Add clock framework support to the usbf/m66592 driver and
adjust the cpu specific code accordingly.
Signed-off-by: Magnus Damm <damm@igel.co.jp>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Add clock framework support to the sh_mobile i2c driver and
adjust the processor specific code accordingly.
Use clk_always_enable() on the sh7722 processor and in the board code
for Migo-R and Solution Engine 7722. Remove duplicate MSTPCR register
definitions.
This patch adds physically contiguous memory chunks to the UIO devices.
The same strategy can be used in the future for the CEU as well.
This patch exports the VPU and VEU blocks of the sh7722 to user space
using the uio_pdrv_genirq platform driver.
This patch is based on interrupt acknowledge code for external
interrupt sources on sh3 processors and adds on sh4a processors.
Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com>
The USBF function on sh7722 is currently not working with the m66592_udc
driver. The driver is using platform_get_resource_byname() so my commit
a0d29798e568116aa6c32aef7bab2d9e620c88ad broke sh7722 support.
The long term fix is to replace platform_get_resource_byname() in the
driver with platform_get_resource(), but this helps until that happens.
Add platform data for the SuperH Mobile I2C block to sh7722.
Use physical addresses and change resource name to follow data sheet.
This header is needed on other architectures as well (namely h8300),
which currently fails to build without this in place. Rather than
duplicating the port definition completely there, just move this to a
common location instead.
This should get h8300 working again for 2.6.25, in addition to the
changes already pushed by Sato-san in -rc2.
This patch removes interrupt priority tables from the intc code.
Optimal priority assignment varies with embedded application anyway,
so keeping the interrupt priority tables together with cpu-specific
code doesn't make sense.
The function intc_set_priority() should be used instead to set the
desired interrupt priority level.
With the intc core improved it is now possible to put the intc data
structures in the initdata section.
Version two of this patch puts the __initdata inside DECLARE_INTC_DESC()
and removes the __initdata included in the board specific r2d code.
We need a secondary register member in struct intc_prio_reg to support
dual priority registers used by ipi on x3.
This patch unifies the cpu specific interrupt setup functions for
interrupt controller blocks such as ipr, intc2 and intc. There is no
point in having separate functions for each interrupt controller, so
let's clean this up.
This patch converts the cpu specific 7722 setup code to use the
new intc controller. Many new vectors are added and also support
for external interrupt sense configuration. So with this patch
it is now possible to configure external interrupt pins as edge
or level triggered using set_irq_type().
This patch contains two serial port related fixes for sh7722:
- Make sure the irqs for the first serial port is correct
- Add the second and third serial port to the platform data
This patch reworks the ipr code by grouping the offset array together
with the ipr_data structure in a new data structure called ipr_desc.
This new structure also contains the name of the controller in struct
irq_chip. The idea behind putting struct irq_chip in there is that we
can use offsetof() to locate the base addresses in the irq_chip
callbacks. This strategy has much in common with the recently merged
intc2 code.
One logic change has been made - the original ipr code enabled the
interrupts by default but with this patch they are all disabled by
default.
This adds the URAM block on SH7722 as a separate node.
Sparsemem is required for this, or it can simply be disabled
by explicitly selecting a flatmem model.
Add the SCIF IRQs to the IPR table for SH7722.
This adds CPU support for the SH7722.
