Bug 200004122
drivers/cpufreq/cpufreq.c
drivers/regulator/core.c
sound/soc/codecs/max98090.c
Change-Id: I9418a05ad5c56b2e902249218bac2fa594d99f56
Signed-off-by: Ishan Mittal <imittal@nvidia.com>
A number of situations currently require the heavyweight smp_mb(),
even though there is no need to order prior stores against later
loads. Many architectures have much cheaper ways to handle these
situations, but the Linux kernel currently has no portable way
to make use of them.
This commit therefore supplies smp_load_acquire() and
smp_store_release() to remedy this situation. The new
smp_load_acquire() primitive orders the specified load against
any subsequent reads or writes, while the new smp_store_release()
primitive orders the specifed store against any prior reads or
writes. These primitives allow array-based circular FIFOs to be
implemented without an smp_mb(), and also allow a theoretical
hole in rcu_assign_pointer() to be closed at no additional
expense on most architectures.
In addition, the RCU experience transitioning from explicit
smp_read_barrier_depends() and smp_wmb() to rcu_dereference()
and rcu_assign_pointer(), respectively resulted in substantial
improvements in readability. It therefore seems likely that
replacing other explicit barriers with smp_load_acquire() and
smp_store_release() will provide similar benefits. It appears
that roughly half of the explicit barriers in core kernel code
might be so replaced.
[Changelog by PaulMck]
(cherry picked from commit 47933ad41a86a4a9b50bed7c9b9bd2ba242aac63)
Reviewed-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Acked-by: Will Deacon <will.deacon@arm.com>
Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Cc: Michael Ellerman <michael@ellerman.id.au>
Cc: Michael Neuling <mikey@neuling.org>
Cc: Victor Kaplansky <VICTORK@il.ibm.com>
Link: http://lkml.kernel.org/r/20131213150640.908486364@infradead.org
arch/avr32/include/asm/Kbuild
arch/c6x/include/asm/Kbuild
arch/cris/include/asm/Kbuild
arch/ia64/include/asm/Kbuild
arch/mips/include/asm/Kbuild
arch/openrisc/include/asm/Kbuild
arch/powerpc/include/asm/Kbuild
arch/score/include/asm/Kbuild
Change-Id: I6800e3f03dbc40e94de1495459dec4b29df4474e
(cherry picked from commit e3fec2f74f7f90d2149a24243a4d040caabe6f30)
In order to prepare to per-arch implementations of preempt_count move
the required bits into an asm-generic header and use this for all
archs.
(cherry picked from commit a787870924dbd6f321661e06d4ec1c7a408c9ccf)
arch/h8300/include/asm/Kbuild
include/linux/preempt.h
Change-Id: I544914d3c23cc50da658296a34f9f2796854e259
Link: http://lkml.kernel.org/n/tip-h5j0c1r3e3fk015m30h8f1zx@git.kernel.org
[ Upstream commit 16932237f2978a2265662f8de4af743b1f55a209 ]
This reverts commit 145e1c0023585e0e8f6df22316308ec61c5066b2.
This commit broke the behavior of __copy_from_user_inatomic when
it is only partially successful. Instead of returning the number
of bytes not copied, it now returns 1. This translates to the
wrong value being returned by iov_iter_copy_from_user_atomic.
xfstests generic/246 and LTP writev01 both fail on btrfs and nfs
because of this.
Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
Cc: sparclinux@vger.kernel.org
commit 20841405940e7be0617612d521e206e4b6b325db upstream.
There are a few subtle races, between change_protection_range (used by
mprotect and change_prot_numa) on one side, and NUMA page migration and
compaction on the other side.
The basic race is that there is a time window between when the PTE gets
made non-present (PROT_NONE or NUMA), and the TLB is flushed.
During that time, a CPU may continue writing to the page.
This is fine most of the time, however compaction or the NUMA migration
code may come in, and migrate the page away.
When that happens, the CPU may continue writing, through the cached
translation, to what is no longer the current memory location of the
process.
This only affects x86, which has a somewhat optimistic pte_accessible.
All other architectures appear to be safe, and will either always flush,
or flush whenever there is a valid mapping, even with no permissions
(SPARC).
The basic race looks like this:
CPU A CPU B CPU C
load TLB entry
make entry PTE/PMD_NUMA
fault on entry
read/write old page
start migrating page
change PTE/PMD to new page
read/write old page [*]
flush TLB
reload TLB from new entry
read/write new page
lose data
[*] the old page may belong to a new user at this point!
The obvious fix is to flush remote TLB entries, by making sure that
pte_accessible aware of the fact that PROT_NONE and PROT_NUMA memory may
still be accessible if there is a TLB flush pending for the mm.
This should fix both NUMA migration and compaction.
[mgorman@suse.de: fix build]
Signed-off-by: Rik van Riel <riel@redhat.com>
Cc: Alex Thorlton <athorlton@sgi.com>
commit 3f0116c3238a96bc18ad4b4acefe4e7be32fa861 upstream.
Fengguang Wu, Oleg Nesterov and Peter Zijlstra tracked down
a kernel crash to a GCC bug: GCC miscompiles certain 'asm goto'
constructs, as outlined here:
http://gcc.gnu.org/bugzilla/show_bug.cgi?id=58670
Implement a workaround suggested by Jakub Jelinek.
Reported-and-tested-by: Fengguang Wu <fengguang.wu@intel.com>
Reported-by: Oleg Nesterov <oleg@redhat.com>
Reported-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Suggested-by: Jakub Jelinek <jakub@redhat.com>
Reviewed-by: Richard Henderson <rth@twiddle.net>
Link: http://lkml.kernel.org/r/20131015062351.GA4666@gmail.com
This reduces the need from two timers to one timer.
Moreover, without this patch, when the "ticker" timer triggers timer_cs_read via
tick_periodic it reads the value of the usual timer it can get an wrapped timer
value without timer_cs_internal_counter having been updated leading to the clock
going backwards. This effectively hangs one cpu that gets stuck in
update_wall_time with an offset slightly smaller than 0xffffffffffffffff.
Signed-off-by: Andreas Larsson <andreas@gaisler.com>
Merge sparc bug fixes that didn't make it into v3.9 into
sparc-next.
Pull networking updates from David Miller:
"Highlights (1721 non-merge commits, this has to be a record of some
sort):
1) Add 'random' mode to team driver, from Jiri Pirko and Eric
Dumazet.
2) Make it so that any driver that supports configuration of multiple
MAC addresses can provide the forwarding database add and del
calls by providing a default implementation and hooking that up if
the driver doesn't have an explicit set of handlers. From Vlad
Yasevich.
3) Support GSO segmentation over tunnels and other encapsulating
devices such as VXLAN, from Pravin B Shelar.
4) Support L2 GRE tunnels in the flow dissector, from Michael Dalton.
5) Implement Tail Loss Probe (TLP) detection in TCP, from Nandita
Dukkipati.
6) In the PHY layer, allow supporting wake-on-lan in situations where
the PHY registers have to be written for it to be configured.
Use it to support wake-on-lan in mv643xx_eth.
From Michael Stapelberg.
7) Significantly improve firewire IPV6 support, from YOSHIFUJI
Hideaki.
8) Allow multiple packets to be sent in a single transmission using
network coding in batman-adv, from Martin Hundebøll.
9) Add support for T5 cxgb4 chips, from Santosh Rastapur.
10) Generalize the VXLAN forwarding tables so that there is more
flexibility in configurating various aspects of the endpoints.
From David Stevens.
11) Support RSS and TSO in hardware over GRE tunnels in bxn2x driver,
from Dmitry Kravkov.
12) Zero copy support in nfnelink_queue, from Eric Dumazet and Pablo
Neira Ayuso.
13) Start adding networking selftests.
14) In situations of overload on the same AF_PACKET fanout socket, or
per-cpu packet receive queue, minimize drop by distributing the
load to other cpus/fanouts. From Willem de Bruijn and Eric
Dumazet.
15) Add support for new payload offset BPF instruction, from Daniel
Borkmann.
16) Convert several drivers over to mdoule_platform_driver(), from
Sachin Kamat.
17) Provide a minimal BPF JIT image disassembler userspace tool, from
Daniel Borkmann.
18) Rewrite F-RTO implementation in TCP to match the final
specification of it in RFC4138 and RFC5682. From Yuchung Cheng.
19) Provide netlink socket diag of netlink sockets ("Yo dawg, I hear
you like netlink, so I implemented netlink dumping of netlink
sockets.") From Andrey Vagin.
20) Remove ugly passing of rtnetlink attributes into rtnl_doit
functions, from Thomas Graf.
21) Allow userspace to be able to see if a configuration change occurs
in the middle of an address or device list dump, from Nicolas
Dichtel.
22) Support RFC3168 ECN protection for ipv6 fragments, from Hannes
Frederic Sowa.
23) Increase accuracy of packet length used by packet scheduler, from
Jason Wang.
24) Beginning set of changes to make ipv4/ipv6 fragment handling more
scalable and less susceptible to overload and locking contention,
from Jesper Dangaard Brouer.
25) Get rid of using non-type-safe NLMSG_* macros and use nlmsg_*()
instead. From Hong Zhiguo.
26) Optimize route usage in IPVS by avoiding reference counting where
possible, from Julian Anastasov.
27) Convert IPVS schedulers to RCU, also from Julian Anastasov.
28) Support cpu fanouts in xt_NFQUEUE netfilter target, from Holger
Eitzenberger.
29) Network namespace support for nf_log, ebt_log, xt_LOG, ipt_ULOG,
nfnetlink_log, and nfnetlink_queue. From Gao feng.
30) Implement RFC3168 ECN protection, from Hannes Frederic Sowa.
31) Support several new r8169 chips, from Hayes Wang.
32) Support tokenized interface identifiers in ipv6, from Daniel
Borkmann.
33) Use usbnet_link_change() helper in USB net driver, from Ming Lei.
34) Add 802.1ad vlan offload support, from Patrick McHardy.
35) Support mmap() based netlink communication, also from Patrick
McHardy.
36) Support HW timestamping in mlx4 driver, from Amir Vadai.
37) Rationalize AF_PACKET packet timestamping when transmitting, from
Willem de Bruijn and Daniel Borkmann.
38) Bring parity to what's provided by /proc/net/packet socket dumping
and the info provided by netlink socket dumping of AF_PACKET
sockets. From Nicolas Dichtel.
39) Fix peeking beyond zero sized SKBs in AF_UNIX, from Benjamin
Poirier"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits)
filter: fix va_list build error
af_unix: fix a fatal race with bit fields
bnx2x: Prevent memory leak when cnic is absent
bnx2x: correct reading of speed capabilities
net: sctp: attribute printl with __printf for gcc fmt checks
netlink: kconfig: move mmap i/o into netlink kconfig
netpoll: convert mutex into a semaphore
netlink: Fix skb ref counting.
net_sched: act_ipt forward compat with xtables
mlx4_en: fix a build error on 32bit arches
Revert "bnx2x: allow nvram test to run when device is down"
bridge: avoid OOPS if root port not found
drivers: net: cpsw: fix kernel warn on cpsw irq enable
sh_eth: use random MAC address if no valid one supplied
3c509.c: call SET_NETDEV_DEV for all device types (ISA/ISAPnP/EISA)
tg3: fix to append hardware time stamping flags
unix/stream: fix peeking with an offset larger than data in queue
unix/dgram: fix peeking with an offset larger than data in queue
unix/dgram: peek beyond 0-sized skbs
openvswitch: Remove unneeded ovs_netdev_get_ifindex()
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal
Pull compat cleanup from Al Viro:
"Mostly about syscall wrappers this time; there will be another pile
with patches in the same general area from various people, but I'd
rather push those after both that and vfs.git pile are in."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal:
syscalls.h: slightly reduce the jungles of macros
get rid of union semop in sys_semctl(2) arguments
make do_mremap() static
sparc: no need to sign-extend in sync_file_range() wrapper
ppc compat wrappers for add_key(2) and request_key(2) are pointless
x86: trim sys_ia32.h
x86: sys32_kill and sys32_mprotect are pointless
get rid of compat_sys_semctl() and friends in case of ARCH_WANT_OLD_COMPAT_IPC
merge compat sys_ipc instances
consolidate compat lookup_dcookie()
convert vmsplice to COMPAT_SYSCALL_DEFINE
switch getrusage() to COMPAT_SYSCALL_DEFINE
switch epoll_pwait to COMPAT_SYSCALL_DEFINE
convert sendfile{,64} to COMPAT_SYSCALL_DEFINE
switch signalfd{,4}() to COMPAT_SYSCALL_DEFINE
make SYSCALL_DEFINE<n>-generated wrappers do asmlinkage_protect
make HAVE_SYSCALL_WRAPPERS unconditional
consolidate cond_syscall and SYSCALL_ALIAS declarations
teach SYSCALL_DEFINE<n> how to deal with long long/unsigned long long
get rid of duplicate logics in __SC_....[1-6] definitions
Pull SMP/hotplug changes from Ingo Molnar:
"This is a pretty large, multi-arch series unifying and generalizing
the various disjunct pieces of idle routines that architectures have
historically copied from each other and have grown in random, wildly
inconsistent and sometimes buggy directions:
101 files changed, 455 insertions(+), 1328 deletions(-)
this went through a number of review and test iterations before it was
committed, it was tested on various architectures, was exposed to
linux-next for quite some time - nevertheless it might cause problems
on architectures that don't read the mailing lists and don't regularly
test linux-next.
This cat herding excercise was motivated by the -rt kernel, and was
brought to you by Thomas "the Whip" Gleixner."
* 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (40 commits)
idle: Remove GENERIC_IDLE_LOOP config switch
um: Use generic idle loop
ia64: Make sure interrupts enabled when we "safe_halt()"
sparc: Use generic idle loop
idle: Remove unused ARCH_HAS_DEFAULT_IDLE
bfin: Fix typo in arch_cpu_idle()
xtensa: Use generic idle loop
x86: Use generic idle loop
unicore: Use generic idle loop
tile: Use generic idle loop
tile: Enter idle with preemption disabled
sh: Use generic idle loop
score: Use generic idle loop
s390: Use generic idle loop
powerpc: Use generic idle loop
parisc: Use generic idle loop
openrisc: Use generic idle loop
mn10300: Use generic idle loop
mips: Use generic idle loop
microblaze: Use generic idle loop
Commit abf09bed3cce ("s390/mm: implement software dirty bits")
introduced another difference in the pte layout vs. the pmd layout on
s390, thoroughly breaking the s390 support for hugetlbfs. This requires
replacing some more pte_xxx functions in mm/hugetlbfs.c with a
huge_pte_xxx version.
This patch introduces those huge_pte_xxx functions and their generic
implementation in asm-generic/hugetlb.h, which will now be included on
all architectures supporting hugetlbfs apart from s390. This change
will be a no-op for those architectures.
[akpm@linux-foundation.org: fix warning]
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Cc: Hillf Danton <dhillf@gmail.com>
Acked-by: Michal Hocko <mhocko@suse.cz> [for !s390 parts]
Cc: Chris Metcalf <cmetcalf@tilera.com>
drivers/net/ethernet/emulex/benet/be_main.c
drivers/net/ethernet/intel/igb/igb_main.c
drivers/net/wireless/brcm80211/brcmsmac/mac80211_if.c
include/net/scm.h
net/batman-adv/routing.c
net/ipv4/tcp_input.c
The e{uid,gid} --> {uid,gid} credentials fix conflicted with the
cleanup in net-next to now pass cred structs around.
The be2net driver had a bug fix in 'net' that overlapped with the VLAN
interface changes by Patrick McHardy in net-next.
An IGB conflict existed because in 'net' the build_skb() support was
reverted, and in 'net-next' there was a comment style fix within that
code.
Several batman-adv conflicts were resolved by making sure that all
calls to batadv_is_my_mac() are changed to have a new bat_priv first
argument.
Eric Dumazet's TS ECR fix in TCP in 'net' conflicted with the F-RTO
rewrite in 'net-next', mostly overlapping changes.
Thanks to Stephen Rothwell and Antonio Quartulli for help with several
of these merge resolutions.
As reported by Dave Kleikamp, when we emit cross calls to do batched
TLB flush processing we have a race because we do not synchronize on
the sibling cpus completing the cross call.
So meanwhile the TLB batch can be reset (tb->tlb_nr set to zero, etc.)
and either flushes are missed or flushes will flush the wrong
addresses.
Fix this by using generic infrastructure to synchonize on the
completion of the cross call.
This first required getting the flush_tlb_pending() call out from
switch_to() which operates with locks held and interrupts disabled.
The problem is that smp_call_function_many() cannot be invoked with
IRQs disabled and this is explicitly checked for with WARN_ON_ONCE().
We get the batch processing outside of locked IRQ disabled sections by
using some ideas from the powerpc port. Namely, we only batch inside
of arch_{enter,leave}_lazy_mmu_mode() calls. If we're not in such a
region, we flush TLBs synchronously.
1) Get rid of xcall_flush_tlb_pending and per-cpu type
implementations.
2) Do TLB batch cross calls instead via:
tlb_pending_func()
__flush_tlb_pending()
3) Batch only in lazy mmu sequences:
a) Add 'active' member to struct tlb_batch
b) Define __HAVE_ARCH_ENTER_LAZY_MMU_MODE
c) Set 'active' in arch_enter_lazy_mmu_mode()
d) Run batch and clear 'active' in arch_leave_lazy_mmu_mode()
e) Check 'active' in tlb_batch_add_one() and do a synchronous
flush if it's clear.
4) Add infrastructure for synchronous TLB page flushes.
a) Implement __flush_tlb_page and per-cpu variants, patch
as needed.
b) Likewise for xcall_flush_tlb_page.
c) Implement smp_flush_tlb_page() to invoke the cross-call.
d) Wire up global_flush_tlb_page() to the right routine based
upon CONFIG_SMP
5) It turns out that singleton batches are very common, 2 out of every
3 batch flushes have only a single entry in them.
The batch flush waiting is very expensive, both because of the poll
on sibling cpu completeion, as well as because passing the tlb batch
pointer to the sibling cpus invokes a shared memory dereference.
Therefore, in flush_tlb_pending(), if there is only one entry in
the batch perform a completely asynchronous global_flush_tlb_page()
instead.
Reported-by: Dave Kleikamp <dave.kleikamp@oracle.com>
Acked-by: Dave Kleikamp <dave.kleikamp@oracle.com>
get_new_mmu_context() is always called with interrupts disabled.
So it's possible to do this micro optimization.
(Also fix the comment to switch_mm, which is called in both cases)
Signed-off-by: Kirill Tkhai <tkhai@yandex.ru>
CC: David Miller <davem@davemloft.net>
Move it to a common place. Preparatory patch for implementing
set/clear for the idle need_resched poll implementation.
Cc: Paul McKenney <paulmck@linux.vnet.ibm.com>
Reviewed-by: Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Cc: Magnus Damm <magnus.damm@gmail.com>
Link: http://lkml.kernel.org/r/20130321215233.446034505@linutronix.de
For consistency, don't use 'mov'.
Currently, when a socket receives something on the error queue it only wakes up
the socket on select if it is in the "read" list, that is the socket has
something to read. It is useful also to wake the socket if it is in the error
list, which would enable software to wait on error queue packets without waking
up for regular data on the socket. The main use case is for receiving
timestamped transmit packets which return the timestamp to the socket via the
error queue. This enables an application to select on the socket for the error
queue only instead of for the regular traffic.
-v2-
* Added the SO_SELECT_ERR_QUEUE socket option to every architechture specific file
* Modified every socket poll function that checks error queue
Signed-off-by: Jacob Keller <jacob.e.keller@intel.com>
Cc: Jeffrey Kirsher <jeffrey.t.kirsher@intel.com>
Cc: Richard Cochran <richardcochran@gmail.com>
Cc: Matthew Vick <matthew.vick@intel.com>
In sparc headers we use the following pattern:
#if defined(__sparc__) && defined(__arch64__)
sparc64 specific stuff
#else
sparc32 specific stuff
#endif
In types.h this pattern was not followed and here
we only checked for __sparc__ for no good reason.
It was a left-over from long time ago.
I checked other architectures - and most of them
do not have any such checks. And all the recently
merged versions uses the asm-generic version.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Use "generic-y" to add generic headers where possible
After genirq and generic clockevent support at sparc32,
smp4m_irq_rotate(), prof_multiplier() and prof_counter()
are no longer used and should be removed.
Find more info from commit 6baa9b20 & 62f08283.
Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
smp_boot_cpus() was replaced smp_prepare_cpus() long ago, and it no
longer needed, so delete it.
As Peter Z. explained at:
https://lkml.org/lkml/2011/12/12/268
it's not needed at all and I even tested it back then.
This patch just got lost in the shuffle for some reason.
Reported-by: Kirill Tkhai <tkhai@yandex.ru>
sparc64 allmodconfig:
drivers/block/blockconsole.c: In function ‘bcon_advance_console_bytes’:
drivers/block/blockconsole.c:164: error: implicit declaration of function ‘cmpxchg64’
Map cmpxchg64() to cmpxchg64_local() (which eventually calls
__cmpxchg_u64()) to fix this.
This patch adds CONFIG_HIBERNATION support for sparc64
architecture. The suspend function is the same as on another
platforms. The restore function uses Bypass feature of MMU
which allows to make the process more comfortable and plesant.
CC: Sam Ravnborg <sam@ravnborg.org>
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
The following patch adds support for correctly
recognizing SPARC-X chips.
cpu : Unknown SUN4V CPU
fpu : Unknown SUN4V FPU
pmu : Unknown SUN4V PMU
Signed-off-by: Katayama Yoshihiro <kata1@jp.fujitsu.com>
Signed-off-by: Allen Pais <allen.pais@oracle.com>
take them to asm/linkage.h, with default in linux/linkage.h
Pull vfs pile (part one) from Al Viro:
"Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent
locking violations, etc.
The most visible changes here are death of FS_REVAL_DOT (replaced with
"has ->d_weak_revalidate()") and a new helper getting from struct file
to inode. Some bits of preparation to xattr method interface changes.
Misc patches by various people sent this cycle *and* ocfs2 fixes from
several cycles ago that should've been upstream right then.
PS: the next vfs pile will be xattr stuff."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits)
saner proc_get_inode() calling conventions
proc: avoid extra pde_put() in proc_fill_super()
fs: change return values from -EACCES to -EPERM
fs/exec.c: make bprm_mm_init() static
ocfs2/dlm: use GFP_ATOMIC inside a spin_lock
ocfs2: fix possible use-after-free with AIO
ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path
get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero
target: writev() on single-element vector is pointless
export kernel_write(), convert open-coded instances
fs: encode_fh: return FILEID_INVALID if invalid fid_type
kill f_vfsmnt
vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op
nfsd: handle vfs_getattr errors in acl protocol
switch vfs_getattr() to struct path
default SET_PERSONALITY() in linux/elf.h
ceph: prepopulate inodes only when request is aborted
d_hash_and_lookup(): export, switch open-coded instances
9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate()
9p: split dropping the acls from v9fs_set_create_acl()
Pull signal handling cleanups from Al Viro:
"This is the first pile; another one will come a bit later and will
contain SYSCALL_DEFINE-related patches.
- a bunch of signal-related syscalls (both native and compat)
unified.
- a bunch of compat syscalls switched to COMPAT_SYSCALL_DEFINE
(fixing several potential problems with missing argument
validation, while we are at it)
- a lot of now-pointless wrappers killed
- a couple of architectures (cris and hexagon) forgot to save
altstack settings into sigframe, even though they used the
(uninitialized) values in sigreturn; fixed.
- microblaze fixes for delivery of multiple signals arriving at once
- saner set of helpers for signal delivery introduced, several
architectures switched to using those."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (143 commits)
x86: convert to ksignal
sparc: convert to ksignal
arm: switch to struct ksignal * passing
alpha: pass k_sigaction and siginfo_t using ksignal pointer
burying unused conditionals
make do_sigaltstack() static
arm64: switch to generic old sigaction() (compat-only)
arm64: switch to generic compat rt_sigaction()
arm64: switch compat to generic old sigsuspend
arm64: switch to generic compat rt_sigqueueinfo()
arm64: switch to generic compat rt_sigpending()
arm64: switch to generic compat rt_sigprocmask()
arm64: switch to generic sigaltstack
sparc: switch to generic old sigsuspend
sparc: COMPAT_SYSCALL_DEFINE does all sign-extension as well as SYSCALL_DEFINE
sparc: kill sign-extending wrappers for native syscalls
kill sparc32_open()
sparc: switch to use of generic old sigaction
sparc: switch sys_compat_rt_sigaction() to COMPAT_SYSCALL_DEFINE
mips: switch to generic sys_fork() and sys_clone()
Pull networking update from David Miller:
1) Checkpoint/restarted TCP sockets now can properly propagate the TCP
timestamp offset. From Andrey Vagin.
2) VMWARE VM VSOCK layer, from Andy King.
3) Much improved support for virtual functions and SR-IOV in bnx2x,
from Ariel ELior.
4) All protocols on ipv4 and ipv6 are now network namespace aware, and
all the compatability checks for initial-namespace-only protocols is
removed. Thanks to Tom Parkin for helping deal with the last major
holdout, L2TP.
5) IPV6 support in netpoll and network namespace support in pktgen,
from Cong Wang.
6) Multiple Registration Protocol (MRP) and Multiple VLAN Registration
Protocol (MVRP) support, from David Ward.
7) Compute packet lengths more accurately in the packet scheduler, from
Eric Dumazet.
8) Use per-task page fragment allocator in skb_append_datato_frags(),
also from Eric Dumazet.
9) Add support for connection tracking labels in netfilter, from
Florian Westphal.
10) Fix default multicast group joining on ipv6, and add anti-spoofing
checks to 6to4 and 6rd. From Hannes Frederic Sowa.
11) Make ipv4/ipv6 fragmentation memory limits more reasonable in modern
times, rearrange inet frag datastructures for better cacheline
locality, and move more operations outside of locking. From Jesper
Dangaard Brouer.
12) Instead of strict master <--> slave relationships, allow arbitrary
scenerios with "upper device lists". From Jiri Pirko.
13) Improve rate limiting accuracy in TBF and act_police, also from Jiri
Pirko.
14) Add a BPF filter netfilter match target, from Willem de Bruijn.
15) Orphan and delete a bunch of pre-historic networking drivers from
Paul Gortmaker.
16) Add TSO support for GRE tunnels, from Pravin B SHelar. Although
this still needs some minor bug fixing before it's %100 correct in
all cases.
17) Handle unresolved IPSEC states like ARP, with a resolution packet
queue. From Steffen Klassert.
18) Remove TCP Appropriate Byte Count support (ABC), from Stephen
Hemminger. This was long overdue.
19) Support SO_REUSEPORT, from Tom Herbert.
20) Allow locking a socket BPF filter, so that it cannot change after a
process drops capabilities.
21) Add VLAN filtering to bridge, from Vlad Yasevich.
22) Bring ipv6 on-par with ipv4 and do not cache neighbour entries in
the ipv6 routes, from YOSHIFUJI Hideaki.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1538 commits)
ipv6: fix race condition regarding dst->expires and dst->from.
net: fix a wrong assignment in skb_split()
ip_gre: remove an extra dst_release()
ppp: set qdisc_tx_busylock to avoid LOCKDEP splat
atl1c: restore buffer state
net: fix a build failure when !CONFIG_PROC_FS
net: ipv4: fix waring -Wunused-variable
net: proc: fix build failed when procfs is not configured
Revert "xen: netback: remove redundant xenvif_put"
net: move procfs code to net/core/net-procfs.c
qmi_wwan, cdc-ether: add ADU960S
bonding: set sysfs device_type to 'bond'
bonding: fix bond_release_all inconsistencies
b44: use netdev_alloc_skb_ip_align()
net: fec: Do a sanity check on the gpio number
ip_gre: propogate target device GSO capability to the tunnel device
ip_gre: allow CSUM capable devices to handle packets
bonding: Fix initialize after use for 3ad machine state spinlock
bonding: Fix race condition between bond_enslave() and bond_3ad_update_lacp_rate()
Pull sparc updates from David Miller:
"Mostly more sparc64 THP bug fixes, and a refactoring of SMP bootup on
sparc32 from Sam Ravnborg."
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc:
sparc32: refactor smp boot
sparc64: Fix huge PMD to PTE translation for sun4u in TLB miss handler.
sparc64: Fix tsb_grow() in atomic context.
sparc64: Handle hugepage TSB being NULL.
sparc64: Fix gfp_flags setting in tsb_grow().
When we set the sun4u version of the PTE execute bit, it's:
or REG, _PAGE_EXEC_4U, REG
_PAGE_EXEC_4U is 0x1000, unfortunately the immedate field of the
'or' instruction is a signed 13-bit value. So the above actually
assembles into:
or REG, -4096, REG
completely corrupting the final PTE value.
Set it with a:
sethi %hi(_PAGE_EXEC_4U), TMP
or REG, TMP, REG
sequence instead.
This fixes "git gc" crashes on sun4u machines.
Reported-by: Meelis Roos <mroos@linux.ee>
Pull ACPI and power management updates from Rafael Wysocki:
- Rework of the ACPI namespace scanning code from Rafael J. Wysocki
with contributions from Bjorn Helgaas, Jiang Liu, Mika Westerberg,
Toshi Kani, and Yinghai Lu.
- ACPI power resources handling and ACPI device PM update from Rafael
J Wysocki.
- ACPICA update to version 20130117 from Bob Moore and Lv Zheng with
contributions from Aaron Lu, Chao Guan, Jesper Juhl, and Tim Gardner.
- Support for Intel Lynxpoint LPSS from Mika Westerberg.
- cpuidle update from Len Brown including Intel Haswell support, C1
state for intel_idle, removal of global pm_idle.
- cpuidle fixes and cleanups from Daniel Lezcano.
- cpufreq fixes and cleanups from Viresh Kumar and Fabio Baltieri with
contributions from Stratos Karafotis and Rickard Andersson.
- Intel P-states driver for Sandy Bridge processors from Dirk
Brandewie.
- cpufreq driver for Marvell Kirkwood SoCs from Andrew Lunn.
- cpufreq fixes related to ordering issues between acpi-cpufreq and
powernow-k8 from Borislav Petkov and Matthew Garrett.
- cpufreq support for Calxeda Highbank processors from Mark Langsdorf
and Rob Herring.
- cpufreq driver for the Freescale i.MX6Q SoC and cpufreq-cpu0 update
from Shawn Guo.
- cpufreq Exynos fixes and cleanups from Jonghwan Choi, Sachin Kamat,
and Inderpal Singh.
- Support for "lightweight suspend" from Zhang Rui.
- Removal of the deprecated power trace API from Paul Gortmaker.
- Assorted updates from Andreas Fleig, Colin Ian King, Davidlohr Bueso,
Joseph Salisbury, Kees Cook, Li Fei, Nishanth Menon, ShuoX Liu,
Srinivas Pandruvada, Tejun Heo, Thomas Renninger, and Yasuaki
Ishimatsu.
* tag 'pm+acpi-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (267 commits)
PM idle: remove global declaration of pm_idle
unicore32 idle: delete stray pm_idle comment
openrisc idle: delete pm_idle
mn10300 idle: delete pm_idle
microblaze idle: delete pm_idle
m32r idle: delete pm_idle, and other dead idle code
ia64 idle: delete pm_idle
cris idle: delete idle and pm_idle
ARM64 idle: delete pm_idle
ARM idle: delete pm_idle
blackfin idle: delete pm_idle
sparc idle: rename pm_idle to sparc_idle
sh idle: rename global pm_idle to static sh_idle
x86 idle: rename global pm_idle to static x86_idle
APM idle: register apm_cpu_idle via cpuidle
cpufreq / intel_pstate: Add kernel command line option disable intel_pstate.
cpufreq / intel_pstate: Change to disallow module build
tools/power turbostat: display SMI count by default
intel_idle: export both C1 and C1E
ACPI / hotplug: Fix concurrency issues and memory leaks
If our first THP installation for an MM is via the set_pmd_at() done
during khugepaged's collapsing we'll end up in tsb_grow() trying to do
a GFP_KERNEL allocation with several locks held.
Simply using GFP_ATOMIC in this situation is not the best option
because we really can't have this fail, so we'd really like to keep
this an order 0 GFP_KERNEL allocation if possible.
Also, doing the TSB allocation from khugepaged is a really bad idea
because we'll allocate it potentially from the wrong NUMA node in that
context.
So what we do is defer the hugepage TSB allocation until the first TLB
miss we take on a hugepage. This is slightly tricky because we have
to handle two unusual cases:
1) Taking the first hugepage TLB miss in the window trap handler.
We'll call the winfix_trampoline when that is detected.
2) An initial TSB allocation via TLB miss races with a hugetlb
fault on another cpu running the same MM. We handle this by
unconditionally loading the TSB we see into the current cpu
even if it's non-NULL at hugetlb_setup time.
Reported-by: Meelis Roos <mroos@ut.ee>
(pm_idle)() is being removed from linux/pm.h
because Linux does not have such a cross-architecture concept.
sparc uses an idle function pointer in its architecture
specific code. So we re-name sparc use of pm_idle to sparc_idle.
Signed-off-by: Len Brown <len.brown@intel.com>
__ARCH_WANT_SYS_RT_SIGACTION,
__ARCH_WANT_SYS_RT_SIGSUSPEND,
__ARCH_WANT_COMPAT_SYS_RT_SIGSUSPEND,
__ARCH_WANT_COMPAT_SYS_SCHED_RR_GET_INTERVAL - not used anymore
CONFIG_GENERIC_{SIGALTSTACK,COMPAT_RT_SIG{ACTION,QUEUEINFO,PENDING,PROCMASK}} -
can be assumed always set.
Mostly mirrors the s390 logic, as unlike x86 we don't need the
SetPageReferenced() bits.
On sparc64 we also lack a user/privileged bit in the huge PMDs.
In order to make this work for THP and non-THP builds, some header
file adjustments were necessary. Namely, provide the PMD_HUGE_* bit
defines and the pmd_large() inline unconditionally rather than
protected by TRANSPARENT_HUGEPAGE.
Reported-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
note that due to historical accident we do *not* directly take
generic versions - need to check and invert the sign of signal
number first.
Only alpha and sparc are unusual - they have ka_restorer in it.
And nobody needs that exposed to userland.
Definitions and macros for implementing soreusport.
Signed-off-by: Tom Herbert <therbert@google.com>
While a privileged program can open a raw socket, attach some
restrictive filter and drop its privileges (or send the socket to an
unprivileged program through some Unix socket), the filter can still
be removed or modified by the unprivileged program. This commit adds a
socket option to lock the filter (SO_LOCK_FILTER) preventing any
modification of a socket filter program.
This is similar to OpenBSD BIOCLOCK ioctl on bpf sockets, except even
root is not allowed change/drop the filter.
The state of the lock can be read with getsockopt(). No error is
triggered if the state is not changed. -EPERM is returned when a user
tries to remove the lock or to change/remove the filter while the lock
is active. The check is done directly in sk_attach_filter() and
sk_detach_filter() and does not affect only setsockopt() syscall.
Signed-off-by: Vincent Bernat <bernat@luffy.cx>
__devinit, __devexit annotations are nops - so drop them.
Likewise for __devexit_p.
Adjusted alignment of arguments when needed.
"sigaltstack infrastructure + conversion for x86, alpha and um,
COMPAT_SYSCALL_DEFINE infrastructure.
Note that there are several conflicts between "unify
SS_ONSTACK/SS_DISABLE definitions" and UAPI patches in mainline;
resolution is trivial - just remove definitions of SS_ONSTACK and
SS_DISABLED from arch/*/uapi/asm/signal.h; they are all identical and
include/uapi/linux/signal.h contains the unified variant."
Fixed up conflicts as per Al.
alpha: switch to generic sigaltstack
new helpers: __save_altstack/__compat_save_altstack, switch x86 and um to those
generic compat_sys_sigaltstack()
introduce generic sys_sigaltstack(), switch x86 and um to it
new helper: compat_user_stack_pointer()
new helper: restore_altstack()
unify SS_ONSTACK/SS_DISABLE definitions
new helper: current_user_stack_pointer()
missing user_stack_pointer() instances
Bury the conditionals from kernel_thread/kernel_execve series
COMPAT_SYSCALL_DEFINE: infrastructure
