path: root/arch/um/drivers/slip_user.c
2008-05-13uml: fix build when SLOB is enabledJeff Dike
Reintroduce uml_kmalloc for the benefit of UML libc code. The previous tactic of declaring __kmalloc so it could be called directly from the libc side of the house turned out to be getting too intimate with slab, and it doesn't work with slob. So, the uml_kmalloc wrapper is back. It calls kmalloc or whatever that translates into, and libc code calls it. kfree is left alone since that still works, leaving a somewhat inconsistent API. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: tidy helper codeJeff Dike
Style fixes to arch/um/os/helper.c and tidying up the breakpoint fix a bit. helper.c gets all the usual style fixes - updated copyright all printks get severities Also - errval changes to err in helper_child fixed an obsolete comment run_helper was killing a child process which is guaranteed to be dead or dying anyway Removed the nohang and pname arguments from helper_wait and fixed the declaration and callers. nohang was used only in the slirp driver and I don't think it was needed. I think pname was a bit of overkill in putting out an error message when something goes wrong. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-17uml: stop gdb from deleting breakpoints when running UMLStanislaw Gruszka
Sometimes when UML is debugged gdb miss breakpoints. When process traced by gdb do fork, debugger remove breakpoints from child address space. There is possibility to trace more than one fork, but this not work with UML, I guess (only guess) there is a deadlock - gdb waits for UML and UML waits for gdb. When clone() is called with SIGCHLD and CLONE_VM flags, gdb see this as PTRACE_EVENT_FORK not as PTRACE_EVENT_CLONE and remove breakpoints from child and at the same time from traced process, because either have the same address space. Maybe it is possible to do fix in gdb, but I'm not sure if there is easy way to find out if traced and child processes share memory. So I do fix for UML, it simply do not call clone() with both SIGCHLD and CLONE_VM flags together. Additionally __WALL flag is used for waitpid() to assure not miss clone and normal process events. [ jdike - checkpatch fixes ] Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: network driver MTU cleanupsJeff Dike
A bunch of MTU-related cleanups in the network code. First, there is the addition of the notion of a maximally-sized packet, which is the MTU plus headers. This is used to size the skb that will receive a packet. This allows ether_adjust_skb to go away, as it was used to resize the skb after it was allocated. Since the skb passed into the low-level read routine is no longer resized, and possibly reallocated, there, they (and the write routines) don't need to get an sk_buff **. They just need the sk_buff * now. The callers of ether_adjust_skb still need to do the skb_put, so that's now inlined. The MAX_PACKET definitions in most of the drivers are gone. The set_mtu methods were all the same and did nothing, so they can be removed. The ethertap driver had a typo which doubled the size of the packet rather than adding two bytes to it. It also wasn't defining its setup_size, causing a zero-byte kmalloc and crash when the invalid pointer returned from kmalloc was dereferenced. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: network formattingJeff Dike
Style and other non-functional changes in the UML networking code, including include tidying style violations copyright updates printks getting severities userspace code calling libc directly rather than using the os_* wrappers There's also a exit path cleanup in the pcap driver. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16uml: Eliminate kernel allocator wrappersJeff Dike
UML had two wrapper procedures for kmalloc, um_kmalloc and um_kmalloc_atomic because the flag constants weren't available in userspace code. kern_constants.h had made kernel constants available for a long time, so there is no need for these wrappers any more. Rather, userspace code calls kmalloc directly with the userspace versions of the gfp flags. kmalloc isn't a real procedure, so I had to essentially copy the inline wrapper around __kmalloc. vmalloc also had its own wrapper for no good reason. This is now gone. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16uml: simplify helper stack handlingJeff Dike
run_helper and run_helper_thread had arguments which were the same in all callers. run_helper's stack_out was always NULL and run_helper_thread's stack_order was always 0. These are now gone, and the constants folded into the code. Also fixed leaks of the helper stack in the AIO and SIGIO code. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: remove page_size()Jeff Dike
userspace code used to have to call the kernelspace function page_size() in order to determine the value of the kernel's PAGE_SIZE. Since this is now available directly from kern_constants.h as UM_KERN_PAGE_SIZE, page_size() can be deleted and calls changed to use the constant. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: remove user_util.hJeff Dike
user_util.h isn't needed any more, so delete it and remove all includes of it. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: network interface hotplug error handlingJeff Dike
This fixes a number of problems associated with network interface hotplug. The userspace initialization function can fail in some cases, but the failure was never passed back to eth_configure, which proceeded with the configuration. This results in a zombie device that is present, but can't work. This is fixed by allowing the initialization routines to return an error, which is checked, and the configuration aborted on failure. eth_configure failed to check for many failures. Even when it did check, it didn't undo whatever initializations has already happened, so a present, but partially initialized and non-working device could result. It now checks everything that can fail, and bails out, undoing whatever had been done. The return value of eth_configure was always ignored, so it is now just void. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-20[PATCH] uml: split memory allocation prototypes out of user.hPaolo 'Blaisorblade' Giarrusso
user.h is too generic a header name. I've split out allocation routines from it. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] uml: const more dataJeff Dike
Make lots of structures const in order to make it obvious that they need no locking. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] uml: separate libc-dependent helper codeJeff Dike
The serial UML OS-abstraction layer patch (um/kernel dir). This moves all systemcalls from helper.c file under os-Linux dir Signed-off-by: Gennady Sharapov <Gennady.V.Sharapov@intel.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-13[PATCH] uml: slirp and slip driver cleanups and fixesJeff Dike
This patch merges a lot of duplicated code in the slip and slirp drivers, abstracts out the slip protocol, and makes the slip driver work in 2.6. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
