path: root/arch/sparc
2011-07-27sparc: Add T3 sun4v cpu type and hypervisor group defines.David S. Miller
2011-07-27sparc: Don't leave sparc_pmu_type NULL on sun4v.David S. Miller
Otherwise we'll crash in the sparc perf init code. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-27sparc: rename atomic_add_unlessStephen Rothwell
Should have been done in commit 1af08a1407f4 ("This is in preparation for more generic atomic"). Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Arun Sharma <asharma@fb.com> Cc: David Miller <davem@davemloft.net> Cc: "Hans-Christian Egtvedt" <hans-christian.egtvedt@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: cleanup asm-generic atomic*.h inclusionArun Sharma
After changing all consumers of atomics to include <linux/atomic.h>, we ran into some compile time errors due to this dependency chain: linux/atomic.h -> asm/atomic.h -> asm-generic/atomic-long.h where atomic-long.h could use funcs defined later in linux/atomic.h without a prototype. This patches moves the code that includes asm-generic/atomic*.h to linux/atomic.h. Archs that need <asm-generic/atomic64.h> need to select CONFIG_GENERIC_ATOMIC64 from now on (some of them used to include it unconditionally). Compile tested on i386 and x86_64 with allnoconfig. Signed-off-by: Arun Sharma <asharma@fb.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: move atomic_add_unless to generic codeArun Sharma
This is in preparation for more generic atomic primitives based on __atomic_add_unless. Signed-off-by: Arun Sharma <asharma@fb.com> Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26asm-generic: add another generic ext2 atomic bitopsAkinobu Mita
The majority of architectures implement ext2 atomic bitops as test_and_{set,clear}_bit() without spinlock. This adds this type of generic implementation in ext2-atomic-setbit.h and use it wherever possible. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Suggested-by: Andreas Dilger <adilger@dilger.ca> Suggested-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26ptrace: unify show_regs() prototypeMike Frysinger
[ poleg@redhat.com: no need to declare show_regs() in ptrace.h, sched.h does this ] Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25Merge 'akpm' patch seriesLinus Torvalds
* Merge akpm patch series: (122 commits) drivers/connector/cn_proc.c: remove unused local Documentation/SubmitChecklist: add RCU debug config options reiserfs: use hweight_long() reiserfs: use proper little-endian bitops pnpacpi: register disabled resources drivers/rtc/rtc-tegra.c: properly initialize spinlock drivers/rtc/rtc-twl.c: check return value of twl_rtc_write_u8() in twl_rtc_set_time() drivers/rtc: add support for Qualcomm PMIC8xxx RTC drivers/rtc/rtc-s3c.c: support clock gating drivers/rtc/rtc-mpc5121.c: add support for RTC on MPC5200 init: skip calibration delay if previously done misc/eeprom: add eeprom access driver for digsy_mtc board misc/eeprom: add driver for microwire 93xx46 EEPROMs checkpatch.pl: update $logFunctions checkpatch: make utf-8 test --strict checkpatch.pl: add ability to ignore various messages checkpatch: add a "prefer __aligned" check checkpatch: validate signature styles and To: and Cc: lines checkpatch: add __rcu as a sparse modifier checkpatch: suggest using min_t or max_t ... Did this as a merge because of (trivial) conflicts in - Documentation/feature-removal-schedule.txt - arch/xtensa/include/asm/uaccess.h that were just easier to fix up in the merge than in the patch series.
2011-07-25sparc64: implement get_user_pages_fast()David S. Miller
Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25sparc64: add support for _PAGE_SPECIALDavid S. Miller
Luckily there are still a few software PTE bits remaining and they even match up in both the sun4u and sun4v pte layouts. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25sparc64: use RCU page table freeingDavid S. Miller
Make use of the generic RCU page table freeing on Sparc64, doing so allows for race-free software page-table walkers like gup_fast(). Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25sparc64: kill page table quicklistsDavid S. Miller
With the recent mmu_gather changes that included generic RCU freeing of page-tables, it is now quite straightforward to implement gup_fast() on sparc64. This patch: Remove the page table quicklists. They are pointless and make it harder to use RCU page table freeing and share code with other architectures. BTW, this is the second time this has happened, see commit 3c936465249f ("[SPARC64]: Kill pgtable quicklists and use SLAB.") Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-07-24modules: make arch's use default loader hooksJonas Bonn
This patch removes all the module loader hook implementations in the architecture specific code where the functionality is the same as that now provided by the recently added default hooks. Signed-off-by: Jonas Bonn <jonas@southpole.se> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Tested-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-07-22Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (123 commits) perf: Remove the nmi parameter from the oprofile_perf backend x86, perf: Make copy_from_user_nmi() a library function perf: Remove perf_event_attr::type check x86, perf: P4 PMU - Fix typos in comments and style cleanup perf tools: Make test use the preset debugfs path perf tools: Add automated tests for events parsing perf tools: De-opt the parse_events function perf script: Fix display of IP address for non-callchain path perf tools: Fix endian conversion reading event attr from file header perf tools: Add missing 'node' alias to the hw_cache[] array perf probe: Support adding probes on offline kernel modules perf probe: Add probed module in front of function perf probe: Introduce debuginfo to encapsulate dwarf information perf-probe: Move dwarf library routines to dwarf-aux.{c, h} perf probe: Remove redundant dwarf functions perf probe: Move strtailcmp to string.c perf probe: Rename DIE_FIND_CB_FOUND to DIE_FIND_CB_END tracing/kprobe: Update symbol reference when loading module tracing/kprobes: Support module init function probing kprobes: Return -ENOENT if probe point doesn't exist ...
2011-07-22Merge branch 'of-pci' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'of-pci' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: pci/of: Consolidate pci_bus_to_OF_node() pci/of: Consolidate pci_device_to_OF_node() x86/devicetree: Use generic PCI <-> OF matching microblaze/pci: Move the remains of pci_32.c to pci-common.c microblaze/pci: Remove powermac originated cruft pci/of: Match PCI devices to OF nodes dynamically
2011-07-22PCI: Make the struct pci_dev * argument of pci_fixup_irqs const.Ralf Baechle
Aside of the usual motivation for constification, this function has a history of being abused a hook for interrupt and other fixups so I turned this function const ages ago in the MIPS code but it should be done treewide. Due to function pointer passing in varous places a few other functions had to be constified as well. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> To: Anton Vorontsov <avorontsov@mvista.com> To: Chris Metcalf <cmetcalf@tilera.com> To: Colin Cross <ccross@android.com> Acked-by: "David S. Miller" <davem@davemloft.net> To: Eric Miao <eric.y.miao@gmail.com> To: Erik Gilling <konkers@android.com> Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn> To: "H. Peter Anvin" <hpa@zytor.com> To: Imre Kaloz <kaloz@openwrt.org> To: Ingo Molnar <mingo@redhat.com> To: Ivan Kokshaysky <ink@jurassic.park.msu.ru> To: Jesse Barnes <jbarnes@virtuousgeek.org> To: Krzysztof Halasa <khc@pm.waw.pl> To: Lennert Buytenhek <kernel@wantstofly.org> To: Matt Turner <mattst88@gmail.com> To: Nicolas Pitre <nico@fluxnic.net> To: Olof Johansson <olof@lixom.net> Acked-by: Paul Mundt <lethal@linux-sh.org> To: Richard Henderson <rth@twiddle.net> To: Russell King <linux@arm.linux.org.uk> To: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: linux-alpha@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-kernel@vger.kernel.org Cc: linux-mips@linux-mips.org Cc: linux-pci@vger.kernel.org Cc: linux-sh@vger.kernel.org Cc: linux-tegra@vger.kernel.org Cc: sparclinux@vger.kernel.org Cc: x86@kernel.org Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-07-21sparc,kgdbts: fix compile regression with kgdb test suiteJason Wessel
Commit 63ab25ebbc (kgdbts: unify/generalize gdb breakpoint adjustment) introduced a compile regression on sparc. kgdbts.c: In function 'check_and_rewind_pc': kgdbts.c:307: error: implicit declaration of function 'instruction_pointer_set' Simply add the correct macro definition for instruction pointer on the Sparc architecture. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: David S. Miller <davem@davemloft.net>
2011-07-21treewide: fix potentially dangerous trailing ';' in #defined values/expressionsPhil Carmody
All these are instances of #define NAME value; or #define NAME(params_opt) value; These of course fail to build when used in contexts like if(foo $OP NAME) while(bar $OP NAME) and may silently generate the wrong code in contexts such as foo = NAME + 1; /* foo = value; + 1; */ bar = NAME - 1; /* bar = value; - 1; */ baz = NAME & quux; /* baz = value; & quux; */ Reported on comp.lang.c, Message-ID: <ab0d55fe-25e5-482b-811e-c475aa6065c3@c29g2000yqd.googlegroups.com> Initial analysis of the dangers provided by Keith Thompson in that thread. There are many more instances of more complicated macros having unnecessary trailing semicolons, but this pile seems to be all of the cases of simple values suffering from the problem. (Thus things that are likely to be found in one of the contexts above, more complicated ones aren't.) Signed-off-by: Phil Carmody <ext-phil.2.carmody@nokia.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-07-16sparc: sun4m SMP: fix wrong shift instruction in IPI handlerWill Simoneau
This shift instruction appears to be shifting in the wrong direction. Without this change, my SparcStation-20MP hangs just after bringing up the second CPU: Entering SMP Mode... Starting CPU 2 at f02b4e90 Brought up 2 CPUs Total of 2 processors activated (99.52 BogoMIPS). *** stuck *** Signed-off-by: Will Simoneau <simoneau@ele.uri.edu> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-11Merge branch 'master' into for-nextJiri Kosina
Sync with Linus' tree to be able to apply pending patches that are based on newer code already present upstream.
2011-07-06sparc32,leon: Added __init declaration to leon_flush_needed()Matthias Rosenfelder
The function leon_flush_needed() is called only during bootup from another __init function. Therefore, we can also add __init to leon_flush_needed(). Signed-off-by: Matthias Rosenfelder <rosenfelder.lkml@googlemail.com> Acked-by: Daniel Hellstrom <daniel@gaisler.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-06sparc/irqs: Do not trace arch_local_{*,irq_*} functionsSteven Rostedt
Do not trace arch_local_save_flags(), arch_local_irq_*() and friends. Although they are marked inline, gcc may still make a function out of them and add it to the pool of functions that are traced by the function tracer. This can cause undesirable results (kernel panic, triple faults, etc). Add the notrace notation to prevent them from ever being traced. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-01perf, arch: Add generic NODE cache eventsPeter Zijlstra
Add a NODE level to the generic cache events which is used to measure local vs remote memory accesses. Like all other cache events, an ACCESS is HIT+MISS, if there is no way to distinguish between reads and writes do reads only etc.. The below needs filling out for !x86 (which I filled out with unsupported events). I'm fairly sure ARM can leave it like that since it doesn't strike me as an architecture that even has NUMA support. SH might have something since it does appear to have some NUMA bits. Sparc64, PowerPC and MIPS certainly want a good look there since they clearly are NUMA capable. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: David Miller <davem@davemloft.net> Cc: Anton Blanchard <anton@samba.org> Cc: David Daney <ddaney@caviumnetworks.com> Cc: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Will Deacon <will.deacon@arm.com> Cc: Robert Richter <robert.richter@amd.com> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1303508226.4865.8.camel@laptop Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-01perf: Remove the nmi parameter from the swevent and overflow interfacePeter Zijlstra
The nmi parameter indicated if we could do wakeups from the current context, if not, we would set some state and self-IPI and let the resulting interrupt do the wakeup. For the various event classes: - hardware: nmi=0; PMI is in fact an NMI or we run irq_work_run from the PMI-tail (ARM etc.) - tracepoint: nmi=0; since tracepoint could be from NMI context. - software: nmi=[0,1]; some, like the schedule thing cannot perform wakeups, and hence need 0. As one can see, there is very little nmi=1 usage, and the down-side of not using it is that on some platforms some software events can have a jiffy delay in wakeup (when arch_irq_work_raise isn't implemented). The up-side however is that we can remove the nmi parameter and save a bunch of conditionals in fast paths. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Michael Cree <mcree@orcon.net.nz> Cc: Will Deacon <will.deacon@arm.com> Cc: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> Cc: Anton Blanchard <anton@samba.org> Cc: Eric B Munson <emunson@mgebm.net> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: David S. Miller <davem@davemloft.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jason Wessel <jason.wessel@windriver.com> Cc: Don Zickus <dzickus@redhat.com> Link: http://lkml.kernel.org/n/tip-agjev8eu666tvknpb3iaj0fg@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-06-27Fix node_start/end_pfn() definition for mm/page_cgroup.cKAMEZAWA Hiroyuki
commit 21a3c96 uses node_start/end_pfn(nid) for detection start/end of nodes. But, it's not defined in linux/mmzone.h but defined in /arch/???/include/mmzone.h which is included only under CONFIG_NEED_MULTIPLE_NODES=y. Then, we see mm/page_cgroup.c: In function 'page_cgroup_init': mm/page_cgroup.c:308: error: implicit declaration of function 'node_start_pfn' mm/page_cgroup.c:309: error: implicit declaration of function 'node_end_pfn' So, fixiing page_cgroup.c is an idea... But node_start_pfn()/node_end_pfn() is a very generic macro and should be implemented in the same manner for all archs. (m32r has different implementation...) This patch removes definitions of node_start/end_pfn() in each archs and defines a unified one in linux/mmzone.h. It's not under CONFIG_NEED_MULTIPLE_NODES, now. A result of macro expansion is here (mm/page_cgroup.c) for !NUMA start_pfn = ((&contig_page_data)->node_start_pfn); end_pfn = ({ pg_data_t *__pgdat = (&contig_page_data); __pgdat->node_start_pfn + __pgdat->node_spanned_pages;}); for NUMA (x86-64) start_pfn = ((node_data[nid])->node_start_pfn); end_pfn = ({ pg_data_t *__pgdat = (node_data[nid]); __pgdat->node_start_pfn + __pgdat->node_spanned_pages;}); Changelog: - fixed to avoid using "nid" twice in node_end_pfn() macro. Reported-and-acked-by: Randy Dunlap <randy.dunlap@oracle.com> Reported-and-tested-by: Ingo Molnar <mingo@elte.hu> Acked-by: Mel Gorman <mgorman@suse.de> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-06-09sparc32, leon: bugfix in LEON SMP interrupt initDaniel Hellstrom
During converting per-cpu ticker to genirq layer some IRQ initialization code was removed by commit 2cf9530420e446bb61f665d02afeb81070106900 ("sparc32,leon: per-cpu ticker use genirq per-cpu handler"). This patch reintroduces the code at the same place it was removed from. IRQ12 - IRQ14 will crash on LEON SMP without this patch because it will run the SUN4M IRQ trap handler. Reported-by: Jan Andersson <jan@gaisler.com> Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-09sparc32, sun4m: bugfix in SMP IPI traphandlerDaniel Hellstrom
Three new IPIs were introduced by commit ecbc42b70acbc6327adefe9635db93fcf62bf59d ("sparc32, sun4m: Implemented SMP IPIs support for SUN4M machines"), the old handler was already prepared for IPIs but handled only IRQ14 and IRQ13, this patch adds support for the new IPI at IRQ12. The IPI trap handler looks at the mask rather than the pending IRQ/IPI, this bug may have masked the problem above, introduced by the same commit. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-08pci/of: Consolidate pci_device_to_OF_node()Benjamin Herrenschmidt
All archs do more or less the same thing now, move it into a single generic place. I chose pci.h rather than of_pci.h to avoid having to change all call-sites to include the later. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Michal Simek <monstr@monstr.eu> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-06-08pci/of: Match PCI devices to OF nodes dynamicallyBenjamin Herrenschmidt
powerpc has two different ways of matching PCI devices to their corresponding OF node (if any) for historical reasons. The ppc64 one does a scan looking for matching bus/dev/fn, while the ppc32 one does a scan looking only for matching dev/fn on each level in order to be agnostic to busses being renumbered (which Linux does on some platforms). This removes both and instead moves the matching code to the PCI core itself. It's the most logical place to do it: when a pci_dev is created, we know the parent and thus can do a single level scan for the matching device_node (if any). The benefit is that all archs now get the matching for free. There's one hook the arch might want to provide to match a PHB bus to its device node. A default weak implementation is provided that looks for the parent device device node, but it's not entirely reliable on powerpc for various reasons so powerpc provides its own. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Michal Simek <monstr@monstr.eu> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-06-07sparc: Remove unnecessary semicolonsJoe Perches
Semicolons are not necessary after switch/while/for/if braces so remove them. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-07Add support for allocating irqs for bootbus devicesoftedal
Some devices that can generate interrupts are connected directly to the CPU through the bootbus on sun4d. This patch allows IRQs to be allocated for such devices. The information used for allocating interrupts for sbus devices are present at the corresponding SBI node. For bootbus devices this information is present in the bootbus node. Signed-off-by: Kjetil Oftedal <oftedal@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-07Do not skip interrupt sources in sun4d interrupt handler and acknowledge ↵oftedal
interrupts correctly During the introduction of genirq on sparc32 bugs were introduced in the interrupt handler for sun4d. The interrupts handler checks the status of the various sbus interfaces in the system and generates a virtual interrupt, based upon the location of the interrupt source. This lookup was broken by restructuring the code in such a way that index and shift operations were performed prior to comparing this against the values read from the interrupt controllers. This could cause the handler to loop eternally as the interrupt source could be skipped before any check was performed. Additionally sun4d_encode_irq performs shifting internally, so it should not be performed twice. In sun4d_unmask interrupts were not correctly acknowledged, as the corresponding bit it the interrupt mask was not actually cleared. Signed-off-by: Kjetil Oftedal <oftedal@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-07Restructure sun4d_build_device_irq so that timer interrupts can be allocatedoftedal
sun4d_build_device_irq was called without a valid platform_device when the system timer was initialized on sun4d systems. This caused a NULL pointer crash. Josip Rodin suggested that the current sun4d_build_device_irq should be split into two functions. So that the timer initialization could skip the slot and sbus interface detection code in sun4d_build_device_irq, as this does not make sence due to the timer interrupts not being generated from a device located on sbus. Signed-off-by: Kjetil Oftedal <oftedal@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-02sparc: PCIC_PCI needs SPARC32 dependencyDavid S. Miller
Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-02sparc: Do not select GENERIC_HARDIRQS_NO_DEPRECATEDGeert Uytterhoeven
Config option GENERIC_HARDIRQS_NO_DEPRECATED was removed in commit 78c89825649a9a5ed526c507603196f467d781a5 ("genirq: Remove the now obsolete config options and select statements"), but the select was accidentally reintroduced in commit 6baa9b20a68a88c2fd751cbe8d7652009379351b ("sparc32: genirq support") Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-02sparc32,leon: add GRPCI2 PCI Host driverDaniel Hellstrom
The DMA region must be accessible in order for PCI peripheral drivers to work, the sparc32 has DMA in the normal memory zone which requires the GRPCI2 to PCI target BARs so that all kernel low mem (192MB) can be mapped 1:1 to PCI address space. The GRPCI2 has resizeable target BARs, by default the first is made 256MB and all other BARs are disabled. I/O space are always located on 0x1000-0x10000, but accessed through the GRPCI2 PCI I/O Window memory mapped to virtual address space. Configuration space is accessed through the 64KB GRPCI2 PCI CFG Window using LDA bypassing the MMU. The GRPCI2 has a single PCI Window for prefetchable and non- prefetchable address space, it is up to the AHB master requesting PCI data to determine access type. Memory space is mapped 1:1. The GRPCI2 core can be configured in 4 different IRQ modes, where PCI Interrupt, Error Interrupt and DMA Interrupt are shared on a single IRQ line or at most 5 IRQs are used. The GRPCI2 can mask/unmask PCI interrupts, Err and DMA in the control and check status bits which tells us which IRQ really happended. The GENIRQ layer is used to unmask/mask each individual IRQ source by creating virtual IRQs and implementing a IRQ chip. The optional DMA functionality of the GRPCI2 is not supported by this patch. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-02sparc32,leon: added LEON-common low-level PCI routinesDaniel Hellstrom
The LEON architecture does not have a BIOS or bootloader that initializes PCI for us, instead Linux generic PCI layer is used to set up resources and IRQ. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-02sparc32: added CONFIG_PCIC_PCI Kconfig settingDaniel Hellstrom
2011-05-28Merge branch 'setns'Linus Torvalds
* setns: ns: Wire up the setns system call Done as a merge to make it easier to fix up conflicts in arm due to addition of sendmmsg system call
2011-05-28ns: Wire up the setns system callEric W. Biederman
32bit and 64bit on x86 are tested and working. The rest I have looked at closely and I can't find any problems. setns is an easy system call to wire up. It just takes two ints so I don't expect any weird architecture porting problems. While doing this I have noticed that we have some architectures that are very slow to get new system calls. cris seems to be the slowest where the last system calls wired up were preadv and pwritev. avr32 is weird in that recvmmsg was wired up but never declared in unistd.h. frv is behind with perf_event_open being the last syscall wired up. On h8300 the last system call wired up was epoll_wait. On m32r the last system call wired up was fallocate. mn10300 has recvmmsg as the last system call wired up. The rest seem to at least have syncfs wired up which was new in the 2.6.39. v2: Most of the architecture support added by Daniel Lezcano <dlezcano@fr.ibm.com> v3: ported to v2.6.36-rc4 by: Eric W. Biederman <ebiederm@xmission.com> v4: Moved wiring up of the system call to another patch v5: ported to v2.6.39-rc6 v6: rebased onto parisc-next and net-next to avoid syscall conflicts. v7: ported to Linus's latest post 2.6.39 tree. >  arch/blackfin/include/asm/unistd.h     |    3 ++- >  arch/blackfin/mach-common/entry.S      |    1 + Acked-by: Mike Frysinger <vapier@gentoo.org> Oh - ia64 wiring looks good. Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26arch: remove CONFIG_GENERIC_FIND_{NEXT_BIT,BIT_LE,LAST_BIT}Akinobu Mita
By the previous style change, CONFIG_GENERIC_FIND_NEXT_BIT, CONFIG_GENERIC_FIND_BIT_LE, and CONFIG_GENERIC_FIND_LAST_BIT are not used to test for existence of find bitops anymore. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25lib: consolidate DEBUG_STACK_USAGE optionStephen Boyd
Most arches define CONFIG_DEBUG_STACK_USAGE exactly the same way. Move it to lib/Kconfig.debug so each arch doesn't have to define it. This obviously makes the option generic, but that's fine because the config is already used in generic code. It's not obvious to me that sysrq-P actually does anything caution by keeping the most inclusive wording. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Cc: Chris Metcalf <cmetcalf@tilera.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Richard Weinberger <richard@nod.at> Acked-by: Mike Frysinger <vapier@gentoo.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Hirokazu Takata <takata@linux-m32r.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: now that all old mmu_gather code is gone, remove the storagePeter Zijlstra
Fold all the mmu_gather rework patches into one for submission Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reported-by: Hugh Dickins <hughd@google.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Tony Luck <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25sparc: mmu_gather reworkPeter Zijlstra
Rework the sparc mmu_gather usage to conform to the new world order :-) Sparc mmu_gather does two things: - tracks vaddrs to unhash - tracks pages to free Split these two things like powerpc has done and keep the vaddrs in per-cpu data structures and flush them on context switch. The remaining bits can then use the generic mmu_gather. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: David Miller <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Tony Luck <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hugh Dickins <hughd@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25arch, mm: filter disallowed nodes from arch specific show_mem functionsDavid Rientjes
Architectures that implement their own show_mem() function did not pass the filter argument to show_free_areas() to appropriately avoid emitting the state of nodes that are disallowed in the current context. This patch now passes the filter argument to show_free_areas() so those nodes are now avoided. This patch also removes the show_free_areas() wrapper around __show_free_areas() and converts existing callers to pass an empty filter. ia64 emits additional information for each node, so skip_free_areas_zone() must be made global to filter disallowed nodes and it is converted to use a nid argument rather than a zone for this use case. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Helge Deller <deller@gmx.de> Cc: James Bottomley <jejb@parisc-linux.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-24Merge branch 'for-2.6.40' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-2.6.40' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu: Unify input section names percpu: Avoid extra NOP in percpu_cmpxchg16b_double percpu: Cast away printk format warning percpu: Always align percpu output section to PAGE_SIZE Fix up fairly trivial conflict in arch/x86/include/asm/percpu.h as per Tejun
2011-05-24Merge branch 'fixes-2.6.39' into for-2.6.40Tejun Heo
