path: root/arch/um/Kconfig.i386
2008-04-17Generic semaphore implementationMatthew Wilcox
Semaphores are no longer performance-critical, so a generic C implementation is better for maintainability, debuggability and extensibility. Thanks to Peter Zijlstra for fixing the lockdep warning. Thanks to Harvey Harrison for pointing out that the unlikely() was unnecessary. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2008-02-08uml: runtime host VMSPLIT detectionJeff Dike
Calculate TASK_SIZE at run-time by figuring out the host's VMSPLIT - this is needed on i386 if UML is to run on hosts with varying VMSPLITs without recompilation. TASK_SIZE is now defined in terms of a variable, task_size. This gets rid of an include of pgtable.h from processor.h, which can cause include loops. On i386, task_size is calculated early in boot by probing the address space in a binary search to figure out where the boundary between usable and non-usable memory is. This tries to make sure that a page that is considered to be in userspace is, or can be made, read-write. I'm concerned about a system-global VDSO page in kernel memory being hit and considered to be a userspace page. On x86_64, task_size is just the old value of CONFIG_TOP_ADDR. A bunch of config variable are gone now. CONFIG_TOP_ADDR is directly replaced by TASK_SIZE. NEST_LEVEL is gone since the relocation of the stubs makes it irrelevant. All the HOST_VMSPLIT stuff is gone. All references to these in arch/um/Makefile are also gone. I noticed and fixed a missing extern in os.h when adding os_get_task_size. Note: This has been revised to fix the 32-bit UML on 64-bit host bug that Miklos ran into. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08aout: mark arches that support A.OUT formatDavid Howells
Mark arches that support A.OUT format by including the following in their master Kconfig files: config ARCH_SUPPORTS_AOUT def_bool y This should also be set if the arch provides compatibility A.OUT support for an older arch, for instance x86_64 for i386 or sparc64 for sparc. I've guessed at which arches don't, based on comments in the code, however I'm sure that some of the ones I've marked as 'yes' actually should be 'no'. Signed-off-by: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-03uml: keep UML Kconfig in sync with x86Jeff Dike
Fix a UML build breakage introduced by commit 1032c0ba9da5c5b53173ad2dcf8b2a2da78f8b17 - it introduces X86_32, with many things which UML needs depending on it. This patch adds definitions of X86_32 and RWSEM_XCHGADD_ALGORITHM to the UML/i386 Kconfig. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-29more x86 merge fallout (uml, again)Al Viro
arch/i386/{Kconfig,Makefile}.cpu got moved Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: fix stub address calculationsJeff Dike
The calculation of CONFIG_STUB_CODE and CONFIG_STUB_DATA didn't take into account anything but 3G/1G and 2G/2G, leaving the other vmsplits out in the cold. I'd rather not duplicate the four known host vmsplit cases for each of these symbols. I'd also like to calculate them based on the highest userspace address. The Kconfig language seems not to allow calculation of hex constants, so I moved this to as-layout.h. CONFIG_STUB_CODE, CONFIG_STUB_DATA, and CONFIG_STUB_START are now gone. In their place are STUB_CODE, STUB_DATA, and STUB_START in as-layout.h. i386 and x86_64 seem to differ as to whether an unadorned constant is an int or a long, so I cast them to unsigned long so they can be printed consistently. However, they are also used in stub.S, where C types don't work so well. So, there are ASM_ versions of these constants for use in stub.S. I also ifdef-ed the non-asm-friendly portion of as-layout.h. With this in place, most of the rest of this patch is changing CONFIG_STUB_* to STUB_*, except in stub.S, where they are changed to ASM_STUB_*. defconfig has the old symbols deleted. I also print these addresses out in case there is any problem mapping them on the host. The two stub.S files had some trailing whitespace, so that is cleaned up here. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-30[PATCH] fix indentation-related breakage in Kconfig.i386Al Viro
Kconfig recognizes the end of help text by receding indentation depth. Recent patch had broken HOST_VMSPLIT_... choice in arch/um/Kconfig.i386 - all alternatives are interpreted as part of help text now. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-26[PATCH] Fix UML on non-standard VM split hostsJeff Dike
This fixes UML on hosts with non-standard VM splits. We had changed the config variable that controls UML behavior on such hosts, but not propogated the change everywhere. In particular, the values of STUB_CODE and STUB_DATA relied on the old variable. I also reformatted the HOST_VMSPLIT_3G help to make it more standard. Spotted by uml@flonatel.org. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Blaisorblade <blaisorblade@yahoo.it> Cc: Pravin <shindepravin@gmail.com> Cc: <uml@flonatel.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-11[PATCH] uml: allow finer tuning for host VMSPLIT settingPaolo 'Blaisorblade' Giarrusso
Now that various memory splits are enabled, add a config option allowing the user to compile UML for its need - HOST_2G_2G allowed to choose either 3G/1G or 2G/2G, and enabling it reduced the usable virtual memory. Detecting this at run time should be implemented in the future, but we must make the stop-gap measure work well enough (this is valid in _many_ cases). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-01[PATCH] uml: skas0 support for 2G/2G hostsJoris van Rantwijk
A quick hack to allow skas0 mode to run on 2G/2G hosts. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] um: fix undefined reference to hweight32Akinobu Mita
Build fix for user mode linux. Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] uml: arch Kconfig menu cleanupsPaolo 'Blaisorblade' Giarrusso
*) mark as "EXPERIMENTAL" various items that either aren't very stable or that are actively crashing the setup of users which don't really need them (i.e. HIGHMEM and 3-level pagetables on x86 - nobody needs either, everybody reports "I'm using it and getting trouble"). *) move net/Kconfig near to the rest of network configurations, and drivers/block/Kconfig near "Block layer" submenu. *) it's useless and doesn't work well to force NETDEVICES on and to disable the prompt like it's done. Better remove the attempt, and change that to a simple "default y if UML". *) drop the warning about "report problems about HPPFS" - it's redundant anyway, as that's the usual procedure, and HPPFS users are especially technical (i.e. they know reporting bugs is _good_). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] uml: fixups for "reuse i386 cpu-specific tuning"Paolo 'Blaisorblade' Giarrusso
A few fixups - show the new submenu only for x86 subarchitecture (it does not make sense to show it for x86_64 users) and remove X86_CMPXCHG, which is now a duplicate of Kconfig.i386, even though Kconfig doesn't complain (we also miss the dependency on !M386 CPU). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-17[PATCH] uml: UML/i386 cmpxchg fixJeff Dike
Using native cmpxchg offers a slight performance improvement in uml/i386. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] uml: Rename Kconfig files to be like the other archesJeff Dike
To the extent that sub-Kconfig files exist elsewhere in the tree, they are named Kconfig.foo, rather than the Kconfig_foo that UML has. This patch brings the names in line with the rest of the tree. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
