[ Upstream commit 56cd0aefa475079e9613085b14a0f05037518fed ]
The PERF_EVENT_IOC_PERIOD ioctl command can be used to change the
sample period of a running perf_event. Consequently, when calculating
the next event period, the new period will only be considered after the
previous one has overflowed.
This patch changes the calculation of the remaining event ticks so that
they are offset if the period has changed.
See commit 3581fe0ef37c ("ARM: 7556/1: perf: fix updated event period in
response to PERF_EVENT_IOC_PERIOD") for details.
Signed-off-by: Young Xiao <92siuyang@gmail.com>
[ Upstream commit 80caf43549e7e41a695c6d1e11066286538b336f ]
In get_vdev_port_node_info(), 'node_info->vdev_port.name' is allcoated
by kstrdup_const(), and it returns NULL when fails. So
'node_info->vdev_port.name' should be checked.
Signed-off-by: Gen Zhang <blackgod016574@gmail.com>
[ Upstream commit 5b4fc3882a649c9411dd0dcad2ddb78e911d340e ]
Right now if we get a corrupted user stack frame we do a
do_exit(SIGILL) which is not helpful.
If under a debugger, this behavior causes the inferior process to
exit. So the register and other state cannot be examined at the time
of the event.
Instead, conditionally log a rate limited kernel log message and then
force a SIGSEGV.
With bits and ideas borrowed (as usual) from powerpc.
[ Upstream commit 455adb3174d2c8518cef1a61140c211f6ac224d2 ]
Like x86 and arm, call perf_sample_event_took() in perf event
NMI interrupt handler.
[ Upstream commit cfdc3170d214046b9509183fe9b9544dc644d40b ]
It is important to clear the hw->state value for non-stopped events
when they are added into the PMU. Otherwise when the event is
scheduled out, we won't read the counter because HES_UPTODATE is still
set. This breaks 'perf stat' and similar use cases, causing all the
events to show zero.
This worked for multi-pcr because we make explicit sparc_pmu_start()
calls in calculate_multiple_pcrs(). calculate_single_pcr() doesn't do
this because the idea there is to accumulate all of the counter
settings into the single pcr value. So we have to add explicit
hw->state handling there.
Like x86, we use the PERF_HES_ARCH bit to track truly stopped events
so that we don't accidently start them on a reload.
Related to all of this, sparc_pmu_start() is missing a userpage update
so add it.
commit 42a0cc3478584d4d63f68f2f5af021ddbea771fa upstream.
Holding uts_sem as a writer while accessing userspace memory allows a
namespace admin to stall all processes that attempt to take uts_sem.
Instead, move data through stack buffers and don't access userspace memory
while uts_sem is held.
Cc: stable@vger.kernel.org
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Signed-off-by: Jann Horn <jannh@google.com>
[ Upstream commit 6f57ed681ed817a4ec444e83f3aa2ad695d5ef34 ]
Code that was added to force gcc not to inline any function that isn't
explicitly declared as inline uncovered that init_tick_ops() isn't
marked as "__init". It is only called by __init functions and more
importantly it too calls an __init function which would require it to be
__init as well.
Link: http://lkml.kernel.org/r/201806060444.hdHcKOBy%fengguang.wu@intel.com
Reported-by: kbuild test robot <lkp@intel.com>
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
[ Upstream commit 00ad691ab140b54ab9f5de5e74cb994f552e8124 ]
Never directly free @dev after calling device_register(), even
if it returned an error. Always use put_device() to give up the
reference initialized.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull namespace updates from Eric Biederman:
"Life has been busy and I have not gotten half as much done this round
as I would have liked. I delayed it so that a minor conflict
resolution with the mips tree could spend a little time in linux-next
before I sent this pull request.
This includes two long delayed user namespace changes from Kirill
Tkhai. It also includes a very useful change from Serge Hallyn that
allows the security capability attribute to be used inside of user
namespaces. The practical effect of this is people can now untar
tarballs and install rpms in user namespaces. It had been suggested to
generalize this and encode some of the namespace information
information in the xattr name. Upon close inspection that makes the
things that should be hard easy and the things that should be easy
more expensive.
Then there is my bugfix/cleanup for signal injection that removes the
magic encoding of the siginfo union member from the kernel internal
si_code. The mips folks reported the case where I had used FPE_FIXME
me is impossible so I have remove FPE_FIXME from mips, while at the
same time including a return statement in that case to keep gcc from
complaining about unitialized variables.
I almost finished the work to get make copy_siginfo_to_user a trivial
copy to user. The code is available at:
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace.git neuter-copy_siginfo_to_user-v3
But I did not have time/energy to get the code posted and reviewed
before the merge window opened.
I was able to see that the security excuse for just copying fields
that we know are initialized doesn't work in practice there are buggy
initializations that don't initialize the proper fields in siginfo. So
we still sometimes copy unitialized data to userspace"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace:
Introduce v3 namespaced file capabilities
mips/signal: In force_fcr31_sig return in the impossible case
signal: Remove kernel interal si_code magic
fcntl: Don't use ambiguous SIG_POLL si_codes
prctl: Allow local CAP_SYS_ADMIN changing exe_file
security: Use user_namespace::level to avoid redundant iterations in cap_capable()
userns,pidns: Verify the userns for new pid namespaces
signal/testing: Don't look for __SI_FAULT in userspace
signal/mips: Document a conflict with SI_USER with SIGFPE
signal/sparc: Document a conflict with SI_USER with SIGFPE
signal/ia64: Document a conflict with SI_USER with SIGFPE
signal/alpha: Document a conflict with SI_USER for SIGTRAP
Pull sparc updates from David Miller:
1) Use register window state adjustment instructions when available,
from Anthony Yznaga.
2) Add VCC console concentrator driver, from Jag Raman.
3) Add 16GB hugepage support, from Nitin Gupta.
4) Support cpu 'poke' hypercall, from Vijay Kumar.
5) Add M7/M8 optimized memcpy/memset/copy_{to,from}_user, from Babu
Moger.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-next: (33 commits)
sparc64: Handle additional cases of no fault loads
sparc64: speed up etrap/rtrap on NG2 and later processors
sparc64: vcc: make ktermios const
sparc: leon: grpci1: constify of_device_id
sparc: leon: grpci2: constify of_device_id
sparc64: vcc: Check for IS_ERR() instead of NULL
sparc64: Cleanup hugepage table walk functions
sparc64: Add 16GB hugepage support
sparc64: Support huge PUD case in get_user_pages
sparc64: vcc: Add install & cleanup TTY operations
sparc64: vcc: Add break_ctl TTY operation
sparc64: vcc: Add chars_in_buffer TTY operation
sparc64: vcc: Add write & write_room TTY operations
sparc64: vcc: Add hangup TTY operation
sparc64: vcc: Add open & close TTY operations
sparc64: vcc: Enable LDC event processing engine
sparc64: vcc: Add RX & TX timer for delayed LDC operation
sparc64: vcc: Create sysfs attribute group
sparc64: vcc: Enable VCC port probe and removal
sparc64: vcc: TTY driver initialization and cleanup
Load instructions using ASI_PNF or other no-fault ASIs should not
cause a SIGSEGV or SIGBUS.
A garden variety unmapped address follows the TSB miss path, and when
no valid mapping is found in the process page tables, the miss handler
checks to see if the access was via a no-fault ASI. It then fixes up
the target register with a zero, and skips the no-fault load
instruction.
But different paths are taken for data access exceptions and alignment
traps, and these do not respect the no-fault ASI. We add checks in
these paths for the no-fault ASI, and fix up the target register and
TPC just like in the TSB miss case.
Signed-off-by: Rob Gardner <rob.gardner@oracle.com>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
For many sun4v processor types, reading or writing a privileged register
has a latency of 40 to 70 cycles. Use a combination of the low-latency
allclean, otherw, normalw, and nop instructions in etrap and rtrap to
replace 2 rdpr and 5 wrpr instructions and improve etrap/rtrap
performance. allclean, otherw, and normalw are available on NG2 and
later processors.
The average ticks to execute the flush windows trap ("ta 0x3") with and
without this patch on select platforms:
CPU Not patched Patched % Latency Reduction
NG2 1762 1558 -11.58
NG4 3619 3204 -11.47
M7 3015 2624 -12.97
SPARC64-X 829 770 -7.12
Signed-off-by: Anthony Yznaga <anthony.yznaga@oracle.com>
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
- add enhanced Downstream Port Containment support, which prints more
details about Root Port Programmed I/O errors (Dongdong Liu)
- add Layerscape ls1088a and ls2088a support (Hou Zhiqiang)
- add MediaTek MT2712 and MT7622 support (Ryder Lee)
- add MediaTek MT2712 and MT7622 MSI support (Honghui Zhang)
- add Qualcom IPQ8074 support (Varadarajan Narayanan)
- add R-Car r8a7743/5 device tree support (Biju Das)
- add Rockchip per-lane PHY support for better power management (Shawn
Lin)
- fix IRQ mapping for hot-added devices by replacing the
pci_fixup_irqs() boot-time design with a host bridge hook called at
probe-time (Lorenzo Pieralisi, Matthew Minter)
- fix race when enabling two devices that results in upstream bridge
not being enabled correctly (Srinath Mannam)
- fix pciehp power fault infinite loop (Keith Busch)
- fix SHPC bridge MSI hotplug events by enabling bus mastering
(Aleksandr Bezzubikov)
- fix a VFIO issue by correcting PCIe capability sizes (Alex
Williamson)
- fix an INTD issue on Xilinx and possibly other drivers by unifying
INTx IRQ domain support (Paul Burton)
- avoid IOMMU stalls by marking AMD Stoney GPU ATS as broken (Joerg
Roedel)
- allow APM X-Gene device assignment to guests by adding an ACS quirk
(Feng Kan)
- fix driver crashes by disabling Extended Tags on Broadcom HT2100
(Extended Tags support is required for PCIe Receivers but not
Requesters, and we now enable them by default when Requesters support
them) (Sinan Kaya)
- fix MSIs for devices that use phantom RIDs for DMA by assuming MSIs
use the real Requester ID (not a phantom RID) (Robin Murphy)
- prevent assignment of Intel VMD children to guests (which may be
supported eventually, but isn't yet) by not associating an IOMMU with
them (Jon Derrick)
- fix Intel VMD suspend/resume by releasing IRQs on suspend (Scott
Bauer)
- fix a Function-Level Reset issue with Intel 750 NVMe by waiting
longer (up to 60sec instead of 1sec) for device to become ready
(Sinan Kaya)
- fix a Function-Level Reset issue on iProc Stingray by working around
hardware defects in the CRS implementation (Oza Pawandeep)
- fix an issue with Intel NVMe P3700 after an iProc reset by adding a
delay during shutdown (Oza Pawandeep)
- fix a Microsoft Hyper-V lockdep issue by polling instead of blocking
in compose_msi_msg() (Stephen Hemminger)
- fix a wireless LAN driver timeout by clearing DesignWare MSI
interrupt status after it is handled, not before (Faiz Abbas)
- fix DesignWare ATU enable checking (Jisheng Zhang)
- reduce Layerscape dependencies on the bootloader by doing more
initialization in the driver (Hou Zhiqiang)
- improve Intel VMD performance allowing allocation of more IRQ vectors
than present CPUs (Keith Busch)
- improve endpoint framework support for initial DMA mask, different
BAR sizes, configurable page sizes, MSI, test driver, etc (Kishon
Vijay Abraham I, Stan Drozd)
- rework CRS support to add periodic messages while we poll during
enumeration and after Function-Level Reset and prepare for possible
other uses of CRS (Sinan Kaya)
- clean up Root Port AER handling by removing unnecessary code and
moving error handler methods to struct pcie_port_service_driver
(Christoph Hellwig)
- clean up error handling paths in various drivers (Bjorn Andersson,
Fabio Estevam, Gustavo A. R. Silva, Harunobu Kurokawa, Jeffy Chen,
Lorenzo Pieralisi, Sergei Shtylyov)
- clean up SR-IOV resource handling by disabling VF decoding before
updating the corresponding resource structs (Gavin Shan)
- clean up DesignWare-based drivers by unifying quirks to update Class
Code and Interrupt Pin and related handling of write-protected
registers (Hou Zhiqiang)
- clean up by adding empty generic pcibios_align_resource() and
pcibios_fixup_bus() and removing empty arch-specific implementations
(Palmer Dabbelt)
- request exclusive reset control for several drivers to allow cleanup
elsewhere (Philipp Zabel)
- constify various structures (Arvind Yadav, Bhumika Goyal)
- convert from full_name() to %pOF (Rob Herring)
- remove unused variables from iProc, HiSi, Altera, Keystone (Shawn
Lin)
* tag 'pci-v4.14-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (170 commits)
PCI: xgene: Clean up whitespace
PCI: xgene: Define XGENE_PCI_EXP_CAP and use generic PCI_EXP_RTCTL offset
PCI: xgene: Fix platform_get_irq() error handling
PCI: xilinx-nwl: Fix platform_get_irq() error handling
PCI: rockchip: Fix platform_get_irq() error handling
PCI: altera: Fix platform_get_irq() error handling
PCI: spear13xx: Fix platform_get_irq() error handling
PCI: artpec6: Fix platform_get_irq() error handling
PCI: armada8k: Fix platform_get_irq() error handling
PCI: dra7xx: Fix platform_get_irq() error handling
PCI: exynos: Fix platform_get_irq() error handling
PCI: iproc: Clean up whitespace
PCI: iproc: Rename PCI_EXP_CAP to IPROC_PCI_EXP_CAP
PCI: iproc: Add 500ms delay during device shutdown
PCI: Fix typos and whitespace errors
PCI: Remove unused "res" variable from pci_resource_io()
PCI: Correct kernel-doc of pci_vpd_srdt_size(), pci_vpd_srdt_tag()
PCI/AER: Reformat AER register definitions
iommu/vt-d: Prevent VMD child devices from being remapping targets
x86/PCI: Use is_vmd() rather than relying on the domain number
* pci/resource:
microblaze/PCI: Remove pcibios_setup_bus_{self/devices} dead code
ARC: Remove empty kernel/pcibios.c
PCI: Add a generic weak pcibios_align_resource()
PCI: Add a generic weak pcibios_fixup_bus()
of_device_id are not supposed to change at runtime. All functions
working with of_device_id provided by <linux/of.h> work with const
of_device_ids. So mark the const and __initconst.
When building the kernel for Sparc using gcc 7.x, the build fails
with:
arch/sparc/kernel/pcic.c: In function ‘pcibios_fixup_bus’:
arch/sparc/kernel/pcic.c:647:8: error: ‘cmd’ may be used uninitialized in this function [-Werror=maybe-uninitialized]
cmd |= PCI_COMMAND_IO;
The simplified code looks like this:
unsigned int cmd;
pcic_read_config(dev->bus, dev->devfn, PCI_COMMAND, 2, &cmd);
I.e, the code assumes that pcic_read_config() will always initialize
cmd. But it's not the case. Looking at pcic_read_config(), if
bus->number is != 0 or if the size is not one of 1, 2 or 4, *val will
not be initialized.
As a simple fix, we initialize cmd to zero at the beginning of
pcibios_fixup_bus.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
There is no need to log message if ATU hvapi couldn't get register.
Unlike PCI hvapi, ATU hvapi registration failure is not hard error.
Even if ATU hvapi registration fails (on system with ATU or without
ATU) system continues with legacy IOMMU. So only log message when
ATU hvapi successfully get registered.
Signed-off-by: Tushar Dave <tushar.n.dave@oracle.com>
Adds support for 16GB hugepage size. To use this page size
use kernel parameters as:
default_hugepagesz=16G hugepagesz=16G hugepages=10
Testing:
Tested with the stream benchmark which allocates 48G of
arrays backed by 16G hugepages and does RW operation on
them in parallel.
Orabug: 25362942
Cc: Anthony Yznaga <anthony.yznaga@oracle.com>
Reviewed-by: Bob Picco <bob.picco@oracle.com>
Signed-off-by: Nitin Gupta <nitin.m.gupta@oracle.com>
Add RX & TX timers to perform delayed/asynchronous LDC
read and write operations.
Signed-off-by: Jagannathan Raman <jag.raman@oracle.com>
Reviewed-by: Liam Merwick <liam.merwick@oracle.com>
Reviewed-by: Shannon Nelson <shannon.nelson@oracle.com>
Enables VCC port probe and removal to initialize and terminate
VCC ports respectively. When a device/port matching the VCC driver
is added, the probe function is invoked along with a reference
to the device. remove function is called when the device is
removed.
Also add APIs to cache and retrieve VCC ports from a VCC table
Add C macros to print debug messages from VCC module
New algorithm that takes advantage of the M7/M8 block init store
ASI, ie, overlapping pipelines and miss buffer filling.
Full details in code comments.
Signed-off-by: Babu Moger <babu.moger@oracle.com>
It overflows the amount of space available in the initial .text section
of trap handler assembler in some configurations, resulting in build
failures.
Use CPU_POKE hypervisor call to resume idle cpu if supported.
Signed-off-by: Vijay Kumar <vijay.ac.kumar@oracle.com>
Reviewed-by: Anthony Yznaga <anthony.yznaga@oracle.com>
This adds a new hypercall CPU_POKE for quickly waking up an idle CPU.
CPU_POKE should only be sent to valid non-local CPUs.
Testing:
them in parallel.
Orabug: 25362942
Recognize SPARC-M8 cpu type, hardware caps and cpu
distribution map.
Signed-off-by: Allen Pais <allen.pais@oracle.com>
Signed-off-by: David Aldridge <david.j.aldridge@oracle.com>
The pci_fixup_irqs() function allocates IRQs for all PCI devices present in
a system; those PCI devices possibly belong to different PCI bus trees (and
possibly rooted at different host bridges) and may well be enabled (ie
probed and bound to a driver) by the time pci_fixup_irqs() is called when
probing a given host bridge driver.
Furthermore, current kernel code relying on pci_fixup_irqs() to assign
legacy PCI IRQs to devices does not work at all for hotplugged devices in
that the code carrying out the IRQ fixup is called at host bridge driver
probe time, which just cannot take into account devices hotplugged after
the system has booted.
The introduction of map/swizzle function hooks in struct pci_host_bridge
allows us to define per-bridge map/swizzle functions that can be used at
device probe time in PCI core code to allocate IRQs for a given device
(through pci_assign_irq()).
Convert PCI host bridge initialization code to the
pci_scan_root_bus_bridge() API (that allows to pass a struct
pci_host_bridge with initialized map/swizzle pointers) and remove the
pci_fixup_irqs() call from arch code.
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Multiple architectures define this as a trivial function, and I'm adding
another one as part of the RISC-V port. Add a __weak version of
pcibios_align_resource() and delete the now-obselete ones in a handful of
ports.
The only functional change should be that a handful of ports used to export
pcibios_fixup_bus(). Only some architectures export this, so I just
dropped it.
Signed-off-by: Palmer Dabbelt <palmer@dabbelt.com>
Multiple architectures define this as an empty function, and I'm adding
pcibios_fixup_bus() and delete the now-obselete ones in a handful of
ports.
The only functional change should be that microblaze used to export
pcibios_fixup_bus(). None of the other architectures exports this, so I
just dropped it.
struct siginfo is a union and the kernel since 2.4 has been hiding a union
tag in the high 16bits of si_code using the values:
__SI_KILL
__SI_TIMER
__SI_POLL
__SI_FAULT
__SI_CHLD
__SI_RT
__SI_MESGQ
__SI_SYS
While this looks plausible on the surface, in practice this situation has
not worked well.
- Injected positive signals are not copied to user space properly
unless they have these magic high bits set.
- Injected positive signals are not reported properly by signalfd
- These kernel internal values leaked to userspace via ptrace_peek_siginfo
- It was possible to inject these kernel internal values and cause the
the kernel to misbehave.
- Kernel developers got confused and expected these kernel internal values
in userspace in kernel self tests.
- Kernel developers got confused and set si_code to __SI_FAULT which
is SI_USER in userspace which causes userspace to think an ordinary user
sent the signal and that it was not kernel generated.
- The values make it impossible to reorganize the code to transform
siginfo_copy_to_user into a plain copy_to_user. As si_code must
be massaged before being passed to userspace.
So remove these kernel internal si codes and make the kernel code simpler
and more maintainable.
To replace these kernel internal magic si_codes introduce the helper
function siginfo_layout, that takes a signal number and an si_code and
computes which union member of siginfo is being used. Have
siginfo_layout return an enumeration so that gcc will have enough
information to warn if a switch statement does not handle all of union
members.
A couple of architectures have a messed up ABI that defines signal
specific duplications of SI_USER which causes more special cases in
siginfo_layout than I would like. The good news is only problem
architectures pay the cost.
Update all of the code that used the previous magic __SI_ values to
use the new SIL_ values and to call siginfo_layout to get those
values. Escept where not all of the cases are handled remove the
defaults in the switch statements so that if a new case is missed in
the future the lack will show up at compile time.
Modify the code that copies siginfo si_code to userspace to just copy
the value and not cast si_code to a short first. The high bits are no
longer used to hold a magic union member.
Fixup the siginfo header files to stop including the __SI_ values in
their constants and for the headers that were missing it to properly
update the number of si_codes for each signal type.
The fixes to copy_siginfo_from_user32 implementations has the
interesting property that several of them perviously should never have
worked as the __SI_ values they depended up where kernel internal.
With that dependency gone those implementations should work much
better.
The idea of not passing the __SI_ values out to userspace and then
not reinserting them has been tested with criu and criu worked without
changes.
Ref: 2.4.0-test1
Setting si_code to __SI_FAULT results in a userspace seeing
an si_code of 0. This is the same si_code as SI_USER. Posix
and common sense requires that SI_USER not be a signal specific
si_code. As such this use of 0 for the si_code is a pretty
horribly broken ABI.
This was introduced in 2.3.41 so this mess has had a long time for
people to be able to start depending on it.
As this bug has existed for 17 years already I don't know if it is
worth fixing. It is definitely worth documenting what is going
on so that no one decides to copy this bad decision.
Cc: sparclinux@vger.kernel.org
This fixes another cause of random segfaults and bus errors that may
occur while running perf with the callgraph option.
Critical sections beginning with spin_lock_irqsave() raise the interrupt
level to PIL_NORMAL_MAX (14) and intentionally do not block performance
counter interrupts, which arrive at PIL_NMI (15).
But some sections of code are "super critical" with respect to perf
because the perf_callchain_user() path accesses user space and may cause
TLB activity as well as faults as it unwinds the user stack.
One particular critical section occurs in switch_mm:
spin_lock_irqsave(&mm->context.lock, flags);
load_secondary_context(mm);
tsb_context_switch(mm);
spin_unlock_irqrestore(&mm->context.lock, flags);
If a perf interrupt arrives in between load_secondary_context() and
tsb_context_switch(), then perf_callchain_user() could execute with
the context ID of one process, but with an active TSB for a different
process. When the user stack is accessed, it is very likely to
incur a TLB miss, since the h/w context ID has been changed. The TLB
will then be reloaded with a translation from the TSB for one process,
but using a context ID for another process. This exposes memory from
one process to another, and since it is a mapping for stack memory,
this usually causes the new process to crash quickly.
This super critical section needs more protection than is provided
by spin_lock_irqsave() since perf interrupts must not be allowed in.
Since __tsb_context_switch already goes through the trouble of
disabling interrupts completely, we fix this by moving the secondary
context load down into this better protected region.
Orabug: 25577560
Signed-off-by: Dave Aldridge <david.j.aldridge@oracle.com>
Pull sparc fixes from David Miller:
- Fix DMA regression in 4.13 merge window, only certain chips can do
64-bit DMA. From Dave Dushar.
- Correct cpu cross-call algorithm to correctly detect stalled or stuck
remote cpus, from Jane Chu.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc:
sparc64: Measure receiver forward progress to avoid send mondo timeout
SPARC64: Fix sun4v DMA panic
A large sun4v SPARC system may have moments of intensive xcall activities,
usually caused by unmapping many pages on many CPUs concurrently. This can
flood receivers with CPU mondo interrupts for an extended period, causing
some unlucky senders to hit send-mondo timeout. This problem gets worse
as cpu count increases because sometimes mappings must be invalidated on
all CPUs, and sometimes all CPUs may gang up on a single CPU.
But a busy system is not a broken system. In the above scenario, as long
as the receiver is making forward progress processing mondo interrupts,
the sender should continue to retry.
This patch implements the receiver's forward progress meter by introducing
a per cpu counter 'cpu_mondo_counter[cpu]' where 'cpu' is in the range
of 0..NR_CPUS. The receiver increments its counter as soon as it receives
a mondo and the sender tracks the receiver's counter. If the receiver has
stopped making forward progress when the retry limit is reached, the sender
declares send-mondo-timeout and panic; otherwise, the receiver is allowed
to keep making forward progress.
In addition, it's been observed that PCIe hotplug events generate Correctable
Errors that are handled by hypervisor and then OS. Hypervisor 'borrows'
a guest cpu strand briefly to provide the service. If the cpu strand is
simultaneously the only cpu targeted by a mondo, it may not be available
for the mondo in 20msec, causing SUN4V mondo timeout. It appears that 1 second
is the agreed wait time between hypervisor and guest OS, this patch makes
the adjustment.
Orabug: 25476541
Orabug: 26417466
Signed-off-by: Jane Chu <jane.chu@oracle.com>
Reviewed-by: Steve Sistare <steven.sistare@oracle.com>
Reviewed-by: Rob Gardner <rob.gardner@oracle.com>
Reviewed-by: Thomas Tai <thomas.tai@oracle.com>
semantic
__GFP_REPEAT was designed to allow retry-but-eventually-fail semantic to
the page allocator. This has been true but only for allocations
requests larger than PAGE_ALLOC_COSTLY_ORDER. It has been always
ignored for smaller sizes. This is a bit unfortunate because there is
no way to express the same semantic for those requests and they are
considered too important to fail so they might end up looping in the
page allocator for ever, similarly to GFP_NOFAIL requests.
Now that the whole tree has been cleaned up and accidental or misled
usage of __GFP_REPEAT flag has been removed for !costly requests we can
give the original flag a better name and more importantly a more useful
semantic. Let's rename it to __GFP_RETRY_MAYFAIL which tells the user
that the allocator would try really hard but there is no promise of a
success. This will work independent of the order and overrides the
default allocator behavior. Page allocator users have several levels of
guarantee vs. cost options (take GFP_KERNEL as an example)
- GFP_KERNEL & ~__GFP_RECLAIM - optimistic allocation without _any_
attempt to free memory at all. The most light weight mode which even
doesn't kick the background reclaim. Should be used carefully because
it might deplete the memory and the next user might hit the more
aggressive reclaim
- GFP_KERNEL & ~__GFP_DIRECT_RECLAIM (or GFP_NOWAIT)- optimistic
allocation without any attempt to free memory from the current
context but can wake kswapd to reclaim memory if the zone is below
the low watermark. Can be used from either atomic contexts or when
the request is a performance optimization and there is another
fallback for a slow path.
- (GFP_KERNEL|__GFP_HIGH) & ~__GFP_DIRECT_RECLAIM (aka GFP_ATOMIC) -
non sleeping allocation with an expensive fallback so it can access
some portion of memory reserves. Usually used from interrupt/bh
context with an expensive slow path fallback.
- GFP_KERNEL - both background and direct reclaim are allowed and the
_default_ page allocator behavior is used. That means that !costly
allocation requests are basically nofail but there is no guarantee of
that behavior so failures have to be checked properly by callers
(e.g. OOM killer victim is allowed to fail currently).
- GFP_KERNEL | __GFP_NORETRY - overrides the default allocator behavior
and all allocation requests fail early rather than cause disruptive
reclaim (one round of reclaim in this implementation). The OOM killer
is not invoked.
- GFP_KERNEL | __GFP_RETRY_MAYFAIL - overrides the default allocator
behavior and all allocation requests try really hard. The request
will fail if the reclaim cannot make any progress. The OOM killer
won't be triggered.
- GFP_KERNEL | __GFP_NOFAIL - overrides the default allocator behavior
and all allocation requests will loop endlessly until they succeed.
This might be really dangerous especially for larger orders.
Existing users of __GFP_REPEAT are changed to __GFP_RETRY_MAYFAIL
because they already had their semantic. No new users are added.
__alloc_pages_slowpath is changed to bail out for __GFP_RETRY_MAYFAIL if
there is no progress and we have already passed the OOM point.
This means that all the reclaim opportunities have been exhausted except
the most disruptive one (the OOM killer) and a user defined fallback
behavior is more sensible than keep retrying in the page allocator.
[akpm@linux-foundation.org: fix arch/sparc/kernel/mdesc.c]
[mhocko@suse.com: semantic fix]
Link: http://lkml.kernel.org/r/20170626123847.GM11534@dhcp22.suse.cz
[mhocko@kernel.org: address other thing spotted by Vlastimil]
Link: http://lkml.kernel.org/r/20170626124233.GN11534@dhcp22.suse.cz
Link: http://lkml.kernel.org/r/20170623085345.11304-3-mhocko@kernel.org
Signed-off-by: Michal Hocko <mhocko@suse.com>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Alex Belits <alex.belits@cavium.com>
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Darrick J. Wong <darrick.wong@oracle.com>
Cc: David Daney <david.daney@cavium.com>
Cc: NeilBrown <neilb@suse.com>
For architectures that define HAVE_NMI_WATCHDOG, instead of having them
provide the complete touch_nmi_watchdog() function, just have them
provide arch_touch_nmi_watchdog().
This gives the generic code more flexibility in implementing this
function, and arch implementations don't miss out on touching the
softlockup watchdog or other generic details.
Link: http://lkml.kernel.org/r/20170616065715.18390-3-npiggin@gmail.com
Signed-off-by: Nicholas Piggin <npiggin@gmail.com>
Reviewed-by: Don Zickus <dzickus@redhat.com>
Reviewed-by: Babu Moger <babu.moger@oracle.com>
Tested-by: Babu Moger <babu.moger@oracle.com> [sparc]
Cc: Michael Ellerman <mpe@ellerman.id.au>
64bit DMA only supported on sun4v equipped with ATU IOMMU HW.
'Commit b02c2b0bfd7ae ("sparc: remove arch specific dma_supported
implementations")' introduced a code that incorrectly allow
dma_supported() to succeed for 64bit dma mask even if system doesn't
have ATU IOMMU. This results into panic.
Fix it.
Reported-by: Meelis Roos <mroos@linux.ee>
1) Queued spinlocks and rwlocks for sparc64, from Babu Moger.
2) Some const'ification from Arvind Yadav.
3) LDC/VIO driver infrastructure changes to facilitate future upcoming
drivers, from Jag Raman.
4) Initialize sched_clock() et al. early so that the initial printk
timestamps are all done while the implementation is available and
functioning. From Pavel Tatashin.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-next: (38 commits)
sparc: kernel: pmc: make of_device_ids const.
sparc64: fix typo in property
sparc64: add port_id to VIO device metadata
sparc64: Enhance search for VIO device in MDESC
sparc64: enhance VIO device probing
sparc64: check if a client is allowed to register for MDESC notifications
sparc64: remove restriction on VIO device name size
sparc64: refactor code to obtain cfg_handle property from MDESC
sparc64: add MDESC node name property to VIO device metadata
sparc64: mdesc: use __GFP_REPEAT action modifier for VM allocation
sparc64: expand MDESC interface
sparc64: skip handshake for LDC channels in RAW mode
sparc64: specify the device class in VIO version info. packet
sparc64: ensure VIO operations are defined while being used
sparc: kernel: apc: make of_device_ids const
sparc/time: make of_device_ids const
sparc64: broken %tick frequency on spitfire cpus
sparc64: use prom interface to get %stick frequency
sparc64: optimize functions that access tick
sparc64: add hot-patched and inlined get_tick()
Pull dma-mapping infrastructure from Christoph Hellwig:
"This is the first pull request for the new dma-mapping subsystem
In this new subsystem we'll try to properly maintain all the generic
code related to dma-mapping, and will further consolidate arch code
into common helpers.
This pull request contains:
- removal of the DMA_ERROR_CODE macro, replacing it with calls to
->mapping_error so that the dma_map_ops instances are more self
contained and can be shared across architectures (me)
- removal of the ->set_dma_mask method, which duplicates the
->dma_capable one in terms of functionality, but requires more
duplicate code.
- various updates for the coherent dma pool and related arm code
(Vladimir)
- various smaller cleanups (me)"
* tag 'dma-mapping-4.13' of git://git.infradead.org/users/hch/dma-mapping: (56 commits)
ARM: dma-mapping: Remove traces of NOMMU code
ARM: NOMMU: Set ARM_DMA_MEM_BUFFERABLE for M-class cpus
ARM: NOMMU: Introduce dma operations for noMMU
drivers: dma-mapping: allow dma_common_mmap() for NOMMU
drivers: dma-coherent: Introduce default DMA pool
drivers: dma-coherent: Account dma_pfn_offset when used with device tree
dma: Take into account dma_pfn_offset
dma-mapping: replace dmam_alloc_noncoherent with dmam_alloc_attrs
dma-mapping: remove dmam_free_noncoherent
crypto: qat - avoid an uninitialized variable warning
au1100fb: remove a bogus dma_free_nonconsistent call
MAINTAINERS: add entry for dma mapping helpers
powerpc: merge __dma_set_mask into dma_set_mask
dma-mapping: remove the set_dma_mask method
powerpc/cell: use the dma_supported method for ops switching
powerpc/cell: clean up fixed mapping dma_ops initialization
tile: remove dma_supported and mapping_error methods
xen-swiotlb: remove xen_swiotlb_set_dma_mask
arm: implement ->dma_supported instead of ->set_dma_mask
mips/loongson64: implement ->dma_supported instead of ->set_dma_mask
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core updates from Greg KH:
"Here is the big driver core update for 4.13-rc1.
The large majority of this is a lot of cleanup of old fields in the
driver core structures and their remaining usages in random drivers.
All of those fixes have been reviewed by the various subsystem
maintainers. There's also some small firmware updates in here, a new
kobject uevent api interface that makes userspace interaction easier,
and a few other minor things.
All of these have been in linux-next for a long while with no reported
issues"
* tag 'driver-core-4.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (56 commits)
arm: mach-rpc: ecard: fix build error
zram: convert remaining CLASS_ATTR() to CLASS_ATTR_RO()
driver-core: remove struct bus_type.dev_attrs
powerpc: vio_cmo: use dev_groups and not dev_attrs for bus_type
powerpc: vio: use dev_groups and not dev_attrs for bus_type
USB: usbip: convert to use DRIVER_ATTR_RW
s390: drivers: convert to use DRIVER_ATTR_RO/WO
platform: thinkpad_acpi: convert to use DRIVER_ATTR_RO/RW
pcmcia: ds: convert to use DRIVER_ATTR_RO
wireless: ipw2x00: convert to use DRIVER_ATTR_RW
net: ehea: convert to use DRIVER_ATTR_RO
net: caif: convert to use DRIVER_ATTR_RO
TTY: hvc: convert to use DRIVER_ATTR_RW
PCI: pci-driver: convert to use DRIVER_ATTR_WO
IB: nes: convert to use DRIVER_ATTR_RW
HID: hid-core: convert to use DRIVER_ATTR_RO and drv_groups
arm: ecard: fix dev_groups patch typo
tty: serdev: use dev_groups and not dev_attrs for bus_type
sparc: vio: use dev_groups and not dev_attrs for bus_type
hid: intel-ish-hid: use dev_groups and not dev_attrs for bus_type
Pull SMP hotplug updates from Thomas Gleixner:
"This update is primarily a cleanup of the CPU hotplug locking code.
The hotplug locking mechanism is an open coded RWSEM, which allows
recursive locking. The main problem with that is the recursive nature
as it evades the full lockdep coverage and hides potential deadlocks.
The rework replaces the open coded RWSEM with a percpu RWSEM and
establishes full lockdep coverage that way.
The bulk of the changes fix up recursive locking issues and address
the now fully reported potential deadlocks all over the place. Some of
these deadlocks have been observed in the RT tree, but on mainline the
probability was low enough to hide them away."
* 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (37 commits)
cpu/hotplug: Constify attribute_group structures
powerpc: Only obtain cpu_hotplug_lock if called by rtasd
ARM/hw_breakpoint: Fix possible recursive locking for arch_hw_breakpoint_init
cpu/hotplug: Remove unused check_for_tasks() function
perf/core: Don't release cred_guard_mutex if not taken
cpuhotplug: Link lock stacks for hotplug callbacks
acpi/processor: Prevent cpu hotplug deadlock
sched: Provide is_percpu_thread() helper
cpu/hotplug: Convert hotplug locking to percpu rwsem
s390: Prevent hotplug rwsem recursion
arm: Prevent hotplug rwsem recursion
arm64: Prevent cpu hotplug rwsem recursion
kprobes: Cure hotplug lock ordering issues
jump_label: Reorder hotplug lock and jump_label_lock
perf/tracing/cpuhotplug: Fix locking order
ACPI/processor: Use cpu_hotplug_disable() instead of get_online_cpus()
PCI: Replace the racy recursion prevention
PCI: Use cpu_hotplug_disable() instead of get_online_cpus()
perf/x86/intel: Drop get_online_cpus() in intel_snb_check_microcode()
x86/perf: Drop EXPORT of perf_check_microcode
of_device_ids are not supposed to change at runtime. All functions
working with of_device_ids provided by <linux/of.h> work with const
of_device_ids. So mark the non-const structs as const.
The only user of thread_saved_pc() in non-arch-specific code was removed
in commit 8243d5597793 ("sched/core: Remove pointless printout in
sched_show_task()"). Remove the implementations as well.
Some architectures use thread_saved_pc() in their arch-specific code.
Leave their thread_saved_pc() intact.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Usually dma_supported decisions are done by the dma_map_ops instance.
Switch sparc to that model by providing a ->dma_supported instance for
sbus that always returns false, and implementations tailored to the sun4u
and sun4v cases for sparc64, and leave it unimplemented for PCI on
sparc32, which means always supported.
We can just use pci32_dma_ops directly.
