Fix the calculation of the end address when flushing iotlb entries to
ram. This bug has been a cause of esp dma errors, and it affects
HyperSPARC systems much worse than SuperSPARC systems.
Signed-off-by: Bob Breuer <breuerr@mc.net>
Acked-by: William Lee Irwin III <wli@holomorphy.com>
this patch changes if() BUG(); constructs
in iommu.c to BUG_ON(); so it gets save
to define BUG() and BUG_ON() to nullstatements.
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de>
Here are the Sparc bits.
Although we tend to associate VM_RESERVED with remap_pfn_range, quite a few
drivers set VM_RESERVED on areas which are then populated by nopage. The
PageReserved removal in 2.6.15-rc1 changed VM_RESERVED not to free pages in
zap_pte_range, without changing those drivers not to set it: so their pages
just leak away.
Let's not change miscellaneous drivers now: introduce VM_UNPAGED at the core,
to flag the special areas where the ptes may have no struct page, or if they
have then it's not to be touched. Replace most instances of VM_RESERVED in
core mm by VM_UNPAGED. Force it on in remap_pfn_range, and the sparc and
sparc64 io_remap_pfn_range.
Revert addition of VM_RESERVED to powerpc vdso, it's not needed there. Is it
needed anywhere? It still governs the mm->reserved_vm statistic, and special
vmas not to be merged, and areas not to be core dumped; but could probably be
eliminated later (the drivers are probably specifying it because in 2.4 it
kept swapout off the vma, but in 2.6 we work from the LRU, which these pages
don't get on).
Use the VM_SHM slot for VM_UNPAGED, and define VM_SHM to 0: it serves no
purpose whatsoever, and should be removed from drivers when we clean up.
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Acked-by: William Irwin <wli@holomorphy.com>
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove a
duplicate of ARRAY_SIZE which is never used anyways.
Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch>
Convert those few architectures which are calling pud_alloc, pmd_alloc,
pte_alloc_map on a user mm, not to take the page_table_lock first, nor drop it
after. Each of these can continue to use pte_alloc_map, no need to change
over to pte_alloc_map_lock, they're neither racy nor swappable.
In the sparc64 io_remap_pfn_range, flush_tlb_range then falls outside of the
page_table_lock: that's okay, on sparc64 it's like flush_tlb_mm, and that has
always been called from outside of page_table_lock in dup_mmap.
Remove PageReserved() calls from core code by tightening VM_RESERVED
handling in mm/ to cover PageReserved functionality.
PageReserved special casing is removed from get_page and put_page.
All setting and clearing of PageReserved is retained, and it is now flagged
in the page_alloc checks to help ensure we don't introduce any refcount
based freeing of Reserved pages.
MAP_PRIVATE, PROT_WRITE of VM_RESERVED regions is tentatively being
deprecated. We never completely handled it correctly anyway, and is be
reintroduced in future if required (Hugh has a proof of concept).
Once PageReserved() calls are removed from kernel/power/swsusp.c, and all
arch/ and driver code, the Set and Clear calls, and the PG_reserved bit can
be trivially removed.
Last real user of PageReserved is swsusp, which uses PageReserved to
determine whether a struct page points to valid memory or not. This still
needs to be addressed (a generic page_is_ram() should work).
A last caveat: the ZERO_PAGE is now refcounted and managed with rmap (and
thus mapcounted and count towards shared rss). These writes to the struct
page could cause excessive cacheline bouncing on big systems. There are a
number of ways this could be addressed if it is an issue.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Refcount bug fix for filemap_xip.c
Signed-off-by: Carsten Otte <cotte@de.ibm.com>
Rename all includes to use asm-offsets.h to match generic name
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
It's been deprecated long enough and there are no in-tree
users any longer.
Removed sparc architecture specific users of asm/segment.h and
asm-sparc/segment.h itself
Signed-off-by: Kumar Gala <kumar.gala@freescale.com>
Remove PG_highmem, to save a page flag. Use is_highmem() instead. It'll
generate a little more code, but we don't use PageHigheMem() in many places.
Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com>
infrastructure for it.
Let it rip!
