path: root/arch/sparc64/Kconfig.debug
2008-02-13[SPARC64]: Remove DEBUG_BOOTMEM.David S. Miller
We'll replace it in the future with better logging facilities that can be enabled at run time. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-29Replace CONFIG_SOFTWARE_SUSPEND with CONFIG_HIBERNATIONRafael J. Wysocki
Replace CONFIG_SOFTWARE_SUSPEND with CONFIG_HIBERNATION to avoid confusion (among other things, with CONFIG_SUSPEND introduced in the next patch). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-10[SPARC64]: Add irqtrace/stacktrace/lockdep support.David S. Miller
2006-03-25[PATCH] kconfig: clarify memory debug optionsAndrew Morton
The Kconfig text for CONFIG_DEBUG_SLAB and CONFIG_DEBUG_PAGEALLOC have always seemed a bit confusing. Change them to: CONFIG_DEBUG_SLAB: "Debug slab memory allocations" CONFIG_DEBUG_PAGEALLOC: "Debug page memory allocations" Cc: "David S. Miller" <davem@davemloft.net> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] Move Kprobes and Oprofile to "Instrumentation Support" menuPrasanna S Panchamukhi
Andrew Morton suggested to move kprobes from kernel hacking menu, since kernel hacking menu is in-appropriate for the Kprobes. This patch moves Kprobes and Oprofile under instrumentation menu. (akpm: it's not a natural fit, but things like djprobes and the s390 guys' statistics library need a home) Signed-of-by: Prasanna S Panchamukhi <prasanna@in.ibm.com> Cc: Philippe Elie <phil.el@wanadoo.fr> Cc: John Levon <levon@movementarian.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-25[SPARC64]: Add CONFIG_DEBUG_PAGEALLOC support.David S. Miller
The trick is that we do the kernel linear mapping TLB miss starting with an instruction sequence like this: ba,pt %xcc, kvmap_load xor %g2, %g4, %g5 succeeded by an instruction sequence which performs a full page table walk starting at swapper_pg_dir. We first take over the trap table from the firmware. Then, using this constant PTE generation for the linear mapping area above, we build the kernel page tables for the linear mapping. After this is setup, we patch that branch above into a "nop", which will cause TLB misses to fall through to the full page table walk. With this, the page unmapping for CONFIG_DEBUG_PAGEALLOC is trivial. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-14[LIB]: Consolidate _atomic_dec_and_lock()David S. Miller
Several implementations were essentialy a common piece of C code using the cmpxchg() macro. Put the implementation in one spot that everyone can share, and convert sparc64 over to using this. Alpha is the lone arch-specific implementation, which codes up a special fast path for the common case in order to avoid GP reloading which a pure C version would require. Signed-off-by: David S. Miller <davem@davemloft.net>
