Bug 200004122
drivers/cpufreq/cpufreq.c
drivers/regulator/core.c
sound/soc/codecs/max98090.c
Change-Id: I9418a05ad5c56b2e902249218bac2fa594d99f56
Signed-off-by: Ishan Mittal <imittal@nvidia.com>
We've switched over every architecture that supports SMP to it, so
remove the new useless config variable.
arch/arm/Kconfig
block/blk-mq.c
Change-Id: Ic19c3ac07a38a1636d6aa2fed5e55a58833f9b2c
Cc: Jan Kara <jack@suse.cz>
(cherry picked from commit 0a06ff068f1255bcd7965ab07bc0f4adc3eb639a)
[ Upstream commit 4f6500fff5f7644a03c46728fd7ef0f62fa6940b ]
In arch/sparc/Kernel/Makefile, we see:
obj-$(CONFIG_SPARC64) += jump_label.o
However, the Kconfig selects HAVE_ARCH_JUMP_LABEL unconditionally
for all SPARC. This in turn leads to the following failure when
doing allmodconfig coverage builds:
kernel/built-in.o: In function `__jump_label_update':
jump_label.c:(.text+0x8560c): undefined reference to `arch_jump_label_transform'
kernel/built-in.o: In function `arch_jump_label_transform_static':
(.text+0x85cf4): undefined reference to `arch_jump_label_transform'
make: *** [vmlinux] Error 1
Change HAVE_ARCH_JUMP_LABEL to be conditional on SPARC64 so that it
matches the Makefile.
Pull removal of GENERIC_GPIO from Grant Likely:
"GENERIC_GPIO now synonymous with GPIOLIB. There are no longer any
valid cases for enableing GENERIC_GPIO without GPIOLIB, even though it
is possible to do so which has been causing confusion and breakage.
This branch does the work to completely eliminate GENERIC_GPIO."
* tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux:
gpio: update gpio Chinese documentation
Remove GENERIC_GPIO config option
Convert selectors of GENERIC_GPIO to GPIOLIB
blackfin: force use of gpiolib
m68k: coldfire: use gpiolib
mips: pnx833x: remove requirement for GENERIC_GPIO
openrisc: default GENERIC_GPIO to false
avr32: default GENERIC_GPIO to false
xtensa: remove explicit selection of GENERIC_GPIO
sh: replace CONFIG_GENERIC_GPIO by CONFIG_GPIOLIB
powerpc: remove redundant GENERIC_GPIO selection
unicore32: default GENERIC_GPIO to false
unicore32: remove unneeded select GENERIC_GPIO
arm: plat-orion: use GPIO driver on CONFIG_GPIOLIB
arm: remove redundant GENERIC_GPIO selection
mips: alchemy: require gpiolib
mips: txx9: change GENERIC_GPIO to GPIOLIB
mips: loongson: use GPIO driver on CONFIG_GPIOLIB
mips: remove redundant GENERIC_GPIO select
Merge sparc bug fixes that didn't make it into v3.9 into
sparc-next.
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal
Pull compat cleanup from Al Viro:
"Mostly about syscall wrappers this time; there will be another pile
with patches in the same general area from various people, but I'd
rather push those after both that and vfs.git pile are in."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal:
syscalls.h: slightly reduce the jungles of macros
get rid of union semop in sys_semctl(2) arguments
make do_mremap() static
sparc: no need to sign-extend in sync_file_range() wrapper
ppc compat wrappers for add_key(2) and request_key(2) are pointless
x86: trim sys_ia32.h
x86: sys32_kill and sys32_mprotect are pointless
get rid of compat_sys_semctl() and friends in case of ARCH_WANT_OLD_COMPAT_IPC
merge compat sys_ipc instances
consolidate compat lookup_dcookie()
convert vmsplice to COMPAT_SYSCALL_DEFINE
switch getrusage() to COMPAT_SYSCALL_DEFINE
switch epoll_pwait to COMPAT_SYSCALL_DEFINE
convert sendfile{,64} to COMPAT_SYSCALL_DEFINE
switch signalfd{,4}() to COMPAT_SYSCALL_DEFINE
make SYSCALL_DEFINE<n>-generated wrappers do asmlinkage_protect
make HAVE_SYSCALL_WRAPPERS unconditional
consolidate cond_syscall and SYSCALL_ALIAS declarations
teach SYSCALL_DEFINE<n> how to deal with long long/unsigned long long
get rid of duplicate logics in __SC_....[1-6] definitions
Pull power management and ACPI updates from Rafael J Wysocki:
- ARM big.LITTLE cpufreq driver from Viresh Kumar.
- exynos5440 cpufreq driver from Amit Daniel Kachhap.
- cpufreq core cleanup and code consolidation from Viresh Kumar and
Stratos Karafotis.
- cpufreq scalability improvement from Nathan Zimmer.
- AMD "frequency sensitivity feedback" powersave bias for the ondemand
cpufreq governor from Jacob Shin.
- cpuidle code consolidation and cleanups from Daniel Lezcano.
- ARM OMAP cpuidle fixes from Santosh Shilimkar and Daniel Lezcano.
- ACPICA fixes and other improvements from Bob Moore, Jung-uk Kim, Lv
Zheng, Yinghai Lu, Tang Chen, Colin Ian King, and Linn Crosetto.
- ACPI core updates related to hotplug from Toshi Kani, Paul Bolle,
Yasuaki Ishimatsu, and Rafael J Wysocki.
- Intel Lynxpoint LPSS (Low-Power Subsystem) support improvements from
Rafael J Wysocki and Andy Shevchenko.
* tag 'pm+acpi-3.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (192 commits)
cpufreq: Revert incorrect commit 5800043
cpufreq: MAINTAINERS: Add co-maintainer
cpuidle: add maintainer entry
ACPI / thermal: do not always return THERMAL_TREND_RAISING for active trip points
ARM: s3c64xx: cpuidle: use init/exit common routine
cpufreq: pxa2xx: initialize variables
ACPI: video: correct acpi_video_bus_add error processing
SH: cpuidle: use init/exit common routine
ARM: S5pv210: compiling issue, ARM_S5PV210_CPUFREQ needs CONFIG_CPU_FREQ_TABLE=y
ACPI: Fix wrong parameter passed to memblock_reserve
cpuidle: fix comment format
pnp: use %*phC to dump small buffers
isapnp: remove debug leftovers
ARM: imx: cpuidle: use init/exit common routine
ARM: davinci: cpuidle: use init/exit common routine
ARM: kirkwood: cpuidle: use init/exit common routine
ARM: calxeda: cpuidle: use init/exit common routine
ARM: tegra: cpuidle: use init/exit common routine for tegra3
ARM: tegra: cpuidle: use init/exit common routine for tegra2
ARM: OMAP4: cpuidle: use init/exit common routine
GENERIC_GPIO has been made equivalent to GPIOLIB in architecture code
and all driver code has been switch to depend on GPIOLIB. It is thus
safe to have GENERIC_GPIO removed.
Signed-off-by: Alexandre Courbot <acourbot@nvidia.com>
This patch moves cpufreq driver of SPARC architecture to drivers/cpufreq.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Just like the OHCI counter part we just can remove the architecture
specific symbols which prevent these configuration symbols from being
selected by platforms/architectures requiring it. The original
implementation did not scale at all since it required each and every
single architecture to be added for these configuration symbols to be
selected. Now it is up to the EHCI driver and/or platform to select
these configuration symbols accordingly.
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Florian Fainelli <florian@openwrt.org>
This patch adds CONFIG_HIBERNATION support for sparc64
architecture. The suspend function is the same as on another
platforms. The restore function uses Bypass feature of MMU
which allows to make the process more comfortable and plesant.
Signed-off-by: Kirill Tkhai <tkhai@yandex.ru>
CC: David Miller <davem@davemloft.net>
CC: Sam Ravnborg <sam@ravnborg.org>
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Some of the GRPCI1 cores does not support detection of all PCI
errors, the default is therefore limited PCI error handling.
The property all_pci_errors my be set by the boot loader to
enable interrupt on all PCI errors.
sparc's asm/module.h got removed in commit
786d35d45cc40b2a51a18f73e14e135d47fdced7 ("Make most arch asm/module.h
files use asm-generic/module.h"). That removed the only two uses of this
Kconfig symbol. So we can remove its entry too.
> >From arch/sparc/Makefile:
> ifeq ($(CONFIG_SPARC32),y)
> export BITS := 32
> else
> export BITS := 64
> So $(BITS) is set depending on whether CONFIG_SPARC32 is set or not.
> Using $(BITS) in sparc's Makefiles is not using CONFIG_BITS. That
> doesn't count as usage of "config BITS".
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
Commit 2d78d4beb64eb07d50665432867971c481192ebf ("[PATCH] bitops:
sparc64: use generic bitops") made the default of GENERIC_HWEIGHT depend
on !ULTRA_HAS_POPULATION_COUNT. But since there's no Kconfig symbol with
that name, this always evaluates to true. Delete this dependency.
Change it to CONFIG_HAVE_VIRT_TO_BUS and set it in all architecures
that already provide virt_to_bus().
Reviewed-by: James Hogan <james.hogan@imgtec.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: H Hartley Sweeten <hartleys@visionengravers.com>
Cc: Vineet Gupta <Vineet.Gupta1@synopsys.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Cc: <linux-arch@vger.kernel.org>
Pull signal handling cleanups from Al Viro:
"This is the first pile; another one will come a bit later and will
contain SYSCALL_DEFINE-related patches.
- a bunch of signal-related syscalls (both native and compat)
unified.
- a bunch of compat syscalls switched to COMPAT_SYSCALL_DEFINE
(fixing several potential problems with missing argument
validation, while we are at it)
- a lot of now-pointless wrappers killed
- a couple of architectures (cris and hexagon) forgot to save
altstack settings into sigframe, even though they used the
(uninitialized) values in sigreturn; fixed.
- microblaze fixes for delivery of multiple signals arriving at once
- saner set of helpers for signal delivery introduced, several
architectures switched to using those."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (143 commits)
x86: convert to ksignal
sparc: convert to ksignal
arm: switch to struct ksignal * passing
alpha: pass k_sigaction and siginfo_t using ksignal pointer
burying unused conditionals
make do_sigaltstack() static
arm64: switch to generic old sigaction() (compat-only)
arm64: switch to generic compat rt_sigaction()
arm64: switch compat to generic old sigsuspend
arm64: switch to generic compat rt_sigqueueinfo()
arm64: switch to generic compat rt_sigpending()
arm64: switch to generic compat rt_sigprocmask()
arm64: switch to generic sigaltstack
sparc: switch to generic old sigsuspend
sparc: COMPAT_SYSCALL_DEFINE does all sign-extension as well as SYSCALL_DEFINE
sparc: kill sign-extending wrappers for native syscalls
kill sparc32_open()
sparc: switch to use of generic old sigaction
sparc: switch sys_compat_rt_sigaction() to COMPAT_SYSCALL_DEFINE
mips: switch to generic sys_fork() and sys_clone()
Pull irq core changes from Ingo Molnar:
"The biggest changes are the IRQ-work and printk changes from Frederic
Weisbecker, which prepare the code for 'full dynticks' (the ability to
stop or slow down the periodic tick arbitrarily, not just in idle time
as today):
- Don't stop tick with irq works pending. This fix is generally
useful and concerns archs that can't raise self IPIs.
- Flush irq works before CPU offlining.
- Introduce "lazy" irq works that can wait for the next tick to be
executed, unless it's stopped.
- Implement klogd wake up using irq work. This removes the ad-hoc
printk_tick()/printk_needs_cpu() hooks and make it working even in
dynticks mode.
- Cleanups and fixes."
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
genirq: Export enable/disable_percpu_irq()
arch Kconfig: Remove references to IRQ_PER_CPU
irq_work: Remove return value from the irq_work_queue() function
genirq: Avoid deadlock in spurious handling
printk: Wake up klogd using irq_work
irq_work: Make self-IPIs optable
irq_work: Warn if there's still work on cpu_down
irq_work: Flush work on CPU_DYING
irq_work: Don't stop the tick with pending works
nohz: Add API to check tick state
irq_work: Remove CONFIG_HAVE_IRQ_WORK
irq_work: Fix racy check on work pending flag
irq_work: Fix racy IRQ_WORK_BUSY flag setting
__ARCH_WANT_SYS_RT_SIGACTION,
__ARCH_WANT_SYS_RT_SIGSUSPEND,
__ARCH_WANT_COMPAT_SYS_RT_SIGSUSPEND,
__ARCH_WANT_COMPAT_SYS_SCHED_RR_GET_INTERVAL - not used anymore
CONFIG_GENERIC_{SIGALTSTACK,COMPAT_RT_SIG{ACTION,QUEUEINFO,PENDING,PROCMASK}} -
can be assumed always set.
This got missed in the cleanups done for the S390 THP
support.
CC: Gerald Schaefer <gerald.schaefer@de.ibm.com>
note that due to historical accident we do *not* directly take
generic versions - need to check and invert the sign of signal
number first.
note that while struct compat_sigaction is the generic one, syscall
itself *isn't* - different arguments. IOW, CONFIG_ODD_RT_SIGACTION
stays.
Switch from __ARCH_WANT_SYS_RT_SIGACTION to opposite
(!CONFIG_ODD_RT_SIGACTION); the only two architectures that
need it are alpha and sparc. The reason for use of CONFIG_...
instead of __ARCH_... is that it's needed only kernel-side
and doing it that way avoids a mess with include order on many
architectures.
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/linux-dynticks into irq/core
irq_work fixes and cleanups, in preparation for full dyntics support.
All architectures have
CONFIG_GENERIC_KERNEL_THREAD
CONFIG_GENERIC_KERNEL_EXECVE
__ARCH_WANT_SYS_EXECVE
None of them have __ARCH_WANT_KERNEL_EXECVE and there are only two callers
of kernel_execve() (which is a trivial wrapper for do_execve() now) left.
Kill the conditionals and make both callers use do_execve().
irq work can run on any arch even without IPI
support because of the hook on update_process_times().
So lets remove HAVE_IRQ_WORK because it doesn't reflect
any backend requirement.
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Sparc32 already supported it, as a consequence of using the
generic atomic64 implementation. And the sparc64 implementation
is rather trivial.
This allows us to set ARCH_HAS_ATOMIC64_DEC_IF_POSITIVE for all
of sparc, and avoid the annoying warning from lib/atomic64_test.c
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull module signing support from Rusty Russell:
"module signing is the highlight, but it's an all-over David Howells frenzy..."
Hmm "Magrathea: Glacier signing key". Somebody has been reading too much HHGTTG.
* 'modules-next' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (37 commits)
X.509: Fix indefinite length element skip error handling
X.509: Convert some printk calls to pr_devel
asymmetric keys: fix printk format warning
MODSIGN: Fix 32-bit overflow in X.509 certificate validity date checking
MODSIGN: Make mrproper should remove generated files.
MODSIGN: Use utf8 strings in signer's name in autogenerated X.509 certs
MODSIGN: Use the same digest for the autogen key sig as for the module sig
MODSIGN: Sign modules during the build process
MODSIGN: Provide a script for generating a key ID from an X.509 cert
MODSIGN: Implement module signature checking
MODSIGN: Provide module signing public keys to the kernel
MODSIGN: Automatically generate module signing keys if missing
MODSIGN: Provide Kconfig options
MODSIGN: Provide gitignore and make clean rules for extra files
MODSIGN: Add FIPS policy
module: signature checking hook
X.509: Add a crypto key parser for binary (DER) X.509 certificates
MPILIB: Provide a function to read raw data into an MPI
X.509: Add an ASN.1 decoder
X.509: Add simple ASN.1 grammar compiler
Narrowing the scope of the page size configurations will make the
transparent hugepage changes much simpler.
In the end what we really want to do is have the kernel support multiple
huge page sizes and use whatever is appropriate as the context dictactes.
Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Introduce SYSCTL_EXCEPTION_TRACE config option and selec it in the
architectures requiring support for the "exception-trace" debug_table
entry in kernel/sysctl.c.
Cc: Chris Metcalf <cmetcalf@tilera.com>
Introduce HAVE_DEBUG_BUGVERBOSE config option and select it in
corresponding architecture Kconfig files. Architectures that already
select GENERIC_BUG don't need to select HAVE_DEBUG_BUGVERBOSE.
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Introduce HAVE_DEBUG_KMEMLEAK config option and select it in corresponding
architecture Kconfig files. DEBUG_KMEMLEAK now only depends on
HAVE_DEBUG_KMEMLEAK.
Introduce HAVE_UID16 config option and select it in corresponding
architecture Kconfig files. UID16 now only depends on HAVE_UID16.
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Weinberger <richard@nod.at>
Use the mapping of Elf_[SPE]hdr, Elf_Addr, Elf_Sym, Elf_Dyn, Elf_Rel/Rela,
ELF_R_TYPE() and ELF_R_SYM() to either the 32-bit version or the 64-bit version
into asm-generic/module.h for all arches bar MIPS.
Also, use the generic definition mod_arch_specific where possible.
To this end, I've defined three new config bools:
(*) HAVE_MOD_ARCH_SPECIFIC
Arches define this if they don't want to use the empty generic
mod_arch_specific struct.
(*) MODULES_USE_ELF_RELA
Arches define this if their modules can contain RELA records. This causes
the Elf_Rela mapping to be emitted and allows apply_relocate_add() to be
defined by the arch rather than have the core emit an error message.
Arches define this if their modules can contain REL records. This causes
the Elf_Rel mapping to be emitted and allows apply_relocate() to be
Note that it is possible to allow both REL and RELA records: m68k and mips are
two arches that do this.
With this, some arch asm/module.h files can be deleted entirely and replaced
with a generic-y marker in the arch Kbuild file.
Additionally, I have removed the bits from m32r and score that handle the
unsupported type of relocation record as that's now handled centrally.
Rather than #define the options manually in the architecture code, add
Kconfig options for them and select them there instead. This also allows
us to select the compat IPC version parsing automatically for platforms
using the old compat IPC interface.
Reported-by: Andrew Morton <akpm@linux-foundation.org>
Fixes this sparc32 defconfig build error:
timekeeping.c:(.text+0x277c4): undefined reference to `arch_gettimeoffset'
This throws away the sparc-specific functions in favor of the generic
optimized version.
Pull sparc changes from David S. Miller:
"This has the generic strncpy_from_user() implementation architectures
can now use, which we've been developing on linux-arch over the past
few days.
For good measure I ran both a 32-bit and a 64-bit glibc testsuite run,
and the latter of which pointed out an adjustment I needed to make to
sparc's user_addr_max() definition. Linus, you were right, STACK_TOP
was not the right thing to use, even on sparc itself :-)
From Sam Ravnborg, we have a conversion of sparc32 over to the common
alloc_thread_info_node(), since the aspect which originally blocked
our doing so (sun4c) has been removed."
Fix up trivial arch/sparc/Kconfig and lib/Makefile conflicts.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc:
sparc: Fix user_addr_max() definition.
lib: Sparc's strncpy_from_user is generic enough, move under lib/
kernel: Move REPEAT_BYTE definition into linux/kernel.h
sparc: Increase portability of strncpy_from_user() implementation.
sparc: Optimize strncpy_from_user() zero byte search.
sparc: Add full proper error handling to strncpy_from_user().
sparc32: use the common implementation of alloc_thread_info_node()
Pull timer updates from Thomas Gleixner.
Various trivial conflict fixups in arch Kconfig due to addition of
unrelated entries nearby. And one slightly more subtle one for sparc32
(new user of GENERIC_CLOCKEVENTS), fixed up as per Thomas.
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (31 commits)
timekeeping: Fix a few minor newline issues.
time: remove obsolete declaration
ntp: Fix a stale comment and a few stray newlines.
ntp: Correct TAI offset during leap second
timers: Fixup the Kconfig consolidation fallout
x86: Use generic time config
unicore32: Use generic time config
um: Use generic time config
tile: Use generic time config
sparc: Use: generic time config
sh: Use generic time config
score: Use generic time config
s390: Use generic time config
openrisc: Use generic time config
powerpc: Use generic time config
mn10300: Use generic time config
mips: Use generic time config
microblaze: Use generic time config
m68k: Use generic time config
m32r: Use generic time config
