path: root/arch/sparc64/mm/generic.c
2008-12-04sparc,sparc64: unify mm/Sam Ravnborg
- move all sparc64/mm/ files to arch/sparc/mm/ - commonly named files are named _64.c - add files to sparc/mm/Makefile preserving link order - delete now unused sparc64/mm/Makefile - sparc64 now finds mm/ in sparc Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20sparc64: remove CVS keywordsAdrian Bunk
This patch removes the CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-29[SPARC64]: Fix X server hangs due to large pages.David S. Miller
This problem was introduced by changeset 14778d9072e53d2171f66ffd9657daff41acfaed Unlike the hugetlb code paths, the normal fault code is not setup to propagate PTE changes for large page sizes correctly like the ones we make for I/O mappings in io_remap_pfn_range(). It is absolutely necessary to update all sub-ptes of a largepage mapping on a fault. Adding special handling for this would add considerably complexity to tlb_batch_add(). So let's just side-step the issue and forcefully dirty any writable PTEs created by io_remap_pfn_range(). The only other real option would be to disable to large PTE code of io_remap_pfn_range() and we really don't want to do that. Much thanks to Mikael Pettersson for tracking down this problem and testing debug patches. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-22[SPARC]: Respect vm_page_prot in io_remap_page_range().David S. Miller
Make sure the callers do a pgprot_noncached() on vma->vm_page_prot. Pointed out by Hugh Dickens. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Deal with PTE layout differences in SUN4V.David S. Miller
Yes, you heard it right, they changed the PTE layout for SUN4V. Ho hum... This is the simple and inefficient way to support this. It'll get optimized, don't worry. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-29[SPARC64]: Fix >8K I/O mappings.David S. Miller
Increment the PFN field of the PTE so that the tests on vm_pfn in mm/memory.c match up. The TLB ignores these lower bits for larger page sizes, so it's OK to set things like this. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-28[PATCH] sparc: convert IO remapping to VM_PFNMAPDavid S. Miller
Here are the Sparc bits. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-22[PATCH] unpaged: VM_UNPAGEDHugh Dickins
Although we tend to associate VM_RESERVED with remap_pfn_range, quite a few drivers set VM_RESERVED on areas which are then populated by nopage. The PageReserved removal in 2.6.15-rc1 changed VM_RESERVED not to free pages in zap_pte_range, without changing those drivers not to set it: so their pages just leak away. Let's not change miscellaneous drivers now: introduce VM_UNPAGED at the core, to flag the special areas where the ptes may have no struct page, or if they have then it's not to be touched. Replace most instances of VM_RESERVED in core mm by VM_UNPAGED. Force it on in remap_pfn_range, and the sparc and sparc64 io_remap_pfn_range. Revert addition of VM_RESERVED to powerpc vdso, it's not needed there. Is it needed anywhere? It still governs the mm->reserved_vm statistic, and special vmas not to be merged, and areas not to be core dumped; but could probably be eliminated later (the drivers are probably specifying it because in 2.4 it kept swapout off the vma, but in 2.6 we work from the LRU, which these pages don't get on). Use the VM_SHM slot for VM_UNPAGED, and define VM_SHM to 0: it serves no purpose whatsoever, and should be removed from drivers when we clean up. Signed-off-by: Hugh Dickins <hugh@veritas.com> Acked-by: William Irwin <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] mm: arches skip ptlockHugh Dickins
Convert those few architectures which are calling pud_alloc, pmd_alloc, pte_alloc_map on a user mm, not to take the page_table_lock first, nor drop it after. Each of these can continue to use pte_alloc_map, no need to change over to pte_alloc_map_lock, they're neither racy nor swappable. In the sparc64 io_remap_pfn_range, flush_tlb_range then falls outside of the page_table_lock: that's okay, on sparc64 it's like flush_tlb_mm, and that has always been called from outside of page_table_lock in dup_mmap. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] core remove PageReservedNick Piggin
Remove PageReserved() calls from core code by tightening VM_RESERVED handling in mm/ to cover PageReserved functionality. PageReserved special casing is removed from get_page and put_page. All setting and clearing of PageReserved is retained, and it is now flagged in the page_alloc checks to help ensure we don't introduce any refcount based freeing of Reserved pages. MAP_PRIVATE, PROT_WRITE of VM_RESERVED regions is tentatively being deprecated. We never completely handled it correctly anyway, and is be reintroduced in future if required (Hugh has a proof of concept). Once PageReserved() calls are removed from kernel/power/swsusp.c, and all arch/ and driver code, the Set and Clear calls, and the PG_reserved bit can be trivially removed. Last real user of PageReserved is swsusp, which uses PageReserved to determine whether a struct page points to valid memory or not. This still needs to be addressed (a generic page_is_ram() should work). A last caveat: the ZERO_PAGE is now refcounted and managed with rmap (and thus mapcounted and count towards shared rss). These writes to the struct page could cause excessive cacheline bouncing on big systems. There are a number of ways this could be addressed if it is an issue. Signed-off-by: Nick Piggin <npiggin@suse.de> Refcount bug fix for filemap_xip.c Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-01[SPARC]: Kill io_remap_page_range()David S. Miller
It's been deprecated long enough and there are no in-tree users any longer. Signed-off-by: David S. Miller <davem@davemloft.net>
