clk_get() used to return NULL or an errno value depending on whether a
clkdev lookup failed or a clock wasn't found in the primary clock list.
As these disjoint paths were unified and everything now is handled via
clkdev lookups, the NULL case never makes it out of clk_get(). Update
accordingly and always look to the errno value.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Fix the complie error in ehci-hcd.c because it needs an additional
configuration.
CC drivers/usb/host/ehci-hcd.o
drivers/usb/host/ehci-hcd.c:1288:2: error: #error "missing bus glue for ehci-hcd"
make[3]: *** [drivers/usb/host/ehci-hcd.o] Error 1
make[2]: *** [drivers/usb/host] Error 2
make[1]: *** [drivers/usb] Error 2
make: *** [drivers] Error 2
This fixes up build issues for SH7720/SH7722/SH7750 that crept in with
the serial rework.
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-3.x
* 'sh-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-3.x:
sh: sh7724: Add USBHS DMAEngine support
sh: ecovec: Add renesas_usbhs support
sh, exec: remove redundant set_fs(USER_DS)
drivers: sh: resume enabled clocks fix
dmaengine: shdma: SH_DMAC_MAX_CHANNELS message fix
sh: Fix up xchg/cmpxchg corruption with gUSA RB.
sh: Remove compressed kernel libgcc dependency.
sh: fix wrong icache/dcache address-array start addr in cache-debugfs.
Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com>
RTC_CLASS is changed to bool, so 'm' is invalid.
Signed-off-by: Wanlong Gao <wanlong.gao@gmail.com>
Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
The address limit is already set in flush_old_exec() so those calls to
set_fs(USER_DS) are redundant.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
This takes a bit of a sledgehammer to the horribly CPU subtype
ifdef-ridden header and abstracts all of the different register layouts
in to distinct types which in turn can be overriden on a per-port basis,
or permitted to default to the map matching the port type at probe time.
In the process this ultimately fixes up inumerable bugs with mismatches
on various CPU types (particularly the legacy ones that were obviously
broken years ago and no one noticed) and provides a more tightly coupled
and consolidated platform for extending and implementing generic
features.
Several fixes as well where the +1 was missing.
Done via coccinelle scripts like:
struct resource *ptr;
- ptr->end - ptr->start + 1
+ resource_size(ptr)
and some grep and typing.
Mostly uncompiled, no cross-compilers.
Non-SCI parts do not have the special port reg necessary for cases where
the RX and SCI pins are muxed and need to be manually polled, so these
like always fall back on the normal FIFO processing paths. SH7760 is in a
class in and of itself with regards to mapping its SIM card interface via
the SCI port class despite not having any of the RXD lines wired up and
so implicitly behaving more like a SCIF in this regard. Out of the other
CPUs, some support the port check via the same block while others do it
through an external SuperI/O, so it's not even possible to perform the
check relative to the ioremapped cookie offset, so the separate read
semantics are preserved here, too.
gUSA special cases r15 for part of its login/out sequence, meaning that
any parameters need to be explicitly prohibited from accidentally being
assigned that particular register, and the compiler ultimately needs to
use a temporary instead.
Certain configurations have begun generating code paths that do indeed
get allocated r15, resulting in immediate corruption of the exchanged
value. This was observed in (amongst others) exit_mm() code generation
where the xchg_u32 call was immediately corrupting a structure address.
As this is a general gUSA restriction, the rest of the users likewise
need to be updated to ensure sensible constraints.
References: https://bugzilla.stlinux.com/show_bug.cgi?id=11229
Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@st.com>
Reviewed-by: Stuart Menefy <stuart.menefy@st.com>
SH-2A is unable to combine the kernel and libgcc objects due to
fundamental disagreements over FDPIC settings. As the kernel already
contains all of the libgcc bits broken out, there's not much need to
bother with the linking anymore, as everything can already be derived
from the lib dir.
This simply plugs in the necessary bits to ensure that everything is
built uniformly, enabling us to wean the compressed build off of explicit
libgcc linking.
Reported-by: Phil Edworthy <phil.edworthy@renesas.com>
This patch fixes a icache/dcache address-array start address while
dumping its entires in debugfs. Perviously the code was attempting to
remember the address in static variable, which is no more required
for debugfs, as the function can be executed in one pass.
Without this patch the start address ends up in wrong place and the
/sys/kernel/debug/sh/icache or dcache debugfs contents may not be correct.
Cc: Stuart Menefy <stuart.menefy@st.com>
There was an ordering issue with regards to instruction_pointer() being
used in profile_pc() prior to the asm-generic/ptrace.h include, which
subsequently provided the instruction_pointer() definition. In the
interest of simplicity we simply open-code the regs->pc deref for the
profile_pc() definition instead.
The FP functions were also broken due to a lack of a common regs->fp,
so provide a common GET_FP() that is safe for both architectures in order
to fix up the frame pointer helpers too.
sh64 doesn't define a P1SEGADDR, resulting in a build failure. The proper
mapping can be attained for both sh32 and 64 via the CAC_ADDR macro, so
switch to that instead.
Needed to satisfy the __in_29bit_mode() check.
Commit 1e56a56410bb64bce62d44563e35a143fc2d515f introduced the mmu_gather
rework for sh, but missed a linux/swap.h include:
CC arch/sh/mm/tlb-urb.o
In file included from arch/sh/mm/tlb-urb.c:14:0:
arch/sh/include/asm/tlb.h: In function '__tlb_remove_page':
arch/sh/include/asm/tlb.h:92:2: error: implicit declaration of function 'free_page_and_swap_cache'
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
CC: Peter Zijlstra <a.p.zijlstra@chello.nl>
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into sh-fixes-for-linus
* setns:
ns: Wire up the setns system call
Done as a merge to make it easier to fix up conflicts in arm due to
addition of sendmmsg system call
32bit and 64bit on x86 are tested and working. The rest I have looked
at closely and I can't find any problems.
setns is an easy system call to wire up. It just takes two ints so I
don't expect any weird architecture porting problems.
While doing this I have noticed that we have some architectures that are
very slow to get new system calls. cris seems to be the slowest where
the last system calls wired up were preadv and pwritev. avr32 is weird
in that recvmmsg was wired up but never declared in unistd.h. frv is
behind with perf_event_open being the last syscall wired up. On h8300
the last system call wired up was epoll_wait. On m32r the last system
call wired up was fallocate. mn10300 has recvmmsg as the last system
call wired up. The rest seem to at least have syncfs wired up which was
new in the 2.6.39.
v2: Most of the architecture support added by Daniel Lezcano <dlezcano@fr.ibm.com>
v3: ported to v2.6.36-rc4 by: Eric W. Biederman <ebiederm@xmission.com>
v4: Moved wiring up of the system call to another patch
v5: ported to v2.6.39-rc6
v6: rebased onto parisc-next and net-next to avoid syscall conflicts.
v7: ported to Linus's latest post 2.6.39 tree.
> arch/blackfin/include/asm/unistd.h | 3 ++-
> arch/blackfin/mach-common/entry.S | 1 +
Oh - ia64 wiring looks good.
Acked-by: Tony Luck <tony.luck@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6:
PM: Fix PM QOS's user mode interface to work with ASCII input
PM / Hibernate: Update kerneldoc comments in hibernate.c
PM / Hibernate: Remove arch_prepare_suspend()
PM / Hibernate: Update some comments in core hibernate code
By the previous style change, CONFIG_GENERIC_FIND_NEXT_BIT,
CONFIG_GENERIC_FIND_BIT_LE, and CONFIG_GENERIC_FIND_LAST_BIT are not used
to test for existence of find bitops anymore.
Acked-by: Greg Ungerer <gerg@uclinux.org>
The Blackfin arch, like the x86 arch, needs to adjust the PC manually
after a breakpoint is hit as normally this is handled by the remote gdb.
However, rather than starting another arch ifdef mess, create a common
GDB_ADJUSTS_BREAK_OFFSET define for any arch to opt-in via their kgdb.h.
Cc: Jason Wessel <jason.wessel@windriver.com>
Acked-by: Paul Mundt <lethal@linux-sh.org>
Acked-by: Dongdong Deng <dongdong.deng@windriver.com>
Cc: Sergei Shtylyov <sshtylyov@mvista.com>
Cc: Dongdong Deng <dongdong.deng@windriver.com>
The ns_cgroup is an annoying cgroup at the namespace / cgroup frontier and
leads to some problems:
* cgroup creation is out-of-control
* cgroup name can conflict when pids are looping
* it is not possible to have a single process handling a lot of
namespaces without falling in a exponential creation time
* we may want to create a namespace without creating a cgroup
The ns_cgroup was replaced by a compatibility flag 'clone_children',
where a newly created cgroup will copy the parent cgroup values.
The userspace has to manually create a cgroup and add a task to
the 'tasks' file.
This patch removes the ns_cgroup as suggested in the following thread:
https://lists.linux-foundation.org/pipermail/containers/2009-June/018616.html
The 'cgroup_clone' function is removed because it is no longer used.
This is a userspace-visible change. Commit 45531757b45c ("cgroup: notify
ns_cgroup deprecated") (merged into 2.6.27) caused the kernel to emit a
printk warning users that the feature is planned for removal. Since that
time we have heard from XXX users who were affected by this.
Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr>
Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Jamal Hadi Salim <hadi@cyberus.ca>
Reviewed-by: Li Zefan <lizf@cn.fujitsu.com>
Acked-by: Paul Menage <menage@google.com>
Acked-by: Matt Helsley <matthltc@us.ibm.com>
Most arches define CONFIG_DEBUG_STACK_USAGE exactly the same way. Move it
to lib/Kconfig.debug so each arch doesn't have to define it. This
obviously makes the option generic, but that's fine because the config is
already used in generic code.
It's not obvious to me that sysrq-P actually does anything caution by
keeping the most inclusive wording.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Acked-by: Richard Weinberger <richard@nod.at>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Cc: Chen Liqin <liqin.chen@sunplusct.com>
Cc: Lennox Wu <lennox.wu@gmail.com>
Fold all the mmu_gather rework patches into one for submission
Reported-by: Hugh Dickins <hughd@google.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Namhyung Kim <namhyung@gmail.com>
Fix up the sh mmu_gather code to conform to the new API.
This makes it possible to leave DMA slave IDs in the platform data
at default 0 value without hitting DMA channel allocation error paths.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
All architectures supporting hibernation define
arch_prepare_suspend() as an empty function, so remove it.
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-2.6.40' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu:
percpu: Unify input section names
percpu: Avoid extra NOP in percpu_cmpxchg16b_double
percpu: Cast away printk format warning
percpu: Always align percpu output section to PAGE_SIZE
Fix up fairly trivial conflict in arch/x86/include/asm/percpu.h as per Tejun
shmin uses __set_io_port_base() for legacy I/O mapping that ethernet and
other SuperI/O functions depend on. Ensure that PIO support is built in
until the board is updated for MMIO properly.
Trivial build fix for certain configurations that don't grab
linux/prefetch.h via alternate means (specifically SH-2 and SH-3 parts).
Cc: Simon Horman <horms@verge.net.au>
Cc: Magnus Damm <damm@opensource.se>
Use soc_camera_platform helper functions to dynamically manage the
camera device.
Some modules may end up with R_SH_NONE relocs with the right combination
of compiler/kernel config (specifically dwarf unwinder), so simply trap
and ignore them instead of letting them get down to the error path.
Reported-by: Carmelo AMOROSO <carmelo.amoroso@st.com>
Both warning and warning_symbol are nowhere used.
Let's get rid of them.
Signed-off-by: Richard Weinberger <richard@nod.at>
Use an existing local variable, instead of calculating the pointer
multiple times explicitly.
Reviewed-by: Simon Horman <horms@verge.net.au>
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into sh-latest
Commit e66eed651fd1 ("list: remove prefetching from regular list
iterators") removed the include of prefetch.h from list.h, which
uncovered several cases that had apparently relied on that rather
obscure header file dependency.
So this fixes things up a bit, using
grep -L linux/prefetch.h $(git grep -l '[^a-z_]prefetchw*(' -- '*.[ch]')
grep -L 'prefetchw*(' $(git grep -l 'linux/prefetch.h' -- '*.[ch]')
to guide us in finding files that either need <linux/prefetch.h>
inclusion, or have it despite not needing it.
There are more of them around (mostly network drivers), but this gets
many core ones.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6
* 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (44 commits)
debugfs: Silence DEBUG_STRICT_USER_COPY_CHECKS=y warning
sysfs: remove "last sysfs file:" line from the oops messages
drivers/base/memory.c: fix warning due to "memory hotplug: Speed up add/remove when blocks are larger than PAGES_PER_SECTION"
SYSFS: Fix erroneous comments for sysfs_update_group().
driver core: remove the driver-model structures from the documentation
driver core: Add the device driver-model structures to kerneldoc
Translated Documentation/email-clients.txt
RAW driver: Remove call to kobject_put().
reboot: disable usermodehelper to prevent fs access
efivars: prevent oops on unload when efi is not enabled
Allow setting of number of raw devices as a module parameter
Introduce CONFIG_GOOGLE_FIRMWARE
driver: Google Memory Console
driver: Google EFI SMI
x86: Better comments for get_bios_ebda()
x86: get_bios_ebda_length()
misc: fix ti-st build issues
params.c: Use new strtobool function to process boolean inputs
debugfs: move to new strtobool
Fix up trivial conflicts in fs/debugfs/file.c due to the same patch
being applied twice, and an unrelated cleanup nearby.
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (60 commits)
sched: Fix and optimise calculation of the weight-inverse
sched: Avoid going ahead if ->cpus_allowed is not changed
sched, rt: Update rq clock when unthrottling of an otherwise idle CPU
sched: Remove unused parameters from sched_fork() and wake_up_new_task()
sched: Shorten the construction of the span cpu mask of sched domain
sched: Wrap the 'cfs_rq->nr_spread_over' field with CONFIG_SCHED_DEBUG
sched: Remove unused 'this_best_prio arg' from balance_tasks()
sched: Remove noop in alloc_rt_sched_group()
sched: Get rid of lock_depth
sched: Remove obsolete comment from scheduler_tick()
sched: Fix sched_domain iterations vs. RCU
sched: Next buddy hint on sleep and preempt path
sched: Make set_*_buddy() work on non-task entities
sched: Remove need_migrate_task()
sched: Move the second half of ttwu() to the remote cpu
sched: Restructure ttwu() some more
sched: Rename ttwu_post_activation() to ttwu_do_wakeup()
sched: Remove rq argument from ttwu_stat()
sched: Remove rq->lock from the first half of ttwu()
sched: Drop rq->lock from sched_exec()
* 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
sched: Fix rt_rq runtime leakage bug
