path: root/arch/sparc/kernel
2012-01-11sparc: Fix handling of orig_i0 wrt. debugging when restarting syscalls.David S. Miller
[ A combination of upstream commits 1d299bc7732c34d85bd43ac1a8745f5a2fed2078 and e88d2468718b0789b4c33da2f7e1cef2a1eee279 ] Although we provide a proper way for a debugger to control whether syscall restart occurs, we run into problems because orig_i0 is not saved and restored properly. Luckily we can solve this problem without having to make debuggers aware of the issue. Across system calls, several registers are considered volatile and can be safely clobbered. Therefore we use the pt_regs save area of one of those registers, %g6, as a place to save and restore orig_i0. Debuggers transparently will do the right thing because they save and restore this register already. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Change-Id: I904bc58192c45c132938a97629578a954f26478d Reviewed-on: http://git-master/r/74212 Reviewed-by: Varun Wadekar <vwadekar@nvidia.com> Tested-by: Varun Wadekar <vwadekar@nvidia.com>
2012-01-11sparc64: Fix masking and shifting in VIS fpcmp emulation.David S. Miller
[ Upstream commit 2e8ecdc008a16b9a6c4b9628bb64d0d1c05f9f92 ] Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Change-Id: Id8e8670b16cd66ceb1ac5c42a0f784a657f069e3 Reviewed-on: http://git-master/r/74211 Reviewed-by: Varun Wadekar <vwadekar@nvidia.com> Tested-by: Varun Wadekar <vwadekar@nvidia.com>
2012-01-11sparc64: Patch sun4v code sequences properly on module load.David S. Miller
[ Upstream commit 0b64120cceb86e93cb1bda0dc055f13016646907 ] Some of the sun4v code patching occurs in inline functions visible to, and usable by, modules. Therefore we have to patch them up during module load. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Change-Id: I52459596488560825f22a9eb4c4afb3c0e2b3428 Reviewed-on: http://git-master/r/74206 Reviewed-by: Varun Wadekar <vwadekar@nvidia.com> Tested-by: Varun Wadekar <vwadekar@nvidia.com>
2012-01-11sparc64: Fix MSIQ HV call ordering in pci_sun4v_msiq_build_irq().David S. Miller
[ Upstream commit 7cc8583372a21d98a23b703ad96cab03180b5030 ] This silently was working for many years and stopped working on Niagara-T3 machines. We need to set the MSIQ to VALID before we can set it's state to IDLE. On Niagara-T3, setting the state to IDLE first was causing HV_EINVAL errors. The hypervisor documentation says, rather ambiguously, that the MSIQ must be "initialized" before one can set the state. I previously understood this to mean merely that a successful setconf() operation has been performed on the MSIQ, which we have done at this point. But it seems to also mean that it has been set VALID too. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Change-Id: I6c1c9cf6f1336fc332d2e1fc0453e2bc16a7089b Reviewed-on: http://git-master/r/74204 Reviewed-by: Varun Wadekar <vwadekar@nvidia.com> Tested-by: Varun Wadekar <vwadekar@nvidia.com>
2011-10-19sparc: Add alignment flag to PCI expansion resourcesKjetil Oftedal
Currently no type of alignment is specified for PCI expansion roms while parsing the openfirmware tree. This causes calls to pci_map_rom() to fail. IORESOURCE_SIZEALIGN is the default alignment used for rom resouces in pci/probe.c, and has been verified to work with various cards on a ultra 10. Signed-off-By: Kjetil Oftedal <oftedal@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-12sparc: Avoid calling sigprocmask()David S. Miller
Use set_current_blocked() instead. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-12sparc: Use set_current_blocked()Matt Fleming
As described in e6fa16ab ("signal: sigprocmask() should do retarget_shared_pending()") the modification of current->blocked is incorrect as we need to check whether the signal we're about to block is pending in the shared queue. Cc: Oleg Nesterov <oleg@redhat.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Matt Fleming <matt.fleming@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-21sparc: Make '-p' boot option meaningful again.David S. Miller
If "-p" is given on the command line, clear the CON_BOOT flag for the initial early boot PROM console. This is necessary to try and see crash messages that occur between the registry of the VT console and the probing of the first framebuffer or serial console. During this time no console messages are emitted because the VT console registry (even if no backend is registered to it) removes the early console if CON_BOOT is set. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-20sparc, exec: remove redundant addr_limit assignmentMathias Krause
The address limit is already set in flush_old_exec() so this assignment of USER_DS is redundant. Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-16sparc64: Future proof Niagara cpu detection.David S. Miller
Recognize T4 and T5 chips. Treating them both as "T2 plus other stuff" should be extremely safe and make sure distributions will work when those chips actually ship to customers. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-29sparc64: Only Panther cheetah+ chips have POPC.David S. Miller
2011-08-29sparc32,sun4d: Change IPI IRQ level to prevent collision between IPI and ↵Kjetil Oftedal
timer interrupt On Sun4d systems running in SMP mode, IRQ 14 is used for timer interrupts and has a specialized interrupt handler. IPI is currently set to use IRQ 14 as well, which causes it to trigger the timer interrupt handler, and not the IPI interrupt handler. The IPI interrupt is therefore changed to IRQ 13, which is the highest normally handled interrupt. This IRQ is also used for SBUS interrupts, however there is nothing in the IPI/SBUS interrupt handlers that indicate that they will not handle sharing the interrupt. (IRQ 13 is indicated as audio interrupt, which is unlikely to be found in a sun4d system) Signed-off-by: Kjetil Oftedal <oftedal@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-29sparc: Remove another reference to nfsservctlStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-26All Arch: remove linkage for sys_nfsservctl system callNeilBrown
The nfsservctl system call is now gone, so we should remove all linkage for it. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-20sparc: Allow handling signals when stack is corrupted.David S. Miller
If we can't push the pending register windows onto the user's stack, we disallow signal delivery even if the signal would be delivered on a valid seperate signal stack. Add a register window save area in the signal frame, and store any unsavable windows there. On sigreturn, if any windows are still queued up in the signal frame, try to push them back onto the stack and if that fails we kill the process immediately. This allows the debug/tst-longjmp_chk2 glibc test case to pass. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-18sparc: fix array bounds error setting up PCIC NMI trapIan Campbell
CC arch/sparc/kernel/pcic.o arch/sparc/kernel/pcic.c: In function 'pcic_probe': arch/sparc/kernel/pcic.c:359:33: error: array subscript is above array bounds [-Werror=array-bounds] arch/sparc/kernel/pcic.c:359:8: error: array subscript is above array bounds [-Werror=array-bounds] arch/sparc/kernel/pcic.c:360:33: error: array subscript is above array bounds [-Werror=array-bounds] arch/sparc/kernel/pcic.c:360:8: error: array subscript is above array bounds [-Werror=array-bounds] arch/sparc/kernel/pcic.c:361:33: error: array subscript is above array bounds [-Werror=array-bounds] arch/sparc/kernel/pcic.c:361:8: error: array subscript is above array bounds [-Werror=array-bounds] cc1: all warnings being treated as errors I'm not particularly familiar with sparc but t_nmi (defined in head_32.S via the TRAP_ENTRY macro) and pcic_nmi_trap_patch (defined in entry.S) both appear to be 4 instructions long and I presume from the usage that instructions are int sized. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: sparclinux@vger.kernel.org Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-11sparc: Don't do hypervisor calls on non-sun4v in DS driver.David S. Miller
Reported-by: Pieter-Paul Giesberts <pieterpg@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: sparc: Size mondo queues more sanely. sparc: Access kernel TSB using physical addressing when possible. sparc: Fix __atomic_add_unless() return value. sparc: use kbuild-generic support for true asm-generic header files sparc: Use popc when possible for ffs/__ffs/ffz. sparc: Set reboot-cmd using reboot data hypervisor call if available. sparc: Add some missing hypervisor API groups. sparc: Use hweight64() in popc emulation. sparc: Use popc if possible for hweight routines. sparc: Minor tweaks to Niagara page copy/clear. sparc: Sanitize cpu feature detection and reporting.
2011-08-05sparc: Size mondo queues more sanely.David S. Miller
There is currently no upper limit on the mondo queue sizes we'll use, which guarentees that we'll eventually his page allocation limits, and thus allocation failures, due to MAX_ORDER. Cap the sizes sanely, current limits are: CPU MONDO 2 * max_possible_cpus DEV MONDO 256 (basically NR_IRQS) RES MONDO 128 NRES MONDO 4 Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-05sparc: Access kernel TSB using physical addressing when possible.David S. Miller
On sun4v this is basically required since we point the hypervisor and the TSB walking hardware at these tables using physical addressing too. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-02sparc: Use popc when possible for ffs/__ffs/ffz.David S. Miller
2011-08-02sparc: Set reboot-cmd using reboot data hypervisor call if available.David S. Miller
2011-08-02sparc: Add some missing hypervisor API groups.David S. Miller
2011-08-02sparc: Use hweight64() in popc emulation.David S. Miller
2011-08-02sparc: Use popc if possible for hweight routines.David S. Miller
Just like powerpc, we code patch at boot time. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-02sparc: Minor tweaks to Niagara page copy/clear.David S. Miller
Don't use floating point on Niagara2, use the traditional plain Niagara code instead. Unroll Niagara loops to 128 bytes for copy, and 256 bytes for clear. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-31Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k: m68k/math-emu: Remove unnecessary code m68k/math-emu: Remove commented out old code m68k: Kill warning in setup_arch() when compiling for Sun3 m68k/atari: Prefix GPIO_{IN,OUT} with CODEC_ sparc: iounmap() and *_free_coherent() - Use lookup_resource() m68k/atari: Reserve some ST-RAM early on for device buffer use m68k/amiga: Chip RAM - Use lookup_resource() resources: Add lookup_resource() sparc: _sparc_find_resource() should check for exact matches m68k/amiga: Chip RAM - Offset resource end by CHIP_PHYSADDR m68k/amiga: Chip RAM - Use resource_size() to fix off-by-one error m68k/amiga: Chip RAM - Change chipavail to an atomic_t m68k/amiga: Chip RAM - Always allocate from the start of memory m68k/amiga: Chip RAM - Convert from printk() to pr_*() m68k/amiga: Chip RAM - Use tabs for indentation
2011-07-30sparc: iounmap() and *_free_coherent() - Use lookup_resource()Geert Uytterhoeven
Replace a custom implementation (which doesn't lock the resource tree) by a call to lookup_resource() Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: David S. Miller <davem@davemloft.net>
2011-07-30sparc: _sparc_find_resource() should check for exact matchesGeert Uytterhoeven
The address that's passed to _sparc_find_resource() should always be the start address of a resource: - iounmap() passes a page-aligned virtual address, while the original address was created by adding the in-page offset to the resource's start address, - sbus_free_coherent() and pci32_free_coherent() should be passed an address obtained from sbus_alloc_coherent() resp. pci32_alloc_coherent(), which is always a resource's start address. Hence replace the range check by a check for an exact match. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: David S. Miller <davem@davemloft.net>
2011-07-29Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: remove printks about disabled bridge windows PCI: fold pci_calc_resource_flags() into decode_bar() PCI: treat mem BAR type "11" (reserved) as 32-bit, not 64-bit, BAR PCI: correct pcie_set_readrq write size PCI: pciehp: change wait time for valid configuration access x86/PCI: Preserve existing pci=bfsort whitelist for Dell systems PCI: ARI is a PCIe v2 feature x86/PCI: quirks: Use pci_dev->revision PCI: Make the struct pci_dev * argument of pci_fixup_irqs const. PCI hotplug: cpqphp: use pci_dev->vendor PCI hotplug: cpqphp: use pci_dev->subsystem_{vendor|device} x86/PCI: config space accessor functions should not ignore the segment argument PCI: Assign values to 'pci_obff_signal_type' enumeration constants x86/PCI: reduce severity of host bridge window conflict warnings PCI: enumerate the PCI device only removed out PCI hieratchy of OS when re-scanning PCI PCI: PCIe AER: add aer_recover_queue x86/PCI: select direct access mode for mmconfig option PCI hotplug: Rename is_ejectable which also exists in dock.c
2011-07-28sparc: Sanitize cpu feature detection and reporting.David S. Miller
Instead of evaluating the cpu features for ELF_HWCAP every exec, calculate it once at boot time. Add AV_SPARC_* capability flag bits, compatible with what Solaris reports to applications. Report these capabilities once in the kernel log, and also via /proc/cpuinfo in a new "cpucaps" entry. If available, fetch the cpu features from the machine description 'hwcap-list' property of the 'cpu' node. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-27sparc: Detect and handle UltraSPARC-T3 cpu types.David S. Miller
The cpu compatible string we look for is "SPARC-T3". As far as memset/memcpy optimizations go, we treat this chip the same as Niagara-T2/T2+. Use cache initializing stores for memset, and use perfetch, FPU block loads, cache initializing stores, and block stores for copies. We use the Niagara-T2 perf support, since T3 is a close relative in this regard. Later we'll add support for the new events T3 can report, plus enable T3's new "sample" mode. For now I haven't added any new ELF hwcap flags. We probably need to add a couple, for example: T2 and T3 both support the population count instruction in hardware. T3 supports VIS3 instructions, including support (finally) for partitioned shift. One can also now move directly between float and integer registers. T3 supports instructions meant to help with Galois Field and other HPC calculations, such as XOR multiply. Also there are "OP and negate" instructions, for example "fnmul" which is multiply-and-negate. T3 recognizes the transactional memory opcodes, however since transactional memory isn't supported: 1) 'commit' behaves as a NOP and 2) 'chkpt' always branches 3) 'rdcps' returns all zeros and 4) 'wrcps' behaves as a NOP. So we'll need about 3 new elf capability flags in the end to represent all of these things. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-27sparc: Don't do expensive hypervisor PCR write unless necessary.David S. Miller
The hypervisor call is only necessary if hypervisor events are being requested. So if we're not tracking hypervisor events, simply do a direct register write. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-27sparc: Add T3 sun4v cpu type and hypervisor group defines.David S. Miller
2011-07-27sparc: Don't leave sparc_pmu_type NULL on sun4v.David S. Miller
Otherwise we'll crash in the sparc perf init code. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-07-24modules: make arch's use default loader hooksJonas Bonn
This patch removes all the module loader hook implementations in the architecture specific code where the functionality is the same as that now provided by the recently added default hooks. Signed-off-by: Jonas Bonn <jonas@southpole.se> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Tested-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-07-22Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (123 commits) perf: Remove the nmi parameter from the oprofile_perf backend x86, perf: Make copy_from_user_nmi() a library function perf: Remove perf_event_attr::type check x86, perf: P4 PMU - Fix typos in comments and style cleanup perf tools: Make test use the preset debugfs path perf tools: Add automated tests for events parsing perf tools: De-opt the parse_events function perf script: Fix display of IP address for non-callchain path perf tools: Fix endian conversion reading event attr from file header perf tools: Add missing 'node' alias to the hw_cache[] array perf probe: Support adding probes on offline kernel modules perf probe: Add probed module in front of function perf probe: Introduce debuginfo to encapsulate dwarf information perf-probe: Move dwarf library routines to dwarf-aux.{c, h} perf probe: Remove redundant dwarf functions perf probe: Move strtailcmp to string.c perf probe: Rename DIE_FIND_CB_FOUND to DIE_FIND_CB_END tracing/kprobe: Update symbol reference when loading module tracing/kprobes: Support module init function probing kprobes: Return -ENOENT if probe point doesn't exist ...
2011-07-22Merge branch 'of-pci' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'of-pci' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: pci/of: Consolidate pci_bus_to_OF_node() pci/of: Consolidate pci_device_to_OF_node() x86/devicetree: Use generic PCI <-> OF matching microblaze/pci: Move the remains of pci_32.c to pci-common.c microblaze/pci: Remove powermac originated cruft pci/of: Match PCI devices to OF nodes dynamically
2011-07-22PCI: Make the struct pci_dev * argument of pci_fixup_irqs const.Ralf Baechle
Aside of the usual motivation for constification, this function has a history of being abused a hook for interrupt and other fixups so I turned this function const ages ago in the MIPS code but it should be done treewide. Due to function pointer passing in varous places a few other functions had to be constified as well. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> To: Anton Vorontsov <avorontsov@mvista.com> To: Chris Metcalf <cmetcalf@tilera.com> To: Colin Cross <ccross@android.com> Acked-by: "David S. Miller" <davem@davemloft.net> To: Eric Miao <eric.y.miao@gmail.com> To: Erik Gilling <konkers@android.com> Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn> To: "H. Peter Anvin" <hpa@zytor.com> To: Imre Kaloz <kaloz@openwrt.org> To: Ingo Molnar <mingo@redhat.com> To: Ivan Kokshaysky <ink@jurassic.park.msu.ru> To: Jesse Barnes <jbarnes@virtuousgeek.org> To: Krzysztof Halasa <khc@pm.waw.pl> To: Lennert Buytenhek <kernel@wantstofly.org> To: Matt Turner <mattst88@gmail.com> To: Nicolas Pitre <nico@fluxnic.net> To: Olof Johansson <olof@lixom.net> Acked-by: Paul Mundt <lethal@linux-sh.org> To: Richard Henderson <rth@twiddle.net> To: Russell King <linux@arm.linux.org.uk> To: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: linux-alpha@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-kernel@vger.kernel.org Cc: linux-mips@linux-mips.org Cc: linux-pci@vger.kernel.org Cc: linux-sh@vger.kernel.org Cc: linux-tegra@vger.kernel.org Cc: sparclinux@vger.kernel.org Cc: x86@kernel.org Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-07-16sparc: sun4m SMP: fix wrong shift instruction in IPI handlerWill Simoneau
This shift instruction appears to be shifting in the wrong direction. Without this change, my SparcStation-20MP hangs just after bringing up the second CPU: Entering SMP Mode... Starting CPU 2 at f02b4e90 Brought up 2 CPUs Total of 2 processors activated (99.52 BogoMIPS). *** stuck *** Signed-off-by: Will Simoneau <simoneau@ele.uri.edu> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-01perf, arch: Add generic NODE cache eventsPeter Zijlstra
Add a NODE level to the generic cache events which is used to measure local vs remote memory accesses. Like all other cache events, an ACCESS is HIT+MISS, if there is no way to distinguish between reads and writes do reads only etc.. The below needs filling out for !x86 (which I filled out with unsupported events). I'm fairly sure ARM can leave it like that since it doesn't strike me as an architecture that even has NUMA support. SH might have something since it does appear to have some NUMA bits. Sparc64, PowerPC and MIPS certainly want a good look there since they clearly are NUMA capable. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: David Miller <davem@davemloft.net> Cc: Anton Blanchard <anton@samba.org> Cc: David Daney <ddaney@caviumnetworks.com> Cc: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Will Deacon <will.deacon@arm.com> Cc: Robert Richter <robert.richter@amd.com> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1303508226.4865.8.camel@laptop Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-01perf: Remove the nmi parameter from the swevent and overflow interfacePeter Zijlstra
The nmi parameter indicated if we could do wakeups from the current context, if not, we would set some state and self-IPI and let the resulting interrupt do the wakeup. For the various event classes: - hardware: nmi=0; PMI is in fact an NMI or we run irq_work_run from the PMI-tail (ARM etc.) - tracepoint: nmi=0; since tracepoint could be from NMI context. - software: nmi=[0,1]; some, like the schedule thing cannot perform wakeups, and hence need 0. As one can see, there is very little nmi=1 usage, and the down-side of not using it is that on some platforms some software events can have a jiffy delay in wakeup (when arch_irq_work_raise isn't implemented). The up-side however is that we can remove the nmi parameter and save a bunch of conditionals in fast paths. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Michael Cree <mcree@orcon.net.nz> Cc: Will Deacon <will.deacon@arm.com> Cc: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> Cc: Anton Blanchard <anton@samba.org> Cc: Eric B Munson <emunson@mgebm.net> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: David S. Miller <davem@davemloft.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jason Wessel <jason.wessel@windriver.com> Cc: Don Zickus <dzickus@redhat.com> Link: http://lkml.kernel.org/n/tip-agjev8eu666tvknpb3iaj0fg@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-06-09sparc32, leon: bugfix in LEON SMP interrupt initDaniel Hellstrom
During converting per-cpu ticker to genirq layer some IRQ initialization code was removed by commit 2cf9530420e446bb61f665d02afeb81070106900 ("sparc32,leon: per-cpu ticker use genirq per-cpu handler"). This patch reintroduces the code at the same place it was removed from. IRQ12 - IRQ14 will crash on LEON SMP without this patch because it will run the SUN4M IRQ trap handler. Reported-by: Jan Andersson <jan@gaisler.com> Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-09sparc32, sun4m: bugfix in SMP IPI traphandlerDaniel Hellstrom
Three new IPIs were introduced by commit ecbc42b70acbc6327adefe9635db93fcf62bf59d ("sparc32, sun4m: Implemented SMP IPIs support for SUN4M machines"), the old handler was already prepared for IPIs but handled only IRQ14 and IRQ13, this patch adds support for the new IPI at IRQ12. The IPI trap handler looks at the mask rather than the pending IRQ/IPI, this bug may have masked the problem above, introduced by the same commit. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-08pci/of: Consolidate pci_device_to_OF_node()Benjamin Herrenschmidt
All archs do more or less the same thing now, move it into a single generic place. I chose pci.h rather than of_pci.h to avoid having to change all call-sites to include the later. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Michal Simek <monstr@monstr.eu> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-06-08pci/of: Match PCI devices to OF nodes dynamicallyBenjamin Herrenschmidt
powerpc has two different ways of matching PCI devices to their corresponding OF node (if any) for historical reasons. The ppc64 one does a scan looking for matching bus/dev/fn, while the ppc32 one does a scan looking only for matching dev/fn on each level in order to be agnostic to busses being renumbered (which Linux does on some platforms). This removes both and instead moves the matching code to the PCI core itself. It's the most logical place to do it: when a pci_dev is created, we know the parent and thus can do a single level scan for the matching device_node (if any). The benefit is that all archs now get the matching for free. There's one hook the arch might want to provide to match a PHB bus to its device node. A default weak implementation is provided that looks for the parent device device node, but it's not entirely reliable on powerpc for various reasons so powerpc provides its own. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Michal Simek <monstr@monstr.eu> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-06-07sparc: Remove unnecessary semicolonsJoe Perches
Semicolons are not necessary after switch/while/for/if braces so remove them. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
