Several fixes as well where the +1 was missing.
Done via coccinelle scripts like:
struct resource *ptr;
- ptr->end - ptr->start + 1
+ resource_size(ptr)
and some grep and typing.
Mostly uncompiled, no cross-compilers.
This plugs in the alignment and emulation fault reporting for perf sw
events.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
This extends some of the existing special casing for HAS_IOPORT
platforms and gets it to the point where platforms can begin to
conditionally select it.
The major changes here are that the PIO routines themselves go away
completely, including all of the machvec port mapping wrappers. With this
in place it's possible for any non-machvec abusing platform to disable
PIO completely. At present this is left as an opt-in until the abusers
are the odd ones out instead of the majority.
Presently trapped I/O is only registered if it's not explicitly disabled
for the platforms that select it openly. From the fault path this runs
through an address lookup before figuring out that nothing matches and
falls back through the error path, but we can forego the lookup
completely by testing if it's been explicitly disabled. This provides a
measurable speedup for things like qemu that rely on runtime disabling.
The old ctrl in/out routines are non-portable and unsuitable for
cross-platform use. While drivers/sh has already been sanitized, there
is still quite a lot of code that is not. This converts the arch/sh/ bits
over, which permits us to flag the routines as deprecated whilst still
building with -Werror for the architecture code, and to ensure that
future users are not added.
Some unaligned accesses are completely expected. For example, the
trapped_io code uses the unaligned access fixup code path so there's no
need to warn about having to fixup the unaligned access.
Signed-off-by: Matt Fleming <matt@console-pimps.org>
This cleans up the irqflags tracing code quite a bit and ties it
in to various missing callsites that caused an imbalance when
CONFIG_PROVE_LOCKING was enabled.
Previously this was catching on:
987 #ifdef CONFIG_PROVE_LOCKING
988 DEBUG_LOCKS_WARN_ON(!p->hardirqs_enabled);
989 DEBUG_LOCKS_WARN_ON(!p->softirqs_enabled);
990 #endif
991 retval = -EAGAIN;
with hardirqs being doubly enabled, and subsequently bailing out
with the following call trace:
Call trace:
[<88035224>] __lock_acquire+0x616/0x6a6
[<88015a8c>] do_fork+0xf8/0x2b0
[<880331ec>] trace_hardirqs_on_caller+0xd4/0x114
[<88241074>] _spin_unlock_irq+0x20/0x64
[<8800386c>] kernel_thread+0x48/0x70
[<88024ecc>] ____call_usermodehelper+0x0/0x110
[<88003894>] kernel_thread_helper+0x0/0x14
[<88024bac>] __call_usermodehelper+0x38/0x70
[<88025dc0>] worker_thread+0x150/0x274
[<88035b9c>] lock_release+0x0/0x198
[<88024b74>] __call_usermodehelper+0x0/0x70
[<88028cf0>] autoremove_wake_function+0x0/0x30
[<88028bf2>] kthread+0x3e/0x70
[<88025c70>] worker_thread+0x0/0x274
[<8800389c>] kernel_thread_helper+0x8/0x14
[<88028bb4>] kthread+0x0/0x70
Reported-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
Signed-off-by: Stuart Menefy <stuart.menefy@st.com>
This is now clashing with a driver, so just rename it.
This adds a 'noiotrap' kernel command line option to permit disabling of
I/O trapping. This is mostly useful for running on emulators where the
physical device limitations are not an issue.
The idea is that we want to get rid of the in/out/readb/writeb callbacks from
the machvec and replace that with simple inline read and write operations to
memory. Fast and simple for most hardware devices (think pci).
Some devices require special treatment though - like 16-bit only CF devices -
so we need to have some method to hook in callbacks.
This patch makes it possible to add a per-device trap generating filter. This
way we can get maximum performance of sane hardware - which doesn't need this
filter - and crappy hardware works but gets punished by a performance hit.
V2 changes things around a bit and replaces io access callbacks with a
simple minimum_bus_width value. In the future we can add stride as well.
Signed-off-by: Magnus Damm <damm@igel.co.jp>
