[sfr@canb.auug.org.au: fix powerpc build]
Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com>
Reviewed-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
Cc: "Rafael J . Wysocki" <rjw@sisk.pl>
Cc: Chen Tang <imtangchen@gmail.com>
Cc: Gong Chen <gong.chen@linux.intel.com>
Cc: Jiang Liu <jiang.liu@huawei.com>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Larry Woodman <lwoodman@redhat.com>
Cc: Len Brown <lenb@kernel.org>
Cc: Liu Jiang <jiang.liu@huawei.com>
Cc: Michal Nazarewicz <mina86@mina86.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Prarit Bhargava <prarit@redhat.com>
Cc: Taku Izumi <izumi.taku@jp.fujitsu.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Thomas Renninger <trenn@suse.de>
Cc: Toshi Kani <toshi.kani@hp.com>
Cc: Vasilis Liaskovitis <vasilis.liaskovitis@profitbricks.com>
Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com>
Cc: Wen Congyang <wency@cn.fujitsu.com>
Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: Yinghai Lu <yinghai@kernel.org>
The __cpuinit type of throwaway sections might have made sense
some time ago when RAM was more constrained, but now the savings
do not offset the cost and complications. For example, the fix in
commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time")
is a good example of the nasty type of bugs that can be created
with improper use of the various __init prefixes.
After a discussion on LKML[1] it was decided that cpuinit should go
the way of devinit and be phased out. Once all the users are gone,
we can then finally remove the macros themselves from linux/init.h.
Note that some harmless section mismatch warnings may result, since
notify_cpu_starting() and cpu_up() are arch independent (kernel/cpu.c)
are flagged as __cpuinit -- so if we remove the __cpuinit from
arch specific callers, we will also get section mismatch warnings.
As an intermediate step, we intend to turn the linux/init.h cpuinit
content into no-ops as early as possible, since that will get rid
of these warnings. In any case, they are temporary and harmless.
This removes all the arch/sh uses of the __cpuinit macros from
all C files. Currently sh does not have any __CPUINIT used in
assembly files.
[1] https://lkml.org/lkml/2013/5/20/589
Cc: linux-sh@vger.kernel.org
The standard (see BSS_SECTION() in <asm-generic/vmlinux.lds.h> and
<asm-generic/sections.h>) symbol for the end of BSS is __bss_stop.
This allows to remove all local declarations that have been added to
several architectures just to please CONFIG_MTD_UCLINUX.
Acked-by: Paul Mundt <lethal@linux-sh.org>
Acked-by: Michal Simek <monstr@monstr.eu>
Acked-by: Greg Ungerer <gerg@uclinux.org>
sh doesn't access early_node_map[] directly and enabling
HAVE_MEMBLOCK_NODE_MAP is trivial - replacing add_active_range() calls
with memblock_set_node() and selecting HAVE_MEMBLOCK_NODE_MAP is
enough.
Register crashk_res so that it can be used by kexec-tools
via /proc/iomem.
The crash kernel resource needs to be requested the same as the
other kernel resources due to the fact that it's handled during
the common path for adding new memory ranges, so it's added in to
__add_active_range() with the others. This ensures that the crash
kernel is properly reserved regardless of which memory range it's
placed in.
Signed-off-by: Simon Horman <horms@verge.net.au>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Presently this is all inlined in setup.c, which is not really the place
for it. Follow the x86 example and split it out into its own file.
The introduction of MAX_PHYSMEM_BITS in to the initial cpuinfo struct
causes a build error when sparsemem is disabled and asm/sparsemem.h is
not brought in by other means. Include it explicitly.
CPUs can be in either the legacy 29-bit or 32-bit physical addressing
modes. This follows the x86 approach of tracking the phys bits in cpuinfo
and exposing it to userspace through procfs.
This change was requested to permit kexec-tools to detect the physical
addressing mode in order to determine the appropriate address mangling.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
While sh previously had its own debugfs root, there now exists a
common arch_debugfs_dir prototype, so we switch everything over to
that. Presumably once more architectures start making use of this
we'll be able to just kill off the stub kdebugfs wrapper.
via following scripts
FILES=$(find * -type f | grep -vE 'oprofile|[^K]config')
sed -i \
-e 's/lmb/memblock/g' \
-e 's/LMB/MEMBLOCK/g' \
$FILES
for N in $(find . -name lmb.[ch]); do
M=$(echo $N | sed 's/lmb/memblock/g')
mv $N $M
done
and remove some wrong change like lmbench and dlmb etc.
also move memblock.c from lib/ to mm/
Suggested-by: Ingo Molnar <mingo@elte.hu>
Acked-by: "H. Peter Anvin" <hpa@zytor.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
arch/sh/kernel/setup.c
In the NUMA or memory hot-add case where system memory has been
partitioned up, we immediately run in to a situation where the existing
PMB entry doesn't cover the new range (primarily as a result of the entry
size being shrunk to match the node size early in the initialization). In
order to fix this up it's necessary to preload a PMB mapping for the new
range prior to activation in order to circumvent reset by MMU.
This reworks much of the bootmem setup and initialization code allowing
us to get rid of duplicate work between the NUMA and non-NUMA cases. The
end result is that we end up with a much more flexible interface for
supporting more complex topologies (fake NUMA, highmem, etc, etc.) which
is entirely LMB backed. This is an incremental step for more NUMA work as
well as gradually enabling migration off of bootmem entirely.
This reworks the memory limit handling to tie in through the available
LMB infrastructure. This requires a bit of reordering as we need to have
all of the LMB reservations taken care of prior to establishing the
limits.
While we're at it, the crash kernel reservation semantics are reworked
so that we allocate from the bottom up and reduce the risk of having
to disable the memory limit due to a clash with the crash kernel
reservation.
This plugs in a memory init callback in the machvec to permit boards to
wire up various bits of memory directly in to LMB. A generic machvec
implementation is provided that simply wraps around the normal
Kconfig-derived memory start/size.
The elfcorehdr parsing was just tossed in setup.c, but nothing outside of
the crash dump code/vmcore bits require it, so we just move it out of the
way, as per ppc.
This bumps up the extra LMB reservations in ordering so that they're
accounted for prior to iterating over the region list. This ensures that
reservations are visible both within the LMB and bootmem context.
This switches over from bootmem -> LMB for the initrd area reservation.
This migrates the crash kernel handling off of bootmem and over to LMB.
Various boot loaders go to various extents to thwart the initrd detection
logic (mostly on account of not being able to be bothered with adhering
to the established boot ABI), so we make the detection logic a bit more
robust. This makes it possible to work around the SDK7786's firmware's
attempts to thwart compressed image booting. Victory is mine.
With the platform ops migration, the definitions still need to be
included in the CONFIG_SMP=n case, so make the asm/smp.h include
explicit.
This cribs the MIPS plat_smp_ops approach for wrapping up the platform
ops. This will allow for mixing and matching different ops on the same
platform in the future.
In the case of NUMA emulation when in range PPNs are being used for
secondary nodes, we need to make sure that the PMB has a mapping for it
before setting up the pgdat. This prevents the MMU from resetting.
This implements a bit of rework for the PMB code, which permits us to
kill off the legacy PMB mode completely. Rather than trusting the boot
loader to do the right thing, we do a quick verification of the PMB
contents to determine whether to have the kernel setup the initial
mappings or whether it needs to mangle them later on instead.
If we're booting from legacy mappings, the kernel will now take control
of them and make them match the kernel's initial mapping configuration.
This is accomplished by breaking the initialization phase out in to
multiple steps: synchronization, merging, and resizing. With the recent
rework, the synchronization code establishes page links for compound
mappings already, so we build on top of this for promoting mappings and
reclaiming unused slots.
At the same time, the changes introduced for the uncached helpers also
permit us to dynamically resize the uncached mapping without any
particular headaches. The smallest page size is more than sufficient for
mapping all of kernel text, and as we're careful not to jump to any far
off locations in the setup code the mapping can safely be resized
regardless of whether we are executing from it or not.
Some devices need to be ioremap'd and accessed very early in the boot
process. It is not possible to use the standard ioremap() function in
this case because that requires kmalloc()'ing some virtual address space
and kmalloc() may not be available so early in boot.
This patch provides fixmap mappings that allow physical address ranges
to be remapped into the kernel address space during the early boot
stages.
Signed-off-by: Matt Fleming <matt@console-pimps.org>
This introduces some much overdue chainsawing of the fixed PMB support.
fixed PMB was introduced initially to work around the fact that dynamic
PMB mode was relatively broken, though they were never intended to
converge. The main areas where there are differences are whether the
system is booted in 29-bit mode or 32-bit mode, and whether legacy
mappings are to be preserved. Any system booting in true 32-bit mode will
not care about legacy mappings, so these are roughly decoupled.
Regardless of the entry point, PMB and 32BIT are directly related as far
as the kernel is concerned, so we also switch back to having one select
the other.
With legacy mappings iterated through and applied in the initialization
path it's now possible to finally merge the two implementations and
permit dynamic remapping overtop of remaining entries regardless of
whether boot mappings are crafted by hand or inherited from the boot
loader.
This is V2 of early serial console support for the sh-sci
driver. The early serial console is using early platform
devices and "earlyprintk". To use this feature the early
platform devices must be broken out to one device per port
and the desired port should be selected on the kernel command
line like: "earlyprintk=sh-sci.N[,baudrate][,keep]"
Signed-off-by: Magnus Damm <damm@opensource.se>
Trivial change for cleaning up the cpuinfo pretty printing on SMP, adds a
newline between CPUs.
The initialisation process differs for CONFIG_PMB and for
CONFIG_PMB_FIXED. For CONFIG_PMB_FIXED we need to register the PMB
entries that were allocated by the bootloader.
There's no need to export the internal PMB functions for allocating,
freeing and modifying PMB entries, etc. This way we can restrict the
interface for PMB.
Also remove the static from pmb_init() so that we have more freedom in
setting up the initial PMB entries and turning on MMU 32bit mode.
arch/sh/mm/cache-sh4.c
So far kernel command line arguments could be passed in by a bootloader
or defined as CONFIG_CMDLINE, which completely overwriting the first one.
This change allows a developer to declare selected kernel parameters in
a kernel configuration (eg. project-specific defconfig), retaining
possibility of passing others by a bootloader.
The obvious examples of the first type are MTD partition or
bigphysarea-like region definitions, while "debug" option or network
configuration should be given by a bootloader or a JTAG boot script.
Signed-off-by: Pawel Moll <pawel.moll@st.com>
Signed-off-by: Stuart Menefy <stuart.menefy@st.com>
Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com>
This adds a family member to struct sh_cpuinfo, which allows us to fall
back more on the probe routines to work out what sort of subtype we are
running on. This will be used by the CPU cache initialization code in
order to first do family-level initialization, followed by subtype-level
optimizations.
Rework the bootmem allocator to use the lmb framework.
This patch reworks the mode pin code to keep the pin
definitions in one place. The mode pins values are now
the value of the bit instead of bit number.
With this patch in place the sh7785 header file contains
mode pin comments. The sh7785 clock code and the sh7785lcr
board code are updated to reflect the new shared mode pins.
Signed-off-by: Magnus Damm <damm@igel.co.jp>
Add mode pin support for the SuperH architecture V2.
With this patch applied the board code can add their
own function to export the cpu mode pin configuration.
In most cases this will be a constant bitmap, but
boards that allow reading this from a register can
instead read out the pin state from hardware.
The code warns if a pin is tested but no board specific
mode pin function has been provided.
Now that everyone is using the clock framework directly and we
unconditionally provide our own calibrate_delay() function, having it
wrapped in an ifndef is no longer useful. So, kill it off.
Add a plat_early_device_setup() function to allow
processor-specific code to register Early Platform Data.
This implements initial support for the SH-Mobile R2R CPU.
Based on Rev 0.11 of the initial SH7724 hardware manual.
Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com>
Triggers -Werror on gcc-4.3:
arch/sh/kernel/setup.c: In function 'early_parse_mem':
arch/sh/kernel/setup.c:111: error: format not a string literal and no format arguments
This adds support for extended ASIDs (up to 16-bits) on newer SH-X3 cores
that implement the PTAEX register and respective functionality. Presently
only the 65nm SH7786 (90nm only supports legacy 8-bit ASIDs).
The main change is in how the PTE is written out when loading the entry
in to the TLB, as well as in how the TLB entry is selectively flushed.
While SH-X2 extended mode splits out the memory-mapped U and I-TLB data
arrays for extra bits, extended ASID mode splits out the address arrays.
While we don't use the memory-mapped data array access, the address
array accesses are necessary for selective TLB flushes, so these are
implemented newly and replace the generic SH-4 implementation.
With this, TLB flushes in switch_mm() are almost non-existent on newer
parts.
This adds preliminary support for the SH7786 CPU subtype.
While this is a dual-core CPU, only UP is supported for now. L2 cache
support is likewise not yet implemented.
More information on this particular CPU subtype is available at:
http://www.renesas.com/fmwk.jsp?cnt=sh7786_root.jsp&fp=/products/mpumcu/superh_family/sh7780_series/sh7786_group/
Signed-off-by: Chris Smith <chris.smith@st.com>
This patch adds support for the SH-2A FPU based SH7201 processor subtype.
Signed-off-by: Peter Griffin <pgriffin@mpc-data.co.uk>
Add support for dynamic crash kernel base address.
