[ Upstream commit b3e1eb8e7ac9aaa283989496651d99267c4cad6c ]
So that when it is unset, ie. '-1', userspace can see it
properly.
[ Upstream commit 455adb3174d2c8518cef1a61140c211f6ac224d2 ]
Like x86 and arm, call perf_sample_event_took() in perf event
NMI interrupt handler.
[ Upstream commit cfdc3170d214046b9509183fe9b9544dc644d40b ]
It is important to clear the hw->state value for non-stopped events
when they are added into the PMU. Otherwise when the event is
scheduled out, we won't read the counter because HES_UPTODATE is still
set. This breaks 'perf stat' and similar use cases, causing all the
events to show zero.
This worked for multi-pcr because we make explicit sparc_pmu_start()
calls in calculate_multiple_pcrs(). calculate_single_pcr() doesn't do
this because the idea there is to accumulate all of the counter
settings into the single pcr value. So we have to add explicit
hw->state handling there.
Like x86, we use the PERF_HES_ARCH bit to track truly stopped events
so that we don't accidently start them on a reload.
Related to all of this, sparc_pmu_start() is missing a userpage update
so add it.
[ Upstream commit cfb61b5e3e09f8b49bc4d685429df75f45127adc ]
pmdp_invalidate() was changed to update the pmd atomically
(to not lose dirty/access bits) and return the original pmd
value.
However, in doing so, we lost a lot of the essential work that
set_pmd_at() does, namely to update hugepage mapping counts and
queuing up the batched TLB flush entry.
Thus we were not flushing entries out of the TLB when making
such PMD changes.
Fix this by abstracting the accounting work of set_pmd_at() out into a
separate function, and call it from pmdp_establish().
Fixes: a8e654f01cb7 ("sparc64: update pmdp_invalidate() to return old pmd value")
commit 42a0cc3478584d4d63f68f2f5af021ddbea771fa upstream.
Holding uts_sem as a writer while accessing userspace memory allows a
namespace admin to stall all processes that attempt to take uts_sem.
Instead, move data through stack buffers and don't access userspace memory
while uts_sem is held.
Cc: stable@vger.kernel.org
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Signed-off-by: Jann Horn <jannh@google.com>
[ Upstream commit 12be1036c536f849ad6f9bba73cffa708aa965c3 ]
This is necessary to be able to include <linux/msi.h> when
CONFIG_GENERIC_MSI_IRQ_DOMAIN is enabled. Without this, a build with
CONFIG_GENERIC_MSI_IRQ_DOMAIN fails with:
In file included from drivers//ata/ahci.c:45:0:
>> include/linux/msi.h:226:10: error: unknown type name 'msi_alloc_info_t'; did you mean 'sg_alloc_fn'?
msi_alloc_info_t *arg);
sg_alloc_fn
include/linux/msi.h:230:9: error: unknown type name 'msi_alloc_info_t'; did you mean 'sg_alloc_fn'?
sg_alloc_fn
include/linux/msi.h:239:12: error: unknown type name 'msi_alloc_info_t'; did you mean 'sg_alloc_fn'?
sg_alloc_fn
include/linux/msi.h:240:22: error: unknown type name 'msi_alloc_info_t'; did you mean 'sg_alloc_fn'?
void (*msi_finish)(msi_alloc_info_t *arg, int retval);
sg_alloc_fn
include/linux/msi.h:241:20: error: unknown type name 'msi_alloc_info_t'; did you mean 'sg_alloc_fn'?
void (*set_desc)(msi_alloc_info_t *arg,
sg_alloc_fn
include/linux/msi.h:316:18: error: unknown type name 'msi_alloc_info_t'; did you mean 'sg_alloc_fn'?
int nvec, msi_alloc_info_t *args);
sg_alloc_fn
include/linux/msi.h:318:29: error: unknown type name 'msi_alloc_info_t'; did you mean 'sg_alloc_fn'?
int virq, int nvec, msi_alloc_info_t *args);
sg_alloc_fn
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com>
[ Upstream commit 6f57ed681ed817a4ec444e83f3aa2ad695d5ef34 ]
Code that was added to force gcc not to inline any function that isn't
explicitly declared as inline uncovered that init_tick_ops() isn't
marked as "__init". It is only called by __init functions and more
importantly it too calls an __init function which would require it to be
__init as well.
Link: http://lkml.kernel.org/r/201806060444.hdHcKOBy%fengguang.wu@intel.com
Reported-by: kbuild test robot <lkp@intel.com>
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
[ Upstream commit d13864b68e41c11e4231de90cf358658f6ecea45 ]
This avoids a lot of -Wunused warnings such as:
kernel/debug/debug_core.c: In function ‘kgdb_cpu_enter’:
./arch/sparc/include/asm/cmpxchg_64.h:55:22: warning: value computed is not used [-Wunused-value]
#define xchg(ptr,x) ((__typeof__(*(ptr)))__xchg((unsigned long)(x),(ptr),sizeof(*(ptr))))
./arch/sparc/include/asm/atomic_64.h:86:30: note: in expansion of macro ‘xchg’
#define atomic_xchg(v, new) (xchg(&((v)->counter), new))
kernel/debug/debug_core.c:508:4: note: in expansion of macro ‘atomic_xchg’
atomic_xchg(&kgdb_active, cpu);
[ Upstream commit 173a3efd3edb2ef6ef07471397c5f542a360e9c1 ]
Looking at functions with large stack frames across all architectures
led me discovering that BUG() suffers from the same problem as
fortify_panic(), which I've added a workaround for already.
In short, variables that go out of scope by calling a noreturn function
or __builtin_unreachable() keep using stack space in functions
afterwards.
A workaround that was identified is to insert an empty assembler
statement just before calling the function that doesn't return. I'm
adding a macro "barrier_before_unreachable()" to document this, and
insert calls to that in all instances of BUG() that currently suffer
from this problem.
The files that saw the largest change from this had these frame sizes
before, and much less with my patch:
fs/ext4/inode.c:82:1: warning: the frame size of 1672 bytes is larger than 800 bytes [-Wframe-larger-than=]
fs/ext4/namei.c:434:1: warning: the frame size of 904 bytes is larger than 800 bytes [-Wframe-larger-than=]
fs/ext4/super.c:2279:1: warning: the frame size of 1160 bytes is larger than 800 bytes [-Wframe-larger-than=]
fs/ext4/xattr.c:146:1: warning: the frame size of 1168 bytes is larger than 800 bytes [-Wframe-larger-than=]
fs/f2fs/inode.c:152:1: warning: the frame size of 1424 bytes is larger than 800 bytes [-Wframe-larger-than=]
net/netfilter/ipvs/ip_vs_core.c:1195:1: warning: the frame size of 1068 bytes is larger than 800 bytes [-Wframe-larger-than=]
net/netfilter/ipvs/ip_vs_core.c:395:1: warning: the frame size of 1084 bytes is larger than 800 bytes [-Wframe-larger-than=]
net/netfilter/ipvs/ip_vs_ftp.c:298:1: warning: the frame size of 928 bytes is larger than 800 bytes [-Wframe-larger-than=]
net/netfilter/ipvs/ip_vs_ftp.c:418:1: warning: the frame size of 908 bytes is larger than 800 bytes [-Wframe-larger-than=]
net/netfilter/ipvs/ip_vs_lblcr.c:718:1: warning: the frame size of 960 bytes is larger than 800 bytes [-Wframe-larger-than=]
drivers/net/xen-netback/netback.c:1500:1: warning: the frame size of 1088 bytes is larger than 800 bytes [-Wframe-larger-than=]
In case of ARC and CRIS, it turns out that the BUG() implementation
actually does return (or at least the compiler thinks it does),
resulting in lots of warnings about uninitialized variable use and
leaving noreturn functions, such as:
block/cfq-iosched.c: In function 'cfq_async_queue_prio':
block/cfq-iosched.c:3804:1: error: control reaches end of non-void function [-Werror=return-type]
include/linux/dmaengine.h: In function 'dma_maxpq':
include/linux/dmaengine.h:1123:1: error: control reaches end of non-void function [-Werror=return-type]
This makes them call __builtin_trap() instead, which should normally
dump the stack and kill the current process, like some of the other
architectures already do.
I tried adding barrier_before_unreachable() to panic() and
fortify_panic() as well, but that had very little effect, so I'm not
submitting that patch.
Vineet said:
: For ARC, it is double win.
: 1. Fixes 3 -Wreturn-type warnings
: | ../net/core/ethtool.c:311:1: warning: control reaches end of non-void function
: [-Wreturn-type]
: | ../kernel/sched/core.c:3246:1: warning: control reaches end of non-void function
: [-Wreturn-type]
: | ../include/linux/sunrpc/svc_xprt.h:180:1: warning: control reaches end of
: non-void function [-Wreturn-type]
: 2. bloat-o-meter reports code size improvements as gcc elides the
: generated code for stack return.
Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=82365
Link: http://lkml.kernel.org/r/20171219114112.939391-1-arnd@arndb.de
Acked-by: Vineet Gupta <vgupta@synopsys.com> [arch/arc]
Tested-by: Vineet Gupta <vgupta@synopsys.com> [arch/arc]
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Christopher Li <sparse@chrisli.org>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: "Steven Rostedt (VMware)" <rostedt@goodmis.org>
Cc: Mark Rutland <mark.rutland@arm.com>
[ Upstream commit 00ad691ab140b54ab9f5de5e74cb994f552e8124 ]
Never directly free @dev after calling device_register(), even
if it returned an error. Always use put_device() to give up the
reference initialized.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
[ Upstream commit a8e654f01cb725d0bfd741ebca1bf4c9337969cc ]
It's required to avoid losing dirty and accessed bits.
[akpm@linux-foundation.org: add a `do' to the do-while loop]
Link: http://lkml.kernel.org/r/20171213105756.69879-9-kirill.shutemov@linux.intel.com
Signed-off-by: Nitin Gupta <nitin.m.gupta@oracle.com>
Cc: Michal Hocko <mhocko@kernel.org>
commit 75f296d93bcebcfe375884ddac79e30263a31766 upstream.
Convert all allocations that used a NOTRACK flag to stop using it.
Link: http://lkml.kernel.org/r/20171007030159.22241-3-alexander.levin@verizon.com
Cc: Alexander Potapenko <glider@google.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Tim Hansen <devtimhansen@gmail.com>
Cc: Vegard Nossum <vegardno@ifi.uio.no>
commit a208fa8f33031b9e0aba44c7d1b7e68eb0cbd29e upstream.
We need to consistently enforce that keyed hashes cannot be used without
setting the key. To do this we need a reliable way to determine whether
a given hash algorithm is keyed or not. AF_ALG currently does this by
checking for the presence of a ->setkey() method. However, this is
actually slightly broken because the CRC-32 algorithms implement
->setkey() but can also be used without a key. (The CRC-32 "key" is not
actually a cryptographic key but rather represents the initial state.
If not overridden, then a default initial state is used.)
Prepare to fix this by introducing a flag CRYPTO_ALG_OPTIONAL_KEY which
indicates that the algorithm has a ->setkey() method, but it is not
required to be called. Then set it on all the CRC-32 algorithms.
The same also applies to the Adler-32 implementation in Lustre.
Also, the cryptd and mcryptd templates have to pass through the flag
from their underlying algorithm.
[ Upstream commit 59585b4be9ae4dc6506551709bdcd6f5210b8a01 ]
Commit v4.12-rc4-1-g9289ea7f952b introduced a mistake that made the
64-bit hweight stub call the 16-bit hweight function.
Fixes: 9289ea7f952b ("sparc64: Use indirect calls in hamming weight stubs")
Signed-off-by: Jan Engelhardt <jengelh@inai.de>
commit d15155824c5014803d91b829736d249c500bdda6 upstream.
linux/compiler.h is included indirectly by linux/types.h via
uapi/linux/types.h -> uapi/linux/posix_types.h -> linux/stddef.h
-> uapi/linux/stddef.h and is needed to provide a proper definition of
offsetof.
Unfortunately, compiler.h requires a definition of
smp_read_barrier_depends() for defining lockless_dereference() and soon
for defining READ_ONCE(), which means that all
users of READ_ONCE() will need to include asm/barrier.h to avoid splats
such as:
In file included from include/uapi/linux/stddef.h:1:0,
from include/linux/stddef.h:4,
from arch/h8300/kernel/asm-offsets.c:11:
include/linux/list.h: In function 'list_empty':
>> include/linux/compiler.h:343:2: error: implicit declaration of function 'smp_read_barrier_depends' [-Werror=implicit-function-declaration]
smp_read_barrier_depends(); /* Enforce dependency ordering from x */ \
A better alternative is to include asm/barrier.h in linux/compiler.h,
but this requires a type definition for "bool" on some architectures
(e.g. x86), which is defined later by linux/types.h. Type "bool" is also
used directly in linux/compiler.h, so the whole thing is pretty fragile.
This patch splits compiler.h in two: compiler_types.h contains type
annotations, definitions and the compiler-specific parts, whereas
compiler.h #includes compiler-types.h and additionally defines macros
such as {READ,WRITE.ACCESS}_ONCE().
uapi/linux/stddef.h and linux/linkage.h are then moved over to include
linux/compiler_types.h, which fixes the build for h8 and blackfin.
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/1508840570-22169-2-git-send-email-will.deacon@arm.com
[ Upstream commit 07aee94394547721ac168cbf4e1c09c14a5fe671 ]
When LD_ABS/IND is used in the program, and we have a BPF helper
call that changes packet data (bpf_helper_changes_pkt_data() returns
true), then in case of sparc JIT, we try to reload cached skb data
from bpf2sparc[BPF_REG_6]. However, there is no such guarantee or
assumption that skb sits in R6 at this point, all helpers changing
skb data only have a guarantee that skb sits in R1. Therefore,
store BPF R1 in L7 temporarily and after procedure call use L7 to
reload cached skb data. skb sitting in R6 is only true at the time
when LD_ABS/IND is executed.
Fixes: 7a12b5031c6b ("sparc64: Add eBPF JIT.")
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Alexei Starovoitov <ast@kernel.org>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
commit 4d2dc2cc766c3b51929658cacbc6e34fc8e242fb upstream.
Currently, we're capping the values too low in the F_GETLK64 case. The
fields in that structure are 64-bit values, so we shouldn't need to do
any sort of fixup there.
Make sure we check that assumption at build time in the future however
by ensuring that the sizes we're copying will fit.
With this, we no longer need COMPAT_LOFF_T_MAX either, so remove it.
Fixes: 94073ad77fff2 (fs/locks: don't mess with the address limit in compat_fcntl64)
Reported-by: Vitaly Lipatov <lav@etersoft.ru>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Reviewed-by: David Howells <dhowells@redhat.com>
[ Upstream commit 2a20aa171071a334d80c4e5d5af719d8374702fc ]
Without deferred struct page feature (CONFIG_DEFERRED_STRUCT_PAGE_INIT),
flags and other fields in "struct page"es are never changed prior to
first initializing struct pages by going through __init_single_page().
With deferred struct page feature enabled there is a case where we set
some fields prior to initializing:
mem_init() {
register_page_bootmem_info();
free_all_bootmem();
When register_page_bootmem_info() is called only non-deferred struct
pages are initialized. But, this function goes through some reserved
pages which might be part of the deferred, and thus are not yet
initialized.
mem_init
register_page_bootmem_info_node
get_page_bootmem
.. setting fields here ..
such as: page->freelist = (void *)type;
free_all_bootmem()
free_low_memory_core_early()
for_each_reserved_mem_region()
reserve_bootmem_region()
init_reserved_page() <- Only if this is deferred reserved page
__init_single_pfn()
memset(0) <-- Loose the set fields here
We end up with similar issue as in the previous patch, where currently
we do not observe problem as memory is zeroed. But, if flag asserts are
changed we can start hitting issues.
Also, because in this patch series we will stop zeroing struct page
memory during allocation, we must make sure that struct pages are
properly initialized prior to using them.
The deferred-reserved pages are initialized in free_all_bootmem().
Therefore, the fix is to switch the above calls.
Link: http://lkml.kernel.org/r/20171013173214.27300-4-pasha.tatashin@oracle.com
Signed-off-by: Pavel Tatashin <pasha.tatashin@oracle.com>
Reviewed-by: Steven Sistare <steven.sistare@oracle.com>
Reviewed-by: Daniel Jordan <daniel.m.jordan@oracle.com>
Reviewed-by: Bob Picco <bob.picco@oracle.com>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Matthew Wilcox <willy@infradead.org>
Cc: Mel Gorman <mgorman@techsingularity.net>
[ Upstream commit 70f3c8b7c2e7ebcdde8354da004872e7c9184e97 ]
For a PUD hugepage entry, we need to propagate bits [32:22]
from virtual address to resolve at 4M granularity. However,
the current code was incorrectly propagating bits [29:19].
This bug can cause incorrect data to be returned for pages
backed with 16G hugepages.
Reported-by: Al Viro <viro@ZenIV.linux.org.uk>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
commit 01c3f0a42a2a0ff0c3fed80a1a25f2641ae72554 upstream.
Fix the following build errors.
In file included from arch/sparc/include/asm/mmu_context.h:4:0,
from include/linux/mmu_context.h:4,
from drivers/gpu/drm/amd/amdgpu/amdgpu_amdkfd.h:29,
from drivers/gpu/drm/amd/amdgpu/amdgpu_amdkfd.c:23:
arch/sparc/include/asm/mmu_context_64.h:22:37: error:
unknown type name 'per_cpu_secondary_mm'
arch/sparc/include/asm/mmu_context_64.h: In function 'switch_mm':
arch/sparc/include/asm/mmu_context_64.h:79:2: error:
implicit declaration of function 'smp_processor_id'
Fixes: 70539bd79500 ("drm/amd: Update MEC HQD loading code for KFD")
Acked-by: Oded Gabbay <oded.gabbay@gmail.com>
commit 23198ddffb6cddb5d5824230af4dd4b46e4046a4 upstream.
This fixes the build with i40e driver enabled.
Reported-by: Guenter Roeck <linux@roeck-us.net>
license
Many user space API headers are missing licensing information, which
makes it hard for compliance tools to determine the correct license.
By default are files without license information under the default
license of the kernel, which is GPLV2. Marking them GPLV2 would exclude
them from being included in non GPLV2 code, which is obviously not
intended. The user space API headers fall under the syscall exception
which is in the kernels COPYING file:
NOTE! This copyright does *not* cover user programs that use kernel
services by normal system calls - this is merely considered normal use
of the kernel, and does *not* fall under the heading of "derived work".
otherwise syscall usage would not be possible.
Update the files which contain no license information with an SPDX
license identifier. The chosen identifier is 'GPL-2.0 WITH
Linux-syscall-note' which is the officially assigned identifier for the
Linux syscall exception. SPDX license identifiers are a legally binding
Philippe Ombredanne. See the previous patch in this series for the
methodology of how this patch was researched.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
The new flag PCI_DEV_FLAGS_NO_RELAXED_ORDERING has been added
to indicate that Relaxed Ordering Attributes (RO) should not
be used for Transaction Layer Packets (TLP) targeted toward
these affected Root Port, it will clear the bit4 in the PCIe
Device Control register, so the PCIe device drivers could
query PCIe configuration space to determine if it can send
TLPs to Root Port with the Relaxed Ordering Attributes set.
With this new flag we don't need the config ARCH_WANT_RELAX_ORDER
to control the Relaxed Ordering Attributes for the ixgbe drivers
just like the commit 1a8b6d76dc5b ("net:add one common config...") did,
so revert this commit.
Signed-off-by: Ding Tianhong <dingtianhong@huawei.com>
Tested-by: Andrew Bowers <andrewx.bowers@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull namespace updates from Eric Biederman:
"Life has been busy and I have not gotten half as much done this round
as I would have liked. I delayed it so that a minor conflict
resolution with the mips tree could spend a little time in linux-next
before I sent this pull request.
This includes two long delayed user namespace changes from Kirill
Tkhai. It also includes a very useful change from Serge Hallyn that
allows the security capability attribute to be used inside of user
namespaces. The practical effect of this is people can now untar
tarballs and install rpms in user namespaces. It had been suggested to
generalize this and encode some of the namespace information
information in the xattr name. Upon close inspection that makes the
things that should be hard easy and the things that should be easy
more expensive.
Then there is my bugfix/cleanup for signal injection that removes the
magic encoding of the siginfo union member from the kernel internal
si_code. The mips folks reported the case where I had used FPE_FIXME
me is impossible so I have remove FPE_FIXME from mips, while at the
same time including a return statement in that case to keep gcc from
complaining about unitialized variables.
I almost finished the work to get make copy_siginfo_to_user a trivial
copy to user. The code is available at:
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace.git neuter-copy_siginfo_to_user-v3
But I did not have time/energy to get the code posted and reviewed
before the merge window opened.
I was able to see that the security excuse for just copying fields
that we know are initialized doesn't work in practice there are buggy
initializations that don't initialize the proper fields in siginfo. So
we still sometimes copy unitialized data to userspace"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace:
Introduce v3 namespaced file capabilities
mips/signal: In force_fcr31_sig return in the impossible case
signal: Remove kernel interal si_code magic
fcntl: Don't use ambiguous SIG_POLL si_codes
prctl: Allow local CAP_SYS_ADMIN changing exe_file
security: Use user_namespace::level to avoid redundant iterations in cap_capable()
userns,pidns: Verify the userns for new pid namespaces
signal/testing: Don't look for __SI_FAULT in userspace
signal/mips: Document a conflict with SI_USER with SIGFPE
signal/sparc: Document a conflict with SI_USER with SIGFPE
signal/ia64: Document a conflict with SI_USER with SIGFPE
signal/alpha: Document a conflict with SI_USER for SIGTRAP
Pull sparc updates from David Miller:
1) Use register window state adjustment instructions when available,
from Anthony Yznaga.
2) Add VCC console concentrator driver, from Jag Raman.
3) Add 16GB hugepage support, from Nitin Gupta.
4) Support cpu 'poke' hypercall, from Vijay Kumar.
5) Add M7/M8 optimized memcpy/memset/copy_{to,from}_user, from Babu
Moger.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-next: (33 commits)
sparc64: Handle additional cases of no fault loads
sparc64: speed up etrap/rtrap on NG2 and later processors
sparc64: vcc: make ktermios const
sparc: leon: grpci1: constify of_device_id
sparc: leon: grpci2: constify of_device_id
sparc64: vcc: Check for IS_ERR() instead of NULL
sparc64: Cleanup hugepage table walk functions
sparc64: Add 16GB hugepage support
sparc64: Support huge PUD case in get_user_pages
sparc64: vcc: Add install & cleanup TTY operations
sparc64: vcc: Add break_ctl TTY operation
sparc64: vcc: Add chars_in_buffer TTY operation
sparc64: vcc: Add write & write_room TTY operations
sparc64: vcc: Add hangup TTY operation
sparc64: vcc: Add open & close TTY operations
sparc64: vcc: Enable LDC event processing engine
sparc64: vcc: Add RX & TX timer for delayed LDC operation
sparc64: vcc: Create sysfs attribute group
sparc64: vcc: Enable VCC port probe and removal
sparc64: vcc: TTY driver initialization and cleanup
Load instructions using ASI_PNF or other no-fault ASIs should not
cause a SIGSEGV or SIGBUS.
A garden variety unmapped address follows the TSB miss path, and when
no valid mapping is found in the process page tables, the miss handler
checks to see if the access was via a no-fault ASI. It then fixes up
the target register with a zero, and skips the no-fault load
instruction.
But different paths are taken for data access exceptions and alignment
traps, and these do not respect the no-fault ASI. We add checks in
these paths for the no-fault ASI, and fix up the target register and
TPC just like in the TSB miss case.
Signed-off-by: Rob Gardner <rob.gardner@oracle.com>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
For many sun4v processor types, reading or writing a privileged register
has a latency of 40 to 70 cycles. Use a combination of the low-latency
allclean, otherw, normalw, and nop instructions in etrap and rtrap to
replace 2 rdpr and 5 wrpr instructions and improve etrap/rtrap
performance. allclean, otherw, and normalw are available on NG2 and
later processors.
The average ticks to execute the flush windows trap ("ta 0x3") with and
without this patch on select platforms:
CPU Not patched Patched % Latency Reduction
NG2 1762 1558 -11.58
NG4 3619 3204 -11.47
M7 3015 2624 -12.97
SPARC64-X 829 770 -7.12
Signed-off-by: Anthony Yznaga <anthony.yznaga@oracle.com>
Merge more updates from Andrew Morton:
- most of the rest of MM
- a small number of misc things
- lib/ updates
- checkpatch
- autofs updates
- ipc/ updates
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (126 commits)
ipc: optimize semget/shmget/msgget for lots of keys
ipc/sem: play nicer with large nsops allocations
ipc/sem: drop sem_checkid helper
ipc: convert kern_ipc_perm.refcount from atomic_t to refcount_t
ipc: convert sem_undo_list.refcnt from atomic_t to refcount_t
ipc: convert ipc_namespace.count from atomic_t to refcount_t
kcov: support compat processes
sh: defconfig: cleanup from old Kconfig options
mn10300: defconfig: cleanup from old Kconfig options
m32r: defconfig: cleanup from old Kconfig options
drivers/pps: use surrounding "if PPS" to remove numerous dependency checks
drivers/pps: aesthetic tweaks to PPS-related content
cpumask: make cpumask_next() out-of-line
kmod: move #ifdef CONFIG_MODULES wrapper to Makefile
kmod: split off umh headers into its own file
MAINTAINERS: clarify kmod is just a kernel module loader
kmod: split out umh code into its own file
test_kmod: flip INT checks to be consistent
test_kmod: remove paranoid UINT_MAX check on uint range processing
vfat: deduplicate hex2bin()
Patch series "Define CPU_BIG_ENDIAN or warn for inconsistencies", v3.
While working on enabling queued rwlock on SPARC, found this following
code in include/asm-generic/qrwlock.h which uses CONFIG_CPU_BIG_ENDIAN to
clear a byte.
static inline u8 *__qrwlock_write_byte(struct qrwlock *lock)
return (u8 *)lock + 3 * IS_BUILTIN(CONFIG_CPU_BIG_ENDIAN);
Problem is many of the fixed big endian architectures don't define
CPU_BIG_ENDIAN and clears the wrong byte.
Define CPU_BIG_ENDIAN for all the fixed big endian architecture to fix it.
Also found few more references of this config parameter in
drivers/of/base.c
drivers/of/fdt.c
drivers/tty/serial/earlycon.c
drivers/tty/serial/serial_core.c
Be aware that this may cause regressions if someone has worked-around
problems in the above code already. Remove the work-around.
Here is our original discussion
https://lkml.org/lkml/2017/5/24/620
Link: http://lkml.kernel.org/r/1499358861-179979-2-git-send-email-babu.moger@oracle.com
Signed-off-by: Babu Moger <babu.moger@oracle.com>
Suggested-by: Arnd Bergmann <arnd@arndb.de>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Stafford Horne <shorne@gmail.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Jonas Bonn <jonas@southpole.se>
Cc: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Helge Deller <deller@gmx.de>
Cc: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Cc: Max Filippov <jcmvbkbc@gmail.com>
Cc: Greg KH <gregkh@linuxfoundation.org>
Where possible, call memset16(), memmove() or memcpy() instead of using
open-coded loops. I don't like the calling convention that uses a byte
count instead of a count of u16s, but it's a little late to change that.
Reduces code size of fbcon.o by almost 400 bytes on my laptop build.
[akpm@linux-foundation.org: fix build]
Link: http://lkml.kernel.org/r/20170720184539.31609-9-willy@infradead.org
Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com>
Cc: "James E.J. Bottomley" <jejb@linux.vnet.ibm.com>
Cc: "Martin K. Petersen" <martin.petersen@oracle.com>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Russell King <rmk+kernel@armlinux.org.uk>
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
- add enhanced Downstream Port Containment support, which prints more
details about Root Port Programmed I/O errors (Dongdong Liu)
- add Layerscape ls1088a and ls2088a support (Hou Zhiqiang)
- add MediaTek MT2712 and MT7622 support (Ryder Lee)
- add MediaTek MT2712 and MT7622 MSI support (Honghui Zhang)
- add Qualcom IPQ8074 support (Varadarajan Narayanan)
- add R-Car r8a7743/5 device tree support (Biju Das)
- add Rockchip per-lane PHY support for better power management (Shawn
Lin)
- fix IRQ mapping for hot-added devices by replacing the
pci_fixup_irqs() boot-time design with a host bridge hook called at
probe-time (Lorenzo Pieralisi, Matthew Minter)
- fix race when enabling two devices that results in upstream bridge
not being enabled correctly (Srinath Mannam)
- fix pciehp power fault infinite loop (Keith Busch)
- fix SHPC bridge MSI hotplug events by enabling bus mastering
(Aleksandr Bezzubikov)
- fix a VFIO issue by correcting PCIe capability sizes (Alex
Williamson)
- fix an INTD issue on Xilinx and possibly other drivers by unifying
INTx IRQ domain support (Paul Burton)
- avoid IOMMU stalls by marking AMD Stoney GPU ATS as broken (Joerg
Roedel)
- allow APM X-Gene device assignment to guests by adding an ACS quirk
(Feng Kan)
- fix driver crashes by disabling Extended Tags on Broadcom HT2100
(Extended Tags support is required for PCIe Receivers but not
Requesters, and we now enable them by default when Requesters support
them) (Sinan Kaya)
- fix MSIs for devices that use phantom RIDs for DMA by assuming MSIs
use the real Requester ID (not a phantom RID) (Robin Murphy)
- prevent assignment of Intel VMD children to guests (which may be
supported eventually, but isn't yet) by not associating an IOMMU with
them (Jon Derrick)
- fix Intel VMD suspend/resume by releasing IRQs on suspend (Scott
Bauer)
- fix a Function-Level Reset issue with Intel 750 NVMe by waiting
longer (up to 60sec instead of 1sec) for device to become ready
(Sinan Kaya)
- fix a Function-Level Reset issue on iProc Stingray by working around
hardware defects in the CRS implementation (Oza Pawandeep)
- fix an issue with Intel NVMe P3700 after an iProc reset by adding a
delay during shutdown (Oza Pawandeep)
- fix a Microsoft Hyper-V lockdep issue by polling instead of blocking
in compose_msi_msg() (Stephen Hemminger)
- fix a wireless LAN driver timeout by clearing DesignWare MSI
interrupt status after it is handled, not before (Faiz Abbas)
- fix DesignWare ATU enable checking (Jisheng Zhang)
- reduce Layerscape dependencies on the bootloader by doing more
initialization in the driver (Hou Zhiqiang)
- improve Intel VMD performance allowing allocation of more IRQ vectors
than present CPUs (Keith Busch)
- improve endpoint framework support for initial DMA mask, different
BAR sizes, configurable page sizes, MSI, test driver, etc (Kishon
Vijay Abraham I, Stan Drozd)
- rework CRS support to add periodic messages while we poll during
enumeration and after Function-Level Reset and prepare for possible
other uses of CRS (Sinan Kaya)
- clean up Root Port AER handling by removing unnecessary code and
moving error handler methods to struct pcie_port_service_driver
(Christoph Hellwig)
- clean up error handling paths in various drivers (Bjorn Andersson,
Fabio Estevam, Gustavo A. R. Silva, Harunobu Kurokawa, Jeffy Chen,
Lorenzo Pieralisi, Sergei Shtylyov)
- clean up SR-IOV resource handling by disabling VF decoding before
updating the corresponding resource structs (Gavin Shan)
- clean up DesignWare-based drivers by unifying quirks to update Class
Code and Interrupt Pin and related handling of write-protected
registers (Hou Zhiqiang)
- clean up by adding empty generic pcibios_align_resource() and
pcibios_fixup_bus() and removing empty arch-specific implementations
(Palmer Dabbelt)
- request exclusive reset control for several drivers to allow cleanup
elsewhere (Philipp Zabel)
- constify various structures (Arvind Yadav, Bhumika Goyal)
- convert from full_name() to %pOF (Rob Herring)
- remove unused variables from iProc, HiSi, Altera, Keystone (Shawn
Lin)
* tag 'pci-v4.14-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (170 commits)
PCI: xgene: Clean up whitespace
PCI: xgene: Define XGENE_PCI_EXP_CAP and use generic PCI_EXP_RTCTL offset
PCI: xgene: Fix platform_get_irq() error handling
PCI: xilinx-nwl: Fix platform_get_irq() error handling
PCI: rockchip: Fix platform_get_irq() error handling
PCI: altera: Fix platform_get_irq() error handling
PCI: spear13xx: Fix platform_get_irq() error handling
PCI: artpec6: Fix platform_get_irq() error handling
PCI: armada8k: Fix platform_get_irq() error handling
PCI: dra7xx: Fix platform_get_irq() error handling
PCI: exynos: Fix platform_get_irq() error handling
PCI: iproc: Clean up whitespace
PCI: iproc: Rename PCI_EXP_CAP to IPROC_PCI_EXP_CAP
PCI: iproc: Add 500ms delay during device shutdown
PCI: Fix typos and whitespace errors
PCI: Remove unused "res" variable from pci_resource_io()
PCI: Correct kernel-doc of pci_vpd_srdt_size(), pci_vpd_srdt_tag()
PCI/AER: Reformat AER register definitions
iommu/vt-d: Prevent VMD child devices from being remapping targets
x86/PCI: Use is_vmd() rather than relying on the domain number
* pci/resource:
microblaze/PCI: Remove pcibios_setup_bus_{self/devices} dead code
ARC: Remove empty kernel/pcibios.c
PCI: Add a generic weak pcibios_align_resource()
PCI: Add a generic weak pcibios_fixup_bus()
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6
Pull crypto updates from Herbert Xu:
"Here is the crypto update for 4.14:
API:
- Defer scompress scratch buffer allocation to first use.
- Add __crypto_xor that takes separte src and dst operands.
- Add ahash multiple registration interface.
- Revamped aead/skcipher algif code to fix async IO properly.
Drivers:
- Add non-SIMD fallback code path on ARM for SVE.
- Add AMD Security Processor framework for ccp.
- Add support for RSA in ccp.
- Add XTS-AES-256 support for CCP version 5.
- Add support for PRNG in sun4i-ss.
- Add support for DPAA2 in caam.
- Add ARTPEC crypto support.
- Add Freescale RNGC hwrng support.
- Add Microchip / Atmel ECC driver.
- Add support for STM32 HASH module"
* 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (116 commits)
crypto: af_alg - get_page upon reassignment to TX SGL
crypto: cavium/nitrox - Fix an error handling path in 'nitrox_probe()'
crypto: inside-secure - fix an error handling path in safexcel_probe()
crypto: rockchip - Don't dequeue the request when device is busy
crypto: cavium - add release_firmware to all return case
crypto: sahara - constify platform_device_id
MAINTAINERS: Add ARTPEC crypto maintainer
crypto: axis - add ARTPEC-6/7 crypto accelerator driver
crypto: hash - add crypto_(un)register_ahashes()
dt-bindings: crypto: add ARTPEC crypto
crypto: algif_aead - fix comment regarding memory layout
crypto: ccp - use dma_mapping_error to check map error
lib/mpi: fix build with clang
crypto: sahara - Remove leftover from previous used spinlock
crypto: sahara - Fix dma unmap direction
crypto: af_alg - consolidation of duplicate code
crypto: caam - Remove unused dentry members
crypto: ccp - select CONFIG_CRYPTO_RSA
crypto: ccp - avoid uninitialized variable warning
crypto: serpent - improve __serpent_setkey with UBSAN
Pull networking updates from David Miller:
1) Support ipv6 checksum offload in sunvnet driver, from Shannon
Nelson.
2) Move to RB-tree instead of custom AVL code in inetpeer, from Eric
Dumazet.
3) Allow generic XDP to work on virtual devices, from John Fastabend.
4) Add bpf device maps and XDP_REDIRECT, which can be used to build
arbitrary switching frameworks using XDP. From John Fastabend.
5) Remove UFO offloads from the tree, gave us little other than bugs.
6) Remove the IPSEC flow cache, from Florian Westphal.
7) Support ipv6 route offload in mlxsw driver.
8) Support VF representors in bnxt_en, from Sathya Perla.
9) Add support for forward error correction modes to ethtool, from
Vidya Sagar Ravipati.
10) Add time filter for packet scheduler action dumping, from Jamal Hadi
Salim.
11) Extend the zerocopy sendmsg() used by virtio and tap to regular
sockets via MSG_ZEROCOPY. From Willem de Bruijn.
12) Significantly rework value tracking in the BPF verifier, from Edward
Cree.
13) Add new jump instructions to eBPF, from Daniel Borkmann.
14) Rework rtnetlink plumbing so that operations can be run without
taking the RTNL semaphore. From Florian Westphal.
15) Support XDP in tap driver, from Jason Wang.
16) Add 32-bit eBPF JIT for ARM, from Shubham Bansal.
17) Add Huawei hinic ethernet driver.
18) Allow to report MD5 keys in TCP inet_diag dumps, from Ivan
Delalande.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1780 commits)
i40e: point wb_desc at the nvm_wb_desc during i40e_read_nvm_aq
i40e: avoid NVM acquire deadlock during NVM update
drivers: net: xgene: Remove return statement from void function
drivers: net: xgene: Configure tx/rx delay for ACPI
drivers: net: xgene: Read tx/rx delay for ACPI
rocker: fix kcalloc parameter order
rds: Fix non-atomic operation on shared flag variable
net: sched: don't use GFP_KERNEL under spin lock
vhost_net: correctly check tx avail during rx busy polling
net: mdio-mux: add mdio_mux parameter to mdio_mux_init()
rxrpc: Make service connection lookup always check for retry
net: stmmac: Delete dead code for MDIO registration
gianfar: Fix Tx flow control deactivation
cxgb4: Ignore MPS_TX_INT_CAUSE[Bubble] for T6
cxgb4: Fix pause frame count in t4_get_port_stats
cxgb4: fix memory leak
tun: rename generic_xdp to skb_xdp
tun: reserve extra headroom only when XDP is set
net: dsa: bcm_sf2: Configure IMP port TC2QOS mapping
net: dsa: bcm_sf2: Advertise number of egress queues
Pull locking updates from Ingo Molnar:
- Add 'cross-release' support to lockdep, which allows APIs like
completions, where it's not the 'owner' who releases the lock, to be
tracked. It's all activated automatically under
CONFIG_PROVE_LOCKING=y.
- Clean up (restructure) the x86 atomics op implementation to be more
readable, in preparation of KASAN annotations. (Dmitry Vyukov)
- Fix static keys (Paolo Bonzini)
- Add killable versions of down_read() et al (Kirill Tkhai)
- Rework and fix jump_label locking (Marc Zyngier, Paolo Bonzini)
- Rework (and fix) tlb_flush_pending() barriers (Peter Zijlstra)
- Remove smp_mb__before_spinlock() and convert its usages, introduce
smp_mb__after_spinlock() (Peter Zijlstra)
* 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (56 commits)
locking/lockdep/selftests: Fix mixed read-write ABBA tests
sched/completion: Avoid unnecessary stack allocation for COMPLETION_INITIALIZER_ONSTACK()
acpi/nfit: Fix COMPLETION_INITIALIZER_ONSTACK() abuse
locking/pvqspinlock: Relax cmpxchg's to improve performance on some architectures
smp: Avoid using two cache lines for struct call_single_data
locking/lockdep: Untangle xhlock history save/restore from task independence
locking/refcounts, x86/asm: Disable CONFIG_ARCH_HAS_REFCOUNT for the time being
futex: Remove duplicated code and fix undefined behaviour
Documentation/locking/atomic: Finish the document...
locking/lockdep: Fix workqueue crossrelease annotation
workqueue/lockdep: 'Fix' flush_work() annotation
locking/lockdep/selftests: Add mixed read-write ABBA tests
mm, locking/barriers: Clarify tlb_flush_pending() barriers
locking/lockdep: Make CONFIG_LOCKDEP_CROSSRELEASE and CONFIG_LOCKDEP_COMPLETIONS truly non-interactive
locking/lockdep: Explicitly initialize wq_barrier::done::map
locking/lockdep: Rename CONFIG_LOCKDEP_COMPLETE to CONFIG_LOCKDEP_COMPLETIONS
locking/lockdep: Reword title of LOCKDEP_CROSSRELEASE config
locking/lockdep: Make CONFIG_LOCKDEP_CROSSRELEASE part of CONFIG_PROVE_LOCKING
locking/refcounts, x86/asm: Implement fast refcount overflow protection
locking/lockdep: Fix the rollback and overwrite detection logic in crossrelease
Pull RCU updates from Ingo Molnad:
"The main RCU related changes in this cycle were:
- Removal of spin_unlock_wait()
- SRCU updates
- RCU torture-test updates
- RCU Documentation updates
- Extend the sys_membarrier() ABI with the MEMBARRIER_CMD_PRIVATE_EXPEDITED variant
- Miscellaneous RCU fixes
- CPU-hotplug fixes"
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (63 commits)
arch: Remove spin_unlock_wait() arch-specific definitions
locking: Remove spin_unlock_wait() generic definitions
drivers/ata: Replace spin_unlock_wait() with lock/unlock pair
ipc: Replace spin_unlock_wait() with lock/unlock pair
exit: Replace spin_unlock_wait() with lock/unlock pair
completion: Replace spin_unlock_wait() with lock/unlock pair
doc: Set down RCU's scheduling-clock-interrupt needs
doc: No longer allowed to use rcu_dereference on non-pointers
doc: Add RCU files to docbook-generation files
doc: Update memory-barriers.txt for read-to-write dependencies
doc: Update RCU documentation
membarrier: Provide expedited private command
rcu: Remove exports from rcu_idle_exit() and rcu_idle_enter()
rcu: Add warning to rcu_idle_enter() for irqs enabled
rcu: Make rcu_idle_enter() rely on callers disabling irqs
rcu: Add assertions verifying blocked-tasks list
rcu/tracing: Set disable_rcu_irq_enter on rcu_eqs_exit()
rcu: Add TPS() protection for _rcu_barrier_trace strings
rcu: Use idle versions of swait to make idle-hack clear
swait: Add idle variants which don't contribute to load average
of_device_id are not supposed to change at runtime. All functions
working with of_device_id provided by <linux/of.h> work with const
of_device_ids. So mark the const and __initconst.
There is code duplicated over all architecture's headers for
futex_atomic_op_inuser. Namely op decoding, access_ok check for uaddr,
and comparison of the result.
Remove this duplication and leave up to the arches only the needed
assembly which is now in arch_futex_atomic_op_inuser.
This effectively distributes the Will Deacon's arm64 fix for undefined
behaviour reported by UBSAN to all architectures. The fix was done in
commit 5f16a046f8e1 (arm64: futex: Fix undefined behaviour with
FUTEX_OP_OPARG_SHIFT usage). Look there for an example dump.
And as suggested by Thomas, check for negative oparg too, because it was
also reported to cause undefined behaviour report.
Note that s390 removed access_ok check in d12a29703 ("s390/uaccess:
remove pointless access_ok() checks") as access_ok there returns true.
We introduce it back to the helper for the sake of simplicity (it gets
optimized away anyway).
Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> [s390]
Acked-by: Chris Metcalf <cmetcalf@mellanox.com> [for tile]
Reviewed-by: Darren Hart (VMware) <dvhart@infradead.org>
Reviewed-by: Will Deacon <will.deacon@arm.com> [core/arm64]
Cc: linux-mips@linux-mips.org
Cc: Rich Felker <dalias@libc.org>
Cc: linux-ia64@vger.kernel.org
Cc: linux-sh@vger.kernel.org
Cc: peterz@infradead.org
Cc: sparclinux@vger.kernel.org
Cc: linux-s390@vger.kernel.org
Cc: linux-hexagon@vger.kernel.org
Cc: linux-snps-arc@lists.infradead.org
Cc: linux-xtensa@linux-xtensa.org
Cc: openrisc@lists.librecores.org
Cc: Stafford Horne <shorne@gmail.com>
Cc: Chris Zankel <chris@zankel.net>
Cc: linux-parisc@vger.kernel.org
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: linux-alpha@vger.kernel.org
Cc: linuxppc-dev@lists.ozlabs.org
Link: http://lkml.kernel.org/r/20170824073105.3901-1-jslaby@suse.cz
When building the kernel for Sparc using gcc 7.x, the build fails
with:
arch/sparc/kernel/pcic.c: In function ‘pcibios_fixup_bus’:
arch/sparc/kernel/pcic.c:647:8: error: ‘cmd’ may be used uninitialized in this function [-Werror=maybe-uninitialized]
cmd |= PCI_COMMAND_IO;
The simplified code looks like this:
unsigned int cmd;
pcic_read_config(dev->bus, dev->devfn, PCI_COMMAND, 2, &cmd);
I.e, the code assumes that pcic_read_config() will always initialize
cmd. But it's not the case. Looking at pcic_read_config(), if
bus->number is != 0 or if the size is not one of 1, 2 or 4, *val will
not be initialized.
As a simple fix, we initialize cmd to zero at the beginning of
pcibios_fixup_bus.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu into core/rcu
Pull RCU updates from Paul E. McKenney:
- SRCU updates
- Torture-test updates
- Documentation updates
- Miscellaneous fixes
- CPU-hotplug fixes
- Miscellaneous non-RCU fixes
There is no agreed-upon definition of spin_unlock_wait()'s semantics,
and it appears that all callers could do just as well with a lock/unlock
pair. This commit therefore removes the underlying arch-specific
arch_spin_unlock_wait() for all architectures providing them.
Cc: <linux-arch@vger.kernel.org>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Andrea Parri <parri.andrea@gmail.com>
Acked-by: Will Deacon <will.deacon@arm.com>
Acked-by: Boqun Feng <boqun.feng@gmail.com>
There is no need to log message if ATU hvapi couldn't get register.
Unlike PCI hvapi, ATU hvapi registration failure is not hard error.
Even if ATU hvapi registration fails (on system with ATU or without
ATU) system continues with legacy IOMMU. So only log message when
ATU hvapi successfully get registered.
Signed-off-by: Tushar Dave <tushar.n.dave@oracle.com>
%g4 and %g5 are fixed registers used by the kernel for the thread
pointer and the per-cpu offset. Use %o4 and %g7 instead.
Diagnosis by Anthony Yznaga.
Fixes: 1b4af13ff2cc ("sparc64: Add __multi3 for gcc 7.x and later.")
Reported-by: Anatoly Pugachev <matorola@gmail.com>
Tested-by: Anatoly Pugachev <matorola@gmail.com>
Flatten out nested code structure in huge_pte_offset()
and huge_pte_alloc().
Adds support for 16GB hugepage size. To use this page size
use kernel parameters as:
default_hugepagesz=16G hugepagesz=16G hugepages=10
Testing:
Tested with the stream benchmark which allocates 48G of
arrays backed by 16G hugepages and does RW operation on
them in parallel.
Orabug: 25362942
Cc: Anthony Yznaga <anthony.yznaga@oracle.com>
get_user_pages() is used to do direct IO. It already
handles the case where the address range is backed
by PMD huge pages. This patch now adds the case where
the range could be backed by PUD huge pages.
