SH7723 is the first hard silicon to implement the L2, and unsurprisingly,
does the precise inverse of what the specification alleges. XOR the
URAM/L2 size bits to get back in line with the existing parsing logic.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
The SH-4A series probe we were relying on doesn't work any more on the
newer parts, bump this up to use CVR.CHIP instead so we have consistent
behaviour across all of the parts, which is what this should have been
testing in the first place.
This adds basic support for the SH7723 MobileR2 CPU.
This patch adds sh7366 cpu supports. Just the most basic things like interrupt
controller, clocks and serial port are included at this point.
Signed-off-by: Magnus Damm <damm@igel.co.jp>
This patch adds support for sh7722 devices with prr value 0xa1.
Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com>
The ST40 stuff in-tree hasn't built for some time, and hasn't been
updated for over 3 years. ST maintains their own out-of-tree changes
and rebases occasionally, and that's ultimately where all of the ST40
users go anyways.
In order for the ST40 code to be brought up to date most of the stuff
removed in this changeset would have to be rewritten anyways, so there's
very little benefit in keeping the remnants around either.
This moves off of smp_processor_id() and only sets the probe
information for the boot CPU directly. This will be copied out
for the secondaries, so there's no reason to do this each time.
This also allows for some header tidying.
The probing logic works for both URAM and L2, with no way to
distinguish between the two. Disable the probing for now and
let the CPU subtypes that have this in a real L2 configuration
explicitly say so.
This patch removes old dead code:
- kill off sh73180 cpu support
- get rid of broken solution engine 73180 board support
This adds basic support for UP SH-X3.
Several errors were spotted during building for custom config (SMP
included). Although SMP still does not compile (no ipi and
__smp_call_function) and does not work, this looks a bit cleaner.
Some other errors obtained via gcc-4.1.0 build.
Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru>
This adds preliminary support for the SH7785-based Highlander board.
Some of the Highlander support code is reordered so that most of it
can be reused directly.
This also plugs in missing SH7785 checks in the places that need it,
as this is the first board to support the CPU.
The code for performing the calculation was only in the SH-4 probe
path, move it out to the common path so the other parts get this
right too.
There are a lot of bogus cpu_data-> references that only end up working
for the boot CPU, convert these to current_cpu_data to fixup SMP.
This converts the lazy dcache handling to the model described in
Documentation/cachetlb.txt and drops the ptep_get_and_clear() hacks
used for the aliasing dcaches on SH-4 and SH7705 in 32kB mode. As a
bonus, this slightly cuts down on the cache flushing frequency.
With that and the PTEA handling out of the way, the update_mmu_cache()
implementations can be consolidated, and we no longer have to worry
about which configuration the cache is in for the SH7705 case.
And finally, explicitly disable the lazy writeback on SMP (SH-4A).
This adds CPU support for the SH7722.
Handle simple TLB miss faults which can be resolved completely
from the page table in assembler.
Signed-off-by: Stuart Menefy <stuart.menefy@st.com>
Figure out the cache desc entry_mask at runtime, and remove
hard-coded assumption about the cacheline size.
This implements preliminary support for the L2 caches found
on newer SH-4A CPUs.
Encode processor flags in AT_HWCAP in the ELF auxiliary vector.
This adds support for the aforementioned CPU subtypes, and cleans
up some build issues encountered as a result.
Add CPU_HAS_PTEA, refactor some of the cpu flag settings.
Merge support for SH7770 and SH7780 SH-4A subtypes.
Newer SH7760 cuts have a range of acceptable PRR values..
This reworks some of the SH-4 cache handling code to more easily
accomodate newer-style caches (particularly for the > direct-mapped
case), as well as optimizing some of the old code.
Signed-off-by: Richard Curnow <richard.curnow@st.com>
infrastructure for it.
Let it rip!
