path: root/arch/sparc/power
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-18sparc64: Prevent perf from running during super critical sectionsRob Gardner
This fixes another cause of random segfaults and bus errors that may occur while running perf with the callgraph option. Critical sections beginning with spin_lock_irqsave() raise the interrupt level to PIL_NORMAL_MAX (14) and intentionally do not block performance counter interrupts, which arrive at PIL_NMI (15). But some sections of code are "super critical" with respect to perf because the perf_callchain_user() path accesses user space and may cause TLB activity as well as faults as it unwinds the user stack. One particular critical section occurs in switch_mm: spin_lock_irqsave(&mm->context.lock, flags); ... load_secondary_context(mm); tsb_context_switch(mm); ... spin_unlock_irqrestore(&mm->context.lock, flags); If a perf interrupt arrives in between load_secondary_context() and tsb_context_switch(), then perf_callchain_user() could execute with the context ID of one process, but with an active TSB for a different process. When the user stack is accessed, it is very likely to incur a TLB miss, since the h/w context ID has been changed. The TLB will then be reloaded with a translation from the TSB for one process, but using a context ID for another process. This exposes memory from one process to another, and since it is a mapping for stack memory, this usually causes the new process to crash quickly. This super critical section needs more protection than is provided by spin_lock_irqsave() since perf interrupts must not be allowed in. Since __tsb_context_switch already goes through the trouble of disabling interrupts completely, we fix this by moving the secondary context load down into this better protected region. Orabug: 25577560 Signed-off-by: Dave Aldridge <david.j.aldridge@oracle.com> Signed-off-by: Rob Gardner <rob.gardner@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
Pull sparc updates from David Miller: 1) Move to 4-level page tables on sparc64 and support up to 53-bits of physical addressing. Kernel static image BSS size reduced by several megabytes. 2) M6/M7 cpu support, from Allan Pais. 3) Move to sparse IRQs, handle hypervisor TLB call errors more gracefully, and add T5 perf_event support. From Bob Picco. 4) Recognize cdroms and compute geometry from capacity in virtual disk driver, also from Allan Pais. 5) Fix memset() return value on sparc32, from Andreas Larsson. 6) Respect gfp flags in dma_alloc_coherent on sparc32, from Daniel Hellstrom. 7) Fix handling of compound pages in virtual disk driver, from Dwight Engen. 8) Fix lockdep warnings in LDC layer by moving IRQ requesting to ldc_alloc() from ldc_bind(). 9) Increase boot string length to 1024 bytes, from Dave Kleikamp. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: (31 commits) sparc64: Fix lockdep warnings on reboot on Ultra-5 sparc64: Increase size of boot string to 1024 bytes sparc64: Kill unnecessary tables and increase MAX_BANKS. sparc64: sparse irq sparc64: Adjust vmalloc region size based upon available virtual address bits. sparc64: Increase MAX_PHYS_ADDRESS_BITS to 53. sparc64: Use kernel page tables for vmemmap. sparc64: Fix physical memory management regressions with large max_phys_bits. sparc64: Adjust KTSB assembler to support larger physical addresses. sparc64: Define VA hole at run time, rather than at compile time. sparc64: Switch to 4-level page tables. sparc64: Fix reversed start/end in flush_tlb_kernel_range() sparc64: Add vio_set_intr() to enable/disable Rx interrupts vio: fix reuse of vio_dring slot sunvdc: limit each sg segment to a page sunvdc: compute vdisk geometry from capacity sunvdc: add cdrom and v1.1 protocol support sparc: VIO protocol version 1.6 sparc64: Fix hibernation code refrence to PAGE_OFFSET. sparc64: Move request_irq() from ldc_bind() to ldc_alloc() ...
2014-10-09nosave: consolidate __nosave_{begin,end} in <asm/sections.h>Geert Uytterhoeven
The different architectures used their own (and different) declarations: extern __visible const void __nosave_begin, __nosave_end; extern const void __nosave_begin, __nosave_end; extern long __nosave_begin, __nosave_end; Consolidate them using the first variant in <asm/sections.h>. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-09-26sparc64: Fix hibernation code refrence to PAGE_OFFSET.David S. Miller
We changed PAGE_OFFSET to be a variable rather than a constant, but this reference here in the hibernate assembler got missed. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-20sparc64: Hibernation supportTkhai Kirill
This patch adds CONFIG_HIBERNATION support for sparc64 architecture. The suspend function is the same as on another platforms. The restore function uses Bypass feature of MMU which allows to make the process more comfortable and plesant. Signed-off-by: Kirill Tkhai <tkhai@yandex.ru> CC: David Miller <davem@davemloft.net> CC: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
