path: root/arch/sparc
2016-01-20dma-mapping: always provide the dma_map_ops based implementationChristoph Hellwig
Move the generic implementation to <linux/dma-mapping.h> now that all architectures support it and remove the HAVE_DMA_ATTR Kconfig symbol now that everyone supports them. [valentinrothberg@gmail.com: remove leftovers in Kconfig] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: David Howells <dhowells@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Helge Deller <deller@gmx.de> Cc: James Hogan <james.hogan@imgtec.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Ley Foon Tan <lftan@altera.com> Cc: Mark Salter <msalter@redhat.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Steven Miao <realmz6@gmail.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Joerg Roedel <jroedel@suse.de> Cc: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Valentin Rothberg <valentinrothberg@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-20sparc: use generic dma_set_maskChristoph Hellwig
Sparc already uses the same code as the generic code for the PCI implementation but just fails the call sbus. This moves to the generic implemenation which eventually return -EIO due to the NULL dma_mask pointer in the device. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Joerg Roedel <jroedel@suse.de> Cc: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-18Merge tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhostLinus Torvalds
Pull virtio barrier rework+fixes from Michael Tsirkin: "This adds a new kind of barrier, and reworks virtio and xen to use it. Plus some fixes here and there" * tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost: (44 commits) checkpatch: add virt barriers checkpatch: check for __smp outside barrier.h checkpatch.pl: add missing memory barriers virtio: make find_vqs() checkpatch.pl-friendly virtio_balloon: fix race between migration and ballooning virtio_balloon: fix race by fill and leak s390: more efficient smp barriers s390: use generic memory barriers xen/events: use virt_xxx barriers xen/io: use virt_xxx barriers xenbus: use virt_xxx barriers virtio_ring: use virt_store_mb sh: move xchg_cmpxchg to a header by itself sh: support 1 and 2 byte xchg virtio_ring: update weak barriers to use virt_xxx Revert "virtio_ring: Update weak barriers to use dma_wmb/rmb" asm-generic: implement virt_xxx memory barriers x86: define __smp_xxx xtensa: define __smp_xxx tile: define __smp_xxx ...
2016-01-16Kconfig: remove HAVE_LATENCYTOP_SUPPORTWill Deacon
As illustrated by commit a3afe70b83fd ("[S390] latencytop s390 support."), HAVE_LATENCYTOP_SUPPORT is defined by an architecture to advertise an implementation of save_stack_trace_tsk. However, as of 9212ddb5eada ("stacktrace: provide save_stack_trace_tsk() weak alias") a dummy implementation is provided if STACKTRACE=y. Given that LATENCYTOP already depends on STACKTRACE_SUPPORT and selects STACKTRACE, we can remove HAVE_LATENCYTOP_SUPPORT altogether. Signed-off-by: Will Deacon <will.deacon@arm.com> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: James Hogan <james.hogan@imgtec.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Helge Deller <deller@gmx.de> Acked-by: Michael Ellerman <mpe@ellerman.id.au> Cc: "David S. Miller" <davem@davemloft.net> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Ingo Molnar <mingo@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-15arch/sparc/include/asm/pgtable_64.h: add pmd_[dirty|mkclean] for THPMinchan Kim
MADV_FREE needs pmd_dirty and pmd_mkclean for detecting recent overwrite of the contents since MADV_FREE syscall is called for THP page. This patch adds pmd_dirty and pmd_mkclean for THP page MADV_FREE support. Signed-off-by: Minchan Kim <minchan@kernel.org> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Cc: Shaohua Li <shli@kernel.org> Cc: <yalin.wang2010@gmail.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chen Gang <gang.chen.5i5j@gmail.com> Cc: Chris Zankel <chris@zankel.net> Cc: Daniel Micay <danielmicay@gmail.com> Cc: Darrick J. Wong <darrick.wong@oracle.com> Cc: David S. Miller <davem@davemloft.net> Cc: Helge Deller <deller@gmx.de> Cc: Hugh Dickins <hughd@google.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Jason Evans <je@fb.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Kirill A. Shutemov <kirill@shutemov.name> Cc: Matt Turner <mattst88@gmail.com> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Mika Penttil <mika.penttila@nextfour.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Rik van Riel <riel@redhat.com> Cc: Roland Dreier <roland@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Shaohua Li <shli@kernel.org> Cc: Will Deacon <will.deacon@arm.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-15sparc, thp: remove infrastructure for handling splitting PMDsKirill A. Shutemov
With new refcounting we don't need to mark PMDs splitting. Let's drop code to handle this. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Jerome Marchand <jmarchan@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Steve Capper <steve.capper@linaro.org> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-15mm: drop tail page refcountingKirill A. Shutemov
Tail page refcounting is utterly complicated and painful to support. It uses ->_mapcount on tail pages to store how many times this page is pinned. get_page() bumps ->_mapcount on tail page in addition to ->_count on head. This information is required by split_huge_page() to be able to distribute pins from head of compound page to tails during the split. We will need ->_mapcount to account PTE mappings of subpages of the compound page. We eliminate need in current meaning of ->_mapcount in tail pages by forbidding split entirely if the page is pinned. The only user of tail page refcounting is THP which is marked BROKEN for now. Let's drop all this mess. It makes get_page() and put_page() much simpler. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Tested-by: Sasha Levin <sasha.levin@oracle.com> Tested-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Jerome Marchand <jmarchan@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Steve Capper <steve.capper@linaro.org> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-14sparc64: Fix numa node distance initializationNitin Gupta
Orabug: 22495713 Currently, NUMA node distance matrix is initialized only when a machine descriptor (MD) exists. However, sun4u machines (e.g. Sun Blade 2500) do not have an MD and thus distance values were left uninitialized. The initialization is now moved such that it happens on both sun4u and sun4v. Signed-off-by: Nitin Gupta <nitin.m.gupta@oracle.com> Tested-by: Mikael Pettersson <mikpelinux@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-01-14sparc64: fix incorrect sign extension in sys_sparc64_personalityDmitry V. Levin
The value returned by sys_personality has type "long int". It is saved to a variable of type "int", which is not a problem yet because the type of task_struct->pesonality is "unsigned int". The problem is the sign extension from "int" to "long int" that happens on return from sys_sparc64_personality. For example, a userspace call personality((unsigned) -EINVAL) will result to any subsequent personality call, including absolutely harmless read-only personality(0xffffffff) call, failing with errno set to EINVAL. Signed-off-by: Dmitry V. Levin <ldv@altlinux.org> Cc: <stable@vger.kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-01-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from Davic Miller: 1) Support busy polling generically, for all NAPI drivers. From Eric Dumazet. 2) Add byte/packet counter support to nft_ct, from Floriani Westphal. 3) Add RSS/XPS support to mvneta driver, from Gregory Clement. 4) Implement IPV6_HDRINCL socket option for raw sockets, from Hannes Frederic Sowa. 5) Add support for T6 adapter to cxgb4 driver, from Hariprasad Shenai. 6) Add support for VLAN device bridging to mlxsw switch driver, from Ido Schimmel. 7) Add driver for Netronome NFP4000/NFP6000, from Jakub Kicinski. 8) Provide hwmon interface to mlxsw switch driver, from Jiri Pirko. 9) Reorganize wireless drivers into per-vendor directories just like we do for ethernet drivers. From Kalle Valo. 10) Provide a way for administrators "destroy" connected sockets via the SOCK_DESTROY socket netlink diag operation. From Lorenzo Colitti. 11) Add support to add/remove multicast routes via netlink, from Nikolay Aleksandrov. 12) Make TCP keepalive settings per-namespace, from Nikolay Borisov. 13) Add forwarding and packet duplication facilities to nf_tables, from Pablo Neira Ayuso. 14) Dead route support in MPLS, from Roopa Prabhu. 15) TSO support for thunderx chips, from Sunil Goutham. 16) Add driver for IBM's System i/p VNIC protocol, from Thomas Falcon. 17) Rationalize, consolidate, and more completely document the checksum offloading facilities in the networking stack. From Tom Herbert. 18) Support aborting an ongoing scan in mac80211/cfg80211, from Vidyullatha Kanchanapally. 19) Use per-bucket spinlock for bpf hash facility, from Tom Leiming. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1375 commits) net: bnxt: always return values from _bnxt_get_max_rings net: bpf: reject invalid shifts phonet: properly unshare skbs in phonet_rcv() dwc_eth_qos: Fix dma address for multi-fragment skbs phy: remove an unneeded condition mdio: remove an unneed condition mdio_bus: NULL dereference on allocation error net: Fix typo in netdev_intersect_features net: freescale: mac-fec: Fix build error from phy_device API change net: freescale: ucc_geth: Fix build error from phy_device API change bonding: Prevent IPv6 link local address on enslaved devices IB/mlx5: Add flow steering support net/mlx5_core: Export flow steering API net/mlx5_core: Make ipv4/ipv6 location more clear net/mlx5_core: Enable flow steering support for the IB driver net/mlx5_core: Initialize namespaces only when supported by device net/mlx5_core: Set priority attributes net/mlx5_core: Connect flow tables net/mlx5_core: Introduce modify flow table command net/mlx5_core: Managing root flow table ...
2016-01-12Merge branch 'work.misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull misc vfs updates from Al Viro: "All kinds of stuff. That probably should've been 5 or 6 separate branches, but by the time I'd realized how large and mixed that bag had become it had been too close to -final to play with rebasing. Some fs/namei.c cleanups there, memdup_user_nul() introduction and switching open-coded instances, burying long-dead code, whack-a-mole of various kinds, several new helpers for ->llseek(), assorted cleanups and fixes from various people, etc. One piece probably deserves special mention - Neil's lookup_one_len_unlocked(). Similar to lookup_one_len(), but gets called without ->i_mutex and tries to avoid ever taking it. That, of course, means that it's not useful for any directory modifications, but things like getting inode attributes in nfds readdirplus are fine with that. I really should've asked for moratorium on lookup-related changes this cycle, but since I hadn't done that early enough... I *am* asking for that for the coming cycle, though - I'm going to try and get conversion of i_mutex to rwsem with ->lookup() done under lock taken shared. There will be a patch closer to the end of the window, along the lines of the one Linus had posted last May - mechanical conversion of ->i_mutex accesses to inode_lock()/inode_unlock()/inode_trylock()/ inode_is_locked()/inode_lock_nested(). To quote Linus back then: ----- | This is an automated patch using | | sed 's/mutex_lock(&\(.*\)->i_mutex)/inode_lock(\1)/' | sed 's/mutex_unlock(&\(.*\)->i_mutex)/inode_unlock(\1)/' | sed 's/mutex_lock_nested(&\(.*\)->i_mutex,[ ]*I_MUTEX_\([A-Z0-9_]*\))/inode_lock_nested(\1, I_MUTEX_\2)/' | sed 's/mutex_is_locked(&\(.*\)->i_mutex)/inode_is_locked(\1)/' | sed 's/mutex_trylock(&\(.*\)->i_mutex)/inode_trylock(\1)/' | | with a very few manual fixups ----- I'm going to send that once the ->i_mutex-affecting stuff in -next gets mostly merged (or when Linus says he's about to stop taking merges)" * 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits) nfsd: don't hold i_mutex over userspace upcalls fs:affs:Replace time_t with time64_t fs/9p: use fscache mutex rather than spinlock proc: add a reschedule point in proc_readfd_common() logfs: constify logfs_block_ops structures fcntl: allow to set O_DIRECT flag on pipe fs: __generic_file_splice_read retry lookup on AOP_TRUNCATED_PAGE fs: xattr: Use kvfree() [s390] page_to_phys() always returns a multiple of PAGE_SIZE nbd: use ->compat_ioctl() fs: use block_device name vsprintf helper lib/vsprintf: add %*pg format specifier fs: use gendisk->disk_name where possible poll: plug an unused argument to do_poll amdkfd: don't open-code memdup_user() cdrom: don't open-code memdup_user() rsxx: don't open-code memdup_user() mtip32xx: don't open-code memdup_user() [um] mconsole: don't open-code memdup_user_nul() [um] hostaudio: don't open-code memdup_user() ...
2016-01-12sparc: define __smp_xxxMichael S. Tsirkin
This defines __smp_xxx barriers for sparc, for use by virtualization. smp_xxx barriers are removed as they are defined correctly by asm-generic/barriers.h Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
2016-01-12sparc: reuse asm-generic/barrier.hMichael S. Tsirkin
On sparc 64 bit dma_rmb, dma_wmb, smp_store_mb, smp_mb, smp_rmb, smp_wmb, read_barrier_depends and smp_read_barrier_depends match the asm-generic variants exactly. Drop the local definitions and pull in asm-generic/barrier.h instead. nop uses __asm__ __volatile but is otherwise identical to the generic version, drop that as well. This is in preparation to refactoring this code area. Note: nop() was in processor.h and not in barrier.h as on other architectures. Nothing seems to depend on it being there though. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
2016-01-08Merge branch 'for-linus' into work.miscAl Viro
2016-01-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2016-01-06net: Add eth_platform_get_mac_address() helper.David S. Miller
A repeating pattern in drivers has become to use OF node information and, if not found, platform specific host information to extract the ethernet address for a given device. Currently this is done with a call to of_get_mac_address() and then some ifdef'd stuff for SPARC. Consolidate this into a portable routine, and provide the arch_get_platform_mac_address() weak function hook for all architectures to implement if they want. Signed-off-by: David S. Miller <davem@davemloft.net>
2016-01-06net: filter: make JITs zero A for SKF_AD_ALU_XOR_XRabin Vincent
The SKF_AD_ALU_XOR_X ancillary is not like the other ancillary data instructions since it XORs A with X while all the others replace A with some loaded value. All the BPF JITs fail to clear A if this is used as the first instruction in a filter. This was found using american fuzzy lop. Add a helper to determine if A needs to be cleared given the first instruction in a filter, and use this in the JITs. Except for ARM, the rest have only been compile-tested. Fixes: 3480593131e0 ("net: filter: get rid of BPF_S_* enum") Signed-off-by: Rabin Vincent <rabin@rab.in> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-01-04soreuseport: setsockopt SO_ATTACH_REUSEPORT_[CE]BPFCraig Gallek
Expose socket options for setting a classic or extended BPF program for use when selecting sockets in an SO_REUSEPORT group. These options can be used on the first socket to belong to a group before bind or on any socket in the group after bind. This change includes refactoring of the existing sk_filter code to allow reuse of the existing BPF filter validation checks. Signed-off-by: Craig Gallek <kraig@google.com> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-01-04put the remnants of ..._user_ret() to restAl Viro
they hadn't been used in last 15 years... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-01-04Merge branch 'memdup_user_nul' into work.miscAl Viro
2015-12-31sparc: Wire up mlock2 system call.David S. Miller
2015-12-31sparc: Add all necessary direct socket system calls.David S. Miller
The GLIBC folks would like to eliminate socketcall support eventually, and this makes sense regardless so wire them all up. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-12-24sparc64: fix FP corruption in user copy functionsRob Gardner
Short story: Exception handlers used by some copy_to_user() and copy_from_user() functions do not diligently clean up floating point register usage, and this can result in a user process seeing invalid values in floating point registers. This sometimes makes the process fail. Long story: Several cpu-specific (NG4, NG2, U1, U3) memcpy functions use floating point registers and VIS alignaddr/faligndata to accelerate data copying when source and dest addresses don't align well. Linux uses a lazy scheme for saving floating point registers; It is not done upon entering the kernel since it's a very expensive operation. Rather, it is done only when needed. If the kernel ends up not using FP regs during the course of some trap or system call, then it can return to user space without saving or restoring them. The various memcpy functions begin their FP code with VISEntry (or a variation thereof), which saves the FP regs. They conclude their FP code with VISExit (or a variation) which essentially marks the FP regs "clean", ie, they contain no unsaved values. fprs.FPRS_FEF is turned off so that a lazy restore will be triggered when/if the user process accesses floating point regs again. The bug is that the user copy variants of memcpy, copy_from_user() and copy_to_user(), employ an exception handling mechanism to detect faults when accessing user space addresses, and when this handler is invoked, an immediate return from the function is forced, and VISExit is not executed, thus leaving the fprs register in an indeterminate state, but often with fprs.FPRS_FEF set and one or more dirty bits. This results in a return to user space with invalid values in the FP regs, and since fprs.FPRS_FEF is on, no lazy restore occurs. This bug affects copy_to_user() and copy_from_user() for NG4, NG2, U3, and U1. All are fixed by using a new exception handler for those loads and stores that are done during the time between VISEnter and VISExit. n.b. In NG4memcpy, the problematic code can be triggered by a copy size greater than 128 bytes and an unaligned source address. This bug is known to be the cause of random user process memory corruptions while perf is running with the callgraph option (ie, perf record -g). This occurs because perf uses copy_from_user() to read user stacks, and may fault when it follows a stack frame pointer off to an invalid page. Validation checks on the stack address just obscure the underlying problem. Signed-off-by: Rob Gardner <rob.gardner@oracle.com> Signed-off-by: Dave Aldridge <david.j.aldridge@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-12-24sparc64: Perf should save/restore fault infoRob Gardner
There have been several reports of random processes being killed with a bus error or segfault during userspace stack walking in perf. One of the root causes of this problem is an asynchronous modification to thread_info fault_address and fault_code, which stems from a perf counter interrupt arriving during kernel processing of a "benign" fault, such as a TSB miss. Since perf_callchain_user() invokes copy_from_user() to read user stacks, a fault is not only possible, but probable. Validity checks on the stack address merely cover up the problem and reduce its frequency. The solution here is to save and restore fault_address and fault_code in perf_callchain_user() so that the benign fault handler is not disturbed by a perf interrupt. Signed-off-by: Rob Gardner <rob.gardner@oracle.com> Signed-off-by: Dave Aldridge <david.j.aldridge@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-12-24sparc64: Ensure perf can access user stacksRob Gardner
When an interrupt (such as a perf counter interrupt) is delivered while executing in user space, the trap entry code puts ASI_AIUS in %asi so that copy_from_user() and copy_to_user() will access the correct memory. But if a perf counter interrupt is delivered while the cpu is already executing in kernel space, then the trap entry code will put ASI_P in %asi, and this will prevent copy_from_user() from reading any useful stack data in either of the perf_callchain_user_X functions, and thus no user callgraph data will be collected for this sample period. An additional problem is that a fault is guaranteed to occur, and though it will be silently covered up, it wastes time and could perturb state. In perf_callchain_user(), we ensure that %asi contains ASI_AIUS because we know for a fact that the subsequent calls to copy_from_user() are intended to read the user's stack. [ Use get_fs()/set_fs() -DaveM ] Signed-off-by: Rob Gardner <rob.gardner@oracle.com> Signed-off-by: Dave Aldridge <david.j.aldridge@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-12-24sparc64: Don't set %pil in rtrap_nmi too earlyRob Gardner
Commit 28a1f53 delays setting %pil to avoid potential hardirq stack overflow in the common rtrap_irq path. Setting %pil also needs to be delayed in the rtrap_nmi path for the same reason. Signed-off-by: Rob Gardner <rob.gardner@oracle.com> Signed-off-by: Dave Aldridge <david.j.aldridge@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-12-24sparc64: Add ADI capability to cpu capabilitiesKhalid Aziz
Add ADI (Application Data Integrity) capability to cpu capabilities list. ADI capability allows virtual addresses to be encoded with a tag in bits 63-60. This tag serves as an access control key for the regions of virtual address with ADI enabled and a key set on them. Hypervisor encodes this capability as "adp" in "hwcap-list" property in machine description. Signed-off-by: Khalid Aziz <khalid.aziz@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-12-23sparc: Hook up userfaultfd system callMike Kravetz
After hooking up system call, userfaultfd selftest was successful for both 32 and 64 bit version of test. Signed-off-by: Mike Kravetz <mike.kravetz@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-12-23new helpers: no_seek_end_llseek{,_size}()Al Viro
2015-11-23treewide: Remove old email addressPeter Zijlstra
There were still a number of references to my old Red Hat email address in the kernel source. Remove these while keeping the Red Hat copyright notices intact. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vince Weaver <vincent.weaver@maine.edu> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-11-09sparc/sparc64: allocate sys_membarrier system call numberMathieu Desnoyers
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Acked-by: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06Merge tag 'pci-v4.4-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI updates from Bjorn Helgaas: "Resource management: - Add support for Enhanced Allocation devices (Sean O. Stalley) - Add Enhanced Allocation register entries (Sean O. Stalley) - Handle IORESOURCE_PCI_FIXED when sizing resources (David Daney) - Handle IORESOURCE_PCI_FIXED when assigning resources (David Daney) - Handle Enhanced Allocation capability for SR-IOV devices (David Daney) - Clear IORESOURCE_UNSET when reverting to firmware-assigned address (Bjorn Helgaas) - Make Enhanced Allocation bitmasks more obvious (Bjorn Helgaas) - Expand Enhanced Allocation BAR output (Bjorn Helgaas) - Add of_pci_check_probe_only to parse "linux,pci-probe-only" (Marc Zyngier) - Fix lookup of linux,pci-probe-only property (Marc Zyngier) - Add sparc mem64 resource parsing for root bus (Yinghai Lu) PCI device hotplug: - pciehp: Queue power work requests in dedicated function (Guenter Roeck) Driver binding: - Add builtin_pci_driver() to avoid registration boilerplate (Paul Gortmaker) Virtualization: - Set SR-IOV NumVFs to zero after enumeration (Alexander Duyck) - Remove redundant validation of SR-IOV offset/stride registers (Alexander Duyck) - Remove VFs in reverse order if virtfn_add() fails (Alexander Duyck) - Reorder pcibios_sriov_disable() (Alexander Duyck) - Wait 1 second between disabling VFs and clearing NumVFs (Alexander Duyck) - Fix sriov_enable() error path for pcibios_enable_sriov() failures (Alexander Duyck) - Enable SR-IOV ARI Capable Hierarchy before reading TotalVFs (Ben Shelton) - Don't try to restore VF BARs (Wei Yang) MSI: - Don't alloc pcibios-irq when MSI is enabled (Joerg Roedel) - Add msi_controller setup_irqs() method for special multivector setup (Lucas Stach) - Export all remapped MSIs to sysfs attributes (Romain Bezut) - Disable MSI on SiS 761 (Ondrej Zary) AER: - Clear error status registers during enumeration and restore (Taku Izumi) Generic host bridge driver: - Fix lookup of linux,pci-probe-only property (Marc Zyngier) - Allow multiple hosts with different map_bus() methods (David Daney) - Pass starting bus number to pci_scan_root_bus() (David Daney) - Fix address window calculation for non-zero starting bus (David Daney) Altera host bridge driver: - Add msi.h to ARM Kbuild (Ley Foon Tan) - Add Altera PCIe host controller driver (Ley Foon Tan) - Add Altera PCIe MSI driver (Ley Foon Tan) APM X-Gene host bridge driver: - Remove msi_controller assignment (Duc Dang) Broadcom iProc host bridge driver: - Fix header comment "Corporation" misspelling (Florian Fainelli) - Fix code comment to match code (Ray Jui) - Remove unused struct iproc_pcie.irqs[] (Ray Jui) - Call pci_fixup_irqs() for ARM64 as well as ARM (Ray Jui) - Fix PCIe reset logic (Ray Jui) - Improve link detection logic (Ray Jui) - Update PCIe device tree bindings (Ray Jui) - Add outbound mapping support (Ray Jui) Freescale i.MX6 host bridge driver: - Return real error code from imx6_add_pcie_port() (Fabio Estevam) - Add PCIE_PHY_RX_ASIC_OUT_VALID definition (Fabio Estevam) Freescale Layerscape host bridge driver: - Remove ls_pcie_establish_link() (Minghuan Lian) - Ignore PCIe controllers in Endpoint mode (Minghuan Lian) - Factor out SCFG related function (Minghuan Lian) - Update ls_add_pcie_port() (Minghuan Lian) - Remove unused fields from struct ls_pcie (Minghuan Lian) - Add support for LS1043a and LS2080a (Minghuan Lian) - Add ls_pcie_msi_host_init() (Minghuan Lian) HiSilicon host bridge driver: - Add HiSilicon SoC Hip05 PCIe driver (Zhou Wang) Marvell MVEBU host bridge driver: - Return zero for reserved or unimplemented config space (Russell King) - Use exact config access size; don't read/modify/write (Russell King) - Use of_get_available_child_count() (Russell King) - Use for_each_available_child_of_node() to walk child nodes (Russell King) - Report full node name when reporting a DT error (Russell King) - Use port->name rather than "PCIe%d.%d" (Russell King) - Move port parsing and resource claiming to separate function (Russell King) - Fix memory leaks and refcount leaks (Russell King) - Split port parsing and resource claiming from port setup (Russell King) - Use gpio_set_value_cansleep() (Russell King) - Use devm_kcalloc() to allocate an array (Russell King) - Use gpio_desc to carry around gpio (Russell King) - Improve clock/reset handling (Russell King) - Add PCI Express root complex capability block (Russell King) - Remove code restricting accesses to slot 0 (Russell King) NVIDIA Tegra host bridge driver: - Wrap static pgprot_t initializer with __pgprot() (Ard Biesheuvel) Renesas R-Car host bridge driver: - Build pci-rcar-gen2.c only on ARM (Geert Uytterhoeven) - Build pcie-rcar.c only on ARM (Geert Uytterhoeven) - Make PCI aware of the I/O resources (Phil Edworthy) - Remove dependency on ARM-specific struct hw_pci (Phil Edworthy) - Set root bus nr to that provided in DT (Phil Edworthy) - Fix I/O offset for multiple host bridges (Phil Edworthy) ST Microelectronics SPEAr13xx host bridge driver: - Fix dw_pcie_cfg_read/write() usage (Gabriele Paoloni) Synopsys DesignWare host bridge driver: - Make "clocks" and "clock-names" optional DT properties (Bhupesh Sharma) - Use exact access size in dw_pcie_cfg_read() (Gabriele Paoloni) - Simplify dw_pcie_cfg_read/write() interfaces (Gabriele Paoloni) - Require config accesses to be naturally aligned (Gabriele Paoloni) - Make "num-lanes" an optional DT property (Gabriele Paoloni) - Move calculation of bus addresses to DRA7xx (Gabriele Paoloni) - Replace ARM pci_sys_data->align_resource with global function pointer (Gabriele Paoloni) - Factor out MSI msg setup (Lucas Stach) - Implement multivector MSI IRQ setup (Lucas Stach) - Make get_msi_addr() return phys_addr_t, not u32 (Lucas Stach) - Set up high part of MSI target address (Lucas Stach) - Fix PORT_LOGIC_LINK_WIDTH_MASK (Zhou Wang) - Revert "PCI: designware: Program ATU with untranslated address" (Zhou Wang) - Use of_pci_get_host_bridge_resources() to parse DT (Zhou Wang) - Make driver arch-agnostic (Zhou Wang) Miscellaneous: - Make x86 pci_subsys_init() static (Alexander Kuleshov) - Turn off Request Attributes to avoid Chelsio T5 Completion erratum (Hariprasad Shenai)" * tag 'pci-v4.4-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (94 commits) PCI: altera: Add Altera PCIe MSI driver PCI: hisi: Add HiSilicon SoC Hip05 PCIe driver PCI: layerscape: Add ls_pcie_msi_host_init() PCI: layerscape: Add support for LS1043a and LS2080a PCI: layerscape: Remove unused fields from struct ls_pcie PCI: layerscape: Update ls_add_pcie_port() PCI: layerscape: Factor out SCFG related function PCI: layerscape: Ignore PCIe controllers in Endpoint mode PCI: layerscape: Remove ls_pcie_establish_link() PCI: designware: Make "clocks" and "clock-names" optional DT properties PCI: designware: Make driver arch-agnostic ARM/PCI: Replace pci_sys_data->align_resource with global function pointer PCI: designware: Use of_pci_get_host_bridge_resources() to parse DT Revert "PCI: designware: Program ATU with untranslated address" PCI: designware: Move calculation of bus addresses to DRA7xx PCI: designware: Make "num-lanes" an optional DT property PCI: designware: Require config accesses to be naturally aligned PCI: designware: Simplify dw_pcie_cfg_read/write() interfaces PCI: designware: Use exact access size in dw_pcie_cfg_read() PCI: spear: Fix dw_pcie_cfg_read/write() usage ...
2015-11-05Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge patch-bomb from Andrew Morton: - inotify tweaks - some ocfs2 updates (many more are awaiting review) - various misc bits - kernel/watchdog.c updates - Some of mm. I have a huge number of MM patches this time and quite a lot of it is quite difficult and much will be held over to next time. * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (162 commits) selftests: vm: add tests for lock on fault mm: mlock: add mlock flags to enable VM_LOCKONFAULT usage mm: introduce VM_LOCKONFAULT mm: mlock: add new mlock system call mm: mlock: refactor mlock, munlock, and munlockall code kasan: always taint kernel on report mm, slub, kasan: enable user tracking by default with KASAN=y kasan: use IS_ALIGNED in memory_is_poisoned_8() kasan: Fix a type conversion error lib: test_kasan: add some testcases kasan: update reference to kasan prototype repo kasan: move KASAN_SANITIZE in arch/x86/boot/Makefile kasan: various fixes in documentation kasan: update log messages kasan: accurately determine the type of the bad access kasan: update reported bug types for kernel memory accesses kasan: update reported bug types for not user nor kernel memory accesses mm/kasan: prevent deadlock in kasan reporting mm/kasan: don't use kasan shadow pointer in generic functions mm/kasan: MODULE_VADDR is not available on all archs ...
2015-11-05mm: mlock: add mlock flags to enable VM_LOCKONFAULT usageEric B Munson
The previous patch introduced a flag that specified pages in a VMA should be placed on the unevictable LRU, but they should not be made present when the area is created. This patch adds the ability to set this state via the new mlock system calls. We add MLOCK_ONFAULT for mlock2 and MCL_ONFAULT for mlockall. MLOCK_ONFAULT will set the VM_LOCKONFAULT modifier for VM_LOCKED. MCL_ONFAULT should be used as a modifier to the two other mlockall flags. When used with MCL_CURRENT, all current mappings will be marked with VM_LOCKED | VM_LOCKONFAULT. When used with MCL_FUTURE, the mm->def_flags will be marked with VM_LOCKED | VM_LOCKONFAULT. When used with both MCL_CURRENT and MCL_FUTURE, all current mappings and mm->def_flags will be marked with VM_LOCKED | VM_LOCKONFAULT. Prior to this patch, mlockall() will unconditionally clear the mm->def_flags any time it is called without MCL_FUTURE. This behavior is maintained after adding MCL_ONFAULT. If a call to mlockall(MCL_FUTURE) is followed by mlockall(MCL_CURRENT), the mm->def_flags will be cleared and new VMAs will be unlocked. This remains true with or without MCL_ONFAULT in either mlockall() invocation. munlock() will unconditionally clear both vma flags. munlockall() unconditionally clears for VMA flags on all VMAs and in the mm->def_flags field. Signed-off-by: Eric B Munson <emunson@akamai.com> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Guenter Roeck <linux@roeck-us.net> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Shuah Khan <shuahkh@osg.samsung.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
Pull sparc updates from David Miller: "Just a couple of fixes/cleanups: - Correct NUMA latency calculations on sparc64, from Nitin Gupta. - ASI_ST_BLKINIT_MRU_S value was wrong, from Rob Gardner. - Fix non-faulting load handling of non-quad values, also from Rob Gardner. - Cleanup VISsave assembler, from Sam Ravnborg. - Fix iommu-common code so it doesn't emit rediculous warnings on some architectures, particularly ARM" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: sparc64: Fix numa distance values sparc64: Don't restrict fp regs for no-fault loads iommu-common: Fix error code used in iommu_tbl_range_{alloc,free}(). sparc64: use ENTRY/ENDPROC in VISsave sparc64: Fix incorrect ASI_ST_BLKINIT_MRU_S value
2015-11-04sparc64: Fix numa distance valuesNitin Gupta
Orabug: 21896119 Use machine descriptor (MD) to get node latency values instead of just using default values. Testing: On an T5-8 system with: - total nodes = 8 - self latencies = 0x26d18 - latency to other nodes = 0x3a598 => latency ratio = ~1.5 output of numactl --hardware - before fix: node distances: node 0 1 2 3 4 5 6 7 0: 10 20 20 20 20 20 20 20 1: 20 10 20 20 20 20 20 20 2: 20 20 10 20 20 20 20 20 3: 20 20 20 10 20 20 20 20 4: 20 20 20 20 10 20 20 20 5: 20 20 20 20 20 10 20 20 6: 20 20 20 20 20 20 10 20 7: 20 20 20 20 20 20 20 10 - after fix: node distances: node 0 1 2 3 4 5 6 7 0: 10 15 15 15 15 15 15 15 1: 15 10 15 15 15 15 15 15 2: 15 15 10 15 15 15 15 15 3: 15 15 15 10 15 15 15 15 4: 15 15 15 15 10 15 15 15 5: 15 15 15 15 15 10 15 15 6: 15 15 15 15 15 15 10 15 7: 15 15 15 15 15 15 15 10 Signed-off-by: Nitin Gupta <nitin.m.gupta@oracle.com> Reviewed-by: Chris Hyser <chris.hyser@oracle.com> Reviewed-by: Santosh Shilimkar <santosh.shilimkar@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-04sparc64: Don't restrict fp regs for no-fault loadsRob Gardner
The function handle_ldf_stq() deals with no-fault ASI loads and stores, but restricts fp registers to quad word regs (ie, %f0, %f4 etc). This is valid for the STQ case, but unnecessarily restricts loads, which may be single precision, double, or quad. This results in SIGFPE being raised for this instruction when the source address is invalid: ldda [%g1] ASI_PNF, %f2 but not for this one: ldda [%g1] ASI_PNF, %f4 The validation check for quad register is moved to within the STQ block so that loads are not affected by the check. An additional problem is that the calculation for freg is incorrect when a single precision load is being handled. This causes %f1 to be seen as %f32 etc, and the incorrect register ends up being overwritten. This code sequence demonstrates the problem: ldd [%g1], %f32 ! g1 = valid address lda [%i3] ASI_PNF, %f1 ! i3 = invalid address std %f32, [%g1] This is corrected by basing the freg calculation on the load size. Signed-off-by: Rob Gardner <rob.gardner@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-04iommu-common: Fix error code used in iommu_tbl_range_{alloc,free}().David S. Miller
The value returned from iommu_tbl_range_alloc() (and the one passed in as a fourth argument to iommu_tbl_range_free) is not a DMA address, it is rather an index into the IOMMU page table. Therefore using DMA_ERROR_CODE is not appropriate. Use a more type matching error code define, IOMMU_ERROR_CODE, and update all users of this interface. Reported-by: Andre Przywara <andre.przywara@arm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: Changes of note: 1) Allow to schedule ICMP packets in IPVS, from Alex Gartrell. 2) Provide FIB table ID in ipv4 route dumps just as ipv6 does, from David Ahern. 3) Allow the user to ask for the statistics to be filtered out of ipv4/ipv6 address netlink dumps. From Sowmini Varadhan. 4) More work to pass the network namespace context around deep into various packet path APIs, starting with the netfilter hooks. From Eric W Biederman. 5) Add layer 2 TX/RX checksum offloading to qeth driver, from Thomas Richter. 6) Use usec resolution for SYN/ACK RTTs in TCP, from Yuchung Cheng. 7) Support Very High Throughput in wireless MESH code, from Bob Copeland. 8) Allow setting the ageing_time in switchdev/rocker. From Scott Feldman. 9) Properly autoload L2TP type modules, from Stephen Hemminger. 10) Fix and enable offload features by default in 8139cp driver, from David Woodhouse. 11) Support both ipv4 and ipv6 sockets in a single vxlan device, from Jiri Benc. 12) Fix CWND limiting of thin streams in TCP, from Bendik Rønning Opstad. 13) Fix IPSEC flowcache overflows on large systems, from Steffen Klassert. 14) Convert bridging to track VLANs using rhashtable entries rather than a bitmap. From Nikolay Aleksandrov. 15) Make TCP listener handling completely lockless, this is a major accomplishment. Incoming request sockets now live in the established hash table just like any other socket too. From Eric Dumazet. 15) Provide more bridging attributes to netlink, from Nikolay Aleksandrov. 16) Use hash based algorithm for ipv4 multipath routing, this was very long overdue. From Peter Nørlund. 17) Several y2038 cures, mostly avoiding timespec. From Arnd Bergmann. 18) Allow non-root execution of EBPF programs, from Alexei Starovoitov. 19) Support SO_INCOMING_CPU as setsockopt, from Eric Dumazet. This influences the port binding selection logic used by SO_REUSEPORT. 20) Add ipv6 support to VRF, from David Ahern. 21) Add support for Mellanox Spectrum switch ASIC, from Jiri Pirko. 22) Add rtl8xxxu Realtek wireless driver, from Jes Sorensen. 23) Implement RACK loss recovery in TCP, from Yuchung Cheng. 24) Support multipath routes in MPLS, from Roopa Prabhu. 25) Fix POLLOUT notification for listening sockets in AF_UNIX, from Eric Dumazet. 26) Add new QED Qlogic river, from Yuval Mintz, Manish Chopra, and Sudarsana Kalluru. 27) Don't fetch timestamps on AF_UNIX sockets, from Hannes Frederic Sowa. 28) Support ipv6 geneve tunnels, from John W Linville. 29) Add flood control support to switchdev layer, from Ido Schimmel. 30) Fix CHECKSUM_PARTIAL handling of potentially fragmented frames, from Hannes Frederic Sowa. 31) Support persistent maps and progs in bpf, from Daniel Borkmann. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1790 commits) sh_eth: use DMA barriers switchdev: respect SKIP_EOPNOTSUPP flag in case there is no recursion net: sched: kill dead code in sch_choke.c irda: Delete an unnecessary check before the function call "irlmp_unregister_service" net: dsa: mv88e6xxx: include DSA ports in VLANs net: dsa: mv88e6xxx: disable SA learning for DSA and CPU ports net/core: fix for_each_netdev_feature vlan: Invoke driver vlan hooks only if device is present arcnet/com20020: add LEDS_CLASS dependency bpf, verifier: annotate verbose printer with __printf dp83640: Only wait for timestamps for packets with timestamping enabled. ptp: Change ptp_class to a proper bitmask dp83640: Prune rx timestamp list before reading from it dp83640: Delay scheduled work. dp83640: Include hash in timestamp/packet matching ipv6: fix tunnel error handling net/mlx5e: Fix LSO vlan insertion net/mlx5e: Re-eanble client vlan TX acceleration net/mlx5e: Return error in case mlx5e_set_features() fails net/mlx5e: Don't allow more than max supported channels ...
2015-11-03Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf updates from Ingo Molnar: "Kernel side changes: - Improve accuracy of perf/sched clock on x86. (Adrian Hunter) - Intel DS and BTS updates. (Alexander Shishkin) - Intel cstate PMU support. (Kan Liang) - Add group read support to perf_event_read(). (Peter Zijlstra) - Branch call hardware sampling support, implemented on x86 and PowerPC. (Stephane Eranian) - Event groups transactional interface enhancements. (Sukadev Bhattiprolu) - Enable proper x86/intel/uncore PMU support on multi-segment PCI systems. (Taku Izumi) - ... misc fixes and cleanups. The perf tooling team was very busy again with 200+ commits, the full diff doesn't fit into lkml size limits. Here's an (incomplete) list of the tooling highlights: New features: - Change the default event used in all tools (record/top): use the most precise "cycles" hw counter available, i.e. when the user doesn't specify any event, it will try using cycles:ppp, cycles:pp, etc and fall back transparently until it finds a working counter. (Arnaldo Carvalho de Melo) - Integration of perf with eBPF that, given an eBPF .c source file (or .o file built for the 'bpf' target with clang), will get it automatically built, validated and loaded into the kernel via the sys_bpf syscall, which can then be used and seen using 'perf trace' and other tools. (Wang Nan) Various user interface improvements: - Automatic pager invocation on long help output. (Namhyung Kim) - Search for more options when passing args to -h, e.g.: (Arnaldo Carvalho de Melo) $ perf report -h interface Usage: perf report [<options>] --gtk Use the GTK2 interface --stdio Use the stdio interface --tui Use the TUI interface - Show ordered command line options when -h is used or when an unknown option is specified. (Arnaldo Carvalho de Melo) - If options are passed after -h, show just its descriptions, not all options. (Arnaldo Carvalho de Melo) - Implement column based horizontal scrolling in the hists browser (top, report), making it possible to use the TUI for things like 'perf mem report' where there are many more columns than can fit in a terminal. (Arnaldo Carvalho de Melo) - Enhance the error reporting of tracepoint event parsing, e.g.: $ oldperf record -e sched:sched_switc usleep 1 event syntax error: 'sched:sched_switc' \___ unknown tracepoint Run 'perf list' for a list of valid events Now we get the much nicer: $ perf record -e sched:sched_switc ls event syntax error: 'sched:sched_switc' \___ can't access trace events Error: No permissions to read /sys/kernel/debug/tracing/events/sched/sched_switc Hint: Try 'sudo mount -o remount,mode=755 /sys/kernel/debug' And after we have those mount point permissions fixed: $ perf record -e sched:sched_switc ls event syntax error: 'sched:sched_switc' \___ unknown tracepoint Error: File /sys/kernel/debug/tracing/events/sched/sched_switc not found. Hint: Perhaps this kernel misses some CONFIG_ setting to enable this feature?. I.e. basically now the event parsing routing uses the strerror_open() routines introduced by and used in 'perf trace' work. (Jiri Olsa) - Fail properly when pattern matching fails to find a tracepoint, i.e. '-e non:existent' was being correctly handled, with a proper error message about that not being a valid event, but '-e non:existent*' wasn't, fix it. (Jiri Olsa) - Do event name substring search as last resort in 'perf list'. (Arnaldo Carvalho de Melo) E.g.: # perf list clock List of pre-defined events (to be used in -e): cpu-clock [Software event] task-clock [Software event] uncore_cbox_0/clockticks/ [Kernel PMU event] uncore_cbox_1/clockticks/ [Kernel PMU event] kvm:kvm_pvclock_update [Tracepoint event] kvm:kvm_update_master_clock [Tracepoint event] power:clock_disable [Tracepoint event] power:clock_enable [Tracepoint event] power:clock_set_rate [Tracepoint event] syscalls:sys_enter_clock_adjtime [Tracepoint event] syscalls:sys_enter_clock_getres [Tracepoint event] syscalls:sys_enter_clock_gettime [Tracepoint event] syscalls:sys_enter_clock_nanosleep [Tracepoint event] syscalls:sys_enter_clock_settime [Tracepoint event] syscalls:sys_exit_clock_adjtime [Tracepoint event] syscalls:sys_exit_clock_getres [Tracepoint event] syscalls:sys_exit_clock_gettime [Tracepoint event] syscalls:sys_exit_clock_nanosleep [Tracepoint event] syscalls:sys_exit_clock_settime [Tracepoint event] Intel PT hardware tracing enhancements: - Accept a zero --itrace period, meaning "as often as possible". In the case of Intel PT that is the same as a period of 1 and a unit of 'instructions' (i.e. --itrace=i1i). (Adrian Hunter) - Harmonize itrace's synthesized callchains with the existing --max-stack tool option. (Adrian Hunter) - Allow time to be displayed in nanoseconds in 'perf script'. (Adrian Hunter) - Fix potential infinite loop when handling Intel PT timestamps. (Adrian Hunter) - Slighly improve Intel PT debug logging. (Adrian Hunter) - Warn when AUX data has been lost, just like when processing PERF_RECORD_LOST. (Adrian Hunter) - Further document export-to-postgresql.py script. (Adrian Hunter) - Add option to synthesize branch stack from auxtrace data. (Adrian Hunter) Misc notable changes: - Switch the default callchain output mode to 'graph,0.5,caller', to make it look like the default for other tools, reducing the learning curve for people used to 'caller' based viewing. (Arnaldo Carvalho de Melo) - various call chain usability enhancements. (Namhyung Kim) - Introduce the 'P' event modifier, meaning 'max precision level, please', i.e.: $ perf record -e cycles:P usleep 1 Is now similar to: $ perf record usleep 1 Useful, for instance, when specifying multiple events. (Jiri Olsa) - Add 'socket' sort entry, to sort by the processor socket in 'perf top' and 'perf report'. (Kan Liang) - Introduce --socket-filter to 'perf report', for filtering by processor socket. (Kan Liang) - Add new "Zoom into Processor Socket" operation in the perf hists browser, used in 'perf top' and 'perf report'. (Kan Liang) - Allow probing on kmodules without DWARF. (Masami Hiramatsu) - Fix 'perf probe -l' for probes added to kernel module functions. (Masami Hiramatsu) - Preparatory work for the 'perf stat record' feature that will allow generating perf.data files with counting data in addition to the sampling mode we have now (Jiri Olsa) - Update libtraceevent KVM plugin. (Paolo Bonzini) - ... plus lots of other enhancements that I failed to list properly, by: Adrian Hunter, Alexander Shishkin, Andi Kleen, Andrzej Hajda, Arnaldo Carvalho de Melo, Dima Kogan, Don Zickus, Geliang Tang, He Kuang, Huaitong Han, Ingo Molnar, Jan Stancek, Jiri Olsa, Kan Liang, Kirill Tkhai, Masami Hiramatsu, Matt Fleming, Namhyung Kim, Paolo Bonzini, Peter Zijlstra, Rabin Vincent, Scott Wood, Stephane Eranian, Sukadev Bhattiprolu, Taku Izumi, Vaishali Thakkar, Wang Nan, Yang Shi and Yunlong Song" * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (260 commits) perf unwind: Pass symbol source to libunwind tools build: Fix libiberty feature detection perf tools: Compile scriptlets to BPF objects when passing '.c' to --event perf record: Add clang options for compiling BPF scripts perf bpf: Attach eBPF filter to perf event perf tools: Make sure fixdep is built before libbpf perf script: Enable printing of branch stack perf trace: Add cmd string table to decode sys_bpf first arg perf bpf: Collect perf_evsel in BPF object files perf tools: Load eBPF object into kernel perf tools: Create probe points for BPF programs perf tools: Enable passing bpf object file to --event perf ebpf: Add the libbpf glue perf tools: Make perf depend on libbpf perf symbols: Fix endless loop in dso__split_kallsyms_for_kcore perf tools: Enable pre-event inherit setting by config terms perf symbols: we can now read separate debug-info files based on a build ID perf symbols: Fix type error when reading a build-id perf tools: Search for more options when passing args to -h perf stat: Cache aggregated map entries in extra cpumap ...
2015-10-29sparc/PCI: Add mem64 resource parsing for root busYinghai Lu
David reported that a T5-8 sparc system failed to boot with: pci_sun4v f02dbcfc: PCI host bridge to bus 0000:00 pci_bus 0000:00: root bus resource [io 0x804000000000-0x80400fffffff] (bus address [0x0000-0xfffffff]) pci_bus 0000:00: root bus resource [mem 0x800000000000-0x80007effffff] (bus address [0x00000000-0x7effffff]) pci 0000:00:01.0: can't claim BAR 15 [mem 0x100000000-0x4afffffff pref]: no compatible bridge window Note that we don't know about a host bridge aperture that contains BAR 15. OF does report a MEM64 aperture, but before this patch, pci_determine_mem_io_space() ignored it. Add support for host bridge apertures with 64-bit PCI addresses. Also set IORESOURCE_MEM_64 for PCI device and bridge resources in PCI 64-bit memory space. Sparc doesn't actually print the device and bridge resources, but after this patch, we should have the equivalent of this: pci_sun4v f02dbcfc: PCI host bridge to bus 0000:00 pci_bus 0000:00: root bus resource [io 0x804000000000-0x80400fffffff] (bus address [0x0000-0xfffffff]) pci_bus 0000:00: root bus resource [mem 0x800000000000-0x80007effffff] (bus address [0x00000000-0x7effffff]) pci_bus 0000:00: root bus resource [mem 0x800100000000-0x8007ffffffff] (bus address [0x100000000-0x7ffffffff]) pci 0000:00:01.0: bridge window [mem 0x800100000000-0x8004afffffff 64bit pref] [bhelgaas: changelog, URL to David's report] Fixes: d63e2e1f3df9 ("sparc/PCI: Clip bridge windows to fit in upstream windows") Link: http://lkml.kernel.org/r/5514391F.2030300@oracle.com Reported-by: David Ahern <david.ahern@oracle.com> Tested-by: David Ahern <david.ahern@oracle.com> Tested-by: Khalid Aziz <khalid.aziz@oracle.com> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2015-10-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/usb/asix_common.c net/ipv4/inet_connection_sock.c net/switchdev/switchdev.c In the inet_connection_sock.c case the request socket hashing scheme is completely different in net-next. The other two conflicts were overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-10-20Merge tag 'v4.3-rc6' into locking/core, to pick up fixes before applying new ↵Ingo Molnar
changes Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-10-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto fixes from Herbert Xu: "This fixes the following issues: - Fix AVX detection to prevent use of non-existent AESNI. - Some SPARC ciphers did not set their IV size which may lead to memory corruption" * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: ahash - ensure statesize is non-zero crypto: camellia_aesni_avx - Fix CPU feature checks crypto: sparc - initialize blkcipher.ivsize
2015-10-08crypto: sparc - initialize blkcipher.ivsizeDave Kleikamp
Some of the crypto algorithms write to the initialization vector, but no space has been allocated for it. This clobbers adjacent memory. Cc: stable@vger.kernel.org Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-10-03ebpf: migrate bpf_prog's flags to bitfieldDaniel Borkmann
As we need to add further flags to the bpf_prog structure, lets migrate both bools to a bitfield representation. The size of the base structure (excluding insns) remains unchanged at 40 bytes. Add also tags for the kmemchecker, so that it doesn't throw false positives. Even in case gcc would generate suboptimal code, it's not being accessed in performance critical paths. Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-28Merge branch 'linus' into perf/core, to pick up fixes before applying new ↵Ingo Molnar
2015-09-23atomic, arch: Audit atomic_{read,set}()Peter Zijlstra
This patch makes sure that atomic_{read,set}() are at least {READ,WRITE}_ONCE(). We already had the 'requirement' that atomic_read() should use ACCESS_ONCE(), and most archs had this, but a few were lacking. All are now converted to use READ_ONCE(). And, by a symmetry and general paranoia argument, upgrade atomic_set() to use WRITE_ONCE(). Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: james.hogan@imgtec.com Cc: linux-kernel@vger.kernel.org Cc: oleg@redhat.com Cc: will.deacon@arm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-09-16genirq: Remove irq argument from irq flow handlersThomas Gleixner
Most interrupt flow handlers do not use the irq argument. Those few which use it can retrieve the irq number from the irq descriptor. Remove the argument. Search and replace was done with coccinelle and some extra helper scripts around it. Thanks to Julia for her help! Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Cc: Jiang Liu <jiang.liu@linux.intel.com>
2015-09-13perf/core: Drop PERF_EVENT_TXNSukadev Bhattiprolu
We currently use PERF_EVENT_TXN flag to determine if we are in the middle of a transaction. If in a transaction, we defer the schedulability checks from pmu->add() operation to the pmu->commit() operation. Now that we have "transaction types" (PERF_PMU_TXN_ADD, PERF_PMU_TXN_READ) we can use the type to determine if we are in a transaction and drop the PERF_EVENT_TXN flag. When PERF_EVENT_TXN is dropped, the cpuhw->group_flag on some architectures becomes unused, so drop that field as well. This is an extension of the Powerpc patch from Peter Zijlstra to s390, Sparc and x86 architectures. Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vince Weaver <vincent.weaver@maine.edu> Link: http://lkml.kernel.org/r/1441336073-22750-11-git-send-email-sukadev@linux.vnet.ibm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
