path: root/arch/sparc64/kernel/setup.c
2008-12-04sparc,sparc64: unify kernel/Sam Ravnborg
o Move all files from sparc64/kernel/ to sparc/kernel - rename as appropriate o Update sparc/Makefile to the changes o Update sparc/kernel/Makefile to include the sparc64 files NOTE: This commit changes link order on sparc64! Link order had to change for either of sparc32 and sparc64. And assuming sparc64 see more testing than sparc32 change link order on sparc64 where issues will be caught faster. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20sparc64: remove CVS keywordsAdrian Bunk
This patch removes the CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-23[SPARC64]: PROM debug console can be CON_ANYTIME.David S. Miller
No per-cpu or similar resources need to be setup before we can use this console device. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-23[SPARC64]: Once we have the boot cmdline, call parse_early_param()David S. Miller
2008-03-25[SPARC64]: Fix sparse warnings in arch/sparc64/kernel/{cpu,setup}.cDavid S. Miller
We create a local header file entry.h, under arch/sparc64/kernel/, that we can use to declare routines either defined in assembler or only invoked from assembler. As well as other data objects which are private to the inner sparc64 kernel arch code. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-18[SPARC]: Kill 'prom_palette'.David S. Miller
The idea of this thing is we could save/restore the firmware's palette when breaking in and out of the firmware prompt. Only one driver implemented this (atyfb) and it's value is questionable. If you're just debugging you don't really care that the characters end up being purple or whatever. And we can provide better debugging and firmware command facilities with minimal in-kernel console I/O drivers. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-18[SPARC64]: Kill 'prom_keyboard'.David S. Miller
Nothing ever sets it, so it just takes up space. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-18[SPARC]: Kill extern decl of 'panic_setup'.David S. Miller
This was made static in kernel/panic.c a long time ago. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-18[SPARC64]: Delete 'boot_flags'.David S. Miller
It is write-only, nothing tests it's value. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-18[SPARC64]: Kill unused function 'kernel_enter_debugger'.David S. Miller
2008-02-17[SPARC64]: Always register a PROM based early console.David S. Miller
2008-02-08aout: remove unnecessary inclusions of {asm, linux}/a.out.hDavid Howells
Remove now unnecessary inclusions of {asm,linux}/a.out.h. [akpm@linux-foundation.org: fix alpha build] Signed-off-by: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-22[SPARC]: Constify function pointer tables.Jan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-20[SPARC]: Fix serial console device detection.David S. Miller
The current scheme works on static interpretation of text names, which is wrong. The output-device setting, for example, must be resolved via an alias or similar to a full path name to the console device. Paths also contain an optional set of 'options', which starts with a colon at the end of the path. The option area is used to specify which of two serial ports ('a' or 'b') the path refers to when a device node drives multiple ports. 'a' is assumed if the option specification is missing. This was caught by the UltraSPARC-T1 simulator. The 'output-device' property was set to 'ttya' and we didn't pick upon the fact that this is an OBP alias set to '/virtual-devices/console'. Instead we saw it as the first serial console device, instead of the hypervisor console. The infrastructure is now there to take advantage of this to resolve the console correctly even in multi-head situations in fbcon too. Thanks to Greg Onufer for the bug report. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-16[SPARC64]: SMP build fix.Fabio Massimo Di Nitto
The UP build fix had some unintended consequences. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-16[SPARC64]: Fix UP build.David S. Miller
2007-07-16[SPARC64]: More sensible udelay implementation.David S. Miller
Take a page from the powerpc folks and just calculate the delay factor directly. Since frequency scaling chips use a system-tick register, the value is going to be the same system-wide. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-04[SPARC64]: Move topology init code into new file, sysfs.cDavid S. Miller
Also, use per-cpu data for struct cpu. Calling kmalloc for each cpu in topology_init() is just plain clumsy. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-29[SPARC64]: Use machine description and OBP properly for cpu probing.David S. Miller
2007-05-15[SPARC64]: Add hypervisor API negotiation and fix console bugs.David S. Miller
Hypervisor interfaces need to be negotiated in order to use some API calls reliably. So add a small set of interfaces to request API versions and query current settings. This allows us to fix some bugs in the hypervisor console: 1) If we can negotiate API group CORE of at least major 1 minor 1 we can use con_read and con_write which can improve console performance quite a bit. 2) When we do a console write request, we should hold the spinlock around the whole request, not a byte at a time. What would happen is that it's easy for output from different cpus to get mixed with each other. 3) Use consistent udelay() based polling, udelay(1) each loop with a limit of 1000 polls to handle stuck hypervisor console. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-12[PATCH] Dynamic kernel command-line: sparc64Alon Bar-Lev
Rename saved_command_line into boot_command_line. Signed-off-by: Alon Bar-Lev <alon.barlev@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-17[SPARC]: Kill BOOTME_SINGLE.David S. Miller
Unused, but still allow the '-s' boot option to be passed down to init. Based upon patches by Martin Habets. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-11[SPARC32]: Fix sparc32 modpost warnings with sunzilogMartin Habets
Fix this 2.6.19-rc1 build warnings from modpost: WARNING: vmlinux - Section mismatch: reference to .init.text:sunzilog_console_setup from .data between 'sunzilog_console' (at offset 0x8394) and 'devices_subsys' Signed-off-by: Martin Habets <errandir_news@mph.eclipse.co.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-10[PATCH] tty: Remove include of screen_info.h from tty.hJon Smirl
screen_info.h doesn't have anything to do with the tty layer and shouldn't be included by tty.h. This patches removes the include and modifies all users to directly include screen_info.h. struct screen_info is mainly used to communicate with the console drivers in drivers/video/console. Note that this patch touches every arch and I have no way of testing it. If there is a mistake the worst thing that will happen is a compile error. [akpm@osdl.org: fix arm build] [akpm@osdl.org: fix alpha build] Signed-off-by: Jon Smirl <jonsmir@gmail.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] node hotplug: register cpu: remove node structKAMEZAWA Hiroyuki
With Goto-san's patch, we can add new pgdat/node at runtime. I'm now considering node-hot-add with cpu + memory on ACPI. I found acpi container, which describes node, could evaluate cpu before memory. This means cpu-hot-add occurs before memory hot add. In most part, cpu-hot-add doesn't depend on node hot add. But register_cpu(), which creates symbolic link from node to cpu, requires that node should be onlined before register_cpu(). When a node is onlined, its pgdat should be there. This patch-set holds off creating symbolic link from node to cpu until node is onlined. This removes node arguments from register_cpu(). Now, register_cpu() requires 'struct node' as its argument. But the array of struct node is now unified in driver/base/node.c now (By Goto's node hotplug patch). We can get struct node in generic way. So, this argument is not necessary now. This patch also guarantees add cpu under node only when node is onlined. It is necessary for node-hot-add vs. cpu-hot-add patch following this. Moreover, register_cpu calculates cpu->node_id by cpu_to_node() without regard to its 'struct node *root' argument. This patch removes it. Also modify callers of register_cpu()/unregister_cpu, whose args are changed by register-cpu-remove-node-struct patch. [Brice.Goglin@ens-lyon.org: fix it] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Ashok Raj <ashok.raj@intel.com> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Brice Goglin <Brice.Goglin@ens-lyon.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[SPARC64]: Must run smp_setup_cpu_possible_map() after paging_init()David S. Miller
Otherwise the in-kernel PROM device tree isn't built yet, and therefore the present cpu bits don't get set properly. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-31[SPARC64]: Make smp_processor_id() functional before start_kernel()David S. Miller
Uses of smp_processor_id() get pushed earlier and earlier in the start_kernel() sequence. So just get it working before we call start_kernel() to avoid all possible problems. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-11[PATCH] for_each_possible_cpu: sparc64KAMEZAWA Hiroyuki
for_each_cpu() actually iterates across all possible CPUs. We've had mistakes in the past where people were using for_each_cpu() where they should have been iterating across only online or present CPUs. This is inefficient and possibly buggy. We're renaming for_each_cpu() to for_each_possible_cpu() to avoid this in the future. This patch replaces for_each_cpu with for_each_possible_cpu. for sparc64. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-20[SPARC64]: CONFIG_BLK_DEV_RAM fixAndrew Morton
init/do_mounts_rd.c depends upon CONFIG_BLK_DEV_RAM, not CONFIG_BLK_DEV_INITRD. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Fix system type in /proc/cpuinfo and remove bogus OBP check.David S. Miller
Report 'sun4v' when appropriate in /proc/cpuinfo Remove all the verifications of the OBP version string. Just make sure it's there, and report it raw in the bootup logs and via /proc/cpuinfo. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: kzalloc() conversionEric Sesterhenn
this patch converts arch/sparc64 to kzalloc usage. Crosscompile tested with allyesconfig. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Init boot cpu's trap_block[] before paging_init()David S. Miller
It must be ready when we take over the trap table. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Fix uniprocessor IRQ targetting on SUN4V.David S. Miller
We need to use the real hardware processor ID when targetting interrupts, not the "define to 0" thing the uniprocessor build gives us. Also, fill in the Node-ID and Agent-ID fields properly on sun4u/Safari. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Get SUN4V SMP working.David S. Miller
The sibling cpu bringup is extremely fragile. We can only perform the most basic calls until we take over the trap table from the firmware/hypervisor on the new cpu. This means no accesses to %g4, %g5, %g6 since those can't be TLB translated without our trap handlers. In order to achieve this: 1) Change sun4v_init_mondo_queues() so that it can operate in several modes. It can allocate the queues, or install them in the current processor, or both. The boot cpu does both in it's call early on. Later, the boot cpu allocates the sibling cpu queue, starts the sibling cpu, then the sibling cpu loads them in. 2) init_cur_cpu_trap() is changed to take the current_thread_info() as an argument instead of reading %g6 directly on the current cpu. 3) Create a trampoline stack for the sibling cpus. We do our basic kernel calls using this stack, which is locked into the kernel image, then go to our proper thread stack after taking over the trap table. 4) While we are in this delicate startup state, we put 0xdeadbeef into %g4/%g5/%g6 in order to catch accidental accesses. 5) On the final prom_set_trap_table*() call, we put &init_thread_union into %g6. This is a hack to make prom_world(0) work. All that wants to do is restore the %asi register using get_thread_current_ds(). Longer term we should just do the OBP calls to set the trap table by hand just like we do for everything else. This would avoid that silly prom_world(0) issue, then we can remove the init_thread_union hack. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64] sunhv: Bug fixes.David S. Miller
Add udelay to polling console write loop, and increment the loop limit. Name the device "ttyHV" and pass that to add_preferred_console() when we're using hypervisor console. Kill sunhv_console_setup(), it's empty. Handle the case where we don't want to use hypervisor console. (ie. we have a head attached to a sun4v machine) Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Recognize "virtual-console" as input and output console device.David S. Miller
2006-03-20[SPARC64]: Deal with PTE layout differences in SUN4V.David S. Miller
Yes, you heard it right, they changed the PTE layout for SUN4V. Ho hum... This is the simple and inefficient way to support this. It'll get optimized, don't worry. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Fix typo in sun4v_patch().David S. Miller
Second instruction offset is '4' not '3'. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Print ARCH as SUN4V when tlb_type is hypervisor.David S. Miller
2006-03-20[SPARC64]: Detect sun4v early in boot process.David S. Miller
We look for "SUNW,sun4v" in the 'compatible' property of the root OBP device tree node. Protect every %ver register access, to make sure it is not touched on sun4v, as %ver is hyperprivileged there. Lock kernel TLB entries using hypervisor calls instead of calls into OBP. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Patch up mmu context register writes for sun4v.David S. Miller
sun4v uses ASI_MMU instead of ASI_DMMU Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Rename gl_{1,2}insn_patch --> sun4v_{1,2}insn_patchDavid S. Miller
2006-03-20[SPARC64]: Add missing memory barriers to instruction patching functions.David S. Miller
V9 requires a write memory barrier before the instruction flush. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Sanitize %pstate writes for sun4v.David S. Miller
If we're just switching between different alternate global sets, nop it out on sun4v. Also, get rid of all of the alternate global save/restore in the OBP CIF trampoline code. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Add initial code to twiddle %gl on trap entry/exit.David S. Miller
Instead of setting/clearing PSTATE_AG we have to change the %gl register value on sun4v. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Add sun4v case to __GET_CPUID() patch tables.David S. Miller
2006-03-20[SPARC64]: Refine code sequences to get the cpu id.David S. Miller
On uniprocessor, it's always zero for optimize that. On SMP, the jmpl to the stub kills the return address stack in the cpu branch prediction logic, so expand the code sequence inline and use a code patching section to fix things up. This also always better and explicit register selection, which will be taken advantage of in a future changeset. The hard_smp_processor_id() function is big, so do not inline it. Fix up tests for Jalapeno to also test for Serrano chips too. These tests want "jbus Ultra-IIIi" cases to match, so that is what we should test for. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Elminate all usage of hard-coded trap globals.David S. Miller
UltraSPARC has special sets of global registers which are switched to for certain trap types. There is one set for MMU related traps, one set of Interrupt Vector processing, and another set (called the Alternate globals) for all other trap types. For what seems like forever we've hard coded the values in some of these trap registers. Some examples include: 1) Interrupt Vector global %g6 holds current processors interrupt work struct where received interrupts are managed for IRQ handler dispatch. 2) MMU global %g7 holds the base of the page tables of the currently active address space. 3) Alternate global %g6 held the current_thread_info() value. Such hardcoding has resulted in some serious issues in many areas. There are some code sequences where having another register available would help clean up the implementation. Taking traps such as cross-calls from the OBP firmware requires some trick code sequences wherein we have to save away and restore all of the special sets of global registers when we enter/exit OBP. We were also using the IMMU TSB register on SMP to hold the per-cpu area base address, which doesn't work any longer now that we actually use the TSB facility of the cpu. The implementation is pretty straight forward. One tricky bit is getting the current processor ID as that is different on different cpu variants. We use a stub with a fancy calling convention which we patch at boot time. The calling convention is that the stub is branched to and the (PC - 4) to return to is in register %g1. The cpu number is left in %g6. This stub can be invoked by using the __GET_CPUID macro. We use an array of per-cpu trap state to store the current thread and physical address of the current address space's page tables. The TRAP_LOAD_THREAD_REG loads %g6 with the current thread from this table, it uses __GET_CPUID and also clobbers %g1. TRAP_LOAD_IRQ_WORK is used by the interrupt vector processing to load the current processor's IRQ software state into %g6. It also uses __GET_CPUID and clobbers %g1. Finally, TRAP_LOAD_PGD_PHYS loads the physical address base of the current address space's page tables into %g7, it clobbers %g1 and uses __GET_CPUID. Many refinements are possible, as well as some tuning, with this stuff in place. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-26[SPARC64]: Make cpu_present_map available earlier.David S. Miller
The change to kernel/sched.c's init code to use for_each_cpu() requires that the cpu_possible_map be setup much earlier. Set it up via setup_arch(), constrained to NR_CPUS, and later constrain it to max_cpus in smp_prepare_cpus(). This fixes SMP booting on sparc64. Signed-off-by: David S. Miller <davem@davemloft.net>
