path: root/arch/sparc/mm/hypersparc.S
2013-07-10[PATCH] sparc32: vm_area_struct access for old Sun SPARCs.Olivier DANET
Commit e4c6bfd2d79d063017ab19a18915f0bc759f32d9 ("mm: rearrange vm_area_struct for fewer cache misses") changed the layout of the vm_area_struct structure, it broke several SPARC32 assembly routines which used numerical constants for accessing the vm_mm field. This patch defines the VMA_VM_MM constant to replace the immediate values. Signed-off-by: Olivier DANET <odanet@caramail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20sparc: remove CVS keywordsAdrian Bunk
This patch removes the CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-09kbuild: arm26,sparc use generic asm-offset supportSam Ravnborg
Rename all includes to use asm-offsets.h to match generic name Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
