path: root/arch/tile
2013-05-09Merge branch 'stable' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile Pull tile update from Chris Metcalf: "The interesting bug fix is support for the upcoming "4.2" release of the Tilera hypervisor, which by default launches Linux at privilege level 2 instead of 1. The fix lets new and old hypervisors and Linuxes interoperate more smoothly, so I've tagged it for stable@kernel.org so that older Linuxes will be able to boot under the newer hypervisor." * 'stable' of git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: usb: tilegx: fix memleak when create hcd fail arch/tile: remove inline marking of EXPORT_SYMBOL functions rtc: rtc-tile: add missing platform_device_unregister() when module exit tile: support new Tilera hypervisor
2013-05-09arch/tile: remove inline marking of EXPORT_SYMBOL functionsDenis Efremov
EXPORT_SYMBOL and inline directives are contradictory to each other. The patch fixes this inconsistency. Found by Linux Driver Verification project (linuxtesting.org). Signed-off-by: Denis Efremov <yefremov.denis@gmail.com> Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2013-05-02tile: support new Tilera hypervisorChris Metcalf
The Tilera hypervisor shipped in releases up through MDE 4.1 launches the client operating system (i.e. Linux) at privilege level 1 (PL1). Starting with MDE 4.2, as part of the work to enable KVM, the Tilera hypervisor launches Linux at PL2 instead. This commit makes the KERNEL_PL option default to 2 for tilegx, while still saying at 1 for tilepro, which doesn't have an updated hypervisor. It also explains how and when you might want to choose another value. In addition, we change a small buglet in the on-chip Ethernet driver, where we were failing to use the KERNEL_PL constant in an API call. To make the transition cleaner, this change also provides the updated hv_init() API for the new hypervisor that supports announcing Linux's compiled-in PL, so the hypervisor can generate a suitable error in the case of a mismatched hypervisor and Linux binary. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Cc: stable@vger.linux.org
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS updates from Al Viro, Misc cleanups all over the place, mainly wrt /proc interfaces (switch create_proc_entry to proc_create(), get rid of the deprecated create_proc_read_entry() in favor of using proc_create_data() and seq_file etc). 7kloc removed. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits) don't bother with deferred freeing of fdtables proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h proc: Make the PROC_I() and PDE() macros internal to procfs proc: Supply a function to remove a proc entry by PDE take cgroup_open() and cpuset_open() to fs/proc/base.c ppc: Clean up scanlog ppc: Clean up rtas_flash driver somewhat hostap: proc: Use remove_proc_subtree() drm: proc: Use remove_proc_subtree() drm: proc: Use minor->index to label things, not PDE->name drm: Constify drm_proc_list[] zoran: Don't print proc_dir_entry data in debug reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show() proc: Supply an accessor for getting the data from a PDE's parent airo: Use remove_proc_subtree() rtl8192u: Don't need to save device proc dir PDE rtl8187se: Use a dir under /proc/net/r8180/ proc: Add proc_mkdir_data() proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h} proc: Move PDE_NET() to fs/proc/proc_net.c ...
2013-05-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
Pull tile arch changes from Chris Metcalf: "These are some minor new feature work and other changes that didn't merit getting pushed up after the 3.9 merge window closed. There should be a lot more activity in the 3.11 merge window" * git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: arch/tile: Fix syscall return value passed to tracepoint tile: comment assumption about __insn_mtspr for <asm/irqflags.h> tile: ns2cycles should use __raw_get_cpu_var arch: remove KCORE_ELF again [tile] tile: remove two outdated Kconfig entries tile: support atomic64_dec_if_positive() tile: support TIF_SYSCALL_TRACEPOINT; select HAVE_SYSCALL_TRACEPOINTS tile: Add definition of NR_syscalls tile: move declaration of sys_call_table to <asm/syscall.h> arch/tile: Enable HAVE_ARCH_TRACEHOOK arch/tile: Call tracehook_report_syscall_{entry,exit} in syscall trace
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull compat cleanup from Al Viro: "Mostly about syscall wrappers this time; there will be another pile with patches in the same general area from various people, but I'd rather push those after both that and vfs.git pile are in." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: syscalls.h: slightly reduce the jungles of macros get rid of union semop in sys_semctl(2) arguments make do_mremap() static sparc: no need to sign-extend in sync_file_range() wrapper ppc compat wrappers for add_key(2) and request_key(2) are pointless x86: trim sys_ia32.h x86: sys32_kill and sys32_mprotect are pointless get rid of compat_sys_semctl() and friends in case of ARCH_WANT_OLD_COMPAT_IPC merge compat sys_ipc instances consolidate compat lookup_dcookie() convert vmsplice to COMPAT_SYSCALL_DEFINE switch getrusage() to COMPAT_SYSCALL_DEFINE switch epoll_pwait to COMPAT_SYSCALL_DEFINE convert sendfile{,64} to COMPAT_SYSCALL_DEFINE switch signalfd{,4}() to COMPAT_SYSCALL_DEFINE make SYSCALL_DEFINE<n>-generated wrappers do asmlinkage_protect make HAVE_SYSCALL_WRAPPERS unconditional consolidate cond_syscall and SYSCALL_ALIAS declarations teach SYSCALL_DEFINE<n> how to deal with long long/unsigned long long get rid of duplicate logics in __SC_....[1-6] definitions
2013-04-30Kconfig: consolidate CONFIG_DEBUG_STRICT_USER_COPY_CHECKSStephen Boyd
The help text for this config is duplicated across the x86, parisc, and s390 Kconfig.debug files. Arnd Bergman noted that the help text was slightly misleading and should be fixed to state that enabling this option isn't a problem when using pre 4.4 gcc. To simplify the rewording, consolidate the text into lib/Kconfig.debug and modify it there to be more explicit about when you should say N to this config. Also, make the text a bit more generic by stating that this option enables compile time checks so we can cover architectures which emit warnings vs. ones which emit errors. The details of how an architecture decided to implement the checks isn't as important as the concept of compile time checking of copy_from_user() calls. While we're doing this, remove all the copy_from_user_overflow() code that's duplicated many times and place it into lib/ so that any architecture supporting this option can get the function for free. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Ingo Molnar <mingo@kernel.org> Acked-by: H. Peter Anvin <hpa@zytor.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Helge Deller <deller@gmx.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30dump_stack: unify debug information printed by show_regs()Tejun Heo
show_regs() is inherently arch-dependent but it does make sense to print generic debug information and some archs already do albeit in slightly different forms. This patch introduces a generic function to print debug information from show_regs() so that different archs print out the same information and it's much easier to modify what's printed. show_regs_print_info() prints out the same debug info as dump_stack() does plus task and thread_info pointers. * Archs which didn't print debug info now do. alpha, arc, blackfin, c6x, cris, frv, h8300, hexagon, ia64, m32r, metag, microblaze, mn10300, openrisc, parisc, score, sh64, sparc, um, xtensa * Already prints debug info. Replaced with show_regs_print_info(). The printed information is superset of what used to be there. arm, arm64, avr32, mips, powerpc, sh32, tile, unicore32, x86 * s390 is special in that it used to print arch-specific information along with generic debug info. Heiko and Martin think that the arch-specific extra isn't worth keeping s390 specfic implementation. Converted to use the generic version. Note that now all archs print the debug info before actual register dumps. An example BUG() dump follows. kernel BUG at /work/os/work/kernel/workqueue.c:4841! invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC Modules linked in: CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #7 Hardware name: empty empty/S3992, BIOS 080011 10/26/2007 task: ffff88007c85e040 ti: ffff88007c860000 task.ti: ffff88007c860000 RIP: 0010:[<ffffffff8234a07e>] [<ffffffff8234a07e>] init_workqueues+0x4/0x6 RSP: 0000:ffff88007c861ec8 EFLAGS: 00010246 RAX: ffff88007c861fd8 RBX: ffffffff824466a8 RCX: 0000000000000001 RDX: 0000000000000046 RSI: 0000000000000001 RDI: ffffffff8234a07a RBP: ffff88007c861ec8 R08: 0000000000000000 R09: 0000000000000000 R10: 0000000000000001 R11: 0000000000000000 R12: ffffffff8234a07a R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000 FS: 0000000000000000(0000) GS:ffff88007dc00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: ffff88015f7ff000 CR3: 00000000021f1000 CR4: 00000000000007f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Stack: ffff88007c861ef8 ffffffff81000312 ffffffff824466a8 ffff88007c85e650 0000000000000003 0000000000000000 ffff88007c861f38 ffffffff82335e5d ffff88007c862080 ffffffff8223d8c0 ffff88007c862080 ffffffff81c47760 Call Trace: [<ffffffff81000312>] do_one_initcall+0x122/0x170 [<ffffffff82335e5d>] kernel_init_freeable+0x9b/0x1c8 [<ffffffff81c47760>] ? rest_init+0x140/0x140 [<ffffffff81c4776e>] kernel_init+0xe/0xf0 [<ffffffff81c6be9c>] ret_from_fork+0x7c/0xb0 [<ffffffff81c47760>] ? rest_init+0x140/0x140 ... v2: Typo fix in x86-32. v3: CPU number dropped from show_regs_print_info() as dump_stack_print_info() has been updated to print it. s390 specific implementation dropped as requested by s390 maintainers. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: Chris Metcalf <cmetcalf@tilera.com> [tile bits] Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon bits] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30Merge branch 'smp-hotplug-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull SMP/hotplug changes from Ingo Molnar: "This is a pretty large, multi-arch series unifying and generalizing the various disjunct pieces of idle routines that architectures have historically copied from each other and have grown in random, wildly inconsistent and sometimes buggy directions: 101 files changed, 455 insertions(+), 1328 deletions(-) this went through a number of review and test iterations before it was committed, it was tested on various architectures, was exposed to linux-next for quite some time - nevertheless it might cause problems on architectures that don't read the mailing lists and don't regularly test linux-next. This cat herding excercise was motivated by the -rt kernel, and was brought to you by Thomas "the Whip" Gleixner." * 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (40 commits) idle: Remove GENERIC_IDLE_LOOP config switch um: Use generic idle loop ia64: Make sure interrupts enabled when we "safe_halt()" sparc: Use generic idle loop idle: Remove unused ARCH_HAS_DEFAULT_IDLE bfin: Fix typo in arch_cpu_idle() xtensa: Use generic idle loop x86: Use generic idle loop unicore: Use generic idle loop tile: Use generic idle loop tile: Enter idle with preemption disabled sh: Use generic idle loop score: Use generic idle loop s390: Use generic idle loop powerpc: Use generic idle loop parisc: Use generic idle loop openrisc: Use generic idle loop mn10300: Use generic idle loop mips: Use generic idle loop microblaze: Use generic idle loop ...
2013-04-29early_printk: consolidate random copies of identical codeThomas Gleixner
The early console implementations are the same all over the place. Move the print function to kernel/printk and get rid of the copies. [akpm@linux-foundation.org: arch/mips/kernel/early_printk.c needs kernel.h for va_list] [paul.gortmaker@windriver.com: sh4: make the bios early console support depend on EARLY_PRINTK] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Mike Frysinger <vapier@gentoo.org> Cc: Michal Simek <monstr@monstr.eu> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Richard Weinberger <richard@nod.at> Reviewed-by: Ingo Molnar <mingo@kernel.org> Tested-by: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29mm, vmalloc: change iterating a vmlist to find_vm_area()Joonsoo Kim
This patchset removes vm_struct list management after initializing vmalloc. Adding and removing an entry to vmlist is linear time complexity, so it is inefficient. If we maintain this list, overall time complexity of adding and removing area to vmalloc space is O(N), although we use rbtree for finding vacant place and it's time complexity is just O(logN). And vmlist and vmlist_lock is used many places of outside of vmalloc.c. It is preferable that we hide this raw data structure and provide well-defined function for supporting them, because it makes that they cannot mistake when manipulating theses structure and it makes us easily maintain vmalloc layer. For kexec and makedumpfile, I export vmap_area_list, instead of vmlist. This comes from Atsushi's recommendation. For more information, please refer below link. https://lkml.org/lkml/2012/12/6/184 This patch: The purpose of iterating a vmlist is finding vm area with specific virtual address. find_vm_area() is provided for this purpose and more efficient, because it uses a rbtree. So change it. Signed-off-by: Joonsoo Kim <js1304@gmail.com> Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Ingo Molnar <mingo@kernel.org> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Atsushi Kumagai <kumagai-atsushi@mxc.nes.nec.co.jp> Cc: Dave Anderson <anderson@redhat.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29mm/hugetlb: add more arch-defined huge_pte functionsGerald Schaefer
Commit abf09bed3cce ("s390/mm: implement software dirty bits") introduced another difference in the pte layout vs. the pmd layout on s390, thoroughly breaking the s390 support for hugetlbfs. This requires replacing some more pte_xxx functions in mm/hugetlbfs.c with a huge_pte_xxx version. This patch introduces those huge_pte_xxx functions and their generic implementation in asm-generic/hugetlb.h, which will now be included on all architectures supporting hugetlbfs apart from s390. This change will be a no-op for those architectures. [akpm@linux-foundation.org: fix warning] Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Hugh Dickins <hughd@google.com> Cc: Hillf Danton <dhillf@gmail.com> Acked-by: Michal Hocko <mhocko@suse.cz> [for !s390 parts] Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-24arch/tile: Fix syscall return value passed to tracepointSimon Marchi
Currently the syscall number is passed, but it should be the return value, which is kept in r0. Signed-off-by: Simon Marchi <simon.marchi@polymtl.ca> Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> [using a raw 0 value]
2013-04-17idle: Remove GENERIC_IDLE_LOOP config switchThomas Gleixner
All archs are converted over. Remove the config switch and the fallback code. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-04-09procfs: new helper - PDE_DATA(inode)Al Viro
The only part of proc_dir_entry the code outside of fs/proc really cares about is PDE(inode)->data. Provide a helper for that; static inline for now, eventually will be moved to fs/proc, along with the knowledge of struct proc_dir_entry layout. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-09tile: comment assumption about __insn_mtspr for <asm/irqflags.h>Chris Metcalf
The arch_local_irq_save(), etc., routines are required to function as compiler barriers. They do, but it's subtle and requires knowing that the gcc builtin __insn_mtspr() is marked as a memory clobber. Provide a comment explaining the assumption. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> [ This came about from me wondering about the synchronization rules of __insn_mtspr() - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-08tile: Use generic idle loopThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Reviewed-by: Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Magnus Damm <magnus.damm@gmail.com> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Link: http://lkml.kernel.org/r/20130321215235.348460344@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-04-08tile: Enter idle with preemption disabledThomas Gleixner
cpu_idle() needs to be called with preemption disabled. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Reviewed-by: Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Magnus Damm <magnus.damm@gmail.com> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Link: http://lkml.kernel.org/r/20130321215235.280451779@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-04-08arch: Consolidate tsk_is_polling()Thomas Gleixner
Move it to a common place. Preparatory patch for implementing set/clear for the idle need_resched poll implementation. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Reviewed-by: Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Magnus Damm <magnus.damm@gmail.com> Link: http://lkml.kernel.org/r/20130321215233.446034505@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-04-01Merge branch 'stable' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile Pull arch/tile fix from Chris Metcalf: "This change allows newer Tilera boot tools to work correctly with current (and stable) kernels by using the right filename to get the initramfs from the Tilera hypervisor filesystem." * 'stable' of git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: tile: expect new initramfs name from hypervisor file system
2013-03-29tile: expect new initramfs name from hypervisor file systemChris Metcalf
The current Tilera boot infrastructure now provides the initramfs to Linux as a Tilera-hypervisor file named "initramfs", rather than "initramfs.cpio.gz", as before. (This makes it reasonable to use other compression techniques than gzip on the file without having to worry about the name causing confusion.) Adapt to use the new name, but also fall back to checking for the old name. Cc'ing to stable so that older kernels will remain compatible with newer Tilera boot infrastructure. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Cc: stable@vger.kernel.org
2013-03-26tile: ns2cycles should use __raw_get_cpu_varHenrik Austad
ns2cycles use per_cpu variables, and will, eventually, find its way into smp_processor_id(). This is not safe in a preemptible kernel; preemption should ideally be disabled. BUG: using smp_processor_id() in preemptible [00000000] code: systemd-modules/367 caller is ns2cycles+0x40/0xb8 Starting stack dump of tid 367, pid 367 (systemd-modules) on cpu 2 at cycle 20969956421 frame 0: 0xfffffff70004b860 dump_stack+0x0/0x20 (sp 0xfffffe407993fa90) frame 1: 0xfffffff7006abc28 debug_smp_processor_id+0x1a8/0x1e0 (sp 0xfffffe407993fa90) frame 2: 0xfffffff7004d7b40 ns2cycles+0x40/0xb8 (sp 0xfffffe407993fab8) frame 3: 0xfffffff7004dc578 __ndelay+0x38/0x80 (sp 0xfffffe407993fae0) However, in this case: - the frequency is the same accross all cores - we use the data read-only - we do not scale the frequency Which means that we can use the __raw_get_cpu_var instead. Signed-off-by: Henrik Austad <haustad@cisco.com> Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2013-03-23Merge tag 'md-3.9-fixes' of git://neil.brown.name/mdLinus Torvalds
Pull md fixes from NeilBrown: "A few bugfixes for md - recent regressions in raid5 - recent regressions in dmraid - a few instances of CONFIG_MULTICORE_RAID456 linger Several tagged for -stable" * tag 'md-3.9-fixes' of git://neil.brown.name/md: md: remove CONFIG_MULTICORE_RAID456 entirely md/raid5: ensure sync and DISCARD don't happen at the same time. MD: Prevent sysfs operations on uninitialized kobjects MD RAID5: Avoid accessing gendisk or queue structs when not available md/raid5: schedule_construction should abort if nothing to do.
2013-03-22arch: remove KCORE_ELF again [tile]Paul Bolle
The Kconfig symbol KCORE_ELF was removed in v2.6.0, but reappeared in two architectures. It is useless. Remove it again. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> (tile only)
2013-03-22tile: remove two outdated Kconfig entriesPaul Bolle
Tile support got added in v2.6.36. Its main Kconfig file was added with two outdated Kconfig entries. DEFAULT_MIGRATION_COST is unused since v2.6.23, and SEMAPHORE_SLEEPERS is unused since v2.6.26. Remove these outdated entries now. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2013-03-22tile: support atomic64_dec_if_positive()Chris Metcalf
Use the normal cmpxchg() idiom to implement this functionality. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2013-03-22tile: support TIF_SYSCALL_TRACEPOINT; select HAVE_SYSCALL_TRACEPOINTSSimon Marchi
This patch adds support for the TIF_SYSCALL_TRACEPOINT on the tile architecture. Basically, it calls the appropriate tracepoints on syscall entry and exit. Signed-off-by: Simon Marchi <simon.marchi@polymtl.ca> Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2013-03-21tile: Add definition of NR_syscallsSimon Marchi
It is required by the syscall tracepoint mechanism. Signed-off-by: Simon Marchi <simon.marchi@polymtl.ca> Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2013-03-21tile: move declaration of sys_call_table to <asm/syscall.h>Simon Marchi
When activating syscall tracing, kernel/trace/trace_syscalls.c doesn't find sys_call_table because it includes <asm/syscall.h>, not <asm/syscalls.h>. Also, looking at the other architectures, that is probably where it should be. Signed-off-by: Simon Marchi <simon.marchi@polymtl.ca> Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2013-03-21arch/tile: Enable HAVE_ARCH_TRACEHOOKSimon Marchi
Looks like we have everything needed for that. Signed-off-by: Simon Marchi <simon.marchi@polymtl.ca> Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2013-03-21arch/tile: Call tracehook_report_syscall_{entry,exit} in syscall traceSimon Marchi
Call tracehook functions for syscall tracing. The check for TIF_SYSCALL_TRACE was removed, because the same check is done right before in the assembly file. Signed-off-by: Simon Marchi <simon.marchi@polymtl.ca> Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> [with ptrace.h fixup]
2013-03-20md: remove CONFIG_MULTICORE_RAID456 entirelyPaul Bolle
Once instance of this Kconfig macro remained after commit 51acbcec6c42b24482bac18e42befc822524535d ("md: remove CONFIG_MULTICORE_RAID456"). Remove that one too. And, while we're at it, also remove it from the defconfig files that carry it. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: NeilBrown <neilb@suse.de>
2013-03-12Select VIRT_TO_BUS directly where neededStephen Rothwell
In commit 887cbce0adea ("arch Kconfig: centralise ARCH_NO_VIRT_TO_BUS") I introduced the config sybmol HAVE_VIRT_TO_BUS and selected that where needed. I am not sure what I was thinking. Instead, just directly select VIRT_TO_BUS where it is needed. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-04tile: properly use COMPAT_SYSCALL_DEFINExChris Metcalf
This was pointed out by Al Viro. Using the correct wrappers properly does sign extension as necessary on syscall arguments. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2013-03-04tile: work around bug in the generic sys_llseekChris Metcalf
sys_llseek should specify the high and low 32-bit seek values as "unsigned int" but instead it specifies "unsigned long". Since compat syscall arguments are always sign-extended on tile, this means that a seek value of 0xffffffff will be incorrectly interpreted as a value of -1ULL. To avoid the risk of breaking binary compatibility on architectures that already use sys_llseek this way, we follow the same path as MIPS and provide a wrapper override. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Cc: stable@kernel.org [v3.6 onwards]
2013-03-03consolidate compat lookup_dcookie()Al Viro
2013-03-03make HAVE_SYSCALL_WRAPPERS unconditionalAl Viro
2013-02-27arch Kconfig: centralise CONFIG_ARCH_NO_VIRT_TO_BUSStephen Rothwell
Change it to CONFIG_HAVE_VIRT_TO_BUS and set it in all architecures that already provide virt_to_bus(). Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Reviewed-by: James Hogan <james.hogan@imgtec.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: H Hartley Sweeten <hartleys@visionengravers.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Vineet Gupta <Vineet.Gupta1@synopsys.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull signal handling cleanups from Al Viro: "This is the first pile; another one will come a bit later and will contain SYSCALL_DEFINE-related patches. - a bunch of signal-related syscalls (both native and compat) unified. - a bunch of compat syscalls switched to COMPAT_SYSCALL_DEFINE (fixing several potential problems with missing argument validation, while we are at it) - a lot of now-pointless wrappers killed - a couple of architectures (cris and hexagon) forgot to save altstack settings into sigframe, even though they used the (uninitialized) values in sigreturn; fixed. - microblaze fixes for delivery of multiple signals arriving at once - saner set of helpers for signal delivery introduced, several architectures switched to using those." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (143 commits) x86: convert to ksignal sparc: convert to ksignal arm: switch to struct ksignal * passing alpha: pass k_sigaction and siginfo_t using ksignal pointer burying unused conditionals make do_sigaltstack() static arm64: switch to generic old sigaction() (compat-only) arm64: switch to generic compat rt_sigaction() arm64: switch compat to generic old sigsuspend arm64: switch to generic compat rt_sigqueueinfo() arm64: switch to generic compat rt_sigpending() arm64: switch to generic compat rt_sigprocmask() arm64: switch to generic sigaltstack sparc: switch to generic old sigsuspend sparc: COMPAT_SYSCALL_DEFINE does all sign-extension as well as SYSCALL_DEFINE sparc: kill sign-extending wrappers for native syscalls kill sparc32_open() sparc: switch to use of generic old sigaction sparc: switch sys_compat_rt_sigaction() to COMPAT_SYSCALL_DEFINE mips: switch to generic sys_fork() and sys_clone() ...
2013-02-23swap: add per-partition lock for swapfileShaohua Li
swap_lock is heavily contended when I test swap to 3 fast SSD (even slightly slower than swap to 2 such SSD). The main contention comes from swap_info_get(). This patch tries to fix the gap with adding a new per-partition lock. Global data like nr_swapfiles, total_swap_pages, least_priority and swap_list are still protected by swap_lock. nr_swap_pages is an atomic now, it can be changed without swap_lock. In theory, it's possible get_swap_page() finds no swap pages but actually there are free swap pages. But sounds not a big problem. Accessing partition specific data (like scan_swap_map and so on) is only protected by swap_info_struct.lock. Changing swap_info_struct.flags need hold swap_lock and swap_info_struct.lock, because scan_scan_map() will check it. read the flags is ok with either the locks hold. If both swap_lock and swap_info_struct.lock must be hold, we always hold the former first to avoid deadlock. swap_entry_free() can change swap_list. To delete that code, we add a new highest_priority_index. Whenever get_swap_page() is called, we check it. If it's valid, we use it. It's a pity get_swap_page() still holds swap_lock(). But in practice, swap_lock() isn't heavily contended in my test with this patch (or I can say there are other much more heavier bottlenecks like TLB flush). And BTW, looks get_swap_page() doesn't really need the lock. We never free swap_info[] and we check SWAP_WRITEOK flag. The only risk without the lock is we could swapout to some low priority swap, but we can quickly recover after several rounds of swap, so sounds not a big deal to me. But I'd prefer to fix this if it's a real problem. "swap: make each swap partition have one address_space" improved the swapout speed from 1.7G/s to 2G/s. This patch further improves the speed to 2.3G/s, so around 15% improvement. It's a multi-process test, so TLB flush isn't the biggest bottleneck before the patches. [arnd@arndb.de: fix it for nommu] [hughd@google.com: add missing unlock] [minchan@kernel.org: get rid of lockdep whinge on sys_swapon] Signed-off-by: Shaohua Li <shli@fusionio.com> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Seth Jennings <sjenning@linux.vnet.ibm.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Cc: Dan Magenheimer <dan.magenheimer@oracle.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-23memory-hotplug: introduce new arch_remove_memory() for removing page tableWen Congyang
For removing memory, we need to remove page tables. But it depends on architecture. So the patch introduce arch_remove_memory() for removing page table. Now it only calls __remove_pages(). Note: __remove_pages() for some archtecuture is not implemented (I don't know how to implement it for s390). Signed-off-by: Wen Congyang <wency@cn.fujitsu.com> Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Jiang Liu <jiang.liu@huawei.com> Cc: Jianguo Wu <wujianguo@huawei.com> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Wu Jianguo <wujianguo@huawei.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-23mm: remove flags argument to mmap_regionMichel Lespinasse
After the MAP_POPULATE handling has been moved to mmap_region() call sites, the only remaining use of the flags argument is to pass the MAP_NORESERVE flag. This can be just as easily handled by do_mmap_pgoff(), so do that and remove the mmap_region() flags parameter. [akpm@linux-foundation.org: remove double parens] Signed-off-by: Michel Lespinasse <walken@google.com> Acked-by: Rik van Riel <riel@redhat.com> Tested-by: Andy Lutomirski <luto@amacapital.net> Cc: Greg Ungerer <gregungerer@westnet.com.au> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21Merge branch 'akpm' (incoming from Andrew)Linus Torvalds
Merge misc patches from Andrew Morton: - Florian has vanished so I appear to have become fbdev maintainer again :( - Joel and Mark are distracted to welcome to the new OCFS2 maintainer - The backlight queue - Small core kernel changes - lib/ updates - The rtc queue - Various random bits * akpm: (164 commits) rtc: rtc-davinci: use devm_*() functions rtc: rtc-max8997: use devm_request_threaded_irq() rtc: rtc-max8907: use devm_request_threaded_irq() rtc: rtc-da9052: use devm_request_threaded_irq() rtc: rtc-wm831x: use devm_request_threaded_irq() rtc: rtc-tps80031: use devm_request_threaded_irq() rtc: rtc-lp8788: use devm_request_threaded_irq() rtc: rtc-coh901331: use devm_clk_get() rtc: rtc-vt8500: use devm_*() functions rtc: rtc-tps6586x: use devm_request_threaded_irq() rtc: rtc-imxdi: use devm_clk_get() rtc: rtc-cmos: use dev_warn()/dev_dbg() instead of printk()/pr_debug() rtc: rtc-pcf8583: use dev_warn() instead of printk() rtc: rtc-sun4v: use pr_warn() instead of printk() rtc: rtc-vr41xx: use dev_info() instead of printk() rtc: rtc-rs5c313: use pr_err() instead of printk() rtc: rtc-at91rm9200: use dev_dbg()/dev_err() instead of printk()/pr_debug() rtc: rtc-rs5c372: use dev_dbg()/dev_warn() instead of printk()/pr_debug() rtc: rtc-ds2404: use dev_err() instead of printk() rtc: rtc-efi: use dev_err()/dev_warn()/pr_err() instead of printk() ...
2013-02-21block: optionally snapshot page contents to provide stable pages during writeDarrick J. Wong
This provides a band-aid to provide stable page writes on jbd without needing to backport the fixed locking and page writeback bit handling schemes of jbd2. The band-aid works by using bounce buffers to snapshot page contents instead of waiting. For those wondering about the ext3 bandage -- fixing the jbd locking (which was done as part of ext4dev years ago) is a lot of surgery, and setting PG_writeback on data pages when we actually hold the page lock dropped ext3 performance by nearly an order of magnitude. If we're going to migrate iscsi and raid to use stable page writes, the complaints about high latency will likely return. We might as well centralize their page snapshotting thing to one place. Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Tested-by: Andy Lutomirski <luto@amacapital.net> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Artem Bityutskiy <dedekind1@gmail.com> Reviewed-by: Jan Kara <jack@suse.cz> Cc: Joel Becker <jlbec@evilplan.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Ron Minnich <rminnich@sandia.gov> Cc: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21Merge tag 'tty-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial patches from Greg Kroah-Hartman: "Here's the big tty/serial driver patches for 3.9-rc1. More tty port rework and fixes from Jiri here, as well as lots of individual serial driver updates and fixes. All of these have been in the linux-next tree for a while." * tag 'tty-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (140 commits) tty: mxser: improve error handling in mxser_probe() and mxser_module_init() serial: imx: fix uninitialized variable warning serial: tegra: assume CONFIG_OF TTY: do not update atime/mtime on read/write lguest: select CONFIG_TTY to build properly. ARM defconfigs: add missing inclusions of linux/platform_device.h fb/exynos: include platform_device.h ARM: sa1100/assabet: include platform_device.h directly serial: imx: Fix recursive locking bug pps: Fix build breakage from decoupling pps from tty tty: Remove ancient hardpps() pps: Additional cleanups in uart_handle_dcd_change pps: Move timestamp read into PPS code proper pps: Don't crash the machine when exiting will do pps: Fix a use-after free bug when unregistering a source. pps: Use pps_lookup_dev to reduce ldisc coupling pps: Add pps_lookup_dev() function tty: serial: uartlite: Support uartlite on big and little endian systems tty: serial: uartlite: Fix sparse and checkpatch warnings serial/arc-uart: Miscll DT related updates (Grant's review comments) ... Fix up trivial conflicts, mostly just due to the TTY config option clashing with the EXPERIMENTAL removal.
2013-02-21Merge tag 'driver-core-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core patches from Greg Kroah-Hartman: "Here is the big driver core merge for 3.9-rc1 There are two major series here, both of which touch lots of drivers all over the kernel, and will cause you some merge conflicts: - add a new function called devm_ioremap_resource() to properly be able to check return values. - remove CONFIG_EXPERIMENTAL Other than those patches, there's not much here, some minor fixes and updates" Fix up trivial conflicts * tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits) base: memory: fix soft/hard_offline_page permissions drivercore: Fix ordering between deferred_probe and exiting initcalls backlight: fix class_find_device() arguments TTY: mark tty_get_device call with the proper const values driver-core: constify data for class_find_device() firmware: Ignore abort check when no user-helper is used firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER firmware: Make user-mode helper optional firmware: Refactoring for splitting user-mode helper code Driver core: treat unregistered bus_types as having no devices watchdog: Convert to devm_ioremap_resource() thermal: Convert to devm_ioremap_resource() spi: Convert to devm_ioremap_resource() power: Convert to devm_ioremap_resource() mtd: Convert to devm_ioremap_resource() mmc: Convert to devm_ioremap_resource() mfd: Convert to devm_ioremap_resource() media: Convert to devm_ioremap_resource() iommu: Convert to devm_ioremap_resource() drm: Convert to devm_ioremap_resource() ...
2013-02-14burying unused conditionalsAl Viro
__ARCH_WANT_SYS_RT_SIGACTION, __ARCH_WANT_SYS_RT_SIGSUSPEND, __ARCH_WANT_COMPAT_SYS_RT_SIGSUSPEND, __ARCH_WANT_COMPAT_SYS_SCHED_RR_GET_INTERVAL - not used anymore CONFIG_GENERIC_{SIGALTSTACK,COMPAT_RT_SIG{ACTION,QUEUEINFO,PENDING,PROCMASK}} - can be assumed always set.
2013-02-08tile: tag some code with #ifdef CONFIG_COMPATChris Metcalf
This allows us to disable COMPAT mode without a link error. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2013-02-08tile: fix memcpy_*io functions for allnoconfigChris Metcalf
On tilepro without CONFIG_PCI, we can't provide inlines of these functions, as we don't have readl/writel. In addition, fix memset_io() signature to take a volatile void *. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
