path: root/arch/um/kernel/Makefile
2007-02-11[PATCH] uml: delete unused fileJeff Dike
It turns out that resource.c isn't needed. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-27[PATCH] uml: file renamingJeff Dike
Move some foo_kern.c files to foo.c now that the old foo.c files are out of the way. Also cleaned up some whitespace and an emacs formatting comment. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: move _kern.c filesJeff Dike
Move most *_kern.c files in arch/um/kernel to *.c. This makes UML somewhat more closely resemble the other arches. [akpm@osdl.org: use the new INTF_* flags] Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: remove syscall debuggingJeff Dike
Eliminate an unused debug option. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] uml: move tty logging to os-LinuxJeff Dike
The serial UML OS-abstraction layer patch (um/kernel dir). This moves all systemcalls from tty_log.c file under os-Linux dir Signed-off-by: Gennady Sharapov <Gennady.V.Sharapov@intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] uml: move sigio_user.c to os-Linux/sigio.cJeff Dike
The serial UML OS-abstraction layer patch (um/kernel dir). This moves sigio_user.c to os-Linux dir Signed-off-by: Gennady Sharapov <Gennady.V.Sharapov@intel.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] uml: merge irq_user.c and irq.cJeff Dike
The serial UML OS-abstraction layer patch (um/kernel dir). This joins irq_user.c and irq.c files. Signed-off-by: Gennady Sharapov <Gennady.V.Sharapov@intel.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] uml: move libc-dependent time codeGennady Sharapov
The serial UML OS-abstraction layer patch (um/kernel dir). This moves all systemcalls from time.c file under os-Linux dir and joins time.c and tine_kernel.c files Signed-off-by: Gennady Sharapov <Gennady.V.Sharapov@intel.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] uml: move libc-dependent utility proceduresGennady Sharapov
The serial UML OS-abstraction layer patch (um/kernel dir). This moves all systemcalls from user_util.c file under os-Linux dir Signed-off-by: Gennady Sharapov <Gennady.V.Sharapov@intel.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] uml: merge trap_user.c and trap_kern.cGennady Sharapov
The serial UML OS-abstraction layer patch (um/kernel dir). This joins trap_user.c and trap_kernel.c files. Signed-off-by: Gennady Sharapov <Gennady.V.Sharapov@intel.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] uml: move libc-dependent code from signal_user.cGennady Sharapov
The serial UML OS-abstraction layer patch (um/kernel dir). This moves all systemcalls from signal_user.c file under os-Linux dir Signed-off-by: Gennady Sharapov <Gennady.V.Sharapov@intel.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] uml: separate libc-dependent umid codeJeff Dike
I reworked Gennady's umid OS abstraction patch because the code shouldn't be moved entirely to os. As it turns out, I moved most of it anyway. This patch is the minimal one needed to move the code and have it work. It turns out that the concept of the umid is OS-independent, but almost everything else about the implementation is OS-dependent. This is code movement without cleanup - a follow-on patch tidies everything up without shuffling code around. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] uml: separate libc-dependent helper codeJeff Dike
The serial UML OS-abstraction layer patch (um/kernel dir). This moves all systemcalls from helper.c file under os-Linux dir Signed-off-by: Gennady Sharapov <Gennady.V.Sharapov@intel.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] uml: separate libc-dependent early initializationJeff Dike
The serial UML OS-abstraction layer patch (um/kernel dir). This moves all systemcalls from main.c file under os-Linux dir and joins mem.c and um_arch.c files. Signed-off-by: Gennady Sharapov <Gennady.V.Sharapov@intel.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] uml: separate libc-dependent uaccess codeGennady Sharapov
The serial UML OS-abstraction layer patch (um/kernel dir). This moves all systemcalls from uaccess_user.c file under os-Linux dir Signed-off-by: Gennady Sharapov <Gennady.V.Sharapov@intel.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-17[PATCH] uml: merge mem_user.c and mem.cJeff Dike
The serial UML OS-abstraction layer patch (um/kernel dir). This joins mem_user.c and mem.c files. Signed-off-by: Gennady Sharapov <Gennady.V.Sharapov@intel.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-17[PATCH] uml: move libc code out of mem_user.c and tempfile.cJeff Dike
The serial UML OS-abstraction layer patch (um/kernel dir). This moves all system calls from mem_user.c and tempfile.c files under os-Linux dir. Signed-off-by: Gennady Sharapov <Gennady.V.Sharapov@intel.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] uml: move libc-dependent startup and signal codeGennady Sharapov
The serial UML OS-abstraction layer patch (um/kernel dir). This moves all systemcalls from process.c file under os-Linux dir and join process.c and process_kern.c files. Signed-off-by: Gennady Sharapov <gennady.v.sharapov@intel.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] uml: system call path cleanupJeff Dike
This merges two sets of files which had no business being split apart in the first place. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-20[PATCH] uml: initrd cleanupJeff Dike
The serial UML OS-abstraction layer patch (um/kernel dir). This moves all systemcalls from initrd_user.c file under os-Linux dir and join initrd_user.c and initrd_kern.c files in new file initrd.c Signed-off-by: Gennady Sharapov <Gennady.V.Sharapov@intel.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-06[PATCH] uml: Makefile cleanupJeff Dike
This eliminates some stuff from arch/um/kernel/Makefile which refers to a file which has long since been deleted. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] uml: s390 preparation, checksumming done in arch codeBodo Stroesser
Checksum handling largely depends on the subarch. Thus, I renamed i386 arch_csum_partial in arch/um/sys-i386/checksum.S back to csum_partial, removed csum_partial from arch/um/kernel/checksum.c and shifted EXPORT_SYMBOL(csum_partial) to arch/um/sys-i386/ksyms.c. Then, csum_partial_copy_to and csum_partial_copy_from were shifted from arch/um/kernel/checksum.c to arch/um/include/sysdep-i386/checksum.h and inserted in the calling functions csum_partial_copy_from_user() and csum_and_copy_to_user(). Now, arch/um/kernel/checksum.c is empty and removed. Signed-off-by: Bodo Stroesser <bstroesser@fujitsu-siemens.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] uml: include the linker script rather than symlink itAl Viro
Make vmlinux.lds.S include appopriate script instead of playing games with symlinks. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] uml kbuild: avoid useless rebuildsPaolo 'Blaisorblade' Giarrusso
- Fix some problems with usage of $(targets) (sometimes missing, sometimes used badly) that trigger partial rebuilds when doing a rebuild. - At that purpose, also factor out some common code for symlinks creation. - Fix a x86-64 build warning, caused by -L/usr/lib, which is anyway useless, and invalid in the x86-64 case. Tested on x86_64 and x86. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] uml: fix syscall table by including $(SUBARCH)'s one, for i386Paolo 'Blaisorblade' Giarrusso
Split the i386 entry.S files into entry.S and syscall_table.S which is included in the previous one (so actually there is no difference between them) and use the syscall_table.S in the UML build, instead of tracking by hand the syscall table changes (which is inherently error-prone). We must only insert the right #defines to inject the changes we need from the i386 syscall table (for instance some different function names); also, we don't implement some i386 syscalls, as ioperm(), nor some TLS-related ones (yet to provide). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] uml: workaround old problematic sed behaviourRob Landley
Old versions of sed from 1998 (predating the first release of gcc 2.95, but still in use by debian stable) don't understand the single-line version of the sed append command. Since newer versions of sed still understand the... ahem, "vintage" form of the command, change our code to use that. Signed-off-by: Rob Landley <rob@landley.net> Acked-by: Ian McDonald <imcdnzl@gmail.com> Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
