path: root/arch/um/include/skas
2008-02-05uml: delete some unused headersJeff Dike
Robert Day noticed a few unused headers in UML, so this gets rid of them. Cc: "Robert P. J. Day" <rpjday@crashcourse.ca> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: fold mmu_context_skas into mm_contextJeff Dike
This patch folds mmu_context_skas into struct mm_context, changing all users of these structures as needed. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: style fixes pass 3Jeff Dike
Formatting changes in the files which have been changed in the course of folding foo_skas functions into their callers. These include: copyright updates header file trimming style fixes adding severity to printks These changes should be entirely non-functional. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: remove code made redundant by CHOOSE_MODE removalJeff Dike
This patch makes a number of simplifications enabled by the removal of CHOOSE_MODE. There were lots of functions that looked like int foo(args){ foo_skas(args); } The bodies of foo_skas are now folded into foo, and their declarations (and sometimes entire header files) are deleted. In addition, the union uml_pt_regs, which was a union between the tt and skas register formats, is now a struct, with the tt-mode arm of the union being removed. It turns out that usr2_handler was unused, so it is gone. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: throw out CHOOSE_MODEJeff Dike
The next stage after removing code which depends on CONFIG_MODE_TT is removing the CHOOSE_MODE abstraction, which provided both compile-time and run-time branching to either tt-mode or skas-mode code. This patch removes choose-mode.h and all inclusions of it, and replaces all CHOOSE_MODE invocations with the skas branch. This leaves a number of trivial functions which will be dealt with in a later patch. There are some changes in the uaccess and tls support which go somewhat beyond this and eliminate some of the now-redundant functions. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: physmem code tidyingJeff Dike
Tidying of the UML physical memory system. These are mostly style fixes, however the includes were cleaned as well. This uncovered a need for mem_user.h to be included in mode_kern_skas.h. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: stop saving process FP stateJeff Dike
Throw out a lot of code dealing with saving and restoring floating-point state. In skas mode, where processes run in a restoring floating-point state on kernel entry and exit is pointless. This eliminates most of arch/um/os-Linux/sys-{i386,x86_64}/registers.c. Most of what remained is now arch-indpendent, and can be moved up to arch/um/os-Linux/registers.c. Both arches need the jmp_buf accessor get_thread_reg, and i386 needs {save,restore}_fp_regs because it cheats during sigreturn by getting the fp state using ptrace rather than copying it out of the process sigcontext. After this, it turns out that arch/um/include/skas/mode-skas.h is almost completely unneeded. The declarations in it are variables which either don't exist or which don't have global scope. The one exception is kill_off_processes_skas. If that's removed, this header can be deleted. This uncovered a bug in user.h, which wasn't correctly making sure that a size_t definition was available to both userspace and kernelspace files. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: speed page fault pathJeff Dike
Give the page fault code a specialized path. There is only one page to look at, so there's no point in going into the general page table walking code. There's only going to be one host operation, so there are no opportunities for merging. So, we go straight to the pte we want, figure out what needs doing, and do it. While I was in here, I fixed the wart where the address passed to unmap was a void *, but an unsigned long to map and protect. This gives me just under 10% on a kernel build. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-04Remove all inclusions of <linux/config.h>Dave Jones
kbuild explicitly includes this at build time. Signed-off-by: Dave Jones <davej@redhat.com>
2006-09-27[PATCH] uml: thread creation tidyingJeff Dike
fork on UML has always somewhat subtle. The underlying cause has been the need to initialize a stack for the new process. The only portable way to initialize a new stack is to set it as the alternate signal stack and take a signal. The signal handler does whatever initialization is needed and jumps back to the original stack, where the fork processing is finished. The basic context switching mechanism is a jmp_buf for each process. You switch to a new process by longjmping to its jmp_buf. Now that UML has its own implementation of setjmp and longjmp, and I can poke around inside a jmp_buf without fear that libc will change the structure, a much simpler mechanism is possible. The jmpbuf can simply be initialized by hand. This eliminates - the need to set up and remove the alternate signal stack sending and handling a signal the signal blocking needed around the stack switching, since there is no stack switching setting up the jmp_buf needed to jump back to the original stack after the new one is set up In addition, since jmp_buf is now defined by UML, and not by libc, it can be embedded in the thread struct. This makes it unnecessary to have it exist on the stack, where it used to be. It also simplifies interfaces, since the switch jmp_buf used to be a void * inside the thread struct, and functions which took it as an argument needed to define a jmp_buf variable and assign it from the void *. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: fix static binary segfaultJeff Dike
When UML is built as a static binary, it segfaults when run. The reason is that a memory hole that is present in dynamic binaries isn't there in static binaries, and it contains essential stuff. This fix removes the code which maps some anonymous memory into that hole and cleans up some related code. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: clean up address space limits codeTyler
I was looking at the code of the UML and more precisely at the functions set_task_sizes_tt and set_task_sizes_skas. I noticed that these 2 functions take a paramater (arg) which is not used : the function is always called with the value 0. I suppose that this value might change in the future (or even can be configured), so I added a constant in mem_user.h file. Also, I rounded CONFIG_HOST_TASk_SIZE to a 4M. Signed-off-by: Tyler <tyler@agat.net> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] uml: oS header cleanupsJeff Dike
This rearranges the OS declarations by moving some declarations into os.h. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] uml: move libc-dependent skas process handlingGennady Sharapov
The serial UML OS-abstraction layer patch (um/kernel/skas dir). This moves all systemcalls from skas/process.c file under os-Linux dir and join skas/process.c and skas/process_kern.c files. Signed-off-by: Gennady Sharapov <gennady.v.sharapov@intel.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] uml: move libc-dependent skas memory mapping codeGennady Sharapov
The serial UML OS-abstraction layer patch (um/kernel/skas dir). This moves all systemcalls from skas/mem_user.c file under os-Linux dir and join skas/mem_user.c and skas/mem.c files. Signed-off-by: Gennady Sharapov <gennady.v.sharapov@intel.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] uml: move headers to arch/um/includeGennady Sharapov
The serial UML OS-abstraction layer patch (um/kernel dir). This moves skas headers to arch/um/include. Signed-off-by: Gennady Sharapov <Gennady.V.Sharapov@intel.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
