path: root/arch/um/drivers/random.c
2012-10-09um: get rid of pointless include "..." where include <...> will doAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Richard Weinberger <richard@nod.at>
2012-07-19um: remove IRQF_SAMPLE_RANDOM which is now a no-opTheodore Ts'o
With the changes in the random tree, IRQF_SAMPLE_RANDOM is now a no-op; interrupt randomness is now collected unconditionally in a very low-overhead fashion; see commit 775f4b297b. The IRQF_SAMPLE_RANDOM flag was scheduled to be removed in 2009 on the feature-removal-schedule, so this patch is preparation for the final removal of this flag. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at>
2012-03-25um: irq: Remove IRQF_DISABLEDYong Zhang
Since commit [e58aa3d2: genirq: Run irq handlers with interrupts disabled], We run all interrupt handlers with interrupts disabled and we even check and yell when an interrupt handler returns with interrupts enabled (see commit [b738a50a: genirq: Warn when handler enables interrupts]). So now this flag is a NOOP and can be removed. Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Signed-off-by: Richard Weinberger <richard@nod.at>
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2009-10-14um: Remove BKL from randomThomas Gleixner
cycle_kernel_lock() was added during the big BKL pushdown. It should ensure the serializiation against driver init code. In this case there is nothing to serialize. Remove it. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> LKML-Reference: <20091010153349.641118498@linutronix.de> Cc: Jeff Dike <jdike@addtoit.com>
2008-07-02uml-random: BKL pushdownArnd Bergmann
2008-05-13uml: style fixes in the random driverJeff Dike
Give random.c a style workover while I'm changing it. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13uml: random driver fixesJeff Dike
The random driver would essentially hang if the host's /dev/random returned -EAGAIN. There was a test of need_resched followed by a schedule inside the loop, but that didn't help and it's the wrong way to work anyway. The right way is to ask for an interrupt when there is input available from the host and handle it then rather than polling. Now, when the host's /dev/random returns -EAGAIN, the driver asks for a wakeup when there's randomness available again and sleeps. The interrupt routine just wakes up whatever processes are sleeping on host_read_wait. There is an atomic_t, host_sleep_count, which counts the number of processes waiting for randomness. When this reaches zero, the interrupt is disabled. An added complication is that async I/O notification was only recently added to /dev/random (by me), so essentially all hosts will lack it. So, we use the sigio workaround here, which is to have a separate thread poll on the descriptor and send an interrupt when there is input on it. This mechanism is activated when a process gets -EAGAIN (activating this multiple times is harmless, if a bit wasteful) and deactivated by the last process still waiting. The module name was changed from "random" to "hw_random" in order for udev to recognize it. The sigio workaround needed some changes. sigio_broken was added for cases when we know that async notification doesn't work. This is now called from maybe_sigio_broken, which deals with pts devices. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: header untanglingJeff Dike
Untangle UML headers somewhat and add some includes where they were needed explicitly, but gotten accidentally via some other header. arch/um/include/um_uaccess.h loses asm/fixmap.h because it uses no fixmap stuff and gains elf.h, because it needs FIXADDR_USER_*, and archsetjmp.h, because it needs jmp_buf. pmd_alloc_one is uninlined because it needs mm_struct, and that's inconvenient to provide in asm-um/pgtable-3level.h. elf_core_copy_fpregs is also uninlined from elf-i386.h and elf-x86_64.h, which duplicated the code anyway, to arch/um/kernel/process.c, so that the reference to current_thread doesn't pull sched.h or anything related into asm/elf.h. arch/um/sys-i386/ldt.c, arch/um/kernel/tlb.c and arch/um/kernel/skas/uaccess.c got sched.h because they dereference task_structs. Its includes of linux and asm headers got turned from "" to <>. arch/um/sys-i386/bug.c gets asm/errno.h because it needs errno constants. asm/elf-i386 gets asm/user.h because it needs user_regs_struct. asm/fixmap.h gets page.h because it needs PAGE_SIZE and PAGE_MASK and system.h for BUG_ON. asm/pgtable doesn't need sched.h. asm/processor-generic.h defined mm_segment_t, but didn't use it. So, that definition is moved to uaccess.h, which defines a bunch of mm_segment_t-related stuff. thread_info.h uses mm_segment_t, and includes uaccess.h, which causes a recursion. So, the definition is placed above the include of thread_info. in uaccess.h. thread_info.h also gets page.h because it needs PAGE_SIZE. ObCheckpatchViolationJustification - I'm not adding a typedef; I'm moving mm_segment_t from one place to another. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: rename os_{read_write}_file_k back to os_{read_write}_fileJeff Dike
Rename os_{read_write}_file_k back to os_{read_write}_file, delete the originals and their bogus infrastructure, and fix all the callers. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: start fixing os_read_file and os_write_fileJeff Dike
This patch starts the removal of a very old, very broken piece of code. This stems from the problem of passing a userspace buffer into read() or write() on the host. If that buffer had not yet been faulted in, read and write will return -EFAULT. To avoid this problem, the solution was to fault the buffer in before the system call by touching the pages that hold the buffer by doing a copy-user of a byte to each page. This is obviously bogus, but it does usually work, in tt mode, since the kernel and process are in the same address space and userspace addresses can be accessed directly in the kernel. In skas mode, where the kernel and process are in separate address spaces, it is completely bogus because the userspace address, which is invalid in the kernel, is passed into the system call instead of the corresponding physical address, which would be valid. Here, it appears that this code, on every host read() or write(), tries to fault in a random process page. This doesn't seem to cause any correctness problems, but there is a performance impact. This patch, and the ones following, result in a 10-15% performance gain on a kernel build. This code can't be immediately tossed out because when it is, you can't log in. Apparently, there is some code in the console driver which depends on this somehow. However, we can start removing it by switching the code which does I/O using kernel addresses to using plain read() and write(). This patch introduces os_read_file_k and os_write_file_k for use with kernel buffers and converts all call locations which use obvious kernel buffers to use them. These include I/O using buffers which are local variables which are on the stack or kmalloc-ed. Later patches will handle the less obvious cases, followed by a mass conversion back to the original interface. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] uml: locking commentary in the random driverJeff Dike
Comment the lack of locking. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-29[PATCH] uml: locking documentationJeff Dike
Some locking documentation and a cleanup. uml_exitcode is copied into a local before sprintf sees it, in case sprintf does anything non-atomic with it. The rest are comments about why certain globals don't need any kind of locking. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] uml: const more dataJeff Dike
Make lots of structures const in order to make it obvious that they need no locking. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] um: fix-up schedule_timeout() usageNishanth Aravamudan
Use schedule_timeout_interruptible() instead of set_current_state()/schedule_timeout() to reduce kernel size. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-28[PATCH] uml: add MOD_LICENSE to random driverPaolo 'Blaisorblade' Giarrusso
Add a MODULE_LICENSE("GPL") to the driver, remove some unused macros and add the GPL license (it's GPL-licensed anyway since it's a GPL-derivative, apart that Jeff Dike releases GPL software, in case anybody is wondering). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
