path: root/arch/tile
2016-01-05tile: provide CONFIG_PAGE_SIZE_64KB etc for tileproChris Metcalf
This allows the build system to know that it can't attempt to configure the Lustre virtual block device, for example, when tilepro is using 64KB pages (as it does by default). The tilegx build already provided those symbols. Previously we required that the tilepro hypervisor be rebuilt with a different hardcoded page size in its headers, and then Linux be rebuilt using the updated hypervisor header. Now we allow each of the hypervisor and Linux to be built independently. We still check at boot time to ensure that the page size provided by the hypervisor matches what Linux expects. Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com> Cc: stable@vger.kernel.org [3.19+]
2015-11-23treewide: Remove old email addressPeter Zijlstra
There were still a number of references to my old Red Hat email address in the kernel source. Remove these while keeping the Red Hat copyright notices intact. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vince Weaver <vincent.weaver@maine.edu> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-11-09kmap_atomic_to_page() has no users, remove itNicolas Pitre
Removal started in commit 5bbeed12bdc3 ("sparc32: drop unused kmap_atomic_to_page"). Let's do it across the whole tree. Signed-off-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-05mm: mlock: add mlock flags to enable VM_LOCKONFAULT usageEric B Munson
The previous patch introduced a flag that specified pages in a VMA should be placed on the unevictable LRU, but they should not be made present when the area is created. This patch adds the ability to set this state via the new mlock system calls. We add MLOCK_ONFAULT for mlock2 and MCL_ONFAULT for mlockall. MLOCK_ONFAULT will set the VM_LOCKONFAULT modifier for VM_LOCKED. MCL_ONFAULT should be used as a modifier to the two other mlockall flags. When used with MCL_CURRENT, all current mappings will be marked with VM_LOCKED | VM_LOCKONFAULT. When used with MCL_FUTURE, the mm->def_flags will be marked with VM_LOCKED | VM_LOCKONFAULT. When used with both MCL_CURRENT and MCL_FUTURE, all current mappings and mm->def_flags will be marked with VM_LOCKED | VM_LOCKONFAULT. Prior to this patch, mlockall() will unconditionally clear the mm->def_flags any time it is called without MCL_FUTURE. This behavior is maintained after adding MCL_ONFAULT. If a call to mlockall(MCL_FUTURE) is followed by mlockall(MCL_CURRENT), the mm->def_flags will be cleared and new VMAs will be unlocked. This remains true with or without MCL_ONFAULT in either mlockall() invocation. munlock() will unconditionally clear both vma flags. munlockall() unconditionally clears for VMA flags on all VMAs and in the mm->def_flags field. Signed-off-by: Eric B Munson <emunson@akamai.com> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Guenter Roeck <linux@roeck-us.net> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Shuah Khan <shuahkh@osg.samsung.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-10-20Merge tag 'v4.3-rc6' into locking/core, to pick up fixes before applying new ↵Ingo Molnar
changes Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-10-06word-at-a-time.h: support zero_bytemask() on alpha and tileChris Metcalf
Both alpha and tile needed implementations of zero_bytemask. The alpha version is untested. Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com>
2015-10-06word-at-a-time.h: fix some Kbuild filesChris Metcalf
arch/tile added word-at-a-time.h after the patch that added generic-y entries; the generic-y entry is now stale. arch/h8300 is newer than the generic-y patch for word-at-a-time.h, and needs a generic-y entry. arch/powerpc seems to have gotten a generic-y entry by mistake in the first patch; this change removes it. Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com>
2015-10-06Merge tag 'v4.3-rc4' into locking/core, to pick up fixes before applying new ↵Ingo Molnar
2015-10-04Merge branch 'strscpy' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile Pull strscpy string copy function implementation from Chris Metcalf. Chris sent this during the merge window, but I waffled back and forth on the pull request, which is why it's going in only now. The new "strscpy()" function is definitely easier to use and more secure than either strncpy() or strlcpy(), both of which are horrible nasty interfaces that have serious and irredeemable problems. strncpy() has a useless return value, and doesn't NUL-terminate an overlong result. To make matters worse, it pads a short result with zeroes, which is a performance disaster if you have big buffers. strlcpy(), by contrast, is a mis-designed "fix" for strlcpy(), lacking the insane NUL padding, but having a differently broken return value which returns the original length of the source string. Which means that it will read characters past the count from the source buffer, and you have to trust the source to be properly terminated. It also makes error handling fragile, since the test for overflow is unnecessarily subtle. strscpy() avoids both these problems, guaranteeing the NUL termination (but not excessive padding) if the destination size wasn't zero, and making the overflow condition very obvious by returning -E2BIG. It also doesn't read past the size of the source, and can thus be used for untrusted source data too. So why did I waffle about this for so long? Every time we introduce a new-and-improved interface, people start doing these interminable series of trivial conversion patches. And every time that happens, somebody does some silly mistake, and the conversion patch to the improved interface actually makes things worse. Because the patch is mindnumbing and trivial, nobody has the attention span to look at it carefully, and it's usually done over large swatches of source code which means that not every conversion gets tested. So I'm pulling the strscpy() support because it *is* a better interface. But I will refuse to pull mindless conversion patches. Use this in places where it makes sense, but don't do trivial patches to fix things that aren't actually known to be broken. * 'strscpy' of git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: tile: use global strscpy() rather than private copy string: provide strscpy() Make asm/word-at-a-time.h available on all architectures
2015-09-28Merge branch 'stable' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile Pull arch/tile bugfix from Chris Metcalf: "This fixes a bug in 'make allmodconfig'" * 'stable' of git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: tile: fix build failure
2015-09-28tile: fix build failureSudip Mukherjee
When building with allmodconfig the build was failing with the error: arch/tile/kernel/usb.c:70:1: warning: data definition has no type or storage class [enabled by default] arch/tile/kernel/usb.c:70:1: error: type defaults to 'int' in declaration of 'arch_initcall' [-Werror=implicit-int] arch/tile/kernel/usb.c:70:1: warning: parameter names (without types) in function declaration [enabled by default] arch/tile/kernel/usb.c:63:19: warning: 'tilegx_usb_init' defined but not used [-Wunused-function] Include linux/module.h to resolve the build failure. Signed-off-by: Sudip Mukherjee <sudip@vectorindia.org> Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com>
2015-09-23atomic, arch: Audit atomic_{read,set}()Peter Zijlstra
This patch makes sure that atomic_{read,set}() are at least {READ,WRITE}_ONCE(). We already had the 'requirement' that atomic_read() should use ACCESS_ONCE(), and most archs had this, but a few were lacking. All are now converted to use READ_ONCE(). And, by a symmetry and general paranoia argument, upgrade atomic_set() to use WRITE_ONCE(). Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: james.hogan@imgtec.com Cc: linux-kernel@vger.kernel.org Cc: oleg@redhat.com Cc: will.deacon@arm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-09-16genirq: Remove irq argument from irq flow handlersThomas Gleixner
Most interrupt flow handlers do not use the irq argument. Those few which use it can retrieve the irq number from the irq descriptor. Remove the argument. Search and replace was done with coccinelle and some extra helper scripts around it. Thanks to Julia for her help! Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Cc: Jiang Liu <jiang.liu@linux.intel.com>
2015-09-10dma-mapping: consolidate dma_set_maskChristoph Hellwig
Almost everyone implements dma_set_mask the same way, although some time that's hidden in ->set_dma_mask methods. This patch consolidates those into a common implementation that either calls ->set_dma_mask if present or otherwise uses the default implementation. Some architectures used to only call ->set_dma_mask after the initial checks, and those instance have been fixed to do the full work. h8300 implemented dma_set_mask bogusly as a no-ops and has been fixed. Unfortunately some architectures overload unrelated semantics like changing the dma_ops into it so we still need to allow for an architecture override for now. [jcmvbkbc@gmail.com: fix xtensa] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Michal Simek <monstr@monstr.eu> Cc: Jonas Bonn <jonas@southpole.se> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10dma-mapping: consolidate dma_supportedChristoph Hellwig
Most architectures just call into ->dma_supported, but some also return 1 if the method is not present, or 0 if no dma ops are present (although that should never happeb). Consolidate this more broad version into common code. Also fix h8300 which inorrectly always returned 0, which would have been a problem if it's dma_set_mask implementation wasn't a similarly buggy noop. As a few architectures have much more elaborate implementations, we still allow for arch overrides. [jcmvbkbc@gmail.com: fix xtensa] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Michal Simek <monstr@monstr.eu> Cc: Jonas Bonn <jonas@southpole.se> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10dma-mapping: cosolidate dma_mapping_errorChristoph Hellwig
Currently there are three valid implementations of dma_mapping_error: (1) call ->mapping_error (2) check for a hardcoded error code (3) always return 0 This patch provides a common implementation that calls ->mapping_error if present, then checks for DMA_ERROR_CODE if defined or otherwise returns 0. [jcmvbkbc@gmail.com: fix xtensa] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Michal Simek <monstr@monstr.eu> Cc: Jonas Bonn <jonas@southpole.se> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10dma-mapping: consolidate dma_{alloc,free}_noncoherentChristoph Hellwig
Most architectures do not support non-coherent allocations and either define dma_{alloc,free}_noncoherent to their coherent versions or stub them out. Openrisc uses dma_{alloc,free}_attrs to implement them, and only Mips implements them directly. This patch moves the Openrisc version to common code, and handles the DMA_ATTR_NON_CONSISTENT case in the mips dma_map_ops instance. Note that actual non-coherent allocations require a dma_cache_sync implementation, so if non-coherent allocations didn't work on an architecture before this patch they still won't work after it. [jcmvbkbc@gmail.com: fix xtensa] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Michal Simek <monstr@monstr.eu> Cc: Jonas Bonn <jonas@southpole.se> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10dma-mapping: consolidate dma_{alloc,free}_{attrs,coherent}Christoph Hellwig
Since 2009 we have a nice asm-generic header implementing lots of DMA API functions for architectures using struct dma_map_ops, but unfortunately it's still missing a lot of APIs that all architectures still have to duplicate. This series consolidates the remaining functions, although we still need arch opt outs for two of them as a few architectures have very non-standard implementations. This patch (of 5): The coherent DMA allocator works the same over all architectures supporting dma_map operations. This patch consolidates them and converges the minor differences: - the debug_dma helpers are now called from all architectures, including those that were previously missing them - dma_alloc_from_coherent and dma_release_from_coherent are now always called from the generic alloc/free routines instead of the ops dma-mapping-common.h always includes dma-coherent.h to get the defintions for them, or the stubs if the architecture doesn't support this feature - checks for ->alloc / ->free presence are removed. There is only one magic instead of dma_map_ops without them (mic_dma_ops) and that one is x86 only anyway. Besides that only x86 needs special treatment to replace a default devices if none is passed and tweak the gfp_flags. An optional arch hook is provided for that. [linux@roeck-us.net: fix build] [jcmvbkbc@gmail.com: fix xtensa] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Michal Simek <monstr@monstr.eu> Cc: Jonas Bonn <jonas@southpole.se> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10kexec: split kexec_load syscall from kexec core codeDave Young
There are two kexec load syscalls, kexec_load another and kexec_file_load. kexec_file_load has been splited as kernel/kexec_file.c. In this patch I split kexec_load syscall code to kernel/kexec.c. And add a new kconfig option KEXEC_CORE, so we can disable kexec_load and use kexec_file_load only, or vice verse. The original requirement is from Ted Ts'o, he want kexec kernel signature being checked with CONFIG_KEXEC_VERIFY_SIG enabled. But kexec-tools use kexec_load syscall can bypass the checking. Vivek Goyal proposed to create a common kconfig option so user can compile in only one syscall for loading kexec kernel. KEXEC/KEXEC_FILE selects KEXEC_CORE so that old config files still work. Because there's general code need CONFIG_KEXEC_CORE, so I updated all the architecture Kconfig with a new option KEXEC_CORE, and let KEXEC selects KEXEC_CORE in arch Kconfig. Also updated general kernel code with to kexec_load syscall. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Dave Young <dyoung@redhat.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Petr Tesarik <ptesarik@suse.cz> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Josh Boyer <jwboyer@fedoraproject.org> Cc: David Howells <dhowells@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10tile: use global strscpy() rather than private copyChris Metcalf
Now that strscpy() is a standard API, remove the local copy. Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com>
2015-09-08Merge tag 'libnvdimm-for-4.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm Pull libnvdimm updates from Dan Williams: "This update has successfully completed a 0day-kbuild run and has appeared in a linux-next release. The changes outside of the typical drivers/nvdimm/ and drivers/acpi/nfit.[ch] paths are related to the removal of IORESOURCE_CACHEABLE, the introduction of memremap(), and the introduction of ZONE_DEVICE + devm_memremap_pages(). Summary: - Introduce ZONE_DEVICE and devm_memremap_pages() as a generic mechanism for adding device-driver-discovered memory regions to the kernel's direct map. This facility is used by the pmem driver to enable pfn_to_page() operations on the page frames returned by DAX ('direct_access' in 'struct block_device_operations'). For now, the 'memmap' allocation for these "device" pages comes from "System RAM". Support for allocating the memmap from device memory will arrive in a later kernel. - Introduce memremap() to replace usages of ioremap_cache() and ioremap_wt(). memremap() drops the __iomem annotation for these mappings to memory that do not have i/o side effects. The replacement of ioremap_cache() with memremap() is limited to the pmem driver to ease merging the api change in v4.3. Completion of the conversion is targeted for v4.4. - Similar to the usage of memcpy_to_pmem() + wmb_pmem() in the pmem driver, update the VFS DAX implementation and PMEM api to provide persistence guarantees for kernel operations on a DAX mapping. - Convert the ACPI NFIT 'BLK' driver to map the block apertures as cacheable to improve performance. - Miscellaneous updates and fixes to libnvdimm including support for issuing "address range scrub" commands, clarifying the optimal 'sector size' of pmem devices, a clarification of the usage of the ACPI '_STA' (status) property for DIMM devices, and other minor fixes" * tag 'libnvdimm-for-4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm: (34 commits) libnvdimm, pmem: direct map legacy pmem by default libnvdimm, pmem: 'struct page' for pmem libnvdimm, pfn: 'struct page' provider infrastructure x86, pmem: clarify that ARCH_HAS_PMEM_API implies PMEM mapped WB add devm_memremap_pages mm: ZONE_DEVICE for "device memory" mm: move __phys_to_pfn and __pfn_to_phys to asm/generic/memory_model.h dax: drop size parameter to ->direct_access() nd_blk: change aperture mapping from WC to WB nvdimm: change to use generic kvfree() pmem, dax: have direct_access use __pmem annotation dax: update I/O path to do proper PMEM flushing pmem: add copy_from_iter_pmem() and clear_pmem() pmem, x86: clean up conditional pmem includes pmem: remove layer when calling arch_has_wmb_pmem() pmem, x86: move x86 PMEM API to new pmem.h header libnvdimm, e820: make CONFIG_X86_PMEM_LEGACY a tristate option pmem: switch to devm_ allocations devres: add devm_memremap libnvdimm, btt: write and validate parent_uuid ...
2015-09-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
Pull tile updates from Chris Metcalf: "This includes secure computing support as well as miscellaneous minor improvements" * git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: tile: correct some typos in opcode type names tile/vdso: emit a GNU hash as well tile: Remove finish_arch_switch tile: enable full SECCOMP support tile/time: Migrate to new 'set-state' interface
2015-09-03Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking and atomic updates from Ingo Molnar: "Main changes in this cycle are: - Extend atomic primitives with coherent logic op primitives (atomic_{or,and,xor}()) and deprecate the old partial APIs (atomic_{set,clear}_mask()) The old ops were incoherent with incompatible signatures across architectures and with incomplete support. Now every architecture supports the primitives consistently (by Peter Zijlstra) - Generic support for 'relaxed atomics': - _acquire/release/relaxed() flavours of xchg(), cmpxchg() and {add,sub}_return() - atomic_read_acquire() - atomic_set_release() This came out of porting qwrlock code to arm64 (by Will Deacon) - Clean up the fragile static_key APIs that were causing repeat bugs, by introducing a new one: DEFINE_STATIC_KEY_TRUE(name); DEFINE_STATIC_KEY_FALSE(name); which define a key of different types with an initial true/false value. Then allow: static_branch_likely() static_branch_unlikely() to take a key of either type and emit the right instruction for the case. To be able to know the 'type' of the static key we encode it in the jump entry (by Peter Zijlstra) - Static key self-tests (by Jason Baron) - qrwlock optimizations (by Waiman Long) - small futex enhancements (by Davidlohr Bueso) - ... and misc other changes" * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (63 commits) jump_label/x86: Work around asm build bug on older/backported GCCs locking, ARM, atomics: Define our SMP atomics in terms of _relaxed() operations locking, include/llist: Use linux/atomic.h instead of asm/cmpxchg.h locking/qrwlock: Make use of _{acquire|release|relaxed}() atomics locking/qrwlock: Implement queue_write_unlock() using smp_store_release() locking/lockref: Remove homebrew cmpxchg64_relaxed() macro definition locking, asm-generic: Add _{relaxed|acquire|release}() variants for 'atomic_long_t' locking, asm-generic: Rework atomic-long.h to avoid bulk code duplication locking/atomics: Add _{acquire|release|relaxed}() variants of some atomic operations locking, compiler.h: Cast away attributes in the WRITE_ONCE() magic locking/static_keys: Make verify_keys() static jump label, locking/static_keys: Update docs locking/static_keys: Provide a selftest jump_label: Provide a self-test s390/uaccess, locking/static_keys: employ static_branch_likely() x86, tsc, locking/static_keys: Employ static_branch_likely() locking/static_keys: Add selftest locking/static_keys: Add a new static_key interface locking/static_keys: Rework update logic locking/static_keys: Add static_key_{en,dis}able() helpers ...
2015-09-01Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq updates from Thomas Gleixner: "This updated pull request does not contain the last few GIC related patches which were reported to cause a regression. There is a fix available, but I let it breed for a couple of days first. The irq departement provides: - new infrastructure to support non PCI based MSI interrupts - a couple of new irq chip drivers - the usual pile of fixlets and updates to irq chip drivers - preparatory changes for removal of the irq argument from interrupt flow handlers - preparatory changes to remove IRQF_VALID" * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (129 commits) irqchip/imx-gpcv2: IMX GPCv2 driver for wakeup sources irqchip: Add bcm2836 interrupt controller for Raspberry Pi 2 irqchip: Add documentation for the bcm2836 interrupt controller irqchip/bcm2835: Add support for being used as a second level controller irqchip/bcm2835: Refactor handle_IRQ() calls out of MAKE_HWIRQ PCI: xilinx: Fix typo in function name irqchip/gic: Ensure gic_cpu_if_up/down() programs correct GIC instance irqchip/gic: Only allow the primary GIC to set the CPU map PCI/MSI: pci-xgene-msi: Consolidate chained IRQ handler install/remove unicore32/irq: Prepare puv3_gpio_handler for irq argument removal tile/pci_gx: Prepare trio_handle_level_irq for irq argument removal m68k/irq: Prepare irq handlers for irq argument removal C6X/megamode-pic: Prepare megamod_irq_cascade for irq argument removal blackfin: Prepare irq handlers for irq argument removal arc/irq: Prepare idu_cascade_isr for irq argument removal sparc/irq: Use access helper irq_data_get_affinity_mask() sparc/irq: Use helper irq_data_get_irq_handler_data() parisc/irq: Use access helper irq_data_get_affinity_mask() mn10300/irq: Use access helper irq_data_get_affinity_mask() irqchip/i8259: Prepare i8259_irq_dispatch for irq argument removal ...
2015-09-01Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 mm updates from Ingo Molnar: "The dominant change in this cycle was the continued work to isolate kernel drivers from MTRR legacies: this tree gets rid of all kernel internal driver interfaces to MTRRs (mostly by rewriting it to proper PAT interfaces), the only access left is the /proc/mtrr ABI. This work was done by Luis R Rodriguez. There's also some related PCI interface additions for which I've Cc:-ed Bjorn" * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (21 commits) x86/mm/mtrr: Remove kernel internal MTRR interfaces: unexport mtrr_add() and mtrr_del() s390/io: Add pci_iomap_wc() and pci_iomap_wc_range() drivers/dma/iop-adma: Use dma_alloc_writecombine() kernel-style drivers/video/fbdev/vt8623fb: Use arch_phys_wc_add() and pci_iomap_wc() drivers/video/fbdev/s3fb: Use arch_phys_wc_add() and pci_iomap_wc() drivers/video/fbdev/arkfb.c: Use arch_phys_wc_add() and pci_iomap_wc() PCI: Add pci_iomap_wc() variants drivers/video/fbdev/gxt4500: Use pci_ioremap_wc_bar() to map framebuffer drivers/video/fbdev/kyrofb: Use arch_phys_wc_add() and pci_ioremap_wc_bar() drivers/video/fbdev/i740fb: Use arch_phys_wc_add() and pci_ioremap_wc_bar() PCI: Add pci_ioremap_wc_bar() x86/mm: Make kernel/check.c explicitly non-modular x86/mm/pat: Make mm/pageattr[-test].c explicitly non-modular x86/mm/pat: Add comments to cachemode translation tables arch/*/io.h: Add ioremap_uc() to all architectures drivers/video/fbdev/atyfb: Use arch_phys_wc_add() and ioremap_wc() drivers/video/fbdev/atyfb: Replace MTRR UC hole with strong UC drivers/video/fbdev/atyfb: Clarify ioremap() base and length used drivers/video/fbdev/atyfb: Carve out framebuffer length fudging into a helper x86/mm, asm-generic: Add IOMMU ioremap_uc() variant default ...
2015-08-31Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler updates from Ingo Molnar: "The biggest change in this cycle is the rewrite of the main SMP load balancing metric: the CPU load/utilization. The main goal was to make the metric more precise and more representative - see the changelog of this commit for the gory details: 9d89c257dfb9 ("sched/fair: Rewrite runnable load and utilization average tracking") It is done in a way that significantly reduces complexity of the code: 5 files changed, 249 insertions(+), 494 deletions(-) and the performance testing results are encouraging. Nevertheless we need to keep an eye on potential regressions, since this potentially affects every SMP workload in existence. This work comes from Yuyang Du. Other changes: - SCHED_DL updates. (Andrea Parri) - Simplify architecture callbacks by removing finish_arch_switch(). (Peter Zijlstra et al) - cputime accounting: guarantee stime + utime == rtime. (Peter Zijlstra) - optimize idle CPU wakeups some more - inspired by Facebook server loads. (Mike Galbraith) - stop_machine fixes and updates. (Oleg Nesterov) - Introduce the 'trace_sched_waking' tracepoint. (Peter Zijlstra) - sched/numa tweaks. (Srikar Dronamraju) - misc fixes and small cleanups" * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (44 commits) sched/deadline: Fix comment in enqueue_task_dl() sched/deadline: Fix comment in push_dl_tasks() sched: Change the sched_class::set_cpus_allowed() calling context sched: Make sched_class::set_cpus_allowed() unconditional sched: Fix a race between __kthread_bind() and sched_setaffinity() sched: Ensure a task has a non-normalized vruntime when returning back to CFS sched/numa: Fix NUMA_DIRECT topology identification tile: Reorganize _switch_to() sched, sparc32: Update scheduler comments in copy_thread() sched: Remove finish_arch_switch() sched, tile: Remove finish_arch_switch sched, sh: Fold finish_arch_switch() into switch_to() sched, score: Remove finish_arch_switch() sched, avr32: Remove finish_arch_switch() sched, MIPS: Get rid of finish_arch_switch() sched, arm: Remove finish_arch_switch() sched/fair: Clean up load average references sched/fair: Provide runnable_load_avg back to cfs_rq sched/fair: Remove task and group entity load when they are dead sched/fair: Init cfs_rq's sched_entity load average ...
2015-08-31Merge tag 'driver-core-4.3-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg KH: "Here is the new patches for the driver core / sysfs for 4.3-rc1. Very small number of changes here, all the details are in the shortlog, nothing major happening at all this kernel release, which is nice to see" * tag 'driver-core-4.3-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: bus: subsys: update return type of ->remove_dev() to void driver core: correct device's shutdown order driver core: fix docbook for device_private.device selftests: firmware: skip timeout checks for kernels without user mode helper kernel, cpu: Remove bogus __ref annotations cpu: Remove bogus __ref annotation of cpu_subsys_online() firmware: fix wrong memory deallocation in fw_add_devm_name() sysfs.txt: update show method notes about sprintf/snprintf/scnprintf usage devres: fix devres_get()
2015-08-27mm: ZONE_DEVICE for "device memory"Dan Williams
While pmem is usable as a block device or via DAX mappings to userspace there are several usage scenarios that can not target pmem due to its lack of struct page coverage. In preparation for "hot plugging" pmem into the vmemmap add ZONE_DEVICE as a new zone to tag these pages separately from the ones that are subject to standard page allocations. Importantly "device memory" can be removed at will by userspace unbinding the driver of the device. Having a separate zone prevents allocation and otherwise marks these pages that are distinct from typical uniform memory. Device memory has different lifetime and performance characteristics than RAM. However, since we have run out of ZONES_SHIFT bits this functionality currently depends on sacrificing ZONE_DMA. Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Jerome Glisse <j.glisse@gmail.com> [hch: various simplifications in the arch interface] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2015-08-27tile: correct some typos in opcode type namesChris Metcalf
These particular opcode names are not used in the kernel directly, so updating them just has the effect of making downstream consumers more likely to end up using better names; this was reported from the qemu community. Reported-by: Richard Henderson <rth@twiddle.net> Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com>
2015-08-25Merge tag 'v4.2-rc8' into x86/mm, before applying new changesIngo Molnar
2015-08-08tile: Reorganize _switch_to()Chris Metcalf
Move the simulator bits into finish_arch_post_lock_switch() and properly call __switch_to() from _switch_to(). Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com> Cc: <efault@gmx.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1438783412-10990-1-git-send-email-cmetcalf@ezchip.com [ Made it a delta to: fe363adb9225 ("sched, tile: Remove finish_arch_switch"). ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-08-07signal: fix information leak in copy_siginfo_from_user32Amanieu d'Antras
This function can leak kernel stack data when the user siginfo_t has a positive si_code value. The top 16 bits of si_code descibe which fields in the siginfo_t union are active, but they are treated inconsistently between copy_siginfo_from_user32, copy_siginfo_to_user32 and copy_siginfo_to_user. copy_siginfo_from_user32 is called from rt_sigqueueinfo and rt_tgsigqueueinfo in which the user has full control overthe top 16 bits of si_code. This fixes the following information leaks: x86: 8 bytes leaked when sending a signal from a 32-bit process to itself. This leak grows to 16 bytes if the process uses x32. (si_code = __SI_CHLD) x86: 100 bytes leaked when sending a signal from a 32-bit process to a 64-bit process. (si_code = -1) sparc: 4 bytes leaked when sending a signal from a 32-bit process to a 64-bit process. (si_code = any) parsic and s390 have similar bugs, but they are not vulnerable because rt_[tg]sigqueueinfo have checks that prevent sending a positive si_code to a different process. These bugs are also fixed for consistency. Signed-off-by: Amanieu d'Antras <amanieu@gmail.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-08-06tile/vdso: emit a GNU hash as wellChris Metcalf
In principle, including the GNU hash can allow libc to avoid calculating SysV hashes at all. Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com>
2015-08-05bus: subsys: update return type of ->remove_dev() to voidViresh Kumar
Its return value is not used by the subsys core and nothing meaningful can be done with it, even if we want to use it. The subsys device is anyway getting removed. Update prototype of ->remove_dev() to make its return type as void. Fix all usage sites as well. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-08-04sched, tile: Remove finish_arch_switchChris Metcalf
Move the simulator bits into switch_to() and use finish_arch_post_lock_switch() for the homecache migration bits. Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-08-03tile: Remove finish_arch_switchChris Metcalf
Move the simulator bits into switch_to() and use finish_arch_post_lock_switch() for the homecache migration bits. Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com>
2015-08-01tile/pci_gx: Prepare trio_handle_level_irq for irq argument removalThomas Gleixner
The irq argument of most interrupt flow handlers is unused or merily used instead of a local variable. The handlers which need the irq argument can retrieve the irq number from the irq descriptor. Search and update was done with coccinelle and the invaluable help of Julia Lawall. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Cc: Chris Metcalf <cmetcalf@ezchip.com>
2015-07-30tile: enable full SECCOMP supportChris Metcalf
2015-07-30tile/time: Migrate to new 'set-state' interfaceViresh Kumar
Migrate tile driver to the new 'set-state' interface provided by clockevents core, the earlier 'set-mode' interface is marked obsolete now. This also enables us to implement callbacks for new states of clockevent devices, for example: ONESHOT_STOPPED. Cc: Chris Metcalf <cmetcalf@ezchip.com> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com>
2015-07-30Merge branch 'linus' into irq/coreThomas Gleixner
Pull in upstream fixes before applying conflicting changes
2015-07-29arch/*/io.h: Add ioremap_uc() to all architecturesLuis R. Rodriguez
This adds ioremap_uc() only for architectures that do not include asm-generic.h/io.h as that already provides a default definition for them for both cases where you have CONFIG_MMU and you do not, and because of this, the number of architectures this patch address is less than the architectures that the ioremap_wt() patch addressed, "arch/*/io.h: Add ioremap_wt() to all architectures"). In order to reduce the number of architectures we have to modify by adding new architecture IO APIs we'll have to review the architectures in this patch, see why they can't add asm-generic.h/io.h or issues that would be created by doing so and then spread a consistent inclusion of this header towards the end of their own header. For instance arch/metag includes the asm-generic/io.h *before* the ioremap*() definitions, this should be the other way around but only once we have guard wrappers for the non-MMU case also for asm-generic/io.h. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com> Cc: Abhilash Kesavan <a.kesavan@samsung.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Borislav Petkov <bp@suse.de> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: David Howells <dhowells@redhat.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Guenter Roeck <linux@roeck-us.net> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Kyle McMartin <kyle@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Hurley <peter@hurleysoftware.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rob Herring <robh@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Toshi Kani <toshi.kani@hp.com> Cc: Will Deacon <will.deacon@arm.com> Cc: linux-am33-list@redhat.com Cc: linux-arch@vger.kernel.org Cc: linux-m68k@lists.linux-m68k.org Cc: linux-sh@vger.kernel.org Cc: linuxppc-dev@lists.ozlabs.org Link: http://lkml.kernel.org/r/20150728181713.GB30479@wotan.suse.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-07-27atomic: Provide atomic_{or,xor,and}Peter Zijlstra
Implement atomic logic ops -- atomic_{or,xor,and}. These will replace the atomic_{set,clear}_mask functions that are available on some archs. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-07-27tile: Provide atomic_{or,xor,and}Chris Metcalf
Implement atomic logic ops -- atomic_{or,xor,and}. For tilegx, these are relatively straightforward; the architecture provides atomic "or" and "and", both 32-bit and 64-bit. To support xor we provide a loop using "cmpexch". For the older 32-bit tilepro architecture, we have to extend the set of low-level assembly routines to include 32-bit "and", as well as all three 64-bit routines. Somewhat confusingly, some 32-bit versions are already used by the bitops inlines, with parameter types appropriate for bitops, so we have to do a bit of casting to match "int" to "unsigned long". Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Link: http://lkml.kernel.org/r/1436474297-32187-1-git-send-email-cmetcalf@ezchip.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-07-23tile: use free_bootmem_late() for initrdChris Metcalf
We were previously using free_bootmem() and just getting lucky that nothing too bad happened. Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com> Cc: stable@vger.kernel.org
2015-07-17mm: clean up per architecture MM hook header filesLaurent Dufour
Commit 2ae416b142b6 ("mm: new mm hook framework") introduced an empty header file (mm-arch-hooks.h) for every architecture, even those which doesn't need to define mm hooks. As suggested by Geert Uytterhoeven, this could be cleaned through the use of a generic header file included via each per architecture asm/include/Kbuild file. The PowerPC architecture is not impacted here since this architecture has to defined the arch_remap MM hook. Signed-off-by: Laurent Dufour <ldufour@linux.vnet.ibm.com> Suggested-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Vineet Gupta <vgupta@synopsys.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-16treewide: Use helper function to access irq_data->msi_descJiang Liu
Use irq_data access helper to access irq_data->msi_desc, so we can move msi_desc from struct irq_data into struct irq_common_data later. Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Chris Metcalf <cmetcalf@ezchip.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-07-08modpost: work correctly with tile coldtext sectionsChris Metcalf
The tilegx and tilepro compilers use .coldtext for their unlikely executed text section name, so an __attribute__((cold)) function will (when compiled with higher optimization levels) land in the .coldtext section. Modify modpost to add .coldtext to the set of OTHER_TEXT_SECTIONS so we don't get warnings about referencing such a section in an __ex_table block, and then also modify arch/tile/lib/memcpy_user_64.c so that it uses plain ".coldtext" instead of ".coldtext.memcpy". The latter naming is a relic of an earlier use of -ffunction-sections, which we no longer use by default. Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au>
2015-07-08Make asm/word-at-a-time.h available on all architecturesChris Metcalf
Added the x86 implementation of word-at-a-time to the generic version, which previously only supported big-endian. Omitted the x86-specific load_unaligned_zeropad(), which in any case is also not present for the existing BE-only implementation of a word-at-a-time, and is only used under CONFIG_DCACHE_WORD_ACCESS. Added as a "generic-y" to the Kbuilds of all architectures that didn't previously have it. Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com>
2015-07-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs updates from Al Viro: "Assorted VFS fixes and related cleanups (IMO the most interesting in that part are f_path-related things and Eric's descriptor-related stuff). UFS regression fixes (it got broken last cycle). 9P fixes. fs-cache series, DAX patches, Jan's file_remove_suid() work" [ I'd say this is much more than "fixes and related cleanups". The file_table locking rule change by Eric Dumazet is a rather big and fundamental update even if the patch isn't huge. - Linus ] * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (49 commits) 9p: cope with bogus responses from server in p9_client_{read,write} p9_client_write(): avoid double p9_free_req() 9p: forgetting to cancel request on interrupted zero-copy RPC dax: bdev_direct_access() may sleep block: Add support for DAX reads/writes to block devices dax: Use copy_from_iter_nocache dax: Add block size note to documentation fs/file.c: __fget() and dup2() atomicity rules fs/file.c: don't acquire files->file_lock in fd_install() fs:super:get_anon_bdev: fix race condition could cause dev exceed its upper limitation vfs: avoid creation of inode number 0 in get_next_ino namei: make set_root_rcu() return void make simple_positive() public ufs: use dir_pages instead of ufs_dir_pages() pagemap.h: move dir_pages() over there remove the pointless include of lglock.h fs: cleanup slight list_entry abuse xfs: Correctly lock inode when removing suid and file capabilities fs: Call security_ops->inode_killpriv on truncate fs: Provide function telling whether file_remove_privs() will do anything ...
2015-07-02Merge tag 'module-misc-v4.1-rc8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull init.h/module.h fragility fixes from Paul Gortmaker: "Fixup various init.h misuses that are fragile wrt code moving to module.h What started as a removal of no longer required include <linux/init.h> due to the earlier __cpuinit and __devinit removal led to the observation that some module specfic support was living in init.h itself, thus preventing the full removal from introducing compile regressions. This series includes a few final fixups needed prior to the relocation of the modular init code from <init.h> to <module.h>. These are things that weren't easily categorized into any of the other previous series categories already requested for pull. That said, each fixup branch (including this one) is independent and there are no ordering constraints. Only the final code relocation (which is NOT in this pull) requires that all my cleanup branches be merged first" * tag 'module-misc-v4.1-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: tile: add init.h to usb.c to avoid compile failure arm: fix implicit #include <linux/init.h> in entry asm. x86: replace __init_or_module with __init in non-modular vsmp_64.c
