Drop extern for all prototypes and adjust alignment of parameters
as required after the removal.
In a few rare cases adjust linelength to conform to maximum 80 chars,
and likewise in a few rare cases adjust alignment of parameters
to static functions.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Move that sucker to just before TI_FPDEPTH and replace stb with sth in
etrap_save(). Take current_ds to its old place, so that we don't push
wsaved into TI_... flags. That allows to lose clearing syscall_noerror
on return from syscall.
Acked-by: Michael Kerrisk <mtk.manpages@gmail.com>
Acked-by: Dave Jones <davej@redhat.com>
Build failures for the typical configs I use
Fixes this build error:
kernel/signal.c: In function 'ptrace_stop':
kernel/signal.c:1860:3: error: implicit declaration of function 'synchronize_user_stack' [-Werror=implicit-function-declaration]
Disintegrate asm/system.h for Sparc.
cc: sparclinux@vger.kernel.org
The audit system previously expected arches calling to audit_syscall_exit to
supply as arguments if the syscall was a success and what the return code was.
Audit also provides a helper AUDITSC_RESULT which was supposed to simplify things
by converting from negative retcodes to an audit internal magic value stating
success or failure. This helper was wrong and could indicate that a valid
pointer returned to userspace was a failed syscall. The fix is to fix the
layering foolishness. We now pass audit_syscall_exit a struct pt_reg and it
in turns calls back into arch code to collect the return value and to
determine if the syscall was a success or failure. We also define a generic
is_syscall_success() macro which determines success/failure based on if the
value is < -MAX_ERRNO. This works for arches like x86 which do not use a
separate mechanism to indicate syscall failure.
We make both the is_syscall_success() and regs_return_value() static inlines
instead of macros. The reason is because the audit function must take a void*
for the regs. (uml calls theirs struct uml_pt_regs instead of just struct
pt_regs so audit_syscall_exit can't take a struct pt_regs). Since the audit
function takes a void* we need to use static inlines to cast it back to the
arch correct structure to dereference it.
The other major change is that on some arches, like ia64, MIPS and ppc, we
change regs_return_value() to give us the negative value on syscall failure.
THE only other user of this macro, kretprobe_example.c, won't notice and it
makes the value signed consistently for the audit functions across all archs.
In arch/sh/kernel/ptrace_64.c I see that we were using regs[9] in the old
audit code as the return value. But the ptrace_64.h code defined the macro
regs_return_value() as regs[3]. I have no idea which one is correct, but this
patch now uses the regs_return_value() function, so it now uses regs[3].
For powerpc we previously used regs->result but now use the
regs_return_value() function which uses regs->gprs[3]. regs->gprs[3] is
always positive so the regs_return_value(), much like ia64 makes it negative
before calling the audit code when appropriate.
Signed-off-by: Eric Paris <eparis@redhat.com>
Acked-by: H. Peter Anvin <hpa@zytor.com> [for x86 portion]
Acked-by: Tony Luck <tony.luck@intel.com> [for ia64]
Acked-by: Richard Weinberger <richard@nod.at> [for uml]
Acked-by: David S. Miller <davem@davemloft.net> [for sparc]
Acked-by: Ralf Baechle <ralf@linux-mips.org> [for mips]
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> [for ppc]
[ poleg@redhat.com: no need to declare show_regs() in ptrace.h, sched.h does this ]
Cc: Tejun Heo <tj@kernel.org>
Commit 63ab25ebbc (kgdbts: unify/generalize gdb breakpoint adjustment)
introduced a compile regression on sparc.
kgdbts.c: In function 'check_and_rewind_pc':
kgdbts.c:307: error: implicit declaration of function 'instruction_pointer_set'
Simply add the correct macro definition for instruction pointer on the
Sparc architecture.
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
The two ptrace.h implementations are very alike but
the small differences required two set of ifdef/else/endif pairs.
The definition of reg_window32 could have been shared but
that would have required several updates in sparc32 code as
all printk formatting for example assume it is longs.
sparc_stackf looked like anohter candidate to share if the 32
bit was renamed to sparc_stackf32.
But it contains two pointers in the sparc32 version which would
have been 64 bit in the sparc64 version so it was non-trivial.
Using a set of accessor macros could do the trick if pursued later.
The sparc64 specific definitions are not protected by
ifdef - as it should not be required to do so.
The majority of this patch was created by the following script:
ASM=arch/sparc/include/asm
mkdir -p $ASM
git mv include/asm-sparc64/ftrace.h $ASM
git rm include/asm-sparc64/*
git mv include/asm-sparc/* $ASM
sed -ie 's/asm-sparc64/asm/g' $ASM/*
sed -ie 's/asm-sparc/asm/g' $ASM/*
The rest was an update of the top-level Makefile to use sparc
for header files when sparc64 is being build.
And a small fixlet to pick up the correct unistd.h from
sparc64 code.
