path: root/arch/sparc
2009-11-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sunsu: Use sunserial_console_termios() in sunsu_console_setup(). sunsu: Pass true 'ignore_line' to console match when RSC or LOM console. serial: suncore: Fix RSC/LOM handling in sunserial_console_termios(). serial: suncore: Add 'ignore_line' argument to sunserial_console_match(). sunsu: Fix detection of SU ports which are RSC console or control. sunsab: Do not set sunsab_reg.cons right before registering minors. sparc64: Fix definition of VMEMMAP_SIZE.
2009-11-23sparc64: Fix definition of VMEMMAP_SIZE.David S. Miller
This was the cause of various boot failures on V480, V880, etc. systems. Kernel image memory was being overwritten because the vmemmap[] array was being sized to small. So if you had physical memory addresses past a certain point, the early bootup would spam all over variables in the kernel data section. The vmemmap mappings map page structs, not page struct pointers. And that was the key thinko in the macro definition. This was fixable thanks to the help, reports, and tireless patience of Hermann Lauer. Reported-by: Hermann Lauer <Hermann.Lauer@iwr.uni-heidelberg.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-17Merge branch 'hostprogs-wmissing-prototypes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/josh/linux-misc * 'hostprogs-wmissing-prototypes' of git://git.kernel.org/pub/scm/linux/kernel/git/josh/linux-misc: Makefile: Add -Wmising-prototypes to HOSTCFLAGS oss: Mark loadhex static in hex2hex.c dtc: Mark various internal functions static dtc: Set "noinput" in the lexer to avoid an unused function drm: radeon: Mark several functions static in mkregtable arch/sparc/boot/*.c: Mark various internal functions static arch/powerpc/boot/addRamDisk.c: Mark several internal functions static arch/alpha/boot/tools/objstrip.c: Mark "usage" static Documentation/vm/page-types.c: Declare checked_open static genksyms: Mark is_reserved_word static kconfig: Mark various internal functions static kconfig: Make zconf.y work with current bison
2009-11-15arch/sparc/boot/*.c: Mark various internal functions staticJosh Triplett
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
2009-11-08sparc: Move of_set_property_mutex acquisition outside of devtree_lock grab.David S. Miller
Otherwise we try to sleep with preemption disabled, etc. Noticed by Thomas Gleixner. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-08sparc64: replace parentheses in pmul()Roel Kluin
`>>' has a higher precedence than `?' so src2 evaluated to either 16 or 0 dependent on the bits set in rs2. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-05sparc64: Add a comment about why we only use certain memory barriers these days.David S. Miller
Based upon feedback from Mathieu Desnoyers. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13sparc64: Set IRQF_DISABLED on LDC channel IRQs.David S. Miller
With lots of virtual devices it's easy to generate a lot of events and chew up the kernel IRQ stack. Reported-by: hyl <heyongli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-12sparc64: Fix D-cache flushing on swapin from SW devices.David S. Miller
Thanks to tip form ARM folks and Russell King. If flush_dcache_page() occurs on a swapin it will have a mapping and we'll try to defer the flush by setting the dirty bit. But when it hits update_dcache_page() we won't flush because the page won't have a mapping any more. So remove the mapping requirement in flush_dcache(). Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-09sparc64: Fix niagara2 perf IRQ bits.David S. Miller
2009-10-08Merge branch 'sparc-perf-events-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sparc-perf-events-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: mm, perf_event: Make vmalloc_user() align base kernel virtual address to SHMLBA perf_event: Provide vmalloc() based mmap() backing
2009-10-06perf_event: Provide vmalloc() based mmap() backingPeter Zijlstra
Some architectures such as Sparc, ARM and MIPS (basically everything with flush_dcache_page()) need to deal with dcache aliases by carefully placing pages in both kernel and user maps. These architectures typically have to use vmalloc_user() for this. However, on other architectures, vmalloc() is not needed and has the downsides of being more restricted and slower than regular allocations. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: David Miller <davem@davemloft.net> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1254830228.21044.272.camel@laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc: using HZ needs an include of linux/param.h sparc32: convert to asm-generic/hardirq.h sparc64: Cache per-cpu %pcr register value in perf code. sparc64: Fix comment typo in perf_event.c sparc64: Minor coding style fixups in perf code. sparc64: Add a basic conflict engine in preparation for multi-counter support. sparc64: Increase vmalloc size to fix percpu regressions. sparc64: Add initial perf event conflict resolution and checks. sparc: Niagara1 perf event support. sparc: Add Niagara2 HW cache event support. sparc: Support all ultra3 and ultra4 derivatives. sparc: Support HW cache events.
2009-10-05sparc: using HZ needs an include of linux/param.hStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-01sparc32: convert to asm-generic/hardirq.hChristoph Hellwig
From: Christoph Hellwig <hch@lst.de> [akpm@linux-foundation.org: /arch/sparc/include/asm/irq_32.h: move NR_IRQS definition] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-29sparc64: Cache per-cpu %pcr register value in perf code.David S. Miller
2009-09-29sparc64: Fix comment typo in perf_event.cDavid S. Miller
2009-09-28sparc64: Minor coding style fixups in perf code.David S. Miller
These got introduced during the counter --> event tree-wide renaming. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-28sparc64: Add a basic conflict engine in preparation for multi-counter support.David S. Miller
The hardware counter ->event_base state records and encoding of the "struct perf_event_map" entry used for the event. We use this to make sure that when we have more than 1 event, both can be scheduled into the hardware at the same time. As usual, structure of code is largely cribbed from powerpc. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-29sparc64: implement page mapping percpu first chunk allocatorTejun Heo
Implement page mapping percpu first chunk allocator as a fallback to the embedding allocator. The next patch will make the embedding allocator check distances between units to determine whether it fits within the vmalloc area so that this fallback can be used on such cases. sparc64 currently has relatively small vmalloc area which makes it impossible to create any dynamic chunks on certain configurations leading to percpu allocation failures. This and the next patch should allow those configurations to keep working until proper solution is found. While at it, mark pcpu_cpu_distance() with __init. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net>
2009-09-28sparc64: Increase vmalloc size to fix percpu regressions.David S. Miller
Since we now use the embedding percpu allocator we have to make the vmalloc area at least as large as the stretch can be between nodes. Besides some minor asm adjustments, this turned out to be pretty trivial. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-27sparc64: Add initial perf event conflict resolution and checks.David S. Miller
Cribbed from powerpc code, as usual. :-) Currently it is only used to validate that all counters have the same user/kernel/hv attributes. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-26sparc: Niagara1 perf event support.David S. Miller
This chip is extremely limited, and many of the events supported are approximations at best. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-26sparc: Add Niagara2 HW cache event support.David S. Miller
2009-09-26sparc: Support all ultra3 and ultra4 derivatives.David S. Miller
For the generic events we support, all of these chips have the same encodings as ultra3i. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-26sparc: Support HW cache events.David S. Miller
First supported chip for HW cache events is Ultra-IIIi. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc64: vio: Kill BUILD_BUG_ON() in vio_dring_avail(). Trivial conflict in arch/sparc/include/asm/vio.h due to David removing the whole messy BUG_ON that was confused.
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: (39 commits) cpumask: Move deprecated functions to end of header. cpumask: remove unused deprecated functions, avoid accusations of insanity cpumask: use new-style cpumask ops in mm/quicklist. cpumask: use mm_cpumask() wrapper: x86 cpumask: use mm_cpumask() wrapper: um cpumask: use mm_cpumask() wrapper: mips cpumask: use mm_cpumask() wrapper: mn10300 cpumask: use mm_cpumask() wrapper: m32r cpumask: use mm_cpumask() wrapper: arm cpumask: Use accessors for cpu_*_mask: um cpumask: Use accessors for cpu_*_mask: powerpc cpumask: Use accessors for cpu_*_mask: mips cpumask: Use accessors for cpu_*_mask: m32r cpumask: remove arch_send_call_function_ipi cpumask: arch_send_call_function_ipi_mask: s390 cpumask: arch_send_call_function_ipi_mask: powerpc cpumask: arch_send_call_function_ipi_mask: mips cpumask: arch_send_call_function_ipi_mask: m32r cpumask: arch_send_call_function_ipi_mask: alpha cpumask: remove obsolete topology_core_siblings and topology_thread_siblings: ia64 ...
2009-09-23headers: utsname.h reduxAlexey Dobriyan
* remove asm/atomic.h inclusion from linux/utsname.h -- not needed after kref conversion * remove linux/utsname.h inclusion from files which do not need it NOTE: it looks like fs/binfmt_elf.c do not need utsname.h, however due to some personality stuff it _is_ needed -- cowardly leave ELF-related headers and files alone. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24cpumask: remove arch_send_call_function_ipiRusty Russell
Now everyone is converted to arch_send_call_function_ipi_mask, remove the shim and the #defines. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-09-24cpumask: remove obsolete topology_core_siblings and ↵Rusty Russell
topology_thread_siblings: sparc There were replaced by topology_core_cpumask and topology_thread_cpumask. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-09-24cpumask: remove obsolete node_to_cpumask now everyone uses cpumask_of_nodeRusty Russell
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (30 commits) Use macros for .data.page_aligned section. Use macros for .bss.page_aligned section. Use new __init_task_data macro in arch init_task.c files. kbuild: Don't define ALIGN and ENTRY when preprocessing linker scripts. arm, cris, mips, sparc, powerpc, um, xtensa: fix build with bash 4.0 kbuild: add static to prototypes kbuild: fail build if recordmcount.pl fails kbuild: set -fconserve-stack option for gcc 4.5 kbuild: echo the record_mcount command gconfig: disable "typeahead find" search in treeviews kbuild: fix cc1 options check to ensure we do not use -fPIC when compiling checkincludes.pl: add option to remove duplicates in place markup_oops: use modinfo to avoid confusion with underscored module names checkincludes.pl: provide usage helper checkincludes.pl: close file as soon as we're done with it ctags: usability fix kernel hacking: move STRIP_ASM_SYMS from General gitignore usr/initramfs_data.cpio.bz2 and usr/initramfs_data.cpio.lzma kbuild: Check if linker supports the -X option kbuild: introduce ld-option ... Fix trivial conflict in scripts/basic/fixdep.c
2009-09-23BUILD_BUG_ON(): fix it and a couple of bogus uses of itJan Beulich
gcc permitting variable length arrays makes the current construct used for BUILD_BUG_ON() useless, as that doesn't produce any diagnostic if the controlling expression isn't really constant. Instead, this patch makes it so that a bit field gets used here. Consequently, those uses where the condition isn't really constant now also need fixing. Note that in the gfp.h, kmemcheck.h, and virtio_config.h cases MAYBE_BUILD_BUG_ON() really just serves documentation purposes - even if the expression is compile time constant (__builtin_constant_p() yields true), the array is still deemed of variable length by gcc, and hence the whole expression doesn't have the intended effect. [akpm@linux-foundation.org: make arch/sparc/include/asm/vio.h compile] [akpm@linux-foundation.org: more nonsensical assertions in tpm.c..] Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Cc: Mimi Zohar <zohar@us.ibm.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits) trivial: fix typo in aic7xxx comment trivial: fix comment typo in drivers/ata/pata_hpt37x.c trivial: typo in kernel-parameters.txt trivial: fix typo in tracing documentation trivial: add __init/__exit macros in drivers/gpio/bt8xxgpio.c trivial: add __init macro/ fix of __exit macro location in ipmi_poweroff.c trivial: remove unnecessary semicolons trivial: Fix duplicated word "options" in comment trivial: kbuild: remove extraneous blank line after declaration of usage() trivial: improve help text for mm debug config options trivial: doc: hpfall: accept disk device to unload as argument trivial: doc: hpfall: reduce risk that hpfall can do harm trivial: SubmittingPatches: Fix reference to renumbered step trivial: fix typos "man[ae]g?ment" -> "management" trivial: media/video/cx88: add __init/__exit macros to cx88 drivers trivial: fix typo in CONFIG_DEBUG_FS in gcov doc trivial: fix missing printk space in amd_k7_smp_check trivial: fix typo s/ketymap/keymap/ in comment trivial: fix typo "to to" in multiple files trivial: fix typos in comments s/DGBU/DBGU/ ...
2009-09-22mm: add MAP_HUGETLB for mmaping pseudo-anonymous huge page regionsArnd Bergmann
Add a flag for mmap that will be used to request a huge page region that will look like anonymous memory to user space. This is accomplished by using a file on the internal vfsmount. MAP_HUGETLB is a modifier of MAP_ANONYMOUS and so must be specified with it. The region will behave the same as a MAP_ANONYMOUS region using small pages. The patch also adds the MAP_STACK flag, which was previously defined only on some architectures but not on others. Since MAP_STACK is meant to be a hint only, architectures can define it without assigning a specific meaning to it. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Eric B Munson <ebmunson@us.ibm.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: David Rientjes <rientjes@google.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22arches: drop superfluous casts in nr_free_pages() callersGeert Uytterhoeven
Commit 96177299416dbccb73b54e6b344260154a445375 ("Drop free_pages()") modified nr_free_pages() to return 'unsigned long' instead of 'unsigned int'. This made the casts to 'unsigned long' in most callers superfluous, so remove them. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Mikael Starvik <starvik@axis.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Chris Zankel <zankel@tensilica.com> Cc: Michal Simek <monstr@monstr.eu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-21trivial: remove unnecessary semicolonsJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-21perf: Do the big rename: Performance Counters -> Performance EventsIngo Molnar
Bye-bye Performance Counters, welcome Performance Events! In the past few months the perfcounters subsystem has grown out its initial role of counting hardware events, and has become (and is becoming) a much broader generic event enumeration, reporting, logging, monitoring, analysis facility. Naming its core object 'perf_counter' and naming the subsystem 'perfcounters' has become more and more of a misnomer. With pending code like hw-breakpoints support the 'counter' name is less and less appropriate. All in one, we've decided to rename the subsystem to 'performance events' and to propagate this rename through all fields, variables and API names. (in an ABI compatible fashion) The word 'event' is also a bit shorter than 'counter' - which makes it slightly more convenient to write/handle as well. Thanks goes to Stephane Eranian who first observed this misnomer and suggested a rename. User-space tooling and ABI compatibility is not affected - this patch should be function-invariant. (Also, defconfigs were not touched to keep the size down.) This patch has been generated via the following script: FILES=$(find * -type f | grep -vE 'oprofile|[^K]config') sed -i \ -e 's/PERF_EVENT_/PERF_RECORD_/g' \ -e 's/PERF_COUNTER/PERF_EVENT/g' \ -e 's/perf_counter/perf_event/g' \ -e 's/nb_counters/nb_events/g' \ -e 's/swcounter/swevent/g' \ -e 's/tpcounter_event/tp_event/g' \ $FILES for N in $(find . -name perf_counter.[ch]); do M=$(echo $N | sed 's/perf_counter/perf_event/g') mv $N $M done FILES=$(find . -name perf_event.*) sed -i \ -e 's/COUNTER_MASK/REG_MASK/g' \ -e 's/COUNTER/EVENT/g' \ -e 's/\<event\>/event_id/g' \ -e 's/counter/event/g' \ -e 's/Counter/Event/g' \ $FILES ... to keep it as correct as possible. This script can also be used by anyone who has pending perfcounters patches - it converts a Linux kernel tree over to the new naming. We tried to time this change to the point in time where the amount of pending patches is the smallest: the end of the merge window. Namespace clashes were fixed up in a preparatory patch - and some stylistic fallout will be fixed up in a subsequent patch. ( NOTE: 'counters' are still the proper terminology when we deal with hardware registers - and these sed scripts are a bit over-eager in renaming them. I've undone some of that, but in case there's something left where 'counter' would be better than 'event' we can undo that on an individual basis instead of touching an otherwise nicely automated patch. ) Suggested-by: Stephane Eranian <eranian@google.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Paul Mackerras <paulus@samba.org> Reviewed-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: <linux-arch@vger.kernel.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-21Merge branch 'linus' into perfcounters/renameIngo Molnar
Merge reason: pull in all the latest code before doing the rename. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-21perf_counter, powerpc, sparc: Fix compilation after perf_counter_overflow() ↵Paul Mackerras
change Commit 5622f295 ("x86, perf_counter, bts: Optimize BTS overflow handling") removed the regs field from struct perf_sample_data and added a regs parameter to perf_counter_overflow(). This breaks the build on powerpc (and Sparc) as reported by Sachin Sant: arch/powerpc/kernel/perf_counter.c: In function 'record_and_restart': arch/powerpc/kernel/perf_counter.c:1165: error: unknown field 'regs' specified in initializer This adjusts arch/powerpc/kernel/perf_counter.c to correspond with the new struct perf_sample_data and perf_counter_overflow(). [ v2: also fix Sparc, Markus Metzger <markus.t.metzger@intel.com> ] Reported-by: Sachin Sant <sachinp@in.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org> Cc: Markus Metzger <markus.t.metzger@intel.com> Cc: David S. Miller <davem@davemloft.net> Cc: benh@kernel.crashing.org Cc: linuxppc-dev@ozlabs.org Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <19127.8400.376239.586120@drongo.ozlabs.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-21Use new __init_task_data macro in arch init_task.c files.Joe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Tim Abbott <tabbott@ksplice.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-09-20arm, cris, mips, sparc, powerpc, um, xtensa: fix build with bash 4.0Sam Ravnborg
Albin Tonnerre <albin.tonnerre@free-electrons.com> reported: Bash 4 filters out variables which contain a dot in them. This happends to be the case of CPPFLAGS_vmlinux.lds. This is rather unfortunate, as it now causes build failures when using SHELL=/bin/bash to compile, or when bash happens to be used by make (eg when it's /bin/sh) Remove the common definition of CPPFLAGS_vmlinux.lds by pushing relevant stuff to either Makefile.build or the arch specific kernel/Makefile where we build the linker script. This is also nice cleanup as we move the information out where it is used. Notes for the different architectures touched: arm - we use an already exported symbol cris - we use a config symbol aleady available [Not build tested] mips - the jiffies complexity has moved to vmlinux.lds.S where we need it. Added a few variables to CPPFLAGS - they are only used by the linker script. [Not build tested] powerpc - removed assignment that is not needed [not build tested] sparc - simplified it using $(BITS) um - introduced a few new exported variables to deal with this xtensa - added options to CPP invocation [not build tested] Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-09-18sparc: Clean up linker script using new linker script macros.Geoffrey Thomas
Signed-off-by: Geoffrey Thomas <geofft@ksplice.com> Signed-off-by: Tim Abbott <tabbott@ksplice.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-17Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (37 commits) sched: Fix SD_POWERSAVING_BALANCE|SD_PREFER_LOCAL vs SD_WAKE_AFFINE sched: Stop buddies from hogging the system sched: Add new wakeup preemption mode: WAKEUP_RUNNING sched: Fix TASK_WAKING & loadaverage breakage sched: Disable wakeup balancing sched: Rename flags to wake_flags sched: Clean up the load_idx selection in select_task_rq_fair sched: Optimize cgroup vs wakeup a bit sched: x86: Name old_perf in a unique way sched: Implement a gentler fair-sleepers feature sched: Add SD_PREFER_LOCAL sched: Add a few SYNC hint knobs to play with sched: Fix sync wakeups again sched: Add WF_FORK sched: Rename sync arguments sched: Rename select_task_rq() argument sched: Feature to disable APERF/MPERF cpu_power x86: sched: Provide arch implementations using aperf/mperf x86: Add generic aperf/mperf code x86: Move APERF/MPERF into a X86_FEATURE ... Fix up trivial conflict in arch/x86/include/asm/processor.h due to nearby addition of amd_get_nb_id() declaration from the EDAC merge.
2009-09-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc: Update defconfigs. sparc: Kill PROM console driver.
2009-09-17sparc64: vio: Kill BUILD_BUG_ON() in vio_dring_avail().David S. Miller
GCC can't see the 'constant' properly as computed by is_power_of_2() etc. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-16Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (75 commits) PCI hotplug: clean up acpi_run_hpp() PCI hotplug: acpiphp: use generic pci_configure_slot() PCI hotplug: shpchp: use generic pci_configure_slot() PCI hotplug: pciehp: use generic pci_configure_slot() PCI hotplug: add pci_configure_slot() PCI hotplug: clean up acpi_get_hp_params_from_firmware() interface PCI hotplug: acpiphp: don't cache hotplug_params in acpiphp_bridge PCI hotplug: acpiphp: remove superfluous _HPP/_HPX evaluation PCI: Clear saved_state after the state has been restored PCI PM: Return error codes from pci_pm_resume() PCI: use dev_printk in quirk messages PCI / PCIe portdrv: Fix pcie_portdrv_slot_reset() PCI Hotplug: convert acpi_pci_detect_ejectable() to take an acpi_handle PCI Hotplug: acpiphp: find bridges the easy way PCI: pcie portdrv: remove unused variable PCI / ACPI PM: Propagate wake-up enable for devices w/o ACPI support ACPI PM: Replace wakeup.prepared with reference counter PCI PM: Introduce device flag wakeup_prepared PCI / ACPI PM: Rework some debug messages PCI PM: Simplify PCI wake-up code ... Fixed up conflict in arch/powerpc/kernel/pci_64.c due to OF device tree scanning having been moved and merged for the 32- and 64-bit cases. The 'needs_freset' initialization added in 6e19314cc ("PCI/powerpc: support PCIe fundamental reset") is now in arch/powerpc/kernel/pci_of_scan.c.
2009-09-16sched: Disable wakeup balancingPeter Zijlstra
Sysbench thinks SD_BALANCE_WAKE is too agressive and kbuild doesn't really mind too much, SD_BALANCE_NEWIDLE picks up most of the slack. On a dual socket, quad core, dual thread nehalem system: sysbench (--num_threads=16): SD_BALANCE_WAKE-: 13982 tx/s SD_BALANCE_WAKE+: 15688 tx/s kbuild (-j16): SD_BALANCE_WAKE-: 47.648295846 seconds time elapsed ( +- 0.312% ) SD_BALANCE_WAKE+: 47.608607360 seconds time elapsed ( +- 0.026% ) (same within noise) Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-16sparc: Update defconfigs.David S. Miller
