path: root/arch/sparc
2012-06-24Fix typo in printed messagesAnatol Pomozov
Coult -> Could Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-06-11sparc: remove two unused headersPaul Bolle
Nothing includes these two headers. None of the macros they define are used anywhere in the tree. This was also the case in v2.6.12-rc2 and, presumably, every release in between. These two headers can safely be removed. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull third pile of signal handling patches from Al Viro: "This time it's mostly helpers and conversions to them; there's a lot of stuff remaining in the tree, but that'll either go in -rc2 (isolated bug fixes, ideally via arch maintainers' trees) or will sit there until the next cycle." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: x86: get rid of calling do_notify_resume() when returning to kernel mode blackfin: check __get_user() return value whack-a-mole with TIF_FREEZE FRV: Optimise the system call exit path in entry.S [ver #2] FRV: Shrink TIF_WORK_MASK [ver #2] FRV: Prevent syscall exit tracing and notify_resume at end of kernel exceptions new helper: signal_delivered() powerpc: get rid of restore_sigmask() most of set_current_blocked() callers want SIGKILL/SIGSTOP removed from set set_restore_sigmask() is never called without SIGPENDING (and never should be) TIF_RESTORE_SIGMASK can be set only when TIF_SIGPENDING is set don't call try_to_freeze() from do_signal() pull clearing RESTORE_SIGMASK into block_sigmask() sh64: failure to build sigframe != signal without handler openrisc: tracehook_signal_handler() is supposed to be called on success new helper: sigmask_to_save() new helper: restore_saved_sigmask() new helpers: {clear,test,test_and_clear}_restore_sigmask() HAVE_RESTORE_SIGMASK is defined on all architectures now
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs changes from Al Viro. "A lot of misc stuff. The obvious groups: * Miklos' atomic_open series; kills the damn abuse of ->d_revalidate() by NFS, which was the major stumbling block for all work in that area. * ripping security_file_mmap() and dealing with deadlocks in the area; sanitizing the neighborhood of vm_mmap()/vm_munmap() in general. * ->encode_fh() switched to saner API; insane fake dentry in mm/cleancache.c gone. * assorted annotations in fs (endianness, __user) * parts of Artem's ->s_dirty work (jff2 and reiserfs parts) * ->update_time() work from Josef. * other bits and pieces all over the place. Normally it would've been in two or three pull requests, but signal.git stuff had eaten a lot of time during this cycle ;-/" Fix up trivial conflicts in Documentation/filesystems/vfs.txt (the 'truncate_range' inode method was removed by the VM changes, the VFS update adds an 'update_time()' method), and in fs/btrfs/ulist.[ch] (due to sparse fix added twice, with other changes nearby). * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (95 commits) nfs: don't open in ->d_revalidate vfs: retry last component if opening stale dentry vfs: nameidata_to_filp(): don't throw away file on error vfs: nameidata_to_filp(): inline __dentry_open() vfs: do_dentry_open(): don't put filp vfs: split __dentry_open() vfs: do_last() common post lookup vfs: do_last(): add audit_inode before open vfs: do_last(): only return EISDIR for O_CREAT vfs: do_last(): check LOOKUP_DIRECTORY vfs: do_last(): make ENOENT exit RCU safe vfs: make follow_link check RCU safe vfs: do_last(): use inode variable vfs: do_last(): inline walk_component() vfs: do_last(): make exit RCU safe vfs: split do_lookup() Btrfs: move over to use ->update_time fs: introduce inode operation ->update_time reiserfs: get rid of resierfs_sync_super reiserfs: mark the superblock as dirty a bit later ...
2012-06-01new helper: signal_delivered()Al Viro
Does block_sigmask() + tracehook_signal_handler(); called when sigframe has been successfully built. All architectures converted to it; block_sigmask() itself is gone now (merged into this one). I'm still not too happy with the signature, but that's a separate story (IMO we need a structure that would contain signal number + siginfo + k_sigaction, so that get_signal_to_deliver() would fill one, signal_delivered(), handle_signal() and probably setup...frame() - take one). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-01most of set_current_blocked() callers want SIGKILL/SIGSTOP removed from setAl Viro
Only 3 out of 63 do not. Renamed the current variant to __set_current_blocked(), added set_current_blocked() that will exclude unblockable signals, switched open-coded instances to it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-01set_restore_sigmask() is never called without SIGPENDING (and never should be)Al Viro
2012-06-01TIF_RESTORE_SIGMASK can be set only when TIF_SIGPENDING is setAl Viro
2012-06-01pull clearing RESTORE_SIGMASK into block_sigmask()Al Viro
2012-06-01new helper: sigmask_to_save()Al Viro
replace boilerplate "should we use ->saved_sigmask or ->blocked?" with calls of obvious inlined helper... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-01new helper: restore_saved_sigmask()Al Viro
first fruits of ..._restore_sigmask() helpers: now we can take boilerplate "signal didn't have a handler, clear RESTORE_SIGMASK and restore the blocked mask from ->saved_mask" into a common helper. Open-coded instances switched... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-01new helpers: {clear,test,test_and_clear}_restore_sigmask()Al Viro
helpers parallel to set_restore_sigmask(), used in the next commits Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-31Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull second pile of signal handling patches from Al Viro: "This one is just task_work_add() series + remaining prereqs for it. There probably will be another pull request from that tree this cycle - at least for helpers, to get them out of the way for per-arch fixes remaining in the tree." Fix trivial conflict in kernel/irq/manage.c: the merge of Andrew's pile had brought in commit 97fd75b7b8e0 ("kernel/irq/manage.c: use the pr_foo() infrastructure to prefix printks") which changed one of the pr_err() calls that this merge moves around. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: keys: kill task_struct->replacement_session_keyring keys: kill the dummy key_replace_session_keyring() keys: change keyctl_session_to_parent() to use task_work_add() genirq: reimplement exit_irq_thread() hook via task_work_add() task_work_add: generic process-context callbacks avr32: missed _TIF_NOTIFY_RESUME on one of do_notify_resume callers parisc: need to check NOTIFY_RESUME when exiting from syscall move key_repace_session_keyring() into tracehook_notify_resume() TIF_NOTIFY_RESUME is defined on all targets now
2012-05-30ia64, sparc64: convert wrappers around do_mremap() to sys_mremap()Al Viro
they contain open-coded sys_mremap() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-30bury __kernel_nlink_t, make internal nlink_t consistentAl Viro
2012-05-29sparc: fix sparc64 build due to leon.h inclusionSam Ravnborg
Stephen Rothwell <sfr@canb.auug.org.au> reported following error: In file included from arch/sparc/kernel/prom_common.c:26:0: arch/sparc/include/asm/leon.h:221:9: error: unknown type name 'irq_flow_handler_t' arch/sparc/include/asm/leon.h:224:10: error: unknown type name 'irq_flow_handler_t' Fix this by: 1) Avoid including leon.h in prom_commen.h (not needed) 2) Include irq.h in leon.h to avoid the missing symbol error Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-29sparc32: remove unused variable in head_32.SSam Ravnborg
It was assigned, but never referenced later. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-29sparc32,leon: fix leon bootupSam Ravnborg
head_32.S failed to set cputypval for leon, causing boot to fail. The boot failed because we failed to recognize this was a LEON cpu so we did not preoperly run-time patch the the kernel. This resulted in an early crash. Reported-by: Daniel Hellstrom <daniel@gaisler.com> Tested-by: Daniel Hellstrom <daniel@gaisler.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Konrad Eisele <konrad@gaisler.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-28sparc32: Export leon_dma_ops to modules.David S. Miller
2012-05-27sparc32: support leon + sun in dma_make_coherent()Sam Ravnborg
No need for two implementations - we check the cpu model. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Konrad Eisele <konrad@gaisler.com>
2012-05-27sparc32,leon: always support leon in ioportSam Ravnborg
Unconditially define pci32_dma_ops as this is used for leon. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Konrad Eisele <konrad@gaisler.com>
2012-05-27sparc32,leon: always include leon_pmc in buildSam Ravnborg
2012-05-27sparc32: refactor cpu_idle()Sam Ravnborg
With the removal of sun4c we can use the same cpu_idle() implementation on UP and SMP. This also fix it so we use the same version independent on LEON enabled or not. V2: Fixed whitespace issue pointed out by Josip Rodin. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Josip Rodin <joy@entuzijast.net> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Konrad Eisele <konrad@gaisler.com>
2012-05-27sparc32: srmmu_probe now knows about leon tooSam Ravnborg
2012-05-27sparc32: drop LEON hack for ASI_M_MMUREGSSam Ravnborg
All users of MMUREGS ASI is now LEON/SUN aware, so this is no longer required. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Konrad Eisele <konrad@gaisler.com>
2012-05-27sparc32: introduce run-time patching of srmmu access functionsSam Ravnborg
LEON uses a different ASI than SUN for MMUREGS Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Konrad Eisele <konrad@gaisler.com>
2012-05-27sparc32: introduce support for run-time patching for all shared assembler codeSam Ravnborg
All users of MMUREGS ASI in kernel/ now uses run-time patching. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Konrad Eisele <konrad@gaisler.com>
2012-05-27sparc32,leon: fix section mismatch warningSam Ravnborg
Fix following warning: WARNING: arch/sparc/kernel/built-in.o(.cpuinit.text+0x9f4): Section mismatch in reference from the function leon_callin() to the function .init.text:leon_configure_cache_smp() The function __cpuinit leon_callin() references a function __init leon_configure_cache_smp(). If leon_configure_cache_smp is only used by leon_callin then annotate leon_configure_cache_smp with a matching annotation. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Konrad Eisele <konrad@gaisler.com>
2012-05-27sparc32,leon: always include leon_smp + leon_mm in buildSam Ravnborg
Fix-up leon specific assembler to use ASI_LEON_MMUREGS Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Konrad Eisele <konrad@gaisler.com>
2012-05-27sparc32,leon: always include leon_kernel in buildSam Ravnborg
2012-05-27sparc32,leon: clean up leon.hSam Ravnborg
- Drop unused stuff accumulated over time - Drop non-leon stuff - Include almost all of the header unconditionally Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Konrad Eisele <konrad@gaisler.com>
2012-05-27sparc32: handle leon in cpu.cSam Ravnborg
A few hardcoded constant were replaced by symbolic versions to improve readability Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Konrad Eisele <konrad@gaisler.com>
2012-05-27sparc32: handle leon in irq_32.cSam Ravnborg
2012-05-27sparc32: add support for run-time patching of leon/sun single instructionsSam Ravnborg
This will be used to handle that MMUREGS has different ASI for SUN and LEON. This is the infrastructure only - users will come later. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Konrad Eisele <konrad@gaisler.com>
2012-05-27sparc32: introduce sparc32_start_kernel called from head_32.SSam Ravnborg
This gives us a C hook before we call start_kernel() Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2012-05-27sparc32: implement proper LEON support in head_32 (after highmem)Sam Ravnborg
We use the compatibility property to determine the sun models. For leon we use psr.impl and ignore the result of the getprops call. Include a hack to allow build as the support code is not yet converted. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Konrad Eisele <konrad@gaisler.com>
2012-05-27sparc32: implement proper LEON support in head_32 (before highmem)Sam Ravnborg
Use PSR to check if the CPU is LEON and jump to LEON specific code in this case. Added a few constants to psr.h to increase readability. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Konrad Eisele <konrad@gaisler.com>
2012-05-27sparc32: string and whitespace cleanup in head_32.SSam Ravnborg
A few strings have been adopted to show more relevant info. Julian Calaby <julian.calaby@gmail.com> pointed out one that I would otherwise have missed. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2012-05-27sparc: fix bad merge of sparc KconfigStephen Rothwell
Fixes this sparc32 defconfig build error: timekeeping.c:(.text+0x277c4): undefined reference to `arch_gettimeoffset' Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linuxDavid S. Miller
Pull in Linus's tree to get the commits that blew away ARCH_USES_GETTIMEOFFSET but didn't update Sparc correctly, so that I can apply Stephen Rothwell's fix for that mis-merge. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-26sparc: use the new generic strnlen_user() functionDavid Miller
This throws away the sparc-specific functions in favor of the generic optimized version. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-26word-at-a-time: make the interfaces truly genericLinus Torvalds
This changes the interfaces in <asm/word-at-a-time.h> to be a bit more complicated, but a lot more generic. In particular, it allows us to really do the operations efficiently on both little-endian and big-endian machines, pretty much regardless of machine details. For example, if you can rely on a fast population count instruction on your architecture, this will allow you to make your optimized <asm/word-at-a-time.h> file with that. NOTE! The "generic" version in include/asm-generic/word-at-a-time.h is not truly generic, it actually only works on big-endian. Why? Because on little-endian the generic algorithms are wasteful, since you can inevitably do better. The x86 implementation is an example of that. (The only truly non-generic part of the asm-generic implementation is the "find_zero()" function, and you could make a little-endian version of it. And if the Kbuild infrastructure allowed us to pick a particular header file, that would be lovely) The <asm/word-at-a-time.h> functions are as follows: - WORD_AT_A_TIME_CONSTANTS: specific constants that the algorithm uses. - has_zero(): take a word, and determine if it has a zero byte in it. It gets the word, the pointer to the constant pool, and a pointer to an intermediate "data" field it can set. This is the "quick-and-dirty" zero tester: it's what is run inside the hot loops. - "prep_zero_mask()": take the word, the data that has_zero() produced, and the constant pool, and generate an *exact* mask of which byte had the first zero. This is run directly *outside* the loop, and allows the "has_zero()" function to answer the "is there a zero byte" question without necessarily getting exactly *which* byte is the first one to contain a zero. If you do multiple byte lookups concurrently (eg "hash_name()", which looks for both NUL and '/' bytes), after you've done the prep_zero_mask() phase, the result of those can be or'ed together to get the "either or" case. - The result from "prep_zero_mask()" can then be fed into "find_zero()" (to find the byte offset of the first byte that was zero) or into "zero_bytemask()" (to find the bytemask of the bytes preceding the zero byte). The existence of zero_bytemask() is optional, and is not necessary for the normal string routines. But dentry name hashing needs it, so if you enable DENTRY_WORD_AT_A_TIME you need to expose it. This changes the generic strncpy_from_user() function and the dentry hashing functions to use these modified word-at-a-time interfaces. This gets us back to the optimized state of the x86 strncpy that we lost in the previous commit when moving over to the generic version. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-25sparc64: Fix several bugs in quad floating point emulation.David S. Miller
UltraSPARC-T2 and later do not use the fp_exception_other trap and do not set the floating point trap type field in the %fsr at all when you try to execute an unimplemented FPU operation. Instead, it uses the illegal_instruction trap and it leaves the floating point trap type field clear. So we should not validate the %fsr trap type field when do_mathemu() is invoked from the illegal instruction handler. Also, the floating point trap type field is 3 bits, not 4 bits. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-24Merge branch 'next' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM changes from Avi Kivity: "Changes include additional instruction emulation, page-crossing MMIO, faster dirty logging, preventing the watchdog from killing a stopped guest, module autoload, a new MSI ABI, and some minor optimizations and fixes. Outside x86 we have a small s390 and a very large ppc update. Regarding the new (for kvm) rebaseless workflow, some of the patches that were merged before we switch trees had to be rebased, while others are true pulls. In either case the signoffs should be correct now." Fix up trivial conflicts in Documentation/feature-removal-schedule.txt arch/powerpc/kvm/book3s_segment.S and arch/x86/include/asm/kvm_para.h. I suspect the kvm_para.h resolution ends up doing the "do I have cpuid" check effectively twice (it was done differently in two different commits), but better safe than sorry ;) * 'next' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (125 commits) KVM: make asm-generic/kvm_para.h have an ifdef __KERNEL__ block KVM: s390: onereg for timer related registers KVM: s390: epoch difference and TOD programmable field KVM: s390: KVM_GET/SET_ONEREG for s390 KVM: s390: add capability indicating COW support KVM: Fix mmu_reload() clash with nested vmx event injection KVM: MMU: Don't use RCU for lockless shadow walking KVM: VMX: Optimize %ds, %es reload KVM: VMX: Fix %ds/%es clobber KVM: x86 emulator: convert bsf/bsr instructions to emulate_2op_SrcV_nobyte() KVM: VMX: unlike vmcs on fail path KVM: PPC: Emulator: clean up SPR reads and writes KVM: PPC: Emulator: clean up instruction parsing kvm/powerpc: Add new ioctl to retreive server MMU infos kvm/book3s: Make kernel emulated H_PUT_TCE available for "PR" KVM KVM: PPC: bookehv: Fix r8/r13 storing in level exception handler KVM: PPC: Book3S: Enable IRQs during exit handling KVM: PPC: Fix PR KVM on POWER7 bare metal KVM: PPC: Fix stbux emulation KVM: PPC: bookehv: Use lwz/stw instead of PPC_LL/PPC_STL for 32-bit fields ...
2012-05-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
Pull sparc changes from David S. Miller: "This has the generic strncpy_from_user() implementation architectures can now use, which we've been developing on linux-arch over the past few days. For good measure I ran both a 32-bit and a 64-bit glibc testsuite run, and the latter of which pointed out an adjustment I needed to make to sparc's user_addr_max() definition. Linus, you were right, STACK_TOP was not the right thing to use, even on sparc itself :-) From Sam Ravnborg, we have a conversion of sparc32 over to the common alloc_thread_info_node(), since the aspect which originally blocked our doing so (sun4c) has been removed." Fix up trivial arch/sparc/Kconfig and lib/Makefile conflicts. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: sparc: Fix user_addr_max() definition. lib: Sparc's strncpy_from_user is generic enough, move under lib/ kernel: Move REPEAT_BYTE definition into linux/kernel.h sparc: Increase portability of strncpy_from_user() implementation. sparc: Optimize strncpy_from_user() zero byte search. sparc: Add full proper error handling to strncpy_from_user(). sparc32: use the common implementation of alloc_thread_info_node()
2012-05-24Merge tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
Pull GPIO driver changes from Grant Likely: "Lots of gpio changes, both to core code and drivers. Changes do touch architecture code to remove the need for separate arm/gpio.h includes in most architectures. Some new drivers are added, and a number of gpio drivers are converted to use irq_domains for gpio inputs used as interrupts. Device tree support has been amended to allow multiple gpio_chips to use the same device tree node. Remaining changes are primarily bug fixes." * tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux-2.6: (33 commits) gpio/generic: initialize basic_mmio_gpio shadow variables properly gpiolib: Remove 'const' from data argument of gpiochip_find() gpio/rc5t583: add gpio driver for RICOH PMIC RC5T583 gpiolib: quiet gpiochip_add boot message noise gpio: mpc8xxx: Prevent NULL pointer deref in demux handler gpio/lpc32xx: Add device tree support gpio: Adjust of_xlate API to support multiple GPIO chips gpiolib: Implement devm_gpio_request_one() gpio-mcp23s08: dbg_show: fix pullup configuration display Add support for TCA6424A gpio/omap: (re)fix wakeups on level-triggered GPIOs gpio/omap: fix broken context restore for non-OFF mode transitions gpio/omap: fix missing check in *_runtime_suspend() gpio/omap: remove cpu_is_omapxxxx() checks from *_runtime_resume() gpio/omap: remove suspend/resume callbacks gpio/omap: remove retrigger variable in gpio_irq_handler gpio/omap: remove saved_wakeup field from struct gpio_bank gpio/omap: remove suspend_wakeup field from struct gpio_bank gpio/omap: remove saved_fallingdetect, saved_risingdetect gpio/omap: remove virtual_irq_start variable ... Conflicts: drivers/gpio/gpio-samsung.c
2012-05-24sparc: Fix user_addr_max() definition.David S. Miller
We need to use TASK_SIZE because for 64-bit tasks the value of STACK_TOP actually sits in the middle of the address space so we'll get false-negatives. Adjust the TASK_SIZE definition on sparc64 to accomodate this, in the context in which user_addr_max() is used we have the test_thread_flag() definition available but not the one for test_tsk_thread_flag(). Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-24Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer updates from Thomas Gleixner. Various trivial conflict fixups in arch Kconfig due to addition of unrelated entries nearby. And one slightly more subtle one for sparc32 (new user of GENERIC_CLOCKEVENTS), fixed up as per Thomas. * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (31 commits) timekeeping: Fix a few minor newline issues. time: remove obsolete declaration ntp: Fix a stale comment and a few stray newlines. ntp: Correct TAI offset during leap second timers: Fixup the Kconfig consolidation fallout x86: Use generic time config unicore32: Use generic time config um: Use generic time config tile: Use generic time config sparc: Use: generic time config sh: Use generic time config score: Use generic time config s390: Use generic time config openrisc: Use generic time config powerpc: Use generic time config mn10300: Use generic time config mips: Use generic time config microblaze: Use generic time config m68k: Use generic time config m32r: Use generic time config ...
2012-05-24lib: Sparc's strncpy_from_user is generic enough, move under lib/David S. Miller
To use this, an architecture simply needs to: 1) Provide a user_addr_max() implementation via asm/uaccess.h 2) Add "select GENERIC_STRNCPY_FROM_USER" to their arch Kcnfig 3) Remove the existing strncpy_from_user() implementation and symbol exports their architecture had. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: David Howells <dhowells@redhat.com>
2012-05-24kernel: Move REPEAT_BYTE definition into linux/kernel.hDavid S. Miller
And make sure that everything using it explicitly includes that header file. Signed-off-by: David S. Miller <davem@davemloft.net>
