path: root/arch/sparc
2013-01-12sparc: remove __devinit, __devexit annotationsSam Ravnborg
__devinit, __devexit annotations are nops - so drop them. Likewise for __devexit_p. Adjusted alignment of arguments when needed. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-28sparc: Hook up finit_module syscall.David S. Miller
2012-12-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull signal handling cleanups from Al Viro: "sigaltstack infrastructure + conversion for x86, alpha and um, COMPAT_SYSCALL_DEFINE infrastructure. Note that there are several conflicts between "unify SS_ONSTACK/SS_DISABLE definitions" and UAPI patches in mainline; resolution is trivial - just remove definitions of SS_ONSTACK and SS_DISABLED from arch/*/uapi/asm/signal.h; they are all identical and include/uapi/linux/signal.h contains the unified variant." Fixed up conflicts as per Al. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: alpha: switch to generic sigaltstack new helpers: __save_altstack/__compat_save_altstack, switch x86 and um to those generic compat_sys_sigaltstack() introduce generic sys_sigaltstack(), switch x86 and um to it new helper: compat_user_stack_pointer() new helper: restore_altstack() unify SS_ONSTACK/SS_DISABLE definitions new helper: current_user_stack_pointer() missing user_stack_pointer() instances Bury the conditionals from kernel_thread/kernel_execve series COMPAT_SYSCALL_DEFINE: infrastructure
2012-12-20Merge tag 'iommu-updates-v3.8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu Pull IOMMU updates from Joerg Roedel: "A few new features this merge-window. The most important one is probably, that dma-debug now warns if a dma-handle is not checked with dma_mapping_error by the device driver. This requires minor changes to some architectures which make use of dma-debug. Most of these changes have the respective Acks by the Arch-Maintainers. Besides that there are updates to the AMD IOMMU driver for refactor the IOMMU-Groups support and to make sure it does not trigger a hardware erratum. The OMAP changes (for which I pulled in a branch from Tony Lindgren's tree) have a conflict in linux-next with the arm-soc tree. The conflict is in the file arch/arm/mach-omap2/clock44xx_data.c which is deleted in the arm-soc tree. It is safe to delete the file too so solve the conflict. Similar changes are done in the arm-soc tree in the common clock framework migration. A missing hunk from the patch in the IOMMU tree will be submitted as a seperate patch when the merge-window is closed." * tag 'iommu-updates-v3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (29 commits) ARM: dma-mapping: support debug_dma_mapping_error ARM: OMAP4: hwmod data: ipu and dsp to use parent clocks instead of leaf clocks iommu/omap: Adapt to runtime pm iommu/omap: Migrate to hwmod framework iommu/omap: Keep mmu enabled when requested iommu/omap: Remove redundant clock handling on ISR iommu/amd: Remove obsolete comment iommu/amd: Don't use 512GB pages iommu/tegra: smmu: Move bus_set_iommu after probe for multi arch iommu/tegra: gart: Move bus_set_iommu after probe for multi arch iommu/tegra: smmu: Remove unnecessary PTC/TLB flush all tile: dma_debug: add debug_dma_mapping_error support sh: dma_debug: add debug_dma_mapping_error support powerpc: dma_debug: add debug_dma_mapping_error support mips: dma_debug: add debug_dma_mapping_error support microblaze: dma-mapping: support debug_dma_mapping_error ia64: dma_debug: add debug_dma_mapping_error support c6x: dma_debug: add debug_dma_mapping_error support ARM64: dma_debug: add debug_dma_mapping_error support intel-iommu: Prevent devices with RMRRs from being placed into SI Domain ...
2012-12-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
Pull sparc fixes from David Miller: "Please pull to get these sparc AES/DES/CAMELLIA crypto bug fixes as well as an addition of a pte_accessible() define for sparc64 and a hugetlb fix from Dave Kleikamp." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: sparc64: Set CRYPTO_TFM_REQ_MAY_SLEEP consistently in CAMELLIA code. sparc64: Set CRYPTO_TFM_REQ_MAY_SLEEP consistently in DES code. sparc64: Fix ECB looping constructs in AES code. sparc64: Set CRYPTO_TFM_REQ_MAY_SLEEP consistently in AES code. sparc64: Fix AES ctr mode block size. sparc64: Fix unrolled AES 256-bit key loops. sparc64: Define pte_accessible() sparc: huge_ptep_set_* functions need to call set_huge_pte_at()
2012-12-19sparc64: Set CRYPTO_TFM_REQ_MAY_SLEEP consistently in CAMELLIA code.David S. Miller
We use the FPU and therefore cannot sleep during the crypto loops. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-19sparc64: Set CRYPTO_TFM_REQ_MAY_SLEEP consistently in DES code.David S. Miller
2012-12-19sparc64: Fix ECB looping constructs in AES code.David S. Miller
Things works better when you increment the source buffer pointer properly. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-19sparc64: Set CRYPTO_TFM_REQ_MAY_SLEEP consistently in AES code.David S. Miller
2012-12-19sparc64: Fix AES ctr mode block size.David S. Miller
Like the generic versions, we need to support a block size of '1' for CTR mode AES. This was discovered thanks to all of the new test cases added by Jussi Kivilinna. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-19sparc64: Fix unrolled AES 256-bit key loops.David S. Miller
The basic scheme of the block mode assembler is that we start by enabling the FPU, loading the key into the floating point registers, then iterate calling the encrypt/decrypt routine for each block. For the 256-bit key cases, we run short on registers in the unrolled loops. So the {ENCRYPT,DECRYPT}_256_2() macros reload the key registers that get clobbered. The unrolled macros, {ENCRYPT,DECRYPT}_256(), are not mindful of this. So if we have a mix of multi-block and single-block calls, the single-block unrolled 256-bit encrypt/decrypt can run with some of the key registers clobbered. Handle this by always explicitly loading those registers before using the non-unrolled 256-bit macro. This was discovered thanks to all of the new test cases added by Jussi Kivilinna. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-19unify SS_ONSTACK/SS_DISABLE definitionsAl Viro
2012-12-19Bury the conditionals from kernel_thread/kernel_execve seriesAl Viro
All architectures have CONFIG_GENERIC_KERNEL_THREAD CONFIG_GENERIC_KERNEL_EXECVE __ARCH_WANT_SYS_EXECVE None of them have __ARCH_WANT_KERNEL_EXECVE and there are only two callers of kernel_execve() (which is a trivial wrapper for do_execve() now) left. Kill the conditionals and make both callers use do_execve(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-12-19Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module update from Rusty Russell: "Nothing all that exciting; a new module-from-fd syscall for those who want to verify the source of the module (ChromeOS) and/or use standard IMA on it or other security hooks." * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: MODSIGN: Fix kbuild output when using default extra_certificates MODSIGN: Avoid using .incbin in C source modules: don't hand 0 to vmalloc. module: Remove a extra null character at the top of module->strtab. ASN.1: Use the ASN1_LONG_TAG and ASN1_INDEFINITE_LENGTH constants ASN.1: Define indefinite length marker constant moduleparam: use __UNIQUE_ID() __UNIQUE_ID() MODSIGN: Add modules_sign make target powerpc: add finit_module syscall. ima: support new kernel module syscall add finit_module syscall to asm-generic ARM: add finit_module syscall to ARM security: introduce kernel_module_from_file hook module: add flags arg to sys_finit_module() module: add syscall to load module from fd
2012-12-18sparc64: Define pte_accessible()David S. Miller
We can elide flush_tlb_*() calls when _PAGE_VALID is clear as that is the test used to determine whether or not to queue up a TLB flush in set_pte_at(). Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-18sparc: huge_ptep_set_* functions need to call set_huge_pte_at()Dave Kleikamp
Modifying the huge pte's requires that all the underlying pte's be modified. Version 2: added missing flush_tlb_page() Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: sparclinux@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-17compat: generic compat_sys_sched_rr_get_interval() implementationCatalin Marinas
This function is used by sparc, powerpc tile and arm64 for compat support. The patch adds a generic implementation with a wrapper for PowerPC to do the u32->int sign extension. The reason for a single patch covering powerpc, tile, sparc and arm64 is to keep it bisectable, otherwise kernel building may fail with mismatched function declarations. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Chris Metcalf <cmetcalf@tilera.com> [for tile] Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-16Merge branches 'iommu/fixes', 'dma-debug', 'x86/amd', 'x86/vt-d', ↵Joerg Roedel
'arm/tegra' and 'arm/omap' into next
2012-12-14modules: don't hand 0 to vmalloc.Rusty Russell
In commit d0a21265dfb5fa8a David Rientjes unified various archs' module_alloc implementation (including x86) and removed the graduitous shortcut for size == 0. Then, in commit de7d2b567d040e3b, Joe Perches added a warning for zero-length vmallocs, which can happen without kallsyms on modules with no init sections (eg. zlib_deflate). Fix this once and for all; the module code has to handle zero length anyway, so get it right at the caller and remove the now-gratuitous checks within the arch-specific module_alloc implementations. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=42608 Reported-by: Conrad Kostecki <ConiKost@gmx.de> Cc: David Rientjes <rientjes@google.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-12-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking changes from David Miller: 1) Allow to dump, monitor, and change the bridge multicast database using netlink. From Cong Wang. 2) RFC 5961 TCP blind data injection attack mitigation, from Eric Dumazet. 3) Networking user namespace support from Eric W. Biederman. 4) tuntap/virtio-net multiqueue support by Jason Wang. 5) Support for checksum offload of encapsulated packets (basically, tunneled traffic can still be checksummed by HW). From Joseph Gasparakis. 6) Allow BPF filter access to VLAN tags, from Eric Dumazet and Daniel Borkmann. 7) Bridge port parameters over netlink and BPDU blocking support from Stephen Hemminger. 8) Improve data access patterns during inet socket demux by rearranging socket layout, from Eric Dumazet. 9) TIPC protocol updates and cleanups from Ying Xue, Paul Gortmaker, and Jon Maloy. 10) Update TCP socket hash sizing to be more in line with current day realities. The existing heurstics were choosen a decade ago. From Eric Dumazet. 11) Fix races, queue bloat, and excessive wakeups in ATM and associated drivers, from Krzysztof Mazur and David Woodhouse. 12) Support DOVE (Distributed Overlay Virtual Ethernet) extensions in VXLAN driver, from David Stevens. 13) Add "oops_only" mode to netconsole, from Amerigo Wang. 14) Support set and query of VEB/VEPA bridge mode via PF_BRIDGE, also allow DCB netlink to work on namespaces other than the initial namespace. From John Fastabend. 15) Support PTP in the Tigon3 driver, from Matt Carlson. 16) tun/vhost zero copy fixes and improvements, plus turn it on by default, from Michael S. Tsirkin. 17) Support per-association statistics in SCTP, from Michele Baldessari. And many, many, driver updates, cleanups, and improvements. Too numerous to mention individually. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits) net/mlx4_en: Add support for destination MAC in steering rules net/mlx4_en: Use generic etherdevice.h functions. net: ethtool: Add destination MAC address to flow steering API bridge: add support of adding and deleting mdb entries bridge: notify mdb changes via netlink ndisc: Unexport ndisc_{build,send}_skb(). uapi: add missing netconf.h to export list pkt_sched: avoid requeues if possible solos-pci: fix double-free of TX skb in DMA mode bnx2: Fix accidental reversions. bna: Driver Version Updated to 3.1.2.1 bna: Firmware update bna: Add RX State bna: Rx Page Based Allocation bna: TX Intr Coalescing Fix bna: Tx and Rx Optimizations bna: Code Cleanup and Enhancements ath9k: check pdata variable before dereferencing it ath5k: RX timestamp is reported at end of frame ath9k_htc: RX timestamp is reported at end of frame ...
2012-12-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull big execve/kernel_thread/fork unification series from Al Viro: "All architectures are converted to new model. Quite a bit of that stuff is actually shared with architecture trees; in such cases it's literally shared branch pulled by both, not a cherry-pick. A lot of ugliness and black magic is gone (-3KLoC total in this one): - kernel_thread()/kernel_execve()/sys_execve() redesign. We don't do syscalls from kernel anymore for either kernel_thread() or kernel_execve(): kernel_thread() is essentially clone(2) with callback run before we return to userland, the callbacks either never return or do successful do_execve() before returning. kernel_execve() is a wrapper for do_execve() - it doesn't need to do transition to user mode anymore. As a result kernel_thread() and kernel_execve() are arch-independent now - they live in kernel/fork.c and fs/exec.c resp. sys_execve() is also in fs/exec.c and it's completely architecture-independent. - daemonize() is gone, along with its parts in fs/*.c - struct pt_regs * is no longer passed to do_fork/copy_process/ copy_thread/do_execve/search_binary_handler/->load_binary/do_coredump. - sys_fork()/sys_vfork()/sys_clone() unified; some architectures still need wrappers (ones with callee-saved registers not saved in pt_regs on syscall entry), but the main part of those suckers is in kernel/fork.c now." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (113 commits) do_coredump(): get rid of pt_regs argument print_fatal_signal(): get rid of pt_regs argument ptrace_signal(): get rid of unused arguments get rid of ptrace_signal_deliver() arguments new helper: signal_pt_regs() unify default ptrace_signal_deliver flagday: kill pt_regs argument of do_fork() death to idle_regs() don't pass regs to copy_process() flagday: don't pass regs to copy_thread() bfin: switch to generic vfork, get rid of pointless wrappers xtensa: switch to generic clone() openrisc: switch to use of generic fork and clone unicore32: switch to generic clone(2) score: switch to generic fork/vfork/clone c6x: sanitize copy_thread(), get rid of clone(2) wrapper, switch to generic clone() take sys_fork/sys_vfork/sys_clone prototypes to linux/syscalls.h mn10300: switch to generic fork/vfork/clone h8300: switch to generic fork/vfork/clone tile: switch to generic clone() ... Conflicts: arch/microblaze/include/asm/Kbuild
2012-12-11Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf updates from Ingo Molnar: "Lots of activity: 211 files changed, 8328 insertions(+), 4116 deletions(-) most of it on the tooling side. Main changes: * ftrace enhancements and fixes from Steve Rostedt. * uprobes fixes, cleanups and preparation for the ARM port from Oleg Nesterov. * UAPI fixes, from David Howels - prepares the arch/x86 UAPI transition * Separate perf tests into multiple objects, one per test, from Jiri Olsa. * Make hardware event translations available in sysfs, from Jiri Olsa. * Fixes to /proc/pid/maps parsing, preparatory to supporting data maps, from Namhyung Kim * Implement ui_progress for GTK, from Namhyung Kim * Add framework for automated perf_event_attr tests, where tools with different command line options will be run from a 'perf test', via python glue, and the perf syscall will be intercepted to verify that the perf_event_attr fields set by the tool are those expected, from Jiri Olsa * Add a 'link' method for hists, so that we can have the leader with buckets for all the entries in all the hists. This new method is now used in the default 'diff' output, making the sum of the 'baseline' column be 100%, eliminating blind spots. * libtraceevent fixes for compiler warnings trying to make perf it build on some distros, like fedora 14, 32-bit, some of the warnings really pointed to real bugs. * Add a browser for 'perf script' and make it available from the report and annotate browsers. It does filtering to find the scripts that handle events found in the perf.data file used. From Feng Tang * perf inject changes to allow showing where a task sleeps, from Andrew Vagin. * Makefile improvements from Namhyung Kim. * Add --pre and --post command hooks in 'stat', from Peter Zijlstra. * Don't stop synthesizing threads when one vanishes, this is for the existing threads when we start a tool like trace. * Use sched:sched_stat_runtime to provide a thread summary, this produces the same output as the 'trace summary' subcommand of tglx's original "trace" tool. * Support interrupted syscalls in 'trace' * Add an event duration column and filter in 'trace'. * There are references to the man pages in some tools, so try to build Documentation when installing, warning the user if that is not possible, from Borislav Petkov. * Give user better message if precise is not supported, from David Ahern. * Try to find cross-built objdump path by using the session environment information in the perf.data file header, from Irina Tirdea, original patch and idea by Namhyung Kim. * Diplays more output on features check for make V=1, so that one can figure out what is happening by looking at gcc output, etc. From Jiri Olsa. * Add on_exit implementation for systems without one, e.g. Android, from Bernhard Rosenkraenzer. * Only process events for vcpus of interest, helps handling large number of events, from David Ahern. * Cross compilation fixes for Android, from Irina Tirdea. * Add documentation on compiling for Android, from Irina Tirdea. * perf diff improvements from Jiri Olsa. * Target (task/user/cpu/syswide) handling improvements, from Namhyung Kim. * Add support in 'trace' for tracing workload given by command line, from Namhyung Kim. * ... and much more." * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (194 commits) uprobes: Use percpu_rw_semaphore to fix register/unregister vs dup_mmap() race perf evsel: Introduce is_group_member method perf powerpc: Use uapi/unistd.h to fix build error tools: Pass the target in descend tools: Honour the O= flag when tool build called from a higher Makefile tools: Define a Makefile function to do subdir processing perf ui: Always compile browser setup code perf ui: Add ui_progress__finish() perf ui gtk: Implement ui_progress functions perf ui: Introduce generic ui_progress helper perf ui tui: Move progress.c under ui/tui directory perf tools: Add basic event modifier sanity check perf tools: Omit group members from perf_evlist__disable/enable perf tools: Ensure single disable call per event in record comand perf tools: Fix 'disabled' attribute config for record command perf tools: Fix attributes for '{}' defined event groups perf tools: Use sscanf for parsing /proc/pid/maps perf tools: Add gtk.<command> config option for launching GTK browser perf tools: Fix compile error on NO_NEWT=1 build perf hists: Initialize all of he->stat with zeroes ...
2012-12-11Merge branch 'akpm' (Andrew's patchbomb)Linus Torvalds
Merge misc updates from Andrew Morton: "About half of most of MM. Going very early this time due to uncertainty over the coreautounifiednumasched things. I'll send the other half of most of MM tomorrow. The rest of MM awaits a slab merge from Pekka." * emailed patches from Andrew Morton: (71 commits) memory_hotplug: ensure every online node has NORMAL memory memory_hotplug: handle empty zone when online_movable/online_kernel mm, memory-hotplug: dynamic configure movable memory and portion memory drivers/base/node.c: cleanup node_state_attr[] bootmem: fix wrong call parameter for free_bootmem() avr32, kconfig: remove HAVE_ARCH_BOOTMEM mm: cma: remove watermark hacks mm: cma: skip watermarks check for already isolated blocks in split_free_page() mm, oom: fix race when specifying a thread as the oom origin mm, oom: change type of oom_score_adj to short mm: cleanup register_node() mm, mempolicy: remove duplicate code mm/vmscan.c: try_to_freeze() returns boolean mm: introduce putback_movable_pages() virtio_balloon: introduce migration primitives to balloon pages mm: introduce compaction and migration for ballooned pages mm: introduce a common interface for balloon pages mobility mm: redefine address_space.assoc_mapping mm: adjust address_space_operations.migratepage() return code arch/sparc/kernel/sys_sparc_64.c: s/COLOUR/COLOR/ ...
2012-12-11arch/sparc/kernel/sys_sparc_64.c: s/COLOUR/COLOR/Andrew Morton
Consistently spell this word across arch/sparc/mm and arch/sparc/kernel. Acked-by: David Miller <davem@davemloft.net> Cc: Michel Lespinasse <walken@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-11mm: use vm_unmapped_area() in hugetlbfs on sparc64 architectureMichel Lespinasse
Update the sparc64 hugetlb_get_unmapped_area function to make use of vm_unmapped_area() instead of implementing a brute force search. Signed-off-by: Michel Lespinasse <walken@google.com> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-11mm: use vm_unmapped_area() on sparc64 architectureMichel Lespinasse
Update the sparc64 arch_get_unmapped_area[_topdown] functions to make use of vm_unmapped_area() instead of implementing a brute force search. [akpm@linux-foundation.org: remove now-unused COLOUR_ALIGN_DOWN()] Signed-off-by: Michel Lespinasse <walken@google.com> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-11mm: use vm_unmapped_area() on sparc32 architectureMichel Lespinasse
Update the sparc32 arch_get_unmapped_area function to make use of vm_unmapped_area() instead of implementing a brute force search. [akpm@linux-foundation.org: fix build] [akpm@linux-foundation.org: remove now-unused COLOUR_ALIGN()] Signed-off-by: Michel Lespinasse <walken@google.com> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mundt <lethal@linux-sh.org> Acked-by: "David S. Miller" <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-11Merge tag 'tty-3.8-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull TTY/Serial merge from Greg Kroah-Hartman: "Here's the big tty/serial tree set of changes for 3.8-rc1. Contained in here is a bunch more reworks of the tty port layer from Jiri and bugfixes from Alan, along with a number of other tty and serial driver updates by the various driver authors. Also, Jiri has been coerced^Wconvinced to be the co-maintainer of the TTY layer, which is much appreciated by me. All of these have been in the linux-next tree for a while. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fixed up some trivial conflicts in the staging tree, due to the fwserial driver having come in both ways (but fixed up a bit in the serial tree), and the ioctl handling in the dgrp driver having been done slightly differently (staging tree got that one right, and removed both TIOCGSOFTCAR and TIOCSSOFTCAR). * tag 'tty-3.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (146 commits) staging: sb105x: fix potential NULL pointer dereference in mp_chars_in_buffer() staging/fwserial: Remove superfluous free staging/fwserial: Use WARN_ONCE when port table is corrupted staging/fwserial: Destruct embedded tty_port on teardown staging/fwserial: Fix build breakage when !CONFIG_BUG staging: fwserial: Add TTY-over-Firewire serial driver drivers/tty/serial/serial_core.c: clean up HIGH_BITS_OFFSET usage staging: dgrp: dgrp_tty.c: Audit the return values of get/put_user() staging: dgrp: dgrp_tty.c: Remove the TIOCSSOFTCAR ioctl handler from dgrp driver serial: ifx6x60: Add modem power off function in the platform reboot process serial: mxs-auart: unmap the scatter list before we copy the data serial: mxs-auart: disable the Receive Timeout Interrupt when DMA is enabled serial: max310x: Setup missing "can_sleep" field for GPIO tty/serial: fix ifx6x60.c declaration warning serial: samsung: add devicetree properties for non-Exynos SoCs serial: samsung: fix potential soft lockup during uart write tty: vt: Remove redundant null check before kfree. tty/8250 Add check for pci_ioremap_bar failure tty/8250 Add support for Commtech's Fastcom Async-335 and Fastcom Async-PCIe cards tty/8250 Add XR17D15x devices to the exar_handle_irq override ...
2012-12-11Merge tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
Pull device tree changes from Grant Likely: "Here are the DT changes I've got queued up for v3.8. As described below, there are a lot of bug fixes here and documentation updates but nothing major: Bug fixes, little cleanups, and documentation changes. The most invasive thing here touches a bunch of the arch directories to use a common build rule for .dtb files. There are no major changes to functionality here other than a few new helper functions." * tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux-2.6: (34 commits) arm64: Fix the dtbs target building mtd: nand: davinci: fix the binding documentation rtc: rtc-mv: Add the device tree binding documentation devicetree/bindings: Move gpio-leds binding into leds directory of/vendor-prefixes: add Imagination Technologies microblaze: use new common dtc rule c6x: use new common dtc rule openrisc: use new common dtc rule arm64: Add dtbs target for building all the enabled dtb files arm64: use new common dtc rule ARM: dt: change .dtb build rules to build in dts directory kbuild: centralize .dts->.dtb rule Fix build when CONFIG_W1_MASTER_GPIO=m b exporting "allnodes" of/spi: Honour "status=disabled" property of device of_mdio: Honour "status=disabled" property of device of_i2c: Honour "status=disabled" property of device powerpc: Fix fallout from device_node->name constification of: add 'const' for of_parse_phandle parameter *np Documentation: correct of_platform_populate() argument list script: dtc: clean generated files ...
2012-12-08Merge branch 'tip/perf/core' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace into perf/core Pull ftrace updates from Steve Rostedt. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-12-03sparc: Fix piggyback with newer binutils.David S. Miller
Newer versions of binutils mark '_end' as 'B' instead of 'A' for whatever reason. To be honest, the piggyback code doesn't actually care what kind of symbol _start and _end are, it just wants to find them and record the address. So remove the type from the match strings. Reported-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-03sparc64: exit_group should kill register windows just like plain exit.David S. Miller
Reported-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-29unify default ptrace_signal_deliverAl Viro
2012-11-29flagday: kill pt_regs argument of do_fork()Al Viro
2012-11-28flagday: don't pass regs to copy_thread()Al Viro
2012-11-28Merge branches 'no-rebases', 'arch-avr32', 'arch-blackfin', 'arch-cris', ↵Al Viro
'arch-h8300', 'arch-m32r', 'arch-mn10300', 'arch-score', 'arch-sh' and 'arch-powerpc' into for-next
2012-11-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/wireless/iwlwifi/pcie/tx.c Minor iwlwifi conflict in TX queue disabling between 'net', which removed a bogus warning, and 'net-next' which added some status register poking code. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-23Merge tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
Pull device tree regression fix from Grant Likely: "Simple build regression fix for DT device drivers on Sparc. An earlier change had masked out the of_iomap() helper on SPARC." * tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux-2.6: of/address: sparc: Declare of_iomap as an extern function for sparc again
2012-11-23of/address: sparc: Declare of_iomap as an extern function for sparc againAndreas Larsson
This bug-fix makes sure that of_iomap is defined extern for sparc so that the sparc-specific implementation of_iomap is once again used when including include/linux/of_address.h in a sparc context. OF_GPIO that is now available for sparc relies on this. The bug was inadvertently introduced in a850a75, "of/address: add empty static inlines for !CONFIG_OF", that added a static dummy inline for of_iomap when !CONFIG_OF_ADDRESS. However, CONFIG_OF_ADDRESS is never defined for sparc, but there is a sparc-specific implementation /arch/sparc/kernel/of_device_common.c. This fix takes the same approach as 0bce04b that solved the equivalent problem for of_address_to_resource. Signed-off-by: Andreas Larsson <andreas@gaisler.com> Acked-by: David Miller <davem@davemloft.net> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-11-18sparc64: not any error from do_sigaltstack() should fail rt_sigreturn()Al Viro
If a signal handler is executed on altstack and another signal comes, we will end up with rt_sigreturn() on return from the second handler getting -EPERM from do_sigaltstack(). It's perfectly OK, since we are not asking to change the settings; in fact, they couldn't have been changed during the second handler execution exactly because we'd been on altstack all along. 64bit sigreturn on sparc treats any error from do_sigaltstack() as "SIGSEGV now"; we need to switch to the same semantics we are using on other architectures. Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Minor line offset auto-merges. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-17sparc: dma-mapping: support debug_dma_mapping_errorShuah Khan
Add support for debug_dma_mapping_error() call to avoid warning from debug_dma_unmap() interface when it checks for mapping error checked status. Without this patch, device driver failed to check map error warning is generated. Signed-off-by: Shuah Khan <shuah.khan@hp.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2012-11-17drivers/of: Constify device_node->name and ->path_component_nameGrant Likely
Neither of these should ever be changed once set. Make them const and fix up the users that try to modify it in-place. In one case kmalloc+memcpy is replaced with kstrdup() to avoid modifying the string. Build tested with defconfigs on ARM, PowerPC, Sparc, MIPS, x86 among others. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Julian Calaby <julian.calaby@gmail.com>
2012-11-16Merge branch 'arch-microblaze' into no-rebasesAl Viro
2012-11-16Merge commit '517ffce4e1a03aea979fe3a18a3dd1761a24fafb' into arch-sparcAl Viro
Backmerge from the point in mainline where a trivial conflict had been introduced (arch/sparc/kernel/sys_sparc_64.c had grown sys_kern_features() right after where kernel_execve() used to be) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-11-14Merge v3.7-rc5 into tty-nextGreg Kroah-Hartman
This pulls in the 3.7-rc5 fixes into tty-next to make it easier to test.
2012-11-13tracing,x86: Add a TSC trace_clockDavid Sharp
In order to promote interoperability between userspace tracers and ftrace, add a trace_clock that reports raw TSC values which will then be recorded in the ring buffer. Userspace tracers that also record TSCs are then on exactly the same time base as the kernel and events can be unambiguously interlaced. Tested: Enabled a tracepoint and the "tsc" trace_clock and saw very large timestamp values. v2: Move arch-specific bits out of generic code. v3: Rename "x86-tsc", cleanups v7: Generic arch bits in Kbuild. Google-Bug-Id: 6980623 Link: http://lkml.kernel.org/r/1352837903-32191-1-git-send-email-dhsharp@google.com Acked-by: Ingo Molnar <mingo@kernel.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@linux.intel.com> Signed-off-by: David Sharp <dhsharp@google.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-11-09sparc64: Fix build with mix of modular vs. non-modular crypto drivers.David S. Miller
We tried linking in a single built object to hold the device table, but only works if all of the sparc64 crypto modules get built the same way (modular vs. non-modular). Just include the device ID stub into each driver source file so that the table gets compiled into the correct result in all cases. Reported-by: Meelis Roos <mroos@linux.ee> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-09sparc: Support atomic64_dec_if_positive properly.David S. Miller
Sparc32 already supported it, as a consequence of using the generic atomic64 implementation. And the sparc64 implementation is rather trivial. This allows us to set ARCH_HAS_ATOMIC64_DEC_IF_POSITIVE for all of sparc, and avoid the annoying warning from lib/atomic64_test.c Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-09of/address: sparc: Declare of_address_to_resource() as an extern function ↵Andreas Larsson
for sparc again This bug-fix makes sure that of_address_to_resource is defined extern for sparc so that the sparc-specific implementation of of_address_to_resource() is once again used when including include/linux/of_address.h in a sparc context. A number of drivers in mainline relies on this function working for sparc. The bug was introduced in a850a7554442f08d3e910c6eeb4ee216868dda1e, "of/address: add empty static inlines for !CONFIG_OF". Contrary to that commit title, the static inlines are added for !CONFIG_OF_ADDRESS, and CONFIG_OF_ADDRESS is never defined for sparc. This is good behavior for the other functions in include/linux/of_address.h, as the extern functions defined in drivers/of/address.c only gets linked when OF_ADDRESS is configured. However, for of_address_to_resource there exists a sparc-specific implementation in arch/sparc/arch/sparc/kernel/of_device_common.c Solution suggested by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andreas Larsson <andreas@gaisler.com> Acked-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: David S. Miller <davem@davemloft.net>
