Bug 200004122
drivers/cpufreq/cpufreq.c
drivers/regulator/core.c
sound/soc/codecs/max98090.c
Change-Id: I9418a05ad5c56b2e902249218bac2fa594d99f56
Signed-off-by: Ishan Mittal <imittal@nvidia.com>
commit a0c32761e73c9999cbf592b702f284221fea8040 upstream.
Kees reported the following error:
arch/sh/kernel/dumpstack.c: In function 'print_trace_address':
arch/sh/kernel/dumpstack.c:118:2: error: format not a string literal and no format arguments [-Werror=format-security]
Use the "%s" format so that it's impossible to interpret 'data' as a
format string.
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
Reported-by: Kees Cook <keescook@chromium.org>
arch/avr32/include/asm/Kbuild
arch/c6x/include/asm/Kbuild
arch/cris/include/asm/Kbuild
arch/ia64/include/asm/Kbuild
arch/mips/include/asm/Kbuild
arch/openrisc/include/asm/Kbuild
arch/powerpc/include/asm/Kbuild
arch/score/include/asm/Kbuild
Change-Id: I6800e3f03dbc40e94de1495459dec4b29df4474e
(cherry picked from commit e3fec2f74f7f90d2149a24243a4d040caabe6f30)
We've switched over every architecture that supports SMP to it, so
remove the new useless config variable.
arch/arm/Kconfig
block/blk-mq.c
Change-Id: Ic19c3ac07a38a1636d6aa2fed5e55a58833f9b2c
Cc: Jan Kara <jack@suse.cz>
(cherry picked from commit 0a06ff068f1255bcd7965ab07bc0f4adc3eb639a)
In order to prepare to per-arch implementations of preempt_count move
the required bits into an asm-generic header and use this for all
archs.
(cherry picked from commit a787870924dbd6f321661e06d4ec1c7a408c9ccf)
arch/h8300/include/asm/Kbuild
include/linux/preempt.h
Change-Id: I544914d3c23cc50da658296a34f9f2796854e259
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/n/tip-h5j0c1r3e3fk015m30h8f1zx@git.kernel.org
Bug 1456092
Change-Id: I3021247ec68a3c2dddd9e98cde13d70a45191d53
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
commit 53a52f17d96c8d47c79a7dafa81426317e89c7c1 upstream.
arch/sh/kernel/kgdb.c: In function 'sleeping_thread_to_gdb_regs':
arch/sh/kernel/kgdb.c:225:32: error: implicit declaration of function 'task_stack_page' [-Werror=implicit-function-declaration]
arch/sh/kernel/kgdb.c:242:23: error: dereferencing pointer to incomplete type
arch/sh/kernel/kgdb.c:243:22: error: dereferencing pointer to incomplete type
arch/sh/kernel/kgdb.c: In function 'singlestep_trap_handler':
arch/sh/kernel/kgdb.c:310:27: error: 'SIGTRAP' undeclared (first use in this function)
arch/sh/kernel/kgdb.c:310:27: note: each undeclared identifier is reported only once for each function it appears in
This was introduced by commit 16559ae48c76 ("kgdb: remove #include
<linux/serial_8250.h> from kgdb.h").
[geert@linux-m68k.org: reworded and reformatted]
Signed-off-by: Wanlong Gao <gaowanlong@cn.fujitsu.com>
Signed-off-by: Geert Uytterhoeven <geert+renesas@linux-m68k.org>
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
sh_ksyms_32.c
commit ad70b029d2c678386384bd72c7fa2705c449b518 upstream.
Min_low_pfn and max_low_pfn were used in pfn_valid macro if defined
CONFIG_FLATMEM. When the functions that use the pfn_valid is used in
driver module, max_low_pfn and min_low_pfn is to undefined, and fail to
build.
ERROR: "min_low_pfn" [drivers/block/aoe/aoe.ko] undefined!
ERROR: "max_low_pfn" [drivers/block/aoe/aoe.ko] undefined!
make[2]: *** [__modpost] Error 1
make[1]: *** [modules] Error 2
This patch fix this problem.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Cc: Kuninori Morimoto <kuninori.morimoto.gx@gmail.com>
commit 84ed8a99058e61567f495cc43118344261641c5f upstream.
E.g. landisk_defconfig, which has CONFIG_NTFS_FS=m:
ERROR: "__ashrdi3" [fs/ntfs/ntfs.ko] undefined!
For "lib-y", if no symbols in a compilation unit are referenced by other
units, the compilation unit will not be included in vmlinux. This
breaks modules that do reference those symbols.
Use "obj-y" instead to fix this.
http://kisskb.ellerman.id.au/kisskb/buildresult/8838077/
This doesn't fix all cases. There are others, e.g. udivsi3.
This is also not limited to sh, many architectures handle this in the
same way.
A simple solution is to unconditionally include all helper functions.
A more complex solution is to make the choice of "lib-y" or "obj-y" depend
on CONFIG_MODULES:
obj-$(CONFIG_MODULES) += ...
lib-y($CONFIG_MODULES) += ...
Tested-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Reviewed-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Unlike global OOM handling, memory cgroup code will invoke the OOM killer
in any OOM situation because it has no way of telling faults occuring in
kernel context - which could be handled more gracefully - from
user-triggered faults.
Pass a flag that identifies faults originating in user space from the
architecture-specific fault handlers to generic code so that memcg OOM
handling can be improved.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Cc: azurIt <azurit@pobox.sk>
(cherry picked from commit 407c454cb0ac6e68ca66974da787a71118cfef84)
arch/arc/mm/fault.c
arch/arm64/mm/fault.c
arch/metag/mm/fault.c
arch/parisc/mm/fault.c
Change-Id: Iee53942737627be8dd8e2e325b5ba87fe85d6814
Signed-off-by: Prashant Gaikwad <pgaikwad@nvidia.com>
Reviewed-on: http://git-master/r/266410
GVS: Gerrit_Virtual_Submit
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
commit 2b047252d087be7f2ba088b4933cd904f92e6fce upstream.
Ben Tebulin reported:
"Since v3.7.2 on two independent machines a very specific Git
repository fails in 9/10 cases on git-fsck due to an SHA1/memory
failures. This only occurs on a very specific repository and can be
reproduced stably on two independent laptops. Git mailing list ran
out of ideas and for me this looks like some very exotic kernel issue"
and bisected the failure to the backport of commit 53a59fc67f97 ("mm:
limit mmu_gather batching to fix soft lockups on !CONFIG_PREEMPT").
That commit itself is not actually buggy, but what it does is to make it
much more likely to hit the partial TLB invalidation case, since it
introduces a new case in tlb_next_batch() that previously only ever
happened when running out of memory.
The real bug is that the TLB gather virtual memory range setup is subtly
buggered. It was introduced in commit 597e1c3580b7 ("mm/mmu_gather:
enable tlb flush range in generic mmu_gather"), and the range handling
was already fixed at least once in commit e6c495a96ce0 ("mm: fix the TLB
range flushed when __tlb_remove_page() runs out of slots"), but that fix
was not complete.
The problem with the TLB gather virtual address range is that it isn't
set up by the initial tlb_gather_mmu() initialization (which didn't get
the TLB range information), but it is set up ad-hoc later by the
functions that actually flush the TLB. And so any such case that forgot
to update the TLB range entries would potentially miss TLB invalidates.
Rather than try to figure out exactly which particular ad-hoc range
setup was missing (I personally suspect it's the hugetlb case in
zap_huge_pmd(), which didn't have the same logic as zap_pte_range()
did), this patch just gets rid of the problem at the source: make the
TLB range information available to tlb_gather_mmu(), and initialize it
when initializing all the other tlb gather fields.
This makes the patch larger, but conceptually much simpler. And the end
result is much more understandable; even if you want to play games with
partial ranges when invalidating the TLB contents in chunks, now the
range information is always there, and anybody who doesn't want to
bother with it won't introduce subtle bugs.
Ben verified that this fixes his problem.
Reported-bisected-and-tested-by: Ben Tebulin <tebulin@googlemail.com>
Build-testing-by: Stephen Rothwell <sfr@canb.auug.org.au>
Build-testing-by: Richard Weinberger <richard.weinberger@gmail.com>
Acked-by: Peter Zijlstra <peterz@infradead.org>
Pull removal of GENERIC_GPIO from Grant Likely:
"GENERIC_GPIO now synonymous with GPIOLIB. There are no longer any
valid cases for enableing GENERIC_GPIO without GPIOLIB, even though it
is possible to do so which has been causing confusion and breakage.
This branch does the work to completely eliminate GENERIC_GPIO."
* tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux:
gpio: update gpio Chinese documentation
Remove GENERIC_GPIO config option
Convert selectors of GENERIC_GPIO to GPIOLIB
blackfin: force use of gpiolib
m68k: coldfire: use gpiolib
mips: pnx833x: remove requirement for GENERIC_GPIO
openrisc: default GENERIC_GPIO to false
avr32: default GENERIC_GPIO to false
xtensa: remove explicit selection of GENERIC_GPIO
sh: replace CONFIG_GENERIC_GPIO by CONFIG_GPIOLIB
powerpc: remove redundant GENERIC_GPIO selection
unicore32: default GENERIC_GPIO to false
unicore32: remove unneeded select GENERIC_GPIO
arm: plat-orion: use GPIO driver on CONFIG_GPIOLIB
arm: remove redundant GENERIC_GPIO selection
mips: alchemy: require gpiolib
mips: txx9: change GENERIC_GPIO to GPIOLIB
mips: loongson: use GPIO driver on CONFIG_GPIOLIB
mips: remove redundant GENERIC_GPIO select
Pull ARM SoC platform updates (part 2) from Arnd Bergmann:
"These patches are all for Renesas shmobile, and depend on the earlier
pinctrl updates. Remarkably, this adds support for three new SoCs:
r8a73a4, r8a73a4 and r8a7778. The bulk of the code added for these is
for pinctrl (using the new subsystem) and for clocks (not yet using
the common clock subsystem). The latter will have to get converted in
one of the upcoming releases, but shmobile is not ready for that yet.
The series also contains Renesas shmobile board changes, adding one
board file for each of the three new SoCs. These boards are using a
mix of classic and device-tree based probing, as there is still a lot
of infrastructure in shmobile that has not been converted to DT yet.
Once those are resolved to the degree that no board specific setup
code is needed, they can get folded into the respective SoC setup files."
* tag 'soc-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (78 commits)
ARM: shmobile: use r8a7790 timer setup code on Lager
ARM: shmobile: force enable of r8a7790 arch timer
ARM: shmobile: Add second I/O range for r8a7790 PFC
ARM: shmobile: bockw: enable network settings on bootargs
ARM: shmobile: bockw: add SMSC ethernet support
ARM: shmobile: R8A7778: add Ether support
ARM: shmobile: bockw: enable SMSC ethernet on defconfig
ARM: shmobile: r8a7778: add r8a7778_init_irq_extpin()
ARM: shmobile: r8a7778: remove pointless PLATFORM_INFO()
ARM: shmobile: mackerel: clean up MMCIF vs. SDHI1 selection
ARM: shmobile: mackerel: add interrupt names for SDHI0
ARM: shmobile: mackerel: switch SDHI and MMCIF interfaces to slot-gpio
ARM: shmobile: mackerel: remove OCR masks, where regulators are used
ARM: shmobile: mackerel: SDHI resources do not have to be numbered
ARM: shmobile: Initial r8a7790 Lager board support
ARM: shmobile: APE6EVM LAN9220 support
ARM: shmobile: APE6EVM PFC support
ARM: shmobile: APE6EVM base support
ARM: shmobile: kzm9g-reference: add ethernet support
ARM: shmobile: add R-Car M1A Bock-W platform support
Cc: vger.kernel.org
Pull ARM SoC pinctrl changes for Renesas from Olof Johansson:
"This is yet another driver change, which is split out just because of
its size. As already in 3.9, a lot of changes are going on here, as
the shmobile platform gets converted from its own pin control API to
the generic drivers/pinctrl subsystem.
Based on agreements with Paul Mundt, we are merging the sh-arch-side
changes here as well"
* tag 'renesas-pinctrl-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (142 commits)
ARM: shmobile: r8a7779: Remove INTC function GPIOs
ARM: shmobile: r8a7779: Remove LBSC function GPIOs
ARM: shmobile: r8a7779: Remove USB function GPIOs
ARM: shmobile: r8a7779: Remove HSPI function GPIOs
ARM: shmobile: r8a7779: Remove SCIF function GPIOs
ARM: shmobile: r8a7779: Remove SDHI and MMCIF function GPIOs
ARM: shmobile: r8a7779: Remove DU function GPIOs
ARM: shmobile: r8a7779: Remove DU1_DOTCLKOUT1 GPIO
ARM: shmobile: r8a7740: Remove SDHI and MMCIF function GPIOs
ARM: shmobile: r8a7740: Remove LCD0 and LCD1 function GPIOs
ARM: shmobile: sh73a0: Remove IrDA function GPIOs
ARM: shmobile: sh73a0: Remove USB function GPIOs
ARM: shmobile: sh73a0: Remove BSC function GPIOs
ARM: shmobile: sh73a0: Remove KEYSC function GPIOs
ARM: shmobile: sh73a0: Remove pull-up function GPIOS
ARM: shmobile: sh73a0: Remove FSI function GPIOs
ARM: shmobile: sh73a0: Remove I2C function GPIOs
ARM: shmobile: sh73a0: Remove SCIFA and SCIFB function GPIOs
ARM: shmobile: sh73a0: Remove LCDC and LCDC2 function GPIOs
ARM: shmobile: sh7372: Remove SDHI and MMCIF function GPIOs
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull powerpc update from Benjamin Herrenschmidt:
"The main highlights this time around are:
- A pile of addition POWER8 bits and nits, such as updated
performance counter support (Michael Ellerman), new branch history
buffer support (Anshuman Khandual), base support for the new PCI
host bridge when not using the hypervisor (Gavin Shan) and other
random related bits and fixes from various contributors.
- Some rework of our page table format by Aneesh Kumar which fixes a
thing or two and paves the way for THP support. THP itself will
not make it this time around however.
- More Freescale updates, including Altivec support on the new e6500
cores, new PCI controller support, and a pile of new boards support
and updates.
- The usual batch of trivial cleanups & fixes"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (156 commits)
powerpc: Fix build error for book3e
powerpc: Context switch the new EBB SPRs
powerpc: Turn on the EBB H/FSCR bits
powerpc: Replace CPU_FTR_BCTAR with CPU_FTR_ARCH_207S
powerpc: Setup BHRB instructions facility in HFSCR for POWER8
powerpc: Fix interrupt range check on debug exception
powerpc: Update tlbie/tlbiel as per ISA doc
powerpc: Print page size info during boot
powerpc: print both base and actual page size on hash failure
powerpc: Fix hpte_decode to use the correct decoding for page sizes
powerpc: Decode the pte-lp-encoding bits correctly.
powerpc: Use encode avpn where we need only avpn values
powerpc: Reduce PTE table memory wastage
powerpc: Move the pte free routines from common header
powerpc: Reduce the PTE_INDEX_SIZE
powerpc: Switch 16GB and 16MB explicit hugepages to a different page table format
powerpc: New hugepage directory format
powerpc: Don't truncate pgd_index wrongly
powerpc: Don't hard code the size of pte page
powerpc: Save DAR and DSISR in pt_regs on MCE
Pull VFS updates from Al Viro,
Misc cleanups all over the place, mainly wrt /proc interfaces (switch
create_proc_entry to proc_create(), get rid of the deprecated
create_proc_read_entry() in favor of using proc_create_data() and
seq_file etc).
7kloc removed.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits)
don't bother with deferred freeing of fdtables
proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h
proc: Make the PROC_I() and PDE() macros internal to procfs
proc: Supply a function to remove a proc entry by PDE
take cgroup_open() and cpuset_open() to fs/proc/base.c
ppc: Clean up scanlog
ppc: Clean up rtas_flash driver somewhat
hostap: proc: Use remove_proc_subtree()
drm: proc: Use remove_proc_subtree()
drm: proc: Use minor->index to label things, not PDE->name
drm: Constify drm_proc_list[]
zoran: Don't print proc_dir_entry data in debug
reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show()
proc: Supply an accessor for getting the data from a PDE's parent
airo: Use remove_proc_subtree()
rtl8192u: Don't need to save device proc dir PDE
rtl8187se: Use a dir under /proc/net/r8180/
proc: Add proc_mkdir_data()
proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h}
proc: Move PDE_NET() to fs/proc/proc_net.c
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal
Pull compat cleanup from Al Viro:
"Mostly about syscall wrappers this time; there will be another pile
with patches in the same general area from various people, but I'd
rather push those after both that and vfs.git pile are in."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal:
syscalls.h: slightly reduce the jungles of macros
get rid of union semop in sys_semctl(2) arguments
make do_mremap() static
sparc: no need to sign-extend in sync_file_range() wrapper
ppc compat wrappers for add_key(2) and request_key(2) are pointless
x86: trim sys_ia32.h
x86: sys32_kill and sys32_mprotect are pointless
get rid of compat_sys_semctl() and friends in case of ARCH_WANT_OLD_COMPAT_IPC
merge compat sys_ipc instances
consolidate compat lookup_dcookie()
convert vmsplice to COMPAT_SYSCALL_DEFINE
switch getrusage() to COMPAT_SYSCALL_DEFINE
switch epoll_pwait to COMPAT_SYSCALL_DEFINE
convert sendfile{,64} to COMPAT_SYSCALL_DEFINE
switch signalfd{,4}() to COMPAT_SYSCALL_DEFINE
make SYSCALL_DEFINE<n>-generated wrappers do asmlinkage_protect
make HAVE_SYSCALL_WRAPPERS unconditional
consolidate cond_syscall and SYSCALL_ALIAS declarations
teach SYSCALL_DEFINE<n> how to deal with long long/unsigned long long
get rid of duplicate logics in __SC_....[1-6] definitions
Merge third batch of fixes from Andrew Morton:
"Most of the rest. I still have two large patchsets against AIO and
IPC, but they're a bit stuck behind other trees and I'm about to
vanish for six days.
- random fixlets
- inotify
- more of the MM queue
- show_stack() cleanups
- DMI update
- kthread/workqueue things
- compat cleanups
- epoll udpates
- binfmt updates
- nilfs2
- hfs
- hfsplus
- ptrace
- kmod
- coredump
- kexec
- rbtree
- pids
- pidns
- pps
- semaphore tweaks
- some w1 patches
- relay updates
- core Kconfig changes
- sysrq tweaks"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (109 commits)
Documentation/sysrq: fix inconstistent help message of sysrq key
ethernet/emac/sysrq: fix inconstistent help message of sysrq key
sparc/sysrq: fix inconstistent help message of sysrq key
powerpc/xmon/sysrq: fix inconstistent help message of sysrq key
ARM/etm/sysrq: fix inconstistent help message of sysrq key
power/sysrq: fix inconstistent help message of sysrq key
kgdb/sysrq: fix inconstistent help message of sysrq key
lib/decompress.c: fix initconst
notifier-error-inject: fix module names in Kconfig
kernel/sys.c: make prctl(PR_SET_MM) generally available
UAPI: remove empty Kbuild files
menuconfig: print more info for symbol without prompts
init/Kconfig: re-order CONFIG_EXPERT options to fix menuconfig display
kconfig menu: move Virtualization drivers near other virtualization options
Kconfig: consolidate CONFIG_DEBUG_STRICT_USER_COPY_CHECKS
relay: use macro PAGE_ALIGN instead of FIX_SIZE
kernel/relay.c: move FIX_SIZE macro into relay.c
kernel/relay.c: remove unused function argument actor
drivers/w1/slaves/w1_ds2760.c: fix the error handling in w1_ds2760_add_slave()
drivers/w1/slaves/w1_ds2781.c: fix the error handling in w1_ds2781_add_slave()
show_regs() is inherently arch-dependent but it does make sense to print
generic debug information and some archs already do albeit in slightly
different forms. This patch introduces a generic function to print debug
information from show_regs() so that different archs print out the same
information and it's much easier to modify what's printed.
show_regs_print_info() prints out the same debug info as dump_stack()
does plus task and thread_info pointers.
* Archs which didn't print debug info now do.
alpha, arc, blackfin, c6x, cris, frv, h8300, hexagon, ia64, m32r,
metag, microblaze, mn10300, openrisc, parisc, score, sh64, sparc,
um, xtensa
* Already prints debug info. Replaced with show_regs_print_info().
The printed information is superset of what used to be there.
arm, arm64, avr32, mips, powerpc, sh32, tile, unicore32, x86
* s390 is special in that it used to print arch-specific information
along with generic debug info. Heiko and Martin think that the
arch-specific extra isn't worth keeping s390 specfic implementation.
Converted to use the generic version.
Note that now all archs print the debug info before actual register
dumps.
An example BUG() dump follows.
kernel BUG at /work/os/work/kernel/workqueue.c:4841!
invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #7
Hardware name: empty empty/S3992, BIOS 080011 10/26/2007
task: ffff88007c85e040 ti: ffff88007c860000 task.ti: ffff88007c860000
RIP: 0010:[<ffffffff8234a07e>] [<ffffffff8234a07e>] init_workqueues+0x4/0x6
RSP: 0000:ffff88007c861ec8 EFLAGS: 00010246
RAX: ffff88007c861fd8 RBX: ffffffff824466a8 RCX: 0000000000000001
RDX: 0000000000000046 RSI: 0000000000000001 RDI: ffffffff8234a07a
RBP: ffff88007c861ec8 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000001 R11: 0000000000000000 R12: ffffffff8234a07a
R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
FS: 0000000000000000(0000) GS:ffff88007dc00000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: ffff88015f7ff000 CR3: 00000000021f1000 CR4: 00000000000007f0
Stack:
ffff88007c861ef8 ffffffff81000312 ffffffff824466a8 ffff88007c85e650
0000000000000003 0000000000000000 ffff88007c861f38 ffffffff82335e5d
ffff88007c862080 ffffffff8223d8c0 ffff88007c862080 ffffffff81c47760
Call Trace:
[<ffffffff81000312>] do_one_initcall+0x122/0x170
[<ffffffff82335e5d>] kernel_init_freeable+0x9b/0x1c8
[<ffffffff81c47760>] ? rest_init+0x140/0x140
[<ffffffff81c4776e>] kernel_init+0xe/0xf0
[<ffffffff81c6be9c>] ret_from_fork+0x7c/0xb0
v2: Typo fix in x86-32.
v3: CPU number dropped from show_regs_print_info() as
dump_stack_print_info() has been updated to print it. s390
specific implementation dropped as requested by s390 maintainers.
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Fengguang Wu <fengguang.wu@intel.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Vineet Gupta <vgupta@synopsys.com>
Acked-by: Chris Metcalf <cmetcalf@tilera.com> [tile bits]
Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon bits]
Both dump_stack() and show_stack() are currently implemented by each
architecture. show_stack(NULL, NULL) dumps the backtrace for the
current task as does dump_stack(). On some archs, dump_stack() prints
extra information - pid, utsname and so on - in addition to the
backtrace while the two are identical on other archs.
The usages in arch-independent code of the two functions indicate
show_stack(NULL, NULL) should print out bare backtrace while
dump_stack() is used for debugging purposes when something went wrong,
so it does make sense to print additional information on the task which
triggered dump_stack().
There's no reason to require archs to implement two separate but mostly
identical functions. It leads to unnecessary subtle information.
This patch expands the dummy fallback dump_stack() implementation in
lib/dump_stack.c such that it prints out debug information (taken from
x86) and invokes show_stack(NULL, NULL) and drops arch-specific
dump_stack() implementations in all archs except blackfin. Blackfin's
dump_stack() does something wonky that I don't understand.
Debug information can be printed separately by calling
dump_stack_print_info() so that arch-specific dump_stack()
implementation can still emit the same debug information. This is used
in blackfin.
This patch brings the following behavior changes.
* On some archs, an extra level in backtrace for show_stack() could be
printed. This is because the top frame was determined in
dump_stack() on those archs while generic dump_stack() can't do that
reliably. It can be compensated by inlining dump_stack() but not
sure whether that'd be necessary.
* Most archs didn't use to print debug info on dump_stack(). They do
now.
An example WARN dump follows.
WARNING: at kernel/workqueue.c:4841 init_workqueues+0x35/0x505()
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #9
0000000000000009 ffff88007c861e08 ffffffff81c614dc ffff88007c861e48
ffffffff8108f50f ffffffff82228240 0000000000000040 ffffffff8234a03c
0000000000000000 0000000000000000 0000000000000000 ffff88007c861e58
Call Trace:
[<ffffffff81c614dc>] dump_stack+0x19/0x1b
[<ffffffff8108f50f>] warn_slowpath_common+0x7f/0xc0
[<ffffffff8108f56a>] warn_slowpath_null+0x1a/0x20
[<ffffffff8234a071>] init_workqueues+0x35/0x505
v2: CPU number added to the generic debug info as requested by s390
folks and dropped the s390 specific dump_stack(). This loses %ksp
from the debug message which the maintainers think isn't important
enough to keep the s390-specific dump_stack() implementation.
dump_stack_print_info() is moved to kernel/printk.c from
lib/dump_stack.c. Because linkage is per objecct file,
dump_stack_print_info() living in the same lib file as generic
dump_stack() means that archs which implement custom dump_stack()
- at this point, only blackfin - can't use dump_stack_print_info()
as that will bring in the generic version of dump_stack() too. v1
The v1 patch broke build on blackfin due to this issue. The build
breakage was reported by Fengguang Wu.
Acked-by: Vineet Gupta <vgupta@synopsys.com>
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390 bits]
Pull power management and ACPI updates from Rafael J Wysocki:
- ARM big.LITTLE cpufreq driver from Viresh Kumar.
- exynos5440 cpufreq driver from Amit Daniel Kachhap.
- cpufreq core cleanup and code consolidation from Viresh Kumar and
Stratos Karafotis.
- cpufreq scalability improvement from Nathan Zimmer.
- AMD "frequency sensitivity feedback" powersave bias for the ondemand
cpufreq governor from Jacob Shin.
- cpuidle code consolidation and cleanups from Daniel Lezcano.
- ARM OMAP cpuidle fixes from Santosh Shilimkar and Daniel Lezcano.
- ACPICA fixes and other improvements from Bob Moore, Jung-uk Kim, Lv
Zheng, Yinghai Lu, Tang Chen, Colin Ian King, and Linn Crosetto.
- ACPI core updates related to hotplug from Toshi Kani, Paul Bolle,
Yasuaki Ishimatsu, and Rafael J Wysocki.
- Intel Lynxpoint LPSS (Low-Power Subsystem) support improvements from
Rafael J Wysocki and Andy Shevchenko.
* tag 'pm+acpi-3.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (192 commits)
cpufreq: Revert incorrect commit 5800043
cpufreq: MAINTAINERS: Add co-maintainer
cpuidle: add maintainer entry
ACPI / thermal: do not always return THERMAL_TREND_RAISING for active trip points
ARM: s3c64xx: cpuidle: use init/exit common routine
cpufreq: pxa2xx: initialize variables
ACPI: video: correct acpi_video_bus_add error processing
SH: cpuidle: use init/exit common routine
ARM: S5pv210: compiling issue, ARM_S5PV210_CPUFREQ needs CONFIG_CPU_FREQ_TABLE=y
ACPI: Fix wrong parameter passed to memblock_reserve
cpuidle: fix comment format
pnp: use %*phC to dump small buffers
isapnp: remove debug leftovers
ARM: imx: cpuidle: use init/exit common routine
ARM: davinci: cpuidle: use init/exit common routine
ARM: kirkwood: cpuidle: use init/exit common routine
ARM: calxeda: cpuidle: use init/exit common routine
ARM: tegra: cpuidle: use init/exit common routine for tegra3
ARM: tegra: cpuidle: use init/exit common routine for tegra2
ARM: OMAP4: cpuidle: use init/exit common routine
Pull SMP/hotplug changes from Ingo Molnar:
"This is a pretty large, multi-arch series unifying and generalizing
the various disjunct pieces of idle routines that architectures have
historically copied from each other and have grown in random, wildly
inconsistent and sometimes buggy directions:
101 files changed, 455 insertions(+), 1328 deletions(-)
this went through a number of review and test iterations before it was
committed, it was tested on various architectures, was exposed to
linux-next for quite some time - nevertheless it might cause problems
on architectures that don't read the mailing lists and don't regularly
test linux-next.
This cat herding excercise was motivated by the -rt kernel, and was
brought to you by Thomas "the Whip" Gleixner."
* 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (40 commits)
idle: Remove GENERIC_IDLE_LOOP config switch
um: Use generic idle loop
ia64: Make sure interrupts enabled when we "safe_halt()"
sparc: Use generic idle loop
idle: Remove unused ARCH_HAS_DEFAULT_IDLE
bfin: Fix typo in arch_cpu_idle()
xtensa: Use generic idle loop
x86: Use generic idle loop
unicore: Use generic idle loop
tile: Use generic idle loop
tile: Enter idle with preemption disabled
sh: Use generic idle loop
score: Use generic idle loop
s390: Use generic idle loop
powerpc: Use generic idle loop
parisc: Use generic idle loop
openrisc: Use generic idle loop
mn10300: Use generic idle loop
mips: Use generic idle loop
microblaze: Use generic idle loop
Merge second batch of fixes from Andrew Morton:
- various misc bits
- some printk updates
- a new "SRAM" driver.
- MAINTAINERS updates
- the backlight driver queue
- checkpatch updates
- a few init/ changes
- a huge number of drivers/rtc changes
- fatfs updates
- some lib/idr.c work
- some renaming of the random driver interfaces
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (285 commits)
net: rename random32 to prandom
net/core: remove duplicate statements by do-while loop
net/core: rename random32() to prandom_u32()
net/netfilter: rename random32() to prandom_u32()
net/sched: rename random32() to prandom_u32()
net/sunrpc: rename random32() to prandom_u32()
scsi: rename random32() to prandom_u32()
lguest: rename random32() to prandom_u32()
uwb: rename random32() to prandom_u32()
video/uvesafb: rename random32() to prandom_u32()
mmc: rename random32() to prandom_u32()
drbd: rename random32() to prandom_u32()
kernel/: rename random32() to prandom_u32()
mm/: rename random32() to prandom_u32()
lib/: rename random32() to prandom_u32()
x86: rename random32() to prandom_u32()
x86: pageattr-test: remove srandom32 call
uuid: use prandom_bytes()
raid6test: use prandom_bytes()
sctp: convert sctp_assoc_set_id() to use idr_alloc_cyclic()
git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq
Pull async update from Tejun Heo:
"This contains three cleanup patches for async from Lai. All three
patches are essentially cosmetic."
* 'for-3.10-async' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq:
async: rename and redefine async_func_ptr
async: remove unused @node from struct async_domain
async: simplify lowest_in_progress()
The early console implementations are the same all over the place. Move
the print function to kernel/printk and get rid of the copies.
[akpm@linux-foundation.org: arch/mips/kernel/early_printk.c needs kernel.h for va_list]
[paul.gortmaker@windriver.com: sh4: make the bios early console support depend on EARLY_PRINTK]
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Richard Weinberger <richard@nod.at>
Reviewed-by: Ingo Molnar <mingo@kernel.org>
Tested-by: Paul Gortmaker <paul.gortmaker@windriver.com>
Commit abf09bed3cce ("s390/mm: implement software dirty bits")
introduced another difference in the pte layout vs. the pmd layout on
s390, thoroughly breaking the s390 support for hugetlbfs. This requires
replacing some more pte_xxx functions in mm/hugetlbfs.c with a
huge_pte_xxx version.
This patch introduces those huge_pte_xxx functions and their generic
implementation in asm-generic/hugetlb.h, which will now be included on
all architectures supporting hugetlbfs apart from s390. This change
will be a no-op for those architectures.
[akpm@linux-foundation.org: fix warning]
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Cc: Hillf Danton <dhillf@gmail.com>
Acked-by: Michal Hocko <mhocko@suse.cz> [for !s390 parts]
Use common help functions to free reserved pages.
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Acked-by: Paul Mundt <lethal@linux-sh.org>
Don't use create_proc_read_entry() as that is deprecated, but rather use
proc_create_data() and seq_file instead.
cc: Paul Mundt <lethal@linux-sh.org>
cc: linux-sh@vger.kernel.org
* pm-cpufreq: (57 commits)
cpufreq: cpu0: Put cpu parent node after using it
cpufreq: ARM big LITTLE: Adapt to latest cpufreq updates
cpufreq: ARM big LITTLE: put DT nodes after using them
cpufreq: Don't call __cpufreq_governor() for drivers without target()
cpufreq: exynos5440: Protect OPP search calls with RCU lock
cpufreq: dbx500: Round to closest available freq
cpufreq: Call __cpufreq_governor() with correct policy->cpus mask
cpufreq / intel_pstate: Optimize intel_pstate_set_policy
cpufreq: OMAP: instantiate omap-cpufreq as a platform_driver
arm: exynos: Enable OPP library support for exynos5440
cpufreq: exynos: Remove error return even if no soc is found
cpufreq: exynos: Add cpufreq driver for exynos5440
cpufreq: AMD "frequency sensitivity feedback" powersave bias for ondemand governor
cpufreq: ondemand: allow custom powersave_bias_target handler to be registered
cpufreq: convert cpufreq_driver to using RCU
cpufreq: powerpc/platforms/cell: move cpufreq driver to drivers/cpufreq
cpufreq: sparc: move cpufreq driver to drivers/cpufreq
MAINTAINERS (with commit a8e39c3 from pm-cpuidle)
drivers/cpufreq/cpufreq_governor.h (with commit beb0ff3)
Remove the duplicated code and use the cpuidle common code for initialization.
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Acked-by: Simon Horman <horms+renesas@verge.net.au>
The en_core_tk_irqen flag is set in all the cpuidle driver which
means it is not necessary to specify this flag.
Remove the flag and the code related to it.
Acked-by: Kevin Hilman <khilman@linaro.org> # for mach-omap2/*
Registering the driver, or the device, can fail, let's check the return code
and return the error code to the PM layer.
Like all the other drivers, let's initialize the structure a compile time
instead of init time.
The states #1 and #2 are not enabled by default. The init function will
check the features of the board in order to enable the state.
The CPUIDLE_DRIVER_STATE_START constant is only set when the kernel compilation
option CONFIG_ARCH_HAS_CPU_RELAX is set, but this is only relatated to x86, so
it is always zero.
Remove the reference to this constant in the code.
The driver is a global static variable automatically initialized to zero.
Removing the useless initialization in the init function.
The Kconfig symbol MAX_ACTIVE_REGIONS is unused. Commit
0ee332c1451869963626bf9cac88f165a90990e1 ("memblock: Kill
early_node_map[]") removed the only place were it was actually used. But
it did not remove its Kconfig entries (for powerpc and sh).
Remove those two entries (and the entry for metag, that popped up in
v3.9-rc1).
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
Acked-by: James Hogan <james.hogan@imgtec.com>
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
All archs are converted over. Remove the config switch and the
fallback code.
GENERIC_GPIO has been made equivalent to GPIOLIB in architecture code
and all driver code has been switch to depend on GPIOLIB. It is thus
safe to have GENERIC_GPIO removed.
Signed-off-by: Alexandre Courbot <acourbot@nvidia.com>
The Kconfig symbol ARCH_HAS_DEFAULT_IDLE is unused. Commit
a0bfa1373859e9d11dc92561a8667588803e42d8 ("cpuidle: stop
depending on pm_idle") removed the only place were it was
actually used. But it did not remove its Kconfig entries (for sh
and x86). Remove those two entries now.
Cc: Len Brown <len.brown@intel.com>
Link: http://lkml.kernel.org/r/1363869683.1390.134.camel@x61.thuisdomein
This patch moves cpufreq driver of SUPERH architecture to drivers/cpufreq.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
The only part of proc_dir_entry the code outside of fs/proc
really cares about is PDE(inode)->data. Provide a helper
for that; static inline for now, eventually will be moved
to fs/proc, along with the knowledge of struct proc_dir_entry
layout.
Cc: Paul McKenney <paulmck@linux.vnet.ibm.com>
Reviewed-by: Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Cc: Magnus Damm <magnus.damm@gmail.com>
Link: http://lkml.kernel.org/r/20130321215235.216323644@linutronix.de
Move it to a common place. Preparatory patch for implementing
set/clear for the idle need_resched poll implementation.
Link: http://lkml.kernel.org/r/20130321215233.446034505@linutronix.de
Some assignments of policy-> min/max/cur/cpuinfo.min_freq/cpuinfo.max_freq
aren't required as part of it is done by cpufreq driver or cpufreq core.
Remove them.
At some places we merge multiple lines together too.
Acked-by: Sekhar Nori <nsekhar@ti.com>
cpufreq layer doesn't call cpufreq driver's callback for any offline
CPU and so checking that isn't useful.
Lets get rid of it.
policy->cpus contains all online cpus that have single shared clock line. And
their frequencies are always updated together.
Many SMP system's cpufreq drivers take care of this in individual drivers but
the best place for this code is in cpufreq core.
This patch modifies cpufreq_notify_transition() to notify frequency change for
all cpus in policy->cpus and hence updates all users of this API.
This patch fixup below sparse errors
CHECK ${RENESAS_USB}/common.c
${RENESAS_USB}/common.c:313:17: error: incompatible types in conditional expression (different base types)
${RENESAS_USB}/common.c:322:17: error: incompatible types in conditional expression (different base types)
${RENESAS_USB}/common.c:384:17: error: incompatible types in conditional expression (different base types)
${RENESAS_USB}/common.c:524:9: error: incompatible types in conditional expression (different base types)
${RENESAS_USB}/common.c:545:9: error: incompatible types in conditional expression (different base types)
${RENESAS_USB}/common.c:574:9: error: incompatible types in conditional expression (different base types)
${RENESAS_USB}/common.c:606:9: error: incompatible types in conditional expression (different base types)
${RENESAS_USB}/mod_gadget.c:233:28: warning: symbol 'req_clear_feature' was not declared. Should it be static?
${RENESAS_USB}/mod_gadget.c:274:28: warning: symbol 'req_set_feature' was not declared. Should it be static?
${RENESAS_USB}/mod_gadget.c:375:28: warning: symbol 'req_get_status' was not declared. Should it be static?
[ balbi@ti.com : added three sparse fixes to mod_gadget.c ]
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
struct resource is defined in linux/ioport.h. Include it.
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
SH GPIO drivers all use gpiolib and CONFIG_GENERIC_GPIO is only selected
through CONFIG_GPIOLIB, yet some compilation units depended on
CONFIG_GENERIC_GPIO. Make them depend on CONFIG_GPIOLIB instead since it
is more accurate and prepares us for the future removal of
