path: root/arch/sparc64/kernel/signal.c
2008-12-04sparc,sparc64: unify kernel/Sam Ravnborg
o Move all files from sparc64/kernel/ to sparc/kernel - rename as appropriate o Update sparc/Makefile to the changes o Update sparc/kernel/Makefile to include the sparc64 files NOTE: This commit changes link order on sparc64! Link order had to change for either of sparc32 and sparc64. And assuming sparc64 see more testing than sparc32 change link order on sparc64 where issues will be caught faster. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-04arch/sparc64/kernel/signal.c: removed duplicated #includeHuang Weiyi
Removed duplicated #include <linux/tracehook.h> in arch/sparc64/kernel/signal.c. Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-31sparc64: Do not clobber %g7 in setcontext() trap.David S. Miller
That's the userland thread register, so we should never try to change it like this. Based upon glibc bug nptl/6577 and suggestions by Jakub Jelinek. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-27sparc64: tracehook_signal_handlerRoland McGrath
Call the standard hook after setting up signal handlers. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-27sparc64: tracehook: TIF_NOTIFY_RESUMERoland McGrath
This adds TIF_NOTIFY_RESUME support for sparc64. When set, we call tracehook_notify_resume() on the way to user mode. Signed-off-by: Roland McGrath <roland@redhat.com>
2008-05-20sparc64: remove CVS keywordsAdrian Bunk
This patch removes the CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-12sparc64: Use a TS_RESTORE_SIGMASKDavid S. Miller
This mirrors x86 changeset 5a8da0ea82db6fa9737041381079fd16f25dcce2 ("signals: x86 TS_RESTORE_SIGMASK") on sparc64. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-11sparc: Fix debugger syscall restart interactions.David S. Miller
So, forever, we've had this ptrace_signal_deliver implementation which tries to handle all of the nasties that can occur when the debugger looks at a process about to take a signal. It's meant to address all of these issues inside of the kernel so that the debugger need not be mindful of such things. Problem is, this doesn't work. The idea was that we should do the syscall restart business first, so that the debugger captures that state. Otherwise, if the debugger for example saves the child's state, makes the child execute something else, then restores the saved state, we won't handle the syscall restart properly because we lose the "we're in a syscall" state. The code here worked for most cases, but if the debugger actually passes the signal through to the child unaltered, it's possible that we would do a syscall restart when we shouldn't have. In particular this breaks the case of debugging a process under a gdb which is being debugged by yet another gdb. gdb uses sigsuspend to wait for SIGCHLD of the inferior, but if gdb itself is being debugged by a top-level gdb we get a ptrace_stop(). The top-level gdb does a PTRACE_CONT with SIGCHLD to let the inferior gdb see the signal. But ptrace_signal_deliver() assumed the debugger would cancel out the signal and therefore did a syscall restart, because the return error was ERESTARTNOHAND. Fix this by simply making ptrace_signal_deliver() a nop, and providing a way for the debugger to control system call restarting properly: 1) Report a "in syscall" software bit in regs->{tstate,psr}. It is set early on in trap entry to a system call and is fully visible to the debugger via ptrace() and regsets. 2) Test this bit right before doing a syscall restart. We have to do a final recheck right after get_signal_to_deliver() in case the debugger cleared the bit during ptrace_stop(). 3) Clear the bit in trap return so we don't accidently try to set that bit in the real register. As a result we also get a ptrace_{is,clear}_syscall() for sparc32 just like sparc64 has. M68K has this same exact bug, and is now the only other user of the ptrace_signal_deliver hook. It needs to be fixed in the same exact way as sparc. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-07sparc: Fix SA_ONSTACK signal handling.David S. Miller
We need to be more liberal about the alignment of the buffer given to us by sigaltstack(). The user should not need to be mindful of all of the alignment constraints we have for the stack frame. This mirrors how we handle this situation in clone() as well. Also, we align the stack even in non-SA_ONSTACK cases so that signals due to bad stack alignment can be delivered properly. This makes such errors easier to debug and recover from. Finally, add the sanity check x86 has to make sure we won't overflow the signal stack. This fixes glibc testcases nptl/tst-cancel20.c and nptl/tst-cancelx20.c Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-02sparc64: Fix syscall restart, for real...David S. Miller
The change I put into copy_thread() just papered over the real problem. When we are looking to see if we should do a syscall restart, when deliverying a signal, we should only interpret the syscall return value as an error if the carry condition code(s) are set. Otherwise it's a success return. Also, sigreturn paths should do a pt_regs_clear_trap_type(). It turns out that doing a syscall restart when returning from a fork() does and should happen, from time to time. Even if copy_thread() returns success, copy_process() can still unwind and signal -ERESTARTNOINTR in the parent. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-27sparc64: Clean up handling of pt_regs trap type encoding.David S. Miller
If we use this from more than one place, it's better to have helpers instead of twiddling magic constants all over. Add pt_regs_trap_type(), pt_regs_clear_trap_type(), and pt_regs_is_syscall(). Use them in do_signal(). Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-27sparc64: Kill bogus RT_ALIGNEDSZ macro from signal.cDavid S. Miller
The structure has to be 8-byte aligned in size, so this macro is just noise. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-26sparc64: Kill CONFIG_SPARC32_COMPATDavid S. Miller
It's completely superfluous, CONFIG_COMPAT is sufficient. What this used to be is an umbrella for enabling code shared by all 32-bit compat binary support types. But with the removal of SunOS and Solaris support, the only one left is Linux 32-bit ELF. Update defconfig. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-24[SPARC64]: %l6 trap return handling no longer necessary.David S. Miller
Now that we indicate the "restart system call" in the trap type field of pt_regs->magic, we don't need to set the %l6 boolean in all of the trap return paths. And we therefore don't need to pass it to do_notify_resume(). Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-24[SPARC64]: Use trap type stored in pt_regs to handle syscall restart.David S. Miller
Now that we can check the trap type directly, we don't need the funny restart_syscall indication from the trap return paths. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-21[SPARC]: Remove SunOS and Solaris binary support.David S. Miller
As per Documentation/feature-removal-schedule.txt Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-03[SPARC64]: Fix FPU saving in 64-bit signal handling.David S. Miller
The calculation of the FPU reg save area pointer was wrong. Based upon an OOPS report from Tom Callaway. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26[SPARC64]: Fix sparse warnings in arch/sparc64/kernel/signal.cDavid S. Miller
2007-07-17[SPARC64]: Kill bogus set_fs(KERNEL_DS) in do_rt_sigreturn().Oleg Nesterov
From: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-19[SPARC]: Add support for *at(), ppoll, and pselect syscalls.David S. Miller
This also includes by necessity _TIF_RESTORE_SIGMASK support, which actually resulted in a lot of cleanups. The sparc signal handling code is quite a mess and I should clean it up some day. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[PATCH] convert signal handling of NODEFER to act like other Unix boxes.Steven Rostedt
It has been reported that the way Linux handles NODEFER for signals is not consistent with the way other Unix boxes handle it. I've written a program to test the behavior of how this flag affects signals and had several reports from people who ran this on various Unix boxes, confirming that Linux seems to be unique on the way this is handled. The way NODEFER affects signals on other Unix boxes is as follows: 1) If NODEFER is set, other signals in sa_mask are still blocked. 2) If NODEFER is set and the signal is in sa_mask, then the signal is still blocked. (Note: this is the behavior of all tested but Linux _and_ NetBSD 2.0 *). The way NODEFER affects signals on Linux: 1) If NODEFER is set, other signals are _not_ blocked regardless of sa_mask (Even NetBSD doesn't do this). 2) If NODEFER is set and the signal is in sa_mask, then the signal being handled is not blocked. The patch converts signal handling in all current Linux architectures to the way most Unix boxes work. Unix boxes that were tested: DU4, AIX 5.2, Irix 6.5, NetBSD 2.0, SFU 3.5 on WinXP, AIX 5.3, Mac OSX, and of course Linux 2.6.13-rcX. * NetBSD was the only other Unix to behave like Linux on point #2. The main concern was brought up by point #1 which even NetBSD isn't like Linux. So with this patch, we leave NetBSD as the lonely one that behaves differently here with #2. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
