path: root/arch/sparc/kernel/unaligned.c
2008-12-04sparc: prepare kernel/ for unificationSam Ravnborg
o sparc32 files with identical names to sparc64 renamed to <name>_32.S o introduced a few Kconfig helpers to simplify Makefile logic o refactored Makefile to prepare for unification - use obj-$(CONFIG_SPARC32) for sparc32 specific files - use <name>_$(BITS) for files where sparc64 has a _64 variant - sparc64 directly include a few files where sparc32 builds them, refer to these files directly (no BITS) - sneaked in -Werror as used by sparc64 o modified sparc/Makefile to use the new names for head/init_task Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20sparc: remove CVS keywordsAdrian Bunk
This patch removes the CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-03[SPARC]: Fix link errors with gcc-4.3David S. Miller
Reported by Adrian Bunk. Just like in changeset a3f9985843b674cbcb58f39fab8416675e7ab842 ("[SPARC64]: Move kernel unaligned trap handlers into assembler file.") we have to move the assembler bits into a seperate asm file because as far as the compiler is concerned these inline bits we're doing in unaligned.c are unreachable. Signed-off-by: David S. Miller <davem@davemloft.net>
