commit a208fa8f33031b9e0aba44c7d1b7e68eb0cbd29e upstream.
We need to consistently enforce that keyed hashes cannot be used without
setting the key. To do this we need a reliable way to determine whether
a given hash algorithm is keyed or not. AF_ALG currently does this by
checking for the presence of a ->setkey() method. However, this is
actually slightly broken because the CRC-32 algorithms implement
->setkey() but can also be used without a key. (The CRC-32 "key" is not
actually a cryptographic key but rather represents the initial state.
If not overridden, then a default initial state is used.)
Prepare to fix this by introducing a flag CRYPTO_ALG_OPTIONAL_KEY which
indicates that the algorithm has a ->setkey() method, but it is not
required to be called. Then set it on all the CRC-32 algorithms.
The same also applies to the Adler-32 implementation in Lustre.
Also, the cryptd and mcryptd templates have to pass through the flag
from their underlying algorithm.
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
There are quite a number of occurrences in the kernel of the pattern
if (dst != src)
memcpy(dst, src, walk.total % AES_BLOCK_SIZE);
crypto_xor(dst, final, walk.total % AES_BLOCK_SIZE);
or
crypto_xor(keystream, src, nbytes);
memcpy(dst, keystream, nbytes);
where crypto_xor() is preceded or followed by a memcpy() invocation
that is only there because crypto_xor() uses its output parameter as
one of the inputs. To avoid having to add new instances of this pattern
in the arm64 code, which will be refactored to implement non-SIMD
fallbacks, add an alternative implementation called crypto_xor_cpy(),
taking separate input and output arguments. This removes the need for
the separate memcpy().
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Some of the crypto algorithms write to the initialization vector,
but no space has been allocated for it. This clobbers adjacent memory.
Cc: stable@vger.kernel.org
Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
Since MD5 IV are now available in crypto/md5.h, use them.
Signed-off-by: LABBE Corentin <clabbe.montjoie@gmail.com>
MD5 is not SHA1.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
This module provides implementations for "des3_ede", too. Announce those
via an appropriate crypto module alias so it can be used in favour to
the generic C implementation.
The module alias should be "camellia", not "aes".
AES is a block cipher, not a hash.
Memset on a local variable may be removed when it is called just before the
variable goes out of scope. Using memzero_explicit defeats this
optimization. A simplified version of the semantic patch that makes this
change is as follows: (http://coccinelle.lip6.fr/)
// <smpl>
identifier x;
type T;
... when any
T x[...];
... when any
when exists
- memset
+ memzero_explicit
(x,
-0,
... when != x
when strict
// </smpl>
This change was suggested by Daniel Borkmann <dborkman@redhat.com>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
This prefixes all crypto module loading with "crypto-" so we never run
the risk of exposing module auto-loading to userspace via a crypto API,
as demonstrated by Mathias Krause:
https://lkml.org/lkml/2013/3/4/70
Fix following warnings:
aes_glue.c:127:16: warning: symbol 'aes128_ops' was not declared. Should it be static?
aes_glue.c:139:16: warning: symbol 'aes192_ops' was not declared. Should it be static?
aes_glue.c:151:16: warning: symbol 'aes256_ops' was not declared. Should it be static?
Fix by defining the variables static as they are not used outside this file
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
We use the FPU and therefore cannot sleep during the crypto
loops.
loops.
Things works better when you increment the source buffer pointer
properly.
loops.
Like the generic versions, we need to support a block size
of '1' for CTR mode AES.
This was discovered thanks to all of the new test cases added by
Jussi Kivilinna.
The basic scheme of the block mode assembler is that we start by
enabling the FPU, loading the key into the floating point registers,
then iterate calling the encrypt/decrypt routine for each block.
For the 256-bit key cases, we run short on registers in the unrolled
loops.
So the {ENCRYPT,DECRYPT}_256_2() macros reload the key registers that
get clobbered.
The unrolled macros, {ENCRYPT,DECRYPT}_256(), are not mindful of this.
So if we have a mix of multi-block and single-block calls, the
single-block unrolled 256-bit encrypt/decrypt can run with some
of the key registers clobbered.
Handle this by always explicitly loading those registers before using
the non-unrolled 256-bit macro.
Jussi Kivilinna.
We tried linking in a single built object to hold the device table,
but only works if all of the sparc64 crypto modules get built the same
way (modular vs. non-modular).
Just include the device ID stub into each driver source file so that
the table gets compiled into the correct result in all cases.
Reported-by: Meelis Roos <mroos@linux.ee>
The IV wasn't being propagated properly past the first loop
iteration.
This bug lived only because the crypto layer tests for
cbc(des) do not have any cases that go more than one loop.
Just simply provide a device table containing an entry for sun4v cpus,
the capability mask checks in the drivers themselves will take care of
the rest.
This makes the bootup logs on pre-T4 cpus slightly more verbose, with
each driver indicating lack of support for the associated opcode(s).
But this isn't too much of a real problem.
I toyed with the idea of using explicit entries with compatability
fields of "SPARC-T4", "SPARC-T5", etc. but all future cpus will have
some subset of these opcodes available and this would just be one more
pointless thing to do as each new cpu is released with a new string.
The hashes and crc32c had it, only the AES/DES/CAMELLIA drivers were
missing it.
Make the crypto opcode implementations have a higher priority than
those provides by the ring buffer based Niagara crypto device.
Also, several crypto opcode hashes were not setting the priority value
at all.
Some dm-crypt testing revealed several bugs in the 256-bit unrolled
loops.
The DECRYPT_256_2() macro had two errors:
1) Missing reload of KEY registers %f60 and %f62
2) Missing "\" in penultimate line of definition.
In aes_sparc64_ecb_decrypt_256, we were storing the second half of the
encryption result from the wrong source registers.
In aes_sparc64_ctr_crypt_256 we have to be careful when we fall out of
the 32-byte-at-a-time loop and handle a trailing 16-byte chunk. In
that case we've clobbered the final key holding registers and have to
restore them before executing the ENCRYPT_256() macro. Inside of the
32-byte-at-a-time loop things are OK, because we do this key register
restoring during the first few rounds of the ENCRYPT_256_2() macro.
Put the opcode macros in a common header
Before:
testing speed of ctr(aes) encryption
test 0 (128 bit key, 16 byte blocks): 1 operation in 206 cycles (16 bytes)
test 1 (128 bit key, 64 byte blocks): 1 operation in 244 cycles (64 bytes)
test 2 (128 bit key, 256 byte blocks): 1 operation in 360 cycles (256 bytes)
test 3 (128 bit key, 1024 byte blocks): 1 operation in 814 cycles (1024 bytes)
test 4 (128 bit key, 8192 byte blocks): 1 operation in 5021 cycles (8192 bytes)
test 5 (192 bit key, 16 byte blocks): 1 operation in 206 cycles (16 bytes)
test 6 (192 bit key, 64 byte blocks): 1 operation in 240 cycles (64 bytes)
test 7 (192 bit key, 256 byte blocks): 1 operation in 378 cycles (256 bytes)
test 8 (192 bit key, 1024 byte blocks): 1 operation in 939 cycles (1024 bytes)
test 9 (192 bit key, 8192 byte blocks): 1 operation in 6395 cycles (8192 bytes)
test 10 (256 bit key, 16 byte blocks): 1 operation in 209 cycles (16 bytes)
test 11 (256 bit key, 64 byte blocks): 1 operation in 249 cycles (64 bytes)
test 12 (256 bit key, 256 byte blocks): 1 operation in 414 cycles (256 bytes)
test 13 (256 bit key, 1024 byte blocks): 1 operation in 1073 cycles (1024 bytes)
test 14 (256 bit key, 8192 byte blocks): 1 operation in 7110 cycles (8192 bytes)
testing speed of ctr(aes) decryption
test 0 (128 bit key, 16 byte blocks): 1 operation in 225 cycles (16 bytes)
test 1 (128 bit key, 64 byte blocks): 1 operation in 233 cycles (64 bytes)
test 2 (128 bit key, 256 byte blocks): 1 operation in 344 cycles (256 bytes)
test 3 (128 bit key, 1024 byte blocks): 1 operation in 810 cycles (1024 bytes)
test 7 (192 bit key, 256 byte blocks): 1 operation in 376 cycles (256 bytes)
test 8 (192 bit key, 1024 byte blocks): 1 operation in 938 cycles (1024 bytes)
test 9 (192 bit key, 8192 byte blocks): 1 operation in 6380 cycles (8192 bytes)
test 10 (256 bit key, 16 byte blocks): 1 operation in 214 cycles (16 bytes)
test 11 (256 bit key, 64 byte blocks): 1 operation in 251 cycles (64 bytes)
test 12 (256 bit key, 256 byte blocks): 1 operation in 411 cycles (256 bytes)
test 13 (256 bit key, 1024 byte blocks): 1 operation in 1070 cycles (1024 bytes)
test 14 (256 bit key, 8192 byte blocks): 1 operation in 7114 cycles (8192 bytes)
After:
test 0 (128 bit key, 16 byte blocks): 1 operation in 211 cycles (16 bytes)
test 1 (128 bit key, 64 byte blocks): 1 operation in 246 cycles (64 bytes)
test 3 (128 bit key, 1024 byte blocks): 1 operation in 799 cycles (1024 bytes)
test 4 (128 bit key, 8192 byte blocks): 1 operation in 4975 cycles (8192 bytes)
test 5 (192 bit key, 16 byte blocks): 1 operation in 210 cycles (16 bytes)
test 6 (192 bit key, 64 byte blocks): 1 operation in 236 cycles (64 bytes)
test 7 (192 bit key, 256 byte blocks): 1 operation in 365 cycles (256 bytes)
test 8 (192 bit key, 1024 byte blocks): 1 operation in 888 cycles (1024 bytes)
test 9 (192 bit key, 8192 byte blocks): 1 operation in 6055 cycles (8192 bytes)
test 11 (256 bit key, 64 byte blocks): 1 operation in 255 cycles (64 bytes)
test 12 (256 bit key, 256 byte blocks): 1 operation in 404 cycles (256 bytes)
test 13 (256 bit key, 1024 byte blocks): 1 operation in 1010 cycles (1024 bytes)
test 14 (256 bit key, 8192 byte blocks): 1 operation in 6669 cycles (8192 bytes)
test 0 (128 bit key, 16 byte blocks): 1 operation in 210 cycles (16 bytes)
test 2 (128 bit key, 256 byte blocks): 1 operation in 340 cycles (256 bytes)
test 3 (128 bit key, 1024 byte blocks): 1 operation in 818 cycles (1024 bytes)
test 4 (128 bit key, 8192 byte blocks): 1 operation in 4956 cycles (8192 bytes)
test 6 (192 bit key, 64 byte blocks): 1 operation in 239 cycles (64 bytes)
test 7 (192 bit key, 256 byte blocks): 1 operation in 361 cycles (256 bytes)
test 9 (192 bit key, 8192 byte blocks): 1 operation in 5996 cycles (8192 bytes)
test 11 (256 bit key, 64 byte blocks): 1 operation in 248 cycles (64 bytes)
test 12 (256 bit key, 256 byte blocks): 1 operation in 395 cycles (256 bytes)
test 14 (256 bit key, 8192 byte blocks): 1 operation in 6664 cycles (8192 bytes)
Before:
testing speed of ecb(aes) decryption
test 0 (128 bit key, 16 byte blocks): 1 operation in 223 cycles (16 bytes)
test 1 (128 bit key, 64 byte blocks): 1 operation in 230 cycles (64 bytes)
test 2 (128 bit key, 256 byte blocks): 1 operation in 325 cycles (256 bytes)
test 3 (128 bit key, 1024 byte blocks): 1 operation in 719 cycles (1024 bytes)
test 4 (128 bit key, 8192 byte blocks): 1 operation in 4266 cycles (8192 bytes)
test 5 (192 bit key, 16 byte blocks): 1 operation in 211 cycles (16 bytes)
test 6 (192 bit key, 64 byte blocks): 1 operation in 234 cycles (64 bytes)
test 7 (192 bit key, 256 byte blocks): 1 operation in 353 cycles (256 bytes)
test 8 (192 bit key, 1024 byte blocks): 1 operation in 808 cycles (1024 bytes)
test 9 (192 bit key, 8192 byte blocks): 1 operation in 5344 cycles (8192 bytes)
test 11 (256 bit key, 64 byte blocks): 1 operation in 243 cycles (64 bytes)
test 12 (256 bit key, 256 byte blocks): 1 operation in 393 cycles (256 bytes)
test 13 (256 bit key, 1024 byte blocks): 1 operation in 939 cycles (1024 bytes)
test 14 (256 bit key, 8192 byte blocks): 1 operation in 6039 cycles (8192 bytes)
After:
test 0 (128 bit key, 16 byte blocks): 1 operation in 226 cycles (16 bytes)
test 1 (128 bit key, 64 byte blocks): 1 operation in 231 cycles (64 bytes)
test 2 (128 bit key, 256 byte blocks): 1 operation in 313 cycles (256 bytes)
test 3 (128 bit key, 1024 byte blocks): 1 operation in 681 cycles (1024 bytes)
test 4 (128 bit key, 8192 byte blocks): 1 operation in 3964 cycles (8192 bytes)
test 5 (192 bit key, 16 byte blocks): 1 operation in 205 cycles (16 bytes)
test 7 (192 bit key, 256 byte blocks): 1 operation in 341 cycles (256 bytes)
test 8 (192 bit key, 1024 byte blocks): 1 operation in 770 cycles (1024 bytes)
test 9 (192 bit key, 8192 byte blocks): 1 operation in 5050 cycles (8192 bytes)
test 10 (256 bit key, 16 byte blocks): 1 operation in 216 cycles (16 bytes)
test 11 (256 bit key, 64 byte blocks): 1 operation in 250 cycles (64 bytes)
test 12 (256 bit key, 256 byte blocks): 1 operation in 371 cycles (256 bytes)
test 13 (256 bit key, 1024 byte blocks): 1 operation in 869 cycles (1024 bytes)
test 14 (256 bit key, 8192 byte blocks): 1 operation in 5494 cycles (8192 bytes)
The AES opcodes have a 3 cycle latency, so by doing 32-bytes at a
time we avoid a pipeline bubble in between every round.
For the 256-bit key case, it looks like we're doing more work in
order to reload the KEY registers during the loop to make space
for scarce temporaries. But the load dual issues with the AES
operations so we get the KEY reloads essentially for free.
Before:
testing speed of ecb(aes) encryption
test 0 (128 bit key, 16 byte blocks): 1 operation in 264 cycles (16 bytes)
test 2 (128 bit key, 256 byte blocks): 1 operation in 329 cycles (256 bytes)
test 3 (128 bit key, 1024 byte blocks): 1 operation in 715 cycles (1024 bytes)
test 4 (128 bit key, 8192 byte blocks): 1 operation in 4248 cycles (8192 bytes)
test 5 (192 bit key, 16 byte blocks): 1 operation in 221 cycles (16 bytes)
test 7 (192 bit key, 256 byte blocks): 1 operation in 359 cycles (256 bytes)
test 8 (192 bit key, 1024 byte blocks): 1 operation in 803 cycles (1024 bytes)
test 9 (192 bit key, 8192 byte blocks): 1 operation in 5366 cycles (8192 bytes)
test 12 (256 bit key, 256 byte blocks): 1 operation in 379 cycles (256 bytes)
test 13 (256 bit key, 1024 byte blocks): 1 operation in 938 cycles (1024 bytes)
test 14 (256 bit key, 8192 byte blocks): 1 operation in 6041 cycles (8192 bytes)
After:
test 0 (128 bit key, 16 byte blocks): 1 operation in 266 cycles (16 bytes)
test 1 (128 bit key, 64 byte blocks): 1 operation in 256 cycles (64 bytes)
test 2 (128 bit key, 256 byte blocks): 1 operation in 305 cycles (256 bytes)
test 3 (128 bit key, 1024 byte blocks): 1 operation in 676 cycles (1024 bytes)
test 4 (128 bit key, 8192 byte blocks): 1 operation in 3981 cycles (8192 bytes)
test 6 (192 bit key, 64 byte blocks): 1 operation in 233 cycles (64 bytes)
test 7 (192 bit key, 256 byte blocks): 1 operation in 340 cycles (256 bytes)
test 8 (192 bit key, 1024 byte blocks): 1 operation in 766 cycles (1024 bytes)
test 9 (192 bit key, 8192 byte blocks): 1 operation in 5136 cycles (8192 bytes)
test 10 (256 bit key, 16 byte blocks): 1 operation in 206 cycles (16 bytes)
test 11 (256 bit key, 64 byte blocks): 1 operation in 268 cycles (64 bytes)
test 12 (256 bit key, 256 byte blocks): 1 operation in 368 cycles (256 bytes)
test 13 (256 bit key, 1024 byte blocks): 1 operation in 890 cycles (1024 bytes)
test 14 (256 bit key, 8192 byte blocks): 1 operation in 5718 cycles (8192 bytes)
Instead of testing and branching off of the key size on every
encrypt/decrypt call, use method ops assigned at key set time.
Reverse the order of float registers used for decryption to make
future changes easier.
Align all assembler routines on a 32-byte boundary.
On SPARC-T4 fsrc2 has 1 cycle of latency, whereas fsrc1 has 11 cycles.
True story.
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
