path: root/arch/sparc/kernel
2016-07-10sparc64: Fix return from trap window fill crashes.David S. Miller
[ Upstream commit 7cafc0b8bf130f038b0ec2dcdd6a9de6dc59b65a ] We must handle data access exception as well as memory address unaligned exceptions from return from trap window fill faults, not just normal TLB misses. Otherwise we can get an OOPS that looks like this: ld-linux.so.2(36808): Kernel bad sw trap 5 [#1] CPU: 1 PID: 36808 Comm: ld-linux.so.2 Not tainted 4.6.0 #34 task: fff8000303be5c60 ti: fff8000301344000 task.ti: fff8000301344000 TSTATE: 0000004410001601 TPC: 0000000000a1a784 TNPC: 0000000000a1a788 Y: 00000002 Not tainted TPC: <do_sparc64_fault+0x5c4/0x700> g0: fff8000024fc8248 g1: 0000000000db04dc g2: 0000000000000000 g3: 0000000000000001 g4: fff8000303be5c60 g5: fff800030e672000 g6: fff8000301344000 g7: 0000000000000001 o0: 0000000000b95ee8 o1: 000000000000012b o2: 0000000000000000 o3: 0000000200b9b358 o4: 0000000000000000 o5: fff8000301344040 sp: fff80003013475c1 ret_pc: 0000000000a1a77c RPC: <do_sparc64_fault+0x5bc/0x700> l0: 00000000000007ff l1: 0000000000000000 l2: 000000000000005f l3: 0000000000000000 l4: fff8000301347e98 l5: fff8000024ff3060 l6: 0000000000000000 l7: 0000000000000000 i0: fff8000301347f60 i1: 0000000000102400 i2: 0000000000000000 i3: 0000000000000000 i4: 0000000000000000 i5: 0000000000000000 i6: fff80003013476a1 i7: 0000000000404d4c I7: <user_rtt_fill_fixup+0x6c/0x7c> Call Trace: [0000000000404d4c] user_rtt_fill_fixup+0x6c/0x7c The window trap handlers are slightly clever, the trap table entries for them are composed of two pieces of code. First comes the code that actually performs the window fill or spill trap handling, and then there are three instructions at the end which are for exception processing. The userland register window fill handler is: add %sp, STACK_BIAS + 0x00, %g1; \ ldxa [%g1 + %g0] ASI, %l0; \ mov 0x08, %g2; \ mov 0x10, %g3; \ ldxa [%g1 + %g2] ASI, %l1; \ mov 0x18, %g5; \ ldxa [%g1 + %g3] ASI, %l2; \ ldxa [%g1 + %g5] ASI, %l3; \ add %g1, 0x20, %g1; \ ldxa [%g1 + %g0] ASI, %l4; \ ldxa [%g1 + %g2] ASI, %l5; \ ldxa [%g1 + %g3] ASI, %l6; \ ldxa [%g1 + %g5] ASI, %l7; \ add %g1, 0x20, %g1; \ ldxa [%g1 + %g0] ASI, %i0; \ ldxa [%g1 + %g2] ASI, %i1; \ ldxa [%g1 + %g3] ASI, %i2; \ ldxa [%g1 + %g5] ASI, %i3; \ add %g1, 0x20, %g1; \ ldxa [%g1 + %g0] ASI, %i4; \ ldxa [%g1 + %g2] ASI, %i5; \ ldxa [%g1 + %g3] ASI, %i6; \ ldxa [%g1 + %g5] ASI, %i7; \ restored; \ retry; nop; nop; nop; nop; \ b,a,pt %xcc, fill_fixup_dax; \ b,a,pt %xcc, fill_fixup_mna; \ b,a,pt %xcc, fill_fixup; And the way this works is that if any of those memory accesses generate an exception, the exception handler can revector to one of those final three branch instructions depending upon which kind of exception the memory access took. In this way, the fault handler doesn't have to know if it was a spill or a fill that it's handling the fault for. It just always branches to the last instruction in the parent trap's handler. For example, for a regular fault, the code goes: winfix_trampoline: rdpr %tpc, %g3 or %g3, 0x7c, %g3 wrpr %g3, %tnpc done All window trap handlers are 0x80 aligned, so if we "or" 0x7c into the trap time program counter, we'll get that final instruction in the trap handler. On return from trap, we have to pull the register window in but we do this by hand instead of just executing a "restore" instruction for several reasons. The largest being that from Niagara and onward we simply don't have enough levels in the trap stack to fully resolve all possible exception cases of a window fault when we are already at trap level 1 (which we enter to get ready to return from the original trap). This is executed inline via the FILL_*_RTRAP handlers. rtrap_64.S's code branches directly to these to do the window fill by hand if necessary. Now if you look at them, we'll see at the end: ba,a,pt %xcc, user_rtt_fill_fixup; ba,a,pt %xcc, user_rtt_fill_fixup; ba,a,pt %xcc, user_rtt_fill_fixup; And oops, all three cases are handled like a fault. This doesn't work because each of these trap types (data access exception, memory address unaligned, and faults) store their auxiliary info in different registers to pass on to the C handler which does the real work. So in the case where the stack was unaligned, the unaligned trap handler sets up the arg registers one way, and then we branched to the fault handler which expects them setup another way. So the FAULT_TYPE_* value ends up basically being garbage, and randomly would generate the backtrace seen above. Reported-by: Nick Alcock <nix@esperi.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-07-10sparc: Harden signal return frame checks.David S. Miller
[ Upstream commit d11c2a0de2824395656cf8ed15811580c9dd38aa ] All signal frames must be at least 16-byte aligned, because that is the alignment we explicitly create when we build signal return stack frames. All stack pointers must be at least 8-byte aligned. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-07-10sparc/PCI: Fix for panic while enabling SR-IOVBabu Moger
[ Upstream commit d0c31e02005764dae0aab130a57e9794d06b824d ] We noticed this panic while enabling SR-IOV in sparc. mlx4_core: Mellanox ConnectX core driver v2.2-1 (Jan 1 2015) mlx4_core: Initializing 0007:01:00.0 mlx4_core 0007:01:00.0: Enabling SR-IOV with 5 VFs mlx4_core: Initializing 0007:01:00.1 Unable to handle kernel NULL pointer dereference insmod(10010): Oops [#1] CPU: 391 PID: 10010 Comm: insmod Not tainted 4.1.12-32.el6uek.kdump2.sparc64 #1 TPC: <dma_supported+0x20/0x80> I7: <__mlx4_init_one+0x324/0x500 [mlx4_core]> Call Trace: [00000000104c5ea4] __mlx4_init_one+0x324/0x500 [mlx4_core] [00000000104c613c] mlx4_init_one+0xbc/0x120 [mlx4_core] [0000000000725f14] local_pci_probe+0x34/0xa0 [0000000000726028] pci_call_probe+0xa8/0xe0 [0000000000726310] pci_device_probe+0x50/0x80 [000000000079f700] really_probe+0x140/0x420 [000000000079fa24] driver_probe_device+0x44/0xa0 [000000000079fb5c] __device_attach+0x3c/0x60 [000000000079d85c] bus_for_each_drv+0x5c/0xa0 [000000000079f588] device_attach+0x88/0xc0 [000000000071acd0] pci_bus_add_device+0x30/0x80 [0000000000736090] virtfn_add.clone.1+0x210/0x360 [00000000007364a4] sriov_enable+0x2c4/0x520 [000000000073672c] pci_enable_sriov+0x2c/0x40 [00000000104c2d58] mlx4_enable_sriov+0xf8/0x180 [mlx4_core] [00000000104c49ac] mlx4_load_one+0x42c/0xd40 [mlx4_core] Disabling lock debugging due to kernel taint Caller[00000000104c5ea4]: __mlx4_init_one+0x324/0x500 [mlx4_core] Caller[00000000104c613c]: mlx4_init_one+0xbc/0x120 [mlx4_core] Caller[0000000000725f14]: local_pci_probe+0x34/0xa0 Caller[0000000000726028]: pci_call_probe+0xa8/0xe0 Caller[0000000000726310]: pci_device_probe+0x50/0x80 Caller[000000000079f700]: really_probe+0x140/0x420 Caller[000000000079fa24]: driver_probe_device+0x44/0xa0 Caller[000000000079fb5c]: __device_attach+0x3c/0x60 Caller[000000000079d85c]: bus_for_each_drv+0x5c/0xa0 Caller[000000000079f588]: device_attach+0x88/0xc0 Caller[000000000071acd0]: pci_bus_add_device+0x30/0x80 Caller[0000000000736090]: virtfn_add.clone.1+0x210/0x360 Caller[00000000007364a4]: sriov_enable+0x2c4/0x520 Caller[000000000073672c]: pci_enable_sriov+0x2c/0x40 Caller[00000000104c2d58]: mlx4_enable_sriov+0xf8/0x180 [mlx4_core] Caller[00000000104c49ac]: mlx4_load_one+0x42c/0xd40 [mlx4_core] Caller[00000000104c5f90]: __mlx4_init_one+0x410/0x500 [mlx4_core] Caller[00000000104c613c]: mlx4_init_one+0xbc/0x120 [mlx4_core] Caller[0000000000725f14]: local_pci_probe+0x34/0xa0 Caller[0000000000726028]: pci_call_probe+0xa8/0xe0 Caller[0000000000726310]: pci_device_probe+0x50/0x80 Caller[000000000079f700]: really_probe+0x140/0x420 Caller[000000000079fa24]: driver_probe_device+0x44/0xa0 Caller[000000000079fb08]: __driver_attach+0x88/0xa0 Caller[000000000079d90c]: bus_for_each_dev+0x6c/0xa0 Caller[000000000079f29c]: driver_attach+0x1c/0x40 Caller[000000000079e35c]: bus_add_driver+0x17c/0x220 Caller[00000000007a02d4]: driver_register+0x74/0x120 Caller[00000000007263fc]: __pci_register_driver+0x3c/0x60 Caller[00000000104f62bc]: mlx4_init+0x60/0xcc [mlx4_core] Kernel panic - not syncing: Fatal exception Press Stop-A (L1-A) to return to the boot prom ---[ end Kernel panic - not syncing: Fatal exception Details: Here is the call sequence virtfn_add->__mlx4_init_one->dma_set_mask->dma_supported The panic happened at line 760(file arch/sparc/kernel/iommu.c) 758 int dma_supported(struct device *dev, u64 device_mask) 759 { 760 struct iommu *iommu = dev->archdata.iommu; 761 u64 dma_addr_mask = iommu->dma_addr_mask; 762 763 if (device_mask >= (1UL << 32UL)) 764 return 0; 765 766 if ((device_mask & dma_addr_mask) == dma_addr_mask) 767 return 1; 768 769 #ifdef CONFIG_PCI 770 if (dev_is_pci(dev)) 771 return pci64_dma_supported(to_pci_dev(dev), device_mask); 772 #endif 773 774 return 0; 775 } 776 EXPORT_SYMBOL(dma_supported); Same panic happened with Intel ixgbe driver also. SR-IOV code looks for arch specific data while enabling VFs. When VF device is added, driver probe function makes set of calls to initialize the pci device. Because the VF device is added different way than the normal PF device(which happens via of_create_pci_dev for sparc), some of the arch specific initialization does not happen for VF device. That causes panic when archdata is accessed. To fix this, I have used already defined weak function pcibios_setup_device to copy archdata from PF to VF. Also verified the fix. Signed-off-by: Babu Moger <babu.moger@oracle.com> Signed-off-by: Sowmini Varadhan <sowmini.varadhan@oracle.com> Reviewed-by: Ethan Zhao <ethan.zhao@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-07-10sparc64: Fix sparc64_set_context stack handling.David S. Miller
[ Upstream commit 397d1533b6cce0ccb5379542e2e6d079f6936c46 ] Like a signal return, we should use synchronize_user_stack() rather than flush_user_windows(). Reported-by: Ilya Malakhov <ilmalakhovthefirst@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-07-10sparc64: Fix bootup regressions on some Kconfig combinations.David S. Miller
[ Upstream commit 49fa5230462f9f2c4e97c81356473a6bdf06c422 ] The system call tracing bug fix mentioned in the Fixes tag below increased the amount of assembler code in the sequence of assembler files included by head_64.S This caused to total set of code to exceed 0x4000 bytes in size, which overflows the expression in head_64.S that works to place swapper_tsb at address 0x408000. When this is violated, the TSB is not properly aligned, and also the trap table is not aligned properly either. All of this together results in failed boots. So, do two things: 1) Simplify some code by using ba,a instead of ba/nop to get those bytes back. 2) Add a linker script assertion to make sure that if this happens again the build will fail. Fixes: 1a40b95374f6 ("sparc: Fix system call tracing register handling.") Reported-by: Meelis Roos <mroos@linux.ee> Reported-by: Joerg Abraham <joerg.abraham@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-07-10sparc: Fix system call tracing register handling.Mike Frysinger
[ Upstream commit 1a40b95374f680625318ab61d81958e949e0afe3 ] A system call trace trigger on entry allows the tracing process to inspect and potentially change the traced process's registers. Account for that by reloading the %g1 (syscall number) and %i0-%i5 (syscall argument) values. We need to be careful to revalidate the range of %g1, and reload the system call table entry it corresponds to into %l7. Reported-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: David S. Miller <davem@davemloft.net> Tested-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-02-03sparc64: fix incorrect sign extension in sys_sparc64_personalityDmitry V. Levin
[ Upstream commit 525fd5a94e1be0776fa652df5c687697db508c91 ] The value returned by sys_personality has type "long int". It is saved to a variable of type "int", which is not a problem yet because the type of task_struct->pesonality is "unsigned int". The problem is the sign extension from "int" to "long int" that happens on return from sys_sparc64_personality. For example, a userspace call personality((unsigned) -EINVAL) will result to any subsequent personality call, including absolutely harmless read-only personality(0xffffffff) call, failing with errno set to EINVAL. Signed-off-by: Dmitry V. Levin <ldv@altlinux.org> Cc: <stable@vger.kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-05-31sparc: Resolve conflict between sparc v9 and M7 on usage of bit 9 of TTEKhalid Aziz
sparc: Resolve conflict between sparc v9 and M7 on usage of bit 9 of TTE Bit 9 of TTE is CV (Cacheable in V-cache) on sparc v9 processor while the same bit 9 is MCDE (Memory Corruption Detection Enable) on M7 processor. This creates a conflicting usage of the same bit. Kernel sets TTE.cv bit on all pages for sun4v architecture which works well for sparc v9 but enables memory corruption detection on M7 processor which is not the intent. This patch adds code to determine if kernel is running on M7 processor and takes steps to not enable memory corruption detection in TTE erroneously. Signed-off-by: Khalid Aziz <khalid.aziz@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-31sparc64: pci slots information is not populated in sysfsEric Snowberg
Add PCI slot numbers within sysfs for PCIe hardware. Larger PCIe systems with nested PCI bridges and slots further down on these bridges were not being populated within sysfs. This will add ACPI style PCI slot numbers for these systems since the OF 'slot-names' information is not available on all PCIe platforms. Signed-off-by: Eric Snowberg <eric.snowberg@oracle.com> Reviewed-by: Bob Picco <bob.picco@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-31sparc: kernel: GRPCI2: Remove a useless memsetChristophe Jaillet
grpci2priv is allocated using kzalloc, so there is no need to memset it. Signed-off-by: Christophe Jaillet <christophe.jaillet@wanadoo.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-22sparc64: Setup sysfs to mark LDOM sockets, cores and threads correctlychris hyser
commit 5f4826a362405748bbf73957027b77993e61e1af Author: chris hyser <chris.hyser@oracle.com> Date: Tue Apr 21 10:31:38 2015 -0400 sparc64: Setup sysfs to mark LDOM sockets, cores and threads correctly The current sparc kernel has no representation for sockets though tools like lscpu can pull this from sysfs. This patch walks the machine description cache and socket hierarchy and marks sockets as well as cores and threads such that a representative sysfs is created by drivers/base/topology.c. Before this patch: $ lscpu Architecture: sparc64 CPU op-mode(s): 32-bit, 64-bit Byte Order: Big Endian CPU(s): 1024 On-line CPU(s) list: 0-1023 Thread(s) per core: 8 Core(s) per socket: 1 <--- wrong Socket(s): 128 <--- wrong NUMA node(s): 4 NUMA node0 CPU(s): 0-255 NUMA node1 CPU(s): 256-511 NUMA node2 CPU(s): 512-767 NUMA node3 CPU(s): 768-1023 After this patch: $ lscpu Architecture: sparc64 CPU op-mode(s): 32-bit, 64-bit Byte Order: Big Endian CPU(s): 1024 On-line CPU(s) list: 0-1023 Thread(s) per core: 8 Core(s) per socket: 32 Socket(s): 4 NUMA node(s): 4 NUMA node0 CPU(s): 0-255 NUMA node1 CPU(s): 256-511 NUMA node2 CPU(s): 512-767 NUMA node3 CPU(s): 768-1023 Most of this patch was done by Chris with updates by David. Signed-off-by: Chris Hyser <chris.hyser@oracle.com> Signed-off-by: David Ahern <david.ahern@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
Pull sparc fixes from David Miller: 1) ldc_alloc_exp_dring() can be called from softints, so use GFP_ATOMIC. From Sowmini Varadhan. 2) Some minor warning/build fixups for the new iommu-common code on certain archs and with certain debug options enabled. Also from Sowmini Varadhan. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: sparc: Use GFP_ATOMIC in ldc_alloc_exp_dring() as it can be called in softirq context sparc64: Use M7 PMC write on all chips T4 and onward. iommu-common: rename iommu_pool_hash to iommu_hash_common iommu-common: fix x86_64 compiler warnings
2015-04-21sparc: Use GFP_ATOMIC in ldc_alloc_exp_dring() as it can be called in ↵Sowmini Varadhan
softirq context Since it is possible for vnet_event_napi to end up doing vnet_control_pkt_engine -> ... -> vnet_send_attr -> vnet_port_alloc_tx_ring -> ldc_alloc_exp_dring -> kzalloc() (i.e., in softirq context), kzalloc() should be called with GFP_ATOMIC from ldc_alloc_exp_dring. Signed-off-by: Sowmini Varadhan <sowmini.varadhan@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-21sparc64: Use M7 PMC write on all chips T4 and onward.David S. Miller
They both work equally well, and the M7 implementation is simpler and cheaper (less register writes). With help from David Ahern. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-20Merge tag 'cpumask-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull final removal of deprecated cpus_* cpumask functions from Rusty Russell: "This is the final removal (after several years!) of the obsolete cpus_* functions, prompted by their mis-use in staging. With these function removed, all cpu functions should only iterate to nr_cpu_ids, so we finally only allocate that many bits when cpumasks are allocated offstack" * tag 'cpumask-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (25 commits) cpumask: remove __first_cpu / __next_cpu cpumask: resurrect CPU_MASK_CPU0 linux/cpumask.h: add typechecking to cpumask_test_cpu cpumask: only allocate nr_cpumask_bits. Fix weird uses of num_online_cpus(). cpumask: remove deprecated functions. mips: fix obsolete cpumask_of_cpu usage. x86: fix more deprecated cpu function usage. ia64: remove deprecated cpus_ usage. powerpc: fix deprecated CPU_MASK_CPU0 usage. CPU_MASK_ALL/CPU_MASK_NONE: remove from deprecated region. staging/lustre/o2iblnd: Don't use cpus_weight staging/lustre/libcfs: replace deprecated cpus_ calls with cpumask_ staging/lustre/ptlrpc: Do not use deprecated cpus_* functions blackfin: fix up obsolete cpu function usage. parisc: fix up obsolete cpu function usage. tile: fix up obsolete cpu function usage. arm64: fix up obsolete cpu function usage. mips: fix up obsolete cpu function usage. x86: fix up obsolete cpu function usage. ...
2015-04-19cpumask: remove __first_cpu / __next_cpuRusty Russell
They were for use by the deprecated first_cpu() and next_cpu() wrappers, but sparc used them directly. They're now replaced by cpumask_first / cpumask_next. And __next_cpu_nr is completely obsolete. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: David S. Miller <davem@davemloft.net>
2015-04-18sparc: Make LDC use common iommu poll management functionsSowmini Varadhan
Note that this conversion is only being done to consolidate the code and ensure that the common code provides the sufficient abstraction. It is not expected to result in any noticeable performance improvement, as there is typically one ldc_iommu per vnet_port, and each one has 8k entries, with a typical request for 1-4 pages. Thus LDC uses npools == 1. Signed-off-by: Sowmini Varadhan <sowmini.varadhan@oracle.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-18sparc: Make sparc64 use scalable lib/iommu-common.c functionsSowmini Varadhan
In iperf experiments running linux as the Tx side (TCP client) with 10 threads results in a severe performance drop when TSO is disabled, indicating a weakness in the software that can be avoided by using the scalable IOMMU arena DMA allocation. Baseline numbers before this patch: with default settings (TSO enabled) : 9-9.5 Gbps Disable TSO using ethtool- drops badly: 2-3 Gbps. After this patch, iperf client with 10 threads, can give a throughput of at least 8.5 Gbps, even when TSO is disabled. Signed-off-by: Sowmini Varadhan <sowmini.varadhan@oracle.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-18sparc: Revert generic IOMMU allocator.David S. Miller
I applied the wrong version of this patch series, V4 instead of V10, due to a patchwork bundling snafu. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-16sparc: Make LDC use common iommu poll management functionsSowmini Varadhan
Note that this conversion is only being done to consolidate the code and ensure that the common code provides the sufficient abstraction. It is not expected to result in any noticeable performance improvement, as there is typically one ldc_iommu per vnet_port, and each one has 8k entries, with a typical request for 1-4 pages. Thus LDC uses npools == 1. Signed-off-by: Sowmini Varadhan <sowmini.varadhan@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-16sparc: Make sparc64 use scalable lib/iommu-common.c functionsSowmini Varadhan
In iperf experiments running linux as the Tx side (TCP client) with 10 threads results in a severe performance drop when TSO is disabled, indicating a weakness in the software that can be avoided by using the scalable IOMMU arena DMA allocation. Baseline numbers before this patch: with default settings (TSO enabled) : 9-9.5 Gbps Disable TSO using ethtool- drops badly: 2-3 Gbps. After this patch, iperf client with 10 threads, can give a throughput of at least 8.5 Gbps, even when TSO is disabled. Signed-off-by: Sowmini Varadhan <sowmini.varadhan@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-15Merge branch 'exec_domain_rip_v2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc Pull exec domain removal from Richard Weinberger: "This series removes execution domain support from Linux. The idea behind exec domains was to support different ABIs. The feature was never complete nor stable. Let's rip it out and make the kernel signal handling code less complicated" * 'exec_domain_rip_v2' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc: (27 commits) arm64: Removed unused variable sparc: Fix execution domain removal Remove rest of exec domains. arch: Remove exec_domain from remaining archs arc: Remove signal translation and exec_domain xtensa: Remove signal translation and exec_domain xtensa: Autogenerate offsets in struct thread_info x86: Remove signal translation and exec_domain unicore32: Remove signal translation and exec_domain um: Remove signal translation and exec_domain tile: Remove signal translation and exec_domain sparc: Remove signal translation and exec_domain sh: Remove signal translation and exec_domain s390: Remove signal translation and exec_domain mn10300: Remove signal translation and exec_domain microblaze: Remove signal translation and exec_domain m68k: Remove signal translation and exec_domain m32r: Remove signal translation and exec_domain m32r: Autogenerate offsets in struct thread_info frv: Remove signal translation and exec_domain ...
2015-04-14sparc: clarify __GFP_NOFAIL allocationMichal Hocko
Commit 920c3ed74134 ("[SPARC64]: Add basic infrastructure for MD add/remove notification") has added __GFP_NOFAIL for the allocation request but it hasn't mentioned why is this strict requirement really needed. The code was handling an allocation failure and propagated it properly up the callchain so it is not clear why it is needed. Dave has clarified the intention when I tried to remove the flag as not being necessary: : It is a serious failure. : : If we miss an MDESC update due to this allocation failure, the update : is not an event which gets retransmitted so we will lose the updated : machine description forever. : : We really need this allocation to succeed. So add a comment to clarify the nofail flag and get rid of the failure check because __GFP_NOFAIL allocation doesn't fail. Signed-off-by: Michal Hocko <mhocko@suse.cz> Cc: David Rientjes <rientjes@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Dave Chinner <david@fromorbit.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Mel Gorman <mgorman@suse.de> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: "David S. Miller" <davem@davemloft.net> Cc: Vipul Pandya <vipul@chelsio.com> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-13Merge tag 'pci-v4.1-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI changes from Bjorn Helgaas: "Enumeration - Read capability list as dwords, not bytes (Sean O. Stalley) Resource management - Don't check for PNP overlaps with unassigned PCI BARs (Bjorn Helgaas) - Mark invalid BARs as unassigned (Bjorn Helgaas) - Show driver, BAR#, and resource on pci_ioremap_bar() failure (Bjorn Helgaas) - Fail pci_ioremap_bar() on unassigned resources (Bjorn Helgaas) - Assign resources before drivers claim devices (Yijing Wang) - Claim bus resources before pci_bus_add_devices() (Yijing Wang) Power management - Optimize device state transition delays (Aaron Lu) - Don't clear ASPM bits when the FADT declares it's unsupported (Matthew Garrett) Virtualization - Add ACS quirks for Intel 1G NICs (Alex Williamson) IOMMU - Add ptr to OF node arg to of_iommu_configure() (Murali Karicheri) - Move of_dma_configure() to device.c to help re-use (Murali Karicheri) - Fix size when dma-range is not used (Murali Karicheri) - Add helper functions pci_get[put]_host_bridge_device() (Murali Karicheri) - Add of_pci_dma_configure() to update DMA configuration (Murali Karicheri) - Update DMA configuration from DT (Murali Karicheri) - dma-mapping: limit IOMMU mapping size (Murali Karicheri) - Calculate device DMA masks based on DT dma-range size (Murali Karicheri) ARM Versatile host bridge driver - Check for devm_ioremap_resource() failures (Jisheng Zhang) Broadcom iProc host bridge driver - Add Broadcom iProc PCIe driver (Ray Jui) Marvell MVEBU host bridge driver - Add suspend/resume support (Thomas Petazzoni) Renesas R-Car host bridge driver - Fix position of MSI enable bit (Nobuhiro Iwamatsu) - Write zeroes to reserved PCIEPARL bits (Nobuhiro Iwamatsu) - Change PCIEPARL and PCIEPARH to PCIEPALR and PCIEPAUR (Nobuhiro Iwamatsu) - Verify that mem_res is 64K-aligned (Nobuhiro Iwamatsu) Samsung Exynos host bridge driver - Fix INTx enablement statement termination error (Jaehoon Chung) Miscellaneous - Make a shareable UUID for PCI firmware ACPI _DSM (Aaron Lu) - Clarify policy for vendor IDs in pci.txt (Michael S. Tsirkin)" * tag 'pci-v4.1-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (36 commits) PCI: Read capability list as dwords, not bytes PCI: layerscape: Simplify platform_get_resource_byname() failure checking PCI: keystone: Don't dereference possible NULL pointer PCI: versatile: Check for devm_ioremap_resource() failures PCI: Don't clear ASPM bits when the FADT declares it's unsupported PCI: Clarify policy for vendor IDs in pci.txt PCI/ACPI: Optimize device state transition delays PCI: Export pci_find_host_bridge() for use inside PCI core PCI: Make a shareable UUID for PCI firmware ACPI _DSM PCI: Fix typo in Thunderbolt kernel message PCI: exynos: Fix INTx enablement statement termination error PCI: iproc: Add Broadcom iProc PCIe support PCI: iproc: Add DT docs for Broadcom iProc PCIe driver PCI: Export symbols required for loadable host driver modules PCI: Add ACS quirks for Intel 1G NICs PCI: mvebu: Add suspend/resume support PCI: Cleanup control flow sparc/PCI: Claim bus resources before pci_bus_add_devices() PCI: Assign resources before drivers claim devices (pci_scan_root_bus()) PCI: Fail pci_ioremap_bar() on unassigned resources ...
2015-04-13Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer updates from Ingo Molnar: "The main changes in this cycle were: - clockevents state machine cleanups and enhancements (Viresh Kumar) - clockevents broadcast notifier horror to state machine conversion and related cleanups (Thomas Gleixner, Rafael J Wysocki) - clocksource and timekeeping core updates (John Stultz) - clocksource driver updates and fixes (Ben Dooks, Dmitry Osipenko, Hans de Goede, Laurent Pinchart, Maxime Ripard, Xunlei Pang) - y2038 fixes (Xunlei Pang, John Stultz) - NMI-safe ktime_get_raw_fast() and general refactoring of the clock code, in preparation to perf's per event clock ID support (Peter Zijlstra) - generic sched/clock fixes, optimizations and cleanups (Daniel Thompson) - clockevents cpu_down() race fix (Preeti U Murthy)" * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (94 commits) timers/PM: Drop unnecessary braces from tick_freeze() timers/PM: Fix up tick_unfreeze() timekeeping: Get rid of stale comment clockevents: Cleanup dead cpu explicitely clockevents: Make tick handover explicit clockevents: Remove broadcast oneshot control leftovers sched/idle: Use explicit broadcast oneshot control function ARM: Tegra: Use explicit broadcast oneshot control function ARM: OMAP: Use explicit broadcast oneshot control function intel_idle: Use explicit broadcast oneshot control function ACPI/idle: Use explicit broadcast control function ACPI/PAD: Use explicit broadcast oneshot control function x86/amd/idle, clockevents: Use explicit broadcast oneshot control functions clockevents: Provide explicit broadcast oneshot control functions clockevents: Remove the broadcast control leftovers ARM: OMAP: Use explicit broadcast control function intel_idle: Use explicit broadcast control function cpuidle: Use explicit broadcast control function ACPI/processor: Use explicit broadcast control function ACPI/PAD: Use explicit broadcast control function ...
2015-04-12sparc: Remove signal translation and exec_domainRichard Weinberger
As execution domain support is gone we can remove signal translation from the signal code and remove exec_domain from thread_info. Signed-off-by: Richard Weinberger <richard@nod.at> Acked-by: David S. Miller <davem@davemloft.net>
2015-04-09Merge tag 'pci-v4.0-fixes-3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI fixes from Bjorn Helgaas: "Here are some fixes for v4.0. I apologize for how late they are. We were hoping for some better fixes, but couldn't get them polished in time. These fix: - a Xen domU oops with PCI passthrough devices - a sparc T5 boot failure - a STM SPEAr13xx crash (use after initdata freed) - a cpcihp hotplug driver thinko - an AER thinko that printed stack junk Details: Enumeration - Don't look for ACPI hotplug parameters if ACPI is disabled (Bjorn Helgaas) Resource management - Revert "sparc/PCI: Clip bridge windows to fit in upstream windows" (Bjorn Helgaas) AER - Avoid info leak in __print_tlp_header() (Rasmus Villemoes) PCI device hotplug - Add missing curly braces in cpci_configure_slot() (Dan Carpenter) ST Microelectronics SPEAr13xx host bridge driver - Drop __initdata from spear13xx_pcie_driver (Matwey V. Kornilov) * tag 'pci-v4.0-fixes-3' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: Revert "sparc/PCI: Clip bridge windows to fit in upstream windows" PCI: Don't look for ACPI hotplug parameters if ACPI is disabled PCI: cpcihp: Add missing curly braces in cpci_configure_slot() PCI/AER: Avoid info leak in __print_tlp_header() PCI: spear: Drop __initdata from spear13xx_pcie_driver
2015-04-08Revert "sparc/PCI: Clip bridge windows to fit in upstream windows"Bjorn Helgaas
This reverts commit d63e2e1f3df904bf6bd150bdafb42ddbb3257ea8. David Ahern reported that d63e2e1f3df9 breaks booting on an 8-socket T5 sparc system. He also verified that the system boots with d63e2e1f3df9 reverted. Yinghai has some fixes, but they need a little more polishing than we can do before v4.0. Link: http://lkml.kernel.org/r/5514391F.2030300@oracle.com # report Link: http://lkml.kernel.org/r/1427857069-6789-1-git-send-email-yinghai@kernel.org # patches Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> CC: stable@vger.kernel.org # v3.19+
2015-03-31Merge tag 'v4.0-rc6' into timers/core, before applying new patchesIngo Molnar
2015-03-19sparc: Touch NMI watchdog when walking cpus and calling printkDavid Ahern
With the increase in number of CPUs calls to functions that dump output to console (e.g., arch_trigger_all_cpu_backtrace) can take a long time to complete. If IRQs are disabled eventually the NMI watchdog kicks in and creates more havoc. Avoid by telling the NMI watchdog everything is ok. Signed-off-by: David Ahern <david.ahern@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-19sparc: perf: Add support M7 processorDavid Ahern
The M7 processor has a different hypervisor group id and different PCR fast trap values. PIC read/write functions and PCR bit fields are the same as the T4 so those are reused. Signed-off-by: David Ahern <david.ahern@oracle.com> Acked-by: Bob Picco <bob.picco@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-19sparc: perf: Make counting mode actually workDavid Ahern
Currently perf-stat (aka, counting mode) does not work: $ perf stat ls ... Performance counter stats for 'ls': 1.585665 task-clock (msec) # 0.580 CPUs utilized 24 context-switches # 0.015 M/sec 0 cpu-migrations # 0.000 K/sec 86 page-faults # 0.054 M/sec <not supported> cycles <not supported> stalled-cycles-frontend <not supported> stalled-cycles-backend <not supported> instructions <not supported> branches <not supported> branch-misses 0.002735100 seconds time elapsed The reason is that state is never reset (stays with PERF_HES_UPTODATE set). Add a call to sparc_pmu_enable_event during the added_event handling. Clean up the encoding since pmu_start calls sparc_pmu_enable_event which does the same. Passing PERF_EF_RELOAD to sparc_pmu_start means the call to sparc_perf_event_set_period can be removed as well. With this patch: $ perf stat ls ... Performance counter stats for 'ls': 1.552890 task-clock (msec) # 0.552 CPUs utilized 24 context-switches # 0.015 M/sec 0 cpu-migrations # 0.000 K/sec 86 page-faults # 0.055 M/sec 5,748,997 cycles # 3.702 GHz <not supported> stalled-cycles-frontend:HG <not supported> stalled-cycles-backend:HG 1,684,362 instructions:HG # 0.29 insns per cycle 295,133 branches:HG # 190.054 M/sec 28,007 branch-misses:HG # 9.49% of all branches 0.002815665 seconds time elapsed Signed-off-by: David Ahern <david.ahern@oracle.com> Acked-by: Bob Picco <bob.picco@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-19sparc: perf: Remove redundant perf_pmu_{en|dis}able callsDavid Ahern
perf_pmu_disable is called by core perf code before pmu->del and the enable function is called by core perf code afterwards. No need to call again within sparc_pmu_del. Ditto for pmu->add and sparc_pmu_add. Signed-off-by: David Ahern <david.ahern@oracle.com> Acked-by: Bob Picco <bob.picco@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-19PCI: Cleanup control flowBjorn Helgaas
Return errors immediately so the straightline path is the normal, no-error path. No functional change. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2015-03-19sparc/PCI: Claim bus resources before pci_bus_add_devices()Yijing Wang
Pci_claim_bus_resources() should be called before pci_bus_add_devices(), or driver may failed to load, because the resources had not claimed. Signed-off-by: Yijing Wang <wangyijing@huawei.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2015-03-19PCI: Assign resources before drivers claim devices (pci_scan_root_bus())Yijing Wang
Previously, pci_scan_root_bus() created a root PCI bus, enumerated the devices on it, and called pci_bus_add_devices(), which made the devices available for drivers to claim them. Most callers assigned resources to devices after pci_scan_root_bus() returns, which may be after drivers have claimed the devices. This is incorrect; the PCI core should not change device resources while a driver is managing the device. Remove pci_bus_add_devices() from pci_scan_root_bus() and do it after any resource assignment in the callers. Note that ARM's pci_common_init_dev() already called pci_bus_add_devices() after pci_scan_root_bus(), so we only need to remove the first call: pci_common_init_dev pcibios_init_hw pci_scan_root_bus pci_bus_add_devices # first call pci_bus_assign_resources pci_bus_add_devices # second call [bhelgaas: changelog, drop "root_bus" var in alpha common_init_pci(), return failure earlier in mn10300, add "return" in x86 pcibios_scan_root(), return early if xtensa platform_pcibios_fixup() fails] Signed-off-by: Yijing Wang <wangyijing@huawei.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> CC: Richard Henderson <rth@twiddle.net> CC: Ivan Kokshaysky <ink@jurassic.park.msu.ru> CC: Matt Turner <mattst88@gmail.com> CC: David Howells <dhowells@redhat.com> CC: Tony Luck <tony.luck@intel.com> CC: Michal Simek <monstr@monstr.eu> CC: Ralf Baechle <ralf@linux-mips.org> CC: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> CC: Sebastian Ott <sebott@linux.vnet.ibm.com> CC: "David S. Miller" <davem@davemloft.net> CC: Chris Metcalf <cmetcalf@ezchip.com> CC: Chris Zankel <chris@zankel.net> CC: Max Filippov <jcmvbkbc@gmail.com> CC: Thomas Gleixner <tglx@linutronix.de>
2015-03-13clocksource, sparc32: Convert to using clocksource_register_hz()John Stultz
While cleaning up some clocksource code, I noticed the time_32 implementation uses the clocksource_hz2mult() helper, but doesn't use the clocksource_register_hz() method. I don't believe the Sparc clocksource is a default clocksource, so we shouldn't need to self-define the mult/shift pair. So convert the time_32.c implementation to use clocksource_register_hz(). Untested. Signed-off-by: John Stultz <john.stultz@linaro.org> Acked-by: David S. Miller <davem@davemloft.net> Cc: Dave Jones <davej@codemonkey.org.uk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Richard Cochran <richardcochran@gmail.com> Cc: Stephen Boyd <sboyd@codeaurora.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1426133800-29329-11-git-send-email-john.stultz@linaro.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-03-13clocksource: Mostly kill clocksource_register()John Stultz
A long running project has been to clean up remaining uses of clocksource_register(), replacing it with the simpler clocksource_register_khz/hz() functions. However, there are a few cases where we need to self-define our mult/shift values, so switch the function to a more obviously internal __clocksource_register() name, and consolidate much of the internal logic so we don't have duplication. Signed-off-by: John Stultz <john.stultz@linaro.org> Cc: Dave Jones <davej@codemonkey.org.uk> Cc: David S. Miller <davem@davemloft.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Richard Cochran <richardcochran@gmail.com> Cc: Stephen Boyd <sboyd@codeaurora.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1426133800-29329-10-git-send-email-john.stultz@linaro.org [ Minor cleanups. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-03-12PCI: Assign resources before drivers claim devices (pci_scan_bus())Yijing Wang
Previously, pci_scan_bus() created a root PCI bus, enumerated the devices on it, and called pci_bus_add_devices(), which made the devices available for drivers to claim them. Most callers assigned resources to devices after pci_scan_bus() returns, which may be after drivers have claimed the devices. This is incorrect; the PCI core should not change device resources while a driver is managing the device. Remove pci_bus_add_devices() from pci_scan_bus() and do it after any resource assignment in the callers. [bhelgaas: changelog, check for failure in mcf_pci_init()] Signed-off-by: Yijing Wang <wangyijing@huawei.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> CC: "David S. Miller" <davem@davemloft.net> CC: Geert Uytterhoeven <geert@linux-m68k.org> CC: Guan Xuetao <gxt@mprc.pku.edu.cn> CC: Richard Henderson <rth@twiddle.net> CC: Ivan Kokshaysky <ink@jurassic.park.msu.ru> CC: Matt Turner <mattst88@gmail.com>
2015-03-03sparc: semtimedop() unreachable due to comparison errorRob Gardner
A bug was reported that the semtimedop() system call was always failing eith ENOSYS. Since SEMCTL is defined as 3, and SEMTIMEDOP is defined as 4, the comparison "call <= SEMCTL" will always prevent SEMTIMEDOP from getting through to the semaphore ops switch statement. This is corrected by changing the comparison to "call <= SEMTIMEDOP". Orabug: 20633375 Signed-off-by: Rob Gardner <rob.gardner@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-01sparc64: fatal trap should stop all cpusDave Kleikamp
"echo c > /proc/sysrq-trigger" does not result in a system crash. There are two problems. One is that the trap handler ignores the global variable, panic_on_oops. The other is that smp_send_stop() is a no-op which leaves the other cpus running normally when one cpu panics. Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-01arch: sparc: kernel: starfire.c: Remove unused functionRickard Strandqvist
Remove the function starfire_hard_smp_processor_id() that is not used anywhere. This was partially found by using a static code analysis program called cppcheck. Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-01arch: sparc: kernel: traps_64.c: Remove some unused functionsRickard Strandqvist
Removes some functions that are not used anywhere: do_fpdis_tl1() do_iae_tl1() do_dae_tl1() do_cee_tl1() This was partially found by using a static code analysis program called cppcheck. Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-13mm: vmalloc: pass additional vm_flags to __vmalloc_node_range()Andrey Ryabinin
For instrumenting global variables KASan will shadow memory backing memory for modules. So on module loading we will need to allocate memory for shadow and map it at address in shadow that corresponds to the address allocated in module_alloc(). __vmalloc_node_range() could be used for this purpose, except it puts a guard hole after allocated area. Guard hole in shadow memory should be a problem because at some future point we might need to have a shadow memory at address occupied by guard hole. So we could fail to allocate shadow for module_alloc(). Now we have VM_NO_GUARD flag disabling guard page, so we need to pass into __vmalloc_node_range(). Add new parameter 'vm_flags' to __vmalloc_node_range() function. Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Konstantin Serebryany <kcc@google.com> Cc: Dmitry Chernenkov <dmitryc@google.com> Signed-off-by: Andrey Konovalov <adech.fo@gmail.com> Cc: Yuri Gribov <tetra2005@gmail.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Christoph Lameter <cl@linux.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-12all arches, signal: move restart_block to struct task_structAndy Lutomirski
If an attacker can cause a controlled kernel stack overflow, overwriting the restart block is a very juicy exploit target. This is because the restart_block is held in the same memory allocation as the kernel stack. Moving the restart block to struct task_struct prevents this exploit by making the restart_block harder to locate. Note that there are other fields in thread_info that are also easy targets, at least on some architectures. It's also a decent simplification, since the restart code is more or less identical on all architectures. [james.hogan@imgtec.com: metag: align thread_info::supervisor_stack] Signed-off-by: Andy Lutomirski <luto@amacapital.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Kees Cook <keescook@chromium.org> Cc: David Miller <davem@davemloft.net> Acked-by: Richard Weinberger <richard@nod.at> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Steven Miao <realmz6@gmail.com> Cc: Mark Salter <msalter@redhat.com> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michal Simek <monstr@monstr.eu> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Jonas Bonn <jonas@southpole.se> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc) Tested-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc) Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Chen Liqin <liqin.linux@gmail.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Chris Zankel <chris@zankel.net> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-01-16sparc/PCI: Clip bridge windows to fit in upstream windowsYinghai Lu
Every PCI-PCI bridge window should fit inside an upstream bridge window because orphaned address space is unreachable from the primary side of the upstream bridge. If we inherit invalid bridge windows that overlap an upstream window from firmware, clip them to fit and update the bridge accordingly. [bhelgaas: changelog] Link: https://bugzilla.kernel.org/show_bug.cgi?id=85491 Reported-by: Marek Kordik <kordikmarek@gmail.com> Fixes: 5b28541552ef ("PCI: Restrict 64-bit prefetchable bridge windows to 64-bit resources") Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: David S. Miller <davem@davemloft.net> CC: Paul Gortmaker <paul.gortmaker@windriver.com> CC: Yijing Wang <wangyijing@huawei.com> CC: Sam Ravnborg <sam@ravnborg.org> CC: sparclinux@vger.kernel.org
2014-12-14Merge tag 'driver-core-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the set of driver core patches for 3.19-rc1. They are dominated by the removal of the .owner field in platform drivers. They touch a lot of files, but they are "simple" changes, just removing a line in a structure. Other than that, a few minor driver core and debugfs changes. There are some ath9k patches coming in through this tree that have been acked by the wireless maintainers as they relied on the debugfs changes. Everything has been in linux-next for a while" * tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits) Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries" fs: debugfs: add forward declaration for struct device type firmware class: Deletion of an unnecessary check before the function call "vunmap" firmware loader: fix hung task warning dump devcoredump: provide a one-way disable function device: Add dev_<level>_once variants ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries ath: use seq_file api for ath9k debugfs files debugfs: add helper function to create device related seq_file drivers/base: cacheinfo: remove noisy error boot message Revert "core: platform: add warning if driver has no owner" drivers: base: support cpu cache information interface to userspace via sysfs drivers: base: add cpu_device_create to support per-cpu devices topology: replace custom attribute macros with standard DEVICE_ATTR* cpumask: factor out show_cpumap into separate helper function driver core: Fix unbalanced device reference in drivers_probe driver core: fix race with userland in device_add() sysfs/kernfs: make read requests on pre-alloc files use the buffer. sysfs/kernfs: allow attributes to request write buffer be pre-allocated. fs: sysfs: return EGBIG on write if offset is larger than file size ...
2014-12-13Merge branch 'akpm' (second patch-bomb from Andrew)Linus Torvalds
Merge second patchbomb from Andrew Morton: - the rest of MM - misc fs fixes - add execveat() syscall - new ratelimit feature for fault-injection - decompressor updates - ipc/ updates - fallocate feature creep - fsnotify cleanups - a few other misc things * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (99 commits) cgroups: Documentation: fix trivial typos and wrong paragraph numberings parisc: percpu: update comments referring to __get_cpu_var percpu: update local_ops.txt to reflect this_cpu operations percpu: remove __get_cpu_var and __raw_get_cpu_var macros fsnotify: remove destroy_list from fsnotify_mark fsnotify: unify inode and mount marks handling fallocate: create FAN_MODIFY and IN_MODIFY events mm/cma: make kmemleak ignore CMA regions slub: fix cpuset check in get_any_partial slab: fix cpuset check in fallback_alloc shmdt: use i_size_read() instead of ->i_size ipc/shm.c: fix overly aggressive shmdt() when calls span multiple segments ipc/msg: increase MSGMNI, remove scaling ipc/sem.c: increase SEMMSL, SEMMNI, SEMOPM ipc/sem.c: change memory barrier in sem_lock() to smp_rmb() lib/decompress.c: consistency of compress formats for kernel image decompress_bunzip2: off by one in get_next_block() usr/Kconfig: make initrd compression algorithm selection not expert fault-inject: add ratelimit option ratelimit: add initialization macro ...
2014-12-13sparc: hook up execveat system callDavid Drysdale
Signed-off-by: David Drysdale <drysdale@google.com> Acked-by: David S. Miller <davem@davemloft.net> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-11sparc/ldc: create separate ldc_unbind from ldc_freeDwight Engen
Signed-off-by: Dwight Engen <dwight.engen@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
