path: root/arch/um/Kconfig.x86_64
2008-04-26x86, bitops: select the generic bitmap search functionsAlexander van Heukelum
Introduce GENERIC_FIND_FIRST_BIT and GENERIC_FIND_NEXT_BIT in lib/Kconfig, defaulting to off. An arch that wants to use the generic implementation now only has to use a select statement to include them. I added an always-y option (X86_CPU) to arch/x86/Kconfig.cpu and used that to select the generic search functions. This way ARCH=um SUBARCH=i386 automatically picks up the change too, and arch/um/Kconfig.i386 can therefore be simplified a bit. ARCH=um SUBARCH=x86_64 does things differently, but still compiles fine. It seems that a "def_bool y" always wins over a "def_bool n"? Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-26x86, UML: remove x86-specific implementations of find_first_bitAlexander van Heukelum
x86 has been switched to the generic versions of find_first_bit and find_first_zero_bit, but the original versions were retained. This patch just removes the now unused x86-specific versions. also update UML. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-26x86, uml: fix uml with generic find_next_bit for x86Alexander van Heukelum
Update UML to use the generic bits too. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-26uml: Kconfig cleanupIngo Molnar
pointed out by Linus: arch/um/Kconfig.x86_64 should include arch/x86/Kconfig.cpu instead of defining those symbols itself. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17Generic semaphore implementationMatthew Wilcox
Semaphores are no longer performance-critical, so a generic C implementation is better for maintainability, debuggability and extensibility. Thanks to Peter Zijlstra for fixing the lockdep warning. Thanks to Harvey Harrison for pointing out that the unlikely() was unnecessary. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2008-02-08uml: runtime host VMSPLIT detectionJeff Dike
Calculate TASK_SIZE at run-time by figuring out the host's VMSPLIT - this is needed on i386 if UML is to run on hosts with varying VMSPLITs without recompilation. TASK_SIZE is now defined in terms of a variable, task_size. This gets rid of an include of pgtable.h from processor.h, which can cause include loops. On i386, task_size is calculated early in boot by probing the address space in a binary search to figure out where the boundary between usable and non-usable memory is. This tries to make sure that a page that is considered to be in userspace is, or can be made, read-write. I'm concerned about a system-global VDSO page in kernel memory being hit and considered to be a userspace page. On x86_64, task_size is just the old value of CONFIG_TOP_ADDR. A bunch of config variable are gone now. CONFIG_TOP_ADDR is directly replaced by TASK_SIZE. NEST_LEVEL is gone since the relocation of the stubs makes it irrelevant. All the HOST_VMSPLIT stuff is gone. All references to these in arch/um/Makefile are also gone. I noticed and fixed a missing extern in os.h when adding os_get_task_size. Note: This has been revised to fix the 32-bit UML on 64-bit host bug that Miklos ran into. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08aout: mark arches that support A.OUT formatDavid Howells
Mark arches that support A.OUT format by including the following in their master Kconfig files: config ARCH_SUPPORTS_AOUT def_bool y This should also be set if the arch provides compatibility A.OUT support for an older arch, for instance x86_64 for i386 or sparc64 for sparc. I've guessed at which arches don't, based on comments in the code, however I'm sure that some of the ones I've marked as 'yes' actually should be 'no'. Signed-off-by: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: fix stub address calculationsJeff Dike
The calculation of CONFIG_STUB_CODE and CONFIG_STUB_DATA didn't take into account anything but 3G/1G and 2G/2G, leaving the other vmsplits out in the cold. I'd rather not duplicate the four known host vmsplit cases for each of these symbols. I'd also like to calculate them based on the highest userspace address. The Kconfig language seems not to allow calculation of hex constants, so I moved this to as-layout.h. CONFIG_STUB_CODE, CONFIG_STUB_DATA, and CONFIG_STUB_START are now gone. In their place are STUB_CODE, STUB_DATA, and STUB_START in as-layout.h. i386 and x86_64 seem to differ as to whether an unadorned constant is an int or a long, so I cast them to unsigned long so they can be printed consistently. However, they are also used in stub.S, where C types don't work so well. So, there are ASM_ versions of these constants for use in stub.S. I also ifdef-ed the non-asm-friendly portion of as-layout.h. With this in place, most of the rest of this patch is changing CONFIG_STUB_* to STUB_*, except in stub.S, where they are changed to ASM_STUB_*. defconfig has the old symbols deleted. I also print these addresses out in case there is any problem mapping them on the host. The two stub.S files had some trailing whitespace, so that is cleaned up here. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-03-26[PATCH] um: fix undefined reference to hweight32Akinobu Mita
Build fix for user mode linux. Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] uml: fix "reuse i386 cpu optimizations"Paolo 'Blaisorblade' Giarrusso
Remove RWSEM_GENERIC_SPINLOCK, it's now defined (only if needed) by the underlying arch/i386/Kconfig.cpu. Leave it only for x86_64. Even there, it's totally wrong, as they even have the code to support XCHG_ADD. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] uml: mark SMP on UML/x86_64 as brokenJeff Dike
Noticed by Al Viro <viro@parcelfarce.linux.theplanet.co.uk> - SMP on x86_64 is fundamentally broken due to UML's reuse of the host arch's percpu stuff. This is OK on x86, but the x86_64 pda stuff just won't work for UML. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] uml: Rename Kconfig files to be like the other archesJeff Dike
To the extent that sub-Kconfig files exist elsewhere in the tree, they are named Kconfig.foo, rather than the Kconfig_foo that UML has. This patch brings the names in line with the rest of the tree. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
