This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
Adapt new API. Almost change is trivial, most important change are to
remove following like =operator.
cpumask_t cpu_mask = *mm_cpumask(mm);
cpus_allowed = current->cpus_allowed;
Because cpumask_var_t is =operator unsafe. These usage might prevent
kernel core improvement.
No functional change.
Cc: sparclinux@vger.kernel.org
Scripted with coccinelle.
Use the proper wrapper functions.
Make use of the new features in genirq:
1) Set the chip flag IRCHIP_EOI_IF_HANDLED, which ensures in the
core code that irq_eoi() is only called when the interrupt was
handled. That removes the extra status check in the callback.
2) Use the preflow handler, which is called from the fasteoi core code
before the device handler. That avoids another status check and the
open coded handler redirection.
The generic irq support uses the term 'irq' for the
allocated irq number.
Fix it so sparc64 use the same term for an irq as the
generic irq support does.
For a naive reader this is less confusing.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Drop all uses of deprecated genirq features.
The irq_set_affinity() call got a third paramter 'force'
which is unused.
For now genirq does not use this paramter and it is
ignored by sparc.
Cc: Josip Rodin <joy@entuzijast.net>
{get,set}_irq_data uses the member "handler_data" in irq_data
which fits the naem of the datatype.
The change has no functional impact
In preparation of moving to use irq_data.handler_data rename
all pointers to irq_handler_data "handler_data".
This will also prevent name clash when we introduce the
new irq methods.
The generic irq support uses "irq" to identify the
virtual irq number. To avoid confusion rename the
argument to handler_irq() to pil to match the
name of the parameter in the PCR register.
GENERIC_HARDIRQS_NO_DEPRECATED require us to access data via irq_data.
No functional changes as data has same layout due to use of union
Otherwise we can overflow the main stack with the function tracer
enabled.
Fix forgotten kmemleak headers inclusion for kmemleak_not_leak()
declaration.
This fixes the following build error:
arch/sparc/kernel/irq_64.c: In function ‘sun4v_build_virq’:
arch/sparc/kernel/irq_64.c:657: error: implicit declaration of function ‘kmemleak_not_leak’
The only reference we store to this memory is in the form of a
physical address, so kmemleak can't see it.
Add a kmemleak_not_leak() annotation.
It's probably useful to be able to look at a dump of these things
either via debugfs or similar, and thus we could at some point store
them in some kind of table and therefore get rid of this annotation.
Can't reference irq_desc[].affinity when !SMP.
Reported-by: Alexander Beregalov <a.beregalov@gmail.com>
As noted by Benjamin Herrenschmidt, the generic IRQ layer
only sets irq_desc[irq].affinity after ->set_affinity()
succeeds.
So we have to use the passed in cpumask.
Convert locks which cannot be sleeping locks in preempt-rt to
raw_spinlocks.
Acked-by: Peter Zijlstra <peterz@infradead.org>
The typename member of struct irq_chip was kept for migration purposes
and is obsolete since more than 2 years. Fix up the leftovers.
Functions invoked early when booting up a cpu can't use
tracing because mcount requires a valid 'current_thread_info()'
and TLB mappings to be setup.
The code path of sun4v_register_mondo_queues --> register_one_mondo
is one such case. sun4v_register_mondo_queues already has the
necessary 'notrace' annotation, but register_one_mondo does not.
Normally register_one_mondo is inlined so the bug doesn't trigger,
but with some config/compiler combinations, it won't be so we
must properly mark it notrace.
While we're here, add 'notrace' annoations to prom_printf and
prom_halt so that early error handling won't have the same problem.
Reported-by: Leif Sawyer <lsawyer@gci.com>
The page allocator and SLAB are available at this point now,
and if we still try to use bootmem allocations here the kernel
spits out warnings.
irq_choose_cpu() should compare the affinity mask against cpu_online_map
rather than CPU_MASK_ALL, since irq_select_affinity() sets the interrupt's
affinity mask to cpu_online_map "and" CPU_MASK_ALL (which ends up being
just cpu_online_map). The mask comparison in irq_choose_cpu() will always
fail since the two masks are not the same. So the CPU chosen is the first CPU
in the intersection of cpu_online_map and CPU_MASK_ALL, which is always CPU0.
That means all interrupts are reassigned to CPU0...
Distributing interrupts to CPUs in a linearly increasing round robin fashion
is not optimal for the UltraSPARC T1/T2. Also, the irq_rover in
irq_choose_cpu() causes an interrupt to be assigned to a different
processor each time the interrupt is allocated and released. This may lead
to an unbalanced distribution over time.
A static mapping of interrupts to processors is done to optimize and balance
interrupt distribution. For the T1/T2, interrupts are spread to different
cores first, and then to strands within a core.
The following is some benchmarks showing the effects of interrupt
distribution on a T2. The test was done with iperf using a pair of T5220
boxes, each with a 10GBe NIU (XAUI) connected back to back.
TCP | Stock Linear RR IRQ Optimized IRQ
Streams | 2.6.30-rc5 Distribution Distribution
| GBits/sec GBits/sec GBits/sec
1 0.839 0.862 0.868
8 1.16 4.96 5.88
16 1.15 6.40 8.04
100 1.09 7.28 8.68
Signed-off-by: Hong H. Pham <hong.pham@windriver.com>
according to Ingo, change set_affinity() in irq_chip should return int,
because that way we can handle failure cases in a much cleaner way, in
the genirq layer.
v2: fix two typos
[ Impact: extend API ]
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Cc: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
LKML-Reference: <49F654E9.4070809@kernel.org>
ssh://master.kernel.org/home/ftp/pub/scm/linux/kernel/git/rusty/linux-2.6-cpumask-for-sparc
arch/sparc/kernel/smp_64.c
arch/parisc/kernel/irq.c
arch/x86/include/asm/fixmap_64.h
arch/x86/include/asm/setup.h
kernel/irq/handle.c
Semantic merge:
arch/x86/include/asm/fixmap.h
sparc64
Impact: cleanup, futureproof
In fact, all cpumask ops will only be valid (in general) for bit
numbers < nr_cpu_ids. So use that instead of NR_CPUS in various
places.
This is always safe: no cpu number can be >= nr_cpu_ids, and
nr_cpu_ids is initialized to NR_CPUS at boot.
Signed-off-by: Mike Travis <travis@sgi.com>
Based upon a report by Meelis Roos.
Sparc64 SBUS and PCI controllers use a combination of IMAP and ICLR
registers to manage device interrupts.
The IMAP register contains the "valid" enable bit as well as CPU
targetting information. Whereas the ICLR register is written with
zero at the end of handling an interrupt to reset the state machine
for that interrupt to IDLE so it can be sent again.
For PCI slot and SBUS slot devices we can have multiple interrupts
sharing the same IMAP register. There are individual ICLR registers
but only one IMAP register for managing those.
We represent each shared case with individual virtual IRQs so the
generic IRQ layer thinks there is only one user of the IRQ instance.
In such shared IMAP cases this is wrong, so if there are multiple
active users then a free_irq() call will prematurely turn off the
interrupt by clearing the Valid bit in the IMAP register even though
there are other active users.
Fix this by simply doing nothing in sun4u_disable_irq() and checking
IRQF_DISABLED during IRQ dispatch.
This situation doesn't exist in the hypervisor sun4v cases, so I left
those alone.
Tested-by: Meelis Roos <mroos@linux.ee>
arch/x86/mach-voyager/voyager_smp.c
arch/x86/mm/fault.c
Changeset d7e51e66899f95dabc89b4d4c6674a6e50fa37fc ("sparseirq: make
some func to be used with genirq") broke the build on sparc64:
arch/sparc/kernel/irq_64.c: In function ‘show_interrupts’:
arch/sparc/kernel/irq_64.c:188: error: ‘struct kernel_stat’ has no member named ‘irqs’
make[1]: *** [arch/sparc/kernel/irq_64.o] Error 1
Fix by using the kstat_irqs_cpu() interface.
Impact: cleanup, update to new cpumask API
Irq_desc.affinity and irq_desc.pending_mask are now cpumask_var_t's
so access to them should be using the new cpumask API.
* 'cpus4096-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (66 commits)
x86: export vector_used_by_percpu_irq
x86: use logical apicid in x2apic_cluster's x2apic_cpu_mask_to_apicid_and()
sched: nominate preferred wakeup cpu, fix
x86: fix lguest used_vectors breakage, -v2
x86: fix warning in arch/x86/kernel/io_apic.c
sched: fix warning in kernel/sched.c
sched: move test_sd_parent() to an SMP section of sched.h
sched: add SD_BALANCE_NEWIDLE at MC and CPU level for sched_mc>0
sched: activate active load balancing in new idle cpus
sched: bias task wakeups to preferred semi-idle packages
sched: favour lower logical cpu number for sched_mc balance
sched: framework for sched_mc/smt_power_savings=N
sched: convert BALANCE_FOR_xx_POWER to inline functions
x86: use possible_cpus=NUM to extend the possible cpus allowed
x86: fix cpu_mask_to_apicid_and to include cpu_online_mask
x86: update io_apic.c to the new cpumask code
x86: Introduce topology_core_cpumask()/topology_thread_cpumask()
x86: xen: use smp_call_function_many()
x86: use work_on_cpu in x86/kernel/cpu/mcheck/mce_amd_64.c
Fixed up trivial conflict in kernel/time/tick-sched.c manually
o Move all files from sparc64/kernel/ to sparc/kernel
- rename as appropriate
o Update sparc/Makefile to the changes
o Update sparc/kernel/Makefile to include the sparc64 files
NOTE: This commit changes link order on sparc64!
Link order had to change for either of sparc32 and sparc64.
And assuming sparc64 see more testing than sparc32 change link
order on sparc64 where issues will be caught faster.
