path: root/arch/sparc64/kernel/sys_sparc.c
2006-10-02[PATCH] provide kernel_execve on all architecturesArnd Bergmann
This adds the new kernel_execve function on all architectures that were using _syscall3() to implement execve. The implementation uses code from the _syscall3 macros provided in the unistd.h header file. I don't have cross-compilers for any of these architectures, so the patch is untested with the exception of i386. Most architectures can probably implement this in a nicer way in assembly or by combining it with the sys_execve implementation itself, but this should do it for now. [bunk@stusta.de: m68knommu build fix] [markh@osdl.org: build fix] [bero@arklinux.org: build fix] [ralf@linux-mips.org: mips fix] [schwidefsky@de.ibm.com: s390 fix] Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Andi Kleen <ak@muc.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Hirokazu Takata <takata.hirokazu@renesas.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Bernhard Rosenkraenzer <bero@arklinux.org> Signed-off-by: Mark Haverkamp <markh@osdl.org> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] namespaces: utsname: switch to using uts namespacesSerge E. Hallyn
Replace references to system_utsname to the per-process uts namespace where appropriate. This includes things like uname. Changes: Per Eric Biederman's comments, use the per-process uts namespace for ELF_PLATFORM, sunrpc, and parts of net/ipv4/ipconfig.c [jdike@addtoit.com: UML fix] [clg@fr.ibm.com: cleanup] [akpm@osdl.org: build fix] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Andrey Savochkin <saw@sw.ru> Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-18[SPARC]: Fix regression in sys_getdomainname()Andy Walker
This patch corrects the buffer length checking in the sys_getdomainname() implementation for sparc/sparc64. Signed-off-by: Andy Walker <andy@puszczka.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-08[PATCH] IA64,sparc: local DoS with corrupted ELFsKirill Korotaev
This prevents cross-region mappings on IA64 and SPARC which could lead to system crash. They were correctly trapped for normal mmap() calls, but not for the kernel internal calls generated by executable loading. This code just moves the architecture-specific cross-region checks into an arch-specific "arch_mmap_check()" macro, and defines that for the architectures that needed it (ia64, sparc and sparc64). Architectures that don't have any special requirements can just ignore the new cross-region check, since the mmap() code will just notice on its own when the macro isn't defined. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Kirill Korotaev <dev@openvz.org> Acked-by: David Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> [ Cleaned up to not affect architectures that don't need it ] Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-21[SPARC]: Fix length parameter verification in sys_getdomainname().David S. Miller
Found by scrashme. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Randomize mm->mmap_base when PF_RANDOMIZE is set.David S. Miller
2006-03-20[SPARC64]: Increase top of 32-bit process stack.David S. Miller
Put it one page below the top of the 32-bit address space. This gives us ~16MB more address space to work with. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Top-down address space allocation for 32-bit tasks.David S. Miller
Currently allocations are very constrained for 32-bit processes. It grows down-up from 0x70000000 to 0xf0000000 which gives about 2GB of stack + dynamic mmap() space. So support the top-down method, and we need to override the generic helper function in order to deal with D-cache coloring. With these changes I was able to squeeze out a mmap() just over 3.6GB in size in a 32-bit process. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: kzalloc() conversionEric Sesterhenn
this patch converts arch/sparc64 to kzalloc usage. Crosscompile tested with allyesconfig. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Do not allow mapping pages within 4GB of 64-bit VA hole.David S. Miller
The UltraSPARC T1 manual recommends this because the chip could instruction prefetch into the VA hole, and this would also make decoding certain kinds of memory access traps more difficult (because the chip sign extends certain pieces of trap state). Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-21[PATCH] Avoiding mmap fragmentationWolfgang Wander
Ingo recently introduced a great speedup for allocating new mmaps using the free_area_cache pointer which boosts the specweb SSL benchmark by 4-5% and causes huge performance increases in thread creation. The downside of this patch is that it does lead to fragmentation in the mmap-ed areas (visible via /proc/self/maps), such that some applications that work fine under 2.4 kernels quickly run out of memory on any 2.6 kernel. The problem is twofold: 1) the free_area_cache is used to continue a search for memory where the last search ended. Before the change new areas were always searched from the base address on. So now new small areas are cluttering holes of all sizes throughout the whole mmap-able region whereas before small holes tended to close holes near the base leaving holes far from the base large and available for larger requests. 2) the free_area_cache also is set to the location of the last munmap-ed area so in scenarios where we allocate e.g. five regions of 1K each, then free regions 4 2 3 in this order the next request for 1K will be placed in the position of the old region 3, whereas before we appended it to the still active region 1, placing it at the location of the old region 2. Before we had 1 free region of 2K, now we only get two free regions of 1K -> fragmentation. The patch addresses thes issues by introducing yet another cache descriptor cached_hole_size that contains the largest known hole size below the current free_area_cache. If a new request comes in the size is compared against the cached_hole_size and if the request can be filled with a hole below free_area_cache the search is started from the base instead. The results look promising: Whereas 2.6.12-rc4 fragments quickly and my (earlier posted) leakme.c test program terminates after 50000+ iterations with 96 distinct and fragmented maps in /proc/self/maps it performs nicely (as expected) with thread creation, Ingo's test_str02 with 20000 threads requires 0.7s system time. Taking out Ingo's patch (un-patch available per request) by basically deleting all mentions of free_area_cache from the kernel and starting the search for new memory always at the respective bases we observe: leakme terminates successfully with 11 distinctive hardly fragmented areas in /proc/self/maps but thread creating is gringdingly slow: 30+s(!) system time for Ingo's test_str02 with 20000 threads. Now - drumroll ;-) the appended patch works fine with leakme: it ends with only 7 distinct areas in /proc/self/maps and also thread creation seems sufficiently fast with 0.71s for 20000 threads. Signed-off-by: Wolfgang Wander <wwc@rentec.com> Credit-to: "Richard Purdie" <rpurdie@rpsys.net> Signed-off-by: Ken Chen <kenneth.w.chen@intel.com> Acked-by: Ingo Molnar <mingo@elte.hu> (partly) Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
