The second argument to free_npages() was being incorrectly
calculated, which would thus access far past the end of the
arena->map[] bitmap.
This patch prevents cross-region mappings
on IA64 and SPARC which could lead to system crash.
Adrian Bunk:
Adapted to 2.6.16.
Signed-Off-By: Kirill Korotaev <dev@openvz.org>
There is an ancient and totally incorrect sanity check being
done on the ramdisk location. The check assumes that the
kernel is always loaded to physical address zero, which is
wrong. It was trying to validate the ramdisk value by saying that
if it fell within the kernel image address range it must be wrong.
Anyways, kill this because it actually creates problems. The
'ramdisk_image' should always be adjusted down by KERNBASE.
SILO can easily put the ramdisk in a location which causes
this test to trigger, breaking things.
[ Based almost entirely upon a patch from Ben Collins. ]
Unfortunately, sparc64 doesn't have an easy way to do a "64 X 64 -->
128" bit multiply like PowerPC and IA64 do. We were doing a
"64 X 64 --> 64" bit multiple which causes overflow very quickly with
a 30-bit quotient shift.
So use a quotientshift count of 10 instead of 30, just like x86 and
ARM do.
This also fixes the wrapping of printk timestamp values every ~17
seconds.
Both csum_partial() and the csum_partial_copy*() family of routines
forget to do a final fold on the computed checksum value on sparc64.
So do the standard Sparc "add + set condition codes, add carry"
sequence, then make sure the high 32-bits of the return value are
clear.
Based upon some excellent detective work and debugging done by
Richard Braun and Samuel Thibault.
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
Using asm-generic/dma-mapping.h does not work because pushing
the call down to pci_alloc_coherent() causes the gfp_t argument
of dma_alloc_coherent() to be ignored.
Fix this by implementing things directly, and adding a gfp_t
argument we can use in the internal call down to the PCI DMA
implementation of pci_alloc_coherent().
This fixes massive memory corruption when using the sound driver
layer, which passes things like __GFP_COMP down into these
routines and (correctly) expects that to work.
This is a disk eater when sound is used, so it's pretty critical.
We must use the "a" (allocate) attribute every time we
emit an entry into the __ex_table section.
For consistency, use "a" instead of #alloc which is some
Solaris compat cruft GNU as provides on Sparc.
Commit 9ec4b1f356b3bad928ae8e2aa9caebfa737d52df made kprobes not compile
without module support, so just make that clear in the Kconfig file.
Also, since it's marked EXPERIMENTAL, make that dependency explicit too.
The change to kernel/sched.c's init code to use for_each_cpu()
requires that the cpu_possible_map be setup much earlier.
Set it up via setup_arch(), constrained to NR_CPUS, and later
constrain it to max_cpus in smp_prepare_cpus().
This fixes SMP booting on sparc64.
The sparc64 64 bit syscall table seems to be broken as it has
compat_sys_newfstatat in its syscall table instead of sys_newfstatat.
Do not enable CONFIG_LOCALVERSION_AUTO by default.
When doing kernel development it just leaves a ton
of crap around.
Also, the Solaris syscall table is sized differrently,
and does not go beyond entry 255, so trim off the excess
entries.
It's wrong and totally unneeded.
To let new syscalls through.
This also includes by necessity _TIF_RESTORE_SIGMASK support,
which actually resulted in a lot of cleanups.
The sparc signal handling code is quite a mess and I should
clean it up some day.
Here is a series of patches which introduce in total 13 new system calls
which take a file descriptor/filename pair instead of a single file
name. These functions, openat etc, have been discussed on numerous
occasions. They are needed to implement race-free filesystem traversal,
they are necessary to implement a virtual per-thread current working
directory (think multi-threaded backup software), etc.
We have in glibc today implementations of the interfaces which use the
/proc/self/fd magic. But this code is rather expensive. Here are some
results (similar to what Jim Meyering posted before).
The test creates a deep directory hierarchy on a tmpfs filesystem. Then
rm -fr is used to remove all directories. Without syscall support I get
this:
real 0m31.921s
user 0m0.688s
sys 0m31.234s
With syscall support the results are much better:
real 0m20.699s
user 0m0.536s
sys 0m20.149s
The interfaces are for obvious reasons currently not much used. But they'll
be used. coreutils (and Jeff's posixutils) are already using them.
Furthermore, code like ftw/fts in libc (maybe even glob) will also start using
them. I expect a patch to make follow soon. Every program which is walking
the filesystem tree will benefit.
Signed-off-by: Ulrich Drepper <drepper@redhat.com>
Cc: Al Viro <viro@ftp.linux.org.uk>
Cc: Michael Kerrisk <mtk-manpages@gmx.net>
Based upon a report and preliminary patch from Jim Gifford.
I have the following patch for serial console over the RSC
(remote system controller) on my E250 machine. It basically adds
support for input-device=rsc and output-device=rsc from OBP, and
allows 115200,8,n,1,- serial mode setting.
Adds the ability to disability packet split at compile time and use the legacy receive path on PCI express hardware. Made this a CONFIG option and modified the Kconfig, to reflect the new option.
Signed-off-by: John Ronciak <john.ronciak@intel.com>
Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
Ensure a consistent value is read from the STICK register by ensuring
that both high and low are read without high changing due to a roll
over of the low register.
Various Debian/SPARC users (myself include) have noticed problems with
Hummingbird based systems. The symptoms are that the system time is
seen to jump forward 3 days, 6 hours, 11 minutes give or take a few
seconds. In many cases the system then hangs some time afterwards.
I've spotted a race condition in the code to read the STICK register.
I could not work out why 3d, 6h, 11m is important but guess that it is
due to the 2^32 jump of STICK (forwards on one read and then the next
read will seem to be backwards) during a timer interrupt. I'm guessing
that a change of -2^32 will get converted to a large unsigned
increment after the arithmetic manipulation between STICK,
nanoseconds, jiffies etc.
I did a test where I modified __hbird_read_stick to artificially
inject rollover faults forcefully every few seconds. With this I saw
the clock jump over 6 times in 12 hours compared to once every month
or so.
Signed-off-by: Richard Mortimer <richm@oldelvet.org.uk>
arch: Use <linux/capability.h> where capable() is used.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
There is a window where a probe gets removed right after the probe is hit
on some different cpu. In this case probe handlers can't find a matching
probe instance related to break address. In this case we need to read the
original instruction at break address to see if that is not a break/int3
instruction and recover safely.
Previous code had a bug where we were not checking for the above race in
case of reentrant probes and the below patch fixes this race.
Tested on IA64, Powerpc, x86_64.
Signed-off-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com>
This patch fixes a typo in the dependencies of HUGETLB_PAGE_SIZE_64K.
It might be more logical to rename the HUGETLB_PAGE_SIZE_*K
dependencies to HUGETLB_PAGE_SIZE_*KB, but let's fix this bug first.
This bug was reported by Jean-Luc Leger <reiga@dspnet.fr.eu.org>.
Currently arch_remove_kprobes() is only implemented/required for x86_64 and
powerpc. All other architecture like IA64, i386 and sparc64 implementes a
dummy function which is being called from arch independent kprobes.c file.
This patch removes the dummy functions and replaces it with
#define arch_remove_kprobe(p, s) do { } while(0)
Since Kprobes runtime exception handlers is now lock free as this code path is
now using RCU to walk through the list, there is no need for the
register/unregister{_kprobe} to use spin_{lock/unlock}_isr{save/restore}. The
serialization during registration/unregistration is now possible using just a
mutex.
In the above process, this patch also fixes a minor memory leak for x86_64 and
powerpc.
Now that all these entries in the arch ioctl32.c files are gone [1], we can
build fs/compat_ioctl.c as a normal object and kill tons of cruft. We need a
special do_ioctl32_pointer handler for s390 so the compat_ptr call is done.
This is not needed but harmless on all other architectures. Also remove some
superflous includes in fs/compat_ioctl.c
Tested on ppc64.
[1] parisc still had it's PPP handler left, which is not fully correct
for ppp and besides that ppp uses the generic SIOCPRIV ioctl so it'd
kick in for all netdevice users. We can introduce a proper handler
in one of the next patch series by adding a compat_ioctl method to
struct net_device but for now let's just kill it - parisc doesn't
compile in mainline anyway and I don't want this to block this
patchset.
Cc: Matthew Wilcox <willy@debian.org>
The comment in compat.c is wrong, every architecture provides a
get_compat_sigevent() for the IPC compat code already.
This basically moves the x86_64 version to common code and removes all the
others.
Acked-by: Paul Mackerras <paulus@samba.org>
Acked-by: Andi Kleen <ak@muc.de>
- create one common dump_thread() prototype in kernel.h
- dump_thread() is only used in fs/binfmt_aout.c and can therefore be
removed on all architectures where CONFIG_BINFMT_AOUT is not
available
Noticed by Jakub Jelinek.
Don't clobber register %l0 while checking TI_SYS_NOERROR value in
syscall return path. This bug was introduced by:
db7d9a4eb700be766cc9f29241483dbb1e748832
Problem narrowed down by Luis F. Ortiz and Richard Mortimer.
I tried using %l2 as suggested by Luis and that works for me.
Looking at the code I wonder if it makes sense to simplify the code
a little bit. The following works for me but I'm not sure how to
exercise the "NOERROR" codepath.
Signed-off-by: Jiri Slaby <xslaby@fi.muni.cz>
Configurable 16-bit UID and friends support
This allows turning off the legacy 16 bit UID interfaces on embedded platforms.
3330172 529036 190556 4049764 3dcb64 vmlinux-baseline
3328268 529040 190556 4047864 3dc3f8 vmlinux
UID16 was accidentially disabled for !EMBEDDED.
Signed-off-by: Matt Mackall <mpm@selenic.com>
The ptrace_get_task_struct() helper that I added as part of the ptrace
consolidation is useful in variety of places that currently opencode it.
Switch them to the common helpers.
Add a ptrace_traceme() helper that needs to be explicitly called, and simplify
the ptrace_get_task_struct() interface. We don't need the request argument
now, and we return the task_struct directly, using ERR_PTR() for error
returns. It's a bit more code in the callers, but we have two sane routines
that do one thing well now.
It's definition is wrong (-1 means "no limit" not 999),
only the Sparc SunOS/Solaris compat code uses it, so
let's just kill it off completely from limits.h and
all referencing code.
Noticed by Ulrich Drepper.
Introduce a Kconfig symbol SPARC that is defined on both the sparc and
sparc64 architectures.
This symbol makes some dependencies more readable.
