path: root/arch/sparc/boot/Makefile
2009-08-16sparc64: build compressed image (zImage) by defaultJurij Smakov
Besides creating the uncompressed vmlinux image for sparc64, also create a compressed zImage. This is more consistent with other architectures and required to make the 'deb-pkg' target work. Signed-off-by: Jurij Smakov <jurij@wooyd.org> Signed-off-by: Frans Pop <elendil@planet.nl> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-25sparc32: Fix makefile not generating required filesJulian Calaby
The tftpboot build was failing with missing file errors. It turns out that $(obj)/image wasn't being generated which was causing the a.out conversion to be skipped and hence piggyback to be called with nonexistent files. Signed-off-by: Julian Calaby <julian.calaby@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-25sparc32: Fix tftpboot.img MakefileJulian Calaby
2009-06-25sparc32: Fix obvious build issues for tftpboot.img build.Robert Reif
Signed-off-by: Robert Reif <reif@earthlink.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-04sparc,sparc64: unify boot/Sam Ravnborg
Simple unification: o renamed piggyback to *_32.c/*_64.c o copied content of Makefile from sparc64 to sparc and guard it o updated sparc/boot/.gitignore o deleted remaining files in sparc64/boot Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-04sparc: clean boot/Sam Ravnborg
Leave all cleaning to boot/Makefile and delete zImage too when we do a 'make clean' Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-04sparc: refactor MakefileSam Ravnborg
The btfixup step needs knowledge of all the .o files, but there is no need to pass them in independent variables. Simplify it to use only two variables. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-24sparc: Add target for a stripped kernelMartin Habets
Add a target for a stripped kernel. This is used for the various packaging targets (*-pkg). Signed-off-by: Martin Habets <errandir_news@mph.eclipse.co.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20sparc: remove CVS keywordsAdrian Bunk
This patch removes the CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
