path: root/arch/um/drivers/stderr_console.c
2007-10-20spelling fixes: arch/um/Simon Arlott
Spelling fixes in arch/um/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-06-08uml: get declaration of simple_strtoulJeff Dike
Include linux/kernel.h wherever simple_strtoul is used. This kills a compile warning in stderr_console.c and potential ones in the other files. This also fixes a bunch of style violations in exitcode.c. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-29[PATCH] uml: locking documentationJeff Dike
Some locking documentation and a cleanup. uml_exitcode is copied into a local before sprintf sees it, in case sprintf does anything non-atomic with it. The rest are comments about why certain globals don't need any kind of locking. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30[PATCH] uml: unregister useless console when it's not neededJeff Dike
-mm in combination with an FC5 init started dying with 'stderr=1' because init didn't like the lack of /dev/console and exited. The problem was that the stderr console, which is intended to dump printk output to the terminal before the regular console is initialized, isn't a tty, and so can't make /dev/console operational. However, since it is registered first, the normal console, when it is registered, doesn't become the preferred console, and isn't attached to /dev/console. Thus, /dev/console is never operational. This patch makes the stderr console unregister itself in an initcall, which is late enough that the normal console is registered. When that happens, the normal console will become the preferred console and will be able to run /dev/console. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-08[PATCH] uml: compile fixes for gcc 4Jeff Dike
This is a bunch of compile fixes provoked by building UML with gcc 4. There are a bunch of signedness mismatches, a couple of uninitialized references, and a botched C99 structure initialization which had somehow gone unnoticed. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
