path: root/arch/sparc
2007-04-12[SPARC]: Fix section mismatch warnings in pci.c and pcic.cRobert Reif
Fix section mismatch in arch/sparc/kernel/pcic.c and arch/sparc64/kernel/pci.c. Signed-off-by: Robert Reif <reif@earthlink.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-12[SPARC]: avoid CHILD_MAX and OPEN_MAX constantsRoland McGrath
I don't figure anyone really cares about SunOS syscall emulation, and I certainly don't. But I'm getting rid of uses of the OPEN_MAX and CHILD_MAX compile-time constant, and these are almost the only ones. OPEN_MAX is a bogus constant with no meaning about anything. The RLIMIT_NOFILE resource limit is what sysconf (_SC_OPEN_MAX) actually wants to return. The CHILD_MAX cases weren't actually using anything I want to get rid of, but I noticed that they are there and are wrong too. The CHILD_MAX value is not really unlimited as a -1 return from sysconf indicates. The RLIMIT_NPROC resource limit is what sysconf (_SC_CHILD_MAX) wants to return. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-26[SPARC32]: Fix SMP build regressionRobert Reif
commit b19cbe2a1695c09c74f83646c4b82b51123b3690 [BRIDGE]: Fix fdb RCU race breaks sparc SMP build because atomic_add_unless is not exported. This patch exports atomic_add_unless and atomic_cmpxchg. Signed-off-by: Robert Reif <reif@earthlink.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-14[PATCH] sparc: nr_free_pages() is unsigned longAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: William Irwin <wli@holomorphy.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-12[SPARC]: Hook up missing syscalls.David S. Miller
sys_mbind sys_get_mempolicy sys_set_mempolicy sys_kexec_load sys_move_pages sys_getcpu sys_epoll_pwait This work is largely a result of David Woodhouse's most excellent missing syscalls patch. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-12[SPARC]: Fix TIF_USEDFPU flag atomicityWilliam Lee Irwin III
From: William Lee Irwin III <wli@holomorphy.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-02[SPARC]: Provide pci_device_to_OF_node() just like powerpc.David S. Miller
2007-03-02[SPARC]: Handle unresolvable resources better in of_device.cDavid S. Miller
Just leave them as zero if we couldn't calculate it. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-02[SPARC]: Fix bus handling in build_device_resources().David S. Miller
We mistakedly modify 'bus' in the innermost loop. What should happen is that at each register index iteration, we start with the same 'bus'. So preserve it's value at the top level, and use a loop local variable 'dbus' for iteration. This bug causes registers other than the first to be decoded improperly. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-12[SPARC]: Re-export saved_command_line to modules.David S. Miller
This reverts some bogosity from the dynamic command-line changes made on sparc32 and sparc64. Drivers such as drivers/sbus/char/openprom.c reference saved_command_line, and can be modular. The boot_command_line is __initdata, yet the dynamic command-line changes add modular exports of that symbol, obviously wrong. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-12[PATCH] mark struct file_operations const 2Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. [akpm@osdl.org: sparc64 fix] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] Dynamic kernel command-line: sparcAlon Bar-Lev
Rename saved_command_line into boot_command_line. Signed-off-by: Alon Bar-Lev <alon.barlev@gmail.com> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] signal: use kill_pgrp not kill_pg in the sunos compatibility codeEric W. Biederman
I am slowly moving to a model where all process killing is struct pid based instead of pid_t based. The sunos compatibility code is one of the last users of the old pid_t based kill_pg in the kernel. By being complete I allow for the future removal of kill_pg from the kernel, which will ensure I don't miss something. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] sort the devres mess outAl Viro
* Split the implementation-agnostic stuff in separate files. * Make sure that targets using non-default request_irq() pull kernel/irq/devres.o * Introduce new symbols (HAS_IOPORT and HAS_IOMEM) defaulting to positive; allow architectures to turn them off (we needed these symbols anyway for dependencies of quite a few drivers). * protect the ioport-related parts of lib/devres.o with CONFIG_HAS_IOPORT. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Consolidate default sched_clock()Alexey Dobriyan
Use attribute(weak). Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] consolidate line discipline number definitionsTilman Schmidt
The line discipline numbers N_* are currently defined for each architecture individually, but (except for a seeming mistake) identically, in asm/termios.h. There is no obvious reason why these numbers should be architecture specific, nor any apparent relationship with the termios structure. The total number of these, NR_LDISCS, is defined in linux/tty.h anyway. So I propose the following patch which moves the definitions of the individual line disciplines to linux/tty.h too. Three of these numbers (N_MASC, N_PROFIBUS_FDL, and N_SMSBLOCK) are unused in the current kernel, but the patch still keeps the complete set in case there are plans to use them yet. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] disable init/initramfs.c: architecturesJean-Paul Saman
Update all arch/*/kernel/vmlinux.lds.S to not include space for initramfs when CONFIG_BLK_DEV_INITRAMFS is not selected. This saves another 4 kbytes on most platfoms (some reserve PAGE_SIZE for initramfs). Signed-off-by: Jean-Paul Saman <jean-paul.saman@nxp.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Set CONFIG_ZONE_DMA for arches with GENERIC_ISA_DMAChristoph Lameter
As Andi pointed out: CONFIG_GENERIC_ISA_DMA only disables the ISA DMA channel management. Other functionality may still expect GFP_DMA to provide memory below 16M. So we need to make sure that CONFIG_ZONE_DMA is set independent of CONFIG_GENERIC_ISA_DMA. Undo the modifications to mm/Kconfig where we made ZONE_DMA dependent on GENERIC_ISA_DMA and set theses explicitly in each arches Kconfig. Reviews must occur for each arch in order to determine if ZONE_DMA can be switched off. It can only be switched off if we know that all devices supported by a platform are capable of performing DMA transfers to all of memory (Some arches already support this: uml, avr32, sh sh64, parisc and IA64/Altix). In order to switch ZONE_DMA off conditionally, one would have to establish a scheme by which one can assure that no drivers are enabled that are only capable of doing I/O to a part of memory, or one needs to provide an alternate means of performing an allocation from a specific range of memory (like provided by alloc_pages_range()) and insure that all drivers use that call. In that case the arches alloc_dma_coherent() may need to be modified to call alloc_pages_range() instead of relying on GFP_DMA. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-01[PATCH] sanitize sections for sparc32 smpAl Viro
a) sun4d_boot_one_cpu() should be __cpuinit (called only from __cpuinit __cpu_up(), for one thing, leads to calls of __cpuinit functions for another). b) got externs in arch/sparc/kernel/smp.c to match reality. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-30[PATCH] missing exports of pm_power_off() on alpha and sparc32Al Viro
2006-12-31[SPARC64]: Fix of_iounmap() region release.David S. Miller
We need to pass in the resource otherwise we cannot release the region properly. We must know whether it is an I/O or MEM resource. Spotted by Eric Brower. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-30[PATCH] sparc32: add offset in pci_map_sg()Jan Andersson
Add sg->offset to sg->dvma_address in pci_map_sg() on sparc32. Without the offset, transfers to buffers that do not begin on a page boundary will not work as expected. Signed-off-by: Jan Andersson <jan.andersson@ieee.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: William Lee Irwin III <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-17[SPARC]: Make bitops use same spinlocks as atomics.David S. Miller
Recent workqueue changes basically make this a formal requirement. Also, move atomic32.o from lib-y to obj-y since it exports symbols to modules. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-17[SPARC]: Update defconfig.David S. Miller
2006-12-13[PATCH] getting rid of all casts of k[cmz]alloc() callsRobert P. J. Day
Run this: #!/bin/sh for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do echo "De-casting $f..." perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f done And then go through and reinstate those cases where code is casting pointers to non-pointers. And then drop a few hunks which conflicted with outstanding work. Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Greg KH <greg@kroah.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Karsten Keil <kkeil@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Ian Kent <raven@themaw.net> Cc: Steven French <sfrench@us.ibm.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-10[SPARC{32,64}]: Propagate ptrace_traceme() return value.Alexey Dobriyan
ptrace_traceme() consolidation made ret = ptrace_traceme(); dead write. Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-10[SPARC]: Check kzalloc() return value in SUN4D irq/iommu init.David S. Miller
2006-12-10[SPARC]: Replace kmalloc+memset with kzallocYan Burman
Replace kmalloc+memset with kzalloc Signed-off-by: Yan Burman <burman.yan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-08[PATCH] LOG2: Implement a general integer log2 facility in the kernelDavid Howells
This facility provides three entry points: ilog2() Log base 2 of unsigned long ilog2_u32() Log base 2 of u32 ilog2_u64() Log base 2 of u64 These facilities can either be used inside functions on dynamic data: int do_something(long q) { ...; y = ilog2(x) ...; } Or can be used to statically initialise global variables with constant values: unsigned n = ilog2(27); When performing static initialisation, the compiler will report "error: initializer element is not constant" if asked to take a log of zero or of something not reducible to a constant. They treat negative numbers as unsigned. When not dealing with a constant, they fall back to using fls() which permits them to use arch-specific log calculation instructions - such as BSR on x86/x86_64 or SCAN on FRV - if available. [akpm@osdl.org: MMC fix] Signed-off-by: David Howells <dhowells@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: David Howells <dhowells@redhat.com> Cc: Wojtek Kaniewski <wojtekka@toxygen.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] struct path: convert sparcJosef Sipek
2006-12-07Merge branch 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6Linus Torvalds
* 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6: (156 commits) [PATCH] x86-64: Export smp_call_function_single [PATCH] i386: Clean up smp_tune_scheduling() [PATCH] unwinder: move .eh_frame to RODATA [PATCH] unwinder: fully support linker generated .eh_frame_hdr section [PATCH] x86-64: don't use set_irq_regs() [PATCH] x86-64: check vector in setup_ioapic_dest to verify if need setup_IO_APIC_irq [PATCH] x86-64: Make ix86 default to HIGHMEM4G instead of NOHIGHMEM [PATCH] i386: replace kmalloc+memset with kzalloc [PATCH] x86-64: remove remaining pc98 code [PATCH] x86-64: remove unused variable [PATCH] x86-64: Fix constraints in atomic_add_return() [PATCH] x86-64: fix asm constraints in i386 atomic_add_return [PATCH] x86-64: Correct documentation for bzImage protocol v2.05 [PATCH] x86-64: replace kmalloc+memset with kzalloc in MTRR code [PATCH] x86-64: Fix numaq build error [PATCH] x86-64: include/asm-x86_64/cpufeature.h isn't a userspace header [PATCH] unwinder: Add debugging output to the Dwarf2 unwinder [PATCH] x86-64: Clarify error message in GART code [PATCH] x86-64: Fix interrupt race in idle callback (3rd try) [PATCH] x86-64: Remove unwind stack pointer alignment forcing again ... Fixed conflict in include/linux/uaccess.h manually Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] mm: pagefault_{disable,enable}()Peter Zijlstra
Introduce pagefault_{disable,enable}() and use these where previously we did manual preempt increments/decrements to make the pagefault handler do the atomic thing. Currently they still rely on the increased preempt count, but do not rely on the disabled preemption, this might go away in the future. (NOTE: the extra barrier() in pagefault_disable might fix some holes on machines which have too many registers for their own good) [heiko.carstens@de.ibm.com: s390 fix] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Nick Piggin <npiggin@suse.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] relocatable kernel: Kallsyms generate relocatable symbolsEric W. Biederman
Print the addresses of non-absolute symbols relative to _text so that ld will generate relocations. Allowing a relocatable kernel to relocate them. We can't actually use the symbol names because kallsyms includes static symbols that are not exported from their object files. Add the _text symbol definitions to the architectures which don't define it otherwise linker will fail. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de>
2006-11-30Fix misc Kconfig typosMatt LaPlante
Fix various Kconfig typos. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-05[SPARC]: Fix robust futex syscalls and wire up migrate_pages.David S. Miller
When I added the entries for the robust futex syscall entries, I forgot to bump NR_SYSCALLS. The current situation is error-prone because NR_SYSCALLS lives in entry.S where the system call limit checks are enforced. Move the definition to asm/unistd.h in order to make this mistake much more difficult to make. And wire up sys_migrate_pages since the powerpc folks implemented the compat wrapper for us. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-27Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6: [SPARC]: Fix bus_id[] string overflow.
2006-10-27[PATCH] vmlinux.lds: consolidate initcall sectionsAndrew Morton
Add a vmlinux.lds.h helper macro for defining the eight-level initcall table, teach all the architectures to use it. This is a prerequisite for a patch which performs initcall synchronisation for multithreaded-probing. Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> [ Added AVR32 as well ] Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-27[SPARC]: Fix bus_id[] string overflow.David S. Miller
dp->path_component_name can be larger than ->bus_id[] so use a different naming scheme for this stuff. Noticed by Jurij Smakov. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-17[SPARC]: Sparc compilation fix with floppy enabledKrzysztof Helt
This patch fixes a typo to make kernel compilable when floppy driver for Sparc is build. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-17[SPARC]: Add sparc profiling supportMartin Habets
This patch adds profiling support to the sparc architecture. It is a copy of the sparc64 implementation. Signed-off-by: Martin Habets <errandir_news@mph.eclipse.co.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-17[SPARC]: Kill BOOTME_SINGLE.David S. Miller
Unused, but still allow the '-s' boot option to be passed down to init. Based upon patches by Martin Habets. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-11[SPARC32]: Fix sparc32 modpost warnings.Martin Habets
Fix these 2.6.19-rc1 build warnings from modpost: WARNING: vmlinux - Section mismatch: reference to .init.text:_sinittext from .text between 'core_kernel_text' (at offset 0x3e060) and '__kernel_text_address' WARNING: vmlinux - Section mismatch: reference to .init.text:_sinittext from .text between 'core_kernel_text' (at offset 0x3e064) and '__kernel_text_address' WARNING: vmlinux - Section mismatch: reference to .init.text:_einittext from .text between 'core_kernel_text' (at offset 0x3e07c) and '__kernel_text_address' WARNING: vmlinux - Section mismatch: reference to .init.text:_einittext from .text between 'core_kernel_text' (at offset 0x3e080) and '__kernel_text_address' WARNING: vmlinux - Section mismatch: reference to .init.text:_sinittext from .text between 'is_ksym_addr' (at offset 0x4b3a4) and 'kallsyms_expand_symbol' WARNING: vmlinux - Section mismatch: reference to .init.text:_sinittext from .text between 'is_ksym_addr' (at offset 0x4b3a8) and 'kallsyms_expand_symbol' WARNING: vmlinux - Section mismatch: reference to .init.text:_einittext from .text between 'is_ksym_addr' (at offset 0x4b3b4) and 'kallsyms_expand_symbol' WARNING: vmlinux - Section mismatch: reference to .init.text:_einittext from .text between 'is_ksym_addr' (at offset 0x4b3e4) and 'kallsyms_expand_symbol' WARNING: vmlinux - Section mismatch: reference to .init.text:_sinittext from .text between 'get_symbol_pos' (at offset 0x4b640) and 'kallsyms_lookup_size_offset' WARNING: vmlinux - Section mismatch: reference to .init.text:_sinittext from .text between 'get_symbol_pos' (at offset 0x4b644) and 'kallsyms_lookup_size_offset' WARNING: vmlinux - Section mismatch: reference to .init.text:_einittext from .text between 'get_symbol_pos' (at offset 0x4b654) and 'kallsyms_lookup_size_offset' WARNING: vmlinux - Section mismatch: reference to .init.text:_einittext from .text between 'get_symbol_pos' (at offset 0x4b658) and 'kallsyms_lookup_size_offset' WARNING: vmlinux - Section mismatch: reference to .init.text:_sinittext from .text between 'get_symbol_pos' (at offset 0x4b68c) and 'kallsyms_lookup_size_offset' The crux of the matter is that modpost only checks the relocatable sections. i386 vmlinux has none, so modpost does no checking on it (it does on the modules). However, sparc vmlinux has plenty of relocatable sections because it is being built with 'ld -r' (to allow for btfixup processing). So for sparc, modpost does do a lot of checking. Sure enough, running modpost on arch/sparc/boot/image yields no output (i.e. all is well). modpost.c check_sec_ref() has: /* We want to process only relocation sections and not .init */ if (sechdrs[i].sh_type == SHT_RELA) { // check here } else if (sechdrs[i].sh_type == SHT_REL) { // check here } Signed-off-by: Martin Habets <errandir_news@mph.eclipse.co.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-11[SPARC32]: Fix sparc32 modpost warnings with sunzilogMartin Habets
Fix this 2.6.19-rc1 build warnings from modpost: WARNING: vmlinux - Section mismatch: reference to .init.text:sunzilog_console_setup from .data between 'sunzilog_console' (at offset 0x8394) and 'devices_subsys' Signed-off-by: Martin Habets <errandir_news@mph.eclipse.co.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-11[SPARC32]: Mark srmmu_nocache_init as __init.Martin Habets
Fix these 2.6.19-rc1 build warnings from modpost: WARNING: vmlinux - Section mismatch: reference to .init.text:__alloc_bootmem from .text between 'srmmu_nocache_init' (at offset 0x1a0f8) and 'srmmu_mmu_info' WARNING: vmlinux - Section mismatch: reference to .init.text:__alloc_bootmem from .text between 'srmmu_nocache_init' (at offset 0x1a118) and 'srmmu_mmu_info' WARNING: vmlinux - Section mismatch: reference to .init.text:srmmu_early_allocate_ptable_skeleton from .text between 'srmmu_nocache_init' (at offset 0x1a188) and 'srmmu_mmu_info' Signed-off-by: Martin Habets <errandir_news@mph.eclipse.co.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-11[SPARC32]: pcic.c needs asm/irq_regs.hDavid S. Miller
2006-10-09[SPARC32]: Fix prom.c build warningMartin Habets
Fix these 2.6.19-rc1 build warnings: CC arch/sparc/kernel/prom.o arch/sparc/kernel/prom.c: In function `of_set_property': arch/sparc/kernel/prom.c:246: warning: passing arg 2 of `prom_setprop' discards qualifiers from pointer target type arch/sparc/kernel/prom.c: In function `build_one_prop': arch/sparc/kernel/prom.c:446: warning: unused variable `len' arch/sparc/kernel/prom.c:480: warning: ignoring return value of `prom_getproperty', declared with attribute warn_unused_result Signed-off-by: Martin Habets <errandir_news@mph.eclipse.co.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-09IRQ: Use the new typedef for interrupt handler function pointersDavid Howells
Use the new typedef for interrupt handler function pointers rather than actually spelling out the full thing each time. This was scripted with the following small shell script: #!/bin/sh egrep -nHrl -e 'irqreturn_t[ ]*[(][*]' $* | while read i do echo $i perl -pi -e 's/irqreturn_t\s*[(]\s*[*]\s*([_a-zA-Z0-9]*)\s*[)]\s*[(]\s*int\s*,\s*void\s*[*]\s*[)]/irq_handler_t \1/g' $i || exit $? done Signed-Off-By: David Howells <dhowells@redhat.com>
2006-10-08[PATCH] sparc32 rwlock fixAl Viro
read_trylock() is broken on sparc32 (doesn't build and didn't work right, actually). Proposed fix: - make "writer holds lock" distinguishable from "reader tries to grab lock" - have __raw_read_trylock() try to acquire the mutex (in LSB of lock), terminating spin if we see that there's writer holding it. Then do the rest as we do in read_lock(). Thanks to Ingo for discussion... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-08[PATCH] sparc32 pt_regs fixesAl Viro
2006-10-04Remove all inclusions of <linux/config.h>Dave Jones
kbuild explicitly includes this at build time. Signed-off-by: Dave Jones <davej@redhat.com>
