path: root/arch/sh/kernel
2008-05-14lib: create common ascii hex arrayHarvey Harrison
Add a common hex array in hexdump.c so everyone can use it. Add a common hi/lo helper to avoid the shifting masking that is done to get the upper and lower nibbles of a byte value. Pull the pack_hex_byte helper from kgdb as it is opencoded many places in the tree that will be consolidated. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Jason Wessel <jason.wessel@windriver.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-09SH: catch negative denormal_subf1() retval in denormal_add()Roel Kluin
'ix' is unsigned but denormal_subf1() may return a negative int. Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-08sh: intc register modify fixMagnus Damm
Make sure register modifications stay atomic. Fixes processors with shared priority register masking. Dual bitmap masking is unaffected. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-08sh: no high level trigger on some sh3 cpusMagnus Damm
The processor models sh7706, sh7707 and sh7709 don't support high level trigger sense configuration. And the intc code looks like crap these days so what's the difference. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-08sh: clean up sh7710 and sh7720 intc tablesMagnus Damm
Clean up the intc tables by removing unneeded #ifdefs. The vector list is what selects which interrupt sources that should be added, having unsupported bitfields listed is ok as long as the vector is excluded from the list. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-08sh: add interrupt ack code to sh3Magnus Damm
This patch adds interrupt acknowledge code for external interrupt sources on sh3 processors. Only really required for edge triggered interrupts, but we ack regardless of sense configuration. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-08sh: unify external irq pin code for sh3Magnus Damm
This patch unifies the sh3 external irq pin code. It buys us some savings with reduced code redundancy, but the main feature with this change is irq sense selection support for all sh3 processors. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-08sh: reset hardware from early printkMagnus Damm
Reset the transmitter and receiver when setting up early printk. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-08sh: drain and wait for early printkMagnus Damm
Drain by waiting for all characters to be sent, and make sure to wait a little bit after setting up the baud rate. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-08sh: use sci_out() for early printkMagnus Damm
Use sci_out() instead of ctrl_outw() for early printk setup code. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-08sh: add memory resources to /proc/iomemMagnus Damm
Add physical memory resources such as System RAM, Kernel code/data/bss and reserved crash dump area to /proc/iomem. Same strategy as on x86. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-08sh: add kernel bss resourceMagnus Damm
Do like everyone else and have a struct resource for kernel bss. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-08sh: fix sh7705 interrupt vector typoMagnus Damm
Fix sh7705 interrupt sources for vectors 0xc80 and 0xca0. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-08sh: intc_sh5 depends on cayman board for IRQ priority table.Paul Mundt
2008-05-08sh64: Some symbol exports to make the allmodconfig happier.Paul Mundt
2008-05-08sh64: Setup I/D-TLB defaults in SH-5 probe path.Paul Mundt
2008-05-08sh64: Fixup the nommu build.Paul Mundt
2008-05-08sh64: fixups for xtime_lock seqlock conversion.Paul Mundt
2008-05-03unified (weak) sys_pipe implementationUlrich Drepper
This replaces the duplicated arch-specific versions of "sys_pipe()" with one unified implementation. This removes almost 250 lines of duplicated code. It's marked __weak, so that *if* an architecture wants to override the default implementation it can do so by simply having its own replacement version, since many architectures use alternate calling conventions for the 'pipe()' system call for legacy reasons (ie traditional UNIX implementations often return the two file descriptors in registers) I still haven't changed the cris version even though Linus says the BKL isn't needed. The arch maintainer can easily do it if there are really no obstacles. Signed-off-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29sh: use kbuild.h instead of defining macros in asm-offsets.cChristoph Lameter
Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proper __do_softirq() prototypeAdrian Bunk
Add a proper prototype for __do_softirq() in include/linux/interrupt.h Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-18sh: Fix up L2 cache probe.Paul Mundt
SH7723 is the first hard silicon to implement the L2, and unsurprisingly, does the precise inverse of what the specification alleges. XOR the URAM/L2 size bits to get back in line with the existing parsing logic. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-04-18sh: Fix up SH-4A part probe.Paul Mundt
The SH-4A series probe we were relying on doesn't work any more on the newer parts, bump this up to use CVR.CHIP instead so we have consistent behaviour across all of the parts, which is what this should have been testing in the first place. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-04-18sh: Add support for SH7723 CPU subtype.Paul Mundt
This adds basic support for the SH7723 MobileR2 CPU. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-04-18sh: Fix up SH7763 build.Paul Mundt
2008-04-18sh: Add I2C platform data to sh7722Magnus Damm
Add platform data for the SuperH Mobile I2C block to sh7722. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-04-18sh: Use physical addresses for sh7722 USBF resourcesMagnus Damm
Use physical addresses and change resource name to follow data sheet. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-04-18sh: Hook up the rest of the SH7770 serial ports.Paul Mundt
2008-04-18sh: Add support for Solution Engine SH7721 boardYoshihiro Shimoda
Add support for Solution Engine SH7721 board(MS7721RP01). Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-04-18sh: Initial support for the MX-G CPU.Paul Mundt
2008-04-18sh: Create an sh debugfs root.Paul Mundt
2008-04-17Generic semaphore implementationMatthew Wilcox
Semaphores are no longer performance-critical, so a generic C implementation is better for maintainability, debuggability and extensibility. Thanks to Peter Zijlstra for fixing the lockdep warning. Thanks to Harvey Harrison for pointing out that the unlikely() was unnecessary. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2008-04-16sh: export empty_zero_pageAndrew Morton
ERROR: "empty_zero_page" [fs/ext4/ext4dev.ko] undefined! Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-04-16sh: arch/sh/kernel/traps_32.c needs asm/fpu.hAndrew Morton
arch/sh/kernel/traps_32.c: In function `do_reserved_inst': arch/sh/kernel/traps_32.c:667: error: implicit declaration of function `do_fpu_inst' Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-04-16sh64: add missing #include <asm/fpu.h>'sAdrian Bunk
This patch fixes some compile errors due to missing save_fpu() prototypes on sh64 caused by commit 9bbafce2eec190ef7e44b0eb1095ba17ce6ad3af (sh: Fix occasional FPU register corruption under preempt). Signed-off-by: Adrian Bunk <adrian.bunk@movial.fi> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-03-26sh: Fix occasional FPU register corruption under preempt.Paul Mundt
Presently with preempt enabled there's the possibility to be preempted after the TIF_USEDFPU test and the register save, leading to bogus state post-__switch_to(). Use an explicit preempt_disable()/enable() pair around unlazy_fpu()/clear_fpu() to avoid this. Follows the x86 change. Reported-by: Takuo Koguchi <takuo.koguchi.sw@hitachi.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-03-21SH: Use newer, non-deprecated __SPIN_LOCK_UNLOCKED macro.Robert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-03-13sh: Fix up the address error exception handler for SH-2.Kieran Bingham
Presently the SH-2/SH-2A address error exception dispatch copies off the register state from the stack and skips over the first register, skewing the rest. Fix up the math here so that the proper register state is handed down to the exception handler itself. Signed-off-by: Kieran Bingham <kbingham@mpc-data.co.uk> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-03-06sh: Fix up section mismatches.Paul Mundt
2008-03-06sh: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-03-06sh: export copy-page() to modulesAndrew Morton
ERROR: "copy_page" [fs/unionfs/unionfs.ko] undefined! like all the other architectures. Cc: Erez Zadok <ezk@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-03-06sh_ksyms_32.c update for gcc 4.3Adrian Bunk
This patch fixes the following build error with landisk_defconfig when using gcc 4.3: <-- snip --> ... MODPOST 50 modules ERROR: "__udivsi3_i4i" [net/sunrpc/sunrpc.ko] undefined! ERROR: "__udivsi3_i4i" [net/appletalk/appletalk.ko] undefined! ERROR: "__udivsi3_i4i" [fs/ufs/ufs.ko] undefined! ERROR: "__udivsi3_i4i" [fs/ntfs/ntfs.ko] undefined! ERROR: "__sdivsi3_i4i" [fs/ntfs/ntfs.ko] undefined! ERROR: "__udivsi3_i4i" [fs/nfsd/nfsd.ko] undefined! ERROR: "__sdivsi3_i4i" [fs/nfsd/nfsd.ko] undefined! ERROR: "__udivsi3_i4i" [fs/nfs/nfs.ko] undefined! ERROR: "__udivsi3_i4i" [fs/lockd/lockd.ko] undefined! ERROR: "__udivsi3_i4i" [drivers/usb/storage/usb-storage.ko] undefined! ERROR: "__sdivsi3_i4i" [drivers/usb/serial/pl2303.ko] undefined! ERROR: "__udivsi3_i4i" [drivers/usb/serial/pl2303.ko] undefined! ERROR: "__sdivsi3_i4i" [drivers/usb/serial/ftdi_sio.ko] undefined! ERROR: "__udivsi3_i4i" [drivers/usb/misc/sisusbvga/sisusbvga.ko] undefined! ERROR: "__sdivsi3_i4i" [drivers/usb/misc/sisusbvga/sisusbvga.ko] undefined! ERROR: "__udivsi3_i4i" [drivers/media/video/v4l1-compat.ko] undefined! ERROR: "__sdivsi3_i4i" [drivers/media/video/v4l1-compat.ko] undefined! ERROR: "__sdivsi3_i4i" [drivers/media/video/usbvideo/vicam.ko] undefined! ERROR: "__udivsi3_i4i" [drivers/media/video/usbvideo/usbvideo.ko] undefined! ERROR: "__sdivsi3_i4i" [drivers/media/video/usbvideo/usbvideo.ko] undefined! ERROR: "__udivsi3_i4i" [drivers/media/video/sn9c102/sn9c102.ko] undefined! ERROR: "__sdivsi3_i4i" [drivers/media/video/sn9c102/sn9c102.ko] undefined! ERROR: "__sdivsi3_i4i" [drivers/media/video/se401.ko] undefined! ERROR: "__sdivsi3_i4i" [drivers/media/video/pwc/pwc.ko] undefined! ERROR: "__udivsi3_i4i" [drivers/md/raid0.ko] undefined! ERROR: "__udivsi3_i4i" [drivers/md/md-mod.ko] undefined! ERROR: "__sdivsi3_i4i" [drivers/md/md-mod.ko] undefined! ERROR: "__udivsi3_i4i" [drivers/md/linear.ko] undefined! ERROR: "__sdivsi3_i4i" [drivers/hid/usbhid/usbhid.ko] undefined! make[2]: *** [__modpost] Error 1 <-- snip --> Signed-off-by: Adrian Bunk <adrian.bunk@movial.fi> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-02-26serial: Move asm-sh/sci.h to linux/serial_sci.h.Paul Mundt
This header is needed on other architectures as well (namely h8300), which currently fails to build without this in place. Rather than duplicating the port definition completely there, just move this to a common location instead. This should get h8300 working again for 2.6.25, in addition to the changes already pushed by Sato-san in -rc2. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-02-26sh: fix rtc_resources setup for sh770xRafael Ignacio Zurita
Fix the RTC resources setup for sh770x. Whit these proper start values RTC driver (drivers/rtc/rtc-sh.c) works. Signed-off-by: Rafael Ignacio Zurita <rizurita@yahoo.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-02-26sh: Storage class should be before const qualifierTobias Klauser
The C99 specification states in section 6.11.5: The placement of a storage-class specifier other than at the beginning of the declaration specifiers in a declaration is an obsolescent feature. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-02-25sh: Rename SH-3 CCR3 reg to avoid synclink_cs clash.Paul Mundt
drivers/char/pcmcia/synclink_cs.c:284:1: warning: "CCR3" redefined In file included from include/asm/cache.h:13, from include/asm/processor_32.h:15, from include/asm/processor.h:60, from include/linux/prefetch.h:14, from include/linux/list.h:8, from include/linux/module.h:9, from drivers/char/pcmcia/synclink_cs.c:38: include/asm/cpu/cache.h:38:1: warning: this is the location of the previous definition Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-02-14sh: Kill off more dead symbols.Paul Mundt
Reported-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-02-14sh: Get SH-5 caches working again post-unification.Paul Mundt
A number of cleanups to get the SH-5 cache management code in line with the rest of the SH backend. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-02-14sh: Shut up some trivial build warnings.Paul Mundt
2008-02-14sh: Symbol exports for trapped I/O.Paul Mundt
