: Tim Chen <tim.c.chen@linux.intel.com>
Cc: Vasily Kulikov <segoon@openwall.com>
Cc: Vineet Gupta <Vineet.Gupta1@synopsys.com>
Cc: Waiman Long <Waiman.Long@hp.com>
Cc: Wolfram Sang <wsa@the-dreams.de>
Cc: adi-buildroot-devel@lists.sourceforge.net
Cc: linux390@de.ibm.com
Cc: linux-alpha@vger.kernel.org
Cc: linux-am33-list@redhat.com
Cc: linux-c6x-dev@linux-c6x.org
Cc: linux-cris-kernel@axis.com
Cc: linux-hexagon@vger.kernel.org
Cc: linux-ia64@vger.kernel.org
Cc: linux@lists.openrisc.net
Cc: linux-m32r-ja@ml.linux-m32r.org
Cc: linux-m32r@ml.linux-m32r.org
Cc: linux-m68k@lists.linux-m68k.org
Cc: linux-metag@vger.kernel.org
Cc: linux-mips@linux-mips.org
Cc: linux-parisc@vger.kernel.org
Cc: linuxppc-dev@lists.ozlabs.org
Cc: linux-s390@vger.kernel.org
Cc: linux-xtensa@linux-xtensa.org
Cc: sparclinux@vger.kernel.org
Link: http://lkml.kernel.org/r/1404079773.2619.4.camel@buesod1.americas.hpqcorp.net
Also add a few definitions that were missing.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux into next
Pull arm64 updates from Catalin Marinas:
- Optimised assembly string/memory routines (based on the AArch64
Cortex Strings library contributed to glibc but re-licensed under
GPLv2)
- Optimised crypto algorithms making use of the ARMv8 crypto extensions
(together with kernel API for using FPSIMD instructions in interrupt
context)
- Ftrace support
- CPU topology parsing from DT
- ESR_EL1 (Exception Syndrome Register) exposed to user space signal
handlers for SIGSEGV/SIGBUS (useful to emulation tools like Qemu)
- 1GB section linear mapping if applicable
- Barriers usage clean-up
- Default pgprot clean-up
Conflicts as per Catalin.
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (57 commits)
arm64: kernel: initialize broadcast hrtimer based clock event device
arm64: ftrace: Add system call tracepoint
arm64: ftrace: Add CALLER_ADDRx macros
arm64: ftrace: Add dynamic ftrace support
arm64: Add ftrace support
ftrace: Add arm64 support to recordmcount
arm64: Add 'notrace' attribute to unwind_frame() for ftrace
arm64: add __ASSEMBLY__ in asm/insn.h
arm64: Fix linker script entry point
arm64: lib: Implement optimized string length routines
arm64: lib: Implement optimized string compare routines
arm64: lib: Implement optimized memcmp routine
arm64: lib: Implement optimized memset routine
arm64: lib: Implement optimized memmove routine
arm64: lib: Implement optimized memcpy routine
arm64: defconfig: enable a few more common/useful options in defconfig
ftrace: Make CALLER_ADDRx macros more generic
arm64: Fix deadlock scenario with smp_send_stop()
arm64: Fix machine_shutdown() definition
arm64: Support arch_irq_work_raise() via self IPIs
sys_sgetmask and sys_ssetmask are obsolete system calls no longer
supported in libc.
This patch replaces architecture related __ARCH_WANT_SYS_SGETMAX by expert
mode configuration.That option is enabled by default for those
architectures.
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Cc: Greg Ungerer <gerg@uclinux.org>
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next
Pull core locking updates from Ingo Molnar:
"The main changes in this cycle were:
- reduced/streamlined smp_mb__*() interface that allows more usecases
and makes the existing ones less buggy, especially in rarer
architectures
- add rwsem implementation comments
- bump up lockdep limits"
* 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (33 commits)
rwsem: Add comments to explain the meaning of the rwsem's count field
lockdep: Increase static allocations
arch: Mass conversion of smp_mb__*()
arch,doc: Convert smp_mb__*()
arch,xtensa: Convert smp_mb__*()
arch,x86: Convert smp_mb__*()
arch,tile: Convert smp_mb__*()
arch,sparc: Convert smp_mb__*()
arch,sh: Convert smp_mb__*()
arch,score: Convert smp_mb__*()
arch,s390: Convert smp_mb__*()
arch,powerpc: Convert smp_mb__*()
arch,parisc: Convert smp_mb__*()
arch,openrisc: Convert smp_mb__*()
arch,mn10300: Convert smp_mb__*()
arch,mips: Convert smp_mb__*()
arch,metag: Convert smp_mb__*()
arch,m68k: Convert smp_mb__*()
arch,m32r: Convert smp_mb__*()
arch,ia64: Convert smp_mb__*()
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci into next
Pull PCI changes from Bjorn Helgaas:
"Enumeration
- Notify driver before and after device reset (Keith Busch)
- Use reset notification in NVMe (Keith Busch)
NUMA
- Warn if we have to guess host bridge node information (Myron Stowe)
- Work around AMD Fam15h BIOSes that fail to provide _PXM (Suravee
Suthikulpanit)
- Clean up and mark early_root_info_init() as deprecated (Suravee
Suthikulpanit)
Driver binding
- Add "driver_override" for force specific binding (Alex Williamson)
- Fail "new_id" addition for devices we already know about (Bandan
Das)
Resource management
- Support BAR sizes up to 8GB (Nikhil Rao, Alan Cox)
- Don't move IORESOURCE_PCI_FIXED resources (Bjorn Helgaas)
- Mark SBx00 HPET BAR as IORESOURCE_PCI_FIXED (Bjorn Helgaas)
- Fail safely if we can't handle BARs larger than 4GB (Bjorn Helgaas)
- Reject BAR above 4GB if dma_addr_t is too small (Bjorn Helgaas)
- Don't convert BAR address to resource if dma_addr_t is too small
(Bjorn Helgaas)
- Don't set BAR to zero if dma_addr_t is too small (Bjorn Helgaas)
- Don't print anything while decoding is disabled (Bjorn Helgaas)
- Don't add disabled subtractive decode bus resources (Bjorn Helgaas)
- Add resource allocation comments (Bjorn Helgaas)
- Restrict 64-bit prefetchable bridge windows to 64-bit resources
(Yinghai Lu)
- Assign i82875p_edac PCI resources before adding device (Yinghai Lu)
PCI device hotplug
- Remove unnecessary "dev->bus" test (Bjorn Helgaas)
- Use PCI_EXP_SLTCAP_PSN define (Bjorn Helgaas)
- Fix rphahp endianess issues (Laurent Dufour)
- Acknowledge spurious "cmd completed" event (Rajat Jain)
- Allow hotplug service drivers to operate in polling mode (Rajat Jain)
- Fix cpqphp possible NULL dereference (Rickard Strandqvist)
MSI
- Replace pci_enable_msi_block() by pci_enable_msi_exact()
(Alexander Gordeev)
- Replace pci_enable_msix() by pci_enable_msix_exact() (Alexander Gordeev)
- Simplify populate_msi_sysfs() (Jan Beulich)
Virtualization
- Add Intel Patsburg (X79) root port ACS quirk (Alex Williamson)
- Mark RTL8110SC INTx masking as broken (Alex Williamson)
Generic host bridge driver
- Add generic PCI host controller driver (Will Deacon)
Freescale i.MX6
- Use new clock names (Lucas Stach)
- Drop old IRQ mapping (Lucas Stach)
- Remove optional (and unused) IRQs (Lucas Stach)
- Add support for MSI (Lucas Stach)
- Fix imx6_add_pcie_port() section mismatch warning (Sachin Kamat)
Renesas R-Car
- Add gen2 device tree support (Ben Dooks)
- Use new OF interrupt mapping when possible (Lucas Stach)
- Add PCIe driver (Phil Edworthy)
- Add PCIe MSI support (Phil Edworthy)
- Add PCIe device tree bindings (Phil Edworthy)
Samsung Exynos
- Remove unnecessary OOM messages (Jingoo Han)
- Fix add_pcie_port() section mismatch warning (Sachin Kamat)
Synopsys DesignWare
- Make MSI ISR shared IRQ aware (Lucas Stach)
Miscellaneous
- Check for broken config space aliasing (Alex Williamson)
- Update email address (Ben Hutchings)
- Fix Broadcom CNB20LE unintended sign extension (Bjorn Helgaas)
- Fix incorrect vgaarb conditional in WARN_ON() (Bjorn Helgaas)
- Remove unnecessary __ref annotations (Bjorn Helgaas)
- Add arch/x86/kernel/quirks.c to MAINTAINERS PCI file patterns
(Bjorn Helgaas)
- Fix use of uninitialized MPS value (Bjorn Helgaas)
- Tidy x86/gart messages (Bjorn Helgaas)
- Fix return value from pci_user_{read,write}_config_*() (Gavin Shan)
- Turn pcibios_penalize_isa_irq() into a weak function (Hanjun Guo)
- Remove unused serial device IDs (Jean Delvare)
- Use designated initialization in PCI_VDEVICE (Mark Rustad)
- Fix powerpc NULL dereference in pci_root_buses traversal (Mike Qiu)
- Configure MPS on ARM (Murali Karicheri)
- Remove unnecessary includes of <linux/init.h> (Paul Gortmaker)
- Move Open Firmware devspec attribute to PCI common code (Sebastian Ott)
- Use pdev->dev.groups for attribute creation on s390 (Sebastian Ott)
- Remove pcibios_add_platform_entries() (Sebastian Ott)
- Add new ID for Intel GPU "spurious interrupt" quirk (Thomas Jarosch)
- Rename pci_is_bridge() to pci_has_subordinate() (Yijing Wang)
- Add and use new pci_is_bridge() interface (Yijing Wang)
- Make pci_bus_add_device() void (Yijing Wang)
DMA API
- Clarify physical/bus address distinction in docs (Bjorn Helgaas)
- Fix typos in docs (Emilio López)
- Update dma_pool_create ()and dma_pool_alloc() descriptions (Gioh Kim)
- Change dma_declare_coherent_memory() CPU address to phys_addr_t
(Bjorn Helgaas)
- Pass GAPSPCI_DMA_BASE CPU & bus address to dma_declare_coherent_memory()
(Bjorn Helgaas)"
* tag 'pci-v3.16-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (92 commits)
MAINTAINERS: Add generic PCI host controller driver
PCI: generic: Add generic PCI host controller driver
PCI: imx6: Add support for MSI
PCI: designware: Make MSI ISR shared IRQ aware
PCI: imx6: Remove optional (and unused) IRQs
PCI: imx6: Drop old IRQ mapping
PCI: imx6: Use new clock names
i82875p_edac: Assign PCI resources before adding device
ARM/PCI: Call pcie_bus_configure_settings() to set MPS
PCI: imx6: Fix imx6_add_pcie_port() section mismatch warning
PCI: Make pci_bus_add_device() void
PCI: exynos: Fix add_pcie_port() section mismatch warning
PCI: Introduce new device binding path using pci_dev.driver_override
PCI: rcar: Add gen2 device tree support
PCI: cpqphp: Fix possible null pointer dereference
PCI: rcar: Add R-Car PCIe device tree bindings
PCI: rcar: Add MSI support for PCIe
PCI: rcar: Add Renesas R-Car PCIe driver
PCI: Fix return value from pci_user_{read,write}_config_*()
PCI: exynos: Remove unnecessary OOM messages
pcibios_penalize_isa_irq() is only implemented by x86 now, and legacy ISA
is not used by some architectures. Make pcibios_penalize_isa_irq() a
__weak function to simplify the code. This removes the need for new
platforms to add stub implementations of pcibios_penalize_isa_irq().
[bhelgaas: changelog, comments]
Signed-off-by: Hanjun Guo <hanjun.guo@linaro.org>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Most archs with HAVE_ARCH_CALLER_ADDR have pretty much the same
definitions of CALLER_ADDRx(n). Instead of duplicating the code for all
the archs, define a ftrace_return_address0() and
ftrace_return_address(n) that can be overwritten by the archs if they
need to do something different. Instead of 7 macros in every arch, we
now only have at most 2 (and actually only 1 as
ftrace_return_address0() should be the same for all archs).
The CALLER_ADDRx(n) will now be defined in linux/ftrace.h and use the
ftrace_return_address*(n?) macros. This removes a lot of the duplicate
code.
Link: http://lkml.kernel.org/p/1400585464-30333-1-git-send-email-takahiro.akashi@linaro.org
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
The mmu-gather operation 'tlb_flush_mmu()' has done two things: the
actual tlb flush operation, and the batched freeing of the pages that
the TLB entries pointed at.
This splits the operation into separate phases, so that the forced
batched flushing done by zap_pte_range() can now do the actual TLB flush
while still holding the page table lock, but delay the batched freeing
of all the pages to after the lock has been dropped.
This in turn allows us to avoid a race condition between
set_page_dirty() (as called by zap_pte_range() when it finds a dirty
shared memory pte) and page_mkclean(): because we now flush all the
dirty page data from the TLB's while holding the pte lock,
page_mkclean() will be held up walking the (recently cleaned) page
tables until after the TLB entries have been flushed from all CPU's.
Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Tested-by: Dave Hansen <dave.hansen@intel.com>
Cc: Russell King - ARM Linux <linux@arm.linux.org.uk>
SH can use the asm-generic/barrier.h implementation since that uses
smp_mb().
Link: http://lkml.kernel.org/n/tip-2z962by2ppzcd984ybw2mwdw@git.kernel.org
If the renamed symbol is defined lib/iomap.c implements ioport_map and
ioport_unmap and currently (nearly) all platforms define the port
accessor functions outb/inb and friend unconditionally. So
HAS_IOPORT_MAP is the better name for this.
Consequently NO_IOPORT is renamed to NO_IOPORT_MAP.
The motivation for this change is to reintroduce a symbol HAS_IOPORT
that signals if outb/int et al are available. I will address that at
least one merge window later though to keep surprises to a minimum and
catch new introductions of (HAS|NO)_IOPORT.
The changes in this commit were done using:
$ git grep -l -E '(NO|HAS)_IOPORT' | xargs perl -p -i -e 's/\b((?:CONFIG_)?(?:NO|HAS)_IOPORT)\b/$1_MAP/'
The compiler is permitted to generate code which overwrites the
parameters to a function. If those parameters include the only saved
copy we have of userspace's registers, we're in trouble.
Signed-off-by: Bobby Bingham <koorogi@koorogi.info>
Cc: Paul Mundt <paul.mundt@gmail.com>
When invoking syscall handlers on sh32, the saved userspace registers
are at the top of the stack. This seems to have been intentional, as it
is an easy way to pass r0, r1, ... to the handler as parameters 5, 6,
It causes problems, however, because the compiler is allowed to generate
code for a function which clobbers that function's own parameters. For
example, gcc generates the following code for clone:
<SyS_clone>:
mov.l 8c020714 <SyS_clone+0xc>,r1 ! 8c020540 <do_fork>
mov.l r7,@r15
mov r6,r7
jmp @r1
mov #0,r6
nop
.word 0x0540
.word 0x8c02
The `mov.l r7,@r15` clobbers the saved value of r0 passed from
userspace. For most system calls, this might not be a problem, because
we'll be overwriting r0 with the return value anyway. But in the case
of clone, copy_thread will need the original value of r0 if the
CLONE_SETTLS flag was specified.
The first patch in this series fixes this issue for system calls by
pushing to the stack and extra copy of r0-r2 before invoking the
handler. We discard this copy before restoring the userspace registers,
so it is not a problem if they are clobbered.
Exception handlers also receive the userspace register values in a
similar manner, and may hit the same problem. The second patch removes
the do_fpu_error handler, which looks susceptible to this problem and
which, as far as I can tell, has not been used in some time. The third
patch addresses other exception handlers.
This patch (of 3):
The userspace registers are stored at the top of the stack when the
syscall handler is invoked, which allows r0-r2 to act as parameters 5-7.
Parameters passed on the stack may be clobbered by the syscall handler.
The solution is to push an extra copy of the registers which might be
used as syscall parameters to the stack, so that the authoritative set
of saved register values does not get clobbered.
A few system call handlers are also updated to get the userspace
registers using current_pt_regs() instead of from the stack.
"The biggest change is the MCS spinlock generalization changes from Tim
Chen, Peter Zijlstra, Jason Low et al. There's also lockdep
fixes/enhancements from Oleg Nesterov, in particular a false negative
fix related to lockdep_set_novalidate_class() usage"
* 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (22 commits)
locking/mutex: Fix debug checks
locking/mutexes: Add extra reschedule point
locking/mutexes: Introduce cancelable MCS lock for adaptive spinning
locking/mutexes: Unlock the mutex without the wait_lock
locking/mutexes: Modify the way optimistic spinners are queued
locking/mutexes: Return false if task need_resched() in mutex_can_spin_on_owner()
locking: Move mcs_spinlock.h into kernel/locking/
m68k: Skip futex_atomic_cmpxchg_inatomic() test
futex: Allow architectures to skip futex_atomic_cmpxchg_inatomic() test
Revert "sched/wait: Suppress Sparse 'variable shadowing' warning"
lockdep: Change lockdep_set_novalidate_class() to use _and_name
lockdep: Change mark_held_locks() to check hlock->check instead of lockdep_no_validate
lockdep: Don't create the wrong dependency on hlock->check == 0
lockdep: Make held_lock->check and "int check" argument bool
locking/mcs: Allow architecture specific asm files to be used for contended case
locking/mcs: Order the header files in Kbuild of each architecture in alphabetical order
hung_task/Documentation: Fix hung_task_warnings description
locking/mcs: Allow architectures to hook in to contended paths
locking/mcs: Micro-optimize the MCS code, add extra comments
Commit bcf24e1daa94 ("mmc: omap_hsmmc: use the generic config for
omap2plus devices"), enabled the build for other platforms for compile
testing.
sh-allmodconfig now fails with:
include/linux/omap-dma.h:171:8: error: expected identifier before numeric constant
make[4]: *** [drivers/mmc/host/omap_hsmmc.o] Error 1
This happens because SuperH #defines "CCR", which is one of the enum
values in include/linux/omap-dma.h. There's a similar issue with "CCR2"
on sh2a.
As "CCR" and "CCR2" are too generic names for global #defines, prefix
them with "SH_" to fix this.
This patch allows each architecture to add its specific assembly optimized
arch_mcs_spin_lock_contended and arch_mcs_spinlock_uncontended for
MCS lock and unlock functions.
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
Cc: Scott J Norton <scott.norton@hp.com>
Cc: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com>
Cc: AswinChandramouleeswaran <aswin@hp.com>
Cc: George Spelvin <linux@horizon.com>
Cc: Rik vanRiel <riel@redhat.com>
Cc: MichelLespinasse <walken@google.com>
Cc: Peter Hurley <peter@hurleysoftware.com>
Cc: Alex Shi <alex.shi@linaro.org>
Cc: "Figo.zhang" <figo1802@gmail.com>
Cc: "Paul E.McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Davidlohr Bueso <davidlohr.bueso@hp.com>
Cc: Waiman Long <waiman.long@hp.com>
Cc: Matthew R Wilcox <matthew.r.wilcox@intel.com>
Link: http://lkml.kernel.org/r/1390347382.3138.67.camel@schen9-DESK
alphabetical order
We perform a clean up of the Kbuid files in each architecture.
We order the files in each Kbuild in alphabetical order
by running the below script.
for i in arch/*/include/asm/Kbuild
do
cat $i | gawk '/^generic-y/ {
i = 3;
do {
for (; i <= NF; i++) {
if ($i == "\\") {
getline;
i = 1;
continue;
if ($i != "")
hdr[$i] = $i;
break;
} while (1);
next;
print $0;
END {
n = asort(hdr);
for (i = 1; i <= n; i++)
print "generic-y += " hdr[i];
}' > ${i}.sorted;
mv ${i}.sorted $i;
done
[ Fixed build bug. ]
Pull networking updates from David Miller:
1) BPF debugger and asm tool by Daniel Borkmann.
2) Speed up create/bind in AF_PACKET, also from Daniel Borkmann.
3) Correct reciprocal_divide and update users, from Hannes Frederic
Sowa and Daniel Borkmann.
4) Currently we only have a "set" operation for the hw timestamp socket
ioctl, add a "get" operation to match. From Ben Hutchings.
5) Add better trace events for debugging driver datapath problems, also
from Ben Hutchings.
6) Implement auto corking in TCP, from Eric Dumazet. Basically, if we
have a small send and a previous packet is already in the qdisc or
device queue, defer until TX completion or we get more data.
7) Allow userspace to manage ipv6 temporary addresses, from Jiri Pirko.
8) Add a qdisc bypass option for AF_PACKET sockets, from Daniel
Borkmann.
9) Share IP header compression code between Bluetooth and IEEE802154
layers, from Jukka Rissanen.
10) Fix ipv6 router reachability probing, from Jiri Benc.
11) Allow packets to be captured on macvtap devices, from Vlad Yasevich.
12) Support tunneling in GRO layer, from Jerry Chu.
13) Allow bonding to be configured fully using netlink, from Scott
Feldman.
14) Allow AF_PACKET users to obtain the VLAN TPID, just like they can
already get the TCI. From Atzm Watanabe.
15) New "Heavy Hitter" qdisc, from Terry Lam.
16) Significantly improve the IPSEC support in pktgen, from Fan Du.
17) Allow ipv4 tunnels to cache routes, just like sockets. From Tom
Herbert.
18) Add Proportional Integral Enhanced packet scheduler, from Vijay
Subramanian.
19) Allow openvswitch to mmap'd netlink, from Thomas Graf.
20) Key TCP metrics blobs also by source address, not just destination
address. From Christoph Paasch.
21) Support 10G in generic phylib. From Andy Fleming.
22) Try to short-circuit GRO flow compares using device provided RX
hash, if provided. From Tom Herbert.
The wireless and netfilter folks have been busy little bees too.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (2064 commits)
net/cxgb4: Fix referencing freed adapter
ipv6: reallocate addrconf router for ipv6 address when lo device up
fib_frontend: fix possible NULL pointer dereference
rtnetlink: remove IFLA_BOND_SLAVE definition
rtnetlink: remove check for fill_slave_info in rtnl_have_link_slave_info
qlcnic: update version to 5.3.55
qlcnic: Enhance logic to calculate msix vectors.
qlcnic: Refactor interrupt coalescing code for all adapters.
qlcnic: Update poll controller code path
qlcnic: Interrupt code cleanup
qlcnic: Enhance Tx timeout debugging.
qlcnic: Use bool for rx_mac_learn.
bonding: fix u64 division
rtnetlink: add missing IFLA_BOND_AD_INFO_UNSPEC
sfc: Use the correct maximum TX DMA ring size for SFC9100
Add Shradha Shah as the sfc driver maintainer.
net/vxlan: Share RX skb de-marking and checksum checks with ovs
tulip: cleanup by using ARRAY_SIZE()
ip_tunnel: clear IPCB in ip_tunnel_xmit() in case dst_link_failure() is called
net/cxgb4: Don't retrieve stats during recovery
Merge second patch-bomb from Andrew Morton:
- various misc bits
- the rest of MM
- add generic fixmap.h, use it
- backlight updates
- dynamic_debug updates
- printk() updates
- checkpatch updates
- binfmt_elf
- ramfs
- init/
- autofs4
- drivers/rtc
- nilfs
- hfsplus
- Documentation/
- coredump
- procfs
- fork
- exec
- kexec
- kdump
- partitions
- rapidio
- rbtree
- userns
- memstick
- w1
- decompressors
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (197 commits)
lib/decompress_unlz4.c: always set an error return code on failures
romfs: fix returm err while getting inode in fill_super
drivers/w1/masters/w1-gpio.c: add strong pullup emulation
drivers/memstick/host/rtsx_pci_ms.c: fix ms card data transfer bug
userns: relax the posix_acl_valid() checks
arch/sh/kernel/dwarf.c: use rbtree postorder iteration helper instead of solution using repeated rb_erase()
fs-ext3-use-rbtree-postorder-iteration-helper-instead-of-opencoding-fix
fs/ext3: use rbtree postorder iteration helper instead of opencoding
fs/jffs2: use rbtree postorder iteration helper instead of opencoding
fs/ext4: use rbtree postorder iteration helper instead of opencoding
fs/ubifs: use rbtree postorder iteration helper instead of opencoding
net/netfilter/ipset/ip_set_hash_netiface.c: use rbtree postorder iteration instead of opencoding
rbtree/test: test rbtree_postorder_for_each_entry_safe()
rbtree/test: move rb_node to the middle of the test struct
rapidio: add modular rapidio core build into powerpc and mips branches
partitions/efi: complete documentation of gpt kernel param purpose
kdump: add /sys/kernel/vmcoreinfo ABI documentation
kdump: fix exported size of vmcoreinfo note
kexec: add sysctl to disable kexec_load
fs/exec.c: call arch_pick_mmap_layout() only once
git://git.linaro.org/people/mike.turquette/linux
Pull clk framework changes from Mike Turquette:
"The first half of the clk framework pull request is made up almost
entirely of new platform/driver support. There are some conversions
of existing drivers to the common-clock Device Tree binding, and a few
non-critical fixes to the framework.
Due to an entirely unnecessary cyclical dependency with the arm-soc
tree this pull request is broken into two pieces. The second piece
will be sent out after arm-soc sends you the pull request that merged
in core support for the HiSilicon 3620 platform. That same pull
request from arm-soc depends on this pull request to merge in those
HiSilicon bits without causing build failures"
[ Just did the ARM SoC merges, so getting ready for the second clk tree
pull request - Linus ]
* tag 'clk-for-linus-3.14-part1' of git://git.linaro.org/people/mike.turquette/linux: (97 commits)
devicetree: bindings: Document qcom,mmcc
devicetree: bindings: Document qcom,gcc
clk: qcom: Add support for MSM8660's global clock controller (GCC)
clk: qcom: Add support for MSM8974's multimedia clock controller (MMCC)
clk: qcom: Add support for MSM8974's global clock controller (GCC)
clk: qcom: Add support for MSM8960's multimedia clock controller (MMCC)
clk: qcom: Add support for MSM8960's global clock controller (GCC)
clk: qcom: Add reset controller support
clk: qcom: Add support for branches/gate clocks
clk: qcom: Add support for root clock generators (RCGs)
clk: qcom: Add support for phase locked loops (PLLs)
clk: qcom: Add a regmap type clock struct
clk: Add set_rate_and_parent() op
reset: Silence warning in reset-controller.h
clk: sirf: re-arch to make the codes support both prima2 and atlas6
clk: composite: pass mux_hw into determine_rate
clk: shmobile: Fix MSTP clock array initialization
clk: shmobile: Fix MSTP clock index
ARM: dts: Add clock provider specific properties to max77686 node
clk: max77686: Register OF clock provider
Signed-off-by: Mark Salter <msalter@redhat.com>
We're going to be adding a few new barrier primitives, and in order to
avoid endless duplication make more agressive use of
asm-generic/barrier.h.
Change the asm-generic/barrier.h such that it allows partial barrier
definitions and fills out the rest with defaults.
There are a few architectures (m32r, m68k) that could probably
do away with their barrier.h file entirely but are kept for now due to
their unconventional nop() implementation.
Suggested-by: Geert Uytterhoeven <geert@linux-m68k.org>
Reviewed-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Reviewed-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Cc: Michael Ellerman <michael@ellerman.id.au>
Cc: Victor Kaplansky <VICTORK@il.ibm.com>
Link: http://lkml.kernel.org/r/20131213150640.846368594@infradead.org
This patch adds common __clk_get(), __clk_put() clkdev helpers that
replace their platform specific counterparts when the common clock
API is used.
The owner module pointer field is added to struct clk so a reference
to the clock supplier module can be taken by the clock consumers.
The owner module is assigned while the clock is being registered,
in functions _clk_register() and __clk_register().
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
