path: root/arch/sparc/kernel
2006-02-12[SPARC]: sys_newfstatat --> sys_fstatat64David S. Miller
2006-02-07Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
2006-02-07[SPARC]: Wire up sys_unshare().David S. Miller
Also, the Solaris syscall table is sized differrently, and does not go beyond entry 255, so trim off the excess entries. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-07[PATCH] restore power-off on sparc32Al Viro
Damn you, Eric Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-01-22[SPARC]: Increase NR_SYSCALLS to 299David S. Miller
To let new syscalls through. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-19[SPARC]: Add support for *at(), ppoll, and pselect syscalls.David S. Miller
This also includes by necessity _TIF_RESTORE_SIGMASK support, which actually resulted in a lot of cleanups. The sparc signal handling code is quite a mess and I should clean it up some day. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-12[PATCH] sparc: task_stack_page()Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] sparc: task_thread_info()Al Viro
2006-01-11[PATCH] capable/capability.h (arch/)Randy Dunlap
arch: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] dump_thread() cleanupakpm@osdl.org
) From: Adrian Bunk <bunk@stusta.de> - create one common dump_thread() prototype in kernel.h - dump_thread() is only used in fs/binfmt_aout.c and can therefore be removed on all architectures where CONFIG_BINFMT_AOUT is not available Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] use ptrace_get_task_struct in various placesChristoph Hellwig
The ptrace_get_task_struct() helper that I added as part of the ptrace consolidation is useful in variety of places that currently opencode it. Switch them to the common helpers. Add a ptrace_traceme() helper that needs to be explicitly called, and simplify the ptrace_get_task_struct() interface. We don't need the request argument now, and we return the task_struct directly, using ERR_PTR() for error returns. It's a bit more code in the callers, but we have two sane routines that do one thing well now. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-28[SPARC]: Use STABS_DEBUG and DWARF_DEBUG macros in vmlinux.lds.SDavid S. Miller
2005-12-22[SPARC]: Kill CHILD_MAX.David S. Miller
It's definition is wrong (-1 means "no limit" not 999), only the Sparc SunOS/Solaris compat code uses it, so let's just kill it off completely from limits.h and all referencing code. Noticed by Ulrich Drepper. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-12-15[PATCH] arch/sparc/kernel/led.c __user annotationsAl Viro
2005-12-15[PATCH] sparc: NULL noise removal (ebus.c)Al Viro
2005-12-15[PATCH] sparc/kernel/time: __iomem annotationsAl Viro
2005-12-15[PATCH] fix iomem annotations in sparc32 pcic codeAl Viro
2005-11-22[PATCH] unpaged: fix sound Bad page statesHugh Dickins
Earlier I unifdefed PageCompound, so that snd_pcm_mmap_control_nopage and others can give out a 0-order component of a higher-order page, which won't be mistakenly freed when zap_pte_range unmaps it. But many Bad page states reported a PG_reserved was freed after all: I had missed that we need to say __GFP_COMP to get compound page behaviour. Some of these higher-order pages are allocated by snd_malloc_pages, some by snd_malloc_dev_pages; or if SBUS, by sbus_alloc_consistent - but that has no gfp arg, so add __GFP_COMP into its sparc32/64 implementations. I'm still rather puzzled that DRM seems not to need a similar change. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[SPARC]: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove a duplicate of ARRAY_SIZE which is never used anyways. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-09[PATCH] sched: resched and cpu_idle reworkNick Piggin
Make some changes to the NEED_RESCHED and POLLING_NRFLAG to reduce confusion, and make their semantics rigid. Improves efficiency of resched_task and some cpu_idle routines. * In resched_task: - TIF_NEED_RESCHED is only cleared with the task's runqueue lock held, and as we hold it during resched_task, then there is no need for an atomic test and set there. The only other time this should be set is when the task's quantum expires, in the timer interrupt - this is protected against because the rq lock is irq-safe. - If TIF_NEED_RESCHED is set, then we don't need to do anything. It won't get unset until the task get's schedule()d off. - If we are running on the same CPU as the task we resched, then set TIF_NEED_RESCHED and no further action is required. - If we are running on another CPU, and TIF_POLLING_NRFLAG is *not* set after TIF_NEED_RESCHED has been set, then we need to send an IPI. Using these rules, we are able to remove the test and set operation in resched_task, and make clear the previously vague semantics of POLLING_NRFLAG. * In idle routines: - Enter cpu_idle with preempt disabled. When the need_resched() condition becomes true, explicitly call schedule(). This makes things a bit clearer (IMO), but haven't updated all architectures yet. - Many do a test and clear of TIF_NEED_RESCHED for some reason. According to the resched_task rules, this isn't needed (and actually breaks the assumption that TIF_NEED_RESCHED is only cleared with the runqueue lock held). So remove that. Generally one less locked memory op when switching to the idle thread. - Many idle routines clear TIF_POLLING_NRFLAG, and only set it in the inner most polling idle loops. The above resched_task semantics allow it to be set until before the last time need_resched() is checked before going into a halt requiring interrupt wakeup. Many idle routines simply never enter such a halt, and so POLLING_NRFLAG can be always left set, completely eliminating resched IPIs when rescheduling the idle task. POLLING_NRFLAG width can be increased, to reduce the chance of resched IPIs. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Con Kolivas <kernel@kolivas.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] sched: disable preempt in idle tasksNick Piggin
Run idle threads with preempt disabled. Also corrected a bugs in arm26's cpu_idle (make it actually call schedule()). How did it ever work before? Might fix the CPU hotplugging hang which Nigel Cunningham noted. We think the bug hits if the idle thread is preempted after checking need_resched() and before going to sleep, then the CPU offlined. After calling stop_machine_run, the CPU eventually returns from preemption and into the idle thread and goes to sleep. The CPU will continue executing previous idle and have no chance to call play_dead. By disabling preemption until we are ready to explicitly schedule, this bug is fixed and the idle threads generally become more robust. From: alexs <ashepard@u.washington.edu> PPC build fix From: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> MIPS build fix Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[SPARC]: Kill remaining kbio.h references.Christoph Hellwig
Would you mind applying the following patch that kills those two + the m68k and Documentation/ references? Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-07[SPARC]: Add sun4m LED driver.Lars Kotthoff
This is a forward port of a 2.4.x sun4m LED driver written by Lars Kotthoff. Signed-off-by: Lars Kotthoff <metalhead@metalhead.ws> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-30[PATCH] jiffies_64 cleanupThomas Gleixner
Define jiffies_64 in kernel/timer.c rather than having 24 duplicated defines in each architecture. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] remove some more check_region stuffJeff Garzik
Removed some more references to check_region(). I checked these changes into the 'checkreg' branch of rsync://rsync.kernel.org/pub/scm/linux/kernel/git/jgarzik/misc-2.6.git The only valid references remaining are in: drivers/scsi/advansys.c drivers/scsi/BusLogic.c drivers/cdrom/sbpcd.c sound/oss/pss.c Remove last vestiges of ide_check_region() drivers/char/specialix: trim trailing whitespace drivers/char/specialix: eliminate use of check_region() Remove outdated and unused references to check_region() [sound oss] remove check_region() usage from cs4232, wavfront [netdrvr eepro] trim trailing whitespace [netdrvr eepro] remove check_region() usage Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-03[SPARC]: "extern inline" doesn't make much sense.Adrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-28[SPARC]: Declare paging_init() in asm/pgtable.hDavid S. Miller
2005-09-11[SPARC]: Fix dot-symbol exporting for good.Al Viro
From: Al Viro <viro@ZenIV.linux.org.uk> Instead of playing all of these hand-coded assembler aliasing games, just translate symbol names in the name space ".sym" to "_Sym" at module load time. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-10[PATCH] spinlock consolidationIngo Molnar
This patch (written by me and also containing many suggestions of Arjan van de Ven) does a major cleanup of the spinlock code. It does the following things: - consolidates and enhances the spinlock/rwlock debugging code - simplifies the asm/spinlock.h files - encapsulates the raw spinlock type and moves generic spinlock features (such as ->break_lock) into the generic code. - cleans up the spinlock code hierarchy to get rid of the spaghetti. Most notably there's now only a single variant of the debugging code, located in lib/spinlock_debug.c. (previously we had one SMP debugging variant per architecture, plus a separate generic one for UP builds) Also, i've enhanced the rwlock debugging facility, it will now track write-owners. There is new spinlock-owner/CPU-tracking on SMP builds too. All locks have lockup detection now, which will work for both soft and hard spin/rwlock lockups. The arch-level include files now only contain the minimally necessary subset of the spinlock code - all the rest that can be generalized now lives in the generic headers: include/asm-i386/spinlock_types.h | 16 include/asm-x86_64/spinlock_types.h | 16 I have also split up the various spinlock variants into separate files, making it easier to see which does what. The new layout is: SMP | UP ----------------------------|----------------------------------- asm/spinlock_types_smp.h | linux/spinlock_types_up.h linux/spinlock_types.h | linux/spinlock_types.h asm/spinlock_smp.h | linux/spinlock_up.h linux/spinlock_api_smp.h | linux/spinlock_api_up.h linux/spinlock.h | linux/spinlock.h /* * here's the role of the various spinlock/rwlock related include files: * * on SMP builds: * * asm/spinlock_types.h: contains the raw_spinlock_t/raw_rwlock_t and the * initializers * * linux/spinlock_types.h: * defines the generic type and initializers * * asm/spinlock.h: contains the __raw_spin_*()/etc. lowlevel * implementations, mostly inline assembly code * * (also included on UP-debug builds:) * * linux/spinlock_api_smp.h: * contains the prototypes for the _spin_*() APIs. * * linux/spinlock.h: builds the final spin_*() APIs. * * on UP builds: * * linux/spinlock_type_up.h: * contains the generic, simplified UP spinlock type. * (which is an empty structure on non-debug builds) * * linux/spinlock_types.h: * defines the generic type and initializers * * linux/spinlock_up.h: * contains the __raw_spin_*()/etc. version of UP * builds. (which are NOPs on non-debug, non-preempt * builds) * * (included on UP-non-debug builds:) * * linux/spinlock_api_up.h: * builds the _spin_*() APIs. * * linux/spinlock.h: builds the final spin_*() APIs. */ All SMP and UP architectures are converted by this patch. arm, i386, ia64, ppc, ppc64, s390/s390x, x64 was build-tested via crosscompilers. m32r, mips, sh, sparc, have not been tested yet, but should be mostly fine. From: Grant Grundler <grundler@parisc-linux.org> Booted and lightly tested on a500-44 (64-bit, SMP kernel, dual CPU). Builds 32-bit SMP kernel (not booted or tested). I did not try to build non-SMP kernels. That should be trivial to fix up later if necessary. I converted bit ops atomic_hash lock to raw_spinlock_t. Doing so avoids some ugly nesting of linux/*.h and asm/*.h files. Those particular locks are well tested and contained entirely inside arch specific code. I do NOT expect any new issues to arise with them. If someone does ever need to use debug/metrics with them, then they will need to unravel this hairball between spinlocks, atomic ops, and bit ops that exist only because parisc has exactly one atomic instruction: LDCW (load and clear word). From: "Luck, Tony" <tony.luck@intel.com> ia64 fix Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjanv@infradead.org> Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Cc: Matthew Wilcox <willy@debian.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Mikael Pettersson <mikpe@csd.uu.se> Signed-off-by: Benoit Boissinot <benoit.boissinot@ens-lyon.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09kbuild: arm26,sparc use generic asm-offset supportSam Ravnborg
Rename all includes to use asm-offsets.h to match generic name Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-09-07[PATCH] NTP: ntp-helper functionsjohn stultz
This patch cleans up a commonly repeated set of changes to the NTP state variables by adding two helper inline functions: ntp_clear(): Clears the ntp state variables ntp_synced(): Returns 1 if the system is synced with a time server. This was compile tested for alpha, arm, i386, x86-64, ppc64, s390, sparc, sparc64. Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-01[SPARC]: Kill io_remap_page_range()David S. Miller
It's been deprecated long enough and there are no in-tree users any longer. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[SPARC]: remove use of asm/segment.hKumar Gala
Removed sparc architecture specific users of asm/segment.h and asm-sparc/segment.h itself Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[PATCH] convert signal handling of NODEFER to act like other Unix boxes.Steven Rostedt
It has been reported that the way Linux handles NODEFER for signals is not consistent with the way other Unix boxes handle it. I've written a program to test the behavior of how this flag affects signals and had several reports from people who ran this on various Unix boxes, confirming that Linux seems to be unique on the way this is handled. The way NODEFER affects signals on other Unix boxes is as follows: 1) If NODEFER is set, other signals in sa_mask are still blocked. 2) If NODEFER is set and the signal is in sa_mask, then the signal is still blocked. (Note: this is the behavior of all tested but Linux _and_ NetBSD 2.0 *). The way NODEFER affects signals on Linux: 1) If NODEFER is set, other signals are _not_ blocked regardless of sa_mask (Even NetBSD doesn't do this). 2) If NODEFER is set and the signal is in sa_mask, then the signal being handled is not blocked. The patch converts signal handling in all current Linux architectures to the way most Unix boxes work. Unix boxes that were tested: DU4, AIX 5.2, Irix 6.5, NetBSD 2.0, SFU 3.5 on WinXP, AIX 5.3, Mac OSX, and of course Linux 2.6.13-rcX. * NetBSD was the only other Unix to behave like Linux on point #2. The main concern was brought up by point #1 which even NetBSD isn't like Linux. So with this patch, we leave NetBSD as the lonely one that behaves differently here with #2. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-19[SPARC]: Fix weak aliasesAl Viro
sparc_ksyms.c used to declare weak alias to several gcc intrinsics. It doesn't work with gcc4 anymore - it wants a declaration for the thing we are aliasing to and that's not going to happen for something like .mul, etc. Replaced with direct injection of weak alias on the assembler level - .weak <alias> followed by <alias> = <aliased>; that works on all gcc versions. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-27[SPARC]: Add inotify syscall entries.David S. Miller
2005-07-26[PATCH] Don't export machine_restart, machine_halt, or machine_power_off.Eric W. Biederman
machine_restart, machine_halt and machine_power_off are machine specific hooks deep into the reboot logic, that modules have no business messing with. Usually code should be calling kernel_restart, kernel_halt, kernel_power_off, or emergency_restart. So don't export machine_restart, machine_halt, and machine_power_off so we can catch buggy users. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-10[SPARC]: Add ioprio system call support.David S. Miller
2005-05-05[SPARC]: Remove legacy stuff from cpu_idle().Coywolf Qi Hunt
Currently sparc and sparc64's UP cpu_idle() checks current pid. This is old time legacy. Now it's paranoia. Signed-off-by: Coywolf Qi Hunt <coywolf@lovecn.org> Acked-by: William Irwin <wli@holomorphy.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-01[PATCH] convert that currently tests _NSIG directly to use valid_signal()Jesper Juhl
Convert most of the current code that uses _NSIG directly to instead use valid_signal(). This avoids gcc -W warnings and off-by-one errors. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-24[SPARC]: dump_stack for sparcTom 'spot' Callaway
Bob Breuer wrote a patch to add dump_stack for sparc. Supposedly, this was applied, but it doesn't exist in 2.6.11. This is the same patch, rediffed against 2.6.11. Signed-off-by: Tom 'spot' Callaway <tcallawa@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-24[SPARC]: More sparc32 ksyms cleanupsTom 'spot' Callaway
The sparc32 ksyms is missing a few more symbols, these are primarily related to SMP, and will be needed as SMP gets beaten back into functionality. Specifically, add __cpu_data (PER_CPU), cpu_online_map, and phys_cpu_present_map. This patch assumes that the earlier "linux-2.6.11-sparc-fixksyms.patch" is applied, otherwise, it will apply with fuzz. Signed-off-by: Tom 'spot' Callaway <tcallawa@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-24[SPARC]: Missing sparc32 ksymsTom 'spot' Callaway
This patch adds some missing sparc32 ksyms that are needed. Specifically, ___rw_read_enter, ___rw_read_exit, ___rw_write_enter, and sys_close. Signed-off-by: Tom 'spot' Callaway <tcallawa@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-17[PATCH] sparc: Fix PTRACE_CONT bogosityDavid S. Miller
SunOS aparently had this weird PTRACE_CONT semantic which we copied. If the addr argument is something other than 1, it sets the process program counter to whatever that value is. This is different from every other Linux architecture, which don't do anything with the addr and data args. This difference in particular breaks the Linux native GDB support for fork and vfork tracing on sparc and sparc64. There is no interest in running SunOS binaries using this weird PTRACE_CONT behavior, so just delete it so we behave like other platforms do. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
