path: root/arch/sparc64/prom/tree.c
2008-05-20sparc64: remove CVS keywordsAdrian Bunk
This patch removes the CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-27[SPARC64]: __inline__ --> inlineDavid S. Miller
2007-07-20[SPARC]: Fix serial console device detection.David S. Miller
The current scheme works on static interpretation of text names, which is wrong. The output-device setting, for example, must be resolved via an alias or similar to a full path name to the console device. Paths also contain an optional set of 'options', which starts with a colon at the end of the path. The option area is used to specify which of two serial ports ('a' or 'b') the path refers to when a device node drives multiple ports. 'a' is assumed if the option specification is missing. This was caught by the UltraSPARC-T1 simulator. The 'output-device' property was set to 'ttya' and we didn't pick upon the fact that this is an OBP alias set to '/virtual-devices/console'. Instead we saw it as the first serial console device, instead of the hypervisor console. The infrastructure is now there to take advantage of this to resolve the console correctly even in multi-head situations in fbcon too. Thanks to Greg Onufer for the bug report. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-16[SPARC64]: Fix setting of variables in LDOM guest.David S. Miller
There is a special domain services capability for setting variables in the OBP options node. Guests don't have permanent store for the OBP variables like a normal system, so they are instead maintained in the LDOM control node or in the SC. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-21[SPARC]: Kill prom_getname, unused and not implemented properly.David S. Miller
The m68k port's sun3 asm/oplib.h had a stray reference too, so I killed that off as well. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Detect sun4v early in boot process.David S. Miller
We look for "SUNW,sun4v" in the 'compatible' property of the root OBP device tree node. Protect every %ver register access, to make sure it is not touched on sun4v, as %ver is hyperprivileged there. Lock kernel TLB entries using hypervisor calls instead of calls into OBP. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-22[SPARC64]: Rewrite bootup sequence.David S. Miller
Instead of all of this cpu-specific code to remap the kernel to the correct location, use portable firmware calls to do this instead. What we do now is the following in position independant assembler: chosen_node = prom_finddevice("/chosen"); prom_mmu_ihandle_cache = prom_getint(chosen_node, "mmu"); vaddr = 4MB_ALIGN(current_text_addr()); prom_translate(vaddr, &paddr_high, &paddr_low, &mode); prom_boot_mapping_mode = mode; prom_boot_mapping_phys_high = paddr_high; prom_boot_mapping_phys_low = paddr_low; prom_map(-1, 8 * 1024 * 1024, KERNBASE, paddr_low); and that replaces the massive amount of by-hand TLB probing and programming we used to do here. The new code should also handle properly the case where the kernel is mapped at the correct address already (think: future kexec support). Consequently, the bulk of remap_kernel() dies as does the entirety of arch/sparc64/prom/map.S We try to share some strings in the PROM library with the ones used at bootup, and while we're here mark input strings to oplib.h routines with "const" when appropriate. There are many more simplifications now possible. For one thing, we can consolidate the two copies we now have of a lot of cpu setup code sitting in head.S and trampoline.S. This is a significant step towards CONFIG_DEBUG_PAGEALLOC support. Signed-off-by: David S. Miller <davem@davemloft.net>
