path: root/arch/sh
2009-09-24Merge branch 'for-linus' of git://neil.brown.name/mdLinus Torvalds
* 'for-linus' of git://neil.brown.name/md: (97 commits) md: raid-1/10: fix RW bits manipulation md: remove unnecessary memset from multipath. md: report device as congested when suspended md: Improve name of threads created by md_register_thread md: remove sparse warnings about lock context. md: remove sparse waring "symbol xxx shadows an earlier one" async_tx/raid6: add missing dma_unmap calls to the async fail case ioat3: fix uninitialized var warnings drivers/dma/ioat/dma_v2.c: fix warnings raid6test: fix stack overflow ioat2: clarify ring size limits md/raid6: cleanup ops_run_compute6_2 md/raid6: eliminate BUG_ON with side effect dca: module load should not be an error message ioat: driver version 4.0 dca: registering requesters in multiple dca domains async_tx: remove HIGHMEM64G restriction dmaengine: sh: Add Support SuperH DMA Engine driver dmaengine: Move all map_sg/unmap_sg for slave channel to its client fsldma: Add DMA_SLAVE support ...
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: (39 commits) cpumask: Move deprecated functions to end of header. cpumask: remove unused deprecated functions, avoid accusations of insanity cpumask: use new-style cpumask ops in mm/quicklist. cpumask: use mm_cpumask() wrapper: x86 cpumask: use mm_cpumask() wrapper: um cpumask: use mm_cpumask() wrapper: mips cpumask: use mm_cpumask() wrapper: mn10300 cpumask: use mm_cpumask() wrapper: m32r cpumask: use mm_cpumask() wrapper: arm cpumask: Use accessors for cpu_*_mask: um cpumask: Use accessors for cpu_*_mask: powerpc cpumask: Use accessors for cpu_*_mask: mips cpumask: Use accessors for cpu_*_mask: m32r cpumask: remove arch_send_call_function_ipi cpumask: arch_send_call_function_ipi_mask: s390 cpumask: arch_send_call_function_ipi_mask: powerpc cpumask: arch_send_call_function_ipi_mask: mips cpumask: arch_send_call_function_ipi_mask: m32r cpumask: arch_send_call_function_ipi_mask: alpha cpumask: remove obsolete topology_core_siblings and topology_thread_siblings: ia64 ...
2009-09-23headers: utsname.h reduxAlexey Dobriyan
* remove asm/atomic.h inclusion from linux/utsname.h -- not needed after kref conversion * remove linux/utsname.h inclusion from files which do not need it NOTE: it looks like fs/binfmt_elf.c do not need utsname.h, however due to some personality stuff it _is_ needed -- cowardly leave ELF-related headers and files alone. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24cpumask: remove arch_send_call_function_ipiRusty Russell
Now everyone is converted to arch_send_call_function_ipi_mask, remove the shim and the #defines. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-09-24cpumask: remove obsolete node_to_cpumask now everyone uses cpumask_of_nodeRusty Russell
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (30 commits) Use macros for .data.page_aligned section. Use macros for .bss.page_aligned section. Use new __init_task_data macro in arch init_task.c files. kbuild: Don't define ALIGN and ENTRY when preprocessing linker scripts. arm, cris, mips, sparc, powerpc, um, xtensa: fix build with bash 4.0 kbuild: add static to prototypes kbuild: fail build if recordmcount.pl fails kbuild: set -fconserve-stack option for gcc 4.5 kbuild: echo the record_mcount command gconfig: disable "typeahead find" search in treeviews kbuild: fix cc1 options check to ensure we do not use -fPIC when compiling checkincludes.pl: add option to remove duplicates in place markup_oops: use modinfo to avoid confusion with underscored module names checkincludes.pl: provide usage helper checkincludes.pl: close file as soon as we're done with it ctags: usability fix kernel hacking: move STRIP_ASM_SYMS from General gitignore usr/initramfs_data.cpio.bz2 and usr/initramfs_data.cpio.lzma kbuild: Check if linker supports the -X option kbuild: introduce ld-option ... Fix trivial conflict in scripts/basic/fixdep.c
2009-09-23kcore: use registerd physmem informationKAMEZAWA Hiroyuki
For /proc/kcore, each arch registers its memory range by kclist_add(). In usual, - range of physical memory - range of vmalloc area - text, etc... are registered but "range of physical memory" has some troubles. It doesn't updated at memory hotplug and it tend to include unnecessary memory holes. Now, /proc/iomem (kernel/resource.c) includes required physical memory range information and it's properly updated at memory hotplug. Then, it's good to avoid using its own code(duplicating information) and to rebuild kclist for physical memory based on /proc/iomem. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: WANG Cong <xiyou.wangcong@gmail.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23kcore: register vmalloc area in generic wayKAMEZAWA Hiroyuki
For /proc/kcore, vmalloc areas are registered per arch. But, all of them registers same range of [VMALLOC_START...VMALLOC_END) This patch unifies them. By this. archs which have no kclist_add() hooks can see vmalloc area correctly. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23kcore: add kclist typesKAMEZAWA Hiroyuki
Presently, kclist_add() only eats start address and size as its arguments. Considering to make kclist dynamically reconfigulable, it's necessary to know which kclists are for System RAM and which are not. This patch add kclist types as KCORE_RAM KCORE_VMALLOC KCORE_TEXT KCORE_OTHER This "type" is used in a patch following this for detecting KCORE_RAM. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23Merge branch 'next' of ↵NeilBrown
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx into for-linus
2009-09-22arches: drop superfluous casts in nr_free_pages() callersGeert Uytterhoeven
Commit 96177299416dbccb73b54e6b344260154a445375 ("Drop free_pages()") modified nr_free_pages() to return 'unsigned long' instead of 'unsigned int'. This made the casts to 'unsigned long' in most callers superfluous, so remove them. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Mikael Starvik <starvik@axis.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Chris Zankel <zankel@tensilica.com> Cc: Michal Simek <monstr@monstr.eu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-21Merge branch 'perfcounters-rename-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perfcounters-rename-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf: Tidy up after the big rename perf: Do the big rename: Performance Counters -> Performance Events perf_counter: Rename 'event' to event_id/hw_event perf_counter: Rename list_entry -> group_entry, counter_list -> group_list Manually resolved some fairly trivial conflicts with the tracing tree in include/trace/ftrace.h and kernel/trace/trace_syscalls.c.
2009-09-21perf: Do the big rename: Performance Counters -> Performance EventsIngo Molnar
Bye-bye Performance Counters, welcome Performance Events! In the past few months the perfcounters subsystem has grown out its initial role of counting hardware events, and has become (and is becoming) a much broader generic event enumeration, reporting, logging, monitoring, analysis facility. Naming its core object 'perf_counter' and naming the subsystem 'perfcounters' has become more and more of a misnomer. With pending code like hw-breakpoints support the 'counter' name is less and less appropriate. All in one, we've decided to rename the subsystem to 'performance events' and to propagate this rename through all fields, variables and API names. (in an ABI compatible fashion) The word 'event' is also a bit shorter than 'counter' - which makes it slightly more convenient to write/handle as well. Thanks goes to Stephane Eranian who first observed this misnomer and suggested a rename. User-space tooling and ABI compatibility is not affected - this patch should be function-invariant. (Also, defconfigs were not touched to keep the size down.) This patch has been generated via the following script: FILES=$(find * -type f | grep -vE 'oprofile|[^K]config') sed -i \ -e 's/PERF_EVENT_/PERF_RECORD_/g' \ -e 's/PERF_COUNTER/PERF_EVENT/g' \ -e 's/perf_counter/perf_event/g' \ -e 's/nb_counters/nb_events/g' \ -e 's/swcounter/swevent/g' \ -e 's/tpcounter_event/tp_event/g' \ $FILES for N in $(find . -name perf_counter.[ch]); do M=$(echo $N | sed 's/perf_counter/perf_event/g') mv $N $M done FILES=$(find . -name perf_event.*) sed -i \ -e 's/COUNTER_MASK/REG_MASK/g' \ -e 's/COUNTER/EVENT/g' \ -e 's/\<event\>/event_id/g' \ -e 's/counter/event/g' \ -e 's/Counter/Event/g' \ $FILES ... to keep it as correct as possible. This script can also be used by anyone who has pending perfcounters patches - it converts a Linux kernel tree over to the new naming. We tried to time this change to the point in time where the amount of pending patches is the smallest: the end of the merge window. Namespace clashes were fixed up in a preparatory patch - and some stylistic fallout will be fixed up in a subsequent patch. ( NOTE: 'counters' are still the proper terminology when we deal with hardware registers - and these sed scripts are a bit over-eager in renaming them. I've undone some of that, but in case there's something left where 'counter' would be better than 'event' we can undo that on an individual basis instead of touching an otherwise nicely automated patch. ) Suggested-by: Stephane Eranian <eranian@google.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Paul Mackerras <paulus@samba.org> Reviewed-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: <linux-arch@vger.kernel.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-21Use macros for .bss.page_aligned section.Tim Abbott
This patch changes the remaining direct references to .bss.page_aligned in C and assembly code to use the macros in include/linux/linkage.h. Signed-off-by: Tim Abbott <tabbott@ksplice.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-09-21Use new __init_task_data macro in arch init_task.c files.Joe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Tim Abbott <tabbott@ksplice.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-09-20kbuild: rename ld-option to cc-ldoptionSam Ravnborg
ld-option is misnamed as it test options to gcc, not to ld. Renamed it to reflect this. Cc: Andi Kleen <andi@firstfloor.org> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-09-20kbuild: use INSTALLKERNEL to select customized installkernel scriptSam Ravnborg
Replace the use of CROSS_COMPILE to select a customized installkernel script with the possibility to set INSTALLKERNEL to select a custom installkernel script when running make: make INSTALLKERNEL=arm-installkernel install With this patch we are now more consistent across different architectures - they did not all support use of CROSS_COMPILE. The use of CROSS_COMPILE was a hack as this really belongs to gcc/binutils and the installkernel script does not change just because we change toolchain. The use of CROSS_COMPILE caused troubles with an upcoming patch that saves CROSS_COMPILE when a kernel is built - it would no longer be installable. [Thanks to Peter Z. for this hint] This patch undos what Ian did in commit: 0f8e2d62fa04441cd12c08ce521e84e5bd3f8a46 ("use ${CROSS_COMPILE}installkernel in arch/*/boot/install.sh") The patch has been lightly tested on x86 only - but all changes looks obvious. Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Mike Frysinger <vapier@gentoo.org> [blackfin] Acked-by: Russell King <linux@arm.linux.org.uk> [arm] Acked-by: Paul Mundt <lethal@linux-sh.org> [sh] Acked-by: "H. Peter Anvin" <hpa@zytor.com> [x86] Cc: Ian Campbell <icampbell@arcom.com> Cc: Tony Luck <tony.luck@intel.com> [ia64] Cc: Fenghua Yu <fenghua.yu@intel.com> [ia64] Cc: Hirokazu Takata <takata@linux-m32r.org> [m32r] Cc: Geert Uytterhoeven <geert@linux-m68k.org> [m68k] Cc: Kyle McMartin <kyle@mcmartin.ca> [parisc] Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> [powerpc] Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390] Cc: Thomas Gleixner <tglx@linutronix.de> [x86] Cc: Ingo Molnar <mingo@redhat.com> [x86] Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-09-19V4L/DVB (12509): sh: prepare board-ap325rxa.c for v4l2-subdev conversionGuennadi Liakhovetski
We will be registering and unregistering the soc_camera_platform platform device multiple times, therefore we need a .release() method and have to nullify the kobj. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12507): sh: soc-camera updatesGuennadi Liakhovetski
Update ap325rxa to specify .bus_id in struct soc_camera_link explicitly, remove unused .iface from struct soc_camera_platform_info. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12505): soc_camera_platform: pass device pointer from soc-camera ↵Guennadi Liakhovetski
core on .add_device() Add a struct device pointer to struct soc_camera_platform_info and let the user (ap325rxa) pass it down to soc_camera_platform.c in its .add_device() method. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-19V4L/DVB (12504): soc-camera: prepare soc_camera_platform.c and its users for ↵Guennadi Liakhovetski
conversion soc_camera_platform.c is only used by y SuperH ap325rxa board. This patch converts soc_camera_platform.c and its users for the soc-camera platform- device conversion and also extends soc-camera core to handle non-I2C cameras. Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (262 commits) sh: mach-ecovec24: Add user debug switch support sh: Kill off unused se_skipped in alignment trap notification code. sh: Wire up HAVE_SYSCALL_TRACEPOINTS. video: sh_mobile_lcdcfb: use both register sets for display panning video: sh_mobile_lcdcfb: implement display panning sh: Fix up sh7705 flush_dcache_page() build. sh: kfr2r09: document the PLL/FLL <-> RF relationship. sh: mach-ecovec24: need asm/clock.h. sh: mach-ecovec24: deassert usb irq on boot. sh: Add KEYSC support for EcoVec24 sh: add kycr2_delay for sh_keysc sh: cpufreq: Include CPU id in info messages. sh: multi-evt support for SH-X3 proto CPU. sh: clkfwk: remove bogus set_bus_parent() from SH7709. sh: Fix the indication point of the liquid crystal of AP-325RXA(AP3300) sh: Add EcoVec24 romImage defconfig sh: USB disable process is needed if romImage boot for EcoVec24 sh: EcoVec24: add HIZA setting for LED sh: EcoVec24: write MAC address in boot sh: Add romImage support for EcoVec24 ...
2009-09-18Merge branch 'timers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (34 commits) time: Prevent 32 bit overflow with set_normalized_timespec() clocksource: Delay clocksource down rating to late boot clocksource: clocksource_select must be called with mutex locked clocksource: Resolve cpu hotplug dead lock with TSC unstable, fix crash timers: Drop a function prototype clocksource: Resolve cpu hotplug dead lock with TSC unstable timer.c: Fix S/390 comments timekeeping: Fix invalid getboottime() value timekeeping: Fix up read_persistent_clock() breakage on sh timekeeping: Increase granularity of read_persistent_clock(), build fix time: Introduce CLOCK_REALTIME_COARSE x86: Do not unregister PIT clocksource on PIT oneshot setup/shutdown clocksource: Avoid clocksource watchdog circular locking dependency clocksource: Protect the watchdog rating changes with clocksource_mutex clocksource: Call clocksource_change_rating() outside of watchdog_lock timekeeping: Introduce read_boot_clock timekeeping: Increase granularity of read_persistent_clock() timekeeping: Update clocksource with stop_machine timekeeping: Add timekeeper read_clock helper functions timekeeping: Move NTP adjusted clock multiplier to struct timekeeper ... Fix trivial conflict due to MIPS lemote -> loongson renaming.
2009-09-17Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (37 commits) sched: Fix SD_POWERSAVING_BALANCE|SD_PREFER_LOCAL vs SD_WAKE_AFFINE sched: Stop buddies from hogging the system sched: Add new wakeup preemption mode: WAKEUP_RUNNING sched: Fix TASK_WAKING & loadaverage breakage sched: Disable wakeup balancing sched: Rename flags to wake_flags sched: Clean up the load_idx selection in select_task_rq_fair sched: Optimize cgroup vs wakeup a bit sched: x86: Name old_perf in a unique way sched: Implement a gentler fair-sleepers feature sched: Add SD_PREFER_LOCAL sched: Add a few SYNC hint knobs to play with sched: Fix sync wakeups again sched: Add WF_FORK sched: Rename sync arguments sched: Rename select_task_rq() argument sched: Feature to disable APERF/MPERF cpu_power x86: sched: Provide arch implementations using aperf/mperf x86: Add generic aperf/mperf code x86: Move APERF/MPERF into a X86_FEATURE ... Fix up trivial conflict in arch/x86/include/asm/processor.h due to nearby addition of amd_get_nb_id() declaration from the EDAC merge.
2009-09-17sh: mach-ecovec24: Add user debug switch supportKuninori Morimoto
Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-09-16Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (75 commits) PCI hotplug: clean up acpi_run_hpp() PCI hotplug: acpiphp: use generic pci_configure_slot() PCI hotplug: shpchp: use generic pci_configure_slot() PCI hotplug: pciehp: use generic pci_configure_slot() PCI hotplug: add pci_configure_slot() PCI hotplug: clean up acpi_get_hp_params_from_firmware() interface PCI hotplug: acpiphp: don't cache hotplug_params in acpiphp_bridge PCI hotplug: acpiphp: remove superfluous _HPP/_HPX evaluation PCI: Clear saved_state after the state has been restored PCI PM: Return error codes from pci_pm_resume() PCI: use dev_printk in quirk messages PCI / PCIe portdrv: Fix pcie_portdrv_slot_reset() PCI Hotplug: convert acpi_pci_detect_ejectable() to take an acpi_handle PCI Hotplug: acpiphp: find bridges the easy way PCI: pcie portdrv: remove unused variable PCI / ACPI PM: Propagate wake-up enable for devices w/o ACPI support ACPI PM: Replace wakeup.prepared with reference counter PCI PM: Introduce device flag wakeup_prepared PCI / ACPI PM: Rework some debug messages PCI PM: Simplify PCI wake-up code ... Fixed up conflict in arch/powerpc/kernel/pci_64.c due to OF device tree scanning having been moved and merged for the 32- and 64-bit cases. The 'needs_freset' initialization added in 6e19314cc ("PCI/powerpc: support PCIe fundamental reset") is now in arch/powerpc/kernel/pci_of_scan.c.
2009-09-16sched: Disable wakeup balancingPeter Zijlstra
Sysbench thinks SD_BALANCE_WAKE is too agressive and kbuild doesn't really mind too much, SD_BALANCE_NEWIDLE picks up most of the slack. On a dual socket, quad core, dual thread nehalem system: sysbench (--num_threads=16): SD_BALANCE_WAKE-: 13982 tx/s SD_BALANCE_WAKE+: 15688 tx/s kbuild (-j16): SD_BALANCE_WAKE-: 47.648295846 seconds time elapsed ( +- 0.312% ) SD_BALANCE_WAKE+: 47.608607360 seconds time elapsed ( +- 0.026% ) (same within noise) Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-16sh: Kill off unused se_skipped in alignment trap notification code.Paul Mundt
Nothing is using this, resulting in a build error with certain configurations. Just kill it off. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-09-16sh: Wire up HAVE_SYSCALL_TRACEPOINTS.Paul Mundt
This is necessary to get ftrace syscall tracing working again.. a fairly trivial and mechanical change. The one benefit is that this can also be enabled on sh64, despite not having its own ftrace port. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-09-16Merge branch 'master' of ↵Paul Mundt
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: arch/sh/kernel/vmlinux.lds.S
2009-09-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (46 commits) powerpc64: convert to dynamic percpu allocator sparc64: use embedding percpu first chunk allocator percpu: kill lpage first chunk allocator x86,percpu: use embedding for 64bit NUMA and page for 32bit NUMA percpu: update embedding first chunk allocator to handle sparse units percpu: use group information to allocate vmap areas sparsely vmalloc: implement pcpu_get_vm_areas() vmalloc: separate out insert_vmalloc_vm() percpu: add chunk->base_addr percpu: add pcpu_unit_offsets[] percpu: introduce pcpu_alloc_info and pcpu_group_info percpu: move pcpu_lpage_build_unit_map() and pcpul_lpage_dump_cfg() upward percpu: add @align to pcpu_fc_alloc_fn_t percpu: make @dyn_size mandatory for pcpu_setup_first_chunk() percpu: drop @static_size from first chunk allocators percpu: generalize first chunk allocator selection percpu: build first chunk allocators selectively percpu: rename 4k first chunk allocator to page percpu: improve boot messages percpu: fix pcpu_reclaim() locking ... Fix trivial conflict as by Tejun Heo in kernel/sched.c
2009-09-15sched: Reduce forkexec_idxPeter Zijlstra
If we're looking to place a new task, we might as well find the idlest position _now_, not 1 tick ago. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-15sched: Improve latencies and throughputMike Galbraith
Make the idle balancer more agressive, to improve a x264 encoding workload provided by Jason Garrett-Glaser: NEXT_BUDDY NO_LB_BIAS encoded 600 frames, 252.82 fps, 22096.60 kb/s encoded 600 frames, 250.69 fps, 22096.60 kb/s encoded 600 frames, 245.76 fps, 22096.60 kb/s NO_NEXT_BUDDY LB_BIAS encoded 600 frames, 344.44 fps, 22096.60 kb/s encoded 600 frames, 346.66 fps, 22096.60 kb/s encoded 600 frames, 352.59 fps, 22096.60 kb/s NO_NEXT_BUDDY NO_LB_BIAS encoded 600 frames, 425.75 fps, 22096.60 kb/s encoded 600 frames, 425.45 fps, 22096.60 kb/s encoded 600 frames, 422.49 fps, 22096.60 kb/s Peter pointed out that this is better done via newidle_idx, not via LB_BIAS, newidle balancing should look for where there is load _now_, not where there was load 2 ticks ago. Worst-case latencies are improved as well as no buddies means less vruntime spread. (as per prior lkml discussions) This change improves kbuild-peak parallelism as well. Reported-by: Jason Garrett-Glaser <darkshikari@gmail.com> Signed-off-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1253011667.9128.16.camel@marge.simson.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-15sched: Tweak wake_idxPeter Zijlstra
When merging select_task_rq_fair() and sched_balance_self() we lost the use of wake_idx, restore that and set them to 0 to make wake balancing more aggressive. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-15sched: Merge select_task_rq_fair() and sched_balance_self()Peter Zijlstra
The problem with wake_idle() is that is doesn't respect things like cpu_power, which means it doesn't deal well with SMT nor the recent RT interaction. To cure this, it needs to do what sched_balance_self() does, which leads to the possibility of merging select_task_rq_fair() and sched_balance_self(). Modify sched_balance_self() to: - update_shares() when walking up the domain tree, (it only called it for the top domain, but it should have done this anyway), which allows us to remove this ugly bit from try_to_wake_up(). - do wake_affine() on the smallest domain that contains both this (the waking) and the prev (the wakee) cpu for WAKE invocations. Then use the top-down balance steps it had to replace wake_idle(). This leads to the dissapearance of SD_WAKE_BALANCE and SD_WAKE_IDLE_FAR, with SD_WAKE_IDLE replaced with SD_BALANCE_WAKE. SD_WAKE_AFFINE needs SD_BALANCE_WAKE to be effective. Touch all topology bits to replace the old with new SD flags -- platforms might need re-tuning, enabling SD_BALANCE_WAKE conditionally on a NUMA distance seems like a good additional feature, magny-core and small nehalem systems would want this enabled, systems with slow interconnects would not. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-15video: sh_mobile_lcdcfb: use both register sets for display panningPhil Edworthy
Switch to using both register sets - side A and side B for display panning. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-09-15sh: Fix up sh7705 flush_dcache_page() build.Paul Mundt
Type mismatch caused the page deref to blow up, fix it up as per the sh4 change. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-09-15sh: kfr2r09: document the PLL/FLL <-> RF relationship.Kuninori Morimoto
Early clock initialization sets up PLL/FLL values for optimal RF behaviour. As this relationship is presently undocumented, we document this in the script so the rationale is apparent. Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-09-15sh: mach-ecovec24: need asm/clock.h.Kuninori Morimoto
Fixes up build failures. Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-09-15sh: mach-ecovec24: deassert usb irq on boot.Kuninori Morimoto
This patch prevents the USB1 interrupt from remaining asserted immediately after re-boot or during a jump in to a secondary kernel. Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-09-15sh: Add KEYSC support for EcoVec24Kuninori Morimoto
2009-09-15sh: add kycr2_delay for sh_keyscKuninori Morimoto
After KYCR2 is set, udelay might become necessary if there are only a small number of keys attached. This patch introduces an optional delay through the platform data to address this problem. Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-09-15sh: cpufreq: Include CPU id in info messages.Paul Mundt
This tidies up the printks when running on SMP, and aids in debugging when certain cores are unable to be scaled. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-09-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1623 commits) netxen: update copyright netxen: fix tx timeout recovery netxen: fix file firmware leak netxen: improve pci memory access netxen: change firmware write size tg3: Fix return ring size breakage netxen: build fix for INET=n cdc-phonet: autoconfigure Phonet address Phonet: back-end for autoconfigured addresses Phonet: fix netlink address dump error handling ipv6: Add IFA_F_DADFAILED flag net: Add DEVTYPE support for Ethernet based devices mv643xx_eth.c: remove unused txq_set_wrr() ucc_geth: Fix hangs after switching from full to half duplex ucc_geth: Rearrange some code to avoid forward declarations phy/marvell: Make non-aneg speed/duplex forcing work for 88E1111 PHYs drivers/net/phy: introduce missing kfree drivers/net/wan: introduce missing kfree net: force bridge module(s) to be GPL Subject: [PATCH] appletalk: Fix skb leak when ipddp interface is not loaded ... Fixed up trivial conflicts: - arch/x86/include/asm/socket.h converted to <asm-generic/socket.h> in the x86 tree. The generic header has the same new #define's, so that works out fine. - drivers/net/tun.c fix conflict between 89f56d1e9 ("tun: reuse struct sock fields") that switched over to using 'tun->socket.sk' instead of the redundantly available (and thus removed) 'tun->sk', and 2b980dbd ("lsm: Add hooks to the TUN driver") which added a new 'tun->sk' use. Noted in 'next' by Stephen Rothwell.
2009-09-14sh: multi-evt support for SH-X3 proto CPU.Paul Mundt
This adds support for multiple vectors per unique IRQ masking source on the SH-X3 proto CPU. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-09-14sh: clkfwk: remove bogus set_bus_parent() from SH7709.Rafael Ignacio Zurita
This fixes up broken clock re-parenting undertaken by the SH7709 clock framework code, which is currently in conflict with the legacy CPG framework. With this change in place, the legacy CPG ancestry is used, and we manage to avoid contending on the clock_list_sem mutex, which is already held under the legacy registration path, resulting in livelock. In order for SH7709 to fully support the varying clock modes, it needs to implement a more complete clock framework. After this change it is in sync with legacy CPG mode, which ends up being the default configuration for this CPU anyways. Signed-off-by: Rafael Ignacio Zurita <rizurita@yahoo.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-09-11sh: Fix the indication point of the liquid crystal of AP-325RXA(AP3300)Yusuke Goda
Signed-off-by: Yusuke Goda <goda.yusuke@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-09-11sh: Add EcoVec24 romImage defconfigKuninori Morimoto
2009-09-11sh: USB disable process is needed if romImage boot for EcoVec24Kuninori Morimoto
when you use romImage on EcoVec24, 1st Linux will enable USB device. But no-one disable it. So re-started Linux will get interrupt before USB driver is attached. This patch disable USB device at first Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-09-11sh: EcoVec24: add HIZA setting for LEDKuninori Morimoto
