When doing an nmi backtrace of many cores, most of which are idle, the
output is a little overwhelming and very uninformative. Suppress
messages for cpus that are idling when they are interrupted and just
emit one line, "NMI backtrace for N skipped: idling at pc 0xNNN".
We do this by grouping all the cpuidle code together into a new
.cpuidle.text section, and then checking the address of the interrupted
PC to see if it lies within that section.
This commit suitably tags x86 and tile idle routines, and only adds in
the minimal framework for other architectures.
Link: http://lkml.kernel.org/r/1472487169-14923-5-git-send-email-cmetcalf@mellanox.com
Signed-off-by: Chris Metcalf <cmetcalf@mellanox.com>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Tested-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Tested-by: Daniel Thompson <daniel.thompson@linaro.org> [arm]
Tested-by: Petr Mladek <pmladek@suse.com>
Cc: Aaron Tomlin <atomlin@redhat.com>
Cc: Peter Zijlstra (Intel) <peterz@infradead.org>
Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net>
Normalize global variables exported by vmlinux.lds to conform usage
guidelines from include/asm-generic/sections.h.
1) Use _text to mark the start of the kernel image including the head
text, and _stext to mark the start of the .text section.
2) Export mandatory global variables __bss_stop.
3) Adjust __init_begin and __init_end to avoid acrossing .text and
.data sections.
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Weinberger <richard@nod.at>
Signed-off-by: Richard Weinberger <richard@nod.at>
With glibc 2.11 or later that was built with --enable-multi-arch, the UML
link fails with undefined references to __rel_iplt_start and similar
symbols. In recent binutils, the default linker script defines these
symbols (see ld --verbose). Fix the UML linker scripts to match the new
defaults for these sections.
Signed-off-by: Roland McGrath <roland@redhat.com>
Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com>
Signed-off-by: Tim Abbott <tabbott@ksplice.com>
Cc: user-mode-linux-devel@lists.sourceforge.net
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Discarded sections in different archs share some commonality but have
considerable differences. This led to linker script for each arch
implementing its own /DISCARD/ definition, which makes maintaining
tedious and adding new entries error-prone.
This patch makes all linker scripts to move discard definitions to the
end of the linker script and use the common DISCARDS macro. As ld
uses the first matching section definition, archs can include default
discarded sections by including them earlier in the linker script.
ia64 is notable because it first throws away some ia64 specific
subsections and then include the rest of the sections into the final
image, so those sections must be discarded before the inclusion.
defconfig compile tested for x86, x86-64, powerpc, powerpc64, ia64,
alpha, sparc, sparc64 and s390. Michal Simek tested microblaze.
Acked-by: Paul Mundt <lethal@linux-sh.org>
Tested-by: Michal Simek <monstr@monstr.eu>
Cc: microblaze-uclinux@itee.uq.edu.au
x86 throws away .discard section but no other archs do. Also,
.discard is not thrown away while linking modules. Make every arch
and module linking throw it away. This will be used to define dummy
variables for percpu declarations and definitions.
This patch is based on Ivan Kokshaysky's alpha percpu patch.
[ Impact: always throw away everything in .discard ]
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
Cc: Bryan Wu <cooloney@kernel.org>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Chris Zankel <chris@zankel.net>
This patch includes page.h header into linker scripts that allow us to
use PAGE_SIZE macro instead of numeric constant.
To be able to include page.h into linker scripts page.h is needed for
some modification - i.e. we need to use __ASSEMBLY__ and _AC macro
[jdike@linux.intel.com - fixed conflict with as-layout.h]
Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com>
Signed-off-by: Jeff Dike <jdike@linux.intel.com>
Cc: WANG Cong <xiyou.wangcong@gmail.com>
This patch consolidate all definitions of .init.text, .init.data
and .exit.text, .exit.data section definitions in
the generic vmlinux.lds.h.
This is a preparational patch - alone it does not buy
us much good.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
This patchset throws out tt mode, which has been non-functional for a while.
This is done in phases, interspersed with code cleanups on the affected files.
The removal is done as follows:
remove all code, config options, and files which depend on
CONFIG_MODE_TT
get rid of the CHOOSE_MODE macro, which decided whether to
call tt-mode or skas-mode code, and replace invocations with their
skas portions
replace all now-trivial procedures with their skas equivalents
There are now a bunch of now-redundant pieces of data structures, including
mode-specific pieces of the thread structure, pt_regs, and mm_context. These
are all replaced with their skas-specific contents.
As part of the ongoing style compliance project, I made a style pass over all
files that were changed. There are three such patches, one for each phase,
covering the files affected by that phase but no later ones.
I noticed that we weren't freeing the LDT state associated with a process when
it exited, so that's fixed in one of the later patches.
The last patch is a tidying patch which I've had for a while, but which caused
inexplicable crashes under tt mode. Since that is no longer a problem, this
can now go in.
This patch:
Start getting rid of tt mode support.
This patch throws out CONFIG_MODE_TT and all config options, code, and files
which depend on it.
CONFIG_MODE_SKAS is gone and everything that depends on it is included
unconditionally.
The few changed lines are in re-written Kconfig help, lines which needed
something skas-related removed from them, and a few more which weren't
strictly deletions.
Fix a class of bugs in the UML linker scripts which caused section boundary
variables to sometimes not line up with their sections.
With this consolidation we can now modify the .data
section definition in one spot for all archs.
Move definition of .text section to asm-generic.
Add a separate IRQ stack. This differs from i386 in having the entire
interrupt run on a separate stack rather than starting on the normal kernel
stack and switching over once some preparation has been done. The underlying
mechanism, is of course, sigaltstack.
Another difference is that interrupts that happen in userspace are handled on
the normal kernel stack. These cause a wait wakeup instead of a signal
delivery so there is no point in trying to switch stacks for these. There's
no other stuff on the stack, so there is no extra stack consumption.
This quirk makes it possible to have the entire interrupt run on a separate
stack - process preemption (and calls to schedule()) happens on a normal
kernel stack. If we enable CONFIG_PREEMPT, this will need to be rethought.
The IRQ stack for CPU 0 is declared in the same way as the initial kernel
stack. IRQ stacks for other CPUs will be allocated dynamically.
An extra field was added to the thread_info structure. When the active
thread_info is copied to the IRQ stack, the real_thread field points back to
the original stack. This makes it easy to tell where to copy the thread_info
struct back to when the interrupt is finished. It also serves as a marker of
a nested interrupt. It is NULL for the first interrupt on the stack, and
non-NULL for any nested interrupts.
Care is taken to behave correctly if a second interrupt comes in when the
thread_info structure is being set up or taken down. I could just disable
interrupts here, but I don't feel like giving up any of the performance gained
by not flipping signals on and off.
If an interrupt comes in during these critical periods, the handler can't run
because it has no idea what shape the stack is in. So, it sets a bit for its
signal in a global mask and returns. The outer handler will deal with this
signal itself.
Atomicity is had with xchg. A nested interrupt that needs to bail out will
xchg its signal mask into pending_mask and repeat in case yet another
interrupt hit at the same time, until the mask stabilizes.
The outermost interrupt will set up the thread_info and xchg a zero into
pending_mask when it is done. At this point, nested interrupts will look at
->real_thread and see that no setup needs to be done. They can just continue
normally.
Similar care needs to be taken when exiting the outer handler. If another
interrupt comes in while it is copying the thread_info, it will drop a bit
into pending_mask. The outer handler will check this and if it is non-zero,
will loop, set up the stack again, and handle the interrupt.
Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
kallsyms now refers to addresses as '_text + 0xADDRESS', rather than just
'0xADDRESS', so we need to define _text.
Signed-off-by: Jeff Dike <jdike@addtoit.com>
The latest toolchains can produce a new ELF section in DSOs and
dynamically-linked executables. The new section ".gnu.hash" replaces
".hash", and allows for more efficient runtime symbol lookups by the
dynamic linker. The new ld option --hash-style={sysv|gnu|both} controls
whether to produce the old ".hash", the new ".gnu.hash", or both. In some
new systems such as Fedora Core 6, gcc by default passes --hash-style=gnu
to the linker, so that a standard invocation of "gcc -shared" results in
producing a DSO with only ".gnu.hash". The new ".gnu.hash" sections need
to be dealt with the same way as ".hash" sections in all respects; only the
dynamic linker cares about their contents. To work with older dynamic
linkers (i.e. preexisting releases of glibc), a binary must have the old
".hash" section. The --hash-style=both option produces binaries that a new
dynamic linker can use more efficiently, but an old dynamic linker can
still handle.
The new section runs afoul of the custom linker scripts used to build vDSO
images for the kernel. On ia64, the failure mode for this is a boot-time
panic because the vDSO's PT_IA_64_UNWIND segment winds up ill-formed.
This patch addresses the problem in two ways.
First, it mentions ".gnu.hash" in all the linker scripts alongside ".hash".
This produces correct vDSO images with --hash-style=sysv (or old tools),
with --hash-style=gnu, or with --hash-style=both.
Second, it passes the --hash-style=sysv option when building the vDSO
images, so that ".gnu.hash" is not actually produced. This is the most
conservative choice for compatibility with any old userland. There is some
concern that some ancient glibc builds (though not any known old production
system) might choke on --hash-style=both binaries. The optimizations
provided by the new style of hash section do not really matter for a DSO
with a tiny number of symbols, as the vDSO has. If someone wants to use
=gnu or =both for their vDSO builds and worry less about that
compatibility, just change the option and the linker script changes will
make any choice work fine.
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Andi Kleen <ak@muc.de>
Inside the linker script, insert the code for DWARF debug info sections. This
may help GDB'ing a Uml binary. Actually, it seems that ld is able to guess
what I added correctly, but normal linker scripts include this section so it
should be correct anyway adding it.
On request by Sam Ravnborg <sam@ravnborg.org>, I've added it to
asm-generic/vmlinux.lds.s. I've also moved there the stabs debug section,
used the new macro in i386 linker script and added DWARF debug section to
that.
In the truth, I've not been able to verify the difference in GDB behaviour
after this change (I've seen large improvements with another patch). This
may depend on my binutils version, older one may have worse defaults.
However, this section is present in normal linker script, so add it at
least for the sake of cleanness.
Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
UML has had two modes of operation - an insecure, slow mode (tt mode) in
which the kernel is mapped into every process address space which requires
no host kernel modifications, and a secure, faster mode (skas mode) in
which the UML kernel is in a separate host address space, which requires a
patch to the host kernel.
This patch implements something very close to skas mode for hosts which
don't support skas - I'm calling this skas0. It provides the security of
the skas host patch, and some of the performance gains.
The two main things that are provided by the skas patch, /proc/mm and
PTRACE_FAULTINFO, are implemented in a way that require no host patch.
For the remote address space changing stuff (mmap, munmap, and mprotect),
we set aside two pages in the process above its stack, one of which
contains a little bit of code which can call mmap et al.
To update the address space, the system call information (system call
number and arguments) are written to the stub page above the code. The
%esp is set to the beginning of the data, the %eip is set the the start of
the stub, and it repeatedly pops the information into its registers and
makes the system call until it sees a system call number of zero. This is
to amortize the cost of the context switch across multiple address space
updates.
When the updates are done, it SIGSTOPs itself, and the kernel process
continues what it was doing.
For a PTRACE_FAULTINFO replacement, we set up a SIGSEGV handler in the
child, and let it handle segfaults rather than nullifying them. The
handler is in the same page as the mmap stub. The second page is used as
the stack. The handler reads cr2 and err from the sigcontext, sticks them
at the base of the stack in a faultinfo struct, and SIGSTOPs itself. The
kernel then reads the faultinfo and handles the fault.
A complication on x86_64 is that this involves resetting the registers to
the segfault values when the process is inside the kill system call. This
breaks on x86_64 because %rcx will contain %rip because you tell SYSRET
where to return to by putting the value in %rcx. So, this corrupts $rcx on
return from the segfault. To work around this, I added an
arch_finish_segv, which on x86 does nothing, but which on x86_64 ptraces
the child back through the sigreturn. This causes %rcx to be restored by
sigreturn and avoids the corruption. Ultimately, I think I will replace
this with the trick of having it send itself a blocked signal which will be
unblocked by the sigreturn. This will allow it to be stopped just after
the sigreturn, and PTRACE_SYSCALLed without all the back-and-forth of
PTRACE_SYSCALLing it through sigreturn.
This runs on a stock host, so theoretically (and hopefully), tt mode isn't
needed any more. We need to make sure that this is better in every way
than tt mode, though. I'm concerned about the speed of address space
updates and page fault handling, since they involve extra round-trips to
the child. We can amortize the round-trip cost for large address space
updates by writing all of the operations to the data page and having the
child execute them all at the same time. This will help fork and exec, but
not page faults, since they involve only one page.
I can't think of any way to help page faults, except to add something like
PTRACE_FAULTINFO to the host. There is PTRACE_SIGINFO, but UML doesn't use
siginfo for SIGSEGV (or anything else) because there isn't enough
information in the siginfo struct to handle page faults (the faulting
operation type is missing). Adding that would make PTRACE_SIGINFO a usable
equivalent to PTRACE_FAULTINFO.
As for the code itself:
- The system call stub is in arch/um/kernel/sys-$(SUBARCH)/stub.S. It is
put in its own section of the binary along with stub_segv_handler in
arch/um/kernel/skas/process.c. This is manipulated with run_syscall_stub
in arch/um/kernel/skas/mem_user.c. syscall_stub will execute any system
call at all, but it's only used for mmap, munmap, and mprotect.
- The x86_64 stub calls sigreturn by hand rather than allowing the normal
sigreturn to happen, because the normal sigreturn is a SA_RESTORER in
UML's address space provided by libc. Needless to say, this is not
available in the child's address space. Also, it does a couple of odd
pops before that which restore the stack to the state it was in at the
time the signal handler was called.
- There is a new field in the arch mmu_context, which is now a union.
This is the pid to be manipulated rather than the /proc/mm file
descriptor. Code which deals with this now checks proc_mm to see whether
it should use the usual skas code or the new code.
- userspace_tramp is now used to create a new host process for every UML
process, rather than one per UML processor. It checks proc_mm and
ptrace_faultinfo to decide whether to map in the pages above its stack.
- start_userspace now makes CLONE_VM conditional on proc_mm since we need
separate address spaces now.
- switch_mm_skas now just sets userspace_pid[0] to the new pid rather
than PTRACE_SWITCH_MM. There is an addition to userspace which updates
its idea of the pid being manipulated each time around the loop. This is
important on exec, when the pid will change underneath userspace().
- The stub page has a pte, but it can't be mapped in using tlb_flush
because it is part of tlb_flush. This is why it's required for it to be
mapped in by userspace_tramp.
Other random things:
- The stub section in uml.lds.S is page aligned. This page is written
out to the backing vm file in setup_physmem because it is mapped from
there into user processes.
- There's some confusion with TASK_SIZE now that there are a couple of
extra pages that the process can't use. TASK_SIZE is considered by the
elf code to be the usable process memory, which is reasonable, so it is
decreased by two pages. This confuses the definition of
USER_PGDS_IN_LAST_PML4, making it too small because of the rounding down
of the uneven division. So we round it to the nearest PGDIR_SIZE rather
than the lower one.
- I added a missing PT_SYSCALL_ARG6_OFFSET macro.
- um_mmu.h was made into a userspace-usable file.
- proc_mm and ptrace_faultinfo are globals which say whether the host
supports these features.
- There is a bad interaction between the mm.nr_ptes check at the end of
exit_mmap, stack randomization, and skas0. exit_mmap will stop freeing
pages at the PGDIR_SIZE boundary after the last vma. If the stack isn't
on the last page table page, the last pte page won't be freed, as it
should be since the stub ptes are there, and exit_mmap will BUG because
there is an unfreed page. To get around this, TASK_SIZE is set to the
next lowest PGDIR_SIZE boundary and mm->nr_ptes is decremented after the
calls to init_stub_pte. This ensures that we know the process stack (and
all other process mappings) will be below the top page table page, and
thus we know that mm->nr_ptes will be one too many, and can be
decremented.
Things that need fixing:
- We may need better assurrences that the stub code is PIC.
- The stub pte is set up in init_new_context_skas.
- alloc_pgdir is probably the right place.
infrastructure for it.
Let it rip!
