path: root/arch/sh/kernel/cpu/sh3
2008-05-08sh: clean up sh7710 and sh7720 intc tablesMagnus Damm
Clean up the intc tables by removing unneeded #ifdefs. The vector list is what selects which interrupt sources that should be added, having unsupported bitfields listed is ok as long as the vector is excluded from the list. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-08sh: add interrupt ack code to sh3Magnus Damm
This patch adds interrupt acknowledge code for external interrupt sources on sh3 processors. Only really required for edge triggered interrupts, but we ack regardless of sense configuration. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-08sh: unify external irq pin code for sh3Magnus Damm
This patch unifies the sh3 external irq pin code. It buys us some savings with reduced code redundancy, but the main feature with this change is irq sense selection support for all sh3 processors. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-08sh: fix sh7705 interrupt vector typoMagnus Damm
Fix sh7705 interrupt sources for vectors 0xc80 and 0xca0. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-02-26serial: Move asm-sh/sci.h to linux/serial_sci.h.Paul Mundt
This header is needed on other architectures as well (namely h8300), which currently fails to build without this in place. Rather than duplicating the port definition completely there, just move this to a common location instead. This should get h8300 working again for 2.6.25, in addition to the changes already pushed by Sato-san in -rc2. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-02-26sh: fix rtc_resources setup for sh770xRafael Ignacio Zurita
Fix the RTC resources setup for sh770x. Whit these proper start values RTC driver (drivers/rtc/rtc-sh.c) works. Signed-off-by: Rafael Ignacio Zurita <rizurita@yahoo.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-02-25sh: Rename SH-3 CCR3 reg to avoid synclink_cs clash.Paul Mundt
drivers/char/pcmcia/synclink_cs.c:284:1: warning: "CCR3" redefined In file included from include/asm/cache.h:13, from include/asm/processor_32.h:15, from include/asm/processor.h:60, from include/linux/prefetch.h:14, from include/linux/list.h:8, from include/linux/module.h:9, from drivers/char/pcmcia/synclink_cs.c:38: include/asm/cpu/cache.h:38:1: warning: this is the location of the previous definition Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-01-28sh: Add OHCI and UDC platform devices for SH7720.Yoshihiro Shimoda
Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-01-28sh: intc - remove default interrupt priority tablesMagnus Damm
This patch removes interrupt priority tables from the intc code. Optimal priority assignment varies with embedded application anyway, so keeping the interrupt priority tables together with cpu-specific code doesn't make sense. The function intc_set_priority() should be used instead to set the desired interrupt priority level. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-01-28sh: sh7712 clock supportAndrew Murray
This patch provides specific clock support for the SH7712. Signed-off-by: Andrew Murray <amurray@mpc-data.co.uk> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-01-28sh: Add support for SH7721 CPU subtype.Yoshihiro Shimoda
2008-01-28sh: Preparation for uncached jumps through PMB.Stuart Menefy
Presently most of the 29-bit physical parts do P1/P2 segmentation with a 1:1 cached/uncached mapping, jumping between the two to control the caching behaviour. This provides the basic infrastructure to maintain this behaviour on 32-bit physical parts that don't map P1/P2 at all, using a shiny new linker section and corresponding fixmap entry. Signed-off-by: Stuart Menefy <stuart.menefy@st.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-01-28sh: GUSA atomic rollback support.Stuart Menefy
This implements kernel-level atomic rollback built on top of gUSA, as an alternative non-IRQ based atomicity method. This is generally a faster method for platforms that are lacking the LL/SC pairs that SH-4A and later use, and is only supportable on legacy cores. Signed-off-by: Stuart Menefy <stuart.menefy@st.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-01-28sh: SH-2A FPU support.Paul Mundt
Signed-off-by: Kieran Bingham <kbingham@mpc-data.co.uk> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-11-07sh: Fix up kgdb-on-NMI branch target.Paul Mundt
This was all reworked some time ago, the old debug_enter was ripped out with everything going through a debug trap jump table instead. Kill off the debug_enter target and reference kgdb_handle_exception directly. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-09-27sh: Use boot_cpu_data for CPU probe.Paul Mundt
This moves off of smp_processor_id() and only sets the probe information for the boot CPU directly. This will be copied out for the secondaries, so there's no reason to do this each time. This also allows for some header tidying. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-09-21sh: intc - mark data structures as __initdataMagnus Damm
With the intc core improved it is now possible to put the intc data structures in the initdata section. Version two of this patch puts the __initdata inside DECLARE_INTC_DESC() and removes the __initdata included in the board specific r2d code. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-09-21sh: intc - add a clear register to struct intc_prio_regMagnus Damm
We need a secondary register member in struct intc_prio_reg to support dual priority registers used by ipi on x3. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-09-21sh: Add SH7720 CPU support.Markus Brunner
This adds support for the SH7720 (SH3-DSP) CPU. Signed-off by: Markus Brunner <super.firetwister@gmail.com> Signed-off by: Mark Jonas <toertel@gmail.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-09-21sh: intc - remove redundant irq code for shminMagnus Damm
This patch removes redundant interrupt code for the shmin board which is using a sh770x processor and 4 IRQ lines as individual interrupts (IRQ-mode). Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-09-21rtc: rtc-sh: Support 4-digit year on SH7705/SH7710/SH7712.Paul Mundt
All SH-4 parts have a 4-digit year, while the SH-3 parts typically only use a 2-digit one. The SH7705, SH7710, and SH7712 SH-3 parts however opted to extend it to 4-digit and still look and act like an SH-3 RTC in all other ways. This adds a capability flag (RTC_CAP_4_DIGIT_YEAR) that these corner-case CPU subtypes can set in their platform data and cleans up some of the ifdef mess in the driver as a result. Reported-by: Markus Brunner <super.firetwister@gmail.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-09-21sh: intc - fix IRQ4 and IRQ5 typo on sh3Magnus Damm
The intc tables for sh3 currently contain a typo where the bit fields in IPRD are mixed up for IRQ4 and IRQ5. This patch makes sure the correct bit fields are used - all according to the datasheets. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-09-21sh: intc - avoid SH7710 specific vector on SH7712Magnus Damm
This patch makes sure that the sh7710 specific ipsec vector is missing if building for a sh7712. All according to the datasheet. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-09-21sh: intc - add missing vectors for SH7707Magnus Damm
This patch adds a few missing vectors for sh7707. The only interrupt controller differences between sh7707 and sh7709 seem to be added vectors for one LCD controller and two PCMCIA slots. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-09-21sh: intc - add support for SH7706, SH7707, SH7708, SH7709Magnus Damm
This patch unifies the cpu specific interrupt setup code for sh7706, sh7707, sh7708 and sh7709 and moves the code into a new file called setup-sh770x.c. It makes sense to share the setup code between these processors because most hardware blocks are identical from a software point of view. With this patch the sh770x processors now have a complete set of vectors that match with the information provided by the data sheets. This is a big improvement for sh7708. Vectors for IRQ4 and IRQ5 are enabled by default. Use plat_irq_setup_pins() if pins IRQ0-3 should be used in IRQ mode. This patch also unifies the platform device setup code which means that the rtc driver now has platform data for all sh770x processors. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-09-21sh: intc - add support for SH7710Magnus Damm
This patch converts the cpu specific interrupt setup code for sh7710 from ipr to intc. While at it new vectors are added to match the information provided by the datasheet. Version two simplifies the Kconfig part. Vectors for IRQ4 and IRQ5 are enabled by default. Use plat_irq_setup_pins() if pins IRQ0-3 should be used in IRQ mode. This patch also adds sh7710 specific platform data for the rtc driver. The base address of SCIF1 is adjusted to match the datasheet. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-09-21sh: intc - add support for SH7705Magnus Damm
This patch converts the cpu specific interrupt setup code for sh7705 from ipr to intc. While at it new vectors are added to match the information provided by the datasheet. Vectors for IRQ4 and IRQ5 are enabled by default. Use plat_irq_setup_pins() if pins IRQ0-3 should be used in IRQ mode. This patch also adds sh7705 specific platform data for the rtc driver. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-08-01sh: Fix lockdep debugging oops on SH-3/4.Paul Mundt
In the SH-3/4 TLB access violation path we were enabling IRQs before the call in to trace_hardirqs_on(), which ended up triggering: if (DEBUG_LOCKS_WARN_ON(!irqs_disabled())) return; in kernel/lockdep.c:2031. Fix this up by removing the early re-enable, we were already re-enabling IRQs post-trace_hardirqs_on() already, so the semantics are now as was initially intended. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-07-26sh: remove support for sh7300 and solution engine 7300Magnus Damm
This patch removes old dead code: - kill off sh7300 cpu support - get rid of broken solution engine 7300 board support Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-07-20sh: IPR/INTC2 IRQ setup consolidation.Magnus Damm
This patch unifies the cpu specific interrupt setup functions for interrupt controller blocks such as ipr, intc2 and intc. There is no point in having separate functions for each interrupt controller, so let's clean this up. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-07-16sh: sh-rtc support for SH7709.Kristoffer Ericson
Signed-off-by: Kristoffer Ericson <kristoffer.ericson@gmail.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-06-20sh: Preliminary support for the SH-X3 CPU.Paul Mundt
This adds basic support for UP SH-X3. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-06-15sh: rework ipr codeMagnus Damm
This patch reworks the ipr code by grouping the offset array together with the ipr_data structure in a new data structure called ipr_desc. This new structure also contains the name of the controller in struct irq_chip. The idea behind putting struct irq_chip in there is that we can use offsetof() to locate the base addresses in the irq_chip callbacks. This strategy has much in common with the recently merged intc2 code. One logic change has been made - the original ipr code enabled the interrupts by default but with this patch they are all disabled by default. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-06-04sh: Fix in_nmi symbol build error.Paul Mundt
If CONFIG_KGDB_NMI is disabled, we're left with a stray in_nmi reference that can't be resolved. Move the symbol under the ifdef, too. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-05-31sh: Fix pcrel too far for in_nmi label.Takashi YOSHII
Add lost in_nmi definition to solve pcrel too far. Signed-off-by: Takashi YOSHII <takasi-y@ops.dti.ne.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-05-09Merge master.kernel.org:/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/lethal/sh-2.6: sh: Fix stacktrace simplification fallout. sh: SH7760 DMABRG support. sh: clockevent/clocksource/hrtimers/nohz TMU support. sh: Truncate MAX_ACTIVE_REGIONS for the common case. rtc: rtc-sh: Fix rtc_dev pointer for rtc_update_irq(). sh: Convert to common die chain. sh: Wire up utimensat syscall. sh: landisk mv_nr_irqs definition. sh: Fixup ndelay() xloops calculation for alternate HZ. sh: Add 32-bit opcode feature CPU flag. sh: Fix PC adjustments for varying opcode length. sh: Support for SH-2A 32-bit opcodes. sh: Kill off redundant __div64_32 symbol export. sh: Share exception vector table for SH-3/4. sh: Always define TRAPA_BUG_OPCODE. sh: __GFP_REPEAT for pte allocations, too. rtc: rtc-sh: Fix up dev_dbg() warnings. sh: generic quicklist support.
2007-05-09fix file specification in commentsUwe Kleine-König
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Kleine-König <ukleinek@informatik.uni-freiburg.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-09sh: Share exception vector table for SH-3/4.Paul Mundt
The only difference between these at the moment are the FPU exceptions, and these are hidden away under CONFIG_SH_FPU (which is only set for the SH-4 case anyways..). This consolidates the two tables, and updates SH-4 to use the updated copy. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-05-07sh: Wire up more IRQs for SH7709.Takashi YOSHII
hp6xx requires some additional IRQs that aren't currently enabled in the SH7709 setup code. Wire them up. Signed-off-by: Takashi YOSHII <takashi.yoshii.ze@hitachi.com> Signed-off-by: Kristoffer Ericson <kristoffer.ericson@gmail.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-05-07sh: Solution Engine SH7705 board and CPU updates.Nobuhiro Iwamatsu
This fixes up SH7705 CPU support and the SE7705 board for some of the recent changes. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.zh@hitachi.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-05-07sh: MS7712SE01 board support.Nobuhiro Iwamatsu
Support the SH7712 (SH3-DSP) Solution Engine reference board. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-03-14sh: Fix bogus regs pointer in do_IRQ().Paul Mundt
SH-3 and SH-4 were trampling the register, and SH-2 wasn't even setting it in the first place. This ended up with some rather broken behaviour in the sysrq show_regs(). Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-02-14sh: Revert TLB miss fast-path changes that broke PTEA parts.Paul Mundt
This ended up causing problems for older parts (particularly ones using PTEA). Revert this for now, it can be added back in once it's had some more testing. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-02-13sh: Fixup cpu_data references for the non-boot CPUs.Paul Mundt
There are a lot of bogus cpu_data-> references that only end up working for the boot CPU, convert these to current_cpu_data to fixup SMP. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-02-13sh: More tidying for large base pages.Paul Mundt
There were a few more things that needed fixing up, namely THREAD_SIZE and the TLB miss handler where certain PTRS_PER_PGD == PTRS_PER_PTE assumptions were being made. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-02-13sh: shmin updates.Takashi YOSHII
This fixes up shmin (and SH7706/SH7708) IPR support for some of the recent API changes. Signed-off-by: Takashi YOSHII <takasi-y@ops.dti.ne.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-02-13sh: Use a jump call table for debug trap handlers.Paul Mundt
This rips out most of the needlessly complicated sh_bios and kgdb trap handling, and forces it all through a common fast dispatch path. As more debug traps are inserted, it's important to keep them in sync for all of the parts, not just SH-3/4. As the SH-2 parts are unable to do traps in the >= 0x40 range, we restrict the debug traps to the 0x30-0x3f range on all parts, and also bump the kgdb breakpoint trap down in to this range (from 0xff to 0x3c) so it's possible to use for nommu. Optionally, this table can be padded out to catch spurious traps for SH-3/4, but we don't do that yet.. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-12-06sh: stacktrace/lockdep/irqflags tracing support.Paul Mundt
Wire up all of the essentials for lockdep.. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-12-06sh: Clock framework tidying.Paul Mundt
This syncs up the SH clock framework with the linux/clk.h API, for which there were only some minor changes required, namely the clk_get() dev_id and subsequent callsites. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-12-06sh: Fixup various PAGE_SIZE == 4096 assumptions.Paul Mundt
There were a number of places that made evil PAGE_SIZE == 4k assumptions that ended up breaking when trying to play with 8k and 64k page sizes, this fixes those up. The most significant change is the way we load THREAD_SIZE, previously this was done via: mov #(THREAD_SIZE >> 8), reg shll8 reg to avoid a memory access and allow the immediate load. With a 64k PAGE_SIZE, we're out of range for the immediate load size without resorting to special instructions available in later ISAs (movi20s and so on). The "workaround" for this is to bump up the shift to 10 and insert a shll2, which gives a bit more flexibility while still being much cheaper than a memory access. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
