path: root/arch/sparc
2009-07-27mm: Pass virtual address to [__]p{te,ud,md}_free_tlb()Benjamin Herrenschmidt
mm: Pass virtual address to [__]p{te,ud,md}_free_tlb() Upcoming paches to support the new 64-bit "BookE" powerpc architecture will need to have the virtual address corresponding to PTE page when freeing it, due to the way the HW table walker works. Basically, the TLB can be loaded with "large" pages that cover the whole virtual space (well, sort-of, half of it actually) represented by a PTE page, and which contain an "indirect" bit indicating that this TLB entry RPN points to an array of PTEs from which the TLB can then create direct entries. Thus, in order to invalidate those when PTE pages are deleted, we need the virtual address to pass to tlbilx or tlbivax instructions. The old trick of sticking it somewhere in the PTE page struct page sucks too much, the address is almost readily available in all call sites and almost everybody implemets these as macros, so we may as well add the argument everywhere. I added it to the pmd and pud variants for consistency. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: David Howells <dhowells@redhat.com> [MN10300 & FRV] Acked-by: Nick Piggin <npiggin@suse.de> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: wm97xx_batery: replace driver_data with dev_get_drvdata() omap: video: remove direct access of driver_data Sound: remove direct access of driver_data driver model: fix show/store prototypes in doc. Firmware: firmware_class, fix lock imbalance Driver Core: remove BUS_ID_SIZE sparc: remove driver-core BUS_ID_SIZE partitions: fix broken uevent_suppress conversion devres: WARN() and return, don't crash on device_del() of uninitialized device
2009-07-12sparc: remove driver-core BUS_ID_SIZEKay Sievers
The name size limit is gone from the driver-core, the BUS_ID_SIZE value will be removed. Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-10sched: INIT_PREEMPT_COUNTPeter Zijlstra
Pull the initial preempt_count value into a single definition site. Maintainers for: alpha, ia64 and m68k, please have a look, your arch code is funny. The header magic is a bit odd, but similar to the KERNEL_DS one, CPP waits with expanding these macros until the INIT_THREAD_INFO macro itself is expanded, which is in arch/*/kernel/init_task.c where we've already included sched.h so we're good. Cc: tony.luck@intel.com Cc: rth@twiddle.net Cc: geert@linux-m68k.org Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-25sparc32: Fix makefile not generating required filesJulian Calaby
The tftpboot build was failing with missing file errors. It turns out that $(obj)/image wasn't being generated which was causing the a.out conversion to be skipped and hence piggyback to be called with nonexistent files. Signed-off-by: Julian Calaby <julian.calaby@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-25sparc32: Fix tftpboot.img MakefileJulian Calaby
2009-06-25sparc: fix tftpboot.img buildSam Ravnborg
Kjetil Oftedal mentioned that piggyback_32 was failing when building a sparc image. I tracked this down to the fact that the kernel no longer provided an absolute symbol named "end". Commit 86ed40bd6fe511d26bb8f3fa65a84cb65c235366 ("sparc: unify sections.h") renamed end to _end but failed to update piggyback_32. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Kjetil Oftedal <oftedal@gmail.com> Cc: Robert Reif <reif@earthlink.net> Signed-off-by: Julian Calaby <julian.calaby@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-25sparc32: Fix obvious build issues for tftpboot.img build.Robert Reif
Signed-off-by: Robert Reif <reif@earthlink.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-25sparc64: Fix build warnings in piggyback_64.cJulian Calaby
This patch fixes the following build warnings: arch/sparc/boot/piggyback_64.c: In function 'main': arch/sparc/boot/piggyback_64.c:44: warning: 'end' may be used uninitialized in this function arch/sparc/boot/piggyback_64.c:44: warning: 'start' may be used uninitialized in this function Signed-off-by: Julian Calaby <julian.calaby@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-25sparc64: Don't use alloc_bootmem() in init_IRQ() code paths.David S. Miller
The page allocator and SLAB are available at this point now, and if we still try to use bootmem allocations here the kernel spits out warnings. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-21Move FAULT_FLAG_xyz into handle_mm_fault() callersLinus Torvalds
This allows the callers to now pass down the full set of FAULT_FLAG_xyz flags to handle_mm_fault(). All callers have been (mechanically) converted to the new calling convention, there's almost certainly room for architectures to clean up their code and then add FAULT_FLAG_RETRY when that support is added. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-next-2.6: sparc64: Fix UP bootup regression.
2009-06-18sparc64: Fix UP bootup regression.David S. Miller
Commit b696fdc259f0d94348a9327bed352fac44d4883d ("sparc64: Defer cpu_data() setup until end of per-cpu data initialization.") broke bootup for UP builds because the cpu_data() initialization only occurs in setup_per_cpu_areas() which is never compiled in nor called in UP builds. Fix this up by calling the setups directly from init_64.c when non-SMP. Reported-by: Alexander Beregalov <a.beregalov@gmail.com> Tested-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-17Delete pcibios_select_rootMatthew Wilcox
This function was only used by pci_claim_resource(), and the last commit deleted that use. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16Merge branch 'akpm'Linus Torvalds
* akpm: (182 commits) fbdev: bf54x-lq043fb: use kzalloc over kmalloc/memset fbdev: *bfin*: fix __dev{init,exit} markings fbdev: *bfin*: drop unnecessary calls to memset fbdev: bfin-t350mcqb-fb: drop unused local variables fbdev: blackfin has __raw I/O accessors, so use them in fb.h fbdev: s1d13xxxfb: add accelerated bitblt functions tcx: use standard fields for framebuffer physical address and length fbdev: add support for handoff from firmware to hw framebuffers intelfb: fix a bug when changing video timing fbdev: use framebuffer_release() for freeing fb_info structures radeon: P2G2CLK_ALWAYS_ONb tested twice, should 2nd be P2G2CLK_DAC_ALWAYS_ONb? s3c-fb: CPUFREQ frequency scaling support s3c-fb: fix resource releasing on error during probing carminefb: fix possible access beyond end of carmine_modedb[] acornfb: remove fb_mmap function mb862xxfb: use CONFIG_OF instead of CONFIG_PPC_OF mb862xxfb: restrict compliation of platform driver to PPC Samsung SoC Framebuffer driver: add Alpha Channel support atmel-lcdc: fix pixclock upper bound detection offb: use framebuffer_alloc() to allocate fb_info struct ... Manually fix up conflicts due to kmemcheck in mm/slab.c
2009-06-16kmap_types: make most arches use generic header fileRandy Dunlap
Convert most arches to use asm-generic/kmap_types.h. Move the KM_FENCE_ macro additions into asm-generic/kmap_types.h, controlled by __WITH_KM_FENCE from each arch's kmap_types.h file. Would be nice to be able to add custom KM_types per arch, but I don't yet see a nice, clean way to do that. Built on x86_64, i386, mips, sparc, alpha(tonyb), powerpc(tonyb), and 68k(tonyb). Note: avr32 should be able to remove KM_PTE2 (since it's not used) and then just use the generic kmap_types.h file. Get avr32 maintainer approval. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: <linux-arch@vger.kernel.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Bryan Wu <cooloney@kernel.org> Cc: Mikael Starvik <starvik@axis.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: "Luck Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm: consolidate init_mm definitionAlexey Dobriyan
* create mm/init-mm.c, move init_mm there * remove INIT_MM, initialize init_mm with C99 initializer * unexport init_mm on all arches: init_mm is already unexported on x86. One strange place is some OMAP driver (drivers/video/omap/) which won't build modular, but it's already wants get_vm_area() export. Somebody should look there. [akpm@linux-foundation.org: add missing #includes] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Cc: Americo Wang <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16sparc64: Update defconfig.David S. Miller
2009-06-16sparc: Wire up sys_rt_tgsigqueueinfo().David S. Miller
2009-06-16sparc: replace uses of CPU_MASK_ALL_PTRStephen Rothwell
CPU_MASK_ALL is the (deprecated) "all bits set" cpumask, defined as so: #define CPU_MASK_ALL (cpumask_t) { { ... } } Taking the address of such a temporary is questionable at best, unfortunately 321a8e9d (cpumask: add CPU_MASK_ALL_PTR macro) added CPU_MASK_ALL_PTR: #define CPU_MASK_ALL_PTR (&CPU_MASK_ALL) Which formalizes this practice. One day gcc could bite us over this usage (though we seem to have gotten away with it so far). [Description by Rusty Russell] Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-16sparc64: Add proper dynamic ftrace support.David S. Miller
Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-06-16sparc: Simplify code using is_power_of_2() routine.Robert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-16sparc: move of_device common code to of_device_commonRobert Reif
This patch moves code common to of_device_32.c and of_device_64.c into of_device_common.h and of_device_common.c. The only functional difference is in sparc32 where of_bus_default_map is used in place of of_bus_sbus_map because they are equivelent. There is still room for further code consolidation with some minor refactoring. Boot tested on sparc32 and compile tested on sparc64. Signed-off-by: Robert Reif <reif@earthlink.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-16sparc: remove dma-mapping_{32|64}.hFUJITA Tomonori
This modifies SPARC32 to use struct dma_map ops. It means that we can remove dma-mapping_{32|64}.h. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Tested-by: Robert Reif <reif@earthlink.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-16sparc: use dma_map_page instead of dma_map_singleFUJITA Tomonori
This patch converts dma_map_single and dma_unmap_single to use map_page and unmap_page respectively and removes unnecessary map_single and unmap_single. map_page can be used to implement map_single but the opposite is impossible. Having only dma_map_page in struct dma_ops is enough. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Tested-by: Robert Reif <reif@earthlink.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-16sparc: add sync_single_for_device and sync_sg_for_device to struct dma_opsFUJITA Tomonori
This adds sync_single_for_device() and sync_sg_for_device() to struct dma_ops in order to unify dma-mpping_{32|64}.h. dma-mpping_32.h needs them though dma-mpping_64.h doesn't. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Tested-by: Robert Reif <reif@earthlink.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-16sparc: move the duplication in dma-mapping_{32|64}.h to dma-mapping.hFUJITA Tomonori
2009-06-16sparc64: fix and optimize irq distributionHong H. Pham
irq_choose_cpu() should compare the affinity mask against cpu_online_map rather than CPU_MASK_ALL, since irq_select_affinity() sets the interrupt's affinity mask to cpu_online_map "and" CPU_MASK_ALL (which ends up being just cpu_online_map). The mask comparison in irq_choose_cpu() will always fail since the two masks are not the same. So the CPU chosen is the first CPU in the intersection of cpu_online_map and CPU_MASK_ALL, which is always CPU0. That means all interrupts are reassigned to CPU0... Distributing interrupts to CPUs in a linearly increasing round robin fashion is not optimal for the UltraSPARC T1/T2. Also, the irq_rover in irq_choose_cpu() causes an interrupt to be assigned to a different processor each time the interrupt is allocated and released. This may lead to an unbalanced distribution over time. A static mapping of interrupts to processors is done to optimize and balance interrupt distribution. For the T1/T2, interrupts are spread to different cores first, and then to strands within a core. The following is some benchmarks showing the effects of interrupt distribution on a T2. The test was done with iperf using a pair of T5220 boxes, each with a 10GBe NIU (XAUI) connected back to back. TCP | Stock Linear RR IRQ Optimized IRQ Streams | 2.6.30-rc5 Distribution Distribution | GBits/sec GBits/sec GBits/sec --------+----------------------------------------- 1 0.839 0.862 0.868 8 1.16 4.96 5.88 16 1.15 6.40 8.04 100 1.09 7.28 8.68 Signed-off-by: Hong H. Pham <hong.pham@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-16sparc64: Use new dynamic per-cpu allocator.David S. Miller
2009-06-16sparc64: Only allocate per-cpu areas for possible cpus.David S. Miller
This gets us real close to the generic implementation of setup_per_cpu_areas() except: 1) We store the per-cpu offset into the trap_block[], whereas the generic code has it's own static array. 2) We have to initialize the %g5 register to hold the boot cpu's per-cpu area offset. 3) The OBP/MDESC cpu info scan is performed at the end. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-16sparc64: Get rid of real_setup_per_cpu_areas().David S. Miller
Now that we defer the cpu_data() initializations to the end of per-cpu setup, we can get rid of this local hack we had to setup the per-cpu areas eary. This is a necessary step in order to support HAVE_DYNAMIC_PER_CPU_AREA since the per-cpu setup must run when page structs are available. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-16sparc64: Defer cpu_data() setup until end of per-cpu data initialization.David S. Miller
2009-06-16sparc64: Make mdesc_fill_in_cpu_data take a cpumask_t pointer.David S. Miller
2009-06-16sparc: Call OF and MD cpu scanning explicitly from paging_init()David S. Miller
We need to split up the cpu present mask setup from the cpu_data initialization, and this is a first step towards that. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-16sparc64: Refactor MDESC cpu scanning code using an iterator.David S. Miller
2009-06-16sparc64: Refactor OBP cpu scanning code using an iterator.David S. Miller
With feedback from Sam Ravnborg. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-16sparc64: Use BUILD_BUG_ON() in trap_init().David S. Miller
2009-06-16sparc64: Store per-cpu offset in trap_block[]David S. Miller
Surprisingly this actually makes LOAD_PER_CPU_BASE() a little more efficient. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-16sparc64: Move trap_block[] definitions into a new header file.David S. Miller
Later we're going to want to get at these definitions from asm/percpu.h and that's not possible via cpudata.h because of the set of dependencies the non-trap_block[] stuff has. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-16sparc64: Reclaim trap_block[]->hdescDavid S. Miller
This really isn't necessary at all, a local variable suits the job just fine. This frees up 8 bytes in the trap_block[] that we can use later to store the per-cpu base addresses. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-15Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: Documentation/feature-removal-schedule.txt drivers/scsi/fcoe/fcoe.c net/core/drop_monitor.c net/core/net-traces.c
2009-06-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic: add generic lib/checksum.c asm-generic: add a generic uaccess.h asm-generic: add generic NOMMU versions of some headers asm-generic: add generic atomic.h and io.h asm-generic: add legacy I/O header files asm-generic: add generic versions of common headers asm-generic: make bitops.h usable asm-generic: make pci.h usable directly asm-generic: make get_rtc_time overridable asm-generic: rename page.h and uaccess.h asm-generic: rename atomic.h to atomic-long.h asm-generic: add a generic unistd.h asm-generic: add generic ABI headers asm-generic: add generic sysv ipc headers asm-generic: introduce asm/bitsperlong.h asm-generic: rename termios.h, signal.h and mman.h
2009-06-12module: cleanup FIXME comments about trimming exception table entries.Rusty Russell
Everyone cut and paste this comment from my original one. We now do it generically, so cut the comments. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Amerigo Wang <amwang@redhat.com>
2009-06-12module: trim exception table on init free.Rusty Russell
It's theoretically possible that there are exception table entries which point into the (freed) init text of modules. These could cause future problems if other modules get loaded into that memory and cause an exception as we'd see the wrong fixup. The only case I know of is kvm-intel.ko (when CONFIG_CC_OPTIMIZE_FOR_SIZE=n). Amerigo fixed this long-standing FIXME in the x86 version, but this patch is more general. This implements trim_init_extable(); most archs are simple since they use the standard lib/extable.c sort code. Alpha and IA64 use relative addresses in their fixups, so thier trimming is a slight variation. Sparc32 is unique; it doesn't seem to define ARCH_HAS_SORT_EXTABLE, yet it defines its own sort_extable() which overrides the one in lib. It doesn't sort, so we have to mark deleted entries instead of actually trimming them. Inspired-by: Amerigo Wang <amwang@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: linux-alpha@vger.kernel.org Cc: sparclinux@vger.kernel.org Cc: linux-ia64@vger.kernel.org
2009-06-12asm-generic: merge branch 'master' of torvalds/linux-2.6Arnd Bergmann
Fixes a merge conflict against the x86 tree caused by a fix to atomic.h which I renamed to atomic_long.h. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-11asm-generic: rename page.h and uaccess.hArnd Bergmann
The current asm-generic/page.h only contains the get_order function, and asm-generic/uaccess.h only implements unaligned accesses. This renames the file to getorder.h and uaccess-unaligned.h to make room for new page.h and uaccess.h file that will be usable by all simple (e.g. nommu) architectures. Signed-off-by: Remis Lima Baima <remis.developer@googlemail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-11asm-generic: rename atomic.h to atomic-long.hArnd Bergmann
The existing asm-generic/atomic.h only defines the atomic_long type. This renames it to atomic-long.h so we have a place to add a truly generic atomic.h that can be used on all non-SMP systems. Signed-off-by: Remis Lima Baima <remis.developer@googlemail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-06-11asm-generic: introduce asm/bitsperlong.hArnd Bergmann
This provides a reliable way for asm-generic/types.h and other files to find out if it is running on a 32 or 64 bit platform. We cannot use CONFIG_64BIT for this in headers that are included from user space because CONFIG symbols are not available there. We also cannot do it inside of asm/types.h because some headers need the word size but cannot include types.h. The solution is to introduce a new header <asm/bitsperlong.h> that defines both __BITS_PER_LONG for user space and BITS_PER_LONG for usage in the kernel. The asm-generic version falls back to 32 bit unless the architecture overrides it, which I did for all 64 bit platforms. Signed-off-by: Remis Lima Baima <remis.developer@googlemail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-11asm-generic: rename termios.h, signal.h and mman.hArnd Bergmann
The existing asm-generic versions are incomplete and included by some architectures. New architectures should be able to use a generic version, so rename the existing files and change all users, which lets us add the new files. Signed-off-by: Remis Lima Baima <remis.developer@googlemail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
