commit f862eefec0b68e099a9fa58d3761ffb10bad97e1 upstream.
It turns out the kernel relies on barrier() to force a reload of the
percpu offset value. Since we can't easily modify the definition of
barrier() to include "tp" as an output register, we instead provide a
definition of __my_cpu_offset as extended assembly that includes a fake
stack read to hazard against barrier(), forcing gcc to know that it
must reread "tp" and recompute anything based on "tp" after a barrier.
This fixes observed hangs in the slub allocator when we are looping
on a percpu cmpxchg_double.
A similar fix for ARMv7 was made in June in change 509eb76ebf97.
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
commit 3cb3f839d306443f3d1e79b0bde1a2ad2c12b555 upstream.
gcc 4.7.x is emitting calls to __ffsdi2 where previously
it used to inline the appropriate ctz instructions.
While this needs to be fixed in gcc, it's also easy to avoid
having it cause build failures when building with those
compilers by exporting __ffsdi2 to modules.
commit 627072b06c362bbe7dc256f618aaa63351f0cfe6 upstream.
The tile tool chain uses the .eh_frame information for backtracing.
The vmlinux build drops any .eh_frame sections at link time, but when
present in kernel modules, it causes a module load failure due to the
presence of unsupported pc-relative relocations. When compiling to
use compiler feedback support, the compiler by default omits .eh_frame
information, so we don't see this problem. But when not using feedback,
we need to explicitly suppress the .eh_frame.
commit 9f1d62bed7f015d11b9164078b7fea433b474114 upstream.
This is because __builtin_clz(0) returns 64 for the "undefined" case
of 0, since the builtin just does a right-shift 32 and "clz" instruction.
So, use the alpha approach of casting to u32 and using __builtin_clzll().
commit e6d9668e119af44ae5bcd5f1197174531458afe3 upstream.
Some discussion with the glibc mailing lists revealed that this was
necessary for 64-bit platforms with MIPS-like sign-extension rules
for 32-bit values. The original symptom was that passing (uid_t)-1 to
setreuid() was failing in programs linked -pthread because of the "setxid"
mechanism for passing setxid-type function arguments to the syscall code.
SYSCALL_WRAPPERS handles ensuring that all syscall arguments end up with
proper sign-extension and is thus the appropriate fix for this problem.
On other platforms (s390, powerpc, sparc64, and mips) this was fixed
in 2.6.28.6. The general issue is tracked as CVE-2009-0029.
commit a134d228298c6aa9007205c6b81cae0cac0acb5d upstream.
This passes siginfo and mcontext to tilegx32 signal handlers that
don't have SA_SIGINFO set just as we have been doing for tilegx64.
commit 21a3c96 uses node_start/end_pfn(nid) for detection start/end
of nodes. But, it's not defined in linux/mmzone.h but defined in
/arch/???/include/mmzone.h which is included only under
CONFIG_NEED_MULTIPLE_NODES=y.
Then, we see
mm/page_cgroup.c: In function 'page_cgroup_init':
mm/page_cgroup.c:308: error: implicit declaration of function 'node_start_pfn'
mm/page_cgroup.c:309: error: implicit declaration of function 'node_end_pfn'
So, fixiing page_cgroup.c is an idea...
But node_start_pfn()/node_end_pfn() is a very generic macro and
should be implemented in the same manner for all archs.
(m32r has different implementation...)
This patch removes definitions of node_start/end_pfn() in each archs
and defines a unified one in linux/mmzone.h. It's not under
CONFIG_NEED_MULTIPLE_NODES, now.
A result of macro expansion is here (mm/page_cgroup.c)
for !NUMA
start_pfn = ((&contig_page_data)->node_start_pfn);
end_pfn = ({ pg_data_t *__pgdat = (&contig_page_data); __pgdat->node_start_pfn + __pgdat->node_spanned_pages;});
for NUMA (x86-64)
start_pfn = ((node_data[nid])->node_start_pfn);
end_pfn = ({ pg_data_t *__pgdat = (node_data[nid]); __pgdat->node_start_pfn + __pgdat->node_spanned_pages;});
Changelog:
- fixed to avoid using "nid" twice in node_end_pfn() macro.
Reported-and-acked-by: Randy Dunlap <randy.dunlap@oracle.com>
Reported-and-tested-by: Ingo Molnar <mingo@elte.hu>
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile:
arch/tile: more /proc and /sys file support
This change introduces a few of the less controversial /proc and
/proc/sys interfaces for tile, along with sysfs attributes for
various things that were originally proposed as /proc/tile files.
It also adjusts the "hardwall" proc API.
Arnd Bergmann reviewed the initial arch/tile submission, which
included a complete set of all the /proc/tile and /proc/sys/tile
knobs that we had added in a somewhat ad hoc way during initial
development, and provided feedback on where most of them should go.
One knob turned out to be similar enough to the existing
/proc/sys/debug/exception-trace that it was re-implemented to use
that model instead.
Another knob was /proc/tile/grid, which reported the "grid" dimensions
of a tile chip (e.g. 8x8 processors = 64-core chip). Arnd suggested
looking at sysfs for that, so this change moves that information
to a pair of sysfs attributes (chip_width and chip_height) in the
/sys/devices/system/cpu directory. We also put the "chip_serial"
and "chip_revision" information from our old /proc/tile/board file
as attributes in /sys/devices/system/cpu.
Other information collected via hypervisor APIs is now placed in
/sys/hypervisor. We create a /sys/hypervisor/type file (holding the
constant string "tilera") to be parallel with the Xen use of
/sys/hypervisor/type holding "xen". We create three top-level files,
"version" (the hypervisor's own version), "config_version" (the
version of the configuration file), and "hvconfig" (the contents of
the configuration file). The remaining information from our old
/proc/tile/board and /proc/tile/switch files becomes an attribute
group appearing under /sys/hypervisor/board/.
Finally, after some feedback from Arnd Bergmann for the previous
version of this patch, the /proc/tile/hardwall file is split up into
two conceptual parts. First, a directory /proc/tile/hardwall/ which
contains one file per active hardwall, each file named after the
hardwall's ID and holding a cpulist that says which cpus are enclosed by
the hardwall. Second, a /proc/PID file "hardwall" that is either
empty (for non-hardwall-using processes) or contains the hardwall ID.
Finally, this change pushes the /proc/sys/tile/unaligned_fixup/
directory, with knobs controlling the kernel code for handling the
fixup of unaligned exceptions.
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
By the previous style change, CONFIG_GENERIC_FIND_NEXT_BIT,
CONFIG_GENERIC_FIND_BIT_LE, and CONFIG_GENERIC_FIND_LAST_BIT are not used
to test for existence of find bitops anymore.
Acked-by: Greg Ungerer <gerg@uclinux.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: (26 commits)
arch/tile: prefer "tilepro" as the name of the 32-bit architecture
compat: include aio_abi.h for aio_context_t
arch/tile: cleanups for tilegx compat mode
arch/tile: allocate PCI IRQs later in boot
arch/tile: support signal "exception-trace" hook
arch/tile: use better definitions of xchg() and cmpxchg()
include/linux/compat.h: coding-style fixes
tile: add an RTC driver for the Tilera hypervisor
arch/tile: finish enabling support for TILE-Gx 64-bit chip
compat: fixes to allow working with tile arch
arch/tile: update defconfig file to something more useful
tile: do_hardwall_trap: do not play with task->sighand
tile: replace mm->cpu_vm_mask with mm_cpumask()
tile,mn10300: add device parameter to dma_cache_sync()
audit: support the "standard" <asm-generic/unistd.h>
arch/tile: clarify flush_buffer()/finv_buffer() function names
arch/tile: kernel-related cleanups from removing static page size
arch/tile: various header improvements for building drivers
arch/tile: disable GX prefetcher during cache flush
arch/tile: tolerate disabling CONFIG_BLK_DEV_INITRD
With this change, you can (and should) build with ARCH=tilepro for the
current 32-bit chips. Building with ARCH=tile continues to work, but
we've renamed the defconfig file to tilepro_defconfig for consistency.
Most arches define CONFIG_DEBUG_STACK_USAGE exactly the same way. Move it
to lib/Kconfig.debug so each arch doesn't have to define it. This
obviously makes the option generic, but that's fine because the config is
already used in generic code.
It's not obvious to me that sysrq-P actually does anything caution by
keeping the most inclusive wording.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Acked-by: Richard Weinberger <richard@nod.at>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Cc: Chen Liqin <liqin.chen@sunplusct.com>
Cc: Lennox Wu <lennox.wu@gmail.com>
Fold all the mmu_gather rework patches into one for submission
Reported-by: Hugh Dickins <hughd@google.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Namhyung Kim <namhyung@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-2.6.40' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu:
percpu: Unify input section names
percpu: Avoid extra NOP in percpu_cmpxchg16b_double
percpu: Cast away printk format warning
percpu: Always align percpu output section to PAGE_SIZE
Fix up fairly trivial conflict in arch/x86/include/asm/percpu.h as per Tejun
These changes make the syscall table line up correctly for
tilegx compat mode, and remove the stale sys32_fadvise64() function,
which isn't actually used by any syscall table.
This change became required due to some recent reworking in the
platform-independent IRQ code. It is required for 2.6.38 and later.
Cc: stable@kernel.org
This change adds support for /proc/sys/debug/exception-trace to tile.
Like x86 and sparc, by default it is set to "1", generating a one-line
printk whenever a user process crashes. By setting it to "2", we get
a much more complete userspace diagnostic at crash time, including
a user-space backtrace, register dump, and memory dump around the
address of the crash.
Some vestiges of the Tilera-internal version of this support are
removed with this patch (the show_crashinfo variable and the
arch_coredump_signal function). We retain a "crashinfo" boot parameter
which allows you to set the boot-time value of exception-trace.
These definitions use a ({}) construct to avoid some cases where
we were getting warnings about unused return values. We also
promote the definition to the common <asm/atomic.h>, since it applies
to both the 32- and 64-bit atomics.
In addition, define __HAVE_ARCH_CMPXCHG for TILE-Gx since it has
efficient direct atomic instructions.
This is a simple RTC driver that lets Tilera hardware boot up and
set the clock correctly.
Acked-by: Andrew Morton <akpm@linux-foundation.org>
This support was partially present in the existing code (look for
"__tilegx__" ifdefs) but with this change you can build a working
kernel using the TILE-Gx toolchain and ARCH=tilegx.
Most of these files are new, generally adding a foo_64.c file
where previously there was just a foo_32.c file.
The ARCH=tilegx directive redirects to arch/tile, not arch/tilegx,
using the existing SRCARCH mechanism in the top-level Makefile.
Changes to existing files:
- <asm/bitops.h> and <asm/bitops_32.h> changed to factor the
include of <asm-generic/bitops/non-atomic.h> in the common header.
- <asm/compat.h> and arch/tile/kernel/compat.c changed to remove
the "const" markers I had put on compat_sys_execve() when trying
to match some recent similar changes to the non-compat execve.
It turns out the compat version wasn't "upgraded" to use const.
- <asm/opcode-tile_64.h> and <asm/opcode_constants_64.h> were
previously included accidentally, with the 32-bit contents. Now
they have the proper 64-bit contents.
Finally, I had to hack the existing hacky drivers/input/input-compat.h
to add yet another "#ifdef" for INPUT_COMPAT_TEST (same as x86_64).
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> [drivers/input]
The existing <asm-generic/unistd.h> mechanism doesn't really provide
enough to create the 64-bit "compat" ABI properly in a generic way,
since the compat ABI is a mix of things were you can re-use the 64-bit
versions of syscalls and things where you need a compat wrapper.
To provide this in the most direct way possible, I added two new macros
to go along with the existing __SYSCALL and __SC_3264 macros: __SC_COMP
and SC_COMP_3264. These macros take an additional argument, typically a
"compat_sys_xxx" function, which is passed to __SYSCALL if you define
__SYSCALL_COMPAT when including the header, resulting in a pointer to
the compat function being placed in the generated syscall table.
The change also adds some missing definitions to <linux/compat.h> so that
it actually has declarations for all the compat syscalls, since the
"[nr] = ##call" approach requires proper C declarations for all the
functions included in the syscall table.
Finally, compat.c defines compat_sys_sigpending() and
compat_sys_sigprocmask() even if the underlying architecture doesn't
request it, which tries to pull in undefined compat_old_sigset_t defines.
We need to guard those compat syscall definitions with appropriate
__ARCH_WANT_SYS_xxx ifdefs.
1. do_hardwall_trap() checks ->sighand != NULL and then takes ->siglock.
This is unsafe even if the task can't run (I assume it is pinned to
the same CPU), its parent can reap the task and set ->sighand = NULL
right after this check. Even if the compiler dosn't read ->sighand
twice and this memory can't to away __group_send_sig_info() is wrong
after that. Use do_send_sig_info().
2. Send SIGILL to the thread, not to the whole process. Unless it has
the handler or blocked this kills the whole thread-group as before.
IIUC, different threads can be bound to different rect's.
3. Check PF_EXITING instead of ->sighand. A zombie thread can go away
but its ->sighand can be !NULL.
Reported-by: Matt Fleming <matt@console-pimps.org>
We plan to change mm->cpu_vm_mask definition later. Thus, this patch convert
it into proper macro.
Since v2.6.20 "Pass struct dev pointer to dma_cache_sync()"
(d3fa72e4556ec1f04e46a0d561d9e785ecaa173d), dma_cache_sync() takes a
struct dev pointer, but these appear to be missing from the tile and
mn10300 implementations, so add them.
Signed-off-by: James Hogan <james.hogan@imgtec.com>
[cmetcalf@tilera.com: took only the "tile" portion as I don't maintain mn10300]
They are only applicable for locally-homecached memory ranges, so
change their names to {flush,finv}_buffer_local(). Change inv_buffer()
to just do an mf instead of any kind of fancier barrier, since you're
obviously not going to be waiting for anything once the local homecache
is invalidated.
Fix tilepro.c network driver not to bother calling finv_buffer when
stopping the EPP, but just mf after memset to ensure that it will not
see any packet data after we finish stopping; use finv_buffer_remote()
when doing exit-time cleanup.
This also fixes a (not very interesting) generic Linux build failure
where drivers/scsi/st.c declares its own flush_buffer().
User space code has been able to discover the static page size
by including a special <hv/pagesize.h> file. In the current release,
that file is now gone, and <asm/page.h> doesn't rely on it. The
getpagesize() API is now the only way for userspace to get the page size.
This change adds a number of missing headers in asm (fb.h, parport.h,
serial.h, and vga.h) using the minimal generic versions.
It also adds a number of missing interfaces that showed up as build
failures when trying to build various drivers not normally included in the
"tile" distribution: ioremap_wc(), memset_io(), io{read,write}{16,32}be(),
virt_to_bus(), bus_to_virt(), irq_canonicalize(), __pte(), __pgd(),
and __pmd(). I also added a cast in virt_to_page() since not all callers
pass a pointer.
I fixed <asm/stat.h> to properly include a __KERNEL__ guard for the
__ARCH_WANT_STAT64 symbol, and <asm/swab.h> to use __builtin_bswap32()
even for our 64-bit architecture, since the same code is produced.
I added an export for get_cycles(), since it's used in some modules.
And I made <arch/spr_def.h> properly include the __KERNEL__ guard,
even though it's not yet exported, since it likely will be soon.
Otherwise, it's possible to end up with the prefetcher pulling
data into cache that the code believes has been flushed.
The code accidentally was relying on this configuration option
being selected.
Otherwise, in principle, there could be stale I$ data present
next time the page that previously held the kernel module code was
used to run some new code.
This allows processes to spread more effectively to multiple cores
(particularly important on 64-core chips!).
This semantic was already true for atomic operations within the kernel,
and this change makes it true for the fast atomic syscalls (__NR_cmpxchg
and __NR_atomic_update) as well. Previously, user-space had to use
the fast atomic syscalls exclusively to update memory, since raw stores
could lose a race with the atomic update code even when the atomic update
hadn't actually modified the value.
With this change, we no longer write back the value to memory if it
hasn't changed. This allows certain types of idioms in user space to
work as expected, e.g. "atomic exchange" to acquire a spinlock, followed
by a raw store of zero to release the lock.
Note that this is not complete hot-plug support; hot-unplug is not included.
This support is required for CONFIG_KEYS, NFSv4 kernel DNS, etc.
The change is slightly more complex than the minimal thing, since
I took advantage of having to go into the assembly code to just
move a bunch of stuff into C code: specifically, the schedule(),
do_async_page_fault(), do_signal(), and single_step_once() support,
in addition to the TIF_NOTIFY_RESUME support.
This change is the result of some work to make the backtrace code more
shareable between kernel, libc, and gdb.
For the kernel, some good effects are to eliminate the hacky
"VirtualAddress" typedef in favor of "unsigned long", to eliminate a
bunch of spurious kernel doc comments, to remove the dead "bt_read_memory"
function, and to use "__tilegx__" in #ifdefs instead of "TILE_CHIP".
For future rework of try_to_wake_up() we'd like to push part of that
function onto the CPU the task is actually going to run on.
In order to do so we need a generic callback from the existing scheduler IPI.
This patch introduces such a generic callback: scheduler_ipi() and
implements it as a NOP.
BenH notes: PowerPC might use this IPI on offline CPUs under rare conditions!
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
Acked-by: Chris Metcalf <cmetcalf@tilera.com>
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Reviewed-by: Frank Rowand <frank.rowand@am.sony.com>
Link: http://lkml.kernel.org/r/20110405152728.744338123@chello.nl
* 'irq-cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
tile: Use generic show_interupts()
tile: Convert to new irq function names
dma: Ipu: Convert interupt code
LKML-Reference: <20110325142049.536190130@linutronix.de>
Converted with coccinelle.
LKML-Reference: <20110325142049.441954268@linutronix.de>
Commit ddd588b5dd55 ("oom: suppress nodes that are not allowed from
meminfo on oom kill") moved lib/show_mem.o out of lib/lib.a, which
resulted in build warnings on all architectures that implement their own
versions of show_mem():
lib/lib.a(show_mem.o): In function `show_mem':
show_mem.c:(.text+0x1f4): multiple definition of `show_mem'
arch/sparc/mm/built-in.o:(.text+0xd70): first defined here
The fix is to remove __show_mem() and add its argument to show_mem() in
all implementations to prevent this breakage.
Architectures that implement their own show_mem() actually don't do
anything with the argument yet, but they could be made to filter nodes
that aren't allowed in the current context in the future just like the
generic implementation.
Reported-by: James Bottomley <James.Bottomley@hansenpartnership.com>
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
Signed-off-by: David Rientjes <rientjes@google.com>
Percpu allocator honors alignment request upto PAGE_SIZE and both the
percpu addresses in the percpu address space and the translated kernel
addresses should be aligned accordingly. The calculation of the
former depends on the alignment of percpu output section in the kernel
image.
The linker script macros PERCPU_VADDR() and PERCPU() are used to
define this output section and the latter takes @align parameter.
Several architectures are using @align smaller than PAGE_SIZE breaking
percpu memory alignment.
This patch removes @align parameter from PERCPU(), renames it to
PERCPU_SECTION() and makes it always align to PAGE_SIZE. While at it,
add PCPU_SETUP_BUG_ON() checks such that alignment problems are
reliably detected and remove percpu alignment comment recently added
in workqueue.c as the condition would trigger BUG way before reaching
there.
For um, this patch raises the alignment of percpu area. As the area
is in .init, there shouldn't be any noticeable difference.
This problem was discovered by David Howells while debugging boot
failure on mn10300.
Cc: uclinux-dist-devel@blackfin.uclinux.org
Cc: user-mode-linux-devel@lists.sourceforge.net
minix bit operations are only used by minix filesystem and useless by
other modules. Because byte order of inode and block bitmaps is different
on each architecture like below:
m68k:
big-endian 16bit indexed bitmaps
h8300, microblaze, s390, sparc, m68knommu:
big-endian 32 or 64bit indexed bitmaps
m32r, mips, sh, xtensa:
big-endian 32 or 64bit indexed bitmaps for big-endian mode
little-endian bitmaps for little-endian mode
Others:
In order to move minix bit operations from asm/bitops.h to architecture
independent code in minix filesystem, this provides two config options.
CONFIG_MINIX_FS_BIG_ENDIAN_16BIT_INDEXED is only selected by m68k.
CONFIG_MINIX_FS_NATIVE_ENDIAN is selected by the architectures which use
native byte order bitmaps (h8300, microblaze, s390, sparc, m68knommu,
m32r, mips, sh, xtensa). The architectures which always use little-endian
bitmaps do not select these options.
Finally, we can remove minix bit operations from asm/bitops.h for all
architectures.
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: Andreas Schwab <schwab@linux-m68k.org>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Acked-by: Paul Mundt <lethal@linux-sh.org>
Cc: Chris Zankel <chris@zankel.net>
As the result of conversions, there are no users of ext2 non-atomic bit
operations except for ext2 filesystem itself. Now we can put them into
architecture independent code in ext2 filesystem, and remove from
asm/bitops.h for all architectures.
Cc: Jan Kara <jack@suse.cz>
Introduce little-endian bit operations to the big-endian architectures
which do not have native little-endian bit operations and the
little-endian architectures. (alpha, avr32, blackfin, cris, frv, h8300,
ia64, m32r, mips, mn10300, parisc, sh, sparc, tile, x86, xtensa)
These architectures can just include generic implementation
(asm-generic/bitops/le.h).
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Mikael Starvik <starvik@axis.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Matthew Wilcox <willy@debian.org>
Cc: Grant Grundler <grundler@parisc-linux.org>
Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp>
Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Acked-by: "H. Peter Anvin" <hpa@zytor.com>
Add a node parameter to alloc_thread_info(), and change its name to
alloc_thread_info_node()
This change is needed to allow NUMA aware kthread_create_on_cpu()
Reviewed-by: Andi Kleen <ak@linux.intel.com>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
Cc: Tejun Heo <tj@kernel.org>
Cc: <linux-arch@vger.kernel.org>
